path: root/scripts
2008-10-14tracing/fastboot: fix bootgraph.pl initcall name regexpArnaud Patard
The regexp used to match the start and the end of an initcall are matching only on [a-zA-Z\_]. This rules out initcalls with a number in them. This patch is fixing that. Signed-off-by: Arnaud Patard <apatard@mandriva.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-14tracing/fastboot: fix issues and improve output of bootgraph.plArjan van de Ven
David Sanders reported some issues with bootgraph.pl's display of his sytems bootup; this commit fixes these by scaling the graph not from 0 - end time but from the first initcall to the end time; the minimum display size etc also now need to scale with this, as does the axis display. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
2008-10-14tracing/fastboot: fix initcalls disposition in bootgraph.plFrederic Weisbecker
When bootgraph.pl parses a file, it gives one row for each initcall's pid. But only few of them will be displayed => the longest. This patch corrects it by giving only a rows for pids which have initcalls that will be displayed. [ mingo@elte.hu: resolved conflicts ] Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-14tracing/fastboot: add a script to visualize the kernel boot process / timeArjan van de Ven
When optimizing the kernel boot time, it's very valuable to visualize what is going on at which time. In addition, with the fastboot asynchronous initcall level, it's very valuable to see which initcall gets run where and when. This patch adds a script to turn a dmesg into a SVG graph (that can be shown with tools such as InkScape, Gimp or Firefox) and a small change to the initcall code to print the PID of the thread calling the initcall (so that the script can work out the parallelism). Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
2008-10-14ftrace: remove warning of old objcopy and local functionsSteven Rostedt
The warning messages about old objcopy and local functions spam the user quite drastically. Remove the warning until we can find a nicer way of tell the user to upgrade their objcopy. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-14kbuild: ftrace: don't assume that scripts/recordmcount.pl is executableAndrew Morton
CHK include/linux/version.h CHK include/linux/utsrelease.h CC scripts/mod/empty.o /bin/sh: /usr/src/25/scripts/recordmcount.pl: Permission denied We shouldn't assume that files have their `x' bits set. There are various ways in which file permissions get lost, including use of patch(1). It might not be correct to assume that perl lives in $PATH? Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-14ftrace: objcopy version test for local symbolsSteven Rostedt
The --globalize-symbols option came out in objcopy version 2.17. If the kernel is being compiled on a system with a lower version of objcopy, then we can not use the globalize / localize trick to link to symbols pointing to local functions. This patch tests the version of objcopy and will only use the trick if the version is greater than or equal to 2.17. Otherwise, if an object has only local functions within a section, it will give a nice warning and recommend the user to upgrade their objcopy. Leaving the symbols unrecorded is not that big of a deal, since the mcount record method changes the actual mcount code to be a simple "ret" without recording registers or anything. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-14ftrace: handle weak symbol functionsSteven Rostedt
During tests and checks, I've discovered that there were failures to convert mcount callers into nops. Looking deeper into these failures, code that was attempted to be changed was not an mcount caller. The current code only updates if the code being changed is what it expects, but I still investigate any time there is a failure. What was happening is that a weak symbol was being used as a reference for other mcount callers. That weak symbol was also referenced elsewhere so the offsets were using the strong symbol and not the function symbol that it was referenced from. This patch changes the setting up of the mcount_loc section to search for a global function that is not weak. It will pick a local over a weak but if only a weak is found in a section, a warning is printed and the mcount location is not recorded (just to be safe). Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-14ftrace: update recordmount.pl arch changesSteven Rostedt
