path: root/security/keys
2011-05-24Merge branch 'next' into for-linusJames Morris
2011-05-07security,rcu: convert call_rcu(user_update_rcu_disposal) to kfree_rcu()Lai Jiangshan
The rcu callback user_update_rcu_disposal() just calls a kfree(), so we use kfree_rcu() instead of the call_rcu(user_update_rcu_disposal). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-03-17KEYS: Make request_key() and co. return an error for a negative keyDavid Howells
Make request_key() and co. return an error for a negative or rejected key. If the key was simply negated, then return ENOKEY, otherwise return the error with which it was rejected. Without this patch, the following command returns a key number (with the latest keyutils): [root@andromeda ~]# keyctl request2 user debug:foo rejected @s 586569904 Trying to print the key merely gets you a permission denied error: [root@andromeda ~]# keyctl print 586569904 keyctl_read_alloc: Permission denied Doing another request_key() call does get you the error, as long as it hasn't expired yet: [root@andromeda ~]# keyctl request user debug:foo request_key: Key was rejected by service Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-03-17KEYS: Improve /proc/keysDavid Howells
Improve /proc/keys by: (1) Don't attempt to summarise the payload of a negated key. It won't have one. To this end, a helper function - key_is_instantiated() has been added that allows the caller to find out whether the key is positively instantiated (as opposed to being uninstantiated or negatively instantiated). (2) Do show keys that are negative, expired or revoked rather than hiding them. This requires an override flag (no_state_check) to be passed to search_my_process_keyrings() and keyring_search_aux() to suppress this check. Without this, keys that are possessed by the caller, but only grant permissions to the caller if possessed are skipped as the possession check fails. Keys that are visible due to user, group or other checks are visible with or without this patch. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-03-08KEYS: Add an iovec version of KEYCTL_INSTANTIATEDavid Howells
Add a keyctl op (KEYCTL_INSTANTIATE_IOV) that is like KEYCTL_INSTANTIATE, but takes an iovec array and concatenates the data in-kernel into one buffer. Since the KEYCTL_INSTANTIATE copies the data anyway, this isn't too much of a problem. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-03-08KEYS: Add a new keyctl op to reject a key with a specified error codeDavid Howells
Add a new keyctl op to reject a key with a specified error code. This works much the same as negating a key, and so keyctl_negate_key() is made a special case of keyctl_reject_key(). The difference is that keyctl_negate_key() selects ENOKEY as the error to be reported. Typically the key would be rejected with EKEYEXPIRED, EKEYREVOKED or EKEYREJECTED, but this is not mandatory. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-03-08KEYS: Add a key type op to permit the key description to be vettedDavid Howells
Add a key type operation to permit the key type to vet the description of a new key that key_alloc() is about to allocate. The operation may reject the description if it wishes with an error of its choosing. If it does this, the key will not be allocated. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-03-08KEYS: Add an RCU payload dereference macroDavid Howells
Add an RCU payload dereference macro as this seems to be a common piece of code amongst key types that use RCU referenced payloads. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-01-26KEYS: Fix __key_link_end() quota fixup on errorDavid Howells
Fix __key_link_end()'s attempt to fix up the quota if an error occurs. There are two erroneous cases: Firstly, we always decrease the quota if the preallocated replacement keyring needs cleaning up, irrespective of whether or not we should (we may have replaced a pointer rather than adding another pointer). Secondly, we never clean up the quota if we added a pointer without the keyring storage being extended (we allocate multiple pointers at a time, even if we're not going to use them all immediately). We handle this by setting the bottom bit of the preallocation pointer in __key_link_begin() to indicate that the quota needs fixing up, which is then passed to __key_link() (which clears the whole thing) and __key_link_end(). Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-24trusted keys: Fix a memory leak in trusted_update().Jesper Juhl
