path: root/sound/arm
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-27sound: Convert to menuconfigTakashi Iwai
Convert menu in sound Kconfig files to menuconfig and if. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-27[ALSA] remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] pxa2xx-ac97: Support PXA3xx AC97Mark Brown
Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable sound platform drivers, to re-enable auto loading. [dbrownell@users.sourceforge.net: more drivers, registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: replace remaining __FUNCTION__ occurencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-19[ARM] pxa: separate GPIOs and their mode definitions to pxa2xx-gpio.heric miao
two reasons: 1. GPIO namings and their mode definitions are conceptually not part of the PXA register definitions 2. this is actually a temporary move in the transition of PXA2xx to use MFP-alike APIs (as what PXA3xx is now doing), so that legacy code will still work and new code can be added in step by step Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] 4833/3: Convert non-SoC PXA2xx AC97 driver to clock APIMark Brown
Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Takashi Iwai <tiwai@suse.de> Acked-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] Add missing device linkTakashi Iwai
Added the missing link to struct device from the card instance. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-12-08[ARM] 4690/1: PXA: fix CKEN corruption in PXA27x AC97 cold reset codeMichael Brunner
Fix CKEN register corruption in the PXA27x cold reset code located in sound/arm/pxa27x-ac97.c. The problem has been introduced with a pxa_set_cken() function change in linux 2.6.23. This patch is based on patch 4527/1 that fixes the same problem in the ASoC PXA-AC97 driver. Additionally a definition for the CKEN index value is added and applied to both PXA AC97 drivers. Signed-off-by: Michael Brunner <mibru@gmx.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-18Add missing newlines to some uses of dev_<level> messagesJoe Perches
Found these while looking at printk uses. Add missing newlines to dev_<level> uses Add missing KERN_<level> prefixes to multiline dev_<level>s Fixed a wierd->weird spelling typo Added a newline to a printk Signed-off-by: Joe Perches <joe@perches.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Mark M. Hoffman <mhoffman@lightlink.com> Cc: Roland Dreier <rolandd@cisco.com> Cc: Tilman Schmidt <tilman@imap.cc> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Greg KH <greg@kroah.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: James Smart <James.Smart@Emulex.Com> Cc: Andrew Vasquez <andrew.vasquez@qlogic.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16[ALSA] Get rid of dead code in sound/arm/sa11xx-uda1341.cMichal Piotrowski
File /home/devel/linux-rdc/sound/arm/sa11xx-uda1341.c line 82 Unknown CONFIG option! CONFIG_H3600_HAL File /home/devel/linux-rdc/sound/arm/sa11xx-uda1341.c line 103 Unknown CONFIG option! CONFIG_H3600_HAL File /home/devel/linux-rdc/sound/arm/sa11xx-uda1341.c line 241 Unknown CONFIG option! CONFIG_H3600_HAL File /home/devel/linux-rdc/sound/arm/sa11xx-uda1341.c line 310 Unknown CONFIG option! CONFIG_H3600_HAL File /home/devel/linux-rdc/sound/arm/sa11xx-uda1341.c line 334 Unknown CONFIG option! CONFIG_H3600_HAL File /home/devel/linux-rdc/sound/arm/sa11xx-uda1341.c line 344 Unknown CONFIG option! CONFIG_H3600_HAL File /home/devel/linux-rdc/sound/arm/sa11xx-uda1341.c line 357 Unknown CONFIG option! CONFIG_H3600_HAL Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-02[ARM] 4458/1: pxa: Fix CKEN usage and hence fix pxa suspend/resumeRichard Purdie
The PXA CKEN changes broken syspend/resume on the pxa27x. This patch corrects the problem and fixes another couple of bad references. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-06-01potential parse error in ifdefYoann Padioleau
I have made a tool to parse the kernel that does not pre-process the source. That means that my parser tries to parse all the code, including code in the #else branch or code that is not often compiled because the driver is not very used (or not used at all). So, my parser sometimes reports parse error not originally detected by gcc. Here is my (first) patch. [akpm@linux-foundation.org: fix amd8111e.c] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Acked-by: Matthew Wilcox <matthew@wil.cx> Acked-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: David Woodhouse <dwmw2@infradead.org> Acked-by: Jeff Garzik <jeff@garzik.org> Acked-by: James Bottomley <James.Bottomley@steeleye.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-21[ARM] 4304/1: removes the unnecessary bit number from CKENnn_XXXXEric Miao
