path: root/scripts
2007-10-18update checkpatch.pl to version 0.11Andy Whitcroft
This version brings a more cautious checkpatch.pl by default. The more subjective checks are only applied with the --strict option. It also brings the usual slew of corrections for false positives. Of note: - new tree detection, the source tree will be found via the executable - a major revamp of the unary detection to make it more parser like - a new summary at the bottom of the report - --strict option for subjective checks - --file to enable checking on complete files - support for use in emacs "compile" window Andy Whitcroft (27): Version: 0.11 fix up cat_vet for the case where there are no control characters any cast to a pointer introduces a type cpp unary operator detection needs to float attributes are also valid in type definitions sizeof may be a bareword and makes its argument unary unary checks for #ifdef et al need to find end of line add new --file mode to handle raw source files add --strict/--subjective which enables the subjective tests add some additional standard type suffixes cpp #elif is also a unary prefix case is not a function name widen asm volatile exceptions __kprobes is a type attribute typeof is a unary operator function open parenthesis checks should check all occurances expand sizeof() binary exceptions linux/irq.h should not be recommended work harder to find the kernel root and add --root= fix --emacs mode line numbers and string concatenation warnings add a summary to the bottom of the main report loosen assignment in if checks update operator spacing to maintain tabs in output revamp unary detection corruption/line wrapped patches need only reporting once revamp s/u/be/le 8/16/32/64 bit types handle missing ,1 in uni-diff header Mike D. Day (2): Adds support to checkpatch.pl for running in the emacs compile window. checkpatch: Fix line number reporting Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17kernel-doc: fix doc blocks and htmlRandy Dunlap
Johannes Berg reports (Thanks!) that &struct names are not highlighted in html output format when they are inside a DOC: block. DOC: blocks were not escaped thru xml_escape() like other kernel-doc comments were. Fixed that. However, that left a problem with <p> ($blankline_html) being processed thru xml_escape(), converting it to &lt;p&gt;, which isn't good for the generated html output (the <p> should remain unchanged), so this patch also introduces the notion of "local" kernel-doc meta-characters ('\\\\mnemonic:'), which are converted to html just before writing the stream to its output file. Please report any problems that you (anyone) see in "highlighting" in any output mode (text, man, html, xml). Also update copyright to include me. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17update checkpatch.pl to version 0.10Andy Whitcroft
This version brings a number of new checks, and a number of bug fixes. Of note: - better categorisation and space checks for dual use unary/binary operators - warn on deprecated use of {SPIN,RW}_LOCK_UNLOCKED - check if/for/while with trailing ';' for hanging statements - detect DOS line endings - detect redundant casts for kalloc() Andy Whitcroft (18): Version: 0.10 asmlinkage is also a storage type pull out inline specifiers allow only some operators before a unary operator parenthesised values may span line ends add additional attribute matching handle sparse annotations within pointer type space checks support alternative function definition syntax for typedefs check if/for/while with trailing ';' for hanging statements fix output format for case checks deprecate SPIN_LOCK_UNLOCKED and RW_LOCK_UNLOCKED allow complex macros with bracketing braces detect and report DOS line endings fastcall is a valid function attribute bracket spacing is ok for 'for' categorise operators into unary/binary/definitions add heuristic to pick up on unannotated types remove spurious warnings from cat_vet Dave Jones (1): Make checkpatch warn about pointless casting of kalloc returns. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Add stack checking for BlackfinMike Frysinger
Simply fill out the bits in checkstack.pl for Blackfin. I thought I already sent this, but I don't see it in -mm anywhere ... Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: (40 commits) kbuild: introduce ccflags-y, asflags-y and ldflags-y kbuild: enable 'make CPPFLAGS=...' to add additional options to CPP kbuild: enable use of AFLAGS and CFLAGS on commandline kbuild: enable 'make AFLAGS=...' to add additional options to AS kbuild: fix AFLAGS use in h8300 and m68knommu kbuild: check for wrong use of CFLAGS kbuild: enable 'make CFLAGS=...' to add additional options to CC kbuild: fix up CFLAGS usage kbuild: make modpost detect unterminated device id lists kbuild: call export_report from the Makefile kbuild: move Kai Germaschewski to CREDITS kconfig/menuconfig: distinguish between selected-by-another options and comments kconfig: tristate choices with mixed tristate and boolean values include/linux/Kbuild: remove duplicate entries kbuild: kill backward compatibility checks kbuild: kill EXTRA_ARFLAGS kbuild: fix documentation in makefiles.txt kbuild: call make once for all targets when O=.. is used kbuild: pass -g to assembler under CONFIG_DEBUG_INFO kbuild: update _shipped files for kconfig syntax cleanup ... Fix up conflicts in arch/um/sys-{x86_64,i386}/Makefile manually.