I'm trying to keep all the arch changes in recordmcount.pl in one place. I moved your code into that area, by adding the flags to the commands that were passed in. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-14ftrace: fix build problem with CONFIG_FTRACEJeremy Fitzhardinge
I'm seeing when I use separate src/build dirs: make[3]: *** [arch/x86/kernel/time_32.o] Error 1 /bin/sh: scripts/recordmcount.pl: No such file or directory make[3]: *** [arch/x86/kernel/irq_32.o] Error 1 /bin/sh: scripts/recordmcount.pl: No such file or directory make[3]: *** [arch/x86/kernel/ldt.o] Error 1 /bin/sh: scripts/recordmcount.pl: No such file or directory make[3]: *** [arch/x86/kernel/i8259.o] Error 1 /bin/sh: scripts/recordmcount.pl: No such file or directory This fixes it. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-14ftrace: scripts/recordmcount.pl cross-build hackIngo Molnar
hack around: ld: Relocatable linking with relocations from format elf32-i386 (init/.tmp_gl_calibrate.o) to format elf64-x86-64 (init/.tmp_mx_calibrate.o) i CC arch/x86/mm/extable.o objcopy: 'init/.tmp_mx_calibrate.o': No such file rm: cannot remove `init/.tmp_mx_calibrate.o': No such file or directory ld: Relocatable linking with relocations from format elf32-i386 (arch/x86/mm/extable.o) to format elf64-x86-64 (arch/x86/mm/.tmp_mx_extable.o) is not supported mv: cannot stat `arch/x86/mm/.tmp_mx_extable.o': No such file or directory ld: Relocatable linking with relocations from format elf32-i386 (arch/x86/mm/fault.o) to format elf64-x86-64 (arch/x86/mm/.tmp_mx_fault.o) is not supported Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-14ftrace: create __mcount_loc sectionSteven Rostedt
This patch creates a section in the kernel called "__mcount_loc". This will hold a list of pointers to the mcount relocation for each call site of mcount. For example: objdump -dr init/main.o [...] Disassembly of section .text: 0000000000000000 <do_one_initcall>: 0: 55 push %rbp [...] 000000000000017b <init_post>: 17b: 55 push %rbp 17c: 48 89 e5 mov %rsp,%rbp 17f: 53 push %rbx 180: 48 83 ec 08 sub $0x8,%rsp 184: e8 00 00 00 00 callq 189 <init_post+0xe> 185: R_X86_64_PC32 mcount+0xfffffffffffffffc [...] We will add a section to point to each function call. .section __mcount_loc,"a",@progbits [...] .quad .text + 0x185 [...] The offset to of the mcount call site in init_post is an offset from the start of the section, and not the start of the function init_post. The mcount relocation is at the call site 0x185 from the start of the .text section. .text + 0x185 == init_post + 0xa We need a way to add this __mcount_loc section in a way that we do not lose the relocations after final link. The .text section here will be attached to all other .text sections after final link and the offsets will be meaningless. We need to keep track of where these .text sections are. To do this, we use the start of the first function in the section. do_one_initcall. We can make a tmp.s file with this function as a reference to the start of the .text section. .section __mcount_loc,"a",@progbits [...] .quad do_one_initcall + 0x185 [...] Then we can compile the tmp.s into a tmp.o gcc -c tmp.s -o tmp.o And link it into back into main.o. ld -r main.o tmp.o -o tmp_main.o mv tmp_main.o main.o But we have a problem. What happens if the first function in a section is not exported, and is a static function. The linker will not let the tmp.o use it. This case exists in main.o as well. Disassembly of section .init.text: 0000000000000000 <set_reset_devices>: 0: 55 push %rbp 1: 48 89 e5 mov %rsp,%rbp 4: e8 00 00 00 00 callq 9 <set_reset_devices+0x9> 5: R_X86_64_PC32 mcount+0xfffffffffffffffc The first function in .init.text is a static function. 00000000000000a8 t __setup_set_reset_devices 000000000000105f t __setup_str_set_reset_devices 0000000000000000 t set_reset_devices The lowercase 't' means that set_reset_devices is local and is not exported. If we simply try to link the tmp.o with the set_reset_devices we end up with two symbols: one local and one global. .section __mcount_loc,"a",@progbits .quad set_reset_devices + 0x10 00000000000000a8 t __setup_set_reset_devices 000000000000105f t __setup_str_set_reset_devices 0000000000000000 t set_reset_devices U set_reset_devices We still have an undefined reference to set_reset_devices, and if we try to compile the kernel, we will end up with an undefined reference to set_reset_devices, or even worst, it could be exported someplace else, and then we will have a reference to the wrong location. To handle this case, we make an intermediate step using objcopy. We convert set_reset_devices into a global exported symbol before linking it with tmp.o and set it back afterwards. 