Currently the packet class in SELinux is not checked if there are no
SECMARK rules in the security or mangle netfilter tables. Some systems
prefer that packets are always checked, for example, to protect the system
should the netfilter rules fail to load or if the nefilter rules
were maliciously flushed.
Add the always_check_network policy capability which, when enabled, treats
SECMARK as enabled, even if there are no netfilter SECMARK rules and
treats peer labeling as enabled, even if there is no Netlabel or
labeled IPSEC configuration.
Includes definition of "redhat1" SELinux policy capability, which
exists in the SELinux userpace library, to keep ordering correct.
The SELinux userpace portion of this was merged last year, but this kernel
change fell on the floor.
Signed-off-by: Chris PeBenito <cpebenito@tresys.com>
Signed-off-by: Eric Paris <eparis@redhat.com>
When the BUG() macro is disabled at compile time it can cause some
problems in the SELinux netnode code: invalid return codes and
uninitialized variables. This patch fixes this by making sure we take
some corrective action after the BUG() macro.
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Signed-off-by: Paul Moore <pmoore@redhat.com>
Use a helper to determine if a superblock should have the seclabel flag
rather than doing it in the function. I'm going to use this in the
security server as well.
Rather than passing pointers to memory locations, strings, and other
stuff just give up on the separation and give security_fs_use the
superblock. It just makes the code easier to read (even if not easier to
reuse on some other OS)
Instead of having special code around the 'non-mount' seclabel mount option
just handle it like the mount options.
We only have 6 options, so char is good enough, but use a short as that
packs nicely. This shrinks the superblock_security_struct just a little
bit.
Just to make it clear that we have mount time options and flags,
separate them. Since I decided to move the non-mount options above
above 0x10, we need a short instead of a char. (x86 padding says
this takes up no additional space as we have a 3byte whole in the
structure)
Currently we set the initialize and seclabel flag in one place. Do some
unrelated printk then we unset the seclabel flag. Eww. Instead do the flag
twiddling in one place in the code not seperated by unrelated printk. Also
don't set and unset the seclabel flag. Only set it if we need to.
Just a flag rename as we prepare to make it not so special.
We had this random hard coded value of '8' in the code (I put it there)
for the number of bits to check for mount options. This is stupid. Instead
use the #define we already have which tells us the number of mount
options.
Instead of just hard coding a value, use the enum to out benefit.
We check if the fsname is proc and if so set the proc superblock security
struct flag. We then check if the flag is set and use the string 'proc'
for the fsname instead of just using the fsname. What's the point? It's
always proc... Get rid of the useless conditional.
The /sys/fs/selinux/policy file is not valid on big endian systems like
ppc64 or s390. Let's see why:
static int hashtab_cnt(void *key, void *data, void *ptr)
int *cnt = ptr;
*cnt = *cnt + 1;
return 0;
static int range_write(struct policydb *p, void *fp)
size_t nel;
/* count the number of entries in the hashtab */
nel = 0;
rc = hashtab_map(p->range_tr, hashtab_cnt, &nel);
if (rc)
return rc;
buf[0] = cpu_to_le32(nel);
rc = put_entry(buf, sizeof(u32), 1, fp);
So size_t is 64 bits. But then we pass a pointer to it as we do to
hashtab_cnt. hashtab_cnt thinks it is a 32 bit int and only deals with
the first 4 bytes. On x86_64 which is little endian, those first 4
bytes and the least significant, so this works out fine. On ppc64/s390
those first 4 bytes of memory are the high order bits. So at the end of
the call to hashtab_map nel has a HUGE number. But the least
significant 32 bits are all 0's.
We then pass that 64 bit number to cpu_to_le32() which happily truncates
it to a 32 bit number and does endian swapping. But the low 32 bits are
all 0's. So no matter how many entries are in the hashtab, big endian
systems always say there are 0 entries because I screwed up the
counting.
The fix is easy. Use a 32 bit int, as the hashtab_cnt expects, for nel.
rootfs (ramfs) can support setting of security contexts
by userspace due to the vfs fallback behavior of calling
the security module to set the in-core inode state
for security.* attributes when the filesystem does not
provide an xattr handler. No xattr handler required
as the inodes are pinned in memory and have no backing
store.
This is useful in allowing early userspace to label individual
files within a rootfs while still providing a policy-defined
default via genfs.
Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
Currently, the ebitmap_node structure has a fixed size of 32 bytes. On
a 32-bit system, the overhead is 8 bytes, leaving 24 bytes for being
used as bitmaps. The overhead ratio is 1/4.
On a 64-bit system, the overhead is 16 bytes. Therefore, only 16 bytes
are left for bitmap purpose and the overhead ratio is 1/2. With a
3.8.2 kernel, a boot-up operation will cause the ebitmap_get_bit()
function to be called about 9 million times. The average number of
ebitmap_node traversal is about 3.7.
