path: root/security/keys
2014-08-06Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "In this release: - PKCS#7 parser for the key management subsystem from David Howells - appoint Kees Cook as seccomp maintainer - bugfixes and general maintenance across the subsystem" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (94 commits) X.509: Need to export x509_request_asymmetric_key() netlabel: shorter names for the NetLabel catmap funcs/structs netlabel: fix the catmap walking functions netlabel: fix the horribly broken catmap functions netlabel: fix a problem when setting bits below the previously lowest bit PKCS#7: X.509 certificate issuer and subject are mandatory fields in the ASN.1 tpm: simplify code by using %*phN specifier tpm: Provide a generic means to override the chip returned timeouts tpm: missing tpm_chip_put in tpm_get_random() tpm: Properly clean sysfs entries in error path tpm: Add missing tpm_do_selftest to ST33 I2C driver PKCS#7: Use x509_request_asymmetric_key() Revert "selinux: fix the default socket labeling in sock_graft()" X.509: x509_request_asymmetric_keys() doesn't need string length arguments PKCS#7: fix sparse non static symbol warning KEYS: revert encrypted key change ima: add support for measuring and appraising firmware firmware_class: perform new LSM checks security: introduce kernel_fw_from_file hook PKCS#7: Missing inclusion of linux/err.h ...
2014-07-28KEYS: revert encrypted key changeMimi Zohar
Commit fc7c70e "KEYS: struct key_preparsed_payload should have two payload pointers" erroneously modified encrypted-keys. This patch reverts the change to that file. Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: David Howells <dhowells@redhat.com>
2014-07-22Merge branch 'keys-fixes' into keys-nextDavid Howells
2014-07-22Merge remote-tracking branch 'integrity/next-with-keys' into keys-nextDavid Howells
2014-07-22KEYS: request_key_auth: Provide key preparsingDavid Howells
Provide key preparsing for the request_key_auth key type so that we can make preparsing mandatory. This does nothing as this type can only be set up internally to the kernel. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Jeff Layton <jlayton@primarydata.com>
2014-07-22KEYS: keyring: Provide key preparsingDavid Howells
Provide key preparsing in the keyring so that we can make preparsing mandatory. For keyrings, however, only an empty payload is permitted. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Jeff Layton <jlayton@primarydata.com>
2014-07-22KEYS: big_key: Use key preparsingDavid Howells
Make use of key preparsing in the big key type so that quota size determination can take place prior to keyring locking when a key is being added. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com>
2014-07-22KEYS: user: Use key preparsingDavid Howells
Make use of key preparsing in user-defined and logon keys so that quota size determination can take place prior to keyring locking when a key is being added. Also the idmapper key types need to change to match as they use the user-defined key type routines. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Jeff Layton <jlayton@primarydata.com>
2014-07-22KEYS: Call ->free_preparse() even after ->preparse() returns an errorDavid Howells
Call the ->free_preparse() key type op even after ->preparse() returns an error as it does cleaning up type stuff. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Jeff Layton <jlayton@primarydata.com> Reviewed-by: Sage Weil <sage@redhat.com>
2014-07-22KEYS: Allow expiry time to be set when preparsing a keyDavid Howells
Allow a key type's preparsing routine to set the expiry time for a key. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Jeff Layton <jlayton@primarydata.com> Reviewed-by: Sage Weil <sage@redhat.com>
2014-07-22KEYS: struct key_preparsed_payload should have two payload pointersDavid Howells
struct key_preparsed_payload should have two payload pointers to correspond with those in struct key. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Jeff Layton <jlayton@primarydata.com> Reviewed-by: Sage Weil <sage@redhat.com>
2014-07-18KEYS: Provide a generic instantiation functionDavid Howells
Provide a generic instantiation function for key types that use the preparse hook. This makes it easier to prereserve key quota before keyrings get locked to retain the new key. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Jeff Layton <jlayton@primarydata.com> Reviewed-by: Sage Weil <sage@redhat.com>
2014-07-17KEYS: Allow special keys (eg. DNS results) to be invalidated by CAP_SYS_ADMINDavid Howells
Special kernel keys, such as those used to hold DNS results for AFS, CIFS and NFS and those used to hold idmapper results for NFS, used to be 'invalidateable' with key_revoke(). However, since the default permissions for keys were reduced: Commit: 96b5c8fea6c0861621051290d705ec2e971963f1 KEYS: Reduce initial permissions on keys it has become impossible to do this. Add a key flag (KEY_FLAG_ROOT_CAN_INVAL) that will permit a key to be invalidated by root. This should not be used for system keyrings as the garbage collector will try and remove any invalidate key. For system keyrings, KEY_FLAG_ROOT_CAN_CLEAR can be used instead. After this, from userspace, keyctl_invalidate() and "keyctl invalidate" can be used by any possessor of CAP_SYS_ADMIN (typically root) to invalidate DNS and idmapper keys. Invalidated keys are immediately garbage collected and will be immediately rerequested if needed again. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Steve Dickson <steved@redhat.com>
2014-07-17KEYS: special dot prefixed keyring name bug fixMimi Zohar