00000000000000a8 t __setup_set_reset_devices 000000000000105f t __setup_str_set_reset_devices 0000000000000000 T set_reset_devices 00000000000000a8 t __setup_set_reset_devices 000000000000105f t __setup_str_set_reset_devices 0000000000000000 T set_reset_devices 00000000000000a8 t __setup_set_reset_devices 000000000000105f t __setup_str_set_reset_devices 0000000000000000 t set_reset_devices Now we have a section in main.o called __mcount_loc that we can place somewhere in the kernel using vmlinux.ld.S and access it to convert all these locations that call mcount into nops before starting SMP and thus, eliminating the need to do this with kstop_machine. Note, A well documented perl script (scripts/recordmcount.pl) is used to do all this in one location. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-12Merge branches 'x86/xen', 'x86/build', 'x86/microcode', 'x86/mm-debug-v2', ↵Ingo Molnar
'x86/memory-corruption-check', 'x86/early-printk', 'x86/xsave', 'x86/ptrace-v2', 'x86/quirks', 'x86/setup', 'x86/spinlocks' and 'x86/signal' into x86/core-v2
2008-10-11Merge branch 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: (27 commits) [S390] Fix checkstack for s390 [S390] fix initialization of stp [S390] 3215: Remove tasklet. [S390] console flush on panic / reboot [S390] introduce dirty bit for kvm live migration [S390] Add ioctl support for EMC Symmetrix Subsystem Control I/O [S390] xpram: per device block request queues. [S390] dasd: fix message flood for unsolicited interrupts [S390] Move private simple udelay function to arch/s390/lib/delay.c. [S390] dcssblk: add >2G DCSSs support and stacked contiguous DCSSs support. [S390] ptrace changes [S390] s390: use sys_pause for 31bit pause entry point [S390] qdio enhanced SIGA (iqdio) support. [S390] cio: fix cio_tpi. [S390] cio: Correct use of ! and & [S390] cio: inline assembly cleanup [S390] bus_id -> dev_set_name() for css and ccw busses [S390] bus_id ->dev_name() conversions in qdio [S390] Use s390_root_dev_* in kvm_virtio. [S390] more bus_id -> dev_name conversions ...
2008-10-10[S390] Fix checkstack for s390Christian Borntraeger
With -march=z990 and later gcc can use the long displacement facility insruction lay for stack register handling. This patch adopts checkstack to catch lay in addition to ahi and aghi. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-10-10Merge branch 'next' into for-linusJames Morris
2008-10-06Marker depmod fix core kernel listMathieu Desnoyers
* Theodore Ts'o (tytso@mit.edu) wrote: > > I've been playing with adding some markers into ext4 to see if they > could be useful in solving some problems along with Systemtap. It > appears, though, that as of 2.6.27-rc8, markers defined in code which is > compiled directly into the kernel (i.e., not as modules) don't show up > in Module.markers: > > kvm_trace_entryexit arch/x86/kvm/kvm-intel %u %p %u %u %u %u %u %u > kvm_trace_handler arch/x86/kvm/kvm-intel %u %p %u %u %u %u %u %u > kvm_trace_entryexit arch/x86/kvm/kvm-amd %u %p %u %u %u %u %u %u > kvm_trace_handler arch/x86/kvm/kvm-amd %u %p %u %u %u %u %u %u > > (Note the lack of any of the kernel_sched_* markers, and the markers I > added for ext4_* and jbd2_* are missing as wel.) > > Systemtap apparently depends on in-kernel trace_mark being recorded in > Module.markers, and apparently it's been claimed that it used to be > there. Is this a bug in systemtap, or in how Module.markers is getting > built? And is there a file that contains the equivalent information > for markers located in non-modules code? I think the problem comes from "markers: fix duplicate modpost entry" (commit d35cb360c29956510b2fe1a953bd4968536f7216) Especially : - add_marker(mod, marker, fmt); + if (!mod->skip) + add_marker(mod, marker, fmt); } return; fail: Here is a fix that should take care if this problem. Thanks for the bug report! Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Tested-by: "Theodore Ts'o" <tytso@mit.edu> CC: Greg KH <greg@kroah.com> CC: David Smith <dsmith@redhat.com> CC: Roland McGrath <roland@redhat.com> CC: Sam Ravnborg <sam@ravnborg.org> CC: Wenji Huang <wenji.huang@oracle.com> CC: Takashi Nishiie <t-nishiie@np.css.fujitsu.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-29kconfig: readd lost change countzippel@linux-m68k.org