This patch increases the size of the ebitmap_node structure to 64
bytes for 64-bit system to keep the overhead ratio at 1/4. This may
also improve performance a little bit by making node to node traversal
less frequent (< 2) as more bits are available in each node.
Signed-off-by: Waiman Long <Waiman.Long@hp.com>
Acked-by: Stephen Smalley <sds@tycho.nsa.gov>
While running the high_systime workload of the AIM7 benchmark on
a 2-socket 12-core Westmere x86-64 machine running 3.10-rc4 kernel
(with HT on), it was found that a pretty sizable amount of time was
spent in the SELinux code. Below was the perf trace of the "perf
record -a -s" of a test run at 1500 users:
5.04% ls [kernel.kallsyms] [k] ebitmap_get_bit
1.96% ls [kernel.kallsyms] [k] mls_level_isvalid
1.95% ls [kernel.kallsyms] [k] find_next_bit
The ebitmap_get_bit() was the hottest function in the perf-report
output. Both the ebitmap_get_bit() and find_next_bit() functions
were, in fact, called by mls_level_isvalid(). As a result, the
mls_level_isvalid() call consumed 8.95% of the total CPU time of
all the 24 virtual CPUs which is quite a lot. The majority of the
mls_level_isvalid() function invocations come from the socket creation
system call.
Looking at the mls_level_isvalid() function, it is checking to see
if all the bits set in one of the ebitmap structure are also set in
another one as well as the highest set bit is no bigger than the one
specified by the given policydb data structure. It is doing it in
a bit-by-bit manner. So if the ebitmap structure has many bits set,
the iteration loop will be done many times.
The current code can be rewritten to use a similar algorithm as the
ebitmap_contains() function with an additional check for the
highest set bit. The ebitmap_contains() function was extended to
cover an optional additional check for the highest set bit, and the
mls_level_isvalid() function was modified to call ebitmap_contains().
With that change, the perf trace showed that the used CPU time drop
down to just 0.08% (ebitmap_contains + mls_level_isvalid) of the
total which is about 100X less than before.
0.07% ls [kernel.kallsyms] [k] ebitmap_contains
0.05% ls [kernel.kallsyms] [k] ebitmap_get_bit
0.01% ls [kernel.kallsyms] [k] mls_level_isvalid
0.01% ls [kernel.kallsyms] [k] find_next_bit
The remaining ebitmap_get_bit() and find_next_bit() functions calls
are made by other kernel routines as the new mls_level_isvalid()
function will not call them anymore.
This patch also improves the high_systime AIM7 benchmark result,
though the improvement is not as impressive as is suggested by the
reduction in CPU time spent in the ebitmap functions. The table below
shows the performance change on the 2-socket x86-64 system (with HT
on) mentioned above.
| Workload | mean % change | mean % change | mean % change |
| | 10-100 users | 200-1000 users | 1100-2000 users |
| high_systime | +0.1% | +0.9% | +2.6% |
Remove the BUG_ON() from selinux_skb_xfrm_sid() and propogate the
error code up to the caller. Also check the return values in the
only caller function, selinux_skb_peerlbl_sid().
Remove the unused get_sock_isec() function and do some formatting
fixes.
Some basic simplification.
Some basic simplification and comment reformatting.
selinux_xfrm_state_pol_flow_match()
Do some basic simplification and comment reformatting.
The SELinux labeled IPsec code state management functions have been
long neglected and could use some cleanup and consolidation.
The xfrm_state_alloc_security() LSM hook implementation is really a
multiplexed hook with two different behaviors depending on the
arguments passed to it by the caller. This patch splits the LSM hook
implementation into two new hook implementations, which match the
LSM hooks in the rest of the kernel:
* xfrm_state_alloc
* xfrm_state_alloc_acquire
Also included in this patch are the necessary changes to the SELinux
code; no other LSMs are affected.
Since everybody sets kstrdup()ed constant string to "struct xattr"->name but
nobody modifies "struct xattr"->name , we can omit kstrdup() and its failure
checking by constifying ->name member of "struct xattr".
Reviewed-by: Joel Becker <jlbec@evilplan.org> [ocfs2]
Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com>
Acked-by: Casey Schaufler <casey@schaufler-ca.com>
Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
Reviewed-by: Paul Moore <paul@paul-moore.com>
Tested-by: Paul Moore <paul@paul-moore.com>
Acked-by: Eric Paris <eparis@redhat.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
Pull networking updates from David Miller:
"This is a re-do of the net-next pull request for the current merge
window. The only difference from the one I made the other day is that
this has Eliezer's interface renames and the timeout handling changes
made based upon your feedback, as well as a few bug fixes that have
trickeled in.
Highlights:
1) Low latency device polling, eliminating the cost of interrupt
handling and context switches. Allows direct polling of a network
device from socket operations, such as recvmsg() and poll().