One failure path in security/keys/trusted.c::trusted_update() does not free 'new_p' while the others do. This patch makes sure we also free it in the remaining path (if datablob_parse() returns different from Opt_update). Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: James Morris <jmorris@namei.org>
2011-01-24encrypted-keys: rename encrypted_defined files to encryptedMimi Zohar
Rename encrypted_defined.c and encrypted_defined.h files to encrypted.c and encrypted.h, respectively. Based on request from David Howells. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-01-24trusted-keys: rename trusted_defined files to trustedMimi Zohar
Rename trusted_defined.c and trusted_defined.h files to trusted.c and trusted.h, respectively. Based on request from David Howells. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-01-21KEYS: Fix up comments in key management codeDavid Howells
Fix up comments in the key management code. No functional changes. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-21KEYS: Do some style cleanup in the key management code.David Howells
Do a bit of a style clean up in the key management code. No functional changes. Done using: perl -p -i -e 's!^/[*]*/\n!!' security/keys/*.c perl -p -i -e 's!} /[*] end [a-z0-9_]*[(][)] [*]/\n!}\n!' security/keys/*.c sed -i -s -e ": next" -e N -e 's/^\n[}]$/}/' -e t -e P -e 's/^.*\n//' -e "b next" security/keys/*.c To remove /*****/ lines, remove comments on the closing brace of a function to name the function and remove blank lines before the closing brace of a function. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-19trusted-keys: avoid scattring va_end()Tetsuo Handa
We can avoid scattering va_end() within the va_start(); for (;;) { } va_end(); loop, assuming that crypto_shash_init()/crypto_shash_update() return 0 on success and negative value otherwise. Make TSS_authhmac()/TSS_checkhmac1()/TSS_checkhmac2() similar to TSS_rawhmac() by removing "va_end()/goto" from the loop. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Reviewed-by: Jesper Juhl <jj@chaosbits.net> Acked-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-01-19trusted-keys: check for NULL before using itTetsuo Handa
TSS_rawhmac() checks for data != NULL before using it. We should do the same thing for TSS_authhmac(). Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Reviewed-by: Jesper Juhl <jj@chaosbits.net> Acked-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-01-19trusted-keys: another free memory bugfixTetsuo Handa
TSS_rawhmac() forgot to call va_end()/kfree() when data == NULL and forgot to call va_end() when crypto_shash_update() < 0. Fix these bugs by escaping from the loop using "break" (rather than "return"/"goto") in order to make sure that va_end()/kfree() are always called. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Reviewed-by: Jesper Juhl <jj@chaosbits.net> Acked-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-01-14trusted-keys: free memory bugfixMimi Zohar
Add missing kfree(td) in tpm_seal() before the return, freeing td on error paths as well. Reported-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: David Safford <safford@watson.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Serge Hallyn <serge@hallyn.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-01-10Merge branch 'master' into nextJames Morris
Conflicts: security/smack/smack_lsm.c Verified and added fix by Stephen Rothwell <sfr@canb.auug.org.au> Ok'd by Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-12-23KEYS: Don't call up_write() if __key_link_begin() returns an errorDavid Howells
