Some .gitignore files have comments like "Generated files",
"Ignore generated files" at the header part, but they are
too obvious.
Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild
Pull Kbuild fixes from Masahiro Yamada:
- fix __uint128_t capability test in Kconfig when GCC that defaults to
32-bit is used to build the 64-bit kernel
- suppress new noisy Clang warnings -Wpointer-to-enum-cast
- move the namespace field in Module.symvers for the backward
compatibility reason for the depmod tool
- use available compression for initramdisk when INTRAMFS_SOURCE is
defined, which was the original behavior
- fix modpost to handle correct large section numbers when it refers to
modversion CRCs and module namespaces
- fix comments and documents
* tag 'kbuild-fixes-v5.6-3' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild:
scripts/kallsyms: fix wrong kallsyms_relative_base
modpost: Get proper section index by get_secindex() instead of st_shndx
initramfs: restore default compression behavior
modpost: move the namespace field in Module.symvers last
kbuild: Disable -Wpointer-to-enum-cast
kbuild: doc: fix references to other documents
int128: fix __uint128_t compiler test in Kconfig
kconfig: introduce m32-flag and m64-flag
kbuild: Fix inconsistent comment
There is the code in the read_symbol function in 'scripts/kallsyms.c':
if (is_ignored_symbol(name, type))
return NULL;
/* Ignore most absolute/undefined (?) symbols. */
if (strcmp(name, "_text") == 0)
_text = addr;
But the is_ignored_symbol function returns true for name="_text" and
type='A'. So the next condition is not executed and the _text variable
is always zero.
It makes the wrong kallsyms_relative_base symbol as a result of the code
(CONFIG_KALLSYMS_BASE_RELATIVE is defined):
if (base_relative) {
output_label("kallsyms_relative_base");
output_address(relative_base);
printf("\n");
Because the output_address function uses the _text variable.
So the kallsyms_lookup function and all related functions in the kernel
do not work properly. For example, the stack trace in oops:
Call Trace:
[aa095e58] [809feab8] kobj_ns_ops_tbl+0x7ff09ac8/0x7ff1c1c4 (unreliable)
[aa095e98] [80002b64] kobj_ns_ops_tbl+0x7f50db74/0x80000010
[aa095ef8] [809c3d24] kobj_ns_ops_tbl+0x7feced34/0x7ff1c1c4
[aa095f28] [80002ed0] kobj_ns_ops_tbl+0x7f50dee0/0x80000010
[aa095f38] [8000f238] kobj_ns_ops_tbl+0x7f51a248/0x80000010
The right stack trace:
Call Trace:
[aa095e58] [809feab8] module_vdu_video_init+0x2fc/0x3bc (unreliable)
[aa095e98] [80002b64] do_one_initcall+0x40/0x1f0
[aa095ef8] [809c3d24] kernel_init_freeable+0x164/0x1d8
[aa095f28] [80002ed0] kernel_init+0x14/0x124
[aa095f38] [8000f238] ret_from_kernel_thread+0x14/0x1c
[masahiroy@kernel.org:
This issue happens on binutils <= 2.22
The following commit fixed it:
https://sourceware.org/git/?p=binutils-gdb.git;a=commit;h=d2667025dd30611514810c28bee9709e4623012a
The symbol type of _text is 'T' on binutils >= 2.23
The minimal supported binutils version for the kernel build is 2.21
Signed-off-by: Mikhail Petrov <Mikhail.Petrov@mir.dev>
(uint16_t) st_shndx is limited to 65535(i.e. SHN_XINDEX) so sym_get_data() gets
wrong section index by st_shndx if requested symbol contains extended section
index that is more than 65535. In this case, we need to get proper section index
by .symtab_shndx section.
Module.symvers generated by building kernel with "-ffunction-sections -fdata-sections"
shows the issue.
Fixes: 56067812d5b0 ("kbuild: modversions: add infrastructure for emitting relative CRCs")
Fixes: e84f9fbbece1 ("modpost: refactor namespace_from_kstrtabns() to not hard-code section name")
Signed-off-by: Xiao Yang <yangx.jy@cn.fujitsu.com>
In order to preserve backwards compatability with kmod tools, we have to
move the namespace field in Module.symvers last, as the depmod -e -E
option looks at the first three fields in Module.symvers to check symbol
versions (and it's expected they stay in the original order of crc,
symbol, module).
In addition, update an ancient comment above read_dump() in modpost that
suggested that the export type field in Module.symvers was optional. I
suspect that there were historical reasons behind that comment that are
no longer accurate. We have been unconditionally printing the export
type since 2.6.18 (commit bd5cbcedf44), which is over a decade ago now.
Fix up read_dump() to treat each field as non-optional. I suspect the
original read_dump() code treated the export field as optional in order
to support pre <= 2.6.18 Module.symvers (which did not have the export
type field). Note that although symbol namespaces are optional, the
field will not be omitted from Module.symvers if a symbol does not have
a namespace. In this case, the field will simply be empty and the next
delimiter or end of line will follow.
