Just code shuffles.
Add a new helper function to guess the default VREF pin control bits
for mic in. This can be used to set the pin control value safely
matching with the actual pin capabilities.
For setting the pin-control values more safely to match with the
actual pin capability bits, a copule of new helper functions,
snd_hda_set_pin_ctl() and snd_hda_set_pin_ctl_cache(), are
introduced. These are simple replacement of the codec verb write with
AC_VERB_SET_PIN_WIDGET but do more sanity checks and filter out
superfluous pin-control bits if they don't fit with the corresponding
pin capabilities.
Some codecs are screwed up or ignore the command when such a wrong bit
is set. These helpers will avoid such secret errors.
Since it's not always safe to assume that the vmaster hook is purely the
mute-LED control, add the flag indicating whether to expose the mute-LED
enum control or not. Currently, conexant codec sets this off for non-HP
laptops where EAPD may be used really as EAPD.
Create snd_hda_add_vmaster_hook() and snd_hda_sync_vmaster_hook()
helper functions to handle the mute-LED in vmaster hook more
commonly. In the former function, a new enum control "Mute-LED Mode"
is added. This provides user to choose whether the mute-LED should be
turned on/off explicitly or to follow the master-mute status.
Reviewed-by: David Henningsson <david.henningsson@canonical.com>
It'll be used for adding hooks in later patches.
When the driver is changed to use vmaster or a new slave element is
added by the improvement of the parser code, user may face often the
silent output because of the muted slave mixer although Master volume
is properly set. And they complain. And I get upset.
Although such a mixer element should be initialized via "alsactl init",
it'd be more user-friendly if the known output slaves are unmuted and
set to 0dB so that user can control the volume only with Master as
default. Since Master is still set muted as default even with this
change, no risk of the speaker blow up, too.
In most cases, the slave strings for vmaster are identical between
volumes and switches except for "xxx Volume" and "xxx Switch" suffix.
Now snd_hda_add_vmaster() takes the optional suffix argument so that
each string can be composed with the given suffix, and we can share the
slave name strings in both volume and switch calls nicely.
When an invalid NID is given, get_wcaps() returns zero as the error,
but get_wcaps_type() takes it as the normal value and returns a bogus
AC_WID_AUD_OUT value. This confuses the parser.
With this patch, get_wcaps_type() returns -1 when value 0 is given,
i.e. an invalid NID is passed to get_wcaps().
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=740118
Cc: <stable@kernel.org>
Instead of managing input-jack stuff separately, call all stuff inside
the kctl-jack creation, deletion and report. The caller no longer needs
to care about input-jack.
The better integration between input-jack and kctl-jack should be done
in the upper layer in near future, but for now, it's implemented locally
for more tests.
The function now gives more unique names for the output pins by adding
some prefix and suffix for the location and the channels. Otherwise, it
can pass the index number.
We can use the very same table in hda_jack.c for managing the list for
input-jack elements, too.
Introduce a table containing the pins and their jack-detection states
for avoiding the unnecessary verbs to check the pin status at each time.
When the unsol event is enabled via snd_hda_jack_detect_enable(), it
automatically adds the given NID to the table. Then the driver supposes
that the codec driver will set the dirty flag appropariately when an
unsolicited event is invoked for that pin.
The behavior for reading other pins that aren't registered in the table
doesn't change. Only the pins assigned to the table are cached, so far.
In near futre, this table can be extended to use the central place for
the unsolicited events of all pins, etc, and eventually include the
jack-detect kcontrols that replace the current input-jack stuff.
Create a new helper function snd_hda_get_pin_label() for getting a label
string for both input and output pins. hda_get_input_pin_label() is
obsoleted by this function, and the callers are replaced appropriately
now by this patch.
memset(eld) clears eld->proc_entry which will leak the struct
snd_info_entry when unloading module.
Fix it by
- memset only the fields before eld->eld_buffer
- set eld->eld_valid to true _after_ all eld fields have been filled
Cc: Pierre-louis Bossart <pierre-louis.bossart@intel.com>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
We disabled the check of NO_PRESENCE bit of the default pin-config
in commit f4419172 temporarily. One problem was that the first
implementation was wrong -- the bit after the shift must be checked.
However, this would still give many regressions on machines with broken
BIOS. They set this bit wrongly even on active pins.
A workaround is to check whether all pins contain this bit. As far as
I've checked, broken BIOSen set this bit on all pins, no matter whether
active or not. In such a case, the driver should ignore this bit check.
The implementation on commit [08a1f5eb: ALSA: hda - Check NO_PRESENCE
pincfg default bit] seems like a mis-interpretation of specification.
The spec gives the reversed bit definition. But, following the spec
also causes to change so many existing device configurations, thus we
can't change it so easily for now. For 3.2-rc1, it's safer to revert
this check (actually this patch comments out the code).
We may re-introduced the fixed version once after the wider test-case
coverages are done.
HD-audio spec defines a bit in pin default configuration for indicating
that the pin isn't used for jack-detection although the codec is capable
of it. Better to check this bit as well in jack_is_detectable() helper
function.
Reported-by: Raymond Yau <superquad.vortex2@gmail.com>
ALC260 has multiple mixer widgets connected to the shared DAC, but the
driver currently doesn't check this possibility and ignores when the DAC
is shared with others. This resulted in the silent output from some
routes because of lack of the amp setup.
