path: root/security/apparmor/sid.c
2017-01-16apparmor: rename sid to secidJohn Johansen
Move to common terminology with other LSMs and kernel infrastucture Signed-off-by: John Johansen <john.johansen@canonical.com>
2010-08-02AppArmor: core policy routinesJohn Johansen
The basic routines and defines for AppArmor policy. AppArmor policy is defined by a few basic components. profiles - the basic unit of confinement contain all the information to enforce policy on a task Profiles tend to be named after an executable that they will attach to but this is not required. namespaces - a container for a set of profiles that will be used during attachment and transitions between profiles. sids - which provide a unique id for each profile Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
