path: root/security
2014-04-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "Apart from reordering the SELinux mmap code to ensure DAC is called before MAC, these are minor maintenance updates" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (23 commits) selinux: correctly label /proc inodes in use before the policy is loaded selinux: put the mmap() DAC controls before the MAC controls selinux: fix the output of ./scripts/get_maintainer.pl for SELinux evm: enable key retention service automatically ima: skip memory allocation for empty files evm: EVM does not use MD5 ima: return d_name.name if d_path fails integrity: fix checkpatch errors ima: fix erroneous removal of security.ima xattr security: integrity: Use a more current logging style MAINTAINERS: email updates and other misc. changes ima: reduce memory usage when a template containing the n field is used ima: restore the original behavior for sending data with ima template Integrity: Pass commname via get_task_comm() fs: move i_readcount ima: use static const char array definitions security: have cap_dentry_init_security return error ima: new helper: file_inode(file) kernel: Mark function as static in kernel/seccomp.c capability: Use current logging styles ...
2014-04-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Here is my initial pull request for the networking subsystem during this merge window: 1) Support for ESN in AH (RFC 4302) from Fan Du. 2) Add full kernel doc for ethtool command structures, from Ben Hutchings. 3) Add BCM7xxx PHY driver, from Florian Fainelli. 4) Export computed TCP rate information in netlink socket dumps, from Eric Dumazet. 5) Allow IPSEC SA to be dumped partially using a filter, from Nicolas Dichtel. 6) Convert many drivers to pci_enable_msix_range(), from Alexander Gordeev. 7) Record SKB timestamps more efficiently, from Eric Dumazet. 8) Switch to microsecond resolution for TCP round trip times, also from Eric Dumazet. 9) Clean up and fix 6lowpan fragmentation handling by making use of the existing inet_frag api for it's implementation. 10) Add TX grant mapping to xen-netback driver, from Zoltan Kiss. 11) Auto size SKB lengths when composing netlink messages based upon past message sizes used, from Eric Dumazet. 12) qdisc dumps can take a long time, add a cond_resched(), From Eric Dumazet. 13) Sanitize netpoll core and drivers wrt. SKB handling semantics. Get rid of never-used-in-tree netpoll RX handling. From Eric W Biederman. 14) Support inter-address-family and namespace changing in VTI tunnel driver(s). From Steffen Klassert. 15) Add Altera TSE driver, from Vince Bridgers. 16) Optimizing csum_replace2() so that it doesn't adjust the checksum by checksumming the entire header, from Eric Dumazet. 17) Expand BPF internal implementation for faster interpreting, more direct translations into JIT'd code, and much cleaner uses of BPF filtering in non-socket ocntexts. From Daniel Borkmann and Alexei Starovoitov" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1976 commits) netpoll: Use skb_irq_freeable to make zap_completion_queue safe. net: Add a test to see if a skb is freeable in irq context qlcnic: Fix build failure due to undefined reference to `vxlan_get_rx_port' net: ptp: move PTP classifier in its own file net: sxgbe: make "core_ops" static net: sxgbe: fix logical vs bitwise operation net: sxgbe: sxgbe_mdio_register() frees the bus Call efx_set_channels() before efx->type->dimension_resources() xen-netback: disable rogue vif in kthread context net/mlx4: Set proper build dependancy with vxlan be2net: fix build dependency on VxLAN mac802154: make csma/cca parameters per-wpan mac802154: allow only one WPAN to be up at any given time net: filter: minor: fix kdoc in __sk_run_filter netlink: don't compare the nul-termination in nla_strcmp can: c_can: Avoid led toggling for every packet. can: c_can: Simplify TX interrupt cleanup can: c_can: Store dlc private can: c_can: Reduce register access can: c_can: Make the code readable ...
2014-03-31Merge branch 'compat' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 compat wrapper rework from Heiko Carstens: "S390 compat system call wrapper simplification work. The intention of this work is to get rid of all hand written assembly compat system call wrappers on s390, which perform proper sign or zero extension, or pointer conversion of compat system call parameters. Instead all of this should be done with C code eg by using Al's COMPAT_SYSCALL_DEFINEx() macro. Therefore all common code and s390 specific compat system calls have been converted to the COMPAT_SYSCALL_DEFINEx() macro. In order to generate correct code all compat system calls may only have eg compat_ulong_t parameters, but no unsigned long parameters. Those patches which change parameter types from unsigned long to compat_ulong_t parameters are separate in this series, but shouldn't cause any harm. The only compat system calls which intentionally have 64 bit parameters (preadv64 and pwritev64) in support of the x86/32 ABI haven't been changed, but are now only available if an architecture defines __ARCH_WANT_COMPAT_SYS_PREADV64/PWRITEV64. System calls which do not have a compat variant but still need proper zero extension on s390, like eg "long sys_brk(unsigned long brk)" will get a proper wrapper function with the new s390 specific COMPAT_SYSCALL_WRAPx() macro: COMPAT_SYSCALL_WRAP1(brk, unsigned long, brk); which generates the following code (simplified): asmlinkage long sys_brk(unsigned long brk); asmlinkage long compat_sys_brk(long brk) { return sys_brk((u32)brk); } Given that the C file which contains all the COMPAT_SYSCALL_WRAP lines includes both linux/syscall.h and linux/compat.h, it will generate build errors, if the declaration of sys_brk() doesn't match, or if there exists a non-matching compat_sys_brk() declaration. In addition this will intentionally result in a link error if somewhere else a compat_sys_brk() function exists, which probably should have been used instead. Two more BUILD_BUG_ONs make sure the size and type of each compat syscall parameter can be handled correctly with the s390 specific macros. I converted the compat system calls step by step to verify the generated code is correct and matches the previous code. In fact it did not always match, however that was always a bug in the hand written asm code. In result we get less code, less bugs, and much more sanity checking" * 'compat' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (44 commits) s390/compat: add copyright statement compat: include linux/unistd.h within linux/compat.h s390/compat: get rid of compat wrapper assembly code s390/compat: build error for large compat syscall args mm/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types kexec/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types net/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types ipc/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types fs/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types ipc/compat: convert to COMPAT_SYSCALL_DEFINE fs/compat: convert to COMPAT_SYSCALL_DEFINE security/compat: convert to COMPAT_SYSCALL_DEFINE mm/compat: convert to COMPAT_SYSCALL_DEFINE net/compat: convert to COMPAT_SYSCALL_DEFINE kernel/compat: convert to COMPAT_SYSCALL_DEFINE fs/compat: optional preadv64/pwrite64 compat system calls ipc/compat_sys_msgrcv: change msgtyp type from long to compat_long_t s390/compat: partial parameter conversion within syscall wrappers s390/compat: automatic zero, sign and pointer conversion of syscalls s390/compat: add sync_file_range and fallocate compat syscalls ...
