commit ee03c0f200eb0d9f22dd8732d9fb7956d91019c2 upstream.
With char becoming unsigned by default, and with `char` alone being
ambiguous and based on architecture, signed chars need to be marked
explicitly as such. This fixes warnings like:
sound/pci/au88x0/au88x0_core.c:2029 vortex_adb_checkinout() warn: signedness bug returning '(-22)'
sound/pci/au88x0/au88x0_core.c:2046 vortex_adb_checkinout() warn: signedness bug returning '(-12)'
sound/pci/au88x0/au88x0_core.c:2125 vortex_adb_allocroute() warn: 'vortex_adb_checkinout(vortex, (0), en, 0)' is unsigned
sound/pci/au88x0/au88x0_core.c:2170 vortex_adb_allocroute() warn: 'vortex_adb_checkinout(vortex, stream->resources, en, 4)' is unsigned
As well, since one function returns errnos, return an `int` rather than
a `signed char`.
Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com>
Cc: <stable@vger.kernel.org>
Link: https://lore.kernel.org/r/20221024162929.536004-1-Jason@zx2c4.com
commit b093de145bc8769c6e9207947afad9efe102f4f6 upstream.
The previous cleanup with devres may lead to the incorrect release
orders at the probe error handling due to the devres's nature. Until
we register the card, snd_card_free() has to be called at first for
releasing the stuff properly when the driver tries to manage and
release the stuff via card->private_free().
This patch fixes it by calling snd_card_free() on the error from the
probe callback using a new helper function.
Fixes: e44b5b440609 ("ALSA: au88x0: Allocate resources with device-managed APIs")
Link: https://lore.kernel.org/r/20220412102636.16000-8-tiwai@suse.de
This patch converts the resource management in PCI au88x0 driver with
devres as a clean up. Each manual resource management is converted
with the corresponding devres helper, and the card object release is
managed now via card->private_free instead of a lowlevel snd_device.
This should give no user-visible functional changes.
Link: https://lore.kernel.org/r/20210715075941.23332-28-tiwai@suse.de
PCI AU88x0 driver code contains a lot of assignments in if condition,
which is a bad coding style that may confuse readers and occasionally
lead to bugs.
This patch is merely for coding-style fixes. A potential real fix is
about the PCI AGP bridge management refcount in addition while spotted
out during conversions.
Link: https://lore.kernel.org/r/20210608140540.17885-36-tiwai@suse.de
MODULE_SUPPORTED_DEVICE was added in pre-git era and never was
implemented. We can safely remove it, because the kernel has grown
to have many more reliable mechanisms to determine if device is
supported or not.
Signed-off-by: Leon Romanovsky <leonro@nvidia.com>
Many PCI drivers still have two explicit calls of dma_set_mask() and
dma_set_coherent_mask().
Let's simplify with dma_set_mask_and_coherent().
Link: https://lore.kernel.org/r/20210114125412.993-2-tiwai@suse.de
A few places (except for ASoC) are left unconverted for the new
fallthrough pseudo keyword. Now replace them all.
Reviewed-by: Gustavo A. R. Silva <gustavoars@kernel.org>
Link: https://lore.kernel.org/r/20200709111750.8337-4-tiwai@suse.de
Fix W=1 warnings. Mark all unused tables with __maybe_unused.
Signed-off-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
Link: https://lore.kernel.org/r/20200702193604.169059-24-pierre-louis.bossart@linux.intel.com
Apply const prefix to each possible place: the static register tables,
the coef tables, the string arrays, etc.
Just for minor optimization and no functional changes.
Link: https://lore.kernel.org/r/20200105144823.29547-14-tiwai@suse.de
Most of snd_kcontrol_new definitions are read-only and passed as-is.
Let's declare them as const for further optimization.
There should be no functional changes by this patch.
Link: https://lore.kernel.org/r/20200103081714.9560-38-tiwai@suse.de
Now snd_ac97_bus() takes the const ops pointer, so we can define the
snd_ac97_bus_ops locally as const as well for further optimization.
