The name argument of request_irq() appears in /proc/interrupts, and
it's quite ugly when the name entry contains a space or special letters.
In general, it's simpler and more readable when the module name appears
there, so let's replace all entries with KBUILD_MODNAME.
The convention for pci_driver.name entry in kernel drivers seem to be
the module name or equivalent ones. But, so far, almost all PCI sound
drivers use more verbose name like "ABC Xyz (12)", and these are fairly
confusing when appearing as a file name.
This patch converts the all pci_driver.name entries in sound/pci/* to
use KBUILD_MODNAME for more unified appearance.
This allow application such as gstreamer and wine which use
snd_pcm_hw_params_set_buffer_time_near() won't fail any more
since sound chips require special containt power 2 period bytes
Signed-off-by: Raymond Yau <superquad.vortex2@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (308 commits)
ALSA: sound/pci/asihpi: check adapter index in hpi_ioctl
ALSA: aloop - Fix possible IRQ lock inversion
ALSA: sound/core: merge list_del()/list_add_tail() to list_move_tail()
ALSA: ctxfi - use list_move() instead of list_del()/list_add() combination
ALSA: firewire - msleep needs delay.h
ALSA: firewire-lib, firewire-speakers: handle packet queueing errors
ALSA: firewire-lib: allocate DMA buffer separately
ALSA: firewire-lib: use no-info SYT for packets without SYT sample
ALSA: add LaCie FireWire Speakers/Griffin FireWave Surround driver
ALSA: hda - Remove an unused variable in patch_realtek.c
ALSA: hda - pin-adc-mux-dmic auto-configuration of 92HD8X codecs
ALSA: hda - fix digital mic selection in mixer on 92HD8X codecs
ALSA: hda - Move default input-src selection to init part
ALSA: hda - Initialize special cases for input src in init phase
ALSA: ctxfi - Clear input settings before initialization
ALSA: ctxfi - Fix SPDIF status retrieval
ALSA: ctxfi - Fix incorrect SPDIF status bit mask
ALSA: ctxfi - Fix microphone boost codes/comments
ALSA: atiixp - Fix wrong time-out checks during ac-link reset
ALSA: intel8x0m: append 'm' to "r_intel8x0"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits)
doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore
Update cpuset info & webiste for cgroups
dcdbas: force SMI to happen when expected
arch/arm/Kconfig: remove one to many l's in the word.
asm-generic/user.h: Fix spelling in comment
drm: fix printk typo 'sracth'
Remove one to many n's in a word
Documentation/filesystems/romfs.txt: fixing link to genromfs
drivers:scsi Change printk typo initate -> initiate
serial, pch uart: Remove duplicate inclusion of linux/pci.h header
fs/eventpoll.c: fix spelling
mm: Fix out-of-date comments which refers non-existent functions
drm: Fix printk typo 'failled'
coh901318.c: Change initate to initiate.
mbox-db5500.c Change initate to initiate.
edac: correct i82975x error-info reported
edac: correct i82975x mci initialisation
edac: correct commented info
fs: update comments to point correct document
target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c
Trivial conflict in fs/eventpoll.c (spelling vs addition)
Add " Playback Volume" to 10 bands Equalizer Controls of au88x0 so that
alsa-lib won't regard them as "Capture Volume".
Fix a bunch of
warning: ‘inline’ is not at beginning of declaration
messages when building a 'make allyesconfig' kernel with -Wextra.
These warnings are trivial to kill, yet rather annoying when building with
-Wextra.
The more we can cut down on pointless crap like this the better (IMHO).
A previous patch to do this for a 'allnoconfig' build has already been
merged. This just takes the cleanup a little further.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Fix playback/capture channels patch to change supported playback
channels of au8830 to 1,2,4 and capture channels to 1,2.
This prevent oops when oss emulation use SNDCTL_DSP_CHANNELS to
set 3 Channels
Cc: <stable@kernel.org>
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net>
Use DEFINE_PCI_DEVICE_TABLE() to make PCI device ids go to
.devinit.rodata section, so they can be discarded in some cases,
and make them const.
The period_elapsed() call should be called when position moves.