Cc: stable@vger.kernel.org
Fixes: cb9b55d21fe0 ("modpost: add support for symbol namespaces")
Tested-by: Matthias Maennich <maennich@google.com>
Reviewed-by: Matthias Maennich <maennich@google.com>
Reviewed-by: Lucas De Marchi <lucas.demarchi@intel.com>
Signed-off-by: Jessica Yu <jeyu@kernel.org>
Clang's -Wpointer-to-int-cast deviates from GCC in that it warns when
casting to enums. The kernel does this in certain places, such as device
tree matches to set the version of the device being used, which allows
the kernel to avoid using a gigantic union.
https://elixir.bootlin.com/linux/v5.5.8/source/drivers/ata/ahci_brcm.c#L428
https://elixir.bootlin.com/linux/v5.5.8/source/drivers/ata/ahci_brcm.c#L402
https://elixir.bootlin.com/linux/v5.5.8/source/include/linux/mod_devicetable.h#L264
To avoid a ton of false positive warnings, disable this particular part
of the warning, which has been split off into a separate diagnostic so
that the entire warning does not need to be turned off for clang. It
will be visible under W=1 in case people want to go about fixing these
easily and enabling the warning treewide.
Link: https://github.com/ClangBuiltLinux/linux/issues/887
Link: https://github.com/llvm/llvm-project/commit/2a41b31fcdfcb67ab7038fc2ffb606fd50b83a84
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
When a compiler supports multiple architectures, some compiler features
can be dependent on the target architecture.
This is typical for Clang, which supports multiple LLVM backends.
Even for GCC, we need to take care of biarch compiler cases.
It is not a problem when we evaluate cc-option in Makefiles because
cc-option is tested against the flag in question + $(KBUILD_CFLAGS).
The cc-option in Kconfig, on the other hand, does not accumulate
tested flags. Due to this simplification, it could potentially test
cc-option against a different target.
At first, Kconfig always evaluated cc-option against the host
architecture.
Since commit e8de12fb7cde ("kbuild: Check for unknown options with
cc-option usage in Kconfig and clang"), in case of cross-compiling
with Clang, the target triple is correctly passed to Kconfig.
The case with biarch GCC (and native build with Clang) is still not
handled properly. We need to pass some flags to specify the target
machine bit.
Due to the design, all the macros in Kconfig are expanded in the
parse stage, where we do not know the target bit size yet.
For example, arch/x86/Kconfig allows a user to toggle CONFIG_64BIT.
If a compiler flag -foo depends on the machine bit, it must be tested
twice, one with -m32 and the other with -m64.
However, -m32/-m64 are not always recognized. So, this commits adds
m64-flag and m32-flag macros. They expand to -m32, -m64, respectively
if supported. Or, they expand to an empty string if unsupported.
The typical usage is like this:
config FOO
bool
default $(cc-option,$(m64-flag) -foo) if 64BIT
default $(cc-option,$(m32-flag) -foo)
This is clumsy, but there is no elegant way to handle this in the
current static macro expansion.
There was discussion for static functions vs dynamic functions.
The consensus was to go as far as possible with the static functions.
(https://lkml.org/lkml/2018/3/2/22)
Tested-by: George Spelvin <lkml@sdf.org>
Reviewed-by: Nathan Chancellor <natechancellor@gmail.com>
This makes the script more convenient to run.
Signed-off-by: Jonathan Neuschäfer <j.neuschaefer@gmx.net>
This trailing semicolon is unneeded.
Acked-by: Rob Herring <robh@kernel.org>
This if_change_rule is not working properly; it cannot detect any
command line change.
The reason is because cmd-check in scripts/Kbuild.include compares
$(cmd_$@) and $(cmd_$1), but cmd_dtc_dt_yaml does not exist here.
For if_change_rule to work properly, the stem part of cmd_* and rule_*
must match. Because this cmd_and_fixdep invokes cmd_dtc, this rule must
be named rule_dtc.
Fixes: 4f0e3a57d6eb ("kbuild: Add support for DT binding schema checks")
Recently, I found that get_maintainer was causing me to send emails to
the old addresses for maintainers. Since I usually just trust the
output of get_maintainer to know the right email address, I didn't even
look carefully and fired off two patch series that went to the wrong
place. Oops.
The problem was introduced recently when trying to add signatures from
Fixes. The problem was that these email addresses were added too early
in the process of compiling our list of places to send. Things added to
the list earlier are considered more canonical and when we later added
maintainer entries we ended up deduplicating to the old address.
Here are two examples using mainline commits (to make it easier to
replicate) for the two maintainers that I messed up recently:
$ git format-patch d8549bcd0529~..d8549bcd0529
$ ./scripts/get_maintainer.pl 0001-clk-Add-clk_hw*.patch | grep Boyd
Stephen Boyd <sboyd@codeaurora.org>...