2007-10-15kbuild: introduce ccflags-y, asflags-y and ldflags-ySam Ravnborg
Introduce ccflags-y, asflags-y and ldflags-y so we soon can deprecate use of EXTRA_CFLAGS, EXTRA_AFLAGS and EXTRA_LDFLAGS. This patch does not touch any in-tree users - thats next round. Lets get this committed first and then fix the users of the soon to be deprecated variants next. The rationale behind this change is to introduce support for makefile fragments like: ccflags-$(CONFIG_WHATEVER_DEBUG) := -DDEBUG As a replacement for the uglier: ifeq ($(CONFIG_WHATEVER_DEBUG),y) EXTRA_CFLAGS := -DDEBUG endif Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-15kbuild: enable 'make CPPFLAGS=...' to add additional options to CPPSam Ravnborg
The variable CPPFLAGS is a wellknown variable and the usage by kbuild may result in unexpected behaviour. This patch replace use of CPPFLAGS with KBUILD_CPPFLAGS all over the tree and enabling one to use: make CPPFLAGS=... to specify additional CPP commandline options. Patch was tested on following architectures: alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k, s390 Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-15kbuild: enable 'make AFLAGS=...' to add additional options to ASSam Ravnborg
The variable AFLAGS is a wellknown variable and the usage by kbuild may result in unexpected behaviour. On top of that several people over time has asked for a way to pass in additional flags to gcc. This patch replace use of AFLAGS with KBUILD_AFLAGS all over the tree. Patch was tested on following architectures: alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k, s390 Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-14kbuild: check for wrong use of CFLAGSSam Ravnborg
External modules have in a few cases modifed gcc option by modifying CFLAGS. This has never been documented and was a bad practice. With the check to use KBUILD_CFLAGS it will no longer work so we better error out and tell what was wrong as a service to the external module users. This check can be overruled if KBUILD_NOPEDANTIC is set to something. Addid this possibility may allow older external module to build without any code modifications but potentially only loosing some un-important gcc options. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-14kbuild: enable 'make CFLAGS=...' to add additional options to CCSam Ravnborg
The variable CFLAGS is a wellknown variable and the usage by kbuild may result in unexpected behaviour. On top of that several people over time has asked for a way to pass in additional flags to gcc. This patch replace use of CFLAGS with KBUILD_CFLAGS all over the tree and enabling one to use: make CFLAGS=... to specify additional gcc commandline options. One usecase is when trying to find gcc bugs but other use cases has been requested too. Patch was tested on following architectures: alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k Test was simple to do a defconfig build, apply the patch and check that nothing got rebuild. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-13i2c: Kill struct i2c_device_idJean Delvare
I2C devices do not have any form of ID as PCI or USB devices have. No driver uses "MODULE_DEVICE_TABLE(i2c, ...)" because it doesn't make sense. So we can get rid of struct i2c_device_id and the associated support code. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Greg KH <greg@kroah.com>
2007-10-12kbuild: make modpost detect unterminated device id listsKees Cook
Cause modpost to fail if any device id lists are incorrectly terminated, after reporting the offender. Improved reporting by akpm Signed-off-by: Kees Cook <kees@ubuntu.com> Cc: Greg KH <greg@kroah.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Ben Collins <bcollins@ubuntu.com> Cc: Michael Wu <flamingice@sourmilk.net> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kconfig/menuconfig: distinguish between selected-by-another options and commentsMatej Laitl
menuconfig currently represents options implied by another option ('select' directive in Kconfig) by prefixing them with '---'. Unfortunately the same notation is used for comments. If the implied option is module capable, user can still switch between Y and M, all without any feedback until she visits option's help. (try saying M to MAC80211 and then toggling CFG80211) This patch changes notation of selected-by-another items by introducing 2 new representations for implied options: {*} or {M} for options selected by another modularized one, thus builtin or module capable, -*- or -M- for options that cannot be at the moment changed by user. The idea is to represent actual capability of the option by braces (dashes) around and to always report actual state by * or M inside. Signed-off-by: Matej Laitl <strohel@gmail.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kconfig: tristate choices with mixed tristate and boolean valuesJan Beulich