This patch removes the unnecessary bit number from CKENnn_XXXX definitions for PXA, so that CKEN0_PWM0 --> CKEN_PWM0 CKEN1_PWM1 --> CKEN_PWM1 ... CKEN24_CAMERA --> CKEN_CAMERA The reasons for the change of these defitions are: 1. they do not scale - they are currently valid for pxa2xx, but definitely not valid for pxa3xx, e.g., pxa3xx has bit 3 for camera instead of bit 24 2. they are unnecessary - the peripheral name within the definition has already announced its usage, we don't need those bit numbers to know which peripheral we are going to enable/disable clock for 3. they are inconvenient - think about this: a driver programmer for pxa has to remember which bit in the CKEN register to turn on/off Another change in the patch is to make the definitions equal to its clock bit index, so that #define CKEN_CAMERA (24) instead of #define CKEN_CAMERA (1 << 24) this change, however, will add a run-time bit shift operation in pxa_set_cken(), but the benefit of this change is that it scales when bit index exceeds 32, e.g., pxa3xx has two registers CKENA and CKENB, totally 64 bit for this, suppose CAMERA clock enabling bit is CKENB:10, one can simply define CKEN_CAMERA to be (32 + 10) and so that pxa_set_cken() need minimum change to adapt to that. Signed-off-by: eric miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-20[ARM] Fix ARM AACI ALSA driverRussell King
CC [M] sound/arm/aaci.o sound/arm/aaci.c:729: error: parse error before '*' token sound/arm/aaci.c:731: warning: function declaration isn't a prototype ... sound/arm/aaci.c:786: error: parse error before '*' token sound/arm/aaci.c:786: warning: function declaration isn't a prototype ... sound/arm/aaci.c:827: error: parse error before '*' token sound/arm/aaci.c:828: warning: function declaration isn't a prototype ... sound/arm/aaci.c:845: error: parse error before "aaci_capture_ops" sound/arm/aaci.c:845: warning: type defaults to `int' in declaration of `aaci_capture_ops' Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-19Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (117 commits) [ARM] 4058/2: iop32x: set ->broken_parity_status on n2100 onboard r8169 ports [ARM] 4140/1: AACI stability add ac97 timeout and retries [ARM] 4139/1: AACI record support [ARM] 4138/1: AACI: multiple channel support for IRQ handling [ARM] 4211/1: Provide a defconfig for ns9xxx [ARM] 4210/1: base for new machine type "NetSilicon NS9360" [ARM] 4222/1: S3C2443: Remove reference to missing S3C2443_PM [ARM] 4221/1: S3C2443: DMA support [ARM] 4220/1: S3C24XX: DMA system initialised from sysdev [ARM] 4219/1: S3C2443: DMA source definitions [ARM] 4218/1: S3C2412: fix CONFIG_CPU_S3C2412_ONLY wrt to S3C2443 [ARM] 4217/1: S3C24XX: remove the dma channel show at startup [ARM] 4090/2: avoid clash between PXA and SA1111 defines [ARM] 4216/1: add .gitignore entries for ARM specific files [ARM] 4214/2: S3C2410: Add Armzone QT2410 [ARM] 4215/1: s3c2410 usb device: per-platform vbus_draw [ARM] 4213/1: S3C2410 - Update definition of ADCTSC_XY_PST [ARM] 4098/1: ARM: rtc_lock only used with rtc_cmos [ARM] 4137/1: Add kexec support [ARM] 4201/1: SMP barriers pair needed for the secondary boot process ... Fix up conflict due to typedef removal in sound/arm/aaci.h
2007-02-18[ARM] 4140/1: AACI stability add ac97 timeout and retriesKevin Hilman
Add timeouts to hardware read/write/probe functions in order to avoid lockups on buggy/broken hardware. Signed-off-by: Kevin Hilman <khilman@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-18[ARM] 4139/1: AACI record supportKevin Hilman
Add PCM audio capture support for AACI audio on Versatile platform. Signed-off-by: Kevin Hilman <khilman@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-18[ARM] 4138/1: AACI: multiple channel support for IRQ handlingKevin Hilman
Add AACI channel support to interrupt handler. Also, clear underrun interrupt for correct channel. Signed-off-by: Kevin Hilman <khilman@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-14[ALSA] Fix __devinit and __devexit issues with sound driversPrarit Bhargava
Fix __devinit and __devexit issues with sound drivers. Resolves MODPOST warnings similar to: WARNING: sound/drivers/snd-dummy.o - Section mismatch: reference to .init.text:snd_dummy_probe from .data.rel.local between 'snd_dummy_driver' (at offset 0x0) and 'snd_dummy_controls' WARNING: sound/drivers/snd-mtpav.o - Section mismatch: reference to .init.text:snd_mtpav_probe from .data.rel.local between 'snd_mtpav_driver' (at offset 0x0) and 'snd_mtpav_input' WARNING: sound/drivers/snd-virmidi.o - Section mismatch: reference to .init.text:snd_virmidi_probe from .data.rel.local after 'snd_virmidi_driver' (at offset 0x0) Signed-off-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] arm header fixAndrew Morton
Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-07[PATCH] make 1-bit bitfields unsignedMariusz Kozlowski
Keeps sparse happy. Signed-of-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-02[PATCH] irq-flags: sound: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] 64bit resource: fix up printks for resources in sound driversGreg Kroah-Hartman