Dot prefixed keyring names are supposed to be reserved for the kernel, but add_key() calls key_get_type_from_user(), which incorrectly verifies the 'type' field, not the 'description' field. This patch verifies the 'description' field isn't dot prefixed, when creating a new keyring, and removes the dot prefix test in key_get_type_from_user(). Changelog v6: - whitespace and other cleanup Changelog v5: - Only prevent userspace from creating a dot prefixed keyring, not regular keys - Dmitry Reported-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Acked-by: David Howells <dhowells@redhat.com>
2014-07-16sched: Remove proliferation of wait_on_bit() action functionsNeilBrown
The current "wait_on_bit" interface requires an 'action' function to be provided which does the actual waiting. There are over 20 such functions, many of them identical. Most cases can be satisfied by one of just two functions, one which uses io_schedule() and one which just uses schedule(). So: Rename wait_on_bit and wait_on_bit_lock to wait_on_bit_action and wait_on_bit_lock_action to make it explicit that they need an action function. Introduce new wait_on_bit{,_lock} and wait_on_bit{,_lock}_io which are *not* given an action function but implicitly use a standard one. The decision to error-out if a signal is pending is now made based on the 'mode' argument rather than being encoded in the action function. All instances of the old wait_on_bit and wait_on_bit_lock which can use the new version have been changed accordingly and their action functions have been discarded. wait_on_bit{_lock} does not return any specific error code in the event of a signal so the caller must check for non-zero and interpolate their own error code as appropriate. The wait_on_bit() call in __fscache_wait_on_invalidate() was ambiguous as it specified TASK_UNINTERRUPTIBLE but used fscache_wait_bit_interruptible as an action function. David Howells confirms this should be uniformly "uninterruptible" The main remaining user of wait_on_bit{,_lock}_action is NFS which needs to use a freezer-aware schedule() call. A comment in fs/gfs2/glock.c notes that having multiple 'action' functions is useful as they display differently in the 'wchan' field of 'ps'. (and /proc/$PID/wchan). As the new bit_wait{,_io} functions are tagged "__sched", they will not show up at all, but something higher in the stack. So the distinction will still be visible, only with different function names (gds2_glock_wait versus gfs2_glock_dq_wait in the gfs2/glock.c case). Since first version of this patch (against 3.15) two new action functions appeared, on in NFS and one in CIFS. CIFS also now uses an action function that makes the same freezer aware schedule call as NFS. Signed-off-by: NeilBrown <neilb@suse.de> Acked-by: David Howells <dhowells@redhat.com> (fscache, keys) Acked-by: Steven Whitehouse <swhiteho@redhat.com> (gfs2) Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Steve French <sfrench@samba.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/20140707051603.28027.72349.stgit@notabene.brown Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-24Merge commit 'v3.15' into nextJames Morris
2014-06-10Merge branch 'serge-next-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sergeh/linux-security Pull security layer updates from Serge Hallyn: "This is a merge of James Morris' security-next tree from 3.14 to yesterday's master, plus four patches from Paul Moore which are in linux-next, plus one patch from Mimi" * 'serge-next-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sergeh/linux-security: ima: audit log files opened with O_DIRECT flag selinux: conditionally reschedule in hashtab_insert while loading selinux policy selinux: conditionally reschedule in mls_convert_context while loading selinux policy selinux: reject setexeccon() on MNT_NOSUID applications with -EACCES selinux: Report permissive mode in avc: denied messages. Warning in scanf string typing Smack: Label cgroup files for systemd Smack: Verify read access on file open - v3 security: Convert use of typedef ctl_table to struct ctl_table Smack: bidirectional UDS connect check Smack: Correctly remove SMACK64TRANSMUTE attribute SMACK: Fix handling value==NULL in post setxattr bugfix patch for SMACK Smack: adds smackfs/ptrace interface Smack: unify all ptrace accesses in the smack Smack: fix the subject/object order in smack_ptrace_traceme() Minor improvement of 'smack_sb_kern_mount' smack: fix key permission verification KEYS: Move the flags representing required permission to linux/key.h
2014-04-15security: Convert use of typedef ctl_table to struct ctl_tableJoe Perches
This typedef is unnecessary and should just be removed. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2014-04-14Merge tag 'keys-20140314' of ↵James Morris
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs into next
2014-04-14Merge commit 'v3.14' into nextJames Morris
2014-04-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "Apart from reordering the SELinux mmap code to ensure DAC is called before MAC, these are minor maintenance updates" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (23 commits) selinux: correctly label /proc inodes in use before the policy is loaded selinux: put the mmap() DAC controls before the MAC controls selinux: fix the output of ./scripts/get_maintainer.pl for SELinux evm: enable key retention service automatically ima: skip memory allocation for empty files evm: EVM does not use MD5 ima: return d_name.name if d_path fails integrity: fix checkpatch errors ima: fix erroneous removal of security.ima xattr security: integrity: Use a more current logging style MAINTAINERS: email updates and other misc. changes ima: reduce memory usage when a template containing the n field is used ima: restore the original behavior for sending data with ima template Integrity: Pass commname via get_task_comm() fs: move i_readcount ima: use static const char array definitions security: have cap_dentry_init_security return error ima: new helper: file_inode(file) kernel: Mark function as static in kernel/seccomp.c capability: Use current logging styles ...
