path: root/scripts
2006-10-02[PATCH] Add unifdef to gitignorePaul Mundt
This seems to have been missed when unifdef went in via Sam's tree.. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] allow /proc/config.gz to be built as a moduleRoss Biro
The driver for /proc/config.gz consumes rather a lot of memory and it is in fact possible to build it as a module. In some ways this is a bit risky, because the .config which is used for compiling kernel/configs.c isn't necessarily the same as the .config which was used to build vmlinux. But OTOH the potential memory savings are decent, and it'd be fairly dumb to build your configs.o with a different .config. Signed-off-by: Andrew Morton <akpm@google.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] docbook: fix segfault in docproc.cHenrik Kretzschmar
Adds a missing exit, if the file that should be parsed couldn't be opened. Without it crashes with a segfault, cause the filedescriptor is accessed even if the file could not be opened. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] EISA bus MODALIAS attributes supportMichael Tokarev
Add modalias attribute support for the almost forgotten now EISA bus and (at least some) EISA-aware modules. The modalias entry looks like (for an 3c509 NIC): eisa:sTCM5093 and the in-module alias like: eisa:sTCM5093* The patch moves struct eisa_device_id declaration from include/linux/eisa.h to include/linux/mod_devicetable.h (so that the former now #includes the latter), adds proper MODULE_DEVICE_TABLE(eisa, ...) statements for all drivers with EISA IDs I found (some drivers already have that DEVICE_TABLE declared), and adds recognision of __mod_eisa_device_table to scripts/mod/file2alias.c so that proper modules.alias will be generated. There's no support for /lib/modules/$kver/modules.eisamap, as it's not used by any existing tools, and because with in-kernel modalias mechanism those maps are obsolete anyway. The rationale for this patch is: a) to make EISA bus to act as other busses with modalias support, to unify driver loading b) to foget about EISA finally - with this patch, kernel (who still supports EISA) will be the only one who knows how to choose the necessary drivers for this bus ;) [akpm@osdl.org: fix the kbuild bit] Signed-off-by: Michael Tokarev <mjt@tls.msk.ru> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Acked-the-net-bits-by: Jeff Garzik <jeff@garzik.org> Acked-the-tulip-bit-by: Valerie Henson <val_henson@linux.intel.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] i386/x86-64: Work around gcc bug with noreturn functions in unwinderJan Beulich
Current gcc generates calls not jumps to noreturn functions. When that happens the return address can point to the next function, which confuses the unwinder. This patch works around it by marking asynchronous exception frames in contrast normal call frames in the unwind information. Then teach the unwinder to decode this. For normal call frames the unwinder now subtracts one from the address which avoids this problem. The standard libgcc unwinder uses the same trick. It doesn't include adjustment of the printed address (i.e. for the original example, it'd still be kernel_math_error+0 that gets displayed, but the unwinder wouldn't get confused anymore. This only works with binutils 2.6.17+ and some versions of H.J.Lu's 2.6.16 unfortunately because earlier binutils don't support .cfi_signal_frame [AK: added automatic detection of the new binutils and wrote description] Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andi Kleen <ak@suse.de>
2006-09-26[PATCH] Add the -fstack-protector option to the CFLAGSArjan van de Ven
Add a feature check that checks that the gcc compiler has stack-protector support and has the bugfix for PR28281 to make this work in kernel mode. The easiest solution I could find was to have a shell script in scripts/ to do the detection; if needed we can make this fancier in the future without making the makefile too complex. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andi Kleen <ak@suse.de> CC: Andi Kleen <ak@suse.de> CC: Sam Ravnborg <sam@ravnborg.org>
2006-09-26[PATCH] x86: Detect CFI support in the assembler at runtimeAndi Kleen
... instead of using a CONFIG option. The config option still controls if the resulting executable actually has unwind information. This is useful to prevent compilation errors when users select CONFIG_STACK_UNWIND on old binutils and also allows to use CFI in the future for non kernel debugging applications. Cc: jbeulich@novell.com Cc: sam@ravnborg.org Signed-off-by: Andi Kleen <ak@suse.de>
2006-09-24Merge git://git.infradead.org/~dwmw2/khdrs-2.6Linus Torvalds
* git://git.infradead.org/~dwmw2/khdrs-2.6: New 'make headers_install_all' target. Use dependencies for 'make headers_install'. [S390] Unexport <asm/z90crypt.h>, export <asm/zcrypt.h> in its place. Remove dead netfilter_logging.h from include/linux/Kbuild Remove offsetof() from user-visible <linux/stddef.h> Clean up exported headers on CRIS Fix v850 exported headers Don't advertise (or allow) headers_{install,check} where inappropriate. Remove UML header export Remove ARM26 header export. Fix H8300 exported headers. Fix m68knommu exported headers Fix exported headers for SPARC, SPARC64 Fix 'make headers_check' on m32r Fix 'make headers_check' on sh64 Fix 'make headers_check' on sh [HEADERS] Fix ARM 'make headers_check' Initial pass of manual conflict resolution in top-level Makefile over conflicting build rule and headers_install changes.