Currently ixgbe, mlx4, and bnx2x support this feature.
Full high level description, performance numbers, and design in
commit 0a4db187a999 ("Merge branch 'll_poll'")
From Eliezer Tamir.
2) With the routing cache removed, ip_check_mc_rcu() gets exercised
more than ever before in the case where we have lots of multicast
addresses. Use a hash table instead of a simple linked list, from
Eric Dumazet.
3) Add driver for Atheros CQA98xx 802.11ac wireless devices, from
Bartosz Markowski, Janusz Dziedzic, Kalle Valo, Marek Kwaczynski,
Marek Puzyniak, Michal Kazior, and Sujith Manoharan.
4) Support reporting the TUN device persist flag to userspace, from
Pavel Emelyanov.
5) Allow controlling network device VF link state using netlink, from
Rony Efraim.
6) Support GRE tunneling in openvswitch, from Pravin B Shelar.
7) Adjust SOCK_MIN_RCVBUF and SOCK_MIN_SNDBUF for modern times, from
Daniel Borkmann and Eric Dumazet.
8) Allow controlling of TCP quickack behavior on a per-route basis,
from Cong Wang.
9) Several bug fixes and improvements to vxlan from Stephen
Hemminger, Pravin B Shelar, and Mike Rapoport. In particular,
support receiving on multiple UDP ports.
10) Major cleanups, particular in the area of debugging and cookie
lifetime handline, to the SCTP protocol code. From Daniel
Borkmann.
11) Allow packets to cross network namespaces when traversing tunnel
devices. From Nicolas Dichtel.
12) Allow monitoring netlink traffic via AF_PACKET sockets, in a
manner akin to how we monitor real network traffic via ptype_all.
From Daniel Borkmann.
13) Several bug fixes and improvements for the new alx device driver,
from Johannes Berg.
14) Fix scalability issues in the netem packet scheduler's time queue,
by using an rbtree. From Eric Dumazet.
15) Several bug fixes in TCP loss recovery handling, from Yuchung
Cheng.
16) Add support for GSO segmentation of MPLS packets, from Simon
Horman.
17) Make network notifiers have a real data type for the opaque
pointer that's passed into them. Use this to properly handle
network device flag changes in arp_netdev_event(). From Jiri
Pirko and Timo Teräs.
18) Convert several drivers over to module_pci_driver(), from Peter
Huewe.
19) tcp_fixup_rcvbuf() can loop 500 times over loopback, just use a
O(1) calculation instead. From Eric Dumazet.
20) Support setting of explicit tunnel peer addresses in ipv6, just
like ipv4. From Nicolas Dichtel.
21) Protect x86 BPF JIT against spraying attacks, from Eric Dumazet.
22) Prevent a single high rate flow from overruning an individual cpu
during RX packet processing via selective flow shedding. From
Willem de Bruijn.
23) Don't use spinlocks in TCP md5 signing fast paths, from Eric
Dumazet.
24) Don't just drop GSO packets which are above the TBF scheduler's
burst limit, chop them up so they are in-bounds instead. Also
from Eric Dumazet.
25) VLAN offloads are missed when configured on top of a bridge, fix
from Vlad Yasevich.
26) Support IPV6 in ping sockets. From Lorenzo Colitti.
27) Receive flow steering targets should be updated at poll() time
too, from David Majnemer.
28) Fix several corner case regressions in PMTU/redirect handling due
to the routing cache removal, from Timo Teräs.
29) We have to be mindful of ipv4 mapped ipv6 sockets in
upd_v6_push_pending_frames(). From Hannes Frederic Sowa.
30) Fix L2TP sequence number handling bugs, from James Chapman."
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1214 commits)
drivers/net: caif: fix wrong rtnl_is_locked() usage
drivers/net: enic: release rtnl_lock on error-path
vhost-net: fix use-after-free in vhost_net_flush
net: mv643xx_eth: do not use port number as platform device id
net: sctp: confirm route during forward progress
virtio_net: fix race in RX VQ processing
virtio: support unlocked queue poll
net/cadence/macb: fix bug/typo in extracting gem_irq_read_clear bit
Documentation: Fix references to defunct linux-net@vger.kernel.org
net/fs: change busy poll time accounting
net: rename low latency sockets functions to busy poll
bridge: fix some kernel warning in multicast timer
sfc: Fix memory leak when discarding scattered packets
sit: fix tunnel update via netlink
dt:net:stmmac: Add dt specific phy reset callback support.
dt:net:stmmac: Add support to dwmac version 3.610 and 3.710
dt:net:stmmac: Allocate platform data only if its NULL.
net:stmmac: fix memleak in the open method
ipv6: rt6_check_neigh should successfully verify neigh if no NUD information are available
net: ipv6: fix wrong ping_v6_sendmsg return value
Pull NFS client updates from Trond Myklebust:
"Feature highlights include:
- Add basic client support for NFSv4.2
- Add basic client support for Labeled NFS (selinux for NFSv4.2)
- Fix the use of credentials in NFSv4.1 stateful operations, and add
support for NFSv4.1 state protection.