2014-03-31Merge branch 'compat' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 compat wrapper rework from Heiko Carstens: "S390 compat system call wrapper simplification work. The intention of this work is to get rid of all hand written assembly compat system call wrappers on s390, which perform proper sign or zero extension, or pointer conversion of compat system call parameters. Instead all of this should be done with C code eg by using Al's COMPAT_SYSCALL_DEFINEx() macro. Therefore all common code and s390 specific compat system calls have been converted to the COMPAT_SYSCALL_DEFINEx() macro. In order to generate correct code all compat system calls may only have eg compat_ulong_t parameters, but no unsigned long parameters. Those patches which change parameter types from unsigned long to compat_ulong_t parameters are separate in this series, but shouldn't cause any harm. The only compat system calls which intentionally have 64 bit parameters (preadv64 and pwritev64) in support of the x86/32 ABI haven't been changed, but are now only available if an architecture defines __ARCH_WANT_COMPAT_SYS_PREADV64/PWRITEV64. System calls which do not have a compat variant but still need proper zero extension on s390, like eg "long sys_brk(unsigned long brk)" will get a proper wrapper function with the new s390 specific COMPAT_SYSCALL_WRAPx() macro: COMPAT_SYSCALL_WRAP1(brk, unsigned long, brk); which generates the following code (simplified): asmlinkage long sys_brk(unsigned long brk); asmlinkage long compat_sys_brk(long brk) { return sys_brk((u32)brk); } Given that the C file which contains all the COMPAT_SYSCALL_WRAP lines includes both linux/syscall.h and linux/compat.h, it will generate build errors, if the declaration of sys_brk() doesn't match, or if there exists a non-matching compat_sys_brk() declaration. In addition this will intentionally result in a link error if somewhere else a compat_sys_brk() function exists, which probably should have been used instead. Two more BUILD_BUG_ONs make sure the size and type of each compat syscall parameter can be handled correctly with the s390 specific macros. I converted the compat system calls step by step to verify the generated code is correct and matches the previous code. In fact it did not always match, however that was always a bug in the hand written asm code. In result we get less code, less bugs, and much more sanity checking" * 'compat' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (44 commits) s390/compat: add copyright statement compat: include linux/unistd.h within linux/compat.h s390/compat: get rid of compat wrapper assembly code s390/compat: build error for large compat syscall args mm/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types kexec/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types net/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types ipc/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types fs/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types ipc/compat: convert to COMPAT_SYSCALL_DEFINE fs/compat: convert to COMPAT_SYSCALL_DEFINE security/compat: convert to COMPAT_SYSCALL_DEFINE mm/compat: convert to COMPAT_SYSCALL_DEFINE net/compat: convert to COMPAT_SYSCALL_DEFINE kernel/compat: convert to COMPAT_SYSCALL_DEFINE fs/compat: optional preadv64/pwrite64 compat system calls ipc/compat_sys_msgrcv: change msgtyp type from long to compat_long_t s390/compat: partial parameter conversion within syscall wrappers s390/compat: automatic zero, sign and pointer conversion of syscalls s390/compat: add sync_file_range and fallocate compat syscalls ...
2014-03-14KEYS: Move the flags representing required permission to linux/key.hDavid Howells
Move the flags representing required permission to linux/key.h as the perm parameter of security_key_permission() is in terms of them - and not the permissions mask flags used in key->perm. Whilst we're at it: (1) Rename them to be KEY_NEED_xxx rather than KEY_xxx to avoid collisions with symbols in uapi/linux/input.h. (2) Don't use key_perm_t for a mask of required permissions, but rather limit it to the permissions mask attached to the key and arguments related directly to that. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Dmitry Kasatkin <d.kasatkin@samsung.com>
2014-03-09KEYS: Make the keyring cycle detector ignore other keyrings of the same nameDavid Howells
This fixes CVE-2014-0102. The following command sequence produces an oops: keyctl new_session i=`keyctl newring _ses @s` keyctl link @s $i The problem is that search_nested_keyrings() sees two keyrings that have matching type and description, so keyring_compare_object() returns true. s_n_k() then passes the key to the iterator function - keyring_detect_cycle_iterator() - which *should* check to see whether this is the keyring of interest, not just one with the same name. Because assoc_array_find() will return one and only one match, I assumed that the iterator function would only see an exact match or never be called - but the iterator isn't only called from assoc_array_find()... The oops looks something like this: kernel BUG at /data/fs/linux-2.6-fscache/security/keys/keyring.c:1003! invalid opcode: 0000 [#1] SMP ... RIP: keyring_detect_cycle_iterator+0xe/0x1f ... Call Trace: search_nested_keyrings+0x76/0x2aa __key_link_check_live_key+0x50/0x5f key_link+0x4e/0x85 keyctl_keyring_link+0x60/0x81 SyS_keyctl+0x65/0xe4 tracesys+0xdd/0xe2 The fix is to make keyring_detect_cycle_iterator() check that the key it has is the key it was actually looking for rather than calling BUG_ON(). A testcase has been included in the keyutils testsuite for this: http://git.kernel.org/cgit/linux/kernel/git/dhowells/keyutils.git/commit/?id=891f3365d07f1996778ade0e3428f01878a1790b Reported-by: Tommi Rantala <tt.rantala@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-06security/compat: convert to COMPAT_SYSCALL_DEFINEHeiko Carstens