$ git format-patch 6d1238aa3395~..6d1238aa3395
$ ./scripts/get_maintainer.pl 0001-arm64-dts-qcom-qcs404*.patch | grep Andy
Andy Gross <andy.gross@linaro.org>
Let's move the adding of addresses from Fixes: to the end since the
email addresses from these are much more likely to be older.
After this patch the above examples get the right addresses for the two
examples.
Link: http://lkml.kernel.org/r/20200127095001.1.I41fba9f33590bfd92cd01960161d8384268c6569@changeid
Fixes: 2f5bd343694e ("scripts/get_maintainer.pl: add signatures from Fixes: <badcommit> lines in commit message")
Signed-off-by: Douglas Anderson <dianders@chromium.org>
Acked-by: Joe Perches <joe@perches.com>
Cc: Stephen Boyd <sboyd@kernel.org>
Cc: Bjorn Andersson <bjorn.andersson@linaro.org>
Cc: Andy Gross <agross@kernel.org>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Commit 1ca84ed6425f ("MAINTAINERS: Reclaim the P: tag for Maintainer
Entry Profile") changed the use of the "P:" tag from "Person" to
"Profile (ie: special subsystem coding styles and characteristics)"
Change how get_maintainer.pl parses the "P:" tag to match.
Link: http://lkml.kernel.org/r/ca53823fc5d25c0be32ad937d0207a0589c08643.camel@perches.com
Acked-by: Dan Williams <dan.j.william@intel.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Since commit 56d589361572 ("kbuild: do not create orphan built-in.a or
obj-y objects"), scripts/link-vmlinux.sh does nothing when descending
into init/.
Once the version number becomes out of sync between .version and
include/generated/compile.h, it is not self-healing.
[How to reproduce]
$ echo 100 > .version
$ make
You will see the number in the .version is always bigger than that in
compile.h by one. After this, every time you run 'make', the vmlinux is
re-linked even when none of source files is updated.
Fixes: 56d589361572 ("kbuild: do not create orphan built-in.a or obj-y objects")
memcpy() writes one more byte than allocated.
Fixes: 8d60526999aa ("scripts/kallsyms: change table to store (strcut sym_entry *)")
Reported-by: youling257 <youling257@gmail.com>
Reported-by: Pavel Machek <pavel@ucw.cz>
Tested-by: Pavel Machek <pavel@ucw.cz>
Pull more Kbuild updates from Masahiro Yamada:
- fix randconfig to generate a sane .config
- rename hostprogs-y / always to hostprogs / always-y, which are more
natual syntax.
- optimize scripts/kallsyms
- fix yes2modconfig and mod2yesconfig
- make multiple directory targets ('make foo/ bar/') work
* tag 'kbuild-v5.6-2' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild:
kbuild: make multiple directory targets work
kconfig: Invalidate all symbols after changing to y or m.
kallsyms: fix type of kallsyms_token_table[]
scripts/kallsyms: rename local variables in read_symbol()
kbuild: rename hostprogs-y/always to hostprogs/always-y
kbuild: fix the document to use extra-y for vmlinux.lds
kconfig: fix broken dependency in randconfig-generated .config
Pull Documentation fixes from Jonathan Corbet:
"A handful of small documentation fixes that wandered in"
* tag 'docs-5.6-2' of git://git.lwn.net/linux:
Allow git builds of Sphinx
Documentation: changes.rst: update several outdated project URLs
Documentation: build warnings related to missing blank lines after explicit markups has been fixed
mailmap: add entry for Tiezhu Yang
Documentation/ko_KR/howto: Update a broken link
Documentation/ko_KR/howto: Update broken web addresses
docs/locking: Fix outdated section names
When using a non-release version of Sphinx, from a local build (with
improvements for kernel doc handling, why not),
sphinx-build --version
reports versions of the form
sphinx-build 3.0.0+/4703d9119972
i.e. base version, a plus symbol, slash, and the start of the git hash
of whatever repository the command is run in (no, not the hash that
was used to build Sphinx!).
This patch fixes the installation check in sphinx-pre-install to
recognise such version output.
Signed-off-by: Stephen Kitt <steve@sk2.org>
Link: https://lore.kernel.org/r/20200124183316.1719218-1-steve@sk2.org
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
Since commit 89b9060987d9 ("kconfig: Add yes2modconfig and
mod2yesconfig targets.") forgot to clear SYMBOL_VALID bit after
changing to y or m, these targets did not save the changes.
Call sym_clear_all_valid() so that all symbols are revalidated.
Fixes: 89b9060987d9 ("kconfig: Add yes2modconfig and mod2yesconfig targets.")
Since 5.5-rc1 the last user of this function is gone, so remove the
functionality.
See commit
2ad9d7747c10 ("netfilter: conntrack: free extension area immediately")
for details.
Link: http://lkml.kernel.org/r/20191212223442.22141-1-fw@strlen.de
Acked-by: Andrew Morton <akpm@linux-foundation.org>
Acked-by: David Rientjes <rientjes@google.com>
Reviewed-by: David Hildenbrand <david@redhat.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
The symbol table is extended every 10000 addition by using realloc(),
where data copy might occur to the new buffer.
