path: root/sound/pci/intel8x0m.c
2006-01-03[ALSA] Optimize for config without PROC_FS (pci drivers)Takashi Iwai
Optimize the code when compiled without CONFIG_PROC_FS for some pci drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] intel8x0 - Fix PM supportTakashi Iwai
Modules: Intel8x0 driver,Intel8x0-modem driver Fix PM support on Intel8x0 and modem drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI Intel8x0Takashi Iwai
Modules: Intel8x0 driver,Intel8x0-modem driver Remove xxx_t typedefs from the PCI Intel8x0 and modem drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] intel8x0 - Clean up delay functionTakashi Iwai
Modules: Intel8x0 driver,Intel8x0-modem driver Remove superfluous delay macro. Call appropriate functions directly. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-10[PATCH] PCI: removed unneeded .owner field from struct pci_driverGreg Kroah-Hartman
2005-11-04[ALSA] Fix schedule_timeout usageNishanth Aravamudan
Use schedule_timeout_{,un}interruptible() instead of set_current_state()/schedule_timeout() to reduce kernel size. Also use human-time conversion functions instead of hard-coded division to avoid rounding issues. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Add missing KERN_* suffix to printkTakashi Iwai
Add missing KERN_* suffix to printk. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Fix the type of enable module optionTakashi Iwai
Fix the type of enable module option to bool. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Sasha Khapyorsky: My email address is changed, there is update.Sasha Khapyorsky
Modules: Intel8x0-modem driver,VIA82xx-modem driver,HDA Codec driver Signed-off-by: Sasha Khapyorsky <sashakh@alsa-project.org> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2005-11-04[ALSA] Add dummy obsoleted module options for backward compatibilityTakashi Iwai
Added dummay obsoleted module options for backward compatibility (to reduce possible bugzilla entries :) Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] highlanderize motherboard AC97/HDA driversClemens Ladisch
Remove the code for supporting eight cards from the integrated controller drivers because There Can Be Only One controller of each type per mainboard. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-11-04[ALSA] Removing obsolete AC97_SHARED_TYPESSasha Khapyorsky
This patch cleans last ac97 audio/modem codec interception in initialization procedures (ac97_mixer_new()) and removes obsolete SHARED_TYPE 'locking' which prevents from AMC codecs to function correctly. Signed-off-by: Sasha Khapyorsky <sashak@smlink.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] dev_class=SNDRV_PCM_CLASS_MODEM for modem PCMsSasha Khapyorsky
dev_class=SNDRV_PCM_CLASS_MODEM for all supported softmodem PCMs Signed-off-by: Sasha Khapyorsky <sashak@smlink.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] set owner field in struct pci_driverClemens Ladisch
AD1889 driver,ALS4000 driver,ATIIXP driver,ATIIXP-modem driver AZT3328 driver,BT87x driver,CMIPCI driver,CS4281 driver ENS1370/1+ driver,ES1938 driver,ES1968 driver,FM801 driver Intel8x0 driver,Intel8x0-modem driver,Maestro3 driver,RME32 driver RME96 driver,SonicVibes driver,VIA82xx driver,VIA82xx-modem driver ALI5451 driver,au88x0 driver,CS46xx driver,EMU10K1/EMU10K2 driver HDA Intel driver,ICE1712 driver,ICE1724 driver,KORG1212 driver MIXART driver,NM256 driver,RME HDSP driver,RME9652 driver Trident driver,Digigram VX222 driver,YMFPCI driver Set the module owner field in each driver's struct pci_driver to get the driver symlink in the sysfs device directory. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-09-12[ALSA] Replace with kzalloc() - pci stuffTakashi Iwai
AD1889 driver,ATIIXP driver,ATIIXP-modem driver,AZT3328 driver BT87x driver,CMIPCI driver,CS4281 driver,ENS1370/1+ driver ES1938 driver,ES1968 driver,FM801 driver,Intel8x0 driver Intel8x0-modem driver,Maestro3 driver,SonicVibes driver,VIA82xx driver VIA82xx-modem driver,AC97 Codec,AK4531 codec,au88x0 driver CA0106 driver,CS46xx driver,EMU10K1/EMU10K2 driver,HDA Codec driver HDA generic driver,HDA Intel driver,ICE1712 driver,ICE1724 driver KORG1212 driver,MIXART driver,NM256 driver,Trident driver,YMFPCI driver Replace kcalloc(1,..) with kzalloc(). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] Remove superfluous PCI ID definitionsTakashi Iwai
CS46xx driver,EMU10K1/EMU10K2 driver,PCM Midlevel,Trident driver YMFPCI driver,BT87x driver,CMIPCI driver,CS4281 driver ENS1370/1+ driver,ES1938 driver,ES1968 driver,Intel8x0 driver Intel8x0-modem driver,Maestro3 driver,RME32 driver,RME96 driver SonicVibes driver,VIA82xx driver,ALI5451 driver,ICE1712 driver ICE1724 driver,NM256 driver,RME HDSP driver,RME9652 driver Remove superfluous PCI ID definitions. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-06-22[ALSA] PCI modem drivers updateSasha Khapyorsky
ATIIXP-modem driver,Intel8x0-modem driver,VIA82xx-modem driver Modem drivers (atiixp-modem, intel8x0m, via82xx-modem) migration for using MC97 generic modem mixer for off-hook operation. Signed-off-by: Sasha Khapyorsky <sashak@smlink.com> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2005-05-29[ALSA] Replace pci_module_init() with pci_register_driver()Takashi Iwai
Documentation,ALS4000 driver,ATIIXP driver,ATIIXP-modem driver AZT3328 driver,BT87x driver,CMIPCI driver,CS4281 driver ENS1370/1+ driver,ES1938 driver,ES1968 driver,FM801 driver Intel8x0 driver,Intel8x0-modem driver,Maestro3 driver,RME32 driver RME96 driver,SonicVibes driver,VIA82xx driver,VIA82xx-modem driver ALI5451 driver,au88x0 driver,CA0106 driver,CS46xx driver EMU10K1/EMU10K2 driver,HDA Intel driver,ICE1712 driver,ICE1724 driver KORG1212 driver,MIXART driver,NM256 driver,RME HDSP driver RME9652 driver,Trident driver,Digigram VX222 driver,YMFPCI driver Replace the obsolete pci_module_init() with pci_register_driver(). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-05-29[ALSA] Fix 'semaphore is not ready' problem with snd-intel8x0mSasha Khapyorsky
Intel8x0-modem driver With some intel based ac97 modems codec access semaphore is not cleared after 0x54 AC97 register (GPIO_STATUS) reads. This may causes problems with newly applied modem mixer (Off-hook switch) and in other cases. Signed-off-by: Sasha Khapyorsky <sashak@smlink.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