2014-03-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: Documentation/devicetree/bindings/net/micrel-ks8851.txt net/core/netpoll.c The net/core/netpoll.c conflict is a bug fix in 'net' happening to code which is completely removed in 'net-next'. In micrel-ks8851.txt we simply have overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-19selinux: correctly label /proc inodes in use before the policy is loadedPaul Moore
This patch is based on an earlier patch by Eric Paris, he describes the problem below: "If an inode is accessed before policy load it will get placed on a list of inodes to be initialized after policy load. After policy load we call inode_doinit() which calls inode_doinit_with_dentry() on all inodes accessed before policy load. In the case of inodes in procfs that means we'll end up at the bottom where it does: /* Default to the fs superblock SID. */ isec->sid = sbsec->sid; if ((sbsec->flags & SE_SBPROC) && !S_ISLNK(inode->i_mode)) { if (opt_dentry) { isec->sclass = inode_mode_to_security_class(...) rc = selinux_proc_get_sid(opt_dentry, isec->sclass, &sid); if (rc) goto out_unlock; isec->sid = sid; } } Since opt_dentry is null, we'll never call selinux_proc_get_sid() and will leave the inode labeled with the label on the superblock. I believe a fix would be to mimic the behavior of xattrs. Look for an alias of the inode. If it can't be found, just leave the inode uninitialized (and pick it up later) if it can be found, we should be able to call selinux_proc_get_sid() ..." On a system exhibiting this problem, you will notice a lot of files in /proc with the generic "proc_t" type (at least the ones that were accessed early in the boot), for example: # ls -Z /proc/sys/kernel/shmmax | awk '{ print $4 " " $5 }' system_u:object_r:proc_t:s0 /proc/sys/kernel/shmmax However, with this patch in place we see the expected result: # ls -Z /proc/sys/kernel/shmmax | awk '{ print $4 " " $5 }' system_u:object_r:sysctl_kernel_t:s0 /proc/sys/kernel/shmmax Cc: Eric Paris <eparis@redhat.com> Signed-off-by: Paul Moore <pmoore@redhat.com> Acked-by: Eric Paris <eparis@redhat.com>
2014-03-19selinux: put the mmap() DAC controls before the MAC controlsPaul Moore
It turns out that doing the SELinux MAC checks for mmap() before the DAC checks was causing users and the SELinux policy folks headaches as users were seeing a lot of SELinux AVC denials for the memprotect:mmap_zero permission that would have also been denied by the normal DAC capability checks (CAP_SYS_RAWIO). Example: # cat mmap_test.c #include <stdlib.h> #include <stdio.h> #include <errno.h> #include <sys/mman.h> int main(int argc, char *argv[]) { int rc; void *mem; mem = mmap(0x0, 4096, PROT_READ | PROT_WRITE, MAP_PRIVATE | MAP_ANONYMOUS | MAP_FIXED, -1, 0); if (mem == MAP_FAILED) return errno; printf("mem = %p\n", mem); munmap(mem, 4096); return 0; } # gcc -g -O0 -o mmap_test mmap_test.c # ./mmap_test mem = (nil) # ausearch -m AVC | grep mmap_zero type=AVC msg=audit(...): avc: denied { mmap_zero } for pid=1025 comm="mmap_test" scontext=unconfined_u:unconfined_r:unconfined_t:s0-s0:c0.c1023 tcontext=unconfined_u:unconfined_r:unconfined_t:s0-s0:c0.c1023 tclass=memprotect This patch corrects things so that when the above example is run by a user without CAP_SYS_RAWIO the SELinux AVC is no longer generated as the DAC capability check fails before the SELinux permission check. Signed-off-by: Paul Moore <pmoore@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov>
2014-03-18Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec Steffen Klassert says: ==================== 1) Fix a sleep in atomic when pfkey_sadb2xfrm_user_sec_ctx() is called from pfkey_compile_policy(). Fix from Nikolay Aleksandrov. 2) security_xfrm_policy_alloc() can be called in process and atomic context. Add an argument to let the callers choose the appropriate way. Fix from Nikolay Aleksandrov. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/usb/r8152.c drivers/net/xen-netback/netback.c Both the r8152 and netback conflicts were simple overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-12Merge branch 'next-fixes' of ↵James Morris
git://git.kernel.org/pub/scm/linux/kernel/git/zohar/linux-integrity into next
2014-03-10selinux: add gfp argument to security_xfrm_policy_alloc and fix callersNikolay Aleksandrov
security_xfrm_policy_alloc can be called in atomic context so the allocation should be done with GFP_ATOMIC. Add an argument to let the callers choose the appropriate way. In order to do so a gfp argument needs to be added to the method xfrm_policy_alloc_security in struct security_operations and to the internal function selinux_xfrm_alloc_user. After that switch to GFP_ATOMIC in the atomic callers and leave GFP_KERNEL as before for the rest. The path that needed the gfp argument addition is: security_xfrm_policy_alloc -> security_ops.xfrm_policy_alloc_security -> all users of xfrm_policy_alloc_security (e.g. selinux_xfrm_policy_alloc) -> selinux_xfrm_alloc_user (here the allocation used to be GFP_KERNEL only) Now adding a gfp argument to selinux_xfrm_alloc_user requires us to also add it to security_context_to_sid which is used inside and prior to this patch did only GFP_KERNEL allocation. So add gfp argument to security_context_to_sid and adjust all of its callers as well. CC: Paul Moore <paul@paul-moore.com> CC: Dave Jones <davej@redhat.com> CC: Steffen Klassert <steffen.klassert@secunet.com> CC: Fan Du <fan.du@windriver.com> CC: David S. Miller <davem@davemloft.net> CC: LSM list <linux-security-module@vger.kernel.org> CC: SELinux list <selinux@tycho.nsa.gov> Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com> Acked-by: Paul Moore <paul@paul-moore.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2014-03-09KEYS: Make the keyring cycle detector ignore other keyrings of the same nameDavid Howells