Change kconfig behavior so that mixing bool and tristate config settings in a choice is possible and has the desired effect of offering just the tristate options individually if the choice gets set to M, and a normal boolean selection if the choice gets set to Y. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: kill backward compatibility checksSam Ravnborg
These checks has been present for several kernel releases (> 5). So lets just get rid of them. With this we no longer check for use of: EXTRA_TARGETS, O_TARGET, L_TARGET, list-multi, export-objs There were three remaining in-tree users of O_TARGET in some unmaintained sh64 code - mail sent to the maintainer + list. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: kill EXTRA_ARFLAGSSam Ravnborg
EXTRA_ARFLAGS have never been used so no need to carry around on this. A google search did not reveal any external module using this either. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: call make once for all targets when O=.. is usedMilton Miller
Change the invocations of make in the output directory Makefile and the main Makefile for separate object trees to pass all goals to one $(MAKE) via a new phony target "sub-make" and the existing target _all. When compiling with separate object directories, a separate make is called in the context of another directory (from the output directory the main Makefile is called, the Makefile is then restarted with current directory set to the object tree). Before this patch, when multiple make command goals are specified, each target results in a separate make invocation. With make -j, these invocations may run in parallel, resulting in multiple commands running in the same directory clobbering each others results. I did not try to address make -j for mixed dot-config and no-dot-config targets. Because the order does matter, a solution was not obvious. Perhaps a simple check for MAKEFLAGS having -j and refusing to run would be appropriate. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: update _shipped files for kconfig syntax cleanupSam Ravnborg
Update _shipped files so regular user does not need to have bison/flex/gperf installed. Code changes were contained in previous commit. Used following program versions (on fedora): bison (GNU Bison) 2.3 flex 2.5.33 GNU gperf 3.0.2 Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kconfig: syntax cleanup - drop support for "depends/requires/def_boolean"Adrian Bunk
Remove the following redundant and never or rarely used kconfig syntax: - "def_boolean" (same as "def_bool") - "requires" (same as "depends on") - "depends" (same as "depends on") This patch contains the code changes and Kconfig updates. The shipped files are in next patch to let actual codechange stand out. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kconfig: fix segv fault in menuconfigSam Ravnborg
With specific configurations requesting help for certain menu lines caused menuconfig to crash. This was tracked down to a null pointer bug. Thanks to "Miles Lane" <miles.lane@gmail.com> for inital reporting and to Gabriel C <nix.or.die@googlemail.com> for the backtrace that helped me locating the bug. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kconfig: make comments stand out in menuconfigSam Ravnborg
Matěj Laitl <strohel@gmail.com> noticed that there was no way to distingush between comments and un-selectable menu lines. This patch marks comments with *** comment *** Cc: Matěj Laitl <strohel@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: fix directory traversal bugSam Ravnborg
Previously kbuild choked over the following: obj-y += ../../../arch/i386/kernel/bootflag.o This has resulted in some rather ugly workarounds in current x86_64 tree. This patch fixes kbuild to allow the above and enable potential cleanups in x86_64 and maybe in other places. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12docproc: style & typo cleanupsRandy Dunlap