To decrease the amount of possible data copy, let's change the table
to store the pointer.
The symbol type + symbol name part is appended at the end of
(struct sym_entry), and allocated together with the struct body.
I will use 'sym' for the point to struce sym_entry in the next commit.
Rename 'sym', 'stype' to 'name', 'type', which are more intuitive.
In old days, the "host-progs" syntax was used for specifying host
programs. It was renamed to the current "hostprogs-y" in 2004.
It is typically useful in scripts/Makefile because it allows Kbuild to
selectively compile host programs based on the kernel configuration.
This commit renames like follows:
always -> always-y
hostprogs-y -> hostprogs
So, scripts/Makefile will look like this:
always-$(CONFIG_BUILD_BIN2C) += ...
always-$(CONFIG_KALLSYMS) += ...
hostprogs := $(always-y) $(always-m)
I think this makes more sense because a host program is always a host
program, irrespective of the kernel configuration. We want to specify
which ones to compile by CONFIG options, so always-y will be handier.
The "always", "hostprogs-y", "hostprogs-m" will be kept for backward
compatibility for a while.
Running randconfig on arm64 using KCONFIG_SEED=0x40C5E904 (e.g. on v5.5)
produces the .config with CONFIG_EFI=y and CONFIG_CPU_BIG_ENDIAN=y,
which does not meet the !CONFIG_CPU_BIG_ENDIAN dependency.
This is because the user choice for CONFIG_CPU_LITTLE_ENDIAN vs
CONFIG_CPU_BIG_ENDIAN is set by randomize_choice_values() after the
value of CONFIG_EFI is calculated.
When this happens, the has_changed flag should be set.
Currently, it takes the result from the last iteration. It should
accumulate all the results of the loop.
Fixes: 3b9a19e08960 ("kconfig: loop as long as we changed some symbols in randconfig")
Reported-by: Vincenzo Frascino <vincenzo.frascino@arm.com>
Pull Kconfig updates from Masahiro Yamada:
- add 'yes2modconfig' and 'mod2yesconfig' targets (useful mainly for
turning syzbot configs into more modular ones as a step to minimizing
the result)
- sanitize help text
- various code cleanups
* tag 'kconfig-v5.6' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild:
kconfig: fix documentation typos
kconfig: fix an "implicit declaration of function" warning
kconfig: fix nesting of symbol help text
kconfig: distinguish between dependencies and visibility in help text
kconfig: list all definitions of a symbol in help text
kconfig: use $(PERL) in Makefile
kconfig: fix too deep indentation in Makefile
kconfig: localmodconfig: fix indentation for closing brace
kconfig: localmodconfig: remove unused $config
kconfig: squash prop_alloc() into menu_add_prop()
kconfig: remove sym from struct property
kconfig: remove 'prompt' argument from menu_add_prop()
kconfig: move prompt handling to menu_add_prompt() from menu_add_prop()
kconfig: remove 'prompt' symbol
kconfig: drop T_WORD from the RHS of 'prompt' symbol
kconfig: use parent->dep as the parentdep of 'menu'
kconfig: remove the rootmenu check in menu_add_prop()
Pull Kbuild updates from Masahiro Yamada:
- detect missing include guard in UAPI headers
- do not create orphan built-in.a or obj-y objects
- generate modules.builtin more simply, and drop tristate.conf
- simplify built-in initramfs creation
- make linux-headers deb package thinner
- optimize the deb package build script
- misc cleanups
* tag 'kbuild-v5.6' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild: (34 commits)
builddeb: split libc headers deployment out into a function
builddeb: split kernel headers deployment out into a function
builddeb: remove redundant make for ARCH=um
builddeb: avoid invoking sub-shells where possible
builddeb: remove redundant $objtree/
builddeb: match temporary directory name to the package name
builddeb: remove unneeded files in hdrobjfiles for headers package
kbuild: use -S instead of -E for precise cc-option test in Kconfig
builddeb: allow selection of .deb compressor
kbuild: remove 'Building modules, stage 2.' log
kbuild: remove *.tmp file when filechk fails
kbuild: remove PYTHON2 variable
modpost: assume STT_SPARC_REGISTER is defined
gen_initramfs.sh: remove intermediate cpio_list on errors
initramfs: refactor the initramfs build rules
gen_initramfs.sh: always output cpio even without -o option
initramfs: add default_cpio_list, and delete -d option support
initramfs: generate dependency list and cpio at the same time
initramfs: specify $(src)/gen_initramfs.sh as a prerequisite in Makefile
initramfs: make initramfs compression choice non-optional
Pull updates from Andrew Morton:
"Most of -mm and quite a number of other subsystems: hotfixes, scripts,
ocfs2, misc, lib, binfmt, init, reiserfs, exec, dma-mapping, kcov.