Link: https://lore.kernel.org/r/20200103081714.9560-28-tiwai@suse.de
Now we may declare const for snd_device_ops definitions, so let's do
it for optimization.
Link: https://lore.kernel.org/r/20200103081714.9560-10-tiwai@suse.de
The driver invokes snd_pcm_period_elapsed() simply from the interrupt
handler. Set card->sync_irq for enabling the missing sync_stop PCM
operation.
Link: https://lore.kernel.org/r/20191210063454.31603-6-tiwai@suse.de
PCM core deals the empty ioctl field now as default(*).
Let's kill the redundant lines.
(*) commit fc033cbf6fb7 ("ALSA: pcm: Allow NULL ioctl ops")
Link: https://lore.kernel.org/r/20191210061145.24641-16-tiwai@suse.de
Clean up the drivers with the new managed buffer allocation API.
The superfluous snd_pcm_lib_malloc_pages() and
snd_pcm_lib_free_pages() calls are dropped.
Link: https://lore.kernel.org/r/20191209094943.14984-26-tiwai@suse.de
The code change in commit 6974f8ad4494 ("ALSA: pci: Avoid non-standard
macro usage") contained an incorrect conversion, which left the
invalid pointer passed to the allocator for au88x0 driver. Fix it.
Fixes: 6974f8ad4494 ("ALSA: pci: Avoid non-standard macro usage")
Link: https://lore.kernel.org/r/20191112143243.22216-1-tiwai@suse.de
Pass the device pointer from the PCI pointer directly, instead of a
non-standard macro. The macro didn't give any better readability.
Link: https://lore.kernel.org/r/20191105151856.10785-24-tiwai@suse.de
snd_pcm_sgbuf_ops_page is no longer needed to be set explicitly to PCM
page ops since the recent change in the PCM core (*). Leaving it NULL
should work as long as the preallocation has been done properly.
This patch drops the redundant lines.
(*) 7e8edae39fd1: ALSA: pcm: Handle special page mapping in the
default mmap handler
Link: https://lore.kernel.org/r/20191105151856.10785-19-tiwai@suse.de
Fix below issues reported by coccicheck
sound/pci/au88x0/au88x0_a3d.c:821:8-15: Unneeded variable: "changed".
Return "1" on line 834
sound/pci/au88x0/au88x0_a3d.c:768:5-12: Unneeded variable: "changed".
Return "1" on line 777
sound/pci/au88x0/au88x0_a3d.c:804:5-12: Unneeded variable: "changed".
Return "1" on line 813
sound/pci/au88x0/au88x0_a3d.c:786:8-15: Unneeded variable: "changed".
Return "1" on line 796
Signed-off-by: Hariprasad Kelam <hariprasad.kelam@gmail.com>
Based on 1 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license as published by
the free software foundation either version 2 of the license or at
your option any later version this program is distributed in the
hope that it will be useful but without any warranty without even
the implied warranty of merchantability or fitness for a particular
purpose see the gnu general public license for more details you
should have received a copy of the gnu general public license along
with this program if not write to the free software foundation inc
59 temple place suite 330 boston ma 02111 1307 usa
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 1334 file(s).
Reviewed-by: Allison Randal <allison@lohutok.net>
Reviewed-by: Richard Fontana <rfontana@redhat.com>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190527070033.113240726@linutronix.de
purpose see the gnu library general public license for more details
you should have received a copy of the gnu general public license
along with this program if not write to the free software foundation
inc 59 temple place suite 330 boston ma 02111 1307 usa
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 10 file(s).