This fixes CVE-2014-0102. The following command sequence produces an oops: keyctl new_session i=`keyctl newring _ses @s` keyctl link @s $i The problem is that search_nested_keyrings() sees two keyrings that have matching type and description, so keyring_compare_object() returns true. s_n_k() then passes the key to the iterator function - keyring_detect_cycle_iterator() - which *should* check to see whether this is the keyring of interest, not just one with the same name. Because assoc_array_find() will return one and only one match, I assumed that the iterator function would only see an exact match or never be called - but the iterator isn't only called from assoc_array_find()... The oops looks something like this: kernel BUG at /data/fs/linux-2.6-fscache/security/keys/keyring.c:1003! invalid opcode: 0000 [#1] SMP ... RIP: keyring_detect_cycle_iterator+0xe/0x1f ... Call Trace: search_nested_keyrings+0x76/0x2aa __key_link_check_live_key+0x50/0x5f key_link+0x4e/0x85 keyctl_keyring_link+0x60/0x81 SyS_keyctl+0x65/0xe4 tracesys+0xdd/0xe2 The fix is to make keyring_detect_cycle_iterator() check that the key it has is the key it was actually looking for rather than calling BUG_ON(). A testcase has been included in the keyutils testsuite for this: http://git.kernel.org/cgit/linux/kernel/git/dhowells/keyutils.git/commit/?id=891f3365d07f1996778ade0e3428f01878a1790b Reported-by: Tommi Rantala <tt.rantala@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-07evm: enable key retention service automaticallyDmitry Kasatkin
If keys are not enabled, EVM is not visible in the configuration menu. It may be difficult to figure out what to do unless you really know. Other subsystems as NFS, CIFS select keys automatically. This patch does the same. This patch also removes '(TRUSTED_KEYS=y || TRUSTED_KEYS=n)' dependency, which is unnecessary. EVM does not depend on trusted keys, but on encrypted keys. evm.h provides compile time dependency. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-03-07ima: skip memory allocation for empty filesDmitry Kasatkin
Memory allocation is unnecessary for empty files. This patch calculates the hash without memory allocation. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-03-07evm: EVM does not use MD5Dmitry Kasatkin
EVM does not use MD5 HMAC. Selection of CRYPTO_MD5 can be safely removed. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-03-07ima: return d_name.name if d_path failsDmitry Kasatkin
This is a small refactoring so ima_d_path() returns dentry name if path reconstruction fails. It simplifies callers actions and removes code duplication. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-03-07integrity: fix checkpatch errorsDmitry Kasatkin
Between checkpatch changes (eg. sizeof) and inconsistencies between Lindent and checkpatch, unfixed checkpatch errors make it difficult to see new errors. This patch fixes them. Some lines with over 80 chars remained unchanged to improve code readability. The "extern" keyword is removed from internal evm.h to make it consistent with internal ima.h. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-03-07ima: fix erroneous removal of security.ima xattrDmitry Kasatkin
ima_inode_post_setattr() calls ima_must_appraise() to check if the file needs to be appraised. If it does not then it removes security.ima xattr. With original policy matching code it might happen that even file needs to be appraised with FILE_CHECK hook, it might not be for POST_SETATTR hook. 'security.ima' might be erronously removed. This patch treats POST_SETATTR as special wildcard function and will cause ima_must_appraise() to be true if any of the hooks rules matches. security.ima will not be removed if any of the hooks would require appraisal. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-03-07security: integrity: Use a more current logging styleJoe Perches
Convert printks to pr_<level>. Add pr_fmt. Remove embedded prefixes. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-03-07ima: reduce memory usage when a template containing the n field is usedRoberto Sassu
Before this change, to correctly calculate the template digest for the 'ima' template, the event name field (id: 'n') length was set to the fixed size of 256 bytes. This patch reduces the length of the event name field to the string length incremented of one (to make room for the termination character '\0') and handles the specific case of the digest calculation for the 'ima' template directly in ima_calc_field_array_hash_tfm(). Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-03-07ima: restore the original behavior for sending data with ima templateRoberto Sassu
