path: root/security
2005-05-01[PATCH] SELinux: add finer grained permissions to Netlink audit processingJames Morris
This patch provides finer grained permissions for the audit family of Netlink sockets under SELinux. 1. We need a way to differentiate between privileged and unprivileged reads of kernel data maintained by the audit subsystem. The AUDIT_GET operation is unprivileged: it returns the current status of the audit subsystem (e.g. whether it's enabled etc.). The AUDIT_LIST operation however returns a list of the current audit ruleset, which is considered privileged by the audit folk. To deal with this, a new SELinux permission has been implemented and applied to the operation: nlmsg_readpriv, which can be allocated to appropriately privileged domains. Unprivileged domains would only be allocated nlmsg_read. 2. There is a requirement for certain domains to generate audit events from userspace. These events need to be collected by the kernel, collated and transmitted sequentially back to the audit daemon. An example is user level login, an auditable event under CAPP, where login-related domains generate AUDIT_USER messages via PAM which are relayed back to auditd via the kernel. To prevent handing out nlmsg_write permissions to such domains, a new permission has been added, nlmsg_relay, which is intended for this type of purpose: data is passed via the kernel back to userspace but no privileged information is written to the kernel. Also, AUDIT_LOGIN messages are now valid only for kernel->user messaging, so this value has been removed from the SELinux nlmsgtab (which is only used to check user->kernel messages). Signed-off-by: James Morris <jmorris@redhat.com> Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] SELinux: cleanup ipc_has_permStephen Smalley
This patch removes the sclass argument from ipc_has_perm in the SELinux module, as it can be obtained from the ipc security structure. The use of a separate argument was a legacy of the older precondition function handling in SELinux and is obsolete. Please apply. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-24[SELINUX]: Fix ipv6_skip_exthdr() invocation causing OOPS.Herbert Xu
The SELinux hooks invoke ipv6_skip_exthdr() with an incorrect length final argument. However, the length argument turns out to be superfluous. I was just reading ipv6_skip_exthdr and it occured to me that we can get rid of len altogether. The only place where len is used is to check whether the skb has two bytes for ipv6_opt_hdr. This check is done by skb_header_pointer/skb_copy_bits anyway. Now it might appear that we've made the code slower by deferring the check to skb_copy_bits. However, this check should not trigger in the common case so this is OK. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-18[PATCH] SELinux: fix deadlock on dcache lockStephen Smalley
This fixes a deadlock on the dcache lock detected during testing at IBM by moving the logging of the current executable information from the SELinux avc_audit function to audit_log_exit (via an audit_log_task_info helper) for processing upon syscall exit. For consistency, the patch also removes the logging of other task-related information from avc_audit, deferring handling to audit_log_exit instead. This allows simplification of the avc_audit code, allows the exe information to be obtained more reliably, always includes the comm information (useful for scripts), and avoids including bogus task information for checks performed from irq or softirq. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@redhat.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] SELinux: add support for NETLINK_KOBJECT_UEVENTJames Morris
This patch adds SELinux support for the KOBJECT_UEVENT Netlink family, so that SELinux can apply finer grained controls to it. For example, security policy for hald can be locked down to the KOBJECT_UEVENT Netlink family only. Currently, this family simply defaults to the default Netlink socket class. Note that some new permission definitions are added to sync with changes in the core userspace policy package, which auto-generates header files. Signed-off-by: James Morris <jmorris@redhat.com> Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] SELinux: fix bug in Netlink message type detectionJames Morris
This patch fixes a bug in the SELinux Netlink message type detection code, where the wrong constant was being used in a case statement. The incorrect value is not valid for this class of object so it would not have been reached, and fallen through to a default handler for all Netlink messages. Signed-off-by: James Morris <jmorris@redhat.com> Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