Convert all compat system call functions where all parameter types have a size of four or less than four bytes, or are pointer types to COMPAT_SYSCALL_DEFINE. The implicit casts within COMPAT_SYSCALL_DEFINE will perform proper zero and sign extension to 64 bit of all parameters if needed. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2014-02-06security: replace strict_strto*() with kstrto*()Jingoo Han
The usage of strict_strto*() is not preferred, because strict_strto*() is obsolete. Thus, kstrto*() should be used. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2013-12-02security: shmem: implement kernel private shmem inodesEric Paris
We have a problem where the big_key key storage implementation uses a shmem backed inode to hold the key contents. Because of this detail of implementation LSM checks are being done between processes trying to read the keys and the tmpfs backed inode. The LSM checks are already being handled on the key interface level and should not be enforced at the inode level (since the inode is an implementation detail, not a part of the security model) This patch implements a new function shmem_kernel_file_setup() which returns the equivalent to shmem_file_setup() only the underlying inode has S_PRIVATE set. This means that all LSM checks for the inode in question are skipped. It should only be used for kernel internal operations where the inode is not exposed to userspace without proper LSM checking. It is possible that some other users of shmem_file_setup() should use the new interface, but this has not been explored. Reproducing this bug is a little bit difficult. The steps I used on Fedora are: (1) Turn off selinux enforcing: setenforce 0 (2) Create a huge key k=`dd if=/dev/zero bs=8192 count=1 | keyctl padd big_key test-key @s` (3) Access the key in another context: runcon system_u:system_r:httpd_t:s0-s0:c0.c1023 keyctl print $k >/dev/null (4) Examine the audit logs: ausearch -m AVC -i --subject httpd_t | audit2allow If the last command's output includes a line that looks like: allow httpd_t user_tmpfs_t:file { open read }; There was an inode check between httpd and the tmpfs filesystem. With this patch no such denial will be seen. (NOTE! you should clear your audit log if you have tested for this previously) (Please return you box to enforcing) Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> cc: Hugh Dickins <hughd@google.com> cc: linux-mm@kvack.org
2013-12-02KEYS: Fix searching of nested keyringsDavid Howells
If a keyring contains more than 16 keyrings (the capacity of a single node in the associative array) then those keyrings are split over multiple nodes arranged as a tree. If search_nested_keyrings() is called to search the keyring then it will attempt to manually walk over just the 0 branch of the associative array tree where all the keyring links are stored. This works provided the key is found before the algorithm steps from one node containing keyrings to a child node or if there are sufficiently few keyring links that the keyrings are all in one node. However, if the algorithm does need to step from a node to a child node, it doesn't change the node pointer unless a shortcut also gets transited. This means that the algorithm will keep scanning the same node over and over again without terminating and without returning. To fix this, move the internal-pointer-to-node translation from inside the shortcut transit handler so that it applies it to node arrival as well. This can be tested by: r=`keyctl newring sandbox @s` for ((i=0; i<=16; i++)); do keyctl newring ring$i $r; done for ((i=0; i<=16; i++)); do keyctl add user a$i a %:ring$i; done for ((i=0; i<=16; i++)); do keyctl search $r user a$i; done for ((i=17; i<=20; i++)); do keyctl search $r user a$i; done The searches should all complete successfully (or with an error for 17-20), but instead one or more of them will hang. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Stephen Gallagher <sgallagh@redhat.com>
2013-12-02KEYS: Fix multiple key add into associative arrayDavid Howells
