path: root/scripts
2006-12-10[PATCH] kbuild: don't put temp files in sourceRoman Zippel
The as-instr/ld-option need to create temporary files, but create them in the output directory, when compiling external modules. Reformat them a bit and use $(CC) instead of $(AS) as the former is used by kbuild to assemble files. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Andi Kleen <ak@suse.de> Cc: Jan Beulich <jbeulich@novell.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: <jpdenheijer@gmail.com> Cc: Horst Schirmeier <horst@schirmeier.com> Cc: Daniel Drake <dsd@gentoo.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] move kallsyms data to .rodataJan Beulich
Kallsyms data is never written to, so it can as well benefit from CONFIG_DEBUG_RODATA. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07Merge branch 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6Linus Torvalds
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6: (156 commits) [PATCH] x86-64: Export smp_call_function_single [PATCH] i386: Clean up smp_tune_scheduling() [PATCH] unwinder: move .eh_frame to RODATA [PATCH] unwinder: fully support linker generated .eh_frame_hdr section [PATCH] x86-64: don't use set_irq_regs() [PATCH] x86-64: check vector in setup_ioapic_dest to verify if need setup_IO_APIC_irq [PATCH] x86-64: Make ix86 default to HIGHMEM4G instead of NOHIGHMEM [PATCH] i386: replace kmalloc+memset with kzalloc [PATCH] x86-64: remove remaining pc98 code [PATCH] x86-64: remove unused variable [PATCH] x86-64: Fix constraints in atomic_add_return() [PATCH] x86-64: fix asm constraints in i386 atomic_add_return [PATCH] x86-64: Correct documentation for bzImage protocol v2.05 [PATCH] x86-64: replace kmalloc+memset with kzalloc in MTRR code [PATCH] x86-64: Fix numaq build error [PATCH] x86-64: include/asm-x86_64/cpufeature.h isn't a userspace header [PATCH] unwinder: Add debugging output to the Dwarf2 unwinder [PATCH] x86-64: Clarify error message in GART code [PATCH] x86-64: Fix interrupt race in idle callback (3rd try) [PATCH] x86-64: Remove unwind stack pointer alignment forcing again ... Fixed conflict in include/linux/uaccess.h manually Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] kernel-doc: stricter function pointer recognitionRandy Dunlap
Be more careful about function pointer args: look for "(...*" instead of just "(". This line in include/linux/input.h fools the current kernel-doc script into deciding that this is a function pointer: unsigned long ffbit[NBITS(FF_MAX)]; Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] ver_linux additionsValdis Kletnieks
scripts/ver_linux needed some minor clean-ups, as follows: 1) Add reporting of actual oprofile release 2) Add reporting of actual wireless-tools release 3) Add reporting of actual pcmciautils release Signed-off-by: Valdis Kletnieks <valdis.kletnieks@vt.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] qconf: support old QTakpm@osdl.org
Might make qconf compilable with qt-3.1 as well as qt-3.3 Cc: greg chesson <xtp@google.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] relocatable kernel: Fix kallsyms on avr32 after relocatable kernel ↵Vivek Goyal
changes o On some platforms like avr32, section init comes before .text and not necessarily a symbol's relative position w.r.t _text is positive. In such cases assembler detects the overflow and emits warning. This patch fixes it. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: Andi Kleen <ak@suse.de> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Andrew Morton <akpm@osdl.org>
2006-12-07[PATCH] paravirt: Patch inline replacements for paravirt interceptsRusty Russell
It turns out that the most called ops, by several orders of magnitude, are the interrupt manipulation ops. These are obvious candidates for patching, so mark them up and create infrastructure for it. The method used is that the ops structure has a patch function, which is called for each place which needs to be patched: this returns a number of instructions (the rest are NOP-padded). Usually we can spare a register (%eax) for the binary patched code to use, but in a couple of critical places in entry.S we can't: we make the clobbers explicit at the call site, and manually clobber the allowed registers in debug mode as an extra check. And: Don't abuse CONFIG_DEBUG_KERNEL, add CONFIG_DEBUG_PARAVIRT. And: AK: Fix warnings in x86-64 alternative.c build And: AK: Fix compilation with defconfig And: ^From: Andrew Morton <akpm@osdl.org> Some binutlises still like to emit references to __stop_parainstructions and __start_parainstructions. And: AK: Fix warnings about unused variables when PARAVIRT is disabled. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Zachary Amsden <zach@vmware.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org>