Bugfix highlights:
- Fix another NFSv4 open state recovery race
- Fix an NFSv4.1 back channel session regression
- Various rpc_pipefs races
- Fix another issue with NFSv3 auth negotiation
Please note that Labeled NFS does require some additional support from
the security subsystem. The relevant changesets have all been
reviewed and acked by James Morris."
* tag 'nfs-for-3.11-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (54 commits)
NFS: Set NFS_CS_MIGRATION for NFSv4 mounts
NFSv4.1 Refactor nfs4_init_session and nfs4_init_channel_attrs
nfs: have NFSv3 try server-specified auth flavors in turn
nfs: have nfs_mount fake up a auth_flavs list when the server didn't provide it
nfs: move server_authlist into nfs_try_mount_request
nfs: refactor "need_mount" code out of nfs_try_mount
SUNRPC: PipeFS MOUNT notification optimization for dying clients
SUNRPC: split client creation routine into setup and registration
SUNRPC: fix races on PipeFS UMOUNT notifications
SUNRPC: fix races on PipeFS MOUNT notifications
NFSv4.1 use pnfs_device maxcount for the objectlayout gdia_maxcount
NFSv4.1 use pnfs_device maxcount for the blocklayout gdia_maxcount
NFSv4.1 Fix gdia_maxcount calculation to fit in ca_maxresponsesize
NFS: Improve legacy idmapping fallback
NFSv4.1 end back channel session draining
NFS: Apply v4.1 capabilities to v4.2
NFSv4.1: Clean up layout segment comparison helper names
NFSv4.1: layout segment comparison helpers should take 'const' parameters
NFSv4: Move the DNS resolver into the NFSv4 module
rpc_pipefs: only set rpc_dentry_ops if d_op isn't already set
Create a file_path_has_perm() function that is like path_has_perm() but
instead takes a file struct that is the source of both the path and the
inode (rather than getting the inode from the dentry in the path). This
is then used where appropriate.
This will be useful for situations like unionmount where it will be
possible to have an apparently-negative dentry (eg. a fallthrough) that is
open with the file struct pointing to an inode on the lower fs.
This patch implements the client transport and handling support for labeled
NFS. The patch adds two functions to encode and decode the security label
recommended attribute which makes use of the LSM hooks added earlier. It also
adds code to grab the label from the file attribute structures and encode the
label to be sent back to the server.
Acked-by: James Morris <james.l.morris@oracle.com>
Signed-off-by: Matthew N. Dodd <Matthew.Dodd@sparta.com>
Signed-off-by: Miguel Rodel Felipe <Rodel_FM@dsi.a-star.edu.sg>
Signed-off-by: Phua Eu Gene <PHUA_Eu_Gene@dsi.a-star.edu.sg>
Signed-off-by: Khin Mi Mi Aung <Mi_Mi_AUNG@dsi.a-star.edu.sg>
Signed-off-by: Steve Dickson <steved@redhat.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
There currently doesn't exist a labeling type that is adequate for use with
labeled NFS. Since NFS doesn't really support xattrs we can't use the use xattr
labeling behavior. For this we developed a new labeling type. The native
labeling type is used solely by NFS to ensure NFS inodes are labeled at runtime
by the NFS code instead of relying on the SELinux security server on the client
end.
There is no way to differentiate if a text mount option is passed from user
space or the kernel. A flags field is being added to the
security_sb_set_mnt_opts hook to allow for in kernel security flags to be sent
to the LSM for processing in addition to the text options received from mount.
This patch also updated existing code to fix compilation errors.
Signed-off-by: David P. Quigley <dpquigl@tycho.nsa.gov>
The interface to request security labels from user space is the xattr
interface. When requesting the security label from an NFS server it is
important to make sure the requested xattr actually is a MAC label. This allows
us to make sure that we get the desired semantics from the attribute instead of
something else such as capabilities or a time based LSM.
There is a time where we need to calculate a context without the
inode having been created yet. To do this we take the negative dentry and
calculate a context based on the process and the parent directory contexts.
Merge 'net' bug fixes into 'net-next' as we have patches
that will build on top of them.
This merge commit includes a change from Emil Goode
(emilgoode@gmail.com) that fixes a warning that would
have been introduced by this merge. Specifically it
fixes the pingv6_ops method ipv6_chk_addr() to add a
"const" to the "struct net_device *dev" argument and
likewise update the dummy_ipv6_chk_addr() declaration.
