git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull general security subsystem updates from James Morris:
"TPM (from Jarkko):
- essential clean up for tpm_crb so that ARM64 and x86 versions do
not distract each other as much as before
- /dev/tpm0 rejects now too short writes (shorter buffer than
specified in the command header
- use DMA-safe buffer in tpm_tis_spi
- otherwise mostly minor fixes.
Smack:
- base support for overlafs
Capabilities:
- BPRM_FCAPS fixes, from Richard Guy Briggs:
The audit subsystem is adding a BPRM_FCAPS record when auditing
setuid application execution (SYSCALL execve). This is not expected
as it was supposed to be limited to when the file system actually
had capabilities in an extended attribute. It lists all
capabilities making the event really ugly to parse what is
happening. The PATH record correctly records the setuid bit and
owner. Suppress the BPRM_FCAPS record on set*id.
TOMOYO:
- Y2038 timestamping fixes"
* 'next-general' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (28 commits)
MAINTAINERS: update the IMA, EVM, trusted-keys, encrypted-keys entries
Smack: Base support for overlayfs
MAINTAINERS: remove David Safford as maintainer for encrypted+trusted keys
tomoyo: fix timestamping for y2038
capabilities: audit log other surprising conditions
capabilities: fix logic for effective root or real root
capabilities: invert logic for clarity
capabilities: remove a layer of conditional logic
capabilities: move audit log decision to function
capabilities: use intuitive names for id changes
capabilities: use root_priveleged inline to clarify logic
capabilities: rename has_cap to has_fcap
capabilities: intuitive names for cap gain status
capabilities: factor out cap_bprm_set_creds privileged root
tpm, tpm_tis: use ARRAY_SIZE() to define TPM_HID_USR_IDX
tpm: fix duplicate inline declaration specifier
tpm: fix type of a local variables in tpm_tis_spi.c
tpm: fix type of a local variable in tpm2_map_command()
tpm: fix type of a local variable in tpm2_get_cc_attrs_tbl()
tpm-dev-common: Reject too short writes
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Tomoyo uses an open-coded version of time_to_tm() to create a timestamp
from the current time as read by get_seconds(). This will overflow and
give wrong results on 32-bit systems in 2038.
To correct this, this changes the code to use ktime_get_real_seconds()
and the generic time64_to_tm() function that are both y2038-safe.
Using the library function avoids adding an expensive 64-bit division
in this code and can benefit from any optimizations we do in common
code.
Acked-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Signed-off-by: James Morris <james.l.morris@oracle.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
The pathname of /usr/sbin/tomoyo-editpolicy seen from Ubuntu 12.04 Live CD is
squashfs:/usr/sbin/tomoyo-editpolicy rather than /usr/sbin/tomoyo-editpolicy .
Therefore, we need to accept manager programs which do not start with / .
"struct file_operations"->poll() expects "unsigned int" return value.
All files in /sys/kernel/security/tomoyo/ directory other than
/sys/kernel/security/tomoyo/query and /sys/kernel/security/tomoyo/audit should
return POLLIN | POLLRDNORM | POLLOUT | POLLWRNORM rather than -ENOSYS.
Also, /sys/kernel/security/tomoyo/query and /sys/kernel/security/tomoyo/audit
should return POLLOUT | POLLWRNORM rather than 0 when there is no data to read.
* 'for-linus' of git://selinuxproject.org/~jmorris/linux-security: (32 commits)
ima: fix invalid memory reference
ima: free duplicate measurement memory
security: update security_file_mmap() docs
selinux: Casting (void *) value returned by kmalloc is useless
apparmor: fix module parameter handling
Security: tomoyo: add .gitignore file
tomoyo: add missing rcu_dereference()
apparmor: add missing rcu_dereference()
evm: prevent racing during tfm allocation
evm: key must be set once during initialization
mpi/mpi-mpow: NULL dereference on allocation failure
digsig: build dependency fix
KEYS: Give key types their own lockdep class for key->sem
TPM: fix transmit_cmd error logic
TPM: NSC and TIS drivers X86 dependency fix
TPM: Export wait_for_stat for other vendor specific drivers
TPM: Use vendor specific function for status probe
tpm_tis: add delay after aborting command
tpm_tis: Check return code from getting timeouts/durations
tpm: Introduce function to poll for result of self test
Fix up trivial conflict in lib/Makefile due to addition of CONFIG_MPI
and SIGSIG next to CONFIG_DQL addition.
Adds a missed rcu_dereference() around real_parent.
Signed-off-by: James Morris <jmorris@namei.org>
tomoyo_policy_lock mutex already protects it.
When TOMOYO started using garbage collector at commit 847b173e "TOMOYO: Add
garbage collector.", we waited for close() before kfree(). Thus, elements to be
kfree()d were queued up using tomoyo_gc_list list.
