Instead of all drivers reading pci config space to get the revision
ID, they can now use the pci_device->revision member.
This exposes some issues where drivers where reading a word or a dword
for the revision number, and adding useless error-handling around the
read. Some drivers even just read it for no purpose of all.
In devices where the revision ID is being copied over and used in what
appears to be the equivalent of hotpath, I have left the copy code
and the cached copy as not to influence the driver's performance.
Compile tested with make all{yes,mod}config on x86_64 and i386.
Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
Acked-by: Dave Jones <davej@redhat.com>
Added a new macro snd_pcm_group_for_each_entry() just for code cleanup.
Old macros, snd_pcm_group_for_each() and snd_pcm_group_substream_entry(),
are removed.
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Clean up quirks in snd-ens1371 driver using snd_pci_quirk_lookup().
Fix IRQ flags for PCI devices.
The shared IRQs for PCI devices shouldn't be allocated with
IRQF_DISABLED. Also, when MSI is enabled, IRQF_SHARED shouldn't
be used.
The patch removes unnecessary cast in request_irq and free_irq,
too.
- Check the return value of pci_enable_device() and request_irq()
in the suspend. If any error occurs there, disable the device
using snd_card_disconnect().
- Call pci_set_power_state() properly with pci_choose_state().
- Fix the order to call pci_set_power_state().
- Removed obsolete house-made PM codes in some drivers.
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
Fixed 'section mismatch' errors in ALSA PCI drivers:
- removed invalid __devinitdata from pci id tables
- fix/remove __devinit of functions called in suspend/resume
Cc: Jaroslav Kysela <perex@suse.cz>
Cc: Takashi Iwai <tiwai@suse.de>
Remove unneeded read/write_size fields in proc text ops.
snd_info_set_text_ops() is fixed, too.
Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de>
Semaphore to mutex conversion.
The conversion was generated via scripts, and the result was validated
automatically via a script as well.
Modules: ENS1370/1+ driver
Fix resume of ens1370 driver.
Move the spdif and lineio parameters around so that they are compiled
even when SUPPORT_JOYSTICK isn't set.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
- spdif module option: some hardware revisions are without spdif output
- lineio module option: force shared line in / rear out jack settings
Fix PM support on ens1371 driver.
Add PM support on ens1370 (together with AK4531), too.
Remove xxx_t typedefs from the PCI ENS137x drivers.
Remove superflous pcm_free callbacks.
This patch fixes missing suspend/resume-code for snd-ens1371
(but not for snd-ens1370)
Signed-off-by: Kurt J. Bosch <kjb-temp-2005@gmx.de>
Use schedule_timeout_{,un}interruptible() instead of
set_current_state()/schedule_timeout() to reduce kernel size. Also use
human-time conversion functions instead of hard-coded division to avoid
rounding issues.
Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com>
Add missing KERN_* suffix to printk.
AD1889 driver,ALS4000 driver,ATIIXP driver,ATIIXP-modem driver
AZT3328 driver,BT87x driver,CMIPCI driver,CS4281 driver
ENS1370/1+ driver,ES1938 driver,ES1968 driver,FM801 driver
Intel8x0 driver,Intel8x0-modem driver,Maestro3 driver,RME32 driver
RME96 driver,SonicVibes driver,VIA82xx driver,VIA82xx-modem driver
ALI5451 driver,au88x0 driver,CS46xx driver,EMU10K1/EMU10K2 driver
HDA Intel driver,ICE1712 driver,ICE1724 driver,KORG1212 driver
MIXART driver,NM256 driver,RME HDSP driver,RME9652 driver
Trident driver,Digigram VX222 driver,YMFPCI driver
Set the module owner field in each driver's struct pci_driver to get
the driver symlink in the sysfs device directory.
AD1889 driver,ATIIXP driver,ATIIXP-modem driver,AZT3328 driver
BT87x driver,CMIPCI driver,CS4281 driver,ENS1370/1+ driver
ES1938 driver,ES1968 driver,FM801 driver,Intel8x0 driver
Intel8x0-modem driver,Maestro3 driver,SonicVibes driver,VIA82xx driver
VIA82xx-modem driver,AC97 Codec,AK4531 codec,au88x0 driver
CA0106 driver,CS46xx driver,EMU10K1/EMU10K2 driver,HDA Codec driver
HDA generic driver,HDA Intel driver,ICE1712 driver,ICE1724 driver
KORG1212 driver,MIXART driver,NM256 driver,Trident driver,YMFPCI driver
Replace kcalloc(1,..) with kzalloc().
CS46xx driver,EMU10K1/EMU10K2 driver,PCM Midlevel,Trident driver
YMFPCI driver,BT87x driver,CMIPCI driver,CS4281 driver
ENS1370/1+ driver,ES1938 driver,ES1968 driver,Intel8x0 driver
Intel8x0-modem driver,Maestro3 driver,RME32 driver,RME96 driver
SonicVibes driver,VIA82xx driver,ALI5451 driver,ICE1712 driver
ICE1724 driver,NM256 driver,RME HDSP driver,RME9652 driver
Remove superfluous PCI ID definitions.
Digigram VX core,ENS1370/1+ driver,CA0106 driver,EMU10K1/EMU10K2 driver
For consistency, use the PCM interface instead of MIXER for IEC958
default/mask/stream mixer controls.
CMI8330 driver,ENS1370/1+ driver,FM801 driver,VIA82xx driver,AC97 Codec
ALI5451 driver,CS46xx driver,EMU10K1/EMU10K2 driver,HDA Codec driver
Where appropriate, use the SNDRV_CTL_NAME_IEC958 instead of a literal
string.
Documentation,CS46xx driver,EMU10K1/EMU10K2 driver,AD1848 driver
SB16/AWE driver,CMIPCI driver,ENS1370/1+ driver,RME32 driver
RME96 driver,ICE1712 driver,ICE1724 driver,KORG1212 driver
This patch changes .iface to SNDRV_CTL_ELEM_IFACE_MIXER whre _PCM or
_HWDEP was used in controls that are not associated with a specific PCM
(sub)stream or hwdep device, and changes some controls that got
inconsitent .iface values due to copy+paste errors. Furthermore, it
makes sure that all control that do use _PCM or _HWDEP use the correct
number in the .device field.
ENS1370/1+ driver,ES1968 driver,Intel8x0 driver,VIA82xx driver
VIA82xx-modem driver,AC97 Codec,ALI5451 driver,CS46xx driver
MIXART driver,RME HDSP driver,Trident driver,YMFPCI driver
Description: Fix-up sleeping in sound/pci. These changes fall under the
following two categories:
1) Replace schedule_timeout() with msleep() to guarantee the
task delays as expected. This also involved replacing/removing
custom sleep functions.
2) Do not assume jiffies will only increment by one if you
request a 1 jiffy sleep, i.e. use time_after/time_before in
while loops.
ENS1370/1+ driver
Documentation,ALS4000 driver,ATIIXP driver,ATIIXP-modem driver
ALI5451 driver,au88x0 driver,CA0106 driver,CS46xx driver
EMU10K1/EMU10K2 driver,HDA Intel driver,ICE1712 driver,ICE1724 driver
KORG1212 driver,MIXART driver,NM256 driver,RME HDSP driver
RME9652 driver,Trident driver,Digigram VX222 driver,YMFPCI driver
Replace the obsolete pci_module_init() with pci_register_driver().
infrastructure for it.
Let it rip!