With the new template mechanism introduced in IMA since kernel 3.13, the format of data sent through the binary_runtime_measurements interface is slightly changed. Now, for a generic measurement, the format of template data (after the template name) is: template_len | field1_len | field1 | ... | fieldN_len | fieldN In addition, fields containing a string now include the '\0' termination character. Instead, the format for the 'ima' template should be: SHA1 digest | event name length | event name It must be noted that while in the IMA 3.13 code 'event name length' is 'IMA_EVENT_NAME_LEN_MAX + 1' (256 bytes), so that the template digest is calculated correctly, and 'event name' contains '\0', in the pre 3.13 code 'event name length' is exactly the string length and 'event name' does not contain the termination character. The patch restores the behavior of the IMA code pre 3.13 for the 'ima' template so that legacy userspace tools obtain a consistent behavior when receiving data from the binary_runtime_measurements interface regardless of which kernel version is used. Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Cc: <stable@vger.kernel.org> # 3.3.13: 3ce1217 ima: define template fields library Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-03-07Integrity: Pass commname via get_task_comm()Tetsuo Handa
When we pass task->comm to audit_log_untrustedstring(), we need to pass it via get_task_comm() because task->comm can be changed to contain untrusted string by other threads after audit_log_untrustedstring() confirmed that task->comm does not contain untrusted string. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-03-07ima: use static const char array definitionsMimi Zohar
A const char pointer allocates memory for a pointer as well as for a string, This patch replaces a number of the const char pointers throughout IMA, with a static const char array. Suggested-by: David Howells <dhowells@redhat.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Acked-by: David Howells <dhowells@redhat.com>
2014-03-07security: have cap_dentry_init_security return errorJeff Layton
Currently, cap_dentry_init_security returns 0 without actually initializing the security label. This confuses its only caller (nfs4_label_init_security) which expects an error in that situation, and causes it to end up sending out junk onto the wire instead of simply suppressing the label in the attributes sent. When CONFIG_SECURITY is disabled, security_dentry_init_security returns -EOPNOTSUPP. Have cap_dentry_init_security do the same. Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2014-03-06security/compat: convert to COMPAT_SYSCALL_DEFINEHeiko Carstens
Convert all compat system call functions where all parameter types have a size of four or less than four bytes, or are pointer types to COMPAT_SYSCALL_DEFINE. The implicit casts within COMPAT_SYSCALL_DEFINE will perform proper zero and sign extension to 64 bit of all parameters if needed. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2014-03-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/wireless/ath/ath9k/recv.c drivers/net/wireless/mwifiex/pcie.c net/ipv6/sit.c The SIT driver conflict consists of a bug fix being done by hand in 'net' (missing u64_stats_init()) whilst in 'net-next' a helper was created (netdev_alloc_pcpu_stats()) which takes care of this. The two wireless conflicts were overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-04ima: new helper: file_inode(file)Libo Chen
Replace "file->f_dentry->d_inode" with the new file_inode() helper function. Signed-off-by: Libo Chen <clbchenlibo.chen@huawei.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-02-24Merge branch 'stable-3.14' of git://git.infradead.org/users/pcmoore/selinux ↵James Morris
into for-linus
2014-02-20SELinux: bigendian problems with filename trans rulesEric Paris
When writing policy via /sys/fs/selinux/policy I wrote the type and class of filename trans rules in CPU endian instead of little endian. On x86_64 this works just fine, but it means that on big endian arch's like ppc64 and s390 userspace reads the policy and converts it from le32_to_cpu. So the values are all screwed up. Write the values in le format like it should have been to start. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Cc: stable@vger.kernel.org Signed-off-by: Paul Moore <pmoore@redhat.com>
2014-02-17security: cleanup Makefiles to use standard syntax for specifying ↵Sam Ravnborg
sub-directories The Makefiles in security/ uses a non-standard way to specify sub-directories for building. Fix it up so the normal (and documented) approach is used. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: James Morris <james.l.morris@oracle.com>
2014-02-12flowcache: Make flow cache name space awareFan Du