Commit f072181e6403b0fe2e2aa800a005497b748fd284 ("kconfig: drop the ""trying to assign nonexistent symbol" warning") simply dropped the warnings, but it does a little more than that, it also marks the current .config as needed saving, so add this back. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-29kconfig: fix silentoldconfigzippel@linux-m68k.org
Recent changes to oldconfig have mixed up the silentoldconfig handling, so this fixes that by clearly separating that special mode, e.g. KCONFIG_NOSILENTUPDATE is only relevant here, the .config is written as needed. This will also properly close Bug 11230. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-23kernel-doc: allow structs whose members are all privateRandy Dunlap
Struct members may be marked as private by using /* private: */ before them, as noted in Documentation/kernel-doc-nano-HOWTO.txt Fix kernel-doc to handle structs whose members are all private; otherwise invalid XML is generated: xmlto: input does not validate (status 3) linux-2.6.27-rc6-git4/Documentation/DocBook/debugobjects.xml:146: element variablelist: validity error : Element variablelist content does not follow the DTD, expecting ((title , titleabbrev?)? , varlistentry+), got () Document linux-2.6.27-rc6-git4/Documentation/DocBook/debugobjects.xml does not validate make[1]: *** [Documentation/DocBook/debugobjects.html] Error 3 Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Reported-by: Roland McGrath <roland@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-09kbuild: fix cc-option and cc-option-ynH. Peter Anvin
David Sanders wrote: > I'm getting this error: > as: unrecognized option `-mtune=generic32' > I have binutils 2.17. Use -c instead of -S in cc-option and cc-option-yn, so we can probe options related to the assembler. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: kbuild devel <kbuild-devel@lists.sourceforge.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-05SELinux: add gitignore file for mdp scriptJames Morris
Add gitignore file for scripts/selinux/mdp/mdp. Signed-off-by: James Morris <jmorris@namei.org>
2008-08-28Merge branch 'master' into nextJames Morris
2008-08-27selinux: add support for installing a dummy policy (v2)Serge E. Hallyn
In August 2006 I posted a patch generating a minimal SELinux policy. This week, David P. Quigley posted an updated version of that as a patch against the kernel. It also had nice logic for auto-installing the policy. Following is David's original patch intro (preserved especially bc it has stats on the generated policies): se interested in the changes there were only two significant changes. The first is that the iteration through the list of classes used NULL as a sentinel value. The problem with this is that the class_to_string array actually has NULL entries in its table as place holders for the user space object classes. The second change was that it would seem at some point the initial sids table was NULL terminated. This is no longer the case so that iteration has to be done on array length instead of looking for NULL. Some statistics on the policy that it generates: The policy consists of 523 lines which contain no blank lines. Of those 523 lines 453 of them are class, permission, and initial sid definitions. These lines are usually little to no concern to the policy developer since they will not be adding object classes or permissions. Of the remaining 70 lines there is one type, one role, and one user statement. The remaining lines are broken into three portions. The first group are TE allow rules which make up 29 of the remaining lines, the second is assignment of labels to the initial sids which consist of 27 lines, and file system labeling statements which are the remaining 11. In addition to the policy.conf generated there is a single file_contexts file containing two lines which labels the entire system with base_t. This policy generates a policy.23 binary that is 7920 bytes. (then a few versions later...): The new policy is 587 lines (stripped of blank lines) with 476 of those lines being the boilerplate that I mentioned last time. The remaining 111 lines have the 3 lines for