path: root/security
2018-04-19apparmor: fix resource audit messages when auditing peerJohn Johansen
commit b5beb07ad32ab533027aa988d96a44965ec116f7 upstream. Resource auditing is using the peer field which is not available when the rlim data struct is used, because it is a different element of the same union. Accessing peer during resource auditing could cause garbage log entries or even oops the kernel. Move the rlim data block into the same struct as the peer field so they can be used together. CC: <stable@vger.kernel.org> Fixes: 86b92cb782b3 ("apparmor: move resource checks to using labels") Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-19apparmor: fix display of .ns_name for containersJohn Johansen
commit 040d9e2bce0a5b321c402b79ee43a8e8d2fd3b06 upstream. The .ns_name should not be virtualized by the current ns view. It needs to report the ns base name as that is being used during startup as part of determining apparmor policy namespace support. BugLink: http://bugs.launchpad.net/bugs/1746463 Fixes: d9f02d9c237aa ("apparmor: fix display of ns name") Cc: Stable <stable@vger.kernel.org> Reported-by: Serge Hallyn <serge@hallyn.com> Tested-by: Serge Hallyn <serge@hallyn.com> Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-19apparmor: fix logging of the existence test for signalsJohn Johansen
commit 98cf5bbff413eadf1b9cb195a7b80cc61c72a50e upstream. The existence test is not being properly logged as the signal mapping maps it to the last entry in the named signal table. This is done to help catch bugs by making the 0 mapped signal value invalid so that we can catch the signal value not being filled in. When fixing the off-by-one comparision logic the reporting of the existence test was broken, because the logic behind the mapped named table was hidden. Fix this by adding a define for the name lookup and using it. Cc: Stable <stable@vger.kernel.org> Fixes: f7dc4c9a855a1 ("apparmor: fix off-by-one comparison on MAXMAPPED_SIG") Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-24/dev/mem: Add bounce buffer for copy-outKees Cook
[ Upstream commit 22ec1a2aea73b9dfe340dff7945bd85af4cc6280 ] As done for /proc/kcore in commit df04abfd181a ("fs/proc/kcore.c: Add bounce buffer for ktext data") this adds a bounce buffer when reading memory via /dev/mem. This is needed to allow kernel text memory to be read out when built with CONFIG_HARDENED_USERCOPY (which refuses to read out kernel text) and without CONFIG_STRICT_DEVMEM (which would have refused to read any RAM contents at all). Since this build configuration isn't common (most systems with CONFIG_HARDENED_USERCOPY also have CONFIG_STRICT_DEVMEM), this also tries to inform Kconfig about the recommended settings. This patch is modified from Brad Spengler/PaX Team's changes to /dev/mem code in the last public patch of grsecurity/PaX based on my understanding of the code. Changes or omissions from the original code are mine and don't reflect the original grsecurity/PaX code. Reported-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Fixes: f5509cc18daa ("mm: Hardened usercopy") Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-19ima: relax requiring a file signature for new files with zero lengthMimi Zohar
[ Upstream commit b7e27bc1d42e8e0cc58b602b529c25cd0071b336 ] Custom policies can require file signatures based on LSM labels. These files are normally created and only afterwards labeled, requiring them to be signed. Instead of requiring file signatures based on LSM labels, entire filesystems could require file signatures. In this case, we need the ability of writing new files without requiring file signatures. The definition of a "new" file was originally defined as any file with a length of zero. Subsequent patches redefined a "new" file to be based on the FILE_CREATE open flag. By combining the open flag with a file size of zero, this patch relaxes the file signature requirement. Fixes: 1ac202e978e1 ima: accept previously set IMA_NEW_FILE Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25selinux: skip bounded transition processing if the policy isn't loadedPaul Moore
commit 4b14752ec4e0d87126e636384cf37c8dd9df157c upstream. We can't do anything reasonable in security_bounded_transition() if we don't have a policy loaded, and in fact we could run into problems with some of the code inside expecting a policy. Fix these problems like we do many others in security/selinux/ss/services.c by checking to see if the policy is loaded (ss_initialized) and returning quickly if it isn't. Reported-by: syzbot <syzkaller-bugs@googlegroups.com> Signed-off-by: Paul Moore <paul@paul-moore.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Reviewed-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25selinux: ensure the context is NUL terminated in security_context_to_sid_core()Paul Moore
commit ef28df55ac27e1e5cd122e19fa311d886d47a756 upstream. The syzbot/syzkaller automated tests found a problem in security_context_to_sid_core() during early boot (before we load the SELinux policy) where we could potentially feed context strings without NUL terminators into the strcmp() function. We already guard against this during normal operation (after the SELinux policy has been loaded) by making a copy of the context strings and explicitly adding a NUL terminator to the end. The patch extends this protection to the early boot case (no loaded policy) by moving the context copy earlier in security_context_to_sid_core(). Reported-by: syzbot <syzkaller@googlegroups.com> Signed-off-by: Paul Moore <paul@paul-moore.com> Reviewed-By: William Roberts <william.c.roberts@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-03ima/policy: fix parsing of fsuuidMike Rapoport
commit 36447456e1cca853188505f2a964dbbeacfc7a7a upstream. The switch to uuid_t invereted the logic of verfication that &entry->fsuuid is zero during parsing of "fsuuid=" rule. Instead of making sure the &entry->fsuuid field is not attempted to be overwritten, we bail out for perfectly correct rule. Fixes: 787d8c530af7 ("ima/policy: switch to use uuid_t") Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17security/Kconfig: Correct the Documentation reference for PTIW. Trevor King