The idea was taken from ALSA bug#4455.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
Appearently, the used mask in the .pointer callback is invalid. It should
be in period_bytes range. The period_bytes is pow(2), so simple bitwise
operation is used.
Idea was taken from ALSA bug#4455.
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)
Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com>
Fixed a typo of || and &&.
As it's in a disabled code section, there is no behavior change, though.
Reported-by: Jörg-Volker Peetz <jvpeetz@web.de>
Convert from snd_card_new() to the new snd_card_create() function
in sound/pci/*.
Use the newly introduced pci_ioremap_bar() function in sound/.
pci_ioremap_bar() just takes a pci device and a bar number, with the goal
of making it really hard to get wrong, while also having a central place
to stick sanity checks.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Clean up SG-buffer helper functions and macros. Helpers take substream
as arguments now.
As is the clipping ceiling loop appears wrong anyways
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
This patch removes CVS keywords that weren't updated for a long time
from comments.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
free_irq() calls synchronize_irq() for you, so there is no need for
drivers to manually do the same thing (again). Thus, calls where
sync-irq immediately precedes free-irq can be simplified.
However, during this audit several bugs were noticed, where free-irq is
preceded by a "irq >= 0" check... but the sync-irq call is not covered
by the same check.
So, where sync-irq could not be eliminated completely, the missing check
was added.
sound/pci/au88x0/au88x0_pcm.c:508:15: warning: Using plain integer as NULL pointer
Also some small codingstyle fixes.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
This header file exists only for some hacks to adapt alsa-driver
tree. It's useless for building in the kernel. Let's move a few
lines in it to sound/core.h and remove it.
With this patch, sound/driver.h isn't removed but has just a single
compile warning to include it. This should be really killed in
future.
Fix the various misspellings of "system", controller", "interrupt" and
"[un]necessary".
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
This patch fixes the code in vortex_wt_SetFrequency() to what seems to
have been intended.
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
In sound/pci/au88x0/au88x0.c::snd_vortex_create() :
The Coverity checker found that if we allocate storage for 'chip'
but then leave via the regions_out: label, then we end up leaking
the storage allocated for 'chip'.
I believe simply freeing 'chip' before the 'return err;' line is
all we need to fix this, but please double-check me :)
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Clean up codes using the new common snd_ctl_boolean_*_info() callbacks.
Instead of all drivers reading pci config space to get the revision
ID, they can now use the pci_device->revision member.
This exposes some issues where drivers where reading a word or a dword
for the revision number, and adding useless error-handling around the
read. Some drivers even just read it for no purpose of all.
In devices where the revision ID is being copied over and used in what
appears to be the equivalent of hotpath, I have left the copy code
and the cached copy as not to influence the driver's performance.
Compile tested with make all{yes,mod}config on x86_64 and i386.
Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
Acked-by: Dave Jones <davej@redhat.com>
Fix IRQ flags for PCI devices.
The shared IRQs for PCI devices shouldn't be allocated with
IRQF_DISABLED. Also, when MSI is enabled, IRQF_SHARED shouldn't
be used.
The patch removes unnecessary cast in request_irq and free_irq,
too.
Signed-off-by: Amol Lad <amol@verismonetworks.com>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
Fixed 'section mismatch' errors in ALSA PCI drivers:
- removed invalid __devinitdata from pci id tables
- fix/remove __devinit of functions called in suspend/resume
Cc: Jaroslav Kysela <perex@suse.cz>
Cc: Takashi Iwai <tiwai@suse.de>
Fix 64bit address of MPU401 MMIO port on au88x0 chip.
Change the 5th argument of snd_mpu401_uart_new() to bit flags
instead of a boolean. The argument takes bits that consist of
MPU401_INFO_XXX flags.
The callers that used the value 1 there are replaced with
MPU401_INFO_INTEGRATED.
Remove an unnecessary ENTER_UART instruction during au88x0 init as it makes
the first/subsequent midi open to fail.
Signed-off-by: Alan Horstmann <gineera@aspect135.co.uk>
Removed zero-initializations of static variables.
A tiny optimization.
Change the order in vortex_probe to set the card details before creating the
components, meaning for example that card->shortname is available when
registering the midi port.
I have also added extra to card->shortname, and a line to overwrite the midi
name following snd_mpu401_uart_new.
Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de>