2006-12-07[PATCH] relocatable kernel: Kallsyms generate relocatable symbolsEric W. Biederman
Print the addresses of non-absolute symbols relative to _text so that ld will generate relocations. Allowing a relocatable kernel to relocate them. We can't actually use the symbol names because kallsyms includes static symbols that are not exported from their object files. Add the _text symbol definitions to the architectures which don't define it otherwise linker will fail. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de>
2006-11-25[PATCH] fix menuconfig colours with TERM=vt100Roman Zippel
On Mon, 13 Nov 2006, Phil Oester wrote: > In commit 350b5b76384e77bcc58217f00455fdbec5cac594, the default menuconfig > color scheme was changed to bluetitle. This breaks the highlighting > of the selected item for me with TERM=vt100. The only way I can see > which item is selected is via: > > make MENUCONFIG_COLOR=mono menuconfig > > Which restores the pre-2.6.19 white on black highlighting. Fix. Cc: Phil Oester <kernel@linuxace.com> Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-25[PATCH] qconf: fix uninitialsied memberRoman Zippel
Fixes a segfault reported by Randy. Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-25[PATCH] initramfs: handle more than one source dir or file listThomas Chou
Fix bug 7401. Handle more than one source dir or file list to the initramfs gen scripts. The Kconfig help for INITRAMFS_SOURCE claims that you can specify multiple space-separated sources in order to allow unprivileged users to build an image. There are two bugs in the current implementation that prevent this from working. First, we pass "file1 dir2" to the gen_initramfs_list.sh script, which it obviously can't open. Second, gen_initramfs_list.sh -l outputs multiple definitions for deps_initramfs -- one for each argument. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-13[PATCH] .gitignore: add miscellaneous filesFranck Bui-Huu
Prevent git from reporting this useless status: On branch refs/heads/master Untracked files: (use "git add" to add to commit) TAGS scripts/kconfig/lkc_defs.h scripts/kconfig/qconf.moc nothing to commit Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-03[PATCH] update some docbook commentsRandy Dunlap
Correct a few comments in kernel-doc Doc and source files. (akpm: note: the patch removes a non-ascii character and might have to be applied by hand..) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-25[POWERPC] Support feature fixups in modulesBenjamin Herrenschmidt
This patch adds support for feature fixups in modules. This involves adding support for R_PPC64_REL64 relocs to the 64 bits module loader. It also modifies modpost.c to ignore the powerpc fixup sections (or it would warn when used in .init.text). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-17[PATCH] kbuild: allow multi-word $M in Makefile.modpostGreg Banks
Some people want to do crazy things like pass multiple directories as the value of $(SUBDIRS) or $M. Mostly this kinda works, except that Makefile.modpost constructs a modpost commandline which fails modpost's argument parsing. This patch fixes that little wrinkle. Signed-off-by: Greg Banks <gnb@melbourne.sgi.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-17[PATCH] fix `make headers_install'David Woodhouse
Fix this: make[3]: *** No rule to make target `/mnt/md0/devel/linux-git/include/linux/version.h', needed by `/mnt/md0/devel/linux-git-obj/usr/include/linux/version.h'. Stop. make[2]: *** [linux] Error 2 make[1]: *** [headers_install] Error 2 Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] kernel-doc: make parameter description indentation uniformRandy Dunlap
