path: root/sound/pci/azt3328.c
2011-12-19ALSA: module_param: make bool parameters really boolRusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-10-31sound: fix drivers needing module.h not moduleparam.hPaul Gortmaker
The implicit presence of module.h lured several users into incorrectly thinking that they only needed/used modparam.h but once we clean up the module.h presence, these will show up as build failures, so fix 'em now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-09-14ALSA: mpu401: clean up interrupt specificationClemens Ladisch
The semantics of snd_mpu401_uart_new()'s interrupt parameters are somewhat counterintuitive: To prevent the function from allocating its own interrupt, either the irq number must be invalid, or the irq_flags parameter must be zero. At the same time, the irq parameter being invalid specifies that the mpu401 code has to work without an interrupt allocated by the caller. This implies that, if there is an interrupt and it is allocated by the caller, the irq parameter must be set to a valid-looking number which then isn't actually used. With the removal of IRQF_DISABLED, zero becomes a valid irq_flags value, which forces us to handle the parameters differently. This patch introduces a new flag MPU401_INFO_IRQ_HOOK for when the device interrupt is handled by the caller, and makes the allocation of the interrupt to depend only on the irq parameter. As suggested by Takashi, the irq_flags parameter was dropped because, when used, it had the constant value IRQF_DISABLED. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-08-10ALSA: azt3328 - adjust error handling code to include debugging codeJulia Lawall
snd_azf3328_dbgcallenter is called at the very beginning of the function, so it could be useful to call snd_azf3328_dbgcallleave at all exit points. Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-10ALSA: use KBUILD_MODNAME for request_irq argument in sound/pci/*Takashi Iwai
The name argument of request_irq() appears in /proc/interrupts, and it's quite ugly when the name entry contains a space or special letters. In general, it's simpler and more readable when the module name appears there, so let's replace all entries with KBUILD_MODNAME. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-10ALSA: Use KBUILD_MODNAME for pci_driver.name entriesTakashi Iwai
The convention for pci_driver.name entry in kernel drivers seem to be the module name or equivalent ones. But, so far, almost all PCI sound drivers use more verbose name like "ABC Xyz (12)", and these are fairly confusing when appearing as a file name. This patch converts the all pci_driver.name entries in sound/pci/* to use KBUILD_MODNAME for more unified appearance. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-11Merge branch 'fix/misc' into topic/miscTakashi Iwai
2011-02-19ALSA: azt3328: add custom AC97 semi-emulation use standard ALSA AC97 layerAndreas Mohr
Make use of the very flexible ALSA ac97 layer (hooks for custom I/O!) on this weird AC97 copycat hardware, via semi-extended I/O translation/emulation. Some 5kB binary/loaded size saved (well... additional huge AC97 module penalty not factored in, of course ;-P). Given that the driver previously had 20kB that's not bad, but the much more important thing is to have AC97 layer stress-tested with a thoroughly weird AC97 copycat (or, simply put, if it were not for this AC97 test aspect, this effort would merely have been a nut job ;). Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-01-25ALSA: azt3328 - fix broken AZF_FMT_XLATE macroAndreas Mohr
Cleanly revert to non-macro implementation of snd_azf3328_codec_setfmt(), to fix last-minute functionality breakage induced by following checkpatch.pl recommendations without giving them their due full share of thought ("revolting computer, ensuing PEBKAC"). I would like to thank Jiri Slaby for his very timely (in -rc1 even) and unexpected (uncommon hardware) "recognition of the dangerous situation" due to his very commendable static parser use. :) Reported-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-01-02ALSA: azt3328: improve snd_azf3328_codec_setdmaa()Andreas Mohr
- add some WARN_ONCE - add multi-I/O helper (and use helper struct) - fix off-by-1 DMA length bug - better variable naming Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-01-02ALSA: azt3328: use proper private_data hookup for codec identificationAndreas Mohr
