path: root/sound/pci/ice1712/se.c
2008-01-31[ALSA] ice1712, ice1724 - Code clean upTakashi Iwai
Clean up ice1712/ice1724 codes. The board-specific data is allocated locally in each code instead of having an ungly union in struct ice1712. Also, fix coding issues in prodigy_hifi.c. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] ice1724 - Clean up ctl callbacks in se.cTakashi Iwai
Clean up ctl callbacks of SE-200PCI driver. Also make sure to check the value ranges. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] ice1724 - Add support of Onkyo SE-90PCI and SE-200PCIShin-ya Okada
Added the support for Onkyo SE-90PCI and SE-200PCI boards. Signed-off-by: Shin-ya Okada <sh_okada at d4.dion.ne.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
