path: root/sound/isa/wavefront
2013-11-13ALSA: isa: not allocating enough spaceDan Carpenter
We allocate only 4 bytes here "sizeof(int)" instead of WF_MSAMPLE_BYTES (259) which was intended. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-05-29ALSA: ISA: Remove superfluous *_set_drvdata(NULL) callsTakashi Iwai
Similarly like the previous commit for PCI drivers, remove dev_set_drvdata(NULL) and pnp_set_drvdata(NULL) calls in ISA drivers now. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-12-07ALSA: isa: remove __dev* attributesBill Pemberton
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-10-06sound: Remove unnecessary semicolonPeter Senna Tschudin
A simplified version of the semantic patch that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r1@ statement S; position p,p1; @@ S@p1;@p @script:python r2@ p << r1.p; p1 << r1.p1; @@ if p[0].line != p1[0].line_end: cocci.include_match(False) @@ position r1.p; @@ -;@p // </smpl> Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-12-19ALSA: module_param: make bool parameters really boolRusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-10-31sound: Add module.h to the previously silent sound usersPaul Gortmaker
Lots of sound drivers were getting module.h via the implicit presence of it in <linux/device.h> but we are going to clean that up. So fix up those users now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31sound: fix drivers needing module.h not moduleparam.hPaul Gortmaker
The implicit presence of module.h lured several users into incorrectly thinking that they only needed/used modparam.h but once we clean up the module.h presence, these will show up as build failures, so fix 'em now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-09-22sound: irq: Remove IRQF_DISABLEDYong Zhang
Since commit [e58aa3d2: genirq: Run irq handlers with interrupts disabled], We run all interrupt handlers with interrupts disabled and we even check and yell when an interrupt handler returns with interrupts enabled (see commit [b738a50a: genirq: Warn when handler enables interrupts]). So now this flag is a NOOP and can be removed. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-09-14ALSA: mpu401: clean up interrupt specificationClemens Ladisch
The semantics of snd_mpu401_uart_new()'s interrupt parameters are somewhat counterintuitive: To prevent the function from allocating its own interrupt, either the irq number must be invalid, or the irq_flags parameter must be zero. At the same time, the irq parameter being invalid specifies that the mpu401 code has to work without an interrupt allocated by the caller. This implies that, if there is an interrupt and it is allocated by the caller, the irq parameter must be set to a valid-looking number which then isn't actually used. With the removal of IRQF_DISABLED, zero becomes a valid irq_flags value, which forces us to handle the parameters differently. This patch introduces a new flag MPU401_INFO_IRQ_HOOK for when the device interrupt is handled by the caller, and makes the allocation of the interrupt to depend only on the irq parameter. As suggested by Takashi, the irq_flags parameter was dropped because, when used, it had the constant value IRQF_DISABLED. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-04-15Merge branch 'topic/memdup_user' into for-linusTakashi Iwai
* topic/memdup_user: ALSA: sound/pci: use memdup_user() ALSA: sound/usb: use memdup_user() ALSA: sound/isa: use memdup_user() ALSA: sound/core: use memdup_user()
2009-04-14ALSA: sound/isa: use memdup_user()Li Zefan
Remove open-coded memdup_user(). Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-06ALSA: wavefront - Always use request_firmware()Takashi Iwai
Always use request_firmware() for loading yss225_registers image. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-02-16Merge branch 'topic/snd_card_new-err' into topic/cs423x-mergeTakashi Iwai
2009-02-05ALSA: isa/*: Add missing KERN_* prefix to printkTakashi Iwai
2009-01-12ALSA: Return proper error code at probe in sound/isa/*Takashi Iwai
Some drivers in sound/isa/* don't handle the error code properly from snd_card_create(). This patch fixes these places. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-12ALSA: Convert to snd_card_create() in sound/isa/*Takashi Iwai
Convert from snd_card_new() to the new snd_card_create() function. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-08-13ALSA: Kill snd_assert() in sound/isa/*Takashi Iwai
Kill snd_assert() in sound/isa/*, either removed or replaced with if () with snd_BUG_ON(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-06ALSA: wss_lib: rename cs4321_foo to wss_fooKrzysztof Helt
Rename functions and structures from the former cs4321_lib to names more corresponding with the new name: wss_lib. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Reviewed-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-06ALSA: wss_lib: rename cs4231.h into wss.hKrzysztof Helt
Rename file include/sound/cs4231.h into include/sound/wss.h Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Reviewed-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-10ALSA: wavefront - add constTakashi Iwai
Fix const to non-const pointer cast warning in wavefront_synth.c. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] sound/isa: kill pnp_resource_changeRene Herman
This removes the pnp_resource_change use from the ALSA ISAPnP drivers. In 2.4 these were useful in providing an easy path to setting the resources, but in 2.6 they retain function as a layering violation only. This makes for a nice cleanup (-550 lines) of ALSA but moreover, ALSA is the only remaining user of pnp_init_resource_table(), pnp_resource_change() and pnp_manual_config_dev() (and, in fact, of 'struct pnp_resource_table') in the tree outide of drivers/pnp itself meaning it makes for more cleanup potential inside the PnP layer. Thomas Renninger acked their removal from that side, you did from the ALSA side (CC list just copied from that thread). Against current alsa-kernel HG. Many more potential cleanups in there, but this _only_ removes the pnp_resource_change code. Compile tested against current alsa-kernel HG and compile- and use-tested against 2.6.23.x (few offsets). Cc: Thomas Renninger <trenn@suse.de> Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