Inserting a entry into flowcache, or flushing flowcache should be based on per net scope. The reason to do so is flushing operation from fat netns crammed with flow entries will also making the slim netns with only a few flow cache entries go away in original implementation. Since flowcache is tightly coupled with IPsec, so it would be easier to put flow cache global parameters into xfrm namespace part. And one last thing needs to do is bumping flow cache genid, and flush flow cache should also be made in per net style. Signed-off-by: Fan Du <fan.du@windriver.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2014-02-10Merge branch 'stable-3.14' of git://git.infradead.org/users/pcmoore/selinux ↵James Morris
into for-linus
2014-02-06security: replace strict_strto*() with kstrto*()Jingoo Han
The usage of strict_strto*() is not preferred, because strict_strto*() is obsolete. Thus, kstrto*() should be used. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2014-02-05SELinux: Fix kernel BUG on empty security contexts.Stephen Smalley
Setting an empty security context (length=0) on a file will lead to incorrectly dereferencing the type and other fields of the security context structure, yielding a kernel BUG. As a zero-length security context is never valid, just reject all such security contexts whether coming from userspace via setxattr or coming from the filesystem upon a getxattr request by SELinux. Setting a security context value (empty or otherwise) unknown to SELinux in the first place is only possible for a root process (CAP_MAC_ADMIN), and, if running SELinux in enforcing mode, only if the corresponding SELinux mac_admin permission is also granted to the domain by policy. In Fedora policies, this is only allowed for specific domains such as livecd for setting down security contexts that are not defined in the build host policy. Reproducer: su setenforce 0 touch foo setfattr -n security.selinux foo Caveat: Relabeling or removing foo after doing the above may not be possible without booting with SELinux disabled. Any subsequent access to foo after doing the above will also trigger the BUG. BUG output from Matthew Thode: [ 473.893141] ------------[ cut here ]------------ [ 473.962110] kernel BUG at security/selinux/ss/services.c:654! [ 473.995314] invalid opcode: 0000 [#6] SMP [ 474.027196] Modules linked in: [ 474.058118] CPU: 0 PID: 8138 Comm: ls Tainted: G D I 3.13.0-grsec #1 [ 474.116637] Hardware name: Supermicro X8ST3/X8ST3, BIOS 2.0 07/29/10 [ 474.149768] task: ffff8805f50cd010 ti: ffff8805f50cd488 task.ti: ffff8805f50cd488 [ 474.183707] RIP: 0010:[<ffffffff814681c7>] [<ffffffff814681c7>] context_struct_compute_av+0xce/0x308 [ 474.219954] RSP: 0018:ffff8805c0ac3c38 EFLAGS: 00010246 [ 474.252253] RAX: 0000000000000000 RBX: ffff8805c0ac3d94 RCX: 0000000000000100 [ 474.287018] RDX: ffff8805e8aac000 RSI: 00000000ffffffff RDI: ffff8805e8aaa000 [ 474.321199] RBP: ffff8805c0ac3cb8 R08: 0000000000000010 R09: 0000000000000006 [ 474.357446] R10: 0000000000000000 R11: ffff8805c567a000 R12: 0000000000000006 [ 474.419191] R13: ffff8805c2b74e88 R14: 00000000000001da R15: 0000000000000000 [ 474.453816] FS: 00007f2e75220800(0000) GS:ffff88061fc00000(0000) knlGS:0000000000000000 [ 474.489254] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 474.522215] CR2: 00007f2e74716090 CR3: 00000005c085e000 CR4: 00000000000207f0 [ 474.556058] Stack: [ 474.584325] ffff8805c0ac3c98 ffffffff811b549b ffff8805c0ac3c98 ffff8805f1190a40 [ 474.618913] ffff8805a6202f08 ffff8805c2b74e88 00068800d0464990 ffff8805e8aac860 [ 474.653955] ffff8805c0ac3cb8 000700068113833a ffff880606c75060 ffff8805c0ac3d94 [ 474.690461] Call Trace: [ 474.723779] [<ffffffff811b549b>] ? lookup_fast+0x1cd/0x22a [ 474.778049] [<ffffffff81468824>] security_compute_av+0xf4/0x20b [ 474.811398] [<ffffffff8196f419>] avc_compute_av+0x2a/0x179 [ 474.843813] [<ffffffff8145727b>] avc_has_perm+0x45/0xf4 [ 474.875694] [<ffffffff81457d0e>] inode_has_perm+0x2a/0x31 [ 474.907370] [<ffffffff81457e76>] selinux_inode_getattr+0x3c/0x3e [ 474.938726] [<ffffffff81455cf6>] security_inode_getattr+0x1b/0x22 [ 474.970036] [<ffffffff811b057d>] vfs_getattr+0x19/0x2d [ 475.000618] [<ffffffff811b05e5>] vfs_fstatat+0x54/0x91 [ 475.030402] [<ffffffff811b063b>] vfs_lstat+0x19/0x1b [ 475.061097] [<ffffffff811b077e>] SyS_newlstat+0x15/0x30 [ 475.094595] [<ffffffff8113c5c1>] ? __audit_syscall_entry+0xa1/0xc3 [ 475.148405] [<ffffffff8197791e>] system_call_fastpath+0x16/0x1b [ 475.179201] Code: 00 48 85 c0 48 89 45 b8 75 02 0f 0b 48 8b 45 a0 48 8b 3d 45 d0 b6 00 8b 40 08 89 c6 ff ce e8 d1 b0 06 00 48 85 c0 49 89 c7 75 02 <0f> 0b 48 8b 45 b8 4c 8b 28 eb 1e 49 8d 7d 08 be 80 01 00 00 e8 [ 475.255884] RIP [<ffffffff814681c7>] context_struct_compute_av+0xce/0x308 [ 475.296120] RSP <ffff8805c0ac3c38> [ 475.328734] ---[ end trace f076482e9d754adc ]--- Reported-by: Matthew Thode <mthode@mthode.org> Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Cc: stable@vger.kernel.org Signed-off-by: Paul Moore <pmoore@redhat.com>
2014-02-05selinux: add SOCK_DIAG_BY_FAMILY to the list of netlink message typesPaul Moore