The SELinux labeled IPsec code was improperly handling its reference
counting, dropping a reference on a delete operation instead of on a
free/release operation.
Reported-by: Ondrej Moris <omoris@redhat.com>
So far, only net_device * could be passed along with netdevice notifier
event. This patch provides a possibility to pass custom structure
able to provide info that event listener needs to know.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
v2->v3: fix typo on simeth
shortened dev_getter
shortened notifier_info struct name
v1->v2: fix notifier_call parameter in call_netdevice_notifier()
"Highlights (1721 non-merge commits, this has to be a record of some
sort):
1) Add 'random' mode to team driver, from Jiri Pirko and Eric
Dumazet.
2) Make it so that any driver that supports configuration of multiple
MAC addresses can provide the forwarding database add and del
calls by providing a default implementation and hooking that up if
the driver doesn't have an explicit set of handlers. From Vlad
Yasevich.
3) Support GSO segmentation over tunnels and other encapsulating
devices such as VXLAN, from Pravin B Shelar.
4) Support L2 GRE tunnels in the flow dissector, from Michael Dalton.
5) Implement Tail Loss Probe (TLP) detection in TCP, from Nandita
Dukkipati.
6) In the PHY layer, allow supporting wake-on-lan in situations where
the PHY registers have to be written for it to be configured.
Use it to support wake-on-lan in mv643xx_eth.
From Michael Stapelberg.
7) Significantly improve firewire IPV6 support, from YOSHIFUJI
Hideaki.
8) Allow multiple packets to be sent in a single transmission using
network coding in batman-adv, from Martin Hundebøll.
9) Add support for T5 cxgb4 chips, from Santosh Rastapur.
10) Generalize the VXLAN forwarding tables so that there is more
flexibility in configurating various aspects of the endpoints.
From David Stevens.
11) Support RSS and TSO in hardware over GRE tunnels in bxn2x driver,
from Dmitry Kravkov.
12) Zero copy support in nfnelink_queue, from Eric Dumazet and Pablo
Neira Ayuso.
13) Start adding networking selftests.
14) In situations of overload on the same AF_PACKET fanout socket, or
per-cpu packet receive queue, minimize drop by distributing the
load to other cpus/fanouts. From Willem de Bruijn and Eric
Dumazet.
15) Add support for new payload offset BPF instruction, from Daniel
Borkmann.
16) Convert several drivers over to mdoule_platform_driver(), from
Sachin Kamat.
17) Provide a minimal BPF JIT image disassembler userspace tool, from
Daniel Borkmann.
18) Rewrite F-RTO implementation in TCP to match the final
specification of it in RFC4138 and RFC5682. From Yuchung Cheng.
19) Provide netlink socket diag of netlink sockets ("Yo dawg, I hear
you like netlink, so I implemented netlink dumping of netlink
sockets.") From Andrey Vagin.
20) Remove ugly passing of rtnetlink attributes into rtnl_doit
functions, from Thomas Graf.
21) Allow userspace to be able to see if a configuration change occurs
in the middle of an address or device list dump, from Nicolas
Dichtel.
22) Support RFC3168 ECN protection for ipv6 fragments, from Hannes
Frederic Sowa.
23) Increase accuracy of packet length used by packet scheduler, from
Jason Wang.
24) Beginning set of changes to make ipv4/ipv6 fragment handling more
scalable and less susceptible to overload and locking contention,
from Jesper Dangaard Brouer.
25) Get rid of using non-type-safe NLMSG_* macros and use nlmsg_*()
instead. From Hong Zhiguo.
26) Optimize route usage in IPVS by avoiding reference counting where
possible, from Julian Anastasov.
27) Convert IPVS schedulers to RCU, also from Julian Anastasov.
28) Support cpu fanouts in xt_NFQUEUE netfilter target, from Holger
Eitzenberger.
29) Network namespace support for nf_log, ebt_log, xt_LOG, ipt_ULOG,
nfnetlink_log, and nfnetlink_queue. From Gao feng.
30) Implement RFC3168 ECN protection, from Hannes Frederic Sowa.
31) Support several new r8169 chips, from Hayes Wang.
32) Support tokenized interface identifiers in ipv6, from Daniel
Borkmann.
33) Use usbnet_link_change() helper in USB net driver, from Ming Lei.
34) Add 802.1ad vlan offload support, from Patrick McHardy.
35) Support mmap() based netlink communication, also from Patrick
McHardy.
36) Support HW timestamping in mlx4 driver, from Amir Vadai.
37) Rationalize AF_PACKET packet timestamping when transmitting, from
Willem de Bruijn and Daniel Borkmann.
38) Bring parity to what's provided by /proc/net/packet socket dumping
and the info provided by netlink socket dumping of AF_PACKET
sockets. From Nicolas Dichtel.