commit a237f762681e2a394ca67f21df2feb2b76a3609b upstream. When the config option for PTI was added a reference to documentation was added as well. But the documentation did not exist at that point. The final documentation has a different file name. Fix it up to point to the proper file. Fixes: 385ce0ea ("x86/mm/pti: Add Kconfig") Signed-off-by: W. Trevor King <wking@tremily.us> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: linux-mm@kvack.org Cc: linux-security-module@vger.kernel.org Cc: James Morris <james.l.morris@oracle.com> Cc: "Serge E. Hallyn" <serge@hallyn.com> Cc: stable@vger.kernel.org Link: https://lkml.kernel.org/r/3009cc8ccbddcd897ec1e0cb6dda524929de0d14.1515799398.git.wking@tremily.us Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17apparmor: fix ptrace label match when matching stacked labelsJohn Johansen
commit 0dda0b3fb255048a221f736c8a2a24c674da8bf3 upstream. Given a label with a profile stack of A//&B or A//&C ... A ptrace rule should be able to specify a generic trace pattern with a rule like ptrace trace A//&**, however this is failing because while the correct label match routine is called, it is being done post label decomposition so it is always being done against a profile instead of the stacked label. To fix this refactor the cross check to pass the full peer label in to the label_match. Fixes: 290f458a4f16 ("apparmor: allow ptrace checks to be finer grained than just capability") Reported-by: Matthew Garrett <mjg59@google.com> Tested-by: Matthew Garrett <mjg59@google.com> Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-10apparmor: fix regression in mount mediation when feature set is pinnedJohn Johansen
commit 5b9f57cf47b87f07210875d6a24776b4496b818d upstream. When the mount code was refactored for Labels it was not correctly updated to check whether policy supported mediation of the mount class. This causes a regression when the kernel feature set is reported as supporting mount and policy is pinned to a feature set that does not support mount mediation. BugLink: https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=882697#41 Fixes: 2ea3ffb7782a ("apparmor: add mount mediation") Reported-by: Fabian Grünbichler <f.gruenbichler@proxmox.com> Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05capabilities: fix buffer overread on very short xattrEric Biggers
commit dc32b5c3e6e2ef29cef76d9ce1b92d394446150e upstream. If userspace attempted to set a "security.capability" xattr shorter than 4 bytes (e.g. 'setfattr -n security.capability -v x file'), then cap_convert_nscap() read past the end of the buffer containing the xattr value because it accessed the ->magic_etc field without verifying that the xattr value is long enough to contain that field. Fix it by validating the xattr value size first. This bug was found using syzkaller with KASAN. The KASAN report was as follows (cleaned up slightly): BUG: KASAN: slab-out-of-bounds in cap_convert_nscap+0x514/0x630 security/commoncap.c:498 Read of size 4 at addr ffff88002d8741c0 by task syz-executor1/2852 CPU: 0 PID: 2852 Comm: syz-executor1 Not tainted 4.15.0-rc6-00200-gcc0aac99d977 #253 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.11.0-20171110_100015-anatol 04/01/2014 Call Trace: __dump_stack lib/dump_stack.c:17 [inline] dump_stack+0xe3/0x195 lib/dump_stack.c:53 print_address_description+0x73/0x260 mm/kasan/report.c:252 kasan_report_error mm/kasan/report.c:351 [inline] kasan_report+0x235/0x350 mm/kasan/report.c:409 cap_convert_nscap+0x514/0x630 security/commoncap.c:498 setxattr+0x2bd/0x350 fs/xattr.c:446 path_setxattr+0x168/0x1b0 fs/xattr.c:472 SYSC_setxattr fs/xattr.c:487 [inline] SyS_setxattr+0x36/0x50 fs/xattr.c:483 entry_SYSCALL_64_fastpath+0x18/0x85 Fixes: 8db6c34f1dbc ("Introduce v3 namespaced file capabilities") Signed-off-by: Eric Biggers <ebiggers@google.com> Reviewed-by: Serge Hallyn <serge@hallyn.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02x86/mm/pti: Add KconfigDave Hansen
commit 385ce0ea4c078517fa51c261882c4e72fba53005 upstream. Finally allow CONFIG_PAGE_TABLE_ISOLATION to be enabled. PARAVIRT generally requires that the kernel not manage its own page tables. It also means that the hypervisor and kernel must agree wholeheartedly about what format the page tables are in and what they contain. PAGE_TABLE_ISOLATION, unfortunately, changes the rules and they can not be used together. I've seen conflicting feedback from maintainers lately about whether they want the Kconfig magic to go first or last in a patch series. It's going last here because the partially-applied series leads to kernels that can not boot in a bunch of cases. I did a run through the entire series with CONFIG_PAGE_TABLE_ISOLATION=y to look for build errors, though. [ tglx: Removed SMP and !PARAVIRT dependencies as they not longer exist ] Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Andy Lutomirski <luto@kernel.org> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: David Laight <David.Laight@aculab.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Eduardo Valentin <eduval@amazon.com> Cc: Greg KH <gregkh@linuxfoundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Juergen Gross <jgross@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Will Deacon <will.deacon@arm.com> Cc: aliguori@amazon.com Cc: daniel.gruss@iaik.tugraz.at Cc: hughd@google.com Cc: keescook@google.com Cc: linux-mm@kvack.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14apparmor: fix leak of null profile name if profile allocation failsJohn Johansen
[ Upstream commit 4633307e5ed6128975595df43f796a10c41d11c1 ] Fixes: d07881d2edb0 ("apparmor: move new_null_profile to after profile lookup fns()") Reported-by: Seth Arnold <seth.arnold@canonical.com> Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14KEYS: reject NULL restriction string when type is specifiedEric Biggers