The SELinux AF_NETLINK/NETLINK_SOCK_DIAG socket class was missing the SOCK_DIAG_BY_FAMILY definition which caused SELINUX_ERR messages when the ss tool was run. # ss Netid State Recv-Q Send-Q Local Address:Port Peer Address:Port u_str ESTAB 0 0 * 14189 * 14190 u_str ESTAB 0 0 * 14145 * 14144 u_str ESTAB 0 0 * 14151 * 14150 {...} # ausearch -m SELINUX_ERR ---- time->Thu Jan 23 11:11:16 2014 type=SYSCALL msg=audit(1390493476.445:374): arch=c000003e syscall=44 success=yes exit=40 a0=3 a1=7fff03aa11f0 a2=28 a3=0 items=0 ppid=1852 pid=1895 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=pts0 ses=1 comm="ss" exe="/usr/sbin/ss" subj=unconfined_u:unconfined_r:unconfined_t:s0-s0:c0.c1023 key=(null) type=SELINUX_ERR msg=audit(1390493476.445:374): SELinux: unrecognized netlink message type=20 for sclass=32 Signed-off-by: Paul Moore <pmoore@redhat.com>
2014-02-05Merge tag 'v3.13' into stable-3.14Paul Moore
Linux 3.13 Conflicts: security/selinux/hooks.c Trivial merge issue in selinux_inet_conn_request() likely due to me including patches that I sent to the stable folks in my next tree resulting in the patch hitting twice (I think). Thankfully it was an easy fix this time, but regardless, lesson learned, I will not do that again.
2014-02-05security: select correct default LSM_MMAP_MIN_ADDR on arm on arm64Colin Cross
Binaries compiled for arm may run on arm64 if CONFIG_COMPAT is selected. Set LSM_MMAP_MIN_ADDR to 32768 if ARM64 && COMPAT to prevent selinux failures launching 32-bit static executables that are mapped at 0x8000. Signed-off-by: Colin Cross <ccross@android.com> Acked-by: Will Deacon <will.deacon@arm.com> Acked-by: Eric Paris <eparis@redhat.com> Acked-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2014-01-23Merge git://git.infradead.org/users/eparis/auditLinus Torvalds
Pull audit update from Eric Paris: "Again we stayed pretty well contained inside the audit system. Venturing out was fixing a couple of function prototypes which were inconsistent (didn't hurt anything, but we used the same value as an int, uint, u32, and I think even a long in a couple of places). We also made a couple of minor changes to when a couple of LSMs called the audit system. We hoped to add aarch64 audit support this go round, but it wasn't ready. I'm disappearing on vacation on Thursday. I should have internet access, but it'll be spotty. If anything goes wrong please be sure to cc rgb@redhat.com. He'll make fixing things his top priority" * git://git.infradead.org/users/eparis/audit: (50 commits) audit: whitespace fix in kernel-parameters.txt audit: fix location of __net_initdata for audit_net_ops audit: remove pr_info for every network namespace audit: Modify a set of system calls in audit class definitions audit: Convert int limit uses to u32 audit: Use more current logging style audit: Use hex_byte_pack_upper audit: correct a type mismatch in audit_syscall_exit() audit: reorder AUDIT_TTY_SET arguments audit: rework AUDIT_TTY_SET to only grab spin_lock once audit: remove needless switch in AUDIT_SET audit: use define's for audit version audit: documentation of audit= kernel parameter audit: wait_for_auditd rework for readability audit: update MAINTAINERS audit: log task info on feature change audit: fix incorrect set of audit_sock audit: print error message when fail to create audit socket audit: fix dangling keywords in audit_log_set_loginuid() output audit: log on errors from filter user rules ...
2014-01-21Merge branch 'for-3.14' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup updates from Tejun Heo: "The bulk of changes are cleanups and preparations for the upcoming kernfs conversion. - cgroup_event mechanism which is and will be used only by memcg is moved to memcg. - pidlist handling is updated so that it can be served by seq_file. Also, the list is not sorted if sane_behavior. cgroup documentation explicitly states that the file is not sorted but it has been for quite some time. - All cgroup file handling now happens on top of seq_file. This is to prepare for kernfs conversion. In addition, all operations are restructured so that they map 1-1 to kernfs operations. - Other cleanups and low-pri fixes" * 'for-3.14' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (40 commits) cgroup: trivial style updates cgroup: remove stray references to css_id doc: cgroups: Fix typo in doc/cgroups cgroup: fix fail path in cgroup_load_subsys() cgroup: fix missing unlock on error in cgroup_load_subsys() cgroup: remove for_each_root_subsys() cgroup: implement for_each_css() cgroup: factor out cgroup_subsys_state creation into create_css() cgroup: combine css handling loops in cgroup_create() cgroup: reorder operations in cgroup_create() cgroup: make for_each_subsys() useable under cgroup_root_mutex cgroup: css iterations and css_from_dir() are safe under cgroup_mutex cgroup: unify pidlist and other file handling cgroup: replace cftype->read_seq_string() with cftype->seq_show() cgroup: attach cgroup_open_file to all cgroup files cgroup: generalize cgroup_pidlist_open_file cgroup: unify read path so that seq_file is always used cgroup: unify cgroup_write_X64() and cgroup_write_string() cgroup: remove cftype->read(), ->read_map() and ->write() hugetlb_cgroup: convert away from cftype->read() ...