39) Fix peeking beyond zero sized SKBs in AF_UNIX, from Benjamin
Poirier"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits)
filter: fix va_list build error
af_unix: fix a fatal race with bit fields
bnx2x: Prevent memory leak when cnic is absent
bnx2x: correct reading of speed capabilities
net: sctp: attribute printl with __printf for gcc fmt checks
netlink: kconfig: move mmap i/o into netlink kconfig
netpoll: convert mutex into a semaphore
netlink: Fix skb ref counting.
net_sched: act_ipt forward compat with xtables
mlx4_en: fix a build error on 32bit arches
Revert "bnx2x: allow nvram test to run when device is down"
bridge: avoid OOPS if root port not found
drivers: net: cpsw: fix kernel warn on cpsw irq enable
sh_eth: use random MAC address if no valid one supplied
3c509.c: call SET_NETDEV_DEV for all device types (ISA/ISAPnP/EISA)
tg3: fix to append hardware time stamping flags
unix/stream: fix peeking with an offset larger than data in queue
unix/dgram: fix peeking with an offset larger than data in queue
unix/dgram: peek beyond 0-sized skbs
openvswitch: Remove unneeded ovs_netdev_get_ifindex()
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem update from James Morris:
"Just some minor updates across the subsystem"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security:
ima: eliminate passing d_name.name to process_measurement()
TPM: Retry SaveState command in suspend path
tpm/tpm_i2c_infineon: Add small comment about return value of __i2c_transfer
tpm/tpm_i2c_infineon.c: Add OF attributes type and name to the of_device_id table entries
tpm_i2c_stm_st33: Remove duplicate inclusion of header files
tpm: Add support for new Infineon I2C TPM (SLB 9645 TT 1.2 I2C)
char/tpm: Convert struct i2c_msg initialization to C99 format
drivers/char/tpm/tpm_ppi: use strlcpy instead of strncpy
tpm/tpm_i2c_stm_st33: formatting and white space changes
Smack: include magic.h in smackfs.c
selinux: make security_sb_clone_mnt_opts return an error on context mismatch
seccomp: allow BPF_XOR based ALU instructions.
Fix NULL pointer dereference in smack_inode_unlink() and smack_inode_rmdir()
Smack: add support for modification of existing rules
smack: SMACK_MAGIC to include/uapi/linux/magic.h
Smack: add missing support for transmute bit in smack_str_from_perm()
Smack: prevent revoke-subject from failing when unseen label is written to it
tomoyo: use DEFINE_SRCU() to define tomoyo_ss
drivers/net/ethernet/emulex/benet/be_main.c
drivers/net/ethernet/intel/igb/igb_main.c
drivers/net/wireless/brcm80211/brcmsmac/mac80211_if.c
include/net/scm.h
net/batman-adv/routing.c
net/ipv4/tcp_input.c
The e{uid,gid} --> {uid,gid} credentials fix conflicted with the
cleanup in net-next to now pass cred structs around.
The be2net driver had a bug fix in 'net' that overlapped with the VLAN
interface changes by Patrick McHardy in net-next.
An IGB conflict existed because in 'net' the build_skb() support was
reverted, and in 'net-next' there was a comment style fix within that
code.
Several batman-adv conflicts were resolved by making sure that all
calls to batadv_is_my_mac() are changed to have a new bat_priv first
argument.
Eric Dumazet's TS ECR fix in TCP in 'net' conflicted with the F-RTO
rewrite in 'net-next', mostly overlapping changes.
Thanks to Stephen Rothwell and Antonio Quartulli for help with several
of these merge resolutions.
Commit 90ba9b1986b5ac (tcp: tcp_make_synack() can use alloc_skb())
broke certain SELinux/NetLabel configurations by no longer correctly
assigning the sock to the outgoing SYNACK packet.
Cost of atomic operations on the LISTEN socket is quite big,
and we would like it to happen only if really needed.
This patch introduces a new security_ops->skb_owned_by() method,
that is a void operation unless selinux is active.
Reported-by: Miroslav Vadkerti <mvadkert@redhat.com>
Diagnosed-by: Paul Moore <pmoore@redhat.com>
Cc: linux-security-module@vger.kernel.org
Tested-by: Paul Moore <pmoore@redhat.com>
Acked-by: Paul Moore <pmoore@redhat.com>
I had the following problem reported a while back. If you mount the
same filesystem twice using NFSv4 with different contexts, then the
second context= option is ignored. For instance:
# mount server:/export /mnt/test1
# mount server:/export /mnt/test2 -o context=system_u:object_r:tmp_t:s0
# ls -dZ /mnt/test1
drwxrwxrwt. root root system_u:object_r:nfs_t:s0 /mnt/test1
# ls -dZ /mnt/test2
drwxrwxrwt. root root system_u:object_r:nfs_t:s0 /mnt/test2
When we call into SELinux to set the context of a "cloned" superblock,
it will currently just bail out when it notices that we're reusing an
existing superblock. Since the existing superblock is already set up and
presumably in use, we can't go overwriting its context with the one from
the "original" sb. Because of this, the second context= option in this
case cannot take effect.