Reviewed-by: Armijn Hemel <armijn@tjaldur.nl>
Link: https://lkml.kernel.org/r/20190527063114.579638220@linutronix.de
Link: https://lkml.kernel.org/r/20190524100843.303899865@linutronix.de
Add SPDX license identifiers to all files which:
- Have no license information of any form
- Have MODULE_LICENCE("GPL*") inside which was used in the initial
scan/conversion to ignore the file
These files fall under the project license, GPL v2 only. The resulting SPDX
license identifier is:
GPL-2.0-only
As a preparatory patch for the upcoming -Wimplicit-fallthrough
compiler checks, add the "fall through" annotation in au88xx driver.
Although the usages in both both functions vortex_adbdma_setbuffers()
and vortex_wtdma_setbuffers() look a bit suspicious, we keep the
behavior as before, just to be safer. If it were broken, we should
have already received bug reports.
The PCM format type is with __bitwise, and it can't be converted from
integer implicitly. Instead of an ugly cast, declare the function
argument of vortex_alsafmt_aspfmt() with the proper snd_pcm_format_t
type.
This fixes the sparse warning like:
sound/pci/au88x0/au88x0_core.c:2778:14: warning: restricted snd_pcm_format_t degrades to integer
https://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus
ASoC: Updates for v4.15
The biggest thing this release has been the conversion of the AC98 bus
to the driver model, that's been a long time coming so thanks to Robert
Jarzmik for his dedication there. Due to there being some AC97 MFD
there's a few fairly large changes in input and the MFD layer, mainly to
the wm97xx driver.
There's also some drivers/drm changes to support the new AMD Stoney
platform, these are shared with the DRM subsystem and should be being
merged via both.
Within the subsystem the overwhelming bulk of the changes is in the
Intel drivers which continue to need lots of cleanups and fixes, this
release they've also gained support for their open source firmware.
There's also some large changs in the core as Morimoto-san continues to
mirror operations into the component level in preparation for conversion
of drivers to that.
- The AC97 bus has finally caught up with the driver model thanks to
some dedicated and persistent work from Robert Jarzmik.
- Continued work from Morimoto-san on moving us towards being able to
use components for everything.
- Lots of cleanups for the Intel platform code, including support for
their open source audio firmware.
- Support for scaling MCLK with sample rate in simple-card.
- Support for AMD Stoney platform.
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
The assignment to variable i is redundant as it is never read
because it is updated a little later on. Remove this assignment.
Cleans up clang warning: Value stored to 'i' is never read
Make these const as they are only used in a copy operation.
Done using Coccinelle.
Signed-off-by: Bhumika Goyal <bhumirks@gmail.com>
snd_pcm_ops are not supposed to change at runtime. All functions
working with snd_pcm_ops provided by <sound/pcm.h> work with
const snd_pcm_ops. So mark the non-const structs as const.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
snd_pcm_hw_constraint_list(), *_ratnums() and *_ratdens() receive the
const pointers. Constify the corresponding static objects for better
hardening.
The latest gcc-7.0.1 snapshot points out that we if nr_ch is zero, we never
initialize some variables:
sound/pci/au88x0/au88x0_core.c: In function 'vortex_adb_allocroute':
sound/pci/au88x0/au88x0_core.c:2304:68: error: 'mix[0]' may be used uninitialized in this function [-Werror=maybe-uninitialized]
sound/pci/au88x0/au88x0_core.c:2305:58: error: 'src[0]' may be used uninitialized in this function [-Werror=maybe-uninitialized]
I assume this can never happen in practice, but adding a check here doesn't
hurt either and avoids the warning. The code has been unchanged since
the start of git history.
Declare snd_kcontrol_new structures as const as they are only passed as
an argument to the function snd_ctl_new1. This argument is of type
const, so snd_kcontrol_new structures having the same property can be
made const too.
Done using Coccinelle:
@r1 disable optional_qualifier @
identifier i;
position p;
static struct snd_kcontrol_new i@p = {...};
@ok1@
identifier r1.i;
position p;
expression e1;
snd_ctl_new1(&i@p,e1)
@bad@
position p!={r1.p,ok1.p};
identifier r1.i;
i@p
@depends on !bad disable optional_qualifier@
identifier r1.i;
+const
struct snd_kcontrol_new i;
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Trival fix, the dev_err message is missing a \n so add it.
vortex_wtdma_bufshift() function does calculate the page index
wrongly, first masking then shift, which always results in zero.