2007-10-16[ALSA] alsa-kernel: schedule_timeout() fixesRene Herman
Fix schedule_timeout() use in alsa-kernel. Mostly just schedule_timeout(1) --> schedule_timeout_uninterruptible(1) The wavefront_synth one fixes the surrounding loop as well. In ymfpci_main, delete a superfluous set_current_state() and in soc/soc-dapm.c replace an _interruptible with _uninterruptible in some debug code; it's not waiting for signals. Signed-off-by: Rene Herman <rene.herman> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] wavefront - Use standard firmware loaderTakashi Iwai
Use the standard firmware loader for loading ICS2115 OS firmware file. This is the last old bad guy that is still using sys_open() and sys_read() calls, and now all should be gone. The patch also adds the missing description of module options related with wavefront_synth.c. Due to this rewrite, user will have to copy or make symlink the firmware file appropriately to the standard firmware path such as /lib/firmware. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] Fix invalid schedule_timeout_interruptible()Takashi Iwai
Fixed the invalid use of schedule_timeout_interruptible() without checking pending signals. Simply replaced with schedule_timeout(). Suggestions thanks to Jeff Garzik. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-16[ALSA] Fix probe of non-PnP ISA devicesRene Herman
isa_register_driver() returns an error if no device is found and it's no fatal error for the drivers with pnp support. Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] wavefront: only declare isapnp on CONFIG_PNPDavid Rientjes
From: David Rientjes <rientjes@google.com> isapnp[] is only used for CONFIG_PNP. If this configuration option is not set, do not declare the array. Cc: Adam Belay <ambx1@neo.rr.com> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] add MODULE_FIRMWARE entriesClemens Ladisch
Add MODULE_FIRMWARE() entries, where appropriate. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] Don't use request_firmware if internal firmwares are definedTakashi Iwai
Don't use request_firmware() if the internal firmwares are defined via Kconfig. Otherwise it results in a significant delay at loading time (minutes). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] isa_bus device/driver namingRene Herman
isa_bus: delete snd_ prefix from the (sysfs visible) device/driver names. Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] Enable Kconfig options for external firmwaresTakashi Iwai
Some drivers are already ifdefs for enabling external firmwares but not defined in Kconfig. Now they appear as the kernel configs. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] Port the rest of ALSA ISA drivers to isa_driverTakashi Iwai
Port the rest of ALSA ISA drivers to use isa_driver framework instead of platform_driver. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] wavefront: add request_firmware()Clemens Ladisch
Load the YSS225 register initialization data using request_firmware(), if possible, instead of using the built-in data blob. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] wavefront: simplify YSS225 register initializationClemens Ladisch
Instead of using a somewhat algorithmic approach of initializing the YSS225's registers, just use a simple series of port/value pairs. This makes it easier to later replace or entirely remove the register data blob. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] use the ALIGN macroClemens Ladisch
Use the ALIGN macro instead of manual calculations. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-12[ALSA] wavefront: fix __init/__devinit confusionClemens Ladisch
The wavefront driver used __init in some places referenced by __devinit functions. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-02[PATCH] irq-flags: sound: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-22[ALSA] Remove zero-initialization of static variablesTakashi Iwai
Removed zero-initializations of static variables. A tiny optimization. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-12[ALSA] unregister platform device again if probe was unsuccessfulRene Herman
Unregister the platform device again if the probe was unsuccessful. This restores the behaviour of not loading the driver on probe() failure. Signed-off-by: Rene Herman <rene.herman@keyaccess.nl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-12[ALSA] continue on IS_ERR from platform device registrationRene Herman
Continue with the next one on error from device registration. This would seem the correct thing to do, even if it's not the probe() error that we're getting. Signed-off-by: Rene Herman <rene.herman@keyaccess.nl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-27[PATCH] PNP: adjust pnp_register_card_driver() signature: wavefrontBjorn Helgaas
Remove the assumption that pnp_register_card_driver() returns the number of devices claimed. And fix some __init/__devinit issues. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Jaroslav Kysela <perex@suse.cz> Acked-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[ALSA] Fix check of enable module optionTakashi Iwai
Fix the check of enable module option in probe of platform_device drivers. It shouldn't break the loop but just ignore if enable[i] is false. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-02-01[ALSA] wavefront - Fix a compile warningTakashi Iwai
Modules: Wavefront drivers Fix a gcc-4.1 compile warning regarding uninitialized variables. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-22[ALSA] Fix compilation without CONFIG_PNPTakashi Iwai
Fix compilation of some ISA drivers without CONFIG_PNP. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-08[PATCH] remove gcc-2 checksAndrew Morton
Remove various things which were checking for gcc-1.x and gcc-2.x compilers. From: Adrian Bunk <bunk@stusta.de> Some documentation updates and removes some code paths for gcc < 3.2. Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[ALSA] unregister platform devicesClemens Ladisch
Call platform_device_unregister() for all platform devices that we've registered. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