2014-01-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security layer updates from James Morris: "Changes for this kernel include maintenance updates for Smack, SELinux (and several networking fixes), IMA and TPM" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (39 commits) SELinux: Fix memory leak upon loading policy tpm/tpm-sysfs: active_show() can be static tpm: tpm_tis: Fix compile problems with CONFIG_PM_SLEEP/CONFIG_PNP tpm: Make tpm-dev allocate a per-file structure tpm: Use the ops structure instead of a copy in tpm_vendor_specific tpm: Create a tpm_class_ops structure and use it in the drivers tpm: Pull all driver sysfs code into tpm-sysfs.c tpm: Move sysfs functions from tpm-interface to tpm-sysfs tpm: Pull everything related to /dev/tpmX into tpm-dev.c char: tpm: nuvoton: remove unused variable tpm: MAINTAINERS: Cleanup TPM Maintainers file tpm/tpm_i2c_atmel: fix coccinelle warnings tpm/tpm_ibmvtpm: fix unreachable code warning (smatch warning) tpm/tpm_i2c_stm_st33: Check return code of get_burstcount tpm/tpm_ppi: Check return value of acpi_get_name tpm/tpm_ppi: Do not compare strcmp(a,b) == -1 ima: remove unneeded size_limit argument from ima_eventdigest_init_common() ima: update IMA-templates.txt documentation ima: pass HASH_ALGO__LAST as hash algo in ima_eventdigest_init() ima: change the default hash algorithm to SHA1 in ima_eventdigest_ng_init() ...
2014-01-13smack: call WARN_ONCE() instead of calling audit_log_start()Richard Guy Briggs
Remove the call to audit_log() (which call audit_log_start()) and deal with the errors in the caller, logging only once if the condition is met. Calling audit_log_start() in this location makes buffer allocation and locking more complicated in the calling tree (audit_filter_user()). Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2014-01-13selinux: call WARN_ONCE() instead of calling audit_log_start()Richard Guy Briggs
Two of the conditions in selinux_audit_rule_match() should never happen and the third indicates a race that should be retried. Remove the calls to audit_log() (which call audit_log_start()) and deal with the errors in the caller, logging only once if the condition is met. Calling audit_log_start() in this location makes buffer allocation and locking more complicated in the calling tree (audit_filter_user()). Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2014-01-12SELinux: Fix possible NULL pointer dereference in selinux_inode_permission()Steven Rostedt
While running stress tests on adding and deleting ftrace instances I hit this bug: BUG: unable to handle kernel NULL pointer dereference at 0000000000000020 IP: selinux_inode_permission+0x85/0x160 PGD 63681067 PUD 7ddbe067 PMD 0 Oops: 0000 [#1] PREEMPT CPU: 0 PID: 5634 Comm: ftrace-test-mki Not tainted 3.13.0-rc4-test-00033-gd2a6dde-dirty #20 Hardware name: /DG965MQ, BIOS MQ96510J.86A.0372.2006.0605.1717 06/05/2006 task: ffff880078375800 ti: ffff88007ddb0000 task.ti: ffff88007ddb0000 RIP: 0010:[<ffffffff812d8bc5>] [<ffffffff812d8bc5>] selinux_inode_permission+0x85/0x160 RSP: 0018:ffff88007ddb1c48 EFLAGS: 00010246 RAX: 0000000000000000 RBX: 0000000000800000 RCX: ffff88006dd43840 RDX: 0000000000000001 RSI: 0000000000000081 RDI: ffff88006ee46000 RBP: ffff88007ddb1c88 R08: 0000000000000000 R09: ffff88007ddb1c54 R10: 6e6576652f6f6f66 R11: 0000000000000003 R12: 0000000000000000 R13: 0000000000000081 R14: ffff88006ee46000 R15: 0000000000000000 FS: 00007f217b5b6700(0000) GS:ffffffff81e21000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033^M CR2: 0000000000000020 CR3: 000000006a0fe000 CR4: 00000000000007f0 Call Trace: security_inode_permission+0x1c/0x30 __inode_permission+0x41/0xa0 inode_permission+0x18/0x50 link_path_walk+0x66/0x920 path_openat+0xa6/0x6c0 do_filp_open+0x43/0xa0 do_sys_open+0x146/0x240 SyS_open+0x1e/0x20 system_call_fastpath+0x16/0x1b Code: 84 a1 00 00 00 81 e3 00 20 00 00 89 d8 83 c8 02 40 f6 c6 04 0f 45 d8 40 f6 c6 08 74 71 80 cf 02 49 8b 46 38 4c 8d 4d cc 45 31 c0 <0f> b7 50 20 8b 70 1c 48 8b 41 70 89 d9 8b 78 04 e8 36 cf ff ff RIP selinux_inode_permission+0x85/0x160 CR2: 0000000000000020 Investigating, I found that the inode->i_security was NULL, and the dereference of it caused the oops. in selinux_inode_permission(): isec = inode->i_security; rc = avc_has_perm_noaudit(sid, isec->sid, isec->sclass, perms, 0, &avd); Note, the crash came from stressing the deletion and reading of debugfs files. I was not able to recreate this via normal files. But I'm not sure they are safe. It may just be that the race window is much harder to hit. What seems to have happened (and what I have traced), is the file is being opened at the same time the file or directory is being deleted. As the dentry and inode locks are not held during the path walk, nor is the inodes ref counts being incremented, there is nothing saving these structures from being discarded except for an rcu_read_lock(). The rcu_read_lock() protects