MM is fairly quiet this time. Holidays, I assume"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (118 commits)
kcov: ignore fault-inject and stacktrace
include/linux/io-mapping.h-mapping: use PHYS_PFN() macro in io_mapping_map_atomic_wc()
execve: warn if process starts with executable stack
reiserfs: prevent NULL pointer dereference in reiserfs_insert_item()
init/main.c: fix misleading "This architecture does not have kernel memory protection" message
init/main.c: fix quoted value handling in unknown_bootoption
init/main.c: remove unnecessary repair_env_string in do_initcall_level
init/main.c: log arguments and environment passed to init
fs/binfmt_elf.c: coredump: allow process with empty address space to coredump
fs/binfmt_elf.c: coredump: delete duplicated overflow check
fs/binfmt_elf.c: coredump: allocate core ELF header on stack
fs/binfmt_elf.c: make BAD_ADDR() unlikely
fs/binfmt_elf.c: better codegen around current->mm
fs/binfmt_elf.c: don't copy ELF header around
fs/binfmt_elf.c: fix ->start_code calculation
fs/binfmt_elf.c: smaller code generation around auxv vector fill
lib/find_bit.c: uninline helper _find_next_bit()
lib/find_bit.c: join _find_next_bit{_le}
uapi: rename ext2_swab() to swab() and share globally in swab.h
lib/scatterlist.c: adjust indentation in __sg_alloc_table
Add "issus" and correct it as "issues".
Link: http://lkml.kernel.org/r/20200105221950.8384-1-luca@lucaceresoli.net
Signed-off-by: Luca Ceresoli <luca@lucaceresoli.net>
Here are some of the common spelling mistakes and typos that I've found
while fixing up spelling mistakes in the kernel. Most of them still
exist in more than two source files.
Link: http://lkml.kernel.org/r/20191229143626.51238-1-xndchn@gmail.com
Signed-off-by: Xiong <xndchn@gmail.com>
Cc: Colin Ian King <colin.king@canonical.com>
Cc: Paul Walmsley <paul.walmsley@sifive.com>
Cc: Chris Paterson <chris.paterson2@renesas.com>
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull devicetree updates from Rob Herring:
- Update dtc to upstream v1.5.1-22-gc40aeb60b47a (plus 1 revert)
- Fix for DMA coherent devices on Power
- Rework and simplify the DT phandle cache code
- DT schema conversions for LEDS, gpio-leds, STM32 dfsdm, STM32 UART,
STM32 ROMEM, STM32 watchdog, STM32 DMAs, STM32 mlahb, STM32 RTC,
STM32 RCC, STM32 syscon, rs485, Renesas rCar CSI2, Faraday FTIDE010,
DWC2, Arm idle-states, Allwinner legacy resets, PRCM and clocks,
Allwinner H6 OPP, Allwinner AHCI, Allwinner MBUS, Allwinner A31 CSI,
Allwinner h/w codec, Allwinner A10 system ctrl, Allwinner SRAM,
Allwinner USB PHY, Renesas CEU, generic PCI host, Arm Versatile PCI
- New binding schemas for SATA and PATA controllers, TI and Infineon VR
controllers, MAX31730
- New compatible strings for i.MX8QM, WCN3991, renesas,r8a77961-wdt,
renesas,etheravb-r8a77961
- Add USB 'super-speed-plus' as a documented speed
- Vendor prefixes for broadmobi, calaosystems, kam, and mps
- Clean-up the multiple flavors of ST-Ericsson vendor prefixes
* tag 'devicetree-for-5.6' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (66 commits)
scripts/dtc: Revert "yamltree: Ensure consistent bracketing of properties with phandles"
of: Add OF_DMA_DEFAULT_COHERENT & select it on powerpc
dt-bindings: leds: Convert gpio-leds to DT schema
dt-bindings: leds: Convert common LED binding to schema
dt-bindings: PCI: Convert generic host binding to DT schema
dt-bindings: PCI: Convert Arm Versatile binding to DT schema
dt-bindings: Be explicit about installing deps
dt-bindings: stm32: convert dfsdm to json-schema
dt-bindings: serial: Convert STM32 UART to json-schema
dt-bindings: serial: Convert rs485 bindings to json-schema
dt-bindings: timer: Use non-empty ranges in example
dt-bindings: arm-boards: typo fix
dt-bindings: Add TI and Infineon VR Controllers as trivial devices
dt-binding: usb: add "super-speed-plus"
dt-bindings: rcar-csi2: Convert bindings to json-schema
dt-bindings: iio: adc: ad7606: Fix wrong maxItems value
dt-bindings: Convert Faraday FTIDE010 to DT schema
dt-bindings: Create DT bindings for PATA controllers
dt-bindings: Create DT bindings for SATA controllers
dt: bindings: add vendor prefix for Kamstrup A/S
Pull documentation updates from Jonathan Corbet:
"It has been a relatively quiet cycle for documentation, but there's
still a couple of things of note:
- Conversion of the NFS documentation to RST
- A new document on how to help with documentation (and a maintainer
profile entry too)
Plus the usual collection of typo fixes, etc"
* tag 'docs-5.6' of git://git.lwn.net/linux: (40 commits)
docs: filesystems: add overlayfs to index.rst
docs: usb: remove some broken references