If sufficient keys (or keyrings) are added into a keyring such that a node in the associative array's tree overflows (each node has a capacity N, currently 16) and such that all N+1 keys have the same index key segment for that level of the tree (the level'th nibble of the index key), then assoc_array_insert() calls ops->diff_objects() to indicate at which bit position the two index keys vary. However, __key_link_begin() passes a NULL object to assoc_array_insert() with the intention of supplying the correct pointer later before we commit the change. This means that keyring_diff_objects() is given a NULL pointer as one of its arguments which it does not expect. This results in an oops like the attached. With the previous patch to fix the keyring hash function, this can be forced much more easily by creating a keyring and only adding keyrings to it. Add any other sort of key and a different insertion path is taken - all 16+1 objects must want to cluster in the same node slot. This can be tested by: r=`keyctl newring sandbox @s` for ((i=0; i<=16; i++)); do keyctl newring ring$i $r; done This should work fine, but oopses when the 17th keyring is added. Since ops->diff_objects() is always called with the first pointer pointing to the object to be inserted (ie. the NULL pointer), we can fix the problem by changing the to-be-inserted object pointer to point to the index key passed into assoc_array_insert() instead. Whilst we're at it, we also switch the arguments so that they are the same as for ->compare_object(). BUG: unable to handle kernel NULL pointer dereference at 0000000000000088 IP: [<ffffffff81191ee4>] hash_key_type_and_desc+0x18/0xb0 ... RIP: 0010:[<ffffffff81191ee4>] hash_key_type_and_desc+0x18/0xb0 ... Call Trace: [<ffffffff81191f9d>] keyring_diff_objects+0x21/0xd2 [<ffffffff811f09ef>] assoc_array_insert+0x3b6/0x908 [<ffffffff811929a7>] __key_link_begin+0x78/0xe5 [<ffffffff81191a2e>] key_create_or_update+0x17d/0x36a [<ffffffff81192e0a>] SyS_add_key+0x123/0x183 [<ffffffff81400ddb>] tracesys+0xdd/0xe2 Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Stephen Gallagher <sgallagh@redhat.com>
2013-12-02KEYS: Fix the keyring hash functionDavid Howells
The keyring hash function (used by the associative array) is supposed to clear the bottommost nibble of the index key (where the hash value resides) for keyrings and make sure it is non-zero for non-keyrings. This is done to make keyrings cluster together on one branch of the tree separately to other keys. Unfortunately, the wrong mask is used, so only the bottom two bits are examined and cleared and not the whole bottom nibble. This means that keys and keyrings can still be successfully searched for under most circumstances as the hash is consistent in its miscalculation, but if a keyring's associative array bottom node gets filled up then approx 75% of the keyrings will not be put into the 0 branch. The consequence of this is that a key in a keyring linked to by another keyring, ie. keyring A -> keyring B -> key may not be found if the search starts at keyring A and then descends into keyring B because search_nested_keyrings() only searches up the 0 branch (as it "knows" all keyrings must be there and not elsewhere in the tree). The fix is to use the right mask. This can be tested with: r=`keyctl newring sandbox @s` for ((i=0; i<=16; i++)); do keyctl newring ring$i $r; done for ((i=0; i<=16; i++)); do keyctl add user a$i a %:ring$i; done for ((i=0; i<=16; i++)); do keyctl search $r user a$i; done This creates a sandbox keyring, then creates 17 keyrings therein (labelled ring0..ring16). This causes the root node of the sandbox's associative array to overflow and for the tree to have extra nodes inserted. Each keyring then is given a user key (labelled aN for ringN) for us to search for. We then search for the user keys we added, starting from the sandbox. If working correctly, it should return the same ordered list of key IDs as for...keyctl add... did. Without this patch, it reports ENOKEY "Required key not available" for some of the keys. Just which keys get this depends as the kernel pointer to the key type forms part of the hash function. Reported-by: Nalin Dahyabhai <nalin@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Stephen Gallagher <sgallagh@redhat.com>
2013-12-02KEYS: Pre-clear struct key on allocationDavid Howells
The second word of key->payload does not get initialised in key_alloc(), but the big_key type is relying on it having been cleared. The problem comes when big_key fails to instantiate a large key and doesn't then set the payload. The big_key_destroy() op is called from the garbage collector and this assumes that the dentry pointer stored in the second word will be NULL if instantiation did not complete. Therefore just pre-clear the entire struct key on allocation rather than trying to be clever and only initialising to 0 only those bits that aren't otherwise initialised. The lack of initialisation can lead to a bug report like the following if big_key failed to initialise its file: general protection fault: 0000 [#1] SMP Modules linked in: ... CPU: 0 PID: 51 Comm: kworker/0:1 Not tainted 3.10.0-53.el7.x86_64 #1 Hardware name: Dell Inc. PowerEdge 1955/0HC513, BIOS 1.4.4 12/09/2008 Workqueue: events key_garbage_collector task: ffff8801294f5680 ti: ffff8801296e2000 task.ti: ffff8801296e2000 RIP: 0010:[<ffffffff811b4a51>] dput+0x21/0x2d0 ... Call Trace: [<ffffffff811a7b06>] path_put+0x16/0x30 [<ffffffff81235604>] big_key_destroy+0x44/0x60 [<ffffffff8122dc4b>] key_gc_unused_keys.constprop.2+0x5b/0xe0 [<ffffffff8122df2f>] key_garbage_collector+0x1df/0x3c0 [<ffffffff8107759b>] process_one_work+0x17b/0x460 [<ffffffff8107834b>] worker_thread+0x11b/0x400 [<ffffffff81078230>] ? rescuer_thread+0x3e0/0x3e0 [<ffffffff8107eb00>] kthread+0xc0/0xd0 [<ffffffff8107ea40>] ? kthread_create_on_node+0x110/0x110 [<ffffffff815c4bec>] ret_from_fork+0x7c/0xb0 [<ffffffff8107ea40>] ? kthread_create_on_node+0x110/0x110 Reported-by: Patrik Kis <pkis@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Stephen Gallagher <sgallagh@redhat.com>
