path: root/sound/isa/sb
2005-08-30[ALSA] sound - fix .iface field of mixer control elementsClemens Ladisch
Documentation,CS46xx driver,EMU10K1/EMU10K2 driver,AD1848 driver SB16/AWE driver,CMIPCI driver,ENS1370/1+ driver,RME32 driver RME96 driver,ICE1712 driver,ICE1724 driver,KORG1212 driver RME HDSP driver,RME9652 driver This patch changes .iface to SNDRV_CTL_ELEM_IFACE_MIXER whre _PCM or _HWDEP was used in controls that are not associated with a specific PCM (sub)stream or hwdep device, and changes some controls that got inconsitent .iface values due to copy+paste errors. Furthermore, it makes sure that all control that do use _PCM or _HWDEP use the correct number in the .device field. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-07-27[PATCH] clean up inline static vs static inlineJesper Juhl
`gcc -W' likes to complain if the static keyword is not at the beginning of the declaration. This patch fixes all remaining occurrences of "inline static" up with "static inline" in the entire kernel tree (140 occurrences in 47 files). While making this change I came across a few lines with trailing whitespace that I also fixed up, I have also added or removed a blank line or two here and there, but there are no functional changes in the patch. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] turn many #if $undefined_string into #ifdef $undefined_stringOlaf Hering
turn many #if $undefined_string into #ifdef $undefined_string to fix some warnings after -Wno-def was added to global CFLAGS Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
