CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Include linux/io.h in ice1712.h since inb() and outb() are used in
inline functions there. Remove the redundant inclusion of that file
in other places at the same time.
Inspired by Alexander Beregalov's patches for wtm and aureon.c,
I decided to run checkpatch on some more files. After some work
checkpatch.pl-0.23 --no-tree --file --strict <file> reports
0 errors, 0 warnings, 0 checks, n lines checked for:
phase.c
phase.h
juli.c (1 check about unused code, maybe we should comment it)
juli.h (no changes necessary)
In other files I have just fixed // comments and long lines along the
way (but not all of them), more coming up.
Signed-off-by: Vedran Miletic <rivanvx@gmail.com>
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
Even though MIDI was fixed on ice1724 chips a while ago, it wasn't yet
enabled for some cards as it didn't get enough testing. This was tested
with MIDI keyboard on PHASE 22 and with looping back output to input and
it works stable, so it's safe to enable it.
Besides this, there are some more minor fixes, not exactly user visible:
* added info about PHASE 28 (collected, as I don't have a card)
* added info about TS22PCI and new revisions of PHASE 22
* disable 192k on PHASE 22 as AK4524 I2S doesn't support it
* enable SPDIF reciever on PHASE 22
Added support for Terrasoniq/MUSONIK TS22 PCI card.
Signed-off-by: Misha Zhilin <misha@epiphan.com>
Don't need to declare a struct when defining a structure layout. Both
of these structs are unused.
sound/pci/ice1712/revo.c:39:3: warning: symbol 'revo51' was not declared. Should it be static?
sound/pci/ice1712/phase.c:54:3: warning: symbol 'phase28' was not declared. Should it be static?
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Clean up ice1712/ice1724 codes. The board-specific data is allocated
locally in each code instead of having an ungly union in struct ice1712.
Also, fix coding issues in prodigy_hifi.c.
This header file exists only for some hacks to adapt alsa-driver
tree. It's useless for building in the kernel. Let's move a few
lines in it to sound/core.h and remove it.
With this patch, sound/driver.h isn't removed but has just a single
compile warning to include it. This should be really killed in
future.
Check the value ranges in ctl put callbacks properly.
Also fixed the wrong access type to enum elements in aureon.c.
Clean up codes using the new common snd_ctl_boolean_*_info() callbacks.
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Marvin told with a depressed face,
gcc doesn't like both __devinitdata and const in the same line.
So, remove const from all over places now...
Mark TLV data as 'const'
Signed-of-by: Philipp Matthias Hahn <pmhahn@pmhahn.de>
Mark a lot of data as 'const'
Reorganize EEPROM data (in C99 style).
Added the dB scale information to each board support code of ice1724 driver.
Semaphore to mutex conversion.
The conversion was generated via scripts, and the result was validated
automatically via a script as well.
Modules: ICE1724 driver,ICE1712 driver
Remove xxx_t typedefs from the PCI ICE1724 driver.
AD1889 driver,ATIIXP driver,ATIIXP-modem driver,AZT3328 driver
BT87x driver,CMIPCI driver,CS4281 driver,ENS1370/1+ driver
ES1938 driver,ES1968 driver,FM801 driver,Intel8x0 driver
Intel8x0-modem driver,Maestro3 driver,SonicVibes driver,VIA82xx driver
VIA82xx-modem driver,AC97 Codec,AK4531 codec,au88x0 driver
CA0106 driver,CS46xx driver,EMU10K1/EMU10K2 driver,HDA Codec driver
HDA generic driver,HDA Intel driver,ICE1712 driver,ICE1724 driver
KORG1212 driver,MIXART driver,NM256 driver,Trident driver,YMFPCI driver
Replace kcalloc(1,..) with kzalloc().
ICE1712 driver
Provides preliminary support for the Terratec Phase 28 card.
Not extensively tested and probably buggy, but it seems to work.
Signed-off-by: Simone Zinanni <simone@develer.com>
infrastructure for it.
Let it rip!