2013-11-14KEYS: Fix keyring content gc scannerDavid Howells
Key pointers stored in the keyring are marked in bit 1 to indicate if they point to a keyring. We need to strip off this bit before using the pointer when iterating over the keyring for the purpose of looking for links to garbage collect. This means that expirable keyrings aren't correctly expiring because the checker is seeing their key pointer with 2 added to it. Since the fix for this involves knowing about the internals of the keyring, key_gc_keyring() is moved to keyring.c and merged into keyring_gc(). This can be tested by: echo 2 >/proc/sys/kernel/keys/gc_delay keyctl timeout `keyctl add keyring qwerty "" @s` 2 cat /proc/keys sleep 5; cat /proc/keys which should see a keyring called "qwerty" appear in the session keyring and then disappear after it expires, and: echo 2 >/proc/sys/kernel/keys/gc_delay a=`keyctl get_persistent @s` b=`keyctl add keyring 0 "" $a` keyctl add user a a $b keyctl timeout $b 2 cat /proc/keys sleep 5; cat /proc/keys which should see a keyring called "0" with a key called "a" in it appear in the user's persistent keyring (which will be attached to the session keyring) and then both the "0" keyring and the "a" key should disappear when the "0" keyring expires. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Simo Sorce <simo@redhat.com>
2013-11-13KEYS: Fix error handling in big_key instantiationDavid Howells
In the big_key_instantiate() function we return 0 if kernel_write() returns us an error rather than returning an error. This can potentially lead to dentry_open() giving a BUG when called from big_key_read() with an unset tmpfile path. ------------[ cut here ]------------ kernel BUG at fs/open.c:798! ... RIP: 0010:[<ffffffff8119bbd1>] dentry_open+0xd1/0xe0 ... Call Trace: [<ffffffff812350c5>] big_key_read+0x55/0x100 [<ffffffff81231084>] keyctl_read_key+0xb4/0xe0 [<ffffffff81231e58>] SyS_keyctl+0xf8/0x1d0 [<ffffffff815bb799>] system_call_fastpath+0x16/0x1b Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Stephen Gallagher <sgallagh@redhat.com>
2013-11-06KEYS: Fix UID check in keyctl_get_persistent()David Howells
If the UID is specified by userspace when calling the KEYCTL_GET_PERSISTENT function and the process does not have the CAP_SETUID capability, then the function will return -EPERM if the current process's uid, suid, euid and fsuid all match the requested UID. This is incorrect. Fix it such that when a non-privileged caller requests a persistent keyring by a specific UID they can only request their own (ie. the specified UID matches either then process's UID or the process's EUID). This can be tested by logging in as the user and doing: keyctl get_persistent @p keyctl get_persistent @p `id -u` keyctl get_persistent @p 0 The first two should successfully print the same key ID. The third should do the same if called by UID 0 or indicate Operation Not Permitted otherwise. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Stephen Gallagher <sgallagh@redhat.com>
2013-10-30KEYS: fix error return code in big_key_instantiate()Wei Yongjun
Fix to return a negative error code from the error handling case instead of 0, as done elsewhere in this function. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: David Howells <dhowells@redhat.com>
2013-10-30KEYS: Fix keyring quota misaccounting on key replacement and unlinkDavid Howells
If a key is displaced from a keyring by a matching one, then four more bytes of quota are allocated to the keyring - despite the fact that the keyring does not change in size. Further, when a key is unlinked from a keyring, the four bytes of quota allocated the link isn't recovered and returned to the user's pool. The first can be tested by repeating: keyctl add big_key a fred @s cat /proc/key-users (Don't put it in a shell loop otherwise the garbage collector won't have time to clear the displaced keys, thus affecting the result). This was causing the kerberos keyring to run out of room fairly quickly. The second can be tested by: cat /proc/key-users a=`keyctl add user a a @s` cat /proc/key-users keyctl unlink $a sleep 1 # Give RCU a chance to delete the key cat /proc/key-users assuming no system activity that otherwise adds/removes keys, the amount of key data allocated should go up (say 40/20000 -> 47/20000) and then return to the original value at the end. Reported-by: Stephen Gallagher <sgallagh@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com>
2013-10-30KEYS: Fix a race between negating a key and reading the error setDavid Howells