In construct_alloc_key(), up_write() is called in the error path if __key_link_begin() fails, but this is incorrect as __key_link_begin() only returns with the nominated keyring locked if it returns successfully. Without this patch, you might see the following in dmesg: ===================================== [ BUG: bad unlock balance detected! ] ------------------------------------- mount.cifs/5769 is trying to release lock (&key->sem) at: [<ffffffff81201159>] request_key_and_link+0x263/0x3fc but there are no more locks to release! other info that might help us debug this: 3 locks held by mount.cifs/5769: #0: (&type->s_umount_key#41/1){+.+.+.}, at: [<ffffffff81131321>] sget+0x278/0x3e7 #1: (&ret_buf->session_mutex){+.+.+.}, at: [<ffffffffa0258e59>] cifs_get_smb_ses+0x35a/0x443 [cifs] #2: (root_key_user.cons_lock){+.+.+.}, at: [<ffffffff81201000>] request_key_and_link+0x10a/0x3fc stack backtrace: Pid: 5769, comm: mount.cifs Not tainted 2.6.37-rc6+ #1 Call Trace: [<ffffffff81201159>] ? request_key_and_link+0x263/0x3fc [<ffffffff81081601>] print_unlock_inbalance_bug+0xca/0xd5 [<ffffffff81083248>] lock_release_non_nested+0xc1/0x263 [<ffffffff81201159>] ? request_key_and_link+0x263/0x3fc [<ffffffff81201159>] ? request_key_and_link+0x263/0x3fc [<ffffffff81083567>] lock_release+0x17d/0x1a4 [<ffffffff81073f45>] up_write+0x23/0x3b [<ffffffff81201159>] request_key_and_link+0x263/0x3fc [<ffffffffa026fe9e>] ? cifs_get_spnego_key+0x61/0x21f [cifs] [<ffffffff812013c5>] request_key+0x41/0x74 [<ffffffffa027003d>] cifs_get_spnego_key+0x200/0x21f [cifs] [<ffffffffa026e296>] CIFS_SessSetup+0x55d/0x1273 [cifs] [<ffffffffa02589e1>] cifs_setup_session+0x90/0x1ae [cifs] [<ffffffffa0258e7e>] cifs_get_smb_ses+0x37f/0x443 [cifs] [<ffffffffa025a9e3>] cifs_mount+0x1aa1/0x23f3 [cifs] [<ffffffff8111fd94>] ? alloc_debug_processing+0xdb/0x120 [<ffffffffa027002c>] ? cifs_get_spnego_key+0x1ef/0x21f [cifs] [<ffffffffa024cc71>] cifs_do_mount+0x165/0x2b3 [cifs] [<ffffffff81130e72>] vfs_kern_mount+0xaf/0x1dc [<ffffffff81131007>] do_kern_mount+0x4d/0xef [<ffffffff811483b9>] do_mount+0x6f4/0x733 [<ffffffff8114861f>] sys_mount+0x88/0xc2 [<ffffffff8100ac42>] system_call_fastpath+0x16/0x1b Reported-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-and-Tested-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-15encrypted-keys: style and other cleanupMimi Zohar
Cleanup based on David Howells suggestions: - use static const char arrays instead of #define - rename init_sdesc to alloc_sdesc - convert 'unsigned int' definitions to 'size_t' - revert remaining 'const unsigned int' definitions to 'unsigned int' Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-12-15encrypted-keys: verify datablob size before converting to binaryMimi Zohar
Verify the hex ascii datablob length is correct before converting the IV, encrypted data, and HMAC to binary. Reported-by: David Howells <dhowells@redhat.com> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-12-15trusted-keys: kzalloc and other cleanupMimi Zohar
Cleanup based on David Howells suggestions: - replace kzalloc, where possible, with kmalloc - revert 'const unsigned int' definitions to 'unsigned int' Signed-off-by: David Safford <safford@watson.ibm.com> Acked-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-12-15trusted-keys: additional TSS return code and other error handlingMimi Zohar
Previously not all TSS return codes were tested, as they were all eventually caught by the TPM. Now all returns are tested and handled immediately. This patch also fixes memory leaks in error and non-error paths. Signed-off-by: David Safford <safford@watson.ibm.com> Acked-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Serge E. Hallyn <serge@hallyn.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-11-30keys: add missing include file for trusted and encrypted keysMimi Zohar
This patch fixes the linux-next powerpc build errors as reported by Stephen Rothwell. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Tested-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-11-29keys: add new key-type encryptedMimi Zohar