- In parameter descriptions, strip all whitespace between the parameter name (e.g., @len) and its description so that the description is indented uniformly in text and man page modes. Previously, spaces or tabs (which are used for cleaner source code viewing) affected the produced output in a negative way. Before (man mode): to Destination address, in user space. from Source address, in kernel space. n Number of bytes to copy. After (man mode): to Destination address, in user space. from Source address, in kernel space. n Number of bytes to copy. - Fix/clarify a few function description comments. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] kernel-doc: drop various "inline" qualifiersRandy Dunlap
Drop __inline, __always_inline, and noinline in the produced kernel-doc output, similar to other pseudo directives. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] Fix menuconfig build failure due to missing stdbool.hLuca Tettamanti
scripts/kconfig/lxdialog/util.c fails to build because it uses true/false without including stdbool.h: kronos:~/src/linux-2.6$ make O=../linux-build-git menuconfig GEN /home/kronos/src/linux-build/Makefile HOSTCC scripts/kconfig/lxdialog/util.o /home/kronos/src/linux-2.6/scripts/kconfig/lxdialog/util.c: In function 'set_classic_theme': /home/kronos/src/linux-2.6/scripts/kconfig/lxdialog/util.c:68: error: 'true' undeclared (first use in this function) /home/kronos/src/linux-2.6/scripts/kconfig/lxdialog/util.c:68: error: (Each undeclared identifier is reported only once /home/kronos/src/linux-2.6/scripts/kconfig/lxdialog/util.c:68: error: for each function it appears in.) /home/kronos/src/linux-2.6/scripts/kconfig/lxdialog/util.c:70: error: 'false' undeclared (first use in this function) /home/kronos/src/linux-2.6/scripts/kconfig/lxdialog/util.c: In function 'set_blackbg_theme': /home/kronos/src/linux-2.6/scripts/kconfig/lxdialog/util.c:101: error: 'true' undeclared (first use in this function) /home/kronos/src/linux-2.6/scripts/kconfig/lxdialog/util.c:102: error: 'false' undeclared (first use in this function) /home/kronos/src/linux-2.6/scripts/kconfig/lxdialog/util.c: In function 'set_bluetitle_theme': /home/kronos/src/linux-2.6/scripts/kconfig/lxdialog/util.c:144: error: 'true' undeclared (first use in this function) make[2]: *** [scripts/kconfig/lxdialog/util.o] Error 1 make[1]: *** [menuconfig] Error 2 make: *** [menuconfig] Error 2 Add <stdbool.h> to dialog.h to fix the breakage. Signed-off-by: Luca Tettamanti <kronos.it@gmail.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] hdrcheck permission fixAndrew Morton
Don't require that scripts/hdrcheck.sh be executable - shit happens... Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03Fix copy&waste bug in comment in scripts/kernel-docRolf Eike Beer
This is obviously copied from some lines before without proper fixing. Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: kbuild: trivial documentation fixes kconfig: fix saving alternate kconfig file in parent dir kbuild: make modpost processing configurable kconfig/menuconfig: do not let ncurses clutter screen on exit kconfig/lxdialog: clear long menu lines kbuild: do not build mconf & lxdialog unless needed kconfig/lxdialog: fix make mrproper kconfig/lxdialog: support resize kconfig/lxdialog: let <ESC><ESC> behave as expected kconfig/menuconfig: lxdialog is now built-in kconfig/lxdialog: add a new theme bluetitle which is now default kconfig/lxdialog: add support for color themes and add blackbg theme kconfig/lxdialog: refactor color support
2006-10-02[PATCH] Add unifdef to gitignorePaul Mundt
This seems to have been missed when unifdef went in via Sam's tree.. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01kconfig: fix saving alternate kconfig file in parent dirSam Ravnborg
This fixes bugzilla entry: 7182 http://bugzilla.kernel.org/show_bug.cgi?id=7182 With this patch we no longer append the directory part twice before saving the config file. This patch has been sent to Roman Zippel for review with no feedback. It is so obviously simple that this should be OK to apply it anyway. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-10-01kbuild: make modpost processing configurableSam Ravnborg