against freeing of the inode, but it does not protect freeing of the inode_security_struct. Now if the freeing of the i_security happens with a call_rcu(), and the i_security field of the inode is not changed (it gets freed as the inode gets freed) then there will be no issue here. (Linus Torvalds suggested not setting the field to NULL such that we do not need to check if it is NULL in the permission check). Note, this is a hack, but it fixes the problem at hand. A real fix is to restructure the destroy_inode() to call all the destructor handlers from the RCU callback. But that is a major job to do, and requires a lot of work. For now, we just band-aid this bug with this fix (it works), and work on a more maintainable solution in the future. Link: http://lkml.kernel.org/r/20140109101932.0508dec7@gandalf.local.home Link: http://lkml.kernel.org/r/20140109182756.17abaaa8@gandalf.local.home Cc: stable@vger.kernel.org Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-08Merge branch 'master' of git://git.infradead.org/users/pcmoore/selinux into nextJames Morris
2014-01-07SELinux: Fix memory leak upon loading policyTetsuo Handa
Hello. I got below leak with linux-3.10.0-54.0.1.el7.x86_64 . [ 681.903890] kmemleak: 5538 new suspected memory leaks (see /sys/kernel/debug/kmemleak) Below is a patch, but I don't know whether we need special handing for undoing ebitmap_set_bit() call. ---------- >>From fe97527a90fe95e2239dfbaa7558f0ed559c0992 Mon Sep 17 00:00:00 2001 From: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Date: Mon, 6 Jan 2014 16:30:21 +0900 Subject: [PATCH] SELinux: Fix memory leak upon loading policy Commit 2463c26d "SELinux: put name based create rules in a hashtable" did not check return value from hashtab_insert() in filename_trans_read(). It leaks memory if hashtab_insert() returns error. unreferenced object 0xffff88005c9160d0 (size 8): comm "systemd", pid 1, jiffies 4294688674 (age 235.265s) hex dump (first 8 bytes): 57 0b 00 00 6b 6b 6b a5 W...kkk. backtrace: [<ffffffff816604ae>] kmemleak_alloc+0x4e/0xb0 [<ffffffff811cba5e>] kmem_cache_alloc_trace+0x12e/0x360 [<ffffffff812aec5d>] policydb_read+0xd1d/0xf70 [<ffffffff812b345c>] security_load_policy+0x6c/0x500 [<ffffffff812a623c>] sel_write_load+0xac/0x750 [<ffffffff811eb680>] vfs_write+0xc0/0x1f0 [<ffffffff811ec08c>] SyS_write+0x4c/0xa0 [<ffffffff81690419>] system_call_fastpath+0x16/0x1b [<ffffffffffffffff>] 0xffffffffffffffff However, we should not return EEXIST error to the caller, or the systemd will show below message and the boot sequence freezes. systemd[1]: Failed to load SELinux policy. Freezing. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Eric Paris <eparis@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: Paul Moore <pmoore@redhat.com>
2014-01-07Merge branch 'master' of git://git.infradead.org/users/pcmoore/selinux into nextJames Morris
Conflicts: security/selinux/hooks.c Resolved using request struct. Signed-off-by: James Morris <james.l.morris@oracle.com>
2014-01-06Merge to v3.13-rc7 for prerequisite changes in the Xen code for TPMJames Morris
2014-01-03ima: remove unneeded size_limit argument from ima_eventdigest_init_common()Roberto Sassu
This patch removes the 'size_limit' argument from ima_eventdigest_init_common(). Since the 'd' field will never include the hash algorithm as prefix and the 'd-ng' will always have it, we can use the hash algorithm to differentiate the two cases in the modified function (it is equal to HASH_ALGO__LAST in the first case, the opposite in the second). Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-01-03ima: pass HASH_ALGO__LAST as hash algo in ima_eventdigest_init()Roberto Sassu
Replace the '-1' value with HASH_ALGO__LAST in ima_eventdigest_init() as the called function ima_eventdigest_init_common() expects an unsigned char. Fix commit: 4d7aeee ima: define new template ima-ng and template fields d-ng and n-ng Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2014-01-03ima: change the default hash algorithm to SHA1 in ima_eventdigest_ng_init()Roberto Sassu
Replace HASH_ALGO__LAST with HASH_ALGO_SHA1 as the initial value of the hash algorithm so that the prefix 'sha1:' is added to violation digests. Fix commit: 4d7aeee ima: define new template ima-ng and template fields d-ng and n-ng Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Cc: <stable@vger.kernel.org> # 3.13.x Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-12-31Smack: File receive audit correctionCasey Schaufler
Eric Paris politely points out: Inside smack_file_receive() it seems like you are initting the audit field with LSM_AUDIT_DATA_TASK. And then use smk_ad_setfield_u_fs_path(). Seems like LSM_AUDIT_DATA_PATH would make more sense. (and depending on how it's used fix a crash...) He is correct. This puts things in order. Targeted for git://git.gitorious.org/smack-next/kernel.git Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