Define a new kernel key-type called 'encrypted'. Encrypted keys are kernel generated random numbers, which are encrypted/decrypted with a 'trusted' symmetric key. Encrypted keys are created/encrypted/decrypted in the kernel. Userspace only ever sees/stores encrypted blobs. Changelog: - bug fix: replaced master-key rcu based locking with semaphore (reported by David Howells) - Removed memset of crypto_shash_digest() digest output - Replaced verification of 'key-type:key-desc' using strcspn(), with one based on string constants. - Moved documentation to Documentation/keys-trusted-encrypted.txt - Replace hash with shash (based on comments by David Howells) - Make lengths/counts size_t where possible (based on comments by David Howells) Could not convert most lengths, as crypto expects 'unsigned int' (size_t: on 32 bit is defined as unsigned int, but on 64 bit is unsigned long) - Add 'const' where possible (based on comments by David Howells) - allocate derived_buf dynamically to support arbitrary length master key (fixed by Roberto Sassu) - wait until late_initcall for crypto libraries to be registered - cleanup security/Kconfig - Add missing 'update' keyword (reported/fixed by Roberto Sassu) - Free epayload on failure to create key (reported/fixed by Roberto Sassu) - Increase the data size limit (requested by Roberto Sassu) - Crypto return codes are always 0 on success and negative on failure, remove unnecessary tests. - Replaced kzalloc() with kmalloc() Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: David Safford <safford@watson.ibm.com> Reviewed-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: James Morris <jmorris@namei.org>
2010-11-29keys: add new trusted key-typeMimi Zohar
Define a new kernel key-type called 'trusted'. Trusted keys are random number symmetric keys, generated and RSA-sealed by the TPM. The TPM only unseals the keys, if the boot PCRs and other criteria match. Userspace can only ever see encrypted blobs. Based on suggestions by Jason Gunthorpe, several new options have been added to support additional usages. The new options are: migratable= designates that the key may/may not ever be updated (resealed under a new key, new pcrinfo or new auth.) pcrlock=n extends the designated PCR 'n' with a random value, so that a key sealed to that PCR may not be unsealed again until after a reboot. keyhandle= specifies the sealing/unsealing key handle. keyauth= specifies the sealing/unsealing key auth. blobauth= specifies the sealed data auth. Implementation of a kernel reserved locality for trusted keys will be investigated for a possible future extension. Changelog: - Updated and added examples to Documentation/keys-trusted-encrypted.txt - Moved generic TPM constants to include/linux/tpm_command.h (David Howell's suggestion.) - trusted_defined.c: replaced kzalloc with kmalloc, added pcrlock failure error handling, added const qualifiers where appropriate. - moved to late_initcall - updated from hash to shash (suggestion by David Howells) - reduced worst stack usage (tpm_seal) from 530 to 312 bytes - moved documentation to Documentation directory (suggestion by David Howells) - all the other code cleanups suggested by David Howells - Add pcrlock CAP_SYS_ADMIN dependency (based on comment by Jason Gunthorpe) - New options: migratable, pcrlock, keyhandle, keyauth, blobauth (based on discussions with Jason Gunthorpe) - Free payload on failure to create key(reported/fixed by Roberto Sassu) - Updated Kconfig and other descriptions (based on Serge Hallyn's suggestion) - Replaced kzalloc() with kmalloc() (reported by Serge Hallyn) Signed-off-by: David Safford <safford@watson.ibm.com> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-10-28Fix install_process_keyring error handlingAndi Kleen
Fix an incorrect error check that returns 1 for error instead of the expected error code. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-10KEYS: Fix bug in keyctl_session_to_parent() if parent has no session keyringDavid Howells
Fix a bug in keyctl_session_to_parent() whereby it tries to check the ownership of the parent process's session keyring whether or not the parent has a session keyring [CVE-2010-2960]. This results in the following oops: BUG: unable to handle kernel NULL pointer dereference at 00000000000000a0 IP: [<ffffffff811ae4dd>] keyctl_session_to_parent+0x251/0x443 ... Call Trace: [<ffffffff811ae2f3>] ? keyctl_session_to_parent+0x67/0x443 [<ffffffff8109d286>] ? __do_fault+0x24b/0x3d0 [<ffffffff811af98c>] sys_keyctl+0xb4/0xb8 [<ffffffff81001eab>] system_call_fastpath+0x16/0x1b if the parent process has no session keyring. If the system is using pam_keyinit then it mostly protected against this as all processes derived from a login will have inherited the session keyring created by pam_keyinit during the log in procedure. To test this, pam_keyinit calls need to be commented out in /etc/pam.d/. Reported-by: Tavis Ormandy <taviso@cmpxchg8b.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Tavis Ormandy <taviso@cmpxchg8b.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-10KEYS: Fix RCU no-lock warning in keyctl_session_to_parent()David Howells
