This patch removes the old PXA DMA API usage and switches over to
generic functions provided by snd-soc-dmaengine-pcm.
More cleanups may be done on top of this, and some function stubs can
now be removed completetly. However, the intention here was to keep
the transition as small as possible.
This was tested on the mioa701 pxa27x board.
Signed-off-by: Daniel Mack <zonque@gmail.com>
[trivial change from mmp-dma to pxa-dma]
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
Signed-off-by: Mark Brown <broonie@kernel.org>
As we are moving the mmp platform towards multiplatform support,
we have to stop including platform header files.
This changes the pxa-ssp sound driver file to no longer depend
on mach/hardware.h and mach/dma.h. The code using the definitions
from those headers is actually gone already, the only thing
that was still being used was the pxa_dma_desc typedef, which
we can easily work around by using the normal 'struct pxa_dma_desc'
name.
The pxa2xx-dma driver still uses this header, so we include it
explicitly there, which is ok because that is only used on pxa,
not on mmp.
Signed-off-by: Xia Kaixu <kaixu.xia@linaro.org>
Signed-off-by: Mark Brown <broonie@linaro.org>
This code sequence is unsafe in modules:
static u64 mask = DMA_BIT_MASK(something);
if (!dev->dma_mask)
dev->dma_mask = &mask;
as if a module is reloaded, the mask will be pointing at the original
module's mask address, and this can lead to oopses. Moreover, they
all follow this with:
if (!dev->coherent_dma_mask)
dev->coherent_dma_mask = mask;
where 'mask' is the same value as the statically defined mask, and this
bypasses the architecture's check on whether the DMA mask is possible.
Fix these issues by using the new dma_coerce_coherent_and_mask()
function.
Acked-by: Mark Brown <broonie@linaro.org>
Acked-by: Takashi Iwai <tiwai@suse.de>
Use snd_dmaengine_dai_dma_data for passing the dma parameters from
clients to the pxa pcm lib. This does no functional change, it's just an
intermedia step to migrate the pxa bits over to dmaengine.
The calculation of dcmd is a transition hack which will be removed again
in a later patch. It's just there to make the transition more readable.
Lots of sound drivers were getting module.h via the implicit presence
of it in <linux/device.h> but we are going to clean that up. So
fix up those users now.
ASoC and non-ASoC drivers for PCM DMA on PXA share lots of common code.
Move it to pxa2xx-lib.
[Fixed some checkpatch warnings -- broonie]
Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com>
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
This just leaves include/asm-arm/plat-* to deal with.
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h.
Then, since asm/hardware.h only exists to include asm/arch/hardware.h,
update everything to directly include asm/arch/hardware.h and remove
asm/hardware.h.
This header file exists only for some hacks to adapt alsa-driver
tree. It's useless for building in the kernel. Let's move a few
lines in it to sound/core.h and remove it.
With this patch, sound/driver.h isn't removed but has just a single
compile warning to include it. This should be really killed in
future.
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
Modules: ARM PXA2XX driver
Remove xxx_t typedefs from the ARM PXA2xx driver.
Documentation,ARM,/arm/Makefile,ARM PXA2XX driver
Added ARM PXA2xx AC97 driver by Nicolas Pitre
(moved from alsa-driver tree).