commit 18026d866801d0c52e5550210563222bd6c7191d upstream. keyctl_restrict_keyring() allows through a NULL restriction when the "type" is non-NULL, which causes a NULL pointer dereference in asymmetric_lookup_restriction() when it calls strcmp() on the restriction string. But no key types actually use a "NULL restriction" to mean anything, so update keyctl_restrict_keyring() to reject it with EINVAL. Reported-by: syzbot <syzkaller@googlegroups.com> Fixes: 97d3aa0f3134 ("KEYS: Add a lookup_restriction function for the asymmetric key type") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14KEYS: add missing permission check for request_key() destinationEric Biggers
commit 4dca6ea1d9432052afb06baf2e3ae78188a4410b upstream. When the request_key() syscall is not passed a destination keyring, it links the requested key (if constructed) into the "default" request-key keyring. This should require Write permission to the keyring. However, there is actually no permission check. This can be abused to add keys to any keyring to which only Search permission is granted. This is because Search permission allows joining the keyring. keyctl_set_reqkey_keyring(KEY_REQKEY_DEFL_SESSION_KEYRING) then will set the default request-key keyring to the session keyring. Then, request_key() can be used to add keys to the keyring. Both negatively and positively instantiated keys can be added using this method. Adding negative keys is trivial. Adding a positive key is a bit trickier. It requires that either /sbin/request-key positively instantiates the key, or that another thread adds the key to the process keyring at just the right time, such that request_key() misses it initially but then finds it in construct_alloc_key(). Fix this bug by checking for Write permission to the keyring in construct_get_dest_keyring() when the default keyring is being used. We don't do the permission check for non-default keyrings because that was already done by the earlier call to lookup_user_key(). Also, request_key_and_link() is currently passed a 'struct key *' rather than a key_ref_t, so the "possessed" bit is unavailable. We also don't do the permission check for the "requestor keyring", to continue to support the use case described by commit 8bbf4976b59f ("KEYS: Alter use of key instantiation link-to-keyring argument") where /sbin/request-key recursively calls request_key() to add keys to the original requestor's destination keyring. (I don't know of any users who actually do that, though...) Fixes: 3e30148c3d52 ("[PATCH] Keys: Make request-key create an authorisation key") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-10ima: fix hash algorithm initializationBoshi Wang
[ Upstream commit ebe7c0a7be92bbd34c6ff5b55810546a0ee05bee ] The hash_setup function always sets the hash_setup_done flag, even when the hash algorithm is invalid. This prevents the default hash algorithm defined as CONFIG_IMA_DEFAULT_HASH from being used. This patch sets hash_setup_done flag only for valid hash algorithms. Fixes: e7a2ad7eb6f4 "ima: enable support for larger default filedata hash algorithms" Signed-off-by: Boshi Wang <wangboshi@huawei.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-05apparmor: fix oops in audit_signal_cb hookJohn Johansen
commit b12cbb21586277f72533769832c24cc6c1d60ab3 upstream. The apparmor_audit_data struct ordering got messed up during a merge conflict, resulting in the signal integer and peer pointer being in a union instead of a struct. For most of the 4.13 and 4.14 life cycle, this was hidden by commit 651e28c5537a ("apparmor: add base infastructure for socket mediation") which fixed the apparmor_audit_data struct when its data was added. When that commit was reverted in -rc7 the signal audit bug was exposed, and unfortunately it never showed up in any of the testing until after 4.14 was released. Shaun Khan, Zephaniah E. Loss-Cutler-Hull filed nearly simultaneous bug reports (with different oopes, the smaller of which is included below). Full credit goes to Tetsuo Handa for jumping on this as well and noticing the audit data struct problem and reporting it. [ 76.178568] BUG: unable to handle kernel paging request at ffffffff0eee3bc0 [ 76.178579] IP: audit_signal_cb+0x6c/0xe0 [ 76.178581] PGD 1a640a067 P4D 1a640a067 PUD 0 [ 76.178586] Oops: 0000 [#1] PREEMPT SMP [ 76.178589] Modules linked in: fuse rfcomm bnep usblp uvcvideo btusb btrtl btbcm btintel bluetooth ecdh_generic ip6table_filter ip6_tables xt_tcpudp nf_conntrack_ipv4 nf_defrag_ipv4 xt_conntrack nf_conntrack iptable_filter ip_tables x_tables intel_rapl joydev wmi_bmof serio_raw iwldvm iwlwifi shpchp kvm_intel kvm irqbypass autofs4 algif_skcipher nls_iso8859_1 nls_cp437 crc32_pclmul ghash_clmulni_intel [ 76.178620] CPU: 0 PID: 10675 Comm: pidgin Not tainted 4.14.0-f1-dirty #135 [ 76.178623] Hardware name: Hewlett-Packard HP EliteBook Folio 9470m/18DF, BIOS 68IBD Ver. F.62 10/22/2015 [ 76.178625] task: ffff9c7a94c31dc0 task.stack: ffffa09b02a4c000 [ 76.178628] RIP: 0010:audit_signal_cb+0x6c/0xe0 [ 76.178631] RSP: 0018:ffffa09b02a4fc08 EFLAGS: 00010292 [ 76.178634] RAX: ffffa09b02a4fd60 RBX: ffff9c7aee0741f8 RCX: 0000000000000000 [ 76.178636] RDX: ffffffffee012290 RSI: 0000000000000006 RDI: ffff9c7a9493d800 [ 76.178638] RBP: ffffa09b02a4fd40 R08: 000000000000004d R09: ffffa09b02a4fc46 [ 76.178641] R10: ffffa09b02a4fcb8 R11: ffff9c7ab44f5072 R12: ffffa09b02a4fd40 [ 76.178643] R13: ffffffff9e447be0 R14: ffff9c7a94c31dc0 R15: 0000000000000001 [ 76.178646] FS: 00007f8b11ba2a80(0000) GS:ffff9c7afea00000(0000) knlGS:0000000000000000 [ 76.178648] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 76.178650] CR2: ffffffff0eee3bc0 CR3: 00000003d5209002 CR4: 00000000001606f0 [ 76.178652] Call Trace: [ 76.178660] common_lsm_audit+0x1da/0x780 [ 76.178665] ? d_absolute_path+0x60/0x90 [ 76.178669] ? aa_check_perms+0xcd/0xe0 [ 76.178672] aa_check_perms+0xcd/0xe0 [ 76.178675] profile_signal_perm.part.0+0x90/0xa0 [ 76.178679] aa_may_signal+0x16e/0x1b0 [ 