There's an protected access to the parent process's credentials in the middle of keyctl_session_to_parent(). This results in the following RCU warning: =================================================== [ INFO: suspicious rcu_dereference_check() usage. ] --------------------------------------------------- security/keys/keyctl.c:1291 invoked rcu_dereference_check() without protection! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 0 1 lock held by keyctl-session-/2137: #0: (tasklist_lock){.+.+..}, at: [<ffffffff811ae2ec>] keyctl_session_to_parent+0x60/0x236 stack backtrace: Pid: 2137, comm: keyctl-session- Not tainted 2.6.36-rc2-cachefs+ #1 Call Trace: [<ffffffff8105606a>] lockdep_rcu_dereference+0xaa/0xb3 [<ffffffff811ae379>] keyctl_session_to_parent+0xed/0x236 [<ffffffff811af77e>] sys_keyctl+0xb4/0xb6 [<ffffffff81001eab>] system_call_fastpath+0x16/0x1b The code should take the RCU read lock to make sure the parents credentials don't go away, even though it's holding a spinlock and has IRQ disabled. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-12Add a dummy printk function for the maintenance of unused printksDavid Howells
Add a dummy printk function for the maintenance of unused printks through gcc format checking, and also so that side-effect checking is maintained too. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-06KEYS: request_key() should return -ENOKEY if the constructed key is negativeDavid Howells
request_key() should return -ENOKEY if the key it constructs has been negatively instantiated. Without this, request_key() can return an unusable key to its caller, and if the caller then does key_validate() that won't catch the problem. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-02KEYS: Reinstate lost passing of process keyring ID in call_sbin_request_key()Justin P. Mattock
In commit bb952bb98a7e479262c7eb25d5592545a3af147d there was the accidental deletion of a statement from call_sbin_request_key() to render the process keyring ID to a text string so that it can be passed to /sbin/request-key. With gcc 4.6.0 this causes the following warning: CC security/keys/request_key.o security/keys/request_key.c: In function 'call_sbin_request_key': security/keys/request_key.c:102:15: warning: variable 'prkey' set but not used This patch reinstates that statement. Without this statement, /sbin/request-key will get some random rubbish from the stack as that parameter. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02KEYS: Use the variable 'key' in keyctl_describe_key()David Howells
keyctl_describe_key() turns the key reference it gets into a usable key pointer and assigns that to a variable called 'key', which it then ignores in favour of recomputing the key pointer each time it needs it. Make it use the precomputed pointer instead. Without this patch, gcc 4.6 reports that the variable key is set but not used: building with gcc 4.6 I'm getting a warning message: CC security/keys/keyctl.o security/keys/keyctl.c: In function 'keyctl_describe_key': security/keys/keyctl.c:472:14: warning: variable 'key' set but not used Reported-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02KEYS: Make /proc/keys check to see if a key is possessed before security checkDavid Howells
Make /proc/keys check to see if the calling process possesses each key before performing the security check. The possession check can be skipped if the key doesn't have the possessor-view permission bit set. This causes the keys a process possesses to show up in /proc/keys, even if they don't have matching user/group/other view permissions. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02KEYS: Authorise keyctl_set_timeout() on a key if we have its authorisation keyDavid Howells