But it turned out that tomoyo_element_linked_by_gc() tends to choke garbage
collector when certain pattern of entries are queued.
Since garbage collector is no longer waiting for close() since commit 2e503bbb
"TOMOYO: Fix lockdep warning.", we can remove tomoyo_gc_list list and
tomoyo_element_linked_by_gc() by doing sequential processing.
Commit efe836ab "TOMOYO: Add built-in policy support." introduced
tomoyo_load_builtin_policy() but was by error called from nowhere.
Commit b22b8b9f "TOMOYO: Rename meminfo to stat and show more statistics."
introduced tomoyo_update_stat() but was by error not called from
tomoyo_assign_domain().
Also, mark tomoyo_io_printf() and tomoyo_path_permission() static functions,
as reported by "make namespacecheck".
I got an opinion that it is difficult to use exception policy's domain
transition control directives because they need to match the pathname specified
to "file execute" directives. For example, if "file execute /bin/\*\-ls\-cat"
is given, corresponding domain transition control directive needs to be like
"no_keep_domain /bin/\*\-ls\-cat from any".
If we can specify like below, it will become more convenient.
file execute /bin/ls keep exec.realpath="/bin/ls" exec.argv[0]="ls"
file execute /bin/cat keep exec.realpath="/bin/cat" exec.argv[0]="cat"
file execute /bin/\*\-ls\-cat child
file execute /usr/sbin/httpd <apache> exec.realpath="/usr/sbin/httpd" exec.argv[0]="/usr/sbin/httpd"
In above examples, "keep" works as if keep_domain is specified, "child" works
as if "no_reset_domain" and "no_initialize_domain" and "no_keep_domain" are
specified, "<apache>" causes domain transition to <apache> domain upon
successful execve() operation.
Moreover, we can also allow transition to different domains based on conditions
like below example.
<kernel> /usr/sbin/sshd
file execute /bin/bash <kernel> /usr/sbin/sshd //batch-session exec.argc=2 exec.argv[1]="-c"
file execute /bin/bash <kernel> /usr/sbin/sshd //root-session task.uid=0
file execute /bin/bash <kernel> /usr/sbin/sshd //nonroot-session task.uid!=0
Tell userland tools that this is TOMOYO 2.5.
To be able to split permissions for Apache's CGI programs which are executed
without execve(), add special domain transition which is performed by writing
a TOMOYO's domainname to /sys/kernel/security/tomoyo/self_domain interface.
This is an API for TOMOYO-aware userland applications. However, since I expect
TOMOYO and other LSM modules to run in parallel, this patch does not use
/proc/self/attr/ interface in order to avoid conflicts with other LSM modules
when it became possible to run multiple LSM modules in parallel.
basis.
Add per-entry flag which controls generation of grant logs because Xen and KVM
issues ioctl requests so frequently. For example,
file ioctl /dev/null 0x5401 grant_log=no
will suppress /sys/kernel/security/tomoyo/audit even if preference says
grant_log=yes .
This patch adds support for permission checks for PF_INET/PF_INET6/PF_UNIX
socket's bind()/listen()/connect()/send() operations.
This patch adds support for checking environment variable's names.
Although TOMOYO already provides ability to check argv[]/envp[] passed to
execve() requests,
file execute /bin/sh exec.envp["LD_LIBRARY_PATH"]="bar"
will reject execution of /bin/sh if environment variable LD_LIBRARY_PATH is not
defined. To grant execution of /bin/sh if LD_LIBRARY_PATH is not defined,
administrators have to specify like
file execute /bin/sh exec.envp["LD_LIBRARY_PATH"]="/system/lib"
file execute /bin/sh exec.envp["LD_LIBRARY_PATH"]=NULL
. Since there are many environment variables whereas conditional checks are
applied as "&&", it is difficult to cover all combinations. Therefore, this
patch supports conditional checks that are applied as "||", by specifying like
misc env LD_LIBRARY_PATH exec.envp["LD_LIBRARY_PATH"]="/system/lib"
which means "grant execution of /bin/sh if environment variable is not defined
or is defined and its value is /system/lib".
Enable conditional ACL by passing object's pointers.
This patch adds support for permission checks using argv[]/envp[] of execve()
request. Hooks are in the last patch of this pathset.
This patch adds support for permission checks using executable file's realpath
upon execve() and symlink's target upon symlink(). Hooks are in the last patch
of this pathset.
This patch adds support for permission checks using file object's DAC
attributes (e.g. owner/group) when checking file's pathnames. Hooks for passing
file object's pointers are in the last patch of this pathset.
This patch adds support for permission checks using current thread's UID/GID
etc. in addition to pathnames.
/sys/kernel/security/tomoyo/.domain_status can be easily emulated using
/sys/kernel/security/tomoyo/domain_policy . We can remove this interface by
updating /usr/sbin/tomoyo-setprofile utility.