2006-09-25kbuild: fix "mkdir -p" usage in scripts/package/mkspecRolf Eike Beer
"mkdir -p" does not only mean not to complain if the directory already exists, but also to create the parent directories if needed. This patch removes "lib" from the list of directories to create as we will also create "lib/modules". Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-25kbuild: update help in top level MakefileRobert P. J. Day
2006-09-25kbuild: fail kernel compilation in case of unresolved module symbolsKirill Korotaev
At stage 2 modpost utility is used to check modules. In case of unresolved symbols modpost only prints warning. IMHO it is a good idea to fail compilation process in case of unresolved symbols (at least in modules coming with kernel), since usually such errors are left unnoticed, but kernel modules are broken. - new option '-w' is added to modpost: if option is specified, modpost only warns about unresolved symbols - modpost is called with '-w' for external modules in Makefile.modpost Signed-off-by: Andrey Mirkin <amirkin@sw.ru> Signed-off-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-25kbuild: remove debug left-over from Makefile.hostSam Ravnborg
2006-09-25kbuild: create output directory for hostprogs with O=.. buildSam Ravnborg
hostprogs-y only supported creating output directory for the final program. Extend this to also cover the situation where a .o file (used when host program is made from compositie objects) is locate in another directory. First user of this is the built-in lxdialog that. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-25kbuild: add missing return statement in modpost.c:secref_whitelist()Sam Ravnborg
Noticed by: Magnus Damm <magnus@valinux.co.jp> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-25kbuild: make V=2 tell why a target is rebuildSam Ravnborg
tell why a a target got build enabled by make V=2 Output (listed in the order they are checked): (1) - due to target is PHONY (2) - due to target missing (3) - due to: file1.h file2.h (4) - due to command line change (5) - due to missing .cmd file (6) - due to target not in $(targets) (1) We always build PHONY targets (2) No target, so we better build it (3) Prerequisite is newer than target (4) The command line stored in the file named dir/.target.cmd differed from actual command line. This happens when compiler options changes (5) No dir/.target.cmd file (used to store command line) (6) No dir/.target.cmd file and target not listed in $(targets) This is a good hint that there is a bug in the kbuild file This patch is inspired by a patch from: Milton Miller <miltonm@bga.com> Cc: Milton Miller <miltonm@bga.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-25kbuild: modpost on vmlinux regardless of CONFIG_MODULESSam Ravnborg
Based on patch from: Magnus Damm <magnus@valinux.co.jp> This has the advantage that all section mismatch checks are run regardless of modules being enabled or not. When running modpost on vmlinux output: MODPOST vmlinux When running modpost on modules output count of modules like this: MODPOST 5 modules Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-25kbuild: ignore references from ".pci_fixup" to ".init.text"Magnus Damm
The modpost code is extended to ignore references from ".pci_fixup" to ".init.text". Signed-off-by: Magnus Damm <magnus@valinux.co.jp>
2006-09-25kbuild: use in-kernel unifdefSam Ravnborg
Let headers_install use in-kernel unifdef Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-25kbuild: replace use of strlcpy with a dedicated implmentation in unifdefSam Ravnborg
2006-09-25kbuild: add unifdefSam Ravnborg
This patch contains a raw copy of unifdef.c Next patch will modify it and add infrastructure to use it Adding unifdef to the kernel is acked by the author. The reason to add unifdef as part of the kernel source is that it is not yet a common utility on most distributions. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-25kbuild: consistently decide when to rebuild a targetSam Ravnborg
Consistently decide when to rebuild a target across all of if_changed, if_changed_dep, if_changed_rule. PHONY targets are now treated alike (ignored) for all targets While add it make Kbuild.include almost readable by factoring out a few bits to some common variables and reuse this in Makefile.build. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-25kconfig: support DOS line endingsMatthew Wilcox
Kconfig doesn't currently handle config files with DOS line endings. While these are, of course, an abomination, etc, etc, it can be handy to not have to convert them first. It's also a tiny patch and even adds support for lines ending in just \r or even \n\r. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-24Use dependencies for 'make headers_install'.David Woodhouse
Re-export header files only if either they or their controlling Kbuild file has actually changed. Also allow for similar dependencies with 'headers_check', once we properly create the dependencies for those. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-09-22Merge branch 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: (44 commits) [S390] hypfs crashes with invalid mount option. [S390] cio: subchannel evaluation function operates without lock [S390] cio: always query all paths on path verification. [S390] cio: update path groups on logical CHPID changes. [S390] cio: subchannels in no-path state. [S390] Replace nopav-message on VM. [S390] set modalias for ccw bus uevents. [S390] Get rid of DBG macro. [S390] Use alternative user-copy operations for new hardware. [S390] Make user-copy operations run-time configurable. [S390] Cleanup in signal handling code. [S390] Cleanup in page table related code. [S390] Linux API for writing z/VM APPLDATA Monitor records. [S390] xpram off by one error. [S390] Remove kexec experimental flag. [S390] cleanup appldata. [S390] fix typo in vmcp. [S390] Kernel stack overflow handling. [S390] qdio slsb processing state. [S390] Missing initialization in common i/o layer. ...