Authorise a process to perform keyctl_set_timeout() on an uninstantiated key if that process has the authorisation key for it. This allows the instantiator to set the timeout on a key it is instantiating - provided it does it before instantiating the key. For instance, the test upcall script provided with the keyutils package could be modified to set the expiry to an hour hence before instantiating the key: [/usr/share/keyutils/request-key-debug.sh] if [ "$3" != "neg" ] then + keyctl timeout $1 3600 keyctl instantiate $1 "Debug $3" $4 || exit 1 else Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-06-27KEYS: Propagate error code instead of returning -EINVALDan Carpenter
This is from a Smatch check I'm writing. strncpy_from_user() returns -EFAULT on error so the first change just silences a warning but doesn't change how the code works. The other change is a bug fix because install_thread_keyring_to_cred() can return a variety of errors such as -EINVAL, -EEXIST, -ENOMEM or -EKEYREVOKED. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27keyctl_session_to_parent(): use thread_group_empty() to check singlethreadnessOleg Nesterov
No functional changes. keyctl_session_to_parent() is the only user of signal->count which needs the correct value. Change it to use thread_group_empty() instead, this must be strictly equivalent under tasklist, and imho looks better. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27umh: creds: convert call_usermodehelper_keys() to use subprocess_info->init()Oleg Nesterov
call_usermodehelper_keys() uses call_usermodehelper_setkeys() to change subprocess_info->cred in advance. Now that we have info->init() we can change this code to set tgcred->session_keyring in context of execing kernel thread. Note: since currently call_usermodehelper_keys() is never called with UMH_NO_WAIT, call_usermodehelper_keys()->key_get() and umh_keys_cleanup() are not really needed, we could rely on install_session_keyring_to_cred() which does key_get() on success. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25kernel-wide: replace USHORT_MAX, SHORT_MAX and SHORT_MIN with USHRT_MAX, ↵Alexey Dobriyan
SHRT_MAX and SHRT_MIN - C99 knows about USHRT_MAX/SHRT_MAX/SHRT_MIN, not USHORT_MAX/SHORT_MAX/SHORT_MIN. - Make SHRT_MIN of type s16, not int, for consistency. [akpm@linux-foundation.org: fix drivers/dma/timb_dma.c] [akpm@linux-foundation.org: fix security/keys/keyring.c] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-18KEYS: Return more accurate error codesDan Carpenter
We were using the wrong variable here so the error codes weren't being returned properly. The original code returns -ENOKEY. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-05-06KEYS: Do preallocation for __key_link()David Howells
Do preallocation for __key_link() so that the various callers in request_key.c can deal with any errors from this source before attempting to construct a key. This allows them to assume that the actual linkage step is guaranteed to be successful. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-05-06Merge branch 'master' into nextJames Morris
Conflicts: security/keys/keyring.c Resolved conflict with whitespace fix in find_keyring_by_name() Signed-off-by: James Morris <jmorris@namei.org>
2010-05-06KEYS: Better handling of errors from construct_alloc_key()David Howells
Errors from construct_alloc_key() shouldn't just be ignored in the way they are by construct_key_and_link(). The only error that can be ignored so is EINPROGRESS as that is used to indicate that we've found a key and don't need to construct one. We don't, however, handle ENOMEM, EDQUOT or EACCES to indicate allocation failures of one sort or another. Reported-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-05-06KEYS: keyring_serialise_link_sem is only needed for keyring->keyring linksDavid Howells
keyring_serialise_link_sem is only needed for keyring->keyring links as it's used to prevent cycle detection from being avoided by parallel keyring additions. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-05-05KEYS: call_sbin_request_key() must write lock keyrings before modifying themDavid Howells