- fix typos/spellos in docproc.c and Makefile - add a little whitespace {while, switch} (coding style) - use NULL instead of 0 for pointer testing Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: apply genksyms changesSam Ravnborg
This patch updates the _shipped files for genksyms. See previous patch for actual functional changes. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: __extension__ support in genksyms (fix unknown CRC warning)Sam Ravnborg
Recently the __extension__ keyword has been introduced in the kernel. Teach genksyms about this keyword so it can generate correct CRC for exported symbols that uses a symbol marked __extension__. For now only the typedef variant: __extension__ typedef ... is supported. Later we may add more variants as needed. This patch contains the actual source file changes. The following patch will hold modifications to the generated files (*_shipped) and only after the second patch the fix has effect. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: fix genksyms MakefileSam Ravnborg
When enabling GENERATE_PARSER the genksyms Makefile failed to create _shipped version of generated files. Modifying keywords.gperf failed to cause a rebuild of genksyms. Fixed by specifying keywowrds .c as explicit prerequisite of the lexer. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: scripts/ver_linux : correct printing of binutils versionJesper Juhl
Currently scripts/ver_linux prints "Binutils" or other random information for the version number in the "binutils" output line on some distributions. This patch corrects that. When I initially submitted a patch to correct that, I was not aware that the output from "ld -v" could differ as much as it turned out it can, so my original fix turned out to not cover all bases. This patch works correctly with all the different "ld -v" output that people posted in replys to my first patch, so it should be a clear win over what we have currently. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: ver_linux fix glibc version printJesper Juhl
Fix ver_linux glibc version printing (for real this time) Alexey Dobriyan reported that commit 4a645d5ea65baaa5736bcb566673bf4a351b2ad8 broke ver_linux when glibc has a 3 digit version number, and proposed a patch. Al Viro then suggested a simpler way to solve the problem which I've then simply put into patch form. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Al Viro <viro@ftp.linux.org.uk> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: improve scripts/gcc-version.sh output a bit when called without argsJesper Juhl
Currently, if you call scripts/gcc-version.sh without arguments it will generate this output : $ sh scripts/gcc-version.sh scripts/gcc-version.sh: line 12: [: =: unary operator expected scripts/gcc-version.sh: line 16: -E: command not found scripts/gcc-version.sh: line 17: -E: command not found 0000 Not too pretty. I believe this is an improvement : $ sh scripts/gcc-version.sh Error: No compiler specified. Usage: scripts/gcc-version.sh <gcc-command> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: fix segfault in modpostPetr Stetiar
Fix modpost segfault. Before: ------- ynezz@ntbk:~/linux-2.6.git$ scripts/mod/modpost vmlinux ath_pci.o Segmentation fault After: ------ ynezz@ntbk:~/linux-2.6.git$ scripts/mod/modpost vmlinux ath_pci.o FATAL: section header offset=815726848 in file 'ath_pci.o' is bigger then filesize=153968 Sam: This seems to warn for a binutils issue. Anyway modpost should not segfault. Signed-off-by: Petr Stetiar <ynezz@true.cz> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: fix perl usage in export_report.plRam Pai
Fixes some subtle perl coding bug observed by Jan Engelhardt <jengelh@computergmbh.de> This patch applies on top of Adrian's fix. Signed-off-by: Ram Pai <linuxram@us.ibm.com> Acked-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: fix export_report.plAdrian Bunk
This patch fixes an annoying bug of export_report.pl missing the usages of some exports. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: script to check for undefined Kconfig symbolsPaolo 'Blaisorblade' Giarrusso