- much improved implementation due to clean codec hierarchy - preparation for potential per-codec spinlock change NOTE: additionally removes a chip->pcm[codec_type] NULL ptr check (due to it requiring access to external chip struct), however I believe this to be ok since this condition should not occur and most drivers don't check against that either. Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-01-02ALSA: azt3328: use a helper variable to remove one indirection in hotpathAndreas Mohr
2011-01-02ALSA: azt3328: cosmetics: use a helper variable for codec setupAndreas Mohr
2011-01-02ALSA: azt3328: _setfmt() updateAndreas Mohr
- use a separate variable for the frequency part, don't always "or" it - use a "clever"(?) macro to shorten the code Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-01-02ALSA: azt3328: cosmetics, minor updatesAndreas Mohr
- correct samples to be POSIX shell compatible - add logging of jiffies value in _pointer() - several comments - cleanup Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-22ALSA: azt3328: period bug fix (for PA), add missing ACK on stop timerAndreas Mohr
. Fix PulseAudio "ALSA driver bug" issue (if we have two alternated areas within a 64k DMA buffer, then max period size should obviously be 32k only). Back references: http://pulseaudio.org/wiki/AlsaIssues http://fedoraproject.org/wiki/Features/GlitchFreeAudio . In stop timer function, need to supply ACK in the timer control byte. . Minor log output correction When I did my first PA testing recently, the period size bug resulted in quite precisely observeable half-period-based playback distortion. PA-based operation is quite a bit more underrun-prone (despite its zero-copy optimizations etc.) than raw ALSA with this rather spartan sound hardware implementation on my puny Athlon. Note that even with this patch, azt3328 still doesn't work for both cases yet, PA tsched=0 and tsched (on tsched=0 it will playback tiny fragments of periods, leading to tiny stuttering sounds with some pauses in between, whereas with timer-scheduled operation playback works fine - minus some quite increased underrun trouble on PA vs. ALSA, that is). Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-02-09sound: use DEFINE_PCI_DEVICE_TABLEAlexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() to make PCI device ids go to .devinit.rodata section, so they can be discarded in some cases, and make them const. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-05ALSA: rename "PC Speaker" and "PC Beep" controls to "Beep"Jaroslav Kysela
To avoid confusion in control names for the standard analog PC Beep generator using a small Internal PC Speaker, rename all related "PC Speaker" and "PC Beep" controls to "Beep" only. This name is more universal and can be also used on more platforms without confusion. Introduce also "Internal Speaker" in ControlNames.txt for systems with full-featured build-in internal speaker. Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-07-15ALSA: azt3328: fix previous breakage, improve suspend, cleanupsAndreas Mohr
- fix my previous codec activity breakage (_non-warned_ variable assignment issue) - convert suspend/resume to 32bit I/O access (I/O is painful; to improve suspend/resume performance) - change DEBUG_PLAY_REC to DEBUG_CODEC for consistency - printk cleanup - some logging improvements - minor cleanup/improvements The variable assignment issue above was a conditional assignment to the call_function variable (this ended with the non-preinitialized variable not getting assigned in some cases, thus a dangling stack value, yet gcc 4.3.3 unbelievably did _NOT_ warn about it in this case!!), needed to change this into _always_ assigning the check result. Practical result of this bug was that when shutting down _either_ playback or capture, _both_ streams dropped dead :P Tested, working (plus resume) and checkpatch.pl:ed on 2.6.30-rc5, applies cleanly to 2.6.30 proper with my previous (committed) patches applied. Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-07-06ALSA: azt3328: large codec cleanup, add I2S port etc.Andreas Mohr