This is needed if we wish to change the size of the resource structures. Based on an original patch from Vivek Goyal <vgoyal@in.ibm.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[ALSA] Remove zero-initialization of static variablesTakashi Iwai
Removed zero-initializations of static variables. A tiny optimization. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] unregister platform device again if probe was unsuccessfulRene Herman
This second one unregisters the platform device again when the probe is unsuccesful for sound/drivers, sound/arm/sa11xx-uda1341.c and sound/ppc/powermac.c. This gets them all. Signed-off-by: Rene Herman <rene.herman@keyaccess.nl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] semaphore -> mutex (Archs, misc buses)Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-02-01[ARM] 3290/1: Fix the FIFO size detectionCatalin Marinas
Patch from Catalin Marinas AACI reports TX FIFO full after the first write to it if the AC97 is not enabled. This patch enables the AC97 probing before the check for the TX FIFO size. The patch also adds a warning if the TX FIFO size is not multiple of 16. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-07Merge with Linus' kernel.Russell King
2006-01-07[ARM] Move AMBA include files to include/linux/amba/Russell King
Since the ARM AMBA bus is used on MIPS as well as ARM, we need to make the bus available for other architectures to use. Move the AMBA include files from include/asm-arm/hardware/ to include/linux/amba/ Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-03[ALSA] make the pxa2xx-ac97 module more robust against PXA27x bugsNicolas Pitre
Modules: ARM PXA2XX driver The SDONE and CDONE interrupt on the PXA27x might become unusable in some conditions. Let's use an hybrid approach (interrupt with timeout) to have the best possible behavior in all conditions. Also let's not care about CAR_CAIP anymore. This is useless. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] unregister platform devicesClemens Ladisch
Call platform_device_unregister() for all platform devices that we've registered. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-03[ALSA] Remove SND_GENERIC_DRIVER from arm/KconfigTakashi Iwai
Modules: ARM Remove the obsolete SND_GENERIC_DRIVER from arm/Kconfig. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Use platform_deviceTakashi Iwai
Modules: SA11xx UDA1341 driver Rewrite the probe/remove with platform_device. Fix PM support, too. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Fix PM supportTakashi Iwai
Modules: ARM AACI PL041 driver,ARM PXA2XX driver Fix PM support of aaci and pxa2xx drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: ARM SA11xx-UDA1341Takashi Iwai
Modules: SA11xx UDA1341 driver Remove xxx_t typedefs from the ARM SA11xx-UDA1341 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: ARM PXA2xxTakashi Iwai
Modules: ARM PXA2XX driver Remove xxx_t typedefs from the ARM PXA2xx driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: ARM AACITakashi Iwai
Modules: ARM AACI PL041 driver,ARM DMA routines Remove xxx_t typedefs from the ARM AACI driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Clean up sa11xx-uda1341 driverTakashi Iwai
Modules: SA11xx UDA1341 driver,L3 drivers,UDA1341 Clean up sa11xx-uda1341 driver: - Fix buggy destructor - Remove the global variable - Move array definitions from uda1341.h - Make functions in uda1341.c static Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-09[DRIVER MODEL] Convert platform drivers to use struct platform_driverRussell King
This allows us to eliminate the casts in the drivers, and eventually remove the use of the device_driver function pointer methods for platform device drivers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28Merge ../bleed-2.6Greg KH
2005-10-28[PATCH] DRIVER MODEL: Get rid of the obsolete tri-level suspend/resume callbacksRussell King
In PM v1, all devices were called at SUSPEND_DISABLE level. Then all devices were called at SUSPEND_SAVE_STATE level, and finally SUSPEND_POWER_DOWN level. However, with PM v2, to maintain compatibility for platform devices, I arranged for the PM v2 suspend/resume callbacks to call the old PM v1 suspend/resume callbacks three times with each level in order so that existing drivers continued to work. Since this is obsolete infrastructure which is no longer necessary, we can remove it. Here's an (untested) patch to do exactly that. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[ARM] 3/4: Remove asm/hardware.h from Versatile and Integrator io.hRussell King
2005-10-07[ALSA] Fix pm_message_t in PXA2XX-AC97 driverDirk Opfer
ARM PXA2XX driver Fix pm_message_t in PXA2XX-AC97 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-17[PATCH] Fix up some pm_message_t typesRichard Purdie
Fix up some pm_message_t types Signed-Off-By: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
