Add missing KERN_* suffix to printk.
- Remove vmalloc wrapper
- Add release_and_free_resource() to remove kfree_nocheck() from each driver
and simplify the code
AD1889 driver,ALS4000 driver,ATIIXP driver,ATIIXP-modem driver
AZT3328 driver,BT87x driver,CMIPCI driver,CS4281 driver
ENS1370/1+ driver,ES1938 driver,ES1968 driver,FM801 driver
Intel8x0 driver,Intel8x0-modem driver,Maestro3 driver,RME32 driver
RME96 driver,SonicVibes driver,VIA82xx driver,VIA82xx-modem driver
ALI5451 driver,au88x0 driver,CS46xx driver,EMU10K1/EMU10K2 driver
HDA Intel driver,ICE1712 driver,ICE1724 driver,KORG1212 driver
MIXART driver,NM256 driver,RME HDSP driver,RME9652 driver
Trident driver,Digigram VX222 driver,YMFPCI driver
Set the module owner field in each driver's struct pci_driver to get
the driver symlink in the sysfs device directory.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
AD1889 driver,ATIIXP driver,ATIIXP-modem driver,AZT3328 driver
BT87x driver,CMIPCI driver,CS4281 driver,ENS1370/1+ driver
ES1938 driver,ES1968 driver,FM801 driver,Intel8x0 driver
Intel8x0-modem driver,Maestro3 driver,SonicVibes driver,VIA82xx driver
VIA82xx-modem driver,AC97 Codec,AK4531 codec,au88x0 driver
CA0106 driver,CS46xx driver,EMU10K1/EMU10K2 driver,HDA Codec driver
HDA generic driver,HDA Intel driver,ICE1712 driver,ICE1724 driver
KORG1212 driver,MIXART driver,NM256 driver,Trident driver,YMFPCI driver
Replace kcalloc(1,..) with kzalloc().
Memalloc module,CS46xx driver,VIA82xx driver,ALI5451 driver
au88x0 driver
Replace pci_find_device() with pci_get_device() and pci_dev_put().
Signed-off-by: Jiri Slaby <xslaby@fi.muni.cz>
CS46xx driver,EMU10K1/EMU10K2 driver,PCM Midlevel,Trident driver
YMFPCI driver,BT87x driver,CMIPCI driver,CS4281 driver
ENS1370/1+ driver,ES1938 driver,ES1968 driver,Intel8x0 driver
Intel8x0-modem driver,Maestro3 driver,RME32 driver,RME96 driver
SonicVibes driver,VIA82xx driver,ALI5451 driver,ICE1712 driver
ICE1724 driver,NM256 driver,RME HDSP driver,RME9652 driver
Remove superfluous PCI ID definitions.
Digigram VX core,CS4231 driver,ATIIXP driver,VIA82xx driver
VIA82xx-modem driver,au88x0 driver,CS46xx driver,Trident driver
This patch disables SNDRV_PCM_INFO_RESUME flag for drivers which does not
support the full resume.
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
CMI8330 driver,ENS1370/1+ driver,FM801 driver,VIA82xx driver,AC97 Codec
ALI5451 driver,CS46xx driver,EMU10K1/EMU10K2 driver,HDA Codec driver
Where appropriate, use the SNDRV_CTL_NAME_IEC958 instead of a literal
string.
Documentation,CS46xx driver,EMU10K1/EMU10K2 driver,AD1848 driver
SB16/AWE driver,CMIPCI driver,ENS1370/1+ driver,RME32 driver
RME96 driver,ICE1712 driver,ICE1724 driver,KORG1212 driver
This patch changes .iface to SNDRV_CTL_ELEM_IFACE_MIXER whre _PCM or
_HWDEP was used in controls that are not associated with a specific PCM
(sub)stream or hwdep device, and changes some controls that got
inconsitent .iface values due to copy+paste errors. Furthermore, it
makes sure that all control that do use _PCM or _HWDEP use the correct
number in the .device field.
ENS1370/1+ driver,ES1968 driver,Intel8x0 driver,VIA82xx driver
VIA82xx-modem driver,AC97 Codec,ALI5451 driver,CS46xx driver
MIXART driver,RME HDSP driver,Trident driver,YMFPCI driver
Description: Fix-up sleeping in sound/pci. These changes fall under the
following two categories:
1) Replace schedule_timeout() with msleep() to guarantee the
task delays as expected. This also involved replacing/removing
custom sleep functions.
2) Do not assume jiffies will only increment by one if you
request a 1 jiffy sleep, i.e. use time_after/time_before in
while loops.
Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com>
Timer Midlevel,ALSA sequencer,ALSA<-OSS sequencer,Digigram VX core
I2C tea6330t,GUS Library,VIA82xx driver,VIA82xx-modem driver
CA0106 driver,CS46xx driver,EMU10K1/EMU10K2 driver,YMFPCI driver
Digigram VX Pocket driver,Common EMU synth,USB generic driver,USB USX2Y
Checking a pointer for NULL before calling kfree() on it is redundant,
kfree() deals with NULL pointers just fine.
This patch removes such checks from sound/
This patch also makes another, but closely related, change.
It avoids casting pointers about to be kfree()'ed.
Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk>
Documentation,ALS4000 driver,ATIIXP driver,ATIIXP-modem driver
ALI5451 driver,au88x0 driver,CA0106 driver,CS46xx driver
EMU10K1/EMU10K2 driver,HDA Intel driver,ICE1712 driver,ICE1724 driver
KORG1212 driver,MIXART driver,NM256 driver,RME HDSP driver
RME9652 driver,Trident driver,Digigram VX222 driver,YMFPCI driver
Replace the obsolete pci_module_init() with pci_register_driver().
infrastructure for it.
Let it rip!