- fully separate codec I/O port handling, enabling the use of a single function each for all codecs (playback, capture, I2S out) - add a new separate pcm for I2S out port (UNTESTED, no I2S DAC available yet) - switch gameport to low frequency while idle, to try to reduce noise/power - improve snd_azf3328_codec_setdmaa() calculation - minor variable type cleanup (u16, bool etc.) - add some doc updates (help those lost Windows users, debug help, ...) Note that due to the large cleanup aspect of the codec I/O change, I was able to fit everything including all improvements into the same binary size!! (a measly 10 bytes more or so) This should now be the almost last patch to this driver (minus some possible kernel clocksource patch and x86_64 fixes or so). I just felt like taking a break from the usual stuff and wanted to get this driver's structure finished, and it's rather clean now... Tested, working and checkpatch.pl:ed on 2.6.30-rc5, applies cleanly to 2.6.30 proper. Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-07dma-mapping: replace all DMA_24BIT_MASK macro with DMA_BIT_MASK(24)Yang Hongyang
Replace all DMA_24BIT_MASK macro with DMA_BIT_MASK(24) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-24Merge branch 'topic/misc' into for-linusTakashi Iwai
2009-02-05ALSA: Fix missing KERN_* prefix to printk in sound/pciTakashi Iwai
2009-01-12ALSA: Convert to snd_card_create() in sound/pci/*Takashi Iwai
Convert from snd_card_new() to the new snd_card_create() function in sound/pci/*. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-08-13ALSA: Kill snd_assert() in sound/pci/*Takashi Iwai
Kill snd_assert() in sound/pci/*, either removed or replaced with if () with snd_BUG_ON(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-06-26ALSA: PCI168 snd-azt3328: some more fixupsAndreas Mohr
- fix problem with codec register 0x6a being write-only by adding a software shadow register (caused annoying noise after module loading due to _toggling_ between gameport and audio bits instead of configuring them properly) - rename several "Wave" mixer controls to "PCM", since this is what Wine and several other apps are looking for (IOW, _requiring_) and this is what AC97 specs use as naming, too, thus I'd guess it's what these controls are - cleanup, small optimizations Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-05-19[ALSA] PCI168 snd-azt3328 Linux driver: another huge updateAndreas Mohr
- figured out 'Digital(ly) Enhanced Game Port' functionality, implemented support for it (eliminating gameport polling overhead) - removed optional joystick activation, gameport now enabled unconditionally, since we now support it via the PCI I/O space, not via conflict-prone legacy I/O (which I was thus able to DISABLE now)! - fix playback bug (a muted wave output would get unmuted upon start of playback, of course this is not what we want, thus remember mute state) - implement partial power management: when idle, lower clock rate and disable codec (reduced noise!), and disable gameport circuit when unused - instantiate OPL3 timer, too - much better implementation of snd_azf3328_mixer_write_volume_gradually() - slightly optimized interrupt handling - lots of cleanup This time, I also found a way to verify proper OPL3 operation via MIDI file playback (emulation via synth hardware). Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-04-24[ALSA] Fix synchronize_irq() bugs, redundanciesJeff Garzik
free_irq() calls synchronize_irq() for you, so there is no need for drivers to manually do the same thing (again). Thus, calls where sync-irq immediately precedes free-irq can be simplified. However, during this audit several bugs were noticed, where free-irq is preceded by a "irq >= 0" check... but the sync-irq call is not covered by the same check. So, where sync-irq could not be eliminated completely, the missing check was added. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: replace remaining __FUNCTION__ occurencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-05-11[ALSA] azt3328.c: small cleanup patchAndreas Mohr
- change 'PCM' mixer control (pre/post 3D) to 'PCM Output Route' - improve snd_azf3328_debug_show_ports - less aggressive module init message - document Bass/Treble non-bug (prompted by user report - Thank You!!) - add some items to card description - add some I/O register documentation - enhance copyright Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] Fix conflicts between const and __devinitdataTakashi Iwai
Marvin told with a depressed face, gcc doesn't like both __devinitdata and const in the same line. So, remove const from all over places now... Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] Remove IRQF_DISABLED for shared PCI irqsTakashi Iwai
Fix IRQ flags for PCI devices. The shared IRQs for PCI devices shouldn't be allocated with IRQF_DISABLED. Also, when MSI is enabled, IRQF_SHARED shouldn't be used. The patch removes unnecessary cast in request_irq and free_irq, too. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-10-22[ALSA] Various fixes for suspend/resume of ALSA PCI driversTakashi Iwai