76.178686] apparmor_task_kill+0x51/0x120 [ 76.178690] security_task_kill+0x44/0x60 [ 76.178695] group_send_sig_info+0x25/0x60 [ 76.178699] kill_pid_info+0x36/0x60 [ 76.178703] SYSC_kill+0xdb/0x180 [ 76.178707] ? preempt_count_sub+0x92/0xd0 [ 76.178712] ? _raw_write_unlock_irq+0x13/0x30 [ 76.178716] ? task_work_run+0x6a/0x90 [ 76.178720] ? exit_to_usermode_loop+0x80/0xa0 [ 76.178723] entry_SYSCALL_64_fastpath+0x13/0x94 [ 76.178727] RIP: 0033:0x7f8b0e58b767 [ 76.178729] RSP: 002b:00007fff19efd4d8 EFLAGS: 00000206 ORIG_RAX: 000000000000003e [ 76.178732] RAX: ffffffffffffffda RBX: 0000557f3e3c2050 RCX: 00007f8b0e58b767 [ 76.178735] RDX: 0000000000000000 RSI: 0000000000000000 RDI: 000000000000263b [ 76.178737] RBP: 0000000000000000 R08: 0000557f3e3c2270 R09: 0000000000000001 [ 76.178739] R10: 000000000000022d R11: 0000000000000206 R12: 0000000000000000 [ 76.178741] R13: 0000000000000001 R14: 0000557f3e3c13c0 R15: 0000000000000000 [ 76.178745] Code: 48 8b 55 18 48 89 df 41 b8 20 00 08 01 5b 5d 48 8b 42 10 48 8b 52 30 48 63 48 4c 48 8b 44 c8 48 31 c9 48 8b 70 38 e9 f4 fd 00 00 <48> 8b 14 d5 40 27 e5 9e 48 c7 c6 7d 07 19 9f 48 89 df e8 fd 35 [ 76.178794] RIP: audit_signal_cb+0x6c/0xe0 RSP: ffffa09b02a4fc08 [ 76.178796] CR2: ffffffff0eee3bc0 [ 76.178799] ---[ end trace 514af9529297f1a3 ]--- Fixes: cd1dbf76b23d ("apparmor: add the ability to mediate signals") Reported-by: Zephaniah E. Loss-Cutler-Hull <warp-spam_kernel@aehallh.com> Reported-by: Shuah Khan <shuahkh@osg.samsung.com> Suggested-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Tested-by: Ivan Kozik <ivan@ludios.org> Tested-by: Zephaniah E. Loss-Cutler-Hull <warp-spam_kernel@aehallh.com> Tested-by: Christian Boltz <apparmor@cboltz.de> Tested-by: Shuah Khan <shuahkh@osg.samsung.com> Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-24ima: do not update security.ima if appraisal status is not INTEGRITY_PASSRoberto Sassu
commit 020aae3ee58c1af0e7ffc4e2cc9fe4dc630338cb upstream. Commit b65a9cfc2c38 ("Untangling ima mess, part 2: deal with counters") moved the call of ima_file_check() from may_open() to do_filp_open() at a point where the file descriptor is already opened. This breaks the assumption made by IMA that file descriptors being closed belong to files whose access was granted by ima_file_check(). The consequence is that security.ima and security.evm are updated with good values, regardless of the current appraisal status. For example, if a file does not have security.ima, IMA will create it after opening the file for writing, even if access is denied. Access to the file will be allowed afterwards. Avoid this issue by checking the appraisal status before updating security.ima. Signed-off-by: Roberto Sassu <roberto.sassu@huawei.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-08apparmor: fix off-by-one comparison on MAXMAPPED_SIGJohn Johansen
This came in yesterday, and I have verified our regression tests were missing this and it can cause an oops. Please apply. There is a an off-by-one comparision on sig against MAXMAPPED_SIG that can lead to a read outside the sig_map array if sig is MAXMAPPED_SIG. Fix this. Verified that the check is an out of bounds case that can cause an oops. Revised: add comparison fix to second case Fixes: cd1dbf76b23d ("apparmor: add the ability to mediate signals") Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-11-02Merge tag 'spdx_identifiers-4.14-rc8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull initial SPDX identifiers from Greg KH: "License cleanup: add SPDX license identifiers to some files Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" * tag 'spdx_identifiers-4.14-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: License cleanup: add SPDX license identifier to uapi header files with a license License cleanup: add SPDX license identifier to uapi header files with no license License cleanup: add SPDX GPL-2.0 license identifier to files with no license
2017-11-02KEYS: trusted: fix writing past end of buffer in trusted_read()Eric Biggers
When calling keyctl_read() on a key of type "trusted", if the user-supplied buffer was too small, the kernel ignored the buffer length and just wrote past the end of the buffer, potentially corrupting userspace memory. Fix it by instead returning the size required, as per the documentation for keyctl_read(). We also don't even fill the buffer at all in this case, as this is slightly easier to implement than doing a short read, and either behavior appears to be permitted. It also makes it match the behavior of the "encrypted" key type. Fixes: d00a1c72f7f4 ("keys: add new trusted key-type") Reported-by: Ben Hutchings <ben@decadent.org.uk> Cc: <stable@vger.kernel.org> # v2.6.38+ Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Reviewed-by: James Morris <james.l.morris@oracle.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2017-11-02KEYS: return full count in keyring_read() if buffer is too smallEric Biggers
Commit e645016abc80 ("KEYS: fix writing past end of user-supplied buffer in keyring_read()") made keyring_read() stop corrupting userspace memory when the user-supplied buffer is too small. However it also made the return value in that case be the short buffer size rather than the size required, yet keyctl_read() is actually documented to return the size required. Therefore, switch it over to the documented behavior. Note that for now we continue to have it fill the short buffer, since it did that before (pre-v3.13) and dump_key_tree_aux() in keyutils arguably relies on it. Fixes: e645016abc80 ("KEYS: fix writing past end of user-supplied buffer in keyring_read()") Reported-by: Ben Hutchings <ben@decadent.org.uk> Cc: <stable@vger.kernel.org> # v3.13+ Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <james.l.morris@oracle.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2017-10-26Revert "apparmor: add base infastructure for socket mediation"Linus Torvalds
