path: root/sound/isa/ad1816a
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] sound/isa: kill pnp_resource_changeRene Herman
This removes the pnp_resource_change use from the ALSA ISAPnP drivers. In 2.4 these were useful in providing an easy path to setting the resources, but in 2.6 they retain function as a layering violation only. This makes for a nice cleanup (-550 lines) of ALSA but moreover, ALSA is the only remaining user of pnp_init_resource_table(), pnp_resource_change() and pnp_manual_config_dev() (and, in fact, of 'struct pnp_resource_table') in the tree outide of drivers/pnp itself meaning it makes for more cleanup potential inside the PnP layer. Thomas Renninger acked their removal from that side, you did from the ALSA side (CC list just copied from that thread). Against current alsa-kernel HG. Many more potential cleanups in there, but this _only_ removes the pnp_resource_change code. Compile tested against current alsa-kernel HG and compile- and use-tested against 2.6.23.x (few offsets). Cc: Thomas Renninger <trenn@suse.de> Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
2007-10-16[ALSA] remove incorrect usage of SNDRV_PCM_INFO_SYNC_START and ↵Clemens Ladisch
snd_pcm_set_sync() Set the SNDRV_PCM_INFO_SYNC_START flag and the substream's sync ID (only) if the substream actually can be linked to another one. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] ad1816a: Fix modprobe snd_mpu401 && modprobe snd_ad1816aRask Ingemann Lambertsen
The ad1816a driver fails if the mpu401 driver has been loaded first. This patch against linux 2.6.20 fixes it by just ignoring the MPU-401 device in that case, so that the rest of the sound card can be used. The ad1816a driver already handles the MPU-401 device being unavailable due to lack of resources in the same way. Signed-off-by: Rask Ingemann Lambertsen <rask@sygehus.dk> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Add even more 'const' to everything related to TLVTakashi Iwai
Mark TLV data as 'const' Signed-of-by: Philipp Matthias Hahn <pmhahn@pmhahn.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-10-22[ALSA] sound/isa/ad1816a/ad1816a.c: check kmalloc() return valueAmit Choudhary
Check the return value of kmalloc() in function snd_card_ad1816a_pnp(), in file sound/isa/ad1816a/ad1816a.c. Signed-off-by: Amit Choudhary <amit2030@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-23[ALSA] Add dB scale information to ad1816a driverTakashi Iwai
Added the dB scale information to ad1816a driver. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-02[PATCH] irq-flags: sound: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] PNP: adjust pnp_register_card_driver() signature: ad1816aBjorn Helgaas
Remove the assumption that pnp_register_card_driver() returns the number of devices claimed. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Jaroslav Kysela <perex@suse.cz> Acked-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[ALSA] ad1816a - Fix PCM trigger directionKen Arromdee
Modules: AD1816A driver Fixed the bug of capture with Shark Predator ISA resulting in: arecord: pcm_read:1196: read error: Input/output error Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Merge ad1816a-lib module to ad1816aTakashi Iwai
Modules: AD1816A driver Merge ad1816a-lib module to ad1816. There is no more reason to split. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] ad1816a - Clean up PnP codeTakashi Iwai
Modules: AD1816A driver Clean up PnP code of ad1816a driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: ISA AD1816ATakashi Iwai
Modules: AD1816A driver Remove xxx_t typedefs from the ISA AD1816A driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove superfluous pcm_free callbacksTakashi Iwai
Remove superflous pcm_free callbacks. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Remove vmalloc wrapper, kfree_nocheck()Takashi Iwai
- Remove vmalloc wrapper - Add release_and_free_resource() to remove kfree_nocheck() from each driver and simplify the code Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] Replace with kzalloc() - isa stuffTakashi Iwai
ES18xx driver,OPL3SA2 driver,AD1816A driver,AD1848 driver,CS4231 driver ES1688 driver,GUS Library,Opti9xx drivers,EMU8000 driver SB16/AWE driver,SB drivers Replace kcalloc(1,..) with kzalloc(). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-08-30[ALSA] ad1816a - Add clockfreq module optionTakashi Iwai
Documentation,AD1816A driver Added clockfreq module option for the card with a different clock frequency than 33kHz. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-05-29[ALSA] Add PnP ID ADS7180Takashi Iwai
AD1816A driver Added PnP ID 'ADS7180' (AD1816?). Signed-off-by: Takashi Iwai <tiwai@suse.de>