To avoid having to look manually for used but undefined Kconfig variables, I've written a script which tries do this efficiently, in case all other attention fail. It accounts for _MODULE suffix and for UML_ prefixes to Kconfig variable, but otherwise looks for exact matches (i.e. \<CONFIG_; this is done to exclude macros like MMCONFIG_). Undefined Kconfig variables should be not be removed without care, but for instance arch/i386/boot/ uses a bunch of undefined Kconfig vars: $ scripts/checkunknowndefines.sh arch/i386/boot/ arch/i386/boot/video.h uses undefined symbol VIDEO_400_HACK arch/i386/boot/video-vga.c uses undefined symbol VIDEO_400_HACK arch/i386/boot/video.c uses undefined symbol VIDEO_RETAIN arch/i386/boot/video.h uses undefined symbol VIDEO_RETAIN arch/i386/boot/video.h uses undefined symbol VIDEO_SVGA arch/i386/boot/video.h uses undefined symbol VIDEO_VESA arch/i386/boot/video-vesa.c uses undefined symbol VIDEO_VESA It should also be mentioned in SubmittingPatches and SubmitChecklist. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: check if we can link gettext not just compileSam Ravnborg
cygwin provides the header file but the lib file needs to be added manually. A generic fix is to check if we can compile and link a program that uses gettext() and if it fails fall back to NO_NLS. International users of cygwin may have to specify HOST_LOADLIBES := "-lintl" on the make command line. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: Use Elfnn_Half as replacement for Elfnn_SectionSam Ravnborg
The Elfnn_Section is not available on all platforms, noteworthy are cygwin. Use the safe replacement _Half. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-11Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (867 commits) [SKY2]: status polling loop (post merge) [NET]: Fix NAPI completion handling in some drivers. [TCP]: Limit processing lost_retrans loop to work-to-do cases [TCP]: Fix lost_retrans loop vs fastpath problems [TCP]: No need to re-count fackets_out/sacked_out at RTO [TCP]: Extract tcp_match_queue_to_sack from sacktag code [TCP]: Kill almost unused variable pcount from sacktag [TCP]: Fix mark_head_lost to ignore R-bit when trying to mark L [TCP]: Add bytes_acked (ABC) clearing to FRTO too [IPv6]: Update setsockopt(IPV6_MULTICAST_IF) to support RFC 3493, try2 [NETFILTER]: x_tables: add missing ip6t_modulename aliases [NETFILTER]: nf_conntrack_tcp: fix connection reopening [QETH]: fix qeth_main.c [NETLINK]: fib_frontend build fixes [IPv6]: Export userland ND options through netlink (RDNSS support) [9P]: build fix with !CONFIG_SYSCTL [NET]: Fix dev_put() and dev_hold() comments [NET]: make netlink user -> kernel interface synchronious [NET]: unify netlink kernel socket recognition [NET]: cleanup 3rd argument in netlink_sendskb ... Fix up conflicts manually in Documentation/feature-removal-schedule.txt and my new least favourite crap, the "mod_devicetable" support in the files include/linux/mod_devicetable.h and scripts/mod/file2alias.c. (The latter files seem to be explicitly _designed_ to get conflicts when different subsystems work with them - that have an absolutely horrid lack of subsystem separation!) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/hskinnemoen/avr32-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/hskinnemoen/avr32-2.6: [AVR32] Fix random segfault with preemption [AVR32] Don't use __builtin_xchg() [AVR32] ngw100 i2c-gpio tweaks [AVR32] Ignore a few irrelevant syscalls [AVR32] SMC configuration in clock cycles [AVR32] Drop support for redundant "keepinitrd" boot-time parm. [AVR32] Make dma_sync_*_for_cpu no-ops [AVR32] Remove unneeded 8K alignment of .text section [AVR32] Kill a few hardcoded constants in vmlinux.lds [AVR32] rename vmlinux.lds [AVR32] fix command line parsing in early_parse_fbmem [AVR32] checkstack support [AVR32] Wire up USBA device [AVR32] add multidrive support for pio driver [AVR32] /sys/kernel/debug/at32ap_clk [AVR32] Move AT32_PM_BASE definition into pm.h
git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc: (67 commits) mmc: don't use weight32() pxamci: support arbitrary block size sdio: make the IRQ thread more resilient in the presence of bad states sdio: fix IRQ diagnostic message sdhci: remove old dma module params sdhci: add SDHCI_QUIRK_BROKEN_DMA quirk sdhci: remove DMA capability check from controller's PCI Class reg sdhci: fix a typo mmc: Disabler for Ricoh MMC controller sdio: adaptive interrupt polling mmc: pxamci: add SDIO card interrupt reporting capability mmc: pxamci: set proper buswidth capabilities according to PXA flavor mmc: pxamci: set proper block capabilities according to PXA flavor mmc: pxamci: better pending IRQ determination arm: i.MX/MX1 SDHC implements SD cards read-only switch read-back mmc: add led trigger mmc_spi host driver MMC core learns about SPI MMC/SD card driver learns SPI MMC headers learn about SPI ...