type, user, and role, 70 lines for the allow rules (one for each object class including user space object classes), 27 lines to assign types to the initial sids, and 11 lines for file system labeling. The policy binary is 9194 bytes. Changelog: Aug 26: Added Documentation/SELinux.txt Aug 26: Incorporated a set of comments by Stephen Smalley: 1. auto-setup SELINUXTYPE=dummy 2. don't auto-install if selinux is enabled with non-dummy policy 3. don't re-compute policy version 4. /sbin/setfiles not /usr/sbin/setfiles Aug 22: As per JMorris comments, made sure make distclean cleans up the mdp directory. Removed a check for file_contexts which is now created in the same file as the check, making it superfluous. Signed-off-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: David Quigley <dpquigl@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2008-08-21pnp: fix "add acpi:* modalias entries"Kay Sievers
With 22454cb99fc39f2629ad06a7eccb3df312f8830e we added only the first entry of the device table. We need to loop over the whole device list. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-06bugfix for scripts/patch-kernel in 2.6 sublevel steppingErkki Lintunen
scripts/patch-kernel script can't patch a tree, say, from 2.6.25 to 2.6.26.1, because of a wrong comparison in context of patching 2.6.x base. Fix it. Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-08-05kernel-doc: skip nested struct/union cleanlyRandy Dunlap
Fix handling of nested structs or unions. The regex to strip (eliminate) nested structs or unions was limited to only 0 or 1 matches. This can cause an uneven number of left/right braces to be stripped, which causes this: Warning(linux-2.6.27-rc1-git2//include/net/mac80211.h:336): No description found for parameter '}' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixesLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes: kconfig: drop the ""trying to assign nonexistent symbol" warning kconfig: always write out .config
2008-08-04kconfig: drop the ""trying to assign nonexistent symbol" warningSam Ravnborg
They really stand out now that make *config is less chatty - and they are generally ignored - so drop them. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Adrian Bunk <bunk@kernel.org>
2008-08-04kconfig: always write out .configSam Ravnborg
Always write out .config also in the case where config did not change. This fixes: http://bugzilla.kernel.org/show_bug.cgi?id=11230 Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Josh Boyer <jwboyer@linux.vnet.ibm.com> Cc: Adrian Bunk <bunk@kernel.org>
2008-08-02firmware: silence __fw_modbuild and __fw_modinst 'Nothing to be done' messagesDavid Woodhouse
People don't like them and think they're errors. Leave the __fw_install one though; when 'make firmware_install' does nothing, it's best to have a 'Nothing to be done for...' message rather than just doing nothing. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-31kbuild: scripts/ver_linux: don't set PATHAdrian Bunk
It would have saved both a bug submitter and me a few hours if scripts/ver_linux had picked the same gcc as the build. Since I can't see any reason why it fiddles with PATH at all this patch therefore removes the PATH setting. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-31kbuild: genksyms: Include extern information in dumpsAndreas Gruenbacher
The extern flag currently is not included in type dump files (genksyms --dump-types). Include that flag there for completeness. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-31kbuild: genksyms parser: fix the __attribute__ ruleAndreas Gruenbacher
We are having two kinds of problems with genksyms today: fake checksum changes without actual ABI changes, and changes which we would rather like to ignore (such as an additional field at the end of a structure that modules are not supposed to touch, for example). I have thought about ways to improve genksyms and compute checksums differently to avoid those problems, but in the end I don't see a fundamentally better way. So here are some genksyms patches for at least making the checksums more easily manageable, if we cannot fully fix them. In addition to the bugfixes (the first two patches), this allows genksyms to track checksum changes and report why a checksum changed (third patch), and to selectively ignore changes (fourth patch). This patch: Gcc __attribute__ definitions may occur repeatedly, e.g., static int foo __attribute__((__used__)) __attribute__((aligned (16))); The genksyms parser does not understand this, and generates a syntax error. Fix this case. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-30kbuild: scripts/genksyms/lex.l: add %option noinputAdrian Bunk