Sort by alphabetic order.
To be able to start using enforcing mode from the early stage of boot sequence,
this patch adds support for built-in policy configuration (and next patch adds
support for activating access control without calling external policy loader
program).
Show statistics such as last policy update time and last policy violation time
in addition to memory usage.
Gather string constants to one file in order to make the object size smaller.
Use unsigned type where appropriate.
read()/write() returns ssize_t.
Currently TOMOYO holds SRCU lock upon open() and releases it upon close()
because list elements stored in the "struct tomoyo_io_buffer" instances are
accessed until close() is called. However, such SRCU usage causes lockdep to
complain about leaving the kernel with SRCU lock held.
This patch solves the warning by holding/releasing SRCU upon each
read()/write(). This patch is doing something similar to calling kfree()
without calling synchronize_srcu(), by selectively deferring kfree() by keeping
track of the "struct tomoyo_io_buffer" instances.
Mauras Olivier reported that it is difficult to use TOMOYO in LXC environments,
for TOMOYO cannot distinguish between environments outside the container and
environments inside the container since LXC environments are created using
pivot_root(). To address this problem, this patch introduces policy namespace.
Each policy namespace has its own set of domain policy, exception policy and
profiles, which are all independent of other namespaces. This independency
allows users to develop policy without worrying interference among namespaces.
ACL group allows administrator to globally grant not only "file read"
permission but also other permissions.
Add /sys/kernel/security/tomoyo/audit interface. This interface generates audit
logs in the form of domain policy so that /usr/sbin/tomoyo-auditd can reuse
audit logs for appending to /sys/kernel/security/tomoyo/domain_policy
interface.
Remove global preference from profile structure in order to make code simpler.
Due to this structure change, printk() warnings upon policy violation are
temporarily disabled. They will be replaced by
/sys/kernel/security/tomoyo/audit by next patch.
Convert "allow_..." style directives to "file ..." style directives.
By converting to the latter style, we can pack policy like
"file read/write/execute /path/to/file".
Use structure for passing ACL line, in preparation for supporting policy
namespace and conditional parameters.
Use common structure for ACL with "struct list_head" + "atomic_t".
Use array/struct where possible.
Remove is_group from "struct tomoyo_name_union"/"struct tomoyo_number_union".
Pass "struct file"->private_data rather than "struct file".
Update some of comments.
Bring tomoyo_same_acl_head() from common.h to domain.c .
Bring tomoyo_invalid()/tomoyo_valid() from common.h to util.c .
Update (or temporarily remove) comments.
Remove or replace some of #define lines.
In order to synchronize with TOMOYO 1.8's syntax,
(1) Remove special handling for allow_read/write permission.
(2) Replace deny_rewrite/allow_rewrite permission with allow_append permission.
(3) Remove file_pattern keyword.
(4) Remove allow_read permission from exception policy.
(5) Allow creating domains in enforcing mode without calling supervisor.
(6) Add permission check for opening directory for reading.
(7) Add permission check for stat() operation.
(8) Make "cat < /sys/kernel/security/tomoyo/self_domain" behave as if
"cat /sys/kernel/security/tomoyo/self_domain".
System call entry functions sys_*() are never to be called from
general kernel code. The fact that they aren't declared in header
files should have been a clue. These functions also don't exist on
Alpha since it has sys_getxpid() instead.
Commit c9e69318 "TOMOYO: Allow wildcard for execute permission." changed execute
permission and domainname to accept wildcards. But tomoyo_find_next_domain()
was using pathname passed to execve() rather than pathname specified by the
execute permission. As a result, processes were not able to transit to domains
which contain wildcards in their domainnames.
This patch passes pathname specified by the execute permission back to
tomoyo_find_next_domain() so that processes can transit to domains which
Commit 1dae08c "TOMOYO: Add interactive enforcing mode." forgot to register
poll() hook. As a result, /usr/sbin/tomoyo-queryd was doing busy loop.
Use shorter name in order to make it easier to fit 80 columns limit.
When userspace program reads policy from /sys/kernel/security/tomoyo/
interface, TOMOYO uses line buffered mode. A line has at least one word.
Commit 006dacc "TOMOYO: Support longer pathname." changed a word's max length
from 4000 bytes to max kmalloc()able bytes. By that commit, a line's max length
changed from 8192 bytes to more than max kmalloc()able bytes.
Max number of words in a line remains finite. This patch changes the way of
buffering so that all words in a line are firstly directly copied to userspace
buffer as much as possible and are secondly queued for next read request.
Words queued are guaranteed to be valid until /sys/kernel/security/tomoyo/
interface is close()d.
Policy editor needs to know allow_execute entries in order to build domain
transition tree. Reading all entries is slow. Thus, allow reading only
allow_execute entries.