key_reject_and_link() marking a key as negative and setting the error with which it was negated races with keyring searches and other things that read that error. The fix is to switch the order in which the assignments are done in key_reject_and_link() and to use memory barriers. Kudos to Dave Wysochanski <dwysocha@redhat.com> and Scott Mayhew <smayhew@redhat.com> for tracking this down. This may be the cause of: BUG: unable to handle kernel NULL pointer dereference at 0000000000000070 IP: [<ffffffff81219011>] wait_for_key_construction+0x31/0x80 PGD c6b2c3067 PUD c59879067 PMD 0 Oops: 0000 [#1] SMP last sysfs file: /sys/devices/system/cpu/cpu3/cache/index2/shared_cpu_map CPU 0 Modules linked in: ... Pid: 13359, comm: amqzxma0 Not tainted 2.6.32-358.20.1.el6.x86_64 #1 IBM System x3650 M3 -[7945PSJ]-/00J6159 RIP: 0010:[<ffffffff81219011>] wait_for_key_construction+0x31/0x80 RSP: 0018:ffff880c6ab33758 EFLAGS: 00010246 RAX: ffffffff81219080 RBX: 0000000000000000 RCX: 0000000000000002 RDX: ffffffff81219060 RSI: 0000000000000000 RDI: 0000000000000000 RBP: ffff880c6ab33768 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000001 R11: 0000000000000000 R12: ffff880adfcbce40 R13: ffffffffa03afb84 R14: ffff880adfcbce40 R15: ffff880adfcbce43 FS: 00007f29b8042700(0000) GS:ffff880028200000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000070 CR3: 0000000c613dc000 CR4: 00000000000007f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process amqzxma0 (pid: 13359, threadinfo ffff880c6ab32000, task ffff880c610deae0) Stack: ffff880adfcbce40 0000000000000000 ffff880c6ab337b8 ffffffff81219695 <d> 0000000000000000 ffff880a000000d0 ffff880c6ab337a8 000000000000000f <d> ffffffffa03afb93 000000000000000f ffff88186c7882c0 0000000000000014 Call Trace: [<ffffffff81219695>] request_key+0x65/0xa0 [<ffffffffa03a0885>] nfs_idmap_request_key+0xc5/0x170 [nfs] [<ffffffffa03a0eb4>] nfs_idmap_lookup_id+0x34/0x80 [nfs] [<ffffffffa03a1255>] nfs_map_group_to_gid+0x75/0xa0 [nfs] [<ffffffffa039a9ad>] decode_getfattr_attrs+0xbdd/0xfb0 [nfs] [<ffffffff81057310>] ? __dequeue_entity+0x30/0x50 [<ffffffff8100988e>] ? __switch_to+0x26e/0x320 [<ffffffffa039ae03>] decode_getfattr+0x83/0xe0 [nfs] [<ffffffffa039b610>] ? nfs4_xdr_dec_getattr+0x0/0xa0 [nfs] [<ffffffffa039b69f>] nfs4_xdr_dec_getattr+0x8f/0xa0 [nfs] [<ffffffffa02dada4>] rpcauth_unwrap_resp+0x84/0xb0 [sunrpc] [<ffffffffa039b610>] ? nfs4_xdr_dec_getattr+0x0/0xa0 [nfs] [<ffffffffa02cf923>] call_decode+0x1b3/0x800 [sunrpc] [<ffffffff81096de0>] ? wake_bit_function+0x0/0x50 [<ffffffffa02cf770>] ? call_decode+0x0/0x800 [sunrpc] [<ffffffffa02d99a7>] __rpc_execute+0x77/0x350 [sunrpc] [<ffffffff81096c67>] ? bit_waitqueue+0x17/0xd0 [<ffffffffa02d9ce1>] rpc_execute+0x61/0xa0 [sunrpc] [<ffffffffa02d03a5>] rpc_run_task+0x75/0x90 [sunrpc] [<ffffffffa02d04c2>] rpc_call_sync+0x42/0x70 [sunrpc] [<ffffffffa038ff80>] _nfs4_call_sync+0x30/0x40 [nfs] [<ffffffffa038836c>] _nfs4_proc_getattr+0xac/0xc0 [nfs] [<ffffffff810aac87>] ? futex_wait+0x227/0x380 [<ffffffffa038b856>] nfs4_proc_getattr+0x56/0x80 [nfs] [<ffffffffa0371403>] __nfs_revalidate_inode+0xe3/0x220 [nfs] [<ffffffffa037158e>] nfs_revalidate_mapping+0x4e/0x170 [nfs] [<ffffffffa036f147>] nfs_file_read+0x77/0x130 [nfs] [<ffffffff811811aa>] do_sync_read+0xfa/0x140 [<ffffffff81096da0>] ? autoremove_wake_function+0x0/0x40 [<ffffffff8100bb8e>] ? apic_timer_interrupt+0xe/0x20 [<ffffffff8100b9ce>] ? common_interrupt+0xe/0x13 [<ffffffff81228ffb>] ? selinux_file_permission+0xfb/0x150 [<ffffffff8121bed6>] ? security_file_permission+0x16/0x20 [<ffffffff81181a95>] vfs_read+0xb5/0x1a0 [<ffffffff81181bd1>] sys_read+0x51/0x90 [<ffffffff810dc685>] ? __audit_syscall_exit+0x265/0x290 [<ffffffff8100b072>] system_call_fastpath+0x16/0x1b Signed-off-by: David Howells <dhowells@redhat.com> cc: Dave Wysochanski <dwysocha@redhat.com> cc: Scott Mayhew <smayhew@redhat.com>
2013-10-30KEYS: Make BIG_KEYS booleanJosh Boyer
Having the big_keys functionality as a module is very marginally useful. The userspace code that would use this functionality will get odd error messages from the keys layer if the module isn't loaded. The code itself is fairly small, so just have this as a boolean option and not a tristate. Signed-off-by: Josh Boyer <jwboyer@fedoraproject.org> Signed-off-by: David Howells <dhowells@redhat.com>
2013-09-25KEYS: initialize root uid and session keyrings earlyMimi Zohar
In order to create the integrity keyrings (eg. _evm, _ima), root's uid and session keyrings need to be initialized early. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: David Howells <dhowells@redhat.com>
2013-09-25KEYS: Add a 'trusted' flag and a 'trusted only' flagDavid Howells
Add KEY_FLAG_TRUSTED to indicate that a key either comes from a trusted source or had a cryptographic signature chain that led back to a trusted key the kernel already possessed. Add KEY_FLAGS_TRUSTED_ONLY to indicate that a keyring will only accept links to keys marked with KEY_FLAGS_TRUSTED. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Kees Cook <keescook@chromium.org>
2013-09-24KEYS: Add per-user_namespace registers for persistent per-UID kerberos cachesDavid Howells
Add support for per-user_namespace registers of persistent per-UID kerberos caches held within the kernel. This allows the kerberos cache to be retained beyond the life of all a user's processes so that the user's cron jobs can work. The kerberos cache is envisioned as a keyring/key tree looking something like: struct user_namespace \___ .krb_cache keyring - The register \___ _krb.0 keyring - Root's Kerberos cache \___ _krb.5000 keyring - User 5000's Kerberos cache \___ _krb.5001 keyring - User 5001's Kerberos cache \___ tkt785 big_key - A ccache blob \___ tkt12345 big_key - Another ccache blob Or possibly: struct user_namespace \___ .krb_cache keyring - The register \___ _krb.0 keyring - Root's Kerberos cache \___ _krb.5000 keyring - User 5000's Kerberos cache \___ _krb.5001 keyring - User 5001's Kerberos cache \___ tkt785 keyring - A ccache \___ krbtgt/REDHAT.COM@REDHAT.COM big_key \___ http/REDHAT.COM@REDHAT.COM user \___ afs/REDHAT.COM@REDHAT.COM user \___ nfs/REDHAT.COM@REDHAT.COM user \___ krbtgt/KERNEL.ORG@KERNEL.ORG big_key \___ http/KERNEL.ORG@KERNEL.ORG big_key What goes into a particular Kerberos cache is entirely up to userspace. Kernel support is limited to giving you the Kerberos cache keyring that you want. The user asks for their Kerberos cache by: krb_cache = keyctl_get_krbcache(uid, dest_keyring); The uid is -1 or the user's own UID for the user's own cache or the uid of some other user's cache (requires CAP_SETUID). This permits rpc.gssd or whatever to mess with the cache. The cache returned is a keyring named "_krb.