The proper computation is to first shift, then mask.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
There are a few calls of memset() to stream->resources, but they all
are called in a wrong size, sizeof(unsigned char) * VORTEX_RESOURCE_LAST,
while this field is a u32 array. This may leave the memories not
zero-cleared.
Fix it by replacing them with a simpler sizeof(stream->resources)
instead.
Reported-by: David Binderman <dcb314@hotmail.com>
au88x0 hardware seems returning the current pointer at the buffer
boundary instead of going back to zero. This results in spewing
warnings from PCM core.
This patch corrects the return value from the pointer callback within
the proper value range, just returning zero if the position is equal
or above the buffer size.
Replace occurences of the pci api by appropriate call to the dma api.
A simplified version of the semantic patch that finds this problem is as
follows: (http://coccinelle.lip6.fr)
@deprecated@
idexpression id;
position p;
pci_dma_supported@p ( id, ...)
pci_alloc_consistent@p ( id, ...)
@bad1@
idexpression id;
position deprecated.p;
...when != &id->dev
when != pci_get_drvdata ( id )
when != pci_enable_device ( id )
@depends on !bad1@
idexpression id;
expression direction;
- pci_dma_supported@p ( id,
+ dma_supported ( &id->dev,
+ , GFP_ATOMIC
- pci_alloc_consistent@p ( id,
+ dma_alloc_coherent ( &id->dev,
+ , GFP_ATOMIC
Signed-off-by: Quentin Lambert <lambert.quentin@gmail.com>
Nowadays it's recommended. Replace all in a shot.
Use the standard dev_*() instead.
pr_* macros replaced with dev_* as they are more preffered over pr_*.
each file which had pr_* was reviewed manually and replaced with dev_*.
here we have actually used the reference of the vortex which was added
to some functions in the previous patch of this series.
The prefix of the CARD_NAME and prefix of "vortex:" was also
removed as the dev_* will print the device name.
Signed-off-by: Sudip Mukherjee <sudip@vectorindia.org>
added a pointer of the vortex in the following functions :
vortex_Vort3D_InitializeSource
a3dsrc_ZeroStateA3D
so that we can have a reference of the vortex in the function.
this reference of the vortex will actually be used in a later patch
to convert the pr_* macro to dev_*.
as pr_* macros are more preffered over printk, so printk replaced
with corresponding pr_* macros.
this patch will generate warning from checkpatch as it only did printk
replacement and didnot fixed other style issues.
We should prefer `struct pci_device_id` over `DEFINE_PCI_DEVICE_TABLE` to
meet kernel coding style guidelines. This issue was reported by checkpatch.
A simplified version of the semantic patch that makes this change is as
follows (http://coccinelle.lip6.fr/):
// <smpl>
identifier i;
declarer name DEFINE_PCI_DEVICE_TABLE;
initializer z;
- DEFINE_PCI_DEVICE_TABLE(i)
+ const struct pci_device_id i[]
= z;
// </smpl>
[bhelgaas: add semantic patch]
Signed-off-by: Benoit Taine <benoit.taine@lip6.fr>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Also remove superfluous snd_card_set_dev() calls.
These aren't necessary after switch and if blocks.
'break' after a return statement is redundant. Remove it.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
As drvdata is cleared to NULL at probe failure or at removal by the
driver core, we don't have to call pci_set_drvdata(pci, NULL) any
longer in each driver.
The only remaining pci_set_drvdata(NULL) is in azx_firmware_cb() in
hda_intel.c. Since this function itself releases the card instance,
we need to clear drvdata here as well, so that it won't be released
doubly in the remove callback.
Define channel map for playback, capture devices of au88x0
Signed-off-by: Raymond Yau <superquad.vortex2@gmail.com>