2007-10-11x86: fixup the x86 namespace change in scripts/namespace.plThomas Gleixner
Let namespace.pl look at the correct files. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-11[AVR32] checkstack supportHaavard Skinnemoen
Add regexes to recognize stack frame adjustments in AVR32 code. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-10-11i386/x86_64: move headers to include/asm-x86Thomas Gleixner
Move the headers to include/asm-x86 and fixup the header install make rules Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-10[NETNS]: Move some code into __init section when CONFIG_NET_NS=nPavel Emelyanov
With the net namespaces many code leaved the __init section, thus making the kernel occupy more memory than it did before. Since we have a config option that prohibits the namespace creation, the functions that initialize/finalize some netns stuff are simply not needed and can be freed after the boot. Currently, this is almost not noticeable, since few calls are no longer in __init, but when the namespaces will be merged it will be possible to free more code. I propose to use the __net_init, __net_exit and __net_initdata "attributes" for functions/variables that are not used if the CONFIG_NET_NS is not set to save more space in memory. The exiting functions cannot just reside in the __exit section, as noticed by David, since the init section will have references on it and the compilation will fail due to modpost checks. These references can exist, since the init namespace never dies and the exit callbacks are never called. So I introduce the __exit_refok attribute just like it is already done with the __init_refok. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[SSB]: add Sonics Silicon Backplane bus supportMichael Buesch
SSB is an SoC bus used in a number of embedded devices. The most well-known of these devices is probably the Linksys WRT54G, but there are others as well. The bus is also used internally on the BCM43xx and BCM44xx devices from Broadcom. This patch also includes support for SSB ID tables in modules, so that SSB drivers can be loaded automatically. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-23sdio: add modalias supportPierre Ossman
Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-09-01kconfig: oldconfig shall not set symbols if it does not need toRoman Zippel
Avoid setting the value if the symbol doesn't need to be changed or can't be changed. Later choices may change the dependencies and thus the possible input range. make oldconfig from a 2.6.22 .config with CONFIG_HOTPLUG_CPU not set was in some configurations setting CONFIG_HOTPLUG_CPU=y without asking, even when there was no actual requirement for CONFIG_HOTPLUG_CPU. This was triggered by SUSPEND_SMP that does a select HOTPLUG_CPU. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Tested-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-08-11update checkpatch.pl to version 0.09Andy Whitcroft
This version brings a number of new checks, and a number of bug fixes. Of note: - checks for spacing on round and square bracket combinations - loosening of the single statement brace checks, to allow them when they contain comments or where other blocks in a compound statement have them. - parks the multple declaration support - allows architecture defines in architecture specific headers Andy Whitcroft (21): Version: 0.09 loosen single statement brace checks fix up multiple declaration to avoid function arguments add some function space parenthesis check exceptions handle EXPORT_'s with parentheses in their names clean up some warnings in multi-line macro bracketing support park the multiple declaration checks make block brace checks count comments as a statement __volatile__ and __extension__ are not functions allow architecture specific defined within architecture includes check spacing on square brackets check spacing on parentheses ensure we apply checks to the part before start comment check #ifdef conditional spacing handle __init_refok and __must_check add noinline to inline checks prevent email addresses from tripping spacing checks handle typed initialiser spacing handle line contination as end of line add bool to the type matcher refine EXPORT_SYMBOL checks to handle pointers Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31kbuild: whitelist references from __dbe_table to .initRalf Baechle
This is needed on MIPS where the same mechanism as get_user() is used to intercept bus error exceptions for some hardware probes. Without this patch modpost will throw spurious warnings: LD vmlinux SYSMAP System.map SYSMAP .tmp_System.map MODPOST vmlinux WARNING: arch/mips/sgi-ip22/built-in.o(__dbe_table+0x0): Section mismatch: reference to .init.text: Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-25kbuild: fix modpost warnings for xtensaSam Ravnborg
The Xtensa architecture places literal pools in sections separate from the instructions. The corresponsing text sections, therefore, reference the .literal section, and we have to suppress those warnings. The naming convention defines the name for a literal section as .SECTION.literal, unless .SECTION is .text. In that case the name is only .literal. Using strncmp() instead of strcmp() to compare the from-section with .SECTION.init.refok in pattern 0 should not cause any regressions for other architectures. We also need to suppress warnings for two informational sections (.xt.lit and .xt.prop) used by the Xtensa architecture. Signed-off-by: Chris Zankel <chris@zankel.net> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-25kbuild: be more foregiving on init section namingSam Ravnborg
In the whitelist function of modpost now use the same check to identify init_section as in other places of modpost. This has the effect that we now recognize sections named .init.text.19 as init sections and we no longer warn when we see these. At the same time make surrounding code readable by dropping use of temporary flags. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-25kbuild: rearrange a few function in modpostSam Ravnborg
This is a preparational patch that just move two functions and add one (for now unused) function. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