<uid>" that the possessor can read, search, clear, invalidate, unlink from and add links to. Active LSMs get a chance to rule on whether the caller is permitted to make a link. Each uid's cache keyring is created when it first accessed and is given a timeout that is extended each time this function is called so that the keyring goes away after a while. The timeout is configurable by sysctl but defaults to three days. Each user_namespace struct gets a lazily-created keyring that serves as the register. The cache keyrings are added to it. This means that standard key search and garbage collection facilities are available. The user_namespace struct's register goes away when it does and anything left in it is then automatically gc'd. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Simo Sorce <simo@redhat.com> cc: Serge E. Hallyn <serge.hallyn@ubuntu.com> cc: Eric W. Biederman <ebiederm@xmission.com>
2013-09-24KEYS: Implement a big key type that can save to tmpfsDavid Howells
Implement a big key type that can save its contents to tmpfs and thus swapspace when memory is tight. This is useful for Kerberos ticket caches. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Simo Sorce <simo@redhat.com>
2013-09-24KEYS: Expand the capacity of a keyringDavid Howells
Expand the capacity of a keyring to be able to hold a lot more keys by using the previously added associative array implementation. Currently the maximum capacity is: (PAGE_SIZE - sizeof(header)) / sizeof(struct key *) which, on a 64-bit system, is a little more 500. However, since this is being used for the NFS uid mapper, we need more than that. The new implementation gives us effectively unlimited capacity. With some alterations, the keyutils testsuite runs successfully to completion after this patch is applied. The alterations are because (a) keyrings that are simply added to no longer appear ordered and (b) some of the errors have changed a bit. Signed-off-by: David Howells <dhowells@redhat.com>
2013-09-24KEYS: Drop the permissions argument from __keyring_search_one()David Howells
Drop the permissions argument from __keyring_search_one() as the only caller passes 0 here - which causes all checks to be skipped. Signed-off-by: David Howells <dhowells@redhat.com>
2013-09-24KEYS: Define a __key_get() wrapper to use rather than atomic_inc()David Howells
Define a __key_get() wrapper to use rather than atomic_inc() on the key usage count as this makes it easier to hook in refcount error debugging. Signed-off-by: David Howells <dhowells@redhat.com>
2013-09-24KEYS: Search for auth-key by name rather than target key IDDavid Howells
Search for auth-key by name rather than by target key ID as, in a future patch, we'll by searching directly by index key in preference to iteration over all keys. Signed-off-by: David Howells <dhowells@redhat.com>
2013-09-24KEYS: Introduce a search context structureDavid Howells
Search functions pass around a bunch of arguments, each of which gets copied with each call. Introduce a search context structure to hold these. Whilst we're at it, create a search flag that indicates whether the search should be directly to the description or whether it should iterate through all keys looking for a non-description match. This will be useful when keyrings use a generic data struct with generic routines to manage their content as the search terms can just be passed through to the iterator callback function. Also, for future use, the data to be supplied to the match function is separated from the description pointer in the search context. This makes it clear which is being supplied. Signed-off-by: David Howells <dhowells@redhat.com>
2013-09-24KEYS: Consolidate the concept of an 'index key' for key accessDavid Howells
Consolidate the concept of an 'index key' for accessing keys. The index key is the search term needed to find a key directly - basically the key type and the key description. We can add to that the description length. This will be useful when turning a keyring into an associative array rather than just a pointer block. Signed-off-by: David Howells <dhowells@redhat.com>
2013-09-24KEYS: key_is_dead() should take a const key pointer argumentDavid Howells
key_is_dead() should take a const key pointer argument as it doesn't modify what it points to. Signed-off-by: David Howells <dhowells@redhat.com>
2013-09-24KEYS: Use bool in make_key_ref() and is_key_possessed()David Howells
Make make_key_ref() take a bool possession parameter and make is_key_possessed() return a bool. Signed-off-by: David Howells <dhowells@redhat.com>