scripts/find-unused-docs: Fix massive false positives
docs: nvdimm: use ReST notation for subsection
zram: correct documentation about sysfs node of huge page writeback
Documentation: zram: various fixes in zram.rst
Add a maintainer entry profile for documentation
Add a document on how to contribute to the documentation
docs: Keep up with the location of NoUri
Documentation: Call out example SYM_FUNC_* usage as x86-specific
Documentation: nfs: fault_injection: convert to ReST
Documentation: nfs: pnfs-scsi-server: convert to ReST
Documentation: nfs: convert pnfs-block-server to ReST
Documentation: nfs: idmapper: convert to ReST
Documentation: convert nfsd-admin-interfaces to ReST
Documentation: nfs-rdma: convert to ReST
Documentation: nfsroot.rst: COSMETIC: refill a paragraph
Documentation: nfsroot.txt: convert to ReST
Documentation: convert nfs.txt to ReST
Documentation: filesystems: convert vfat.txt to RST
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial driver updates from Greg KH:
"Here are the big set of tty and serial driver updates for 5.6-rc1
Included in here are:
- dummy_con cleanups (touches lots of arch code)
- sysrq logic cleanups (touches lots of serial drivers)
- samsung driver fixes (wasn't really being built)
- conmakeshash move to tty subdir out of scripts
- lots of small tty/serial driver updates
All of these have been in linux-next for a while with no reported
issues"
* tag 'tty-5.6-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (140 commits)
tty: n_hdlc: Use flexible-array member and struct_size() helper
tty: baudrate: SPARC supports few more baud rates
tty: baudrate: Synchronise baud_table[] and baud_bits[]
tty: serial: meson_uart: Add support for kernel debugger
serial: imx: fix a race condition in receive path
serial: 8250_bcm2835aux: Document struct bcm2835aux_data
serial: 8250_bcm2835aux: Use generic remapping code
serial: 8250_bcm2835aux: Allocate uart_8250_port on stack
serial: 8250_bcm2835aux: Suppress register_port error on -EPROBE_DEFER
serial: 8250_bcm2835aux: Suppress clk_get error on -EPROBE_DEFER
serial: 8250_bcm2835aux: Fix line mismatch on driver unbind
serial_core: Remove unused member in uart_port
vt: Correct comment documenting do_take_over_console()
vt: Delete comment referencing non-existent unbind_con_driver()
arch/xtensa/setup: Drop dummy_con initialization
arch/x86/setup: Drop dummy_con initialization
arch/unicore32/setup: Drop dummy_con initialization
arch/sparc/setup: Drop dummy_con initialization
arch/sh/setup: Drop dummy_con initialization
arch/s390/setup: Drop dummy_con initialization
Pull networking updates from David Miller:
1) Add WireGuard
2) Add HE and TWT support to ath11k driver, from John Crispin.
3) Add ESP in TCP encapsulation support, from Sabrina Dubroca.
4) Add variable window congestion control to TIPC, from Jon Maloy.
5) Add BCM84881 PHY driver, from Russell King.
6) Start adding netlink support for ethtool operations, from Michal
Kubecek.
7) Add XDP drop and TX action support to ena driver, from Sameeh
Jubran.
8) Add new ipv4 route notifications so that mlxsw driver does not have
to handle identical routes itself. From Ido Schimmel.
9) Add BPF dynamic program extensions, from Alexei Starovoitov.
10) Support RX and TX timestamping in igc, from Vinicius Costa Gomes.
11) Add support for macsec HW offloading, from Antoine Tenart.
12) Add initial support for MPTCP protocol, from Christoph Paasch,
Matthieu Baerts, Florian Westphal, Peter Krystad, and many others.
13) Add Octeontx2 PF support, from Sunil Goutham, Geetha sowjanya, Linu
Cherian, and others.
* git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net-next: (1469 commits)
net: phy: add default ARCH_BCM_IPROC for MDIO_BCM_IPROC
udp: segment looped gso packets correctly
netem: change mailing list
qed: FW 8.42.2.0 debug features
qed: rt init valid initialization changed
qed: Debug feature: ilt and mdump
qed: FW 8.42.2.0 Add fw overlay feature
qed: FW 8.42.2.0 HSI changes
qed: FW 8.42.2.0 iscsi/fcoe changes
qed: Add abstraction for different hsi values per chip
qed: FW 8.42.2.0 Additional ll2 type
qed: Use dmae to write to widebus registers in fw_funcs
qed: FW 8.42.2.0 Parser offsets modified
qed: FW 8.42.2.0 Queue Manager changes
qed: FW 8.42.2.0 Expose new registers and change windows
qed: FW 8.42.2.0 Internal ram offsets modifications
MAINTAINERS: Add entry for Marvell OcteonTX2 Physical Function driver
Documentation: net: octeontx2: Add RVU HW and drivers overview
octeontx2-pf: ethtool RSS config support
octeontx2-pf: Add basic ethtool support
Deploy user-space headers (linux-libc-dev package) in a separate
function for readability.