2006-09-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpcLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (114 commits) [POWERPC] Fix ohare IDE irq workaround on old powermacs [POWERPC] EEH: Power4 systems sometimes need multiple resets. [POWERPC] Include <asm/mmu.h> in arch/powerpc/sysdev/fsl_soc.h for phys_addr_t. [POWERPC] Demacrofy arch/powerpc/platforms/maple/pci.c [POWERPC] Maple U3 HT - reject inappropriate config space access [POWERPC] Fix IPIC pending register assignments [POWERPC] powerpc: fix building gdb against asm/ptrace.h [POWERPC] Remove DISCONTIGMEM cruft from page.h [POWERPC] Merge iSeries i/o operations with the rest [POWERPC] 40x: Fix debug status register defines [POWERPC] Fix compile error in sbc8560 [POWERPC] EEH: support MMIO enable recovery step [POWERPC] EEH: enable MMIO/DMA on frozen slot [POWERPC] EEH: code comment cleanup [POWERPC] EEH: balance pcidev_get/put calls [POWERPC] PPC: Fix xmon stack frame address in backtrace [POWERPC] Add AT_PLATFORM value for Xilinx Virtex-4 FX [POWERPC] Start arch/powerpc/boot code reorganization [POWERPC] Define of_read_ulong helper [POWERPC] iseries: eliminate a couple of warnings ...
2006-09-20[S390] zcrypt adjunct processor bus.Martin Schwidefsky
Add a bus for the adjunct processor interface. Up to 64 devices can be connect to the ap bus interface, each device with 16 domains. That makes 1024 message queues. The interface is asynchronous, the answer to a message sent to a queue needs to be received at some later point in time. Unfortunately the interface does not provide interrupts when a message reply is pending. So the ap bus needs to implement some fancy polling, each active queue is polled once per 1/HZ second or continuously if an idle cpus exsists and the poll thread is activ (see poll_thread parameter). The ap bus uses the sysfs path /sys/bus/ap and has two bus attributes, ap_domain and config_time. The ap_domain selects one of the 16 domains to be used for this system. This limits the maximum number of ap devices to 64. The config_time attribute contains the number of seconds between two ap bus scans to find new devices. The ap bus uses the modalias entries of the form "ap:tN" to autoload the ap driver for hardware type N. Currently known types are: 3 - PCICC, 4 - PCICA, 5 - PCIXCC, 6 - CEX2A and 7 - CEX2C. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Ralph Wuerthner <rwuerthn@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-09-16[PATCH] Fix 'make headers_check' on biarch architecturesDavid Woodhouse
We generate an <asm/foo.h> which includes either <asm-$ARCH/foo.h> or <asm-$ALTARCH/foo.h> as appropriate. But we were doing this dependent on whether the file in question existed in the _unexported_ tree, not the exported tree. So if a file was exported to userspace in one asm- directory but not the other, the generated file in asm/ was incorrect. This only changed the failure mode if it _was_ included from a nice #error to a less explicable #include failure -- but it also gave false errors in 'make headers_check' output. Fix it by looking in the right place instead. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-16[PATCH] Add a missing space that prevents building modules that require host ↵Ross Biro
programs Signed-off-by: Ross Biro <rossb@google.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-14Merge branch 'linux-2.6'Paul Mackerras
2006-09-13[PATCH] headers_check: clarify error messageAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-13[PATCH] headers_check: improve #include regexpAlexey Dobriyan
The following combinations of pp-tokens are used #include #include # include so, script'd better check for all of them. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-31Merge branch 'merge'Paul Mackerras
2006-08-25[POWERPC] make checkstack work with ARCH=powerpcJohannes Berg
This patch adds 'powerpc' architecture support to checkstack.pl. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-08-15[PATCH] PATCH: 1 line 2.6.18 bugfix: modpost-64bit-fix.patchHans de Goede
There is a small but annoying bug in scripts/mod/file2alias.c which causes it to generate invalid aliases for input devices on 64 bit archs. