Change-Id: Ib3b69ffc5ac3e07c9cc44cc49e9142088eec477e
Lots of sound drivers were getting module.h via the implicit presence
of it in <linux/device.h> but we are going to clean that up. So
fix up those users now.
Drop a few variables that are never read.
Signed-off-by: Luca Tettamanti <kronos.it@gmail.com>
The card-id parser assigns the string "default" when no appropriate word
is found in the card name. But this string may confuse the alsa-lib, so
better to avoid. Use "Default" now instead.
This patch fixes a race between snd_card_file_remove() and
snd_card_disconnect(). When the card is added to shutdown_files list
in snd_card_disconnect(), but it's freed in snd_card_file_remove() at
the same time, the shutdown_files list gets corrupted. The list member
must be freed in snd_card_file_remove() as well.
Reported-and-tested-by: Russ Dill <russ.dill@gmail.com>
Cc: <stable@kernel.org>
"gadget", "through", "command", "maintain", "maintain", "controller", "address",
"between", "initiali[zs]e", "instead", "function", "select", "already",
"equal", "access", "management", "hierarchy", "registration", "interest",
"relative", "memory", "offset", "already",
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (365 commits)
ALSA: hda - Disable sticky PCM stream assignment for AD codecs
ALSA: usb - Creative USB X-Fi volume knob support
ALSA: ca0106: Use card specific dac id for mute controls.
ALSA: ca0106: Allow different sound cards to use different SPI channel mappings.
ALSA: ca0106: Create a nice spot for mapping channels to dacs.
ALSA: ca0106: Move enabling of front dac out of hardcoded setup sequence.
ALSA: ca0106: Pull out dac powering routine into separate function.
ALSA: ca0106 - add Sound Blaster 5.1vx info.
ASoC: tlv320dac33: Use usleep_range for delays
ALSA: usb-audio: add Novation Launchpad support
ALSA: hda - Add workarounds for CT-IBG controllers
ALSA: hda - Fix wrong TLV mute bit for STAC/IDT codecs
ASoC: tpa6130a2: Error handling for broken chip
ASoC: max98088: Staticise m98088_eq_band
ASoC: soc-core: Fix codec->name memory leak
ALSA: hda - Apply ideapad quirk to Acer laptops with Cxt5066
ALSA: hda - Add some workarounds for Creative IBG
ALSA: hda - Fix wrong SPDIF NID assignment for CA0110
ALSA: hda - Fix codec rename rules for ALC662-compatible codecs
ALSA: hda - Add alc_init_jacks() call to other codecs
This patch removes the old CONFIG_SYSFS_DEPRECATED_V2 config option,
but it keeps the logic around to handle block devices in the old manner
as some people like to run new kernel versions on old (pre 2007/2008)
distros.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Cc: Stephen Hemminger <shemminger@vyatta.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: "James E.J. Bottomley" <James.Bottomley@suse.de>
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Jaroslav Kysela <perex@perex.cz>
Cc: Takashi Iwai <tiwai@suse.de>
When user want to change the card id to the same string
on the card via /sys/class/sound/cardX/id, do not
report error. Instead return with success without
doing anything.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
The struct snd_monitor_file is used locally only in sound/core/init.c,
thus it should be moved there from the public sound/core.h.
Move locking outside snd_card_set_id_internal() function and rename it
to snd_card_set_id_no_lock() for better function description.
User defined id is just copied to card structure at allocation time.
The real unique id procedure is called in snd_card_register() to
ensure real atomicity.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
The introduction of snd_card_set_id() added a lock on the card list
to the old choose_default_id() function when using it to implement
the new API call. This lock is needed to allow us to walk the list
and check to see if our new name is a duplicate. Unfortunately this
causes a lockup when called from snd_card_register() (in cases
where no ID is supplied for the card) since the card list is already
locked there.
Fix this fairly hideously by factoring out the implementation and
using a flag to indicate if the lock should be held. A better fix
would probably be to refactor snd_card_register() to move the
_set_id() outside the locking region but I can't immediately see
anything I can convince myself is safe.
Introduce snd_card_set_id() function to allow lowlevel drivers to set
default identification name for card slot. The function checks also
for identification name collisions and tries to create unique name.
Also, the snd_card_create() function is simplified, because this new
function is used. As bonus, proper name collision checks are evaluated
at the card create time.
Use the standard linked list for snd_monitor_file management.
Also, move the list deletion of shutdown_list element into
snd_disconnect_release() (for simplification).
Introduced snd_card_create() function as a replacement of snd_card_new().
The new function returns a negative error code so that the probe callback
can return the proper error code, while snd_card_new() can give only NULL
check.
The old snd_card_new() is still provided as an inline function but with
__deprecated attribute. It'll be removed soon later.
Do not ignore the return of 'device_create_file' in
'snd_card_register' and thereby fixing the following warnings:
sound/core/init.c: In function 'snd_card_register':
sound/core/init.c:640: warning: ignoring return value of
'device_create_file', declared with attribute warn_unused_result
sound/core/init.c:641: warning: ignoring return value of
Signed-off-by: Hannes Eder <hannes@hanneseder.net>
For udev, we need a way to rename soundcard names. The soundcard numbers
(indexes) are hardwired but we have a text identification which can be
changed at run-time. The ALSA user space tools already allow using of
this text identification.
As it is, all instances of ->release() for files that have ->fasync()
need to remember to evict file from fasync lists; forgetting that
creates a hole and we actually have a bunch that *does* forget.
So let's keep our lives simple - let __fput() check FASYNC in
file->f_flags and call ->fasync() there if it's been set. And lose that
crap in ->release() instances - leaving it there is still valid, but we
don't have to bother anymore.
Now that device_create() has been audited, rename things back to the
original call to be sane.
Kill snd_assert() in sound/core/*, either removed or replaced with
if () with snd_BUG_ON().
device_create() is race-prone, so use the race-free
device_create_drvdata() instead as device_create() is going away.
Fix and improve the slots option handling. The sound core tries to
find the slot with the given module name first and assign if it's
still available. If all pre-given slots are unavailable, then try
to find another free slot.
Also, when a module name begins with '!', it means the negative match:
the slot will be given for any modules but that one.
A little clean up of snd_card_free*().
Removed snd_card_free_prepare() since it's actually almost identical
with snd_card_disconnect().
Move the call of device_unregister() for the card instance in
snd_card_disconnect() to avoid the race of sysfs card entry, which
can be typically found on usb-audio reconnection.
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
'snd_shutdown_f_ops' is not a pointer so its address will never be NULL.
GCC will complain because 'fops_get' will do an unnecessary check because
'&snd_shutdown_f_ops' is always true.
Signed-off-by: Miguel Boton <mboton@gmail.com>
This header file exists only for some hacks to adapt alsa-driver
tree. It's useless for building in the kernel. Let's move a few
lines in it to sound/core.h and remove it.
With this patch, sound/driver.h isn't removed but has just a single
compile warning to include it. This should be really killed in
future.
Introduced the global 'slots' option to snd module. This option provides
an alternative way to handle the order of multiple sound card instances.
It's an easier approach to avoid conflict with hotplug devices, and can
be used together with the existing 'order' option of each card driver.
I noticed that many source files include <linux/pci.h> while they do
not appear to need it. Here is an attempt to clean it all up.
In order to find all possibly affected files, I searched for all
files including <linux/pci.h> but without any other occurence of "pci"
or "PCI". I removed the include statement from all of these, then I
compiled an allmodconfig kernel on both i386 and x86_64 and fixed the
false positives manually.
My tests covered 66% of the affected files, so there could be false
positives remaining. Untested files are:
arch/alpha/kernel/err_common.c
arch/alpha/kernel/err_ev6.c
arch/alpha/kernel/err_ev7.c
arch/ia64/sn/kernel/huberror.c
arch/ia64/sn/kernel/xpnet.c
arch/m68knommu/kernel/dma.c
arch/mips/lib/iomap.c
arch/powerpc/platforms/pseries/ras.c
arch/ppc/8260_io/enet.c
arch/ppc/8260_io/fcc_enet.c
arch/ppc/8xx_io/enet.c
arch/ppc/syslib/ppc4xx_sgdma.c
arch/sh64/mach-cayman/iomap.c
arch/xtensa/kernel/xtensa_ksyms.c
arch/xtensa/platform-iss/setup.c
drivers/i2c/busses/i2c-at91.c
drivers/i2c/busses/i2c-mpc.c
drivers/media/video/saa711x.c
drivers/misc/hdpuftrs/hdpu_cpustate.c
drivers/misc/hdpuftrs/hdpu_nexus.c
drivers/net/au1000_eth.c
drivers/net/fec_8xx/fec_main.c
drivers/net/fec_8xx/fec_mii.c
drivers/net/fs_enet/fs_enet-main.c
drivers/net/fs_enet/mac-fcc.c
drivers/net/fs_enet/mac-fec.c
drivers/net/fs_enet/mac-scc.c
drivers/net/fs_enet/mii-bitbang.c
drivers/net/fs_enet/mii-fec.c
drivers/net/ibm_emac/ibm_emac_core.c
drivers/net/lasi_82596.c
drivers/parisc/hppb.c
drivers/sbus/sbus.c
drivers/video/g364fb.c
drivers/video/platinumfb.c
drivers/video/stifb.c
drivers/video/valkyriefb.c
include/asm-arm/arch-ixp4xx/dma.h
sound/oss/au1550_ac97.c
I would welcome test reports for these files. I am fine with removing
the untested files from the patch if the general opinion is that these
changes aren't safe. The tested part would still be nice to have.
Note that this patch depends on another header fixup patch I submitted
to LKML yesterday:
[PATCH] scatterlist.h needs types.h
http://lkml.org/lkml/2007/3/01/141
Cc: Badari Pulavarty <pbadari@us.ibm.com>
Many struct file_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Make the control flow clear with indentation, adds some comments
and improves error reporting.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
The recent change for a new sysfs tree with card* object breaks the
/sys/class/sound tree if CONFIG_SYSFS_DEPRECATED is enabled.
The device in each entry doesn't point the correct device object:
/sys/class/sound
|-- pcmC0D0c
| |-- dev
| |-- device -> ../../../class/sound/card0
| |-- pcm_class
| |-- power
| | `-- wakeup
| |-- subsystem -> ../../../class/sound
| `-- uevent
Also, this change breaks some drivers (like sound/arm/*) referring
card->dev directly to obtain the device object for memory handling.
This patch reverts the semantics of card->dev to the former version,
which points to a real device object. The card* object is stored in a
new card->card_dev field, instead. The device parent is chosen either
card->dev or card->card_dev according to CONFIG_SYSFS_DEPRECATED to
keep the tree compatibility.
Also, card* isn't created if CONFIG_SYSFS_DEPRECATED is enabled. The
reason of card* object is a root of all beloing devices, and it makes
little sense if each sound device points to the real device object
directly.
Acked-by: Monty Montgomery <xiphmont@gmail.com>
Converts from using struct "class_device" to "struct device" making
everything show up properly in /sys/devices/ with symlinks from the
/sys/class directory.
It also makes the struct sound_card to show up as a "real" device
where all the different sound class devices are placed as childs
and different card attribute files can hang off of. /sys/class/sound is
still a flat directory, but the symlink targets of all devices belonging
to the same card, point the the /sys/devices tree below the new card
device object.
Thanks to Kay for the updates to this patch.
Signed-off-by: Kay Sievers <kay.sievers@novell.com>
Acked-by: Jaroslav Kysela <perex@suse.cz>
file->f_op
Alsa used to kmalloc one file->f_op per file per disconnecting snd_card.
This led to oopses sometimes when file->f_op was freed before __fput()
finished.
Patch adds a virtual device for disconnect: VDD.
VDD consists of:
LIST_HEAD(shutdown_files)
protected by DEFINE_SPINLOCK(shutdown_mutex)
static struct file_operations snd_shutdown_f_ops
and functions assigned to it
Additions to struct snd_monitor_file
to specify if instance is hidden by VDD or not.
A VDD's instance is
created in snd_card_disconnect() under the card->files_lock.
cleaned up in snd_card_file_remove() under the card->files_lock.
Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de>
Deprecated snd_card_free_in_thread(), replaced with
snd_card_free_when_closed().
Orignally proposed by Sam Revitch <sam.revitch@gmail.com>.
Unregister device files at disconnection to avoid the futher accesses.
Also, the dev_unregister callback is removed and replaced with the
combination of disconnect + free.
A new function snd_card_free_when_closed() is introduced, which is
used in USB disconnect callback.
- Add the linked list to each proc entry to enable a single-shot
disconnection (unregister)
- Deprecate snd_info_unregister(), use snd_info_free_entry()
- Removed NULL checks of snd_info_free_entry()
Removed zero-initializations of static variables.
A tiny optimization.
Fixed rwlock around snd_iprintf() in sound core part.
Replaced with mutex.
Also, make mutex and flags static variables with addition of
snd_card_locked() function (just for sound.c).
Remove unneeded read/write_size fields in proc text ops.
snd_info_set_text_ops() is fixed, too.
Move EXPORT_SYMBOL()s to places adjacent to functions/variables.
Removed the unused file argument of snd_power_wait().
Mark the f_ops members of inodes as const, as well as fix the
ripple-through this causes by places that copy this f_ops and then "do
stuff" with it.
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
Modules: ALSA Core
Add dummy functions that return -ENODEV for the struct file_operations
of a disconnected device. Without such functions, userspace would get
ENOTTY.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Semaphore to mutex conversion.
The conversion was generated via scripts, and the result was validated
automatically via a script as well.
Modules: HWDEP Midlevel,ALSA Core,PCM Midlevel,Timer Midlevel
Optimize the code when compiled without CONFIG_PROC_FS.
Modules: ALSA Core,Memalloc module,ALSA sequencer
With dynamic minor numbers, we can increase the number of sound cards.
This requires that the sequencer client numbers of some kernel drivers
are allocated dynamically, too.