This patch fixes this by turning security_sb_clone_mnt_opts into an int
return operation. When it finds that the "new" superblock that it has
been handed is already set up, it checks to see whether the contexts on
the old superblock match it. If it does, then it will just return
success, otherwise it'll return -EBUSY and emit a printk to tell the
admin why the second mount failed.
Note that this patch may cause casualties. The NFSv4 code relies on
being able to walk down to an export from the pseudoroot. If you mount
filesystems that are nested within one another with different contexts,
then this patch will make those mounts fail in new and "exciting" ways.
For instance, suppose that /export is a separate filesystem on the
server:
# mount server:/ /mnt/test1
# mount salusa:/export /mnt/test2 -o context=system_u:object_r:tmp_t:s0
mount.nfs: an incorrect mount option was specified
...with the printk in the ring buffer. Because we *might* eventually
walk down to /mnt/test1/export, the mount is denied due to this patch.
The second mount needs the pseudoroot superblock, but that's already
present with the wrong context.
OTOH, if we mount these in the reverse order, then both mounts work,
because the pseudoroot superblock created when mounting /export is
discarded once that mount is done. If we then however try to walk into
that directory, the automount fails for the similar reasons:
# cd /mnt/test1/scratch/
-bash: cd: /mnt/test1/scratch: Device or resource busy
The story I've gotten from the SELinux folks that I've talked to is that
this is desirable behavior. In SELinux-land, mounting the same data
under different contexts is wrong -- there can be only one.
Cc: Steve Dickson <steved@redhat.com>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Hong Zhiguo <honkiko@gmail.com>
Acked-by: Thomas Graf <tgraf@suug.ch>
The call tree here is:
sk_clone_lock() <- takes bh_lock_sock(newsk);
xfrm_sk_clone_policy()
__xfrm_sk_clone_policy()
clone_policy() <- uses GFP_ATOMIC for allocations
security_xfrm_policy_clone()
security_ops->xfrm_policy_clone_security()
selinux_xfrm_policy_clone()
Cc: stable@kernel.org
Pull more VFS bits from Al Viro:
"Unfortunately, it looks like xattr series will have to wait until the
next cycle ;-/
This pile contains 9p cleanups and fixes (races in v9fs_fid_add()
etc), fixup for nommu breakage in shmem.c, several cleanups and a bit
more file_inode() work"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
constify path_get/path_put and fs_struct.c stuff
fix nommu breakage in shmem.c
cache the value of file_inode() in struct file
9p: if v9fs_fid_lookup() gets to asking server, it'd better have hashed dentry
9p: make sure ->lookup() adds fid to the right dentry
9p: untangle ->lookup() a bit
9p: double iput() in ->lookup() if d_materialise_unique() fails
9p: v9fs_fid_add() can't fail now
v9fs: get rid of v9fs_dentry
9p: turn fid->dlist into hlist
9p: don't bother with private lock in ->d_fsdata; dentry->d_lock will do just fine
more file_inode() open-coded instances
selinux: opened file can't have NULL or negative ->f_path.dentry
(In the meantime, the hlist traversal macros have changed, so this
required a semantic conflict fixup for the newly hlistified fid->dlist)
I'm not sure why, but the hlist for each entry iterators were conceived
list_for_each_entry(pos, head, member)
The hlist ones were greedy and wanted an extra parameter:
hlist_for_each_entry(tpos, pos, head, member)
Why did they need an extra pos parameter? I'm not quite sure. Not only
they don't really need it, it also prevents the iterator from looking
exactly like the list iterator, which is unfortunate.
Besides the semantic patch, there was some manual work required:
- Fix up the actual hlist iterators in linux/list.h
- Fix up the declaration of other iterators based on the hlist ones.
- A very small amount of places were using the 'node' parameter, this
was modified to use 'obj->member' instead.
- Coccinelle didn't handle the hlist_for_each_entry_safe iterator
properly, so those had to be fixed up manually.