gcc 4.3 correctly determines that input() is unused and gives the following warning: <-- snip --> ... HOSTCC scripts/genksyms/lex.o scripts/genksyms/lex.c:1487: warning: ‘input’ defined but not used ... <-- snip --> Fix it by adding %option noinput to scripts/genksyms/lex.l and regeneration of scripts/genksyms/lex.c_shipped. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-30kconfig: scripts/kconfig/zconf.l: add %option noinputAdrian Bunk
gcc 4.3 correctly determines that input() is unused and gives the following warning: <-- snip --> ... HOSTCC scripts/kconfig/zconf.tab.o scripts/kconfig/lex.zconf.c:1628: warning: ‘input’ defined but not used ... <-- snip --> Fix it by adding %option noinput to scripts/kconfig/zconf.l and regeneration of scripts/kconfig/lex.zconf.c_shipped. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-30scripts/mod/modpost.c: fix spelling of module and happensBen Dooks
Spelling fixes in scripts/mod/modpost.c Signed-off-by: Ben Dooks <ben-linux@fluff.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (25 commits) setlocalversion: do not describe if there is nothing to describe kconfig: fix typos: "Suport" -> "Support" kconfig: make defconfig is no longer chatty kconfig: make oldconfig is now less chatty kconfig: speed up all*config + randconfig kconfig: set all new symbols automatically kconfig: add diffconfig utility kbuild: remove Module.markers during mrproper kbuild: sparse needs CF not CHECKFLAGS kernel-doc: handle/strip __init vmlinux.lds: move __attribute__((__cold__)) functions back into final .text section init: fix URL of "The GNU Accounting Utilities" kbuild: add arch/$ARCH/include to search path kbuild: asm symlink support for arch/$ARCH/include kbuild: support arch/$ARCH/include for tags, cscope kbuild: prepare headers_* for arch/$ARCH/include kbuild: install all headers when arch is changed kbuild: make clean removes *.o.* as well kbuild: optimize headers_* targets kbuild: only one call for include/ in make headers_* ...
2008-07-25setlocalversion: do not describe if there is nothing to describeSebastian Siewior
Jan Engelhardt wrote: > Just a note that when you run git-describe, you should probably quiten it. > > fatal: cannot describe 'bd7364a0fd5a4a2878fe4a224be1b142a4e6698e' > > This happens when tags are not present, which can happen if Linus's tree > is sent upwards again, IOW: > > machine1$ git-clone torvalds/linux-2.6.git > machine1$ git push elsewhere master > > machine2$ git-clone elsewhere:/linux > machine2$ git-describe HEAD > fatal: cannot describe that Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Acked-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-25kconfig: make defconfig is no longer chattySam Ravnborg
make defconfig generated a lot of output then noone actually read. Use conf_set_all_new_symbols() to generate the default configuration and avoid the chatty output. A typical run now looks like this: $ make defconfig *** Default configuration is based on 'i386_defconfig' arch/x86/configs/i386_defconfig:13:warning: trying to assign nonexistent symbol SEMAPHORE_SLEEPERS arch/x86/configs/i386_defconfig:176:warning: trying to assign nonexistent symbol PREEMPT_BKL ... arch/x86/configs/i386_defconfig:1386:warning: trying to assign nonexistent symbol INSTRUMENTATION $ As an added benefit we now clearly see the warnings generated in the start of the process. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2008-07-25kconfig: make oldconfig is now less chattySam Ravnborg
Previously when running "make oldconfig" we saw all the propmt lines from kconfig and noone actully read this. With this patch the user will only see output if there is new symbols. This will be seen as "make oldconfig" runs which does not generate any output. A typical run now looks like this: $ make oldconfig scripts/kconfig/conf -o arch/x86/Kconfig $ If a new symbol is found then we restart the config process like this: $ make oldconfig scripts/kconfig/conf -o arch/x86/Kconfig * * Restart config... * * * General setup * Prompt for development and/or incomplete code/drivers (EXPERIMENTAL) [Y/n/?] y Local version - append to kernel release (LOCALVERSION) [] ... The bahaviour is similar to what we know when running the implicit oldconfig target "make silentoldconfig". "make silentoldconfig" are run as part of the kernel build process if the configuration has changed. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2008-07-25kconfig: speed up all*config + randconfigSam Ravnborg