Deploy kernel headers (linux-headers package) in a separate function
for readability.
The kernel build has already been done before builddeb is invoked.
The commands surrounded by ( ... ) is run in a sub-shell, but you do
not have to spawn a sub-shell for every single line.
Use just one ( ... ) for creating debian/hdrsrcfiles.
For tar, use -C option instead.
This script works only when it is invoked in the $objtree, that is,
it is already relying on $objtree is '.'
The temporary directory names, debian/hdrtmp (linux-headers package)
vs debian/headertmp (linux-libc-dev package), are confusing.
Matching the directory name to the package name is clearer, IMHO.
- We do not need tools/objtool/fixdep or tools/objtool/sync-check.sh
for building external modules. Including tools/objtool/objtool is
enough.
- gcc-common.h is a check-in file. I do not see any point to search
for it in objtree.
Pull objtool updates from Ingo Molnar:
"The main changes are to move the ORC unwind table sorting from early
init to build-time - this speeds up booting.
No change in functionality intended"
* 'core-objtool-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/unwind/orc: Fix !CONFIG_MODULES build warning
x86/unwind/orc: Remove boot-time ORC unwind tables sorting
scripts/sorttable: Implement build-time ORC unwind table sorting
scripts/sorttable: Rename 'sortextable' to 'sorttable'
scripts/sortextable: Refactor the do_func() function
scripts/sortextable: Remove dead code
scripts/sortextable: Clean up the code to meet the kernel coding style better
scripts/sortextable: Rewrite error/success handling
with phandles"
This reverts upstream commit 18d7b2f4ee45fec422b7d82bab0b3c762ee907e4. A
revert in upstream dtc is pending.
This commit didn't work for properties such as 'interrupt-map' that have
phandle in the middle of an entry. It would also not work for a 0 or -1
phandle value that acts as a NULL.
Signed-off-by: Rob Herring <robh@kernel.org>
scripts/find-unused-docs.sh invokes scripts/kernel-doc to find out if a
source file contains kerneldoc or not.
However, as it passes the no longer supported "-text" option to
scripts/kernel-doc, the latter prints out its help text, causing all
files to be considered containing kerneldoc.
Get rid of these false positives by removing the no longer supported
"-text" option from the scripts/kernel-doc invocation.
Cc: stable@vger.kernel.org # 4.16+
Fixes: b05142675310d2ac ("scripts: kernel-doc: get rid of unused output formats")
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Link: https://lore.kernel.org/r/20200127093107.26401-1-geert+renesas@glider.be
Pull ioremap updates from Christoph Hellwig:
"Remove the ioremap_nocache API (plus wrappers) that are always
identical to ioremap"
* tag 'ioremap-5.6' of git://git.infradead.org/users/hch/ioremap:
remove ioremap_nocache and devm_ioremap_nocache
MIPS: define ioremap_nocache to ioremap
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 updates from Will Deacon:
"The changes are a real mixed bag this time around.
The only scary looking one from the diffstat is the uapi change to
asm-generic/mman-common.h, but this has been acked by Arnd and is
actually just adding a pair of comments in an attempt to prevent
allocation of some PROT values which tend to get used for
arch-specific purposes. We'll be using them for Branch Target
Identification (a CFI-like hardening feature), which is currently
under review on the mailing list.
New architecture features:
- Support for Armv8.5 E0PD, which benefits KASLR in the same way as
KPTI but without the overhead. This allows KPTI to be disabled on
CPUs that are not affected by Meltdown, even is KASLR is enabled.
- Initial support for the Armv8.5 RNG instructions, which claim to
provide access to a high bandwidth, cryptographically secure
hardware random number generator. As well as exposing these to
userspace, we also use them as part of the KASLR seed and to seed
the crng once all CPUs have come online.
- Advertise a bunch of new instructions to userspace, including
support for Data Gathering Hint, Matrix Multiply and 16-bit
floating point.
Kexec:
- Cleanups in preparation for relocating with the MMU enabled
- Support for loading crash dump kernels with kexec_file_load()
Perf and PMU drivers:
- Cleanups and non-critical fixes for a couple of system PMU drivers
FPU-less (aka broken) CPU support:
- Considerable fixes to support CPUs without the FP/SIMD extensions,
including their presence in heterogeneous systems. Good luck
finding a 64-bit userspace that handles this.
Modern assembly function annotations:
- Start migrating our use of ENTRY() and ENDPROC() over to the
new-fangled SYM_{CODE,FUNC}_{START,END} macros, which are intended
to aid debuggers
Kbuild:
- Cleanup detection of LSE support in the assembler by introducing
'as-instr'
- Remove compressed Image files when building clean targets
IP checksumming:
- Implement optimised IPv4 checksumming routine when hardware offload
is not in use. An IPv6 version is in the works, pending testing.
