path: root/sound/oss/tuning.h
2017-10-31sound: Retire OSSTakashi Iwai
Since no complaints have been raised after disabling the build of OSS (Open Sound System) by the commit 31cbee6a5611 ("sound: Disable the build of OSS drivers"), let's finally drop the whole code and documentation. Some glue codes are still left intact since sound/oss/dmasound stuff remains -- which is an independent implementation solely for m68k, and it's not covered by ALSA yet. Also, a couple of API header files (linux/sound.h and linux/soundcard.h) are kept remaining as well, since the OSS API itself is still supported by ALSA OSS emulation, and applications can refer to these. Where we're at it, some help texts in the top-level Kconfig are adjusted, too (who still needs to specify I/O port in kbuild nowadays?). Reviewed-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-10-04[PATCH] The scheduled removal of some OSS driversAdrian Bunk
This patch contains the scheduled removal of OSS drivers that: - have ALSA drivers for the same hardware without known regressions and - whose Kconfig options have been removed in 2.6.17. [michal.k.k.piotrowski@gmail.com: build fix] Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