Drop the chatty mode when we generate the all*config, randconfig configurations. Ths speeds up the process considerably and noone looked at the output anyway. This patch uses the conf_set_all_new_symbols() function just added to kconfig. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2008-07-25kconfig: set all new symbols automaticallyRoman Zippel
Add conf_set_all_new_symbols() which set all symbols (which don't have a value yet) to a specifed value. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-25kconfig: add diffconfig utilityTim Bird
Diffconfig is a simple utility for comparing two kernel configuration files. See usage in the script for more info. Signed-off-by: Tim Bird <tim.bird@am.sony.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-25kernel-doc: handle/strip __initRandy Dunlap
Handle __init in functions with kernel-doc notation by stripping the __init away from the output doc. This is already being done for "__devinit". This patch fixes these kernel-doc error/aborts: Error(linux-next-20080619//drivers/usb/gadget/config.c:132): cannot understand prototype: 'struct usb_descriptor_header **__init usb_copy_descriptors(struct usb_descriptor_header **src) ' Error(linux-next-20080619//drivers/usb/gadget/config.c:182): cannot understand prototype: 'struct usb_endpoint_descriptor *__init usb_find_endpoint( struct usb_descriptor_header **src, struct usb_descriptor_header **copy, struct usb_endpoint_descriptor *match ) ' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-25kbuild: prepare headers_* for arch/$ARCH/includeSam Ravnborg
Factor out the headers_*_all support to a seperate shell script and add support for arch specific header files can be located in either arch/$ARCH/include/asm or include/asm-$ARCH/ In "make help" always display the headers_* targets. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-25kbuild: install all headers when arch is changedSam Ravnborg
We see some header files that are selected dependent on the actual architecture so force a reinstallation of all header files when the arch changes. This slows down "make headers_check_all" but then we better reflect reality. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-25kbuild: optimize headers_* targetsSam Ravnborg
Move the core functionality of headers_install and headers_check to two small perl scripts. The makefile is adapted to use the perl scrip and changed to operate on all files in a directory. So if one file is changed then all files in the directory is processed. perl were chosen for the helper scripts because this is pure text processing which perl is good at and especially the headers_check.pl script are expected to see changes / new checks implmented. The speed is ~300% faster on this box. And the output generated to the screen is now down to two lines per directory (one for install, one for check) so it is easier to scroll back after a kernel build. The perl scripts has been brought to sanity by patient feedback from: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-25kbuild: only one call for include/ in make headers_*Sam Ravnborg
Move it to the top-level file to decide if we install/check the generic headers or the arch specific headers. This revealed a long standing bug where "make headers_check_all" relied on the files in asm/ for the current architecture. So make headers_check_all is now broken by this commit. In addition: o add a simpler way to detect if an arch support exporting header files. o add 'set -e;' so we error out early if make headers_check_all fails. o add sparc64 and cris to arch we do not process in make headers_*_all because: sparc64 - use sparc to export headers cris - is know seriously broken Includes suggestions from: David Woodhouse <dwmw2@infradead.org>. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: David Woodhouse <dwmw2@infradead.org>
2008-07-25kbuild: code refactoring in Makefile.headerinstSam Ravnborg
No functional changes just improved readability Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