Hardware errata:
- Work around Cortex-A55 erratum #1530923
Shadow call stack:
- Work around some issues with Clang's integrated assembler not
liking our perfectly reasonable assembly code
- Avoid allocating the X18 register, so that it can be used to hold
the shadow call stack pointer in future
ACPI:
- Fix ID count checking in IORT code. This may regress broken
firmware that happened to work with the old implementation, in
which case we'll have to revert it and try something else
- Fix DAIF corruption on return from GHES handler with pseudo-NMIs
Miscellaneous:
- Whitelist some CPUs that are unaffected by Spectre-v2
- Reduce frequency of ASID rollover when KPTI is compiled in but
inactive
- Reserve a couple of arch-specific PROT flags that are already used
by Sparc and PowerPC and are planned for later use with BTI on
arm64
- Preparatory cleanup of our entry assembly code in preparation for
moving more of it into C later on
- Refactoring and cleanup"
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (73 commits)
arm64: acpi: fix DAIF manipulation with pNMI
arm64: kconfig: Fix alignment of E0PD help text
arm64: Use v8.5-RNG entropy for KASLR seed
arm64: Implement archrandom.h for ARMv8.5-RNG
arm64: kbuild: remove compressed images on 'make ARCH=arm64 (dist)clean'
arm64: entry: Avoid empty alternatives entries
arm64: Kconfig: select HAVE_FUTEX_CMPXCHG
arm64: csum: Fix pathological zero-length calls
arm64: entry: cleanup sp_el0 manipulation
arm64: entry: cleanup el0 svc handler naming
arm64: entry: mark all entry code as notrace
arm64: assembler: remove smp_dmb macro
arm64: assembler: remove inherit_daif macro
ACPI/IORT: Fix 'Number of IDs' handling in iort_id_map()
mm: Reserve asm-generic prot flags 0x10 and 0x20 for arch use
arm64: Use macros instead of hard-coded constants for MAIR_EL1
arm64: Add KRYO{3,4}XX CPU cores to spectre-v2 safe list
arm64: kernel: avoid x18 in __cpu_soft_restart
arm64: kvm: stop treating register x18 as caller save
arm64/lib: copy_page: avoid x18 register in assembler code
Minor conflict in mlx5 because changes happened to code that has
moved meanwhile.
Pull ARM fixes from Russell King:
- fix ftrace relocation type filtering
- relax arch timer version check
* tag 'for-linus' of git://git.armlinux.org.uk/~rmk/linux-arm:
ARM: 8955/1: virt: Relax arch timer version check during early boot
ARM: 8950/1: ftrace/recordmcount: filter relocation types
Alexei Starovoitov says:
pull-request: bpf-next 2020-01-22
The following pull-request contains BPF updates for your *net-next* tree.
We've added 92 non-merge commits during the last 16 day(s) which contain
a total of 320 files changed, 7532 insertions(+), 1448 deletions(-).
The main changes are:
1) function by function verification and program extensions from Alexei.
2) massive cleanup of selftests/bpf from Toke and Andrii.
3) batched bpf map operations from Brian and Yonghong.
4) tcp congestion control in bpf from Martin.
5) bulking for non-map xdp_redirect form Toke.
6) bpf_send_signal_thread helper from Yonghong.
When trying to compile with CONFIG_DEBUG_INFO_BTF enabled, I got this
error:
% make -s
Failed to generate BTF for vmlinux
Try to disable CONFIG_DEBUG_INFO_BTF
make[3]: *** [vmlinux] Error 1
Compiling again without -s shows the true error (that pahole is
missing), but since this is fatal, we should show the error
unconditionally on stderr as well, not silence it using the `info`
function. With this patch:
% make -s
BTF: .tmp_vmlinux.btf: pahole (pahole) is not available
Signed-off-by: Chris Down <chris@chrisdown.name>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Andrii Nakryiko <andriin@fb.com>
Link: https://lore.kernel.org/bpf/20200122000110.GA310073@chrisdown.name
Currently, -E (stop after the preprocessing stage) is used to check
whether the given compiler flag is supported.
While it is faster than -S (or -c), it can be false-positive. You need
to run the compilation proper to check the flag more precisely.
For example, -E and -S disagree about the support of
"--param asan-instrument-allocas=1".
$ gcc -Werror --param asan-instrument-allocas=1 -E -x c /dev/null -o /dev/null
$ echo $?
0
$ gcc -Werror --param asan-instrument-allocas=1 -S -x c /dev/null -o /dev/null
cc1: error: invalid --param name ‘asan-instrument-allocas’; did you mean ‘asan-instrument-writes’?
$ echo $?
1
Select deb compression using KDEB_COMPRESS make variable. This allows to
use gzip compression for local or test builds, and that's way faster
than now-default xz compression.
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