- Check the return value of pci_enable_device() and request_irq() in the suspend. If any error occurs there, disable the device using snd_card_disconnect(). - Call pci_set_power_state() properly with pci_choose_state(). - Fix the order to call pci_set_power_state(). - Removed obsolete house-made PM codes in some drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-12[ALSA] Fix section mismatch errors in ALSA PCI driversTakashi Iwai
Fixed 'section mismatch' errors in ALSA PCI drivers: - removed invalid __devinitdata from pci id tables - fix/remove __devinit of functions called in suspend/resume Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-02[PATCH] irq-flags: sound: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-22[ALSA] Change an arugment of snd_mpu401_uart_new() to bit flagsTakashi Iwai
Change the 5th argument of snd_mpu401_uart_new() to bit flags instead of a boolean. The argument takes bits that consist of MPU401_INFO_XXX flags. The callers that used the value 1 there are replaced with MPU401_INFO_INTEGRATED. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] azt3328.c: use kernel coding styleAndreas Mohr
Scope braces were not done the One True Kernel Way. Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] azt3328.c: add 3D sound mixer switch/rename controlsAndreas Mohr
- add 3D sound pre-3D/post-3D switch, as seen in standard AC-97 - rename controls to shorter and more accurate strings Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] azt3328.c: add suspend/resume supportAndreas Mohr
- add suspend/resume handlers - fix problem (private_data members not set) Playing a file while suspending will resume correctly with this patch, so I assume the hardware to get fully correctly reinitialized with this patch. Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-27[ALSA] add __devinitdata to all pci_device_idHenrik Kretzschmar
Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-28[PATCH] Replace 0xff.. with correct DMA_xBIT_MASKMatthias Gehre
Replace all occurences of 0xff.. in calls to function pci_set_dma_mask() and pci_set_consistant_dma_mask() with the corresponding DMA_xBIT_MASK from linux/dma-mapping.h. Signed-off-by: Matthias Gehre <M.Gehre@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI AZT3328Takashi Iwai
Modules: AZT3328 driver Remove xxx_t typedefs from the PCI AZT3328 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove superfluous pcm_free callbacksTakashi Iwai
Remove superflous pcm_free callbacks. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-10[PATCH] PCI: removed unneeded .owner field from struct pci_driverGreg Kroah-Hartman
2005-11-04[ALSA] AZT3328 driver updateAndreas Mohr
Modules: AZT3328 driver this is now an even much more reworked patch (#3) for my azt3328.c ALSA driver. IOW I spent another 4 evenings to get the sequencer timer to work properly (my head is still hurting) and do lots of other cleanups. Note that despite the extensive sequencer timer additions, the driver object is still only 2kB bigger than the previous version, due to those many optimizations... Changes in version #3: - fully working ALSA sequencer timer support for the card's 1024000Hz DirectX timer (downscaling adjustable via seqtimer_scaling module param) - an insane amount of code optimizations - many, many cleanups Changes in version #2: - FOUND the 1us DirectX timer area (yay!), made the code respect it properly - renamed some 'weird' mixer control names according to ControlNames.txt - cleanup unneeded debug messages, reformatting - improved I/O register documentation - constified many more structs Changes in version #1: - improves/fixes some fatal playback/recording interaction - improves IRQ handler performance (and actually fixes some weird code) - coalesces some I/O accesses - slightly improves I/O interface documentation - improves/fixes logging - defines out some less important debug code - constifies some data Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Add missing KERN_* suffix to printkTakashi Iwai
Add missing KERN_* suffix to printk. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Remove vmalloc wrapper, kfree_nocheck()Takashi Iwai
- Remove vmalloc wrapper - Add release_and_free_resource() to remove kfree_nocheck() from each driver and simplify the code Signed-off-by: Takashi Iwai <tiwai@suse.de>