The semantic patch which is mostly the work of Peter Senna Tschudin is here:
iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host;
type T;
expression a,c,d,e;
identifier b;
statement S;
-T b;
<+... when != b
hlist_for_each_entry(a,
- b,
c, d) S
hlist_for_each_entry_continue(a,
- b,
c) S
hlist_for_each_entry_from(a,
- b,
c) S
hlist_for_each_entry_rcu(a,
- b,
c, d) S
hlist_for_each_entry_rcu_bh(a,
- b,
c, d) S
hlist_for_each_entry_continue_rcu_bh(a,
- b,
c) S
for_each_busy_worker(a, c,
- b,
d) S
ax25_uid_for_each(a,
- b,
c) S
ax25_for_each(a,
- b,
c) S
inet_bind_bucket_for_each(a,
- b,
c) S
sctp_for_each_hentry(a,
- b,
c) S
sk_for_each(a,
- b,
c) S
sk_for_each_rcu(a,
- b,
c) S
sk_for_each_from
-(a, b)
+(a)
S
+ sk_for_each_from(a) S
sk_for_each_safe(a,
- b,
c, d) S
sk_for_each_bound(a,
- b,
c) S
hlist_for_each_entry_safe(a,
- b,
c, d, e) S
hlist_for_each_entry_continue_rcu(a,
- b,
c) S
nr_neigh_for_each(a,
- b,
c) S
nr_neigh_for_each_safe(a,
- b,
c, d) S
nr_node_for_each(a,
- b,
c) S
nr_node_for_each_safe(a,
- b,
c, d) S
- for_each_gfn_sp(a, c, d, b) S
+ for_each_gfn_sp(a, c, d) S
- for_each_gfn_indirect_valid_sp(a, c, d, b) S
+ for_each_gfn_indirect_valid_sp(a, c, d) S
for_each_host(a,
- b,
c) S
for_each_host_safe(a,
- b,
c, d) S
for_each_mesh_entry(a,
- b,
c, d) S
[akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c]
[akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c]
[akpm@linux-foundation.org: checkpatch fixes]
[akpm@linux-foundation.org: fix warnings]
[akpm@linux-foudnation.org: redo intrusive kvm changes]
Tested-by: Peter Senna Tschudin <peter.senna@gmail.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Gleb Natapov <gleb@redhat.com>
Pull vfs pile (part one) from Al Viro:
"Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent
locking violations, etc.
The most visible changes here are death of FS_REVAL_DOT (replaced with
"has ->d_weak_revalidate()") and a new helper getting from struct file
to inode. Some bits of preparation to xattr method interface changes.
Misc patches by various people sent this cycle *and* ocfs2 fixes from
several cycles ago that should've been upstream right then.
PS: the next vfs pile will be xattr stuff."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits)
saner proc_get_inode() calling conventions
proc: avoid extra pde_put() in proc_fill_super()
fs: change return values from -EACCES to -EPERM
fs/exec.c: make bprm_mm_init() static
ocfs2/dlm: use GFP_ATOMIC inside a spin_lock
ocfs2: fix possible use-after-free with AIO
ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path
get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero
target: writev() on single-element vector is pointless
export kernel_write(), convert open-coded instances
fs: encode_fh: return FILEID_INVALID if invalid fid_type
kill f_vfsmnt
vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op
nfsd: handle vfs_getattr errors in acl protocol
switch vfs_getattr() to struct path
default SET_PERSONALITY() in linux/elf.h
ceph: prepopulate inodes only when request is aborted
d_hash_and_lookup(): export, switch open-coded instances
9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate()
9p: split dropping the acls from v9fs_set_create_acl()
This patch corrects some problems with LSM/SELinux that were introduced
with the multiqueue patchset. The problem stems from the fact that the
multiqueue work changed the relationship between the tun device and its
associated socket; before the socket persisted for the life of the
device, however after the multiqueue changes the socket only persisted
for the life of the userspace connection (fd open). For non-persistent
devices this is not an issue, but for persistent devices this can cause
the tun device to lose its SELinux label.
We correct this problem by adding an opaque LSM security blob to the
tun device struct which allows us to have the LSM security state, e.g.
SELinux labeling information, persist for the lifetime of the tun
device. In the process we tweak the LSM hooks to work with this new
approach to TUN device/socket labeling and introduce a new LSM hook,
security_tun_dev_attach_queue(), to approve requests to attach to a
TUN queue via TUNSETQUEUE.
The SELinux code has been adjusted to match the new LSM hooks, the
other LSMs do not make use of the LSM TUN controls. This patch makes
use of the recently added "tun_socket:attach_queue" permission to
restrict access to the TUNSETQUEUE operation. On older SELinux
policies which do not define the "tun_socket:attach_queue" permission
the access control decision for TUNSETQUEUE will be handled according
to the SELinux policy's unknown permission setting.
Acked-by: Eric Paris <eparis@parisplace.org>
Tested-by: Jason Wang <jasowang@redhat.com>
Add a new permission to align with the new TUN multiqueue support,
"tun_socket:attach_queue".
The corresponding SELinux reference policy patch is show below:
diff --git a/policy/flask/access_vectors b/policy/flask/access_vectors
index 28802c5..a0664a1 100644
--- a/policy/flask/access_vectors
+++ b/policy/flask/access_vectors
@@ -827,6 +827,9 @@ class kernel_service
class tun_socket
inherits socket
+ attach_queue
class x_pointer
inherits x_device