call_sbin_request_key() creates a keyring and then attempts to insert a link to the authorisation key into that keyring, but does so without holding a write lock on the keyring semaphore. It will normally get away with this because it hasn't told anyone that the keyring exists yet. The new keyring, however, has had its serial number published, which means it can be accessed directly by that handle. This was found by a previous patch that adds RCU lockdep checks to the code that reads the keyring payload pointer, which includes a check that the keyring semaphore is actually locked. Without this patch, the following command: keyctl request2 user b a @s will provoke the following lockdep warning is displayed in dmesg: =================================================== [ INFO: suspicious rcu_dereference_check() usage. ] --------------------------------------------------- security/keys/keyring.c:727 invoked rcu_dereference_check() without protection! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 0 2 locks held by keyctl/2076: #0: (key_types_sem){.+.+.+}, at: [<ffffffff811a5b29>] key_type_lookup+0x1c/0x71 #1: (keyring_serialise_link_sem){+.+.+.}, at: [<ffffffff811a6d1e>] __key_link+0x4d/0x3c5 stack backtrace: Pid: 2076, comm: keyctl Not tainted 2.6.34-rc6-cachefs #54 Call Trace: [<ffffffff81051fdc>] lockdep_rcu_dereference+0xaa/0xb2 [<ffffffff811a6d1e>] ? __key_link+0x4d/0x3c5 [<ffffffff811a6e6f>] __key_link+0x19e/0x3c5 [<ffffffff811a5952>] ? __key_instantiate_and_link+0xb1/0xdc [<ffffffff811a59bf>] ? key_instantiate_and_link+0x42/0x5f [<ffffffff811aa0dc>] call_sbin_request_key+0xe7/0x33b [<ffffffff8139376a>] ? mutex_unlock+0x9/0xb [<ffffffff811a5952>] ? __key_instantiate_and_link+0xb1/0xdc [<ffffffff811a59bf>] ? key_instantiate_and_link+0x42/0x5f [<ffffffff811aa6fa>] ? request_key_auth_new+0x1c2/0x23c [<ffffffff810aaf15>] ? cache_alloc_debugcheck_after+0x108/0x173 [<ffffffff811a9d00>] ? request_key_and_link+0x146/0x300 [<ffffffff810ac568>] ? kmem_cache_alloc+0xe1/0x118 [<ffffffff811a9e45>] request_key_and_link+0x28b/0x300 [<ffffffff811a89ac>] sys_request_key+0xf7/0x14a [<ffffffff81052c0b>] ? trace_hardirqs_on_caller+0x10c/0x130 [<ffffffff81394fb9>] ? trace_hardirqs_on_thunk+0x3a/0x3f [<ffffffff81001eeb>] system_call_fastpath+0x16/0x1b Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-05-05KEYS: Use RCU dereference wrappers in keyring key type codeDavid Howells
The keyring key type code should use RCU dereference wrappers, even when it holds the keyring's key semaphore. Reported-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-05-05KEYS: find_keyring_by_name() can gain access to a freed keyringToshiyuki Okajima
find_keyring_by_name() can gain access to a keyring that has had its reference count reduced to zero, and is thus ready to be freed. This then allows the dead keyring to be brought back into use whilst it is being destroyed. The following timeline illustrates the process: |(cleaner) (user) | | free_user(user) sys_keyctl() | | | | key_put(user->session_keyring) keyctl_get_keyring_ID() | || //=> keyring->usage = 0 | | |schedule_work(&key_cleanup_task) lookup_user_key() | || | | kmem_cache_free(,user) | | . |[KEY_SPEC_USER_KEYRING] | . install_user_keyrings() | . || | key_cleanup() [<= worker_thread()] || | | || | [spin_lock(&key_serial_lock)] |[mutex_lock(&key_user_keyr..mutex)] | | || | atomic_read() == 0 || | |{ rb_ease(&key->serial_node,) } || | | || | [spin_unlock(&key_serial_lock)] |find_keyring_by_name() | | ||| | keyring_destroy(keyring) ||[read_lock(&keyring_name_lock)] | || ||| | |[write_lock(&keyring_name_lock)] ||atomic_inc(&keyring->usage) | |. ||| *** GET freeing keyring *** | |. ||[read_unlock(&keyring_name_lock)] | || || | |list_del() |[mutex_unlock(&key_user_k..mutex)] | || | | |[write_unlock(&keyring_name_lock)] ** INVALID keyring is returned ** | | . | kmem_cache_free(,keyring) . | . | atomic_dec(&keyring->usage) v *** DESTROYED *** TIME If CONFIG_SLUB_DEBUG=y then we may see the following message generated: ============================================================================= BUG key_jar: Poison overwritten ----------------------------------------------------------------------------- INFO: 0xffff880197a7e200-0xffff880197a7e200. First byte 0x6a instead of 0x6b INFO: Allocated in key_alloc+0x10b/0x35f age=25 cpu=1 pid=5086 INFO: Freed in key_cleanup+0xd0/0xd5 age=12 cpu=1 pid=10 INFO: Slab 0xffffea000592cb90 objects=16 used=2 fp=0xffff880197a7e200 flags=0x200000000000c3 INFO: Object 0xffff880197a7e200 @offset=512 fp=0xffff880197a7e300 Bytes b4 0xffff880197a7e1f0: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a ZZZZZZZZZZZZZZZZ Object 0xffff880197a7e200: 6a 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b jkkkkkkkkkkkkkkk Alternatively, we may see a system panic happen, such as: BUG: unable to handle kernel NULL pointer dereference at 0000000000000001 IP: [<ffffffff810e61a3>] kmem_cache_alloc+0x5b/0xe9 PGD 6b2b4067 PUD 6a80d067 PMD 0 Oops: 0000 [#1] SMP last sysfs file: /sys/kernel/kexec_crash_loaded CPU 1 ... Pid: 31245, comm: su Not tainted 2.6.34-rc5-nofixed-nodebug #2 D2089/PRIMERGY RIP: 0010:[<ffffffff810e61a3>] [<ffffffff810e61a3>] kmem_cache_alloc+0x5b/0xe9 RSP: 0018:ffff88006af3bd98 EFLAGS: 00010002 RAX: 0000000000000000 RBX: 0000000000000001 RCX: ffff88007d19900b RDX: 0000000100000000 RSI: 00000000000080d0 RDI: ffffffff81828430 RBP: ffffffff81828430 R08: ffff88000a293750 R09: 0000000000000000 R10: 0000000000000001 R11: 0000000000100000 R12: 00000000000080d0 R13: 00000000000080d0 R14: 0000000000000296 R15: ffffffff810f20ce FS: 00007f97116bc700(0000) GS:ffff88000a280000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000001 CR3: 000000006a91c000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process su (pid: 31245, threadinfo ffff88006af3a000, task ffff8800374414c0) Stack: 0000000512e0958e 0000000000008000 ffff880037f8d180 0000000000000001 0000000000000000 0000000000008001 ffff88007d199000 ffffffff810f20ce 0000000000008000 ffff88006af3be48 0000000000000024 ffffffff810face3 Call Trace: [<ffffffff810f20ce>] ? get_empty_filp+0x70/0x12f [<ffffffff810face3>] ? do_filp_open+0x145/0x590 [<ffffffff810ce208>] ? tlb_finish_mmu+0x2a/0x33 [<ffffffff810ce43c>] ? unmap_region+0xd3/0xe2 [<ffffffff810e4393>] ? virt_to_head_page+0x9/0x2d [<ffffffff81103916>] ? alloc_fd+0x69/0x10e [<ffffffff810ef4ed>] ? do_sys_open+0x56/0xfc [<ffffffff81008a02>] ? system_call_fastpath+0x16/0x1b Code: 0f 1f 44 00 00 49 89 c6 fa 66 0f 1f 44 00 00 65 4c 8b 04 25 60 e8 00 00 48 8b 45 00 49 01 c0 49 8b 18 48 85 db 74 0d 48 63 45 18 <48> 8b 04 03 49 89 00 eb 14 4c 89 f9 83 ca ff 44 89 e6 48 89 ef RIP [<ffffffff810e61a3>] kmem_cache_alloc+0x5b/0xe9 This problem is that find_keyring_by_name does not confirm that the keyring is valid before accepting it. Skipping keyrings that have been reduced to a zero count seems the way to go. To this end, use atomic_inc_not_zero() to increment the usage count and skip the candidate keyring if that returns false. The following script _may_ cause the bug to happen, but there's no guarantee as the window of opportunity is small: #!/bin/sh LOOP=100000 USER=dummy_user /bin/su -c "exit;" $USER || { /usr/sbin/adduser -m $USER; add=1; } for ((i=0; i<LOOP; i++)) do /bin/su -c "echo '$i' > /dev/null" $USER done (( add == 1 )) && /usr/sbin/userdel -r $USER exit Note that the nominated user must not be in use. An alternative way of testing this may be: for ((i=0; i<100000; i++)) do keyctl session foo /bin/true || break done >&/dev/null as that uses a keyring named "foo" rather than relying on the user and user-session named keyrings. Reported-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-05-05KEYS: Fix RCU handling in key_gc_keyring()David Howells
key_gc_keyring() needs to either hold the RCU read lock or hold the keyring semaphore if it's going to scan the keyring's list. Given that it only needs to read the key list, and it's doing so under a spinlock, the RCU read lock is the thing to use. Furthermore, the RCU check added in e7b0a61b7929632d36cf052d9e2820ef0a9c1bfe is incorrect as holding the spinlock on key_serial_lock is not grounds for assuming a keyring's pointer list can be read safely. Instead, a simple rcu_dereference() inside of the previously mentioned RCU read lock is what we want. Reported-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