On request from Al Viro make modpost processing configurable. KBUILD_MODPOST_WARN can be set to make modpost warn instead of error out in case on unresolved symbols in final module link. KBUILD_MODPOST_NOFINAL can be set to avoid the final and timeconsuming .c file generation and link of .ko files. This is solely useful for speeding up when doing compile checks with for example allmodconfig Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-10-01[PATCH] allow /proc/config.gz to be built as a moduleRoss Biro
The driver for /proc/config.gz consumes rather a lot of memory and it is in fact possible to build it as a module. In some ways this is a bit risky, because the .config which is used for compiling kernel/configs.c isn't necessarily the same as the .config which was used to build vmlinux. But OTOH the potential memory savings are decent, and it'd be fairly dumb to build your configs.o with a different .config. Signed-off-by: Andrew Morton <akpm@google.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-30kconfig/menuconfig: do not let ncurses clutter screen on exitSam Ravnborg
Do not initialize ncurses twice - it causes unpredicable results. My display was sometimes weird after running make menuconfig and I had to execute 'reset' to properly restore my display. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-30kconfig/lxdialog: clear long menu linesSam Ravnborg
Menulines that were wider than the available line width is now properly null terminated. While at it renamed the variable choice => line_y so it better reflect the usage in do_print_item(). Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-30kbuild: do not build mconf & lxdialog unless neededSam Ravnborg
Due to a limitation in kbuild all objects referred by xxx-y or xxx-objs will be build when one of the targets needs to e build. This caused lxdialog to be build pulling in ncurses that is not always available. So avoid building mconf & lxdialog unless really needed. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-30kconfig/lxdialog: fix make mrproperSam Ravnborg
No Makefile in scripts/kconfig/lxdialog anymore, so do not go there during make mrproper. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-30kconfig/lxdialog: support resizeSam Ravnborg
In all dialogs now properly catch KEY_RESIZE and take proper action. In mconf try to behave sensibly when a dialog routine returns -ERRDISPLAYTOOSMALL. The original check for a screnn size of 80x19 is kept for now. It may make sense to remove it later, but thats anyway what much text is adjusted for. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-30kconfig/lxdialog: let <ESC><ESC> behave as expectedSam Ravnborg
<ESC><ESC> is used to step one back in the dialogs. When lxdialog became built-in pressing <ESC> once would cause one step back and pressing <ESC><ESC> would cause two steps back. This patch - based on concept from Roman Zippel <zippel@linux-m68k.org> - makes one <ESC> a noop and pressing <ESC><ESC> will cause one step backward. In addition the final yes/no dialog now has the option to go back to the the kernel configuration. So if you get too far out you can now go back to configuring the kernel without saving and starting all over again. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-30kconfig/menuconfig: lxdialog is now built-inSam Ravnborg
lxdialog was previously called as an external program causing screen to flicker when used. With this patch lxdialog is now built-in. It is loosly based om previous work by: Petr Baudis <pasky@ucw.cz> Following is a list of changes: o Moved build of dialog routings to kconfig Makefile o menubox + checklist uses a new item list to hold all menu items o in util.c implmented helper function to deal with item list o menubox now uses parameters to save scroll state (avoids temp file) o textbox now get text to be displayed as parameter and not a file o make sure to properly delete subwin's before main windows o killed unused files: lxdialog.c msgbox.c o modified return value for ESC to match direct calling o in a few places the code has been adjusted to 80 char wide o in textbox a small refactoring was made to make code remotely readable o in mconf removed all unused stuff (functions/variables) Following is a list of know short comings: a) pressing ESC twice will be interpreted as two ESC presses b) resize does not work. menuconfig needs to be restarted to be adjusted Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-30kconfig/lxdialog: add a new theme bluetitle which is now defaultSam Ravnborg