This patch adds the workaround for it by checking the route even with the
shared DAC, but also checking the conflict with the existing control for
the very same widget NID.
Reference: https://bugzilla.novell.com/show_bug.cgi?id=726812
Since hda_proc.c is now the only user of snd_print_pcm_rates(), better to
put it back locally to hda_proc.c and revert to the old style.
Applications may want to read ELD information to
understand what codecs are supported on the HDMI
receiver and handle the a-v delay for better lip-sync.
ELD information is exposed in a device-specific
IFACE_PCM kcontrol. Tested both with amixer and
PulseAudio; with a corresponding patch passthrough modes
are enabled automagically.
ELD control size is set to zero in case of errors or
wrong configurations. No notifications are implemented
for now, it is expected that jack detection is used to
reconfigure the audio outputs.
Signed-off-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
For supporting both the multiple headphones and the multiple speakers,
add the new field in struct hda_multi_out, and evaluate in the standard
setup functions.
... and add a new bit-flags argument to specify the behavior of the
function. The older function is kept as is (as a wrapper).
It makes little sense to enable power-saving without PM.
This removes SND_HDA_NEEDS_RESUME define so that we can use CONFIG_PM
in all places.
to fix build problems when it is disabled.
A future change won't store an entire hda_pcm_stream just to represent
the capabilities of a codec; a custom data-structure will be used. To
ease that transition, modify hdmi_eld_update_pcm_info to expect the
hda_pcm_stream to be pre-initialized with the codec's capabilities, and
to update those capabilities in-place based on the ELD.
The SPDIF output controls apply to converter widgets. A future change
will create a PCM device per pin widget, and hence a set of SPDIF output
controls per pin widget, for certain HDMI codecs. To support this, we
need the ability to virtualize the SPDIF output controls. Specifically:
* Controls can be "unassigned" from real hardware when a converter is
not used for the PCM the control was created for.
* Control puts only write to hardware when they are assigned.
* Controls can be "assigned" to real hardware when a converter is picked
to support output for a particular PCM.
* When a converter is assigned, the hardware is updated to the cached
configuration.
Also replace more open-codes with this function.
Implement the same functionality as Realtek's auto-mute mode control.
Now Conexant auto-parser can also mutes line-out and provide the enum
control for different automute behavior.
Also fixed the assignment of multiout.dac_nids to satisfy const.
Since multiple codec drivers already use the input-jack stuff, let's
make common helper functions to reduce the duplicated codes.
The HDA specification does not allow for a codec to mute itself just
because the volume is reduced, so _of course_ somebody had to go and do
it. This wouldn'\''t hurt too much when the volume is adjusted by hand,
but programs like PA that try to set the volume automatically could
inadvertently mute the output.
To work around this, change the TLV dB information for the Master volume
on all Sigmatel HDA codecs to indicate the the minimal volume setting
actually mutes.
Reported-by: Colin Guthrie <gmane@colin.guthr.ie>
Reported-by: "Alexander E. Patrakov" <patrakov@gmail.com>
Tested-by: Colin Guthrie <cguthrie@mandriva.org>
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Make the helper function to give the input-pin attribute for jack
connectivity and location. This simplifies checks of input-pin jacks
a bit in some places.
This patch improves the input-source label strings to be generated from
the pin information instead of fixed strings per AUTO_PIN_* type.
This gives more suitable labels, especially for mic and line-in pins.
We can assign multiple pins to a single role now, let's reduce the
redundant FRONT_MIC and FRONT_LINE. Also, autocfg->input_pins[] is
no longer used, so this is removed as well.
Keep char array in the input_mux item itself instead of pointing to
an external string. This is a preliminary work for improving the
input-mux name based on the pin role.
Added snd_hda_get_input_pin_label() helper function to return the
string that can be used for control or capture-source ids.
Added the new fields to contain all input-pins to struct auto_pin_cfg.
Unlike the existing input_pins[], this array contains all input pins
even if the multiple pins are assigned for a single role (i.e. two
front mics). The former input_pins[] still remains for a while, but
will be removed in near future.
When a device is plugged over HDMI, it passes some information in ELD
including the supported PCM parameters like formats, rates, channels.
This patch adds the check to PCM open callback of HDMI streams so that
only valid parameters the device supports are used.
When no device is plugged, the parameters the codec supports are used;
it's mostly all parameters the hardware can work. This is for apps
that are started before device plugging and do probing (e.g. a sound
daemon), so that at least, probing would work even before the device
plugging.
I think this should be automatic pin instead of ping.
(but could be wrong).
Fix the wrong implementation of NID <-> kctl mapping for capture mixers
introduced by the ocmmit 5b0cb1d850c26893b1468b3a519433a1b7a176be.
So far, the driver returns an error at probe.
The HDA_SUBDEV_NID_FLAG is duplicate for amplifier control elements. Move
get_amp_nid_() call to the snd_hda_ctl_add() function.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
The purpose of this changeset is to show information about amplifier
setting in the codec proc file. Something like:
Control: name="Front Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Control: name="Front Playback Switch", index=0, device=0
ControlAmp: chs=3, dir=In, idx=2, ofs=0
This set of changes add missing NID values to some static control
elemenents. Also, it handles all "Capture Source" or "Input Source"
controls.
This helps merge duplicate code.
v2: add snd_hda_jack_detect() and comments recommended by Takashi.
Disable beep-related codes when CONFIG_SND_HDA_INPUT_BEEP isn't set.