This reverts commit 651e28c5537abb39076d3949fb7618536f1d242e. This caused a regression: "The specific problem is that dnsmasq refuses to start on openSUSE Leap 42.2. The specific cause is that and attempt to open a PF_LOCAL socket gets EACCES. This means that networking doesn't function on a system with a 4.14-rc2 system." Sadly, the developers involved seemed to be in denial for several weeks about this, delaying the revert. This has not been a good release for the security subsystem, and this area needs to change development practices. Reported-and-bisected-by: James Bottomley <James.Bottomley@hansenpartnership.com> Tracked-by: Thorsten Leemhuis <regressions@leemhuis.info> Cc: John Johansen <john.johansen@canonical.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Seth Arnold <seth.arnold@canonical.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-10-19commoncap: move assignment of fs_ns to avoid null pointer dereferenceColin Ian King
The pointer fs_ns is assigned from inode->i_ib->s_user_ns before a null pointer check on inode, hence if inode is actually null we will get a null pointer dereference on this assignment. Fix this by only dereferencing inode after the null pointer check on inode. Detected by CoverityScan CID#1455328 ("Dereference before null check") Fixes: 8db6c34f1dbc ("Introduce v3 namespaced file capabilities") Signed-off-by: Colin Ian King <colin.king@canonical.com> Cc: stable@vger.kernel.org Acked-by: Serge Hallyn <serge@hallyn.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2017-10-19Merge commit 'tags/keys-fixes-20171018' into fixes-v4.14-rc5James Morris
2017-10-18KEYS: load key flags and expiry time atomically in proc_keys_show()Eric Biggers
In proc_keys_show(), the key semaphore is not held, so the key ->flags and ->expiry can be changed concurrently. We therefore should read them atomically just once. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com>
2017-10-18KEYS: Load key expiry time atomically in keyring_search_iterator()Eric Biggers
Similar to the case for key_validate(), we should load the key ->expiry once atomically in keyring_search_iterator(), since it can be changed concurrently with the flags whenever the key semaphore isn't held. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com>
2017-10-18KEYS: load key flags and expiry time atomically in key_validate()Eric Biggers
In key_validate(), load the flags and expiry time once atomically, since these can change concurrently if key_validate() is called without the key semaphore held. And we don't want to get inconsistent results if a variable is referenced multiple times. For example, key->expiry was referenced in both 'if (key->expiry)' and in 'if (now.tv_sec >= key->expiry)', making it theoretically possible to see a spurious EKEYEXPIRED while the expiration time was being removed, i.e. set to 0. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com>
2017-10-18KEYS: don't let add_key() update an uninstantiated keyDavid Howells
Currently, when passed a key that already exists, add_key() will call the key's ->update() method if such exists. But this is heavily broken in the case where the key is uninstantiated because it doesn't call __key_instantiate_and_link(). Consequently, it doesn't do most of the things that are supposed to happen when the key is instantiated, such as setting the instantiation state, clearing KEY_FLAG_USER_CONSTRUCT and awakening tasks waiting on it, and incrementing key->user->nikeys. It also never takes key_construction_mutex, which means that ->instantiate() can run concurrently with ->update() on the same key. In the case of the "user" and "logon" key types this causes a memory leak, at best. Maybe even worse, the ->update() methods of the "encrypted" and "trusted" key types actually just dereference a NULL pointer when passed an uninstantiated key. Change key_create_or_update() to wait interruptibly for the key to finish construction before continuing. This patch only affects *uninstantiated* keys. For now we still allow a negatively instantiated key to be updated (thereby positively instantiating it), although that's broken too (the next patch fixes it) and I'm not sure that anyone actually uses that functionality either. Here is a simple reproducer for the bug using the "encrypted" key type (requires CONFIG_ENCRYPTED_KEYS=y), though as noted above the bug pertained to more than just the "encrypted" key type: #include <stdlib.h> #include <unistd.h> #include <keyutils.h> int main(void) { int ringid = keyctl_join_session_keyring(NULL); if (fork()) { for (;;) { const char payload[] = "update user:foo 32"; usleep(rand() % 10000); add_key("encrypted", "desc", payload, sizeof(payload), ringid); keyctl_clear(ringid); } } else { for (;;) request_key("encrypted", "desc", "callout_info", ringid); } } It causes: BUG: unable to handle kernel NULL pointer dereference at 0000000000000018 IP: encrypted_update+0xb0/0x170 PGD 7a178067 P4D 7a178067 PUD 77269067 PMD 0 PREEMPT SMP CPU: 0 PID: 340 Comm: reproduce Tainted: G D 4.14.0-rc1-00025-g428490e38b2e #796 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 task: ffff8a467a39a340 task.stack: ffffb15c40770000 RIP: 0010:encrypted_update+0xb0/0x170 RSP: 0018:ffffb15c40773de8 EFLAGS: 00010246 RAX: 0000000000000000 RBX: ffff8a467a275b00 RCX: 0000000000000000 RDX: 0000000000000005 RSI: ffff8a467a275b14 RDI: ffffffffb742f303 RBP: ffffb15c40773e20 R08: 0000000000000000 R09: ffff8a467a275b17 R10: 0000000000000020 R11: 0000000000000000 R12: 0000000000000000 R13: 0000000000000000 R14: ffff8a4677057180 R15: ffff8a467a275b0f FS: 00007f5d7fb08700(0000) GS:ffff8a467f200000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000018 CR3: 0000000077262005 CR4: 00000000001606f0 Call Trace: key_create_or_update+0x2bc/0x460 SyS_add_key+0x10c/0x1d0 entry_SYSCALL_64_fastpath+0x1f/0xbe RIP: 0033:0x7f5d7f211259 RSP: 002b:00007ffed03904c8 EFLAGS: 00000246 ORIG_RAX: 00000000000000f8 RAX: ffffffffffffffda RBX: 000000003b2a7955 RCX: 00007f5d7f211259 RDX: 00000000004009e4 RSI: 00000000004009ff RDI: 0000000000400a04 RBP: 0000000068db8bad R08: 000000003b2a7955 R09: 0000000000000004 R10: 000000000000001a R11: 0000000000000246 R12: 0000000000400868 R13: 00007ffed03905d0 R14: 0000000000000000 R15: 0000000000000000 Code: 77 28 e8 64 34 1f 00 45 31 c0 31 c9 48 8d 55 c8 48 89 df 48 8d 75 d0 e8 ff f9 ff ff 85 c0 41 89 c4 0f 88 84 00 00 00 4c 8b 7d c8 <49> 8b 75 18 4c 89 ff e8 24 f8 ff ff 85 c0 41 89 c4 78 6d 49 8b RIP: encrypted_update+0xb0/0x170 RSP: ffffb15c40773de8 CR2: 0000000000000018 Cc: <stable@vger.kernel.org> # v2.6.12+ Reported-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> cc: Eric Biggers <ebiggers@google.com>