The bluetitle theme is a slightly modified version of the colorscheme that -mm users has been used to. The bluetitle is more readable especially on some LCD screens so it is now default. Anyone that really wants the old color selection can get it by selecting the classic color theme: make MENUCONFIG_COLOR=classic menuconfig The bluetitle theme was modified by Roman Zippel <zippel@linux-m68k.org> to further improve readability on LCD screens. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-30kconfig/lxdialog: add support for color themes and add blackbg themeSam Ravnborg
The blackbg theme was originally made by: Han Boetes It was copied from a patch by "Randy.Dunlap" <rdunlap@xenotime.net> which was also the inspiration source for the color theme support. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-30kconfig/lxdialog: refactor color supportSam Ravnborg
Clean up and refactor color support. All color support are now in util.c including color definitions. In the process introduced a global variable named 'dlg' which is used all over to set color - thats the reason why all files are changed. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-29[PATCH] docbook: fix segfault in docproc.cHenrik Kretzschmar
Adds a missing exit, if the file that should be parsed couldn't be opened. Without it crashes with a segfault, cause the filedescriptor is accessed even if the file could not be opened. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] EISA bus MODALIAS attributes supportMichael Tokarev
Add modalias attribute support for the almost forgotten now EISA bus and (at least some) EISA-aware modules. The modalias entry looks like (for an 3c509 NIC): eisa:sTCM5093 and the in-module alias like: eisa:sTCM5093* The patch moves struct eisa_device_id declaration from include/linux/eisa.h to include/linux/mod_devicetable.h (so that the former now #includes the latter), adds proper MODULE_DEVICE_TABLE(eisa, ...) statements for all drivers with EISA IDs I found (some drivers already have that DEVICE_TABLE declared), and adds recognision of __mod_eisa_device_table to scripts/mod/file2alias.c so that proper modules.alias will be generated. There's no support for /lib/modules/$kver/modules.eisamap, as it's not used by any existing tools, and because with in-kernel modalias mechanism those maps are obsolete anyway. The rationale for this patch is: a) to make EISA bus to act as other busses with modalias support, to unify driver loading b) to foget about EISA finally - with this patch, kernel (who still supports EISA) will be the only one who knows how to choose the necessary drivers for this bus ;) [akpm@osdl.org: fix the kbuild bit] Signed-off-by: Michael Tokarev <mjt@tls.msk.ru> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Acked-the-net-bits-by: Jeff Garzik <jeff@garzik.org> Acked-the-tulip-bit-by: Valerie Henson <val_henson@linux.intel.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] i386/x86-64: Work around gcc bug with noreturn functions in unwinderJan Beulich
Current gcc generates calls not jumps to noreturn functions. When that happens the return address can point to the next function, which confuses the unwinder. This patch works around it by marking asynchronous exception frames in contrast normal call frames in the unwind information. Then teach the unwinder to decode this. For normal call frames the unwinder now subtracts one from the address which avoids this problem. The standard libgcc unwinder uses the same trick. It doesn't include adjustment of the printed address (i.e. for the original example, it'd still be kernel_math_error+0 that gets displayed, but the unwinder wouldn't get confused anymore. This only works with binutils 2.6.17+ and some versions of H.J.Lu's 2.6.16 unfortunately because earlier binutils don't support .cfi_signal_frame [AK: added automatic detection of the new binutils and wrote description] Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andi Kleen <ak@suse.de>
2006-09-26[PATCH] Add the -fstack-protector option to the CFLAGSArjan van de Ven
Add a feature check that checks that the gcc compiler has stack-protector support and has the bugfix for PR28281 to make this work in kernel mode. The easiest solution I could find was to have a shell script in scripts/ to do the detection; if needed we can make this fancier in the future without making the makefile too complex. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andi Kleen <ak@suse.de> CC: Andi Kleen <ak@suse.de> CC: Sam Ravnborg <sam@ravnborg.org>
2006-09-26[PATCH] x86: Detect CFI support in the assembler at runtimeAndi Kleen
... instead of using a CONFIG option. The config option still controls if the resulting executable actually has unwind information. This is useful to prevent compilation errors when users select CONFIG_STACK_UNWIND on old binutils and also allows to use CFI in the future for non kernel debugging applications. Cc: jbeulich@novell.com Cc: sam@ravnborg.org Signed-off-by: Andi Kleen <ak@suse.de>
2006-09-24Merge git://git.infradead.org/~dwmw2/khdrs-2.6Linus Torvalds
* git://git.infradead.org/~dwmw2/khdrs-2.6: New 'make headers_install_all' target. Use dependencies for 'make headers_install'. [S390] Unexport <asm/z90crypt.h>, export <asm/zcrypt.h> in its place. Remove dead netfilter_logging.h from include/linux/Kbuild Remove offsetof() from user-visible <linux/stddef.h> Clean up exported headers on CRIS Fix v850 exported headers Don't advertise (or allow) headers_{install,check} where inappropriate. Remove UML header export Remove ARM26 header export. Fix H8300 exported headers. Fix m68knommu exported headers Fix exported headers for SPARC, SPARC64 Fix 'make headers_check' on m32r Fix 'make headers_check' on sh64 Fix 'make headers_check' on sh [HEADERS] Fix ARM 'make headers_check' Initial pass of manual conflict resolution in top-level Makefile over conflicting build rule and headers_install changes.
2006-09-25kbuild: fix "mkdir -p" usage in scripts/package/mkspecRolf Eike Beer
"mkdir -p" does not only mean not to complain if the directory already exists, but also to create the parent directories if needed. This patch removes "lib" from the list of directories to create as we will also create "lib/modules". Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-25kbuild: update help in top level MakefileRobert P. J. Day
2006-09-25kbuild: fail kernel compilation in case of unresolved module symbolsKirill Korotaev
At stage 2 modpost utility is used to check modules. In case of unresolved symbols modpost only prints warning. IMHO it is a good idea to fail compilation process in case of unresolved symbols (at least in modules coming with kernel), since usually such errors are left unnoticed, but kernel modules are broken. - new option '-w' is added to modpost: if option is specified, modpost only warns about unresolved symbols - modpost is called with '-w' for external modules in Makefile.modpost Signed-off-by: Andrey Mirkin <amirkin@sw.ru> Signed-off-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-25kbuild: remove debug left-over from Makefile.hostSam Ravnborg
2006-09-25kbuild: create output directory for hostprogs with O=.. buildSam Ravnborg
hostprogs-y only supported creating output directory for the final program. Extend this to also cover the situation where a .o file (used when host program is made from compositie objects) is locate in another directory. First user of this is the built-in lxdialog that. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-25kbuild: add missing return statement in modpost.c:secref_whitelist()Sam Ravnborg
Noticed by: Magnus Damm <magnus@valinux.co.jp> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-25kbuild: make V=2 tell why a target is rebuildSam Ravnborg
tell why a a target got build enabled by make V=2 Output (listed in the order they are checked): (1) - due to target is PHONY (2) - due to target missing (3) - due to: file1.h file2.h (4) - due to command line change (5) - due to missing .cmd file (6) - due to target not in $(targets) (1) We always build PHONY targets (2) No target, so we better build it (3) Prerequisite is newer than target (4) The command line stored in the file named dir/.target.cmd differed from actual command line. This happens when compiler options changes (5) No dir/.target.cmd file (used to store command line) (6) No dir/.target.cmd file and target not listed in $(targets) This is a good hint that there is a bug in the kbuild file This patch is inspired by a patch from: Milton Miller <miltonm@bga.com> Cc: Milton Miller <miltonm@bga.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