2017-10-18KEYS: Fix race between updating and finding a negative keyDavid Howells
Consolidate KEY_FLAG_INSTANTIATED, KEY_FLAG_NEGATIVE and the rejection error into one field such that: (1) The instantiation state can be modified/read atomically. (2) The error can be accessed atomically with the state. (3) The error isn't stored unioned with the payload pointers. This deals with the problem that the state is spread over three different objects (two bits and a separate variable) and reading or updating them atomically isn't practical, given that not only can uninstantiated keys change into instantiated or rejected keys, but rejected keys can also turn into instantiated keys - and someone accessing the key might not be using any locking. The main side effect of this problem is that what was held in the payload may change, depending on the state. For instance, you might observe the key to be in the rejected state. You then read the cached error, but if the key semaphore wasn't locked, the key might've become instantiated between the two reads - and you might now have something in hand that isn't actually an error code. The state is now KEY_IS_UNINSTANTIATED, KEY_IS_POSITIVE or a negative error code if the key is negatively instantiated. The key_is_instantiated() function is replaced with key_is_positive() to avoid confusion as negative keys are also 'instantiated'. Additionally, barriering is included: (1) Order payload-set before state-set during instantiation. (2) Order state-read before payload-read when using the key. Further separate barriering is necessary if RCU is being used to access the payload content after reading the payload pointers. Fixes: 146aa8b1453b ("KEYS: Merge the type-specific data with the payload data") Cc: stable@vger.kernel.org # v4.4+ Reported-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Eric Biggers <ebiggers@google.com>
2017-10-18security/keys: BIG_KEY requires CONFIG_CRYPTOArnd Bergmann
The recent rework introduced a possible randconfig build failure when CONFIG_CRYPTO configured to only allow modules: security/keys/big_key.o: In function `big_key_crypt': big_key.c:(.text+0x29f): undefined reference to `crypto_aead_setkey' security/keys/big_key.o: In function `big_key_init': big_key.c:(.init.text+0x1a): undefined reference to `crypto_alloc_aead' big_key.c:(.init.text+0x45): undefined reference to `crypto_aead_setauthsize' big_key.c:(.init.text+0x77): undefined reference to `crypto_destroy_tfm' crypto/gcm.o: In function `gcm_hash_crypt_remain_continue': gcm.c:(.text+0x167): undefined reference to `crypto_ahash_finup' crypto/gcm.o: In function `crypto_gcm_exit_tfm': gcm.c:(.text+0x847): undefined reference to `crypto_destroy_tfm' When we 'select CRYPTO' like the other users, we always get a configuration that builds. Fixes: 428490e38b2e ("security/keys: rewrite all of big_key crypto") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David Howells <dhowells@redhat.com>
2017-10-12KEYS: encrypted: fix dereference of NULL user_key_payloadEric Biggers
A key of type "encrypted" references a "master key" which is used to encrypt and decrypt the encrypted key's payload. However, when we accessed the master key's payload, we failed to handle the case where the master key has been revoked, which sets the payload pointer to NULL. Note that request_key() *does* skip revoked keys, but there is still a window where the key can be revoked before we acquire its semaphore. Fix it by checking for a NULL payload, treating it like a key which was already revoked at the time it was requested. This was an issue for master keys of type "user" only. Master keys can also be of type "trusted", but those cannot be revoked. Fixes: 7e70cb497850 ("keys: add new key-type encrypted") Reviewed-by: James Morris <james.l.morris@oracle.com> Cc: <stable@vger.kernel.org> [v2.6.38+] Cc: Mimi Zohar <zohar@linux.vnet.ibm.com> Cc: David Safford <safford@us.ibm.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com>
2017-10-04lsm: fix smack_inode_removexattr and xattr_getsecurity memleakCasey Schaufler
security_inode_getsecurity() provides the text string value of a security attribute. It does not provide a "secctx". The code in xattr_getsecurity() that calls security_inode_getsecurity() and then calls security_release_secctx() happened to work because SElinux and Smack treat the attribute and the secctx the same way. It fails for cap_inode_getsecurity(), because that module has no secctx that ever needs releasing. It turns out that Smack is the one that's doing things wrong by not allocating memory when instructed to do so by the "alloc" parameter. The fix is simple enough. Change the security_release_secctx() to kfree() because it isn't a secctx being returned by security_inode_getsecurity(). Change Smack to allocate the string when told to do so. Note: this also fixes memory leaks for LSMs which implement inode_getsecurity but not release_secctx, such as capabilities. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> Reported-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Cc: stable@vger.kernel.org Signed-off-by: James Morris <james.l.morris@oracle.com>
2017-09-28Merge commit 'keys-fixes-20170927' into fixes-v4.14-rc3James Morris
From David Howells: "There are two sets of patches here: (1) A bunch of core keyrings bug fixes from Eric Biggers. (2) Fixing big_key to use safe crypto from Jason A. Donenfeld."
2017-09-25security/keys: rewrite all of big_key cryptoJason A. Donenfeld
This started out as just replacing the use of crypto/rng with get_random_bytes_wait, so that we wouldn't use bad randomness at boot time. But, upon looking further, it appears that there were even deeper underlying cryptographic problems, and that this seems to have been committed with very little crypto review. So, I rewrote the whole thing, trying to keep to the conventions introduced by the previous author, to fix these cryptographic flaws. It makes no sense to seed crypto/rng at boot time and then keep using it like this, when in fact there's already get_random_bytes_wait, which can ensure there's enough entropy and be a much more standard way of generating keys. Since this sensitive material is being stored untrusted, using ECB and no authentication is simply not okay at all. I find it surprising and a bit horrifying that this code even made it past basic crypto review, which perhaps points to some larger issues. This patch moves from using AES-ECB to using AES-GCM. Since keys are uniquely generated each time, we can set the nonce to zero. There was also a race condition in which the same key would be reused at the same time in different threads. A mutex fixes this issue now. So, to summarize, this commit fixes the following vulnerabilities: * Low entropy key generation, allowing an attacker to potentially guess or predict keys. * Unauthenticated encryption, allowing an attacker to modify the cipher text in particular ways in order to manipulate the plaintext, which is is even more frightening considering the next point. * Use of ECB mode, allowing an attacker to trivially swap blocks or compare identical plaintext blocks. * Key re-use. * Faulty memory zeroing. Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com> Reviewed-by: Eric Biggers <ebiggers3@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Kirill Marinushkin <k.marinushkin@gmail.com> Cc: security@kernel.org Cc: stable@vger.kernel.org
2017-09-25security/keys: properly zero out sensitive key material in big_keyJason A. Donenfeld
Error paths forgot to zero out sensitive material, so this patch changes some kfrees into a kzfrees. Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Eric Biggers <ebiggers3@gmail.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Kirill Marinushkin <k.marinushkin@gmail.com> Cc: security@kernel.org Cc: stable@vger.kernel.org
2017-09-25KEYS: use kmemdup() in request_key_auth_new()Eric Biggers
kmemdup() is preferred to kmalloc() followed by memcpy(). Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com>
2017-09-25KEYS: restrict /proc/keys by credentials at open timeEric Biggers
When checking for permission to view keys whilst reading from /proc/keys, we should use the credentials with which the /proc/keys file was opened. This is because, in a classic type of exploit, it can be possible to bypass checks for the *current* credentials by passing the file descriptor to a suid program. Following commit 34dbbcdbf633 ("Make file credentials available to the seqfile interfaces") we can finally fix it. So let's do it. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com>
2017-09-25KEYS: reset parent each time before searching key_user_treeEric Biggers
In key_user_lookup(), if there is no key_user for the given uid, we drop key_user_lock, allocate a new key_user, and search the tree again. But we failed to set 'parent' to NULL at the beginning of the second search. If the tree were to be empty for the second search, the insertion would be done with an invalid 'parent', scribbling over freed memory. Fortunately this can't actually happen currently because the tree always contains at least the root_key_user. But it still should be fixed to make the code more robust. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com>
2017-09-25KEYS: prevent KEYCTL_READ on negative keyEric Biggers
Because keyctl_read_key() looks up the key with no permissions requested, it may find a negatively instantiated key. If the key is also possessed, we went ahead and called ->read() on the key. But the key payload will actually contain the ->reject_error rather than the normal payload. Thus, the kernel oopses trying to read the user_key_payload from memory address (int)-ENOKEY = 0x00000000ffffff82. Fortunately the payload data is stored inline, so it shouldn't be possible to abuse this as an arbitrary memory read primitive... Reproducer: keyctl new_session keyctl request2 user desc '' @s keyctl read $(keyctl show | awk '/user: desc/ {print $1}') It causes a crash like the following: BUG: unable to handle kernel paging request at 00000000ffffff92 IP: user_read+0x33/0xa0 PGD 36a54067 P4D 36a54067 PUD 0 Oops: 0000 [#1] SMP CPU: 0 PID: 211 Comm: keyctl Not tainted 4.14.0-rc1 #337 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-20170228_101828-anatol 04/01/2014 task: ffff90aa3b74c3c0 task.stack: ffff9878c0478000 RIP: 0010:user_read+0x33/0xa0 RSP: 0018:ffff9878c047bee8 EFLAGS: 00010246 RAX: 0000000000000001 RBX: ffff90aa3d7da340 RCX: 0000000000000017 RDX: 0000000000000000 RSI: 00000000ffffff82 RDI: ffff90aa3d7da340 RBP: ffff9878c047bf00 R08: 00000024f95da94f R09: 0000000000000000 R10: 0000000000000001 R11: 0000000000000000 R12: 0000000000000000 R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000 FS: 00007f58ece69740(0000) GS:ffff90aa3e200000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00000000ffffff92 CR3: 0000000036adc001 CR4: 00000000003606f0 Call Trace: keyctl_read_key+0xac/0xe0 SyS_keyctl+0x99/0x120 entry_SYSCALL_64_fastpath+0x1f/0xbe RIP: 0033:0x7f58ec787bb9 RSP: 002b:00007ffc8d401678 EFLAGS: 00000206 ORIG_RAX: 00000000000000fa RAX: ffffffffffffffda RBX: 00007ffc8d402800 RCX: 00007f58ec787bb9 RDX: 0000000000000000 RSI: 00000000174a63ac RDI: 000000000000000b RBP: 0000000000000004 R08: 00007ffc8d402809 R09: 0000000000000020 R10: 0000000000000000 R11: 0000000000000206 R12: 00007ffc8d402800 R13: 00007ffc8d4016e0 R14: 0000000000000000 R15: 0000000000000000 Code: e5 41 55 49 89 f5 41 54 49 89 d4 53 48 89 fb e8 a4 b4 ad ff 85 c0 74 09 80 3d b9 4c 96 00 00 74 43 48 8b b3 20 01 00 00 4d 85 ed <0f> b7 5e 10 74 29 4d 85 e4 74 24 4c 39 e3 4c 89 e2 4c 89 ef 48 RIP: user_read+0x33/0xa0 RSP: ffff9878c047bee8 CR2: 00000000ffffff92 Fixes: 61ea0c0ba904 ("KEYS: Skip key state checks when checking for possession") Cc: <stable@vger.kernel.org> [v3.13+] Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com>
2017-09-25KEYS: prevent creating a different user's keyringsEric Biggers
It was possible for an unprivileged user to create the user and user session keyrings for another user. For example: sudo -u '#3000' sh -c 'keyctl add keyring _uid.4000 "" @u keyctl add keyring _uid_ses.4000 "" @u sleep 15' & sleep 1 sudo -u '#4000' keyctl describe @u sudo -u '#4000' keyctl describe @us This is problematic because these "fake" keyrings won't have the right permissions. In particular, the user who created them first will own them and will have full access to them via the possessor permissions, which can be used to compromise the security of a user's keys: -4: alswrv-----v------------ 3000 0 keyring: _uid.4000 -5: alswrv-----v------------ 3000 0 keyring: _uid_ses.4000 Fix it by marking user and user session keyrings with a flag KEY_FLAG_UID_KEYRING. Then, when searching for a user or user session keyring by name, skip all keyrings that don't have the flag set. Fixes: 69664cf16af4 ("keys: don't generate user and user session keyrings unless they're accessed") Cc: <stable@vger.kernel.org> [v2.6.26+] Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com>
2017-09-25KEYS: fix writing past end of user-supplied buffer in keyring_read()Eric Biggers
Userspace can call keyctl_read() on a keyring to get the list of IDs of keys in the keyring. But if the user-supplied buffer is too small, the kernel would write the full list anyway --- which will corrupt whatever userspace memory happened to be past the end of the buffer. Fix it by only filling the space that is available. Fixes: b2a4df200d57 ("KEYS: Expand the capacity of a keyring") Cc: <stable@vger.kernel.org> [v3.13+] Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com>
2017-09-25KEYS: fix key refcount leak in keyctl_read_key()Eric Biggers
In keyctl_read_key(), if key_permission() were to return an error code other than EACCES, we would leak a the reference to the key. This can't actually happen currently because key_permission() can only return an error code other than EACCES if security_key_permission() does, only SELinux and Smack implement that hook, and neither can return an error code other than EACCES. But it should still be fixed, as it is a bug waiting to happen. Fixes: 29db91906340 ("[PATCH] Keys: Add LSM hooks for key management [try #3]") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com>
2017-09-25KEYS: fix key refcount leak in keyctl_assume_authority()Eric Biggers
In keyctl_assume_authority(), if keyctl_change_reqkey_auth() were to fail, we would leak the reference to the 'authkey'. Currently this can only happen if prepare_creds() fails to allocate memory. But it still should be fixed, as it is a more severe bug waiting to happen. This patch also moves the read of 'authkey->serial' to before the reference to the authkey is dropped. Doing the read after dropping the reference is very fragile because it assumes we still hold another reference to the key. (Which we do, in current->cred->request_key_auth, but there's no reason not to write it in the "obviously correct" way.) Fixes: d84f4f992cbd ("CRED: Inaugurate COW credentials") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com>
2017-09-25KEYS: don't revoke uninstantiated key in request_key_auth_new()Eric Biggers
If key_instantiate_and_link() were to fail (which fortunately isn't possible currently), the call to key_revoke(authkey) would crash with a NULL pointer dereference in request_key_auth_revoke() because the key has not yet been instantiated. Fix this by removing the call to key_revoke(). key_put() is sufficient, as it's not possible for an uninstantiated authkey to have been used for anything yet. Fixes: b5f545c880a2 ("[PATCH] keys: Permit running process to instantiate keys") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com>
2017-09-25KEYS: fix cred refcount leak in request_key_auth_new()Eric Biggers
In request_key_auth_new(), if key_alloc() or key_instantiate_and_link() were to fail, we would leak a reference to the 'struct cred'. Currently this can only happen if key_alloc() fails to allocate memory. But it still should be fixed, as it is a more severe bug waiting to happen. Fix it by cleaning things up to use a helper function which frees a 'struct request_key_auth' correctly. Fixes: d84f4f992cbd ("CRED: Inaugurate COW credentials") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com>
2017-09-24Merge branch 'next-general' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull misc security layer update from James Morris: "This is the remaining 'general' change in the security tree for v4.14, following the direct merging of SELinux (+ TOMOYO), AppArmor, and seccomp. That's everything now for the security tree except IMA, which will follow shortly (I've been traveling for the past week with patchy internet)" * 'next-general' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: security: fix description of values returned by cap_inode_need_killpriv
2017-09-23security: fix description of values returned by cap_inode_need_killprivStefan Berger
cap_inode_need_killpriv returns 1 if security.capability exists and has a value and inode_killpriv() is required, 0 otherwise. Fix the description of the return value to reflect this. Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Reviewed-by: Serge Hallyn <serge@hallyn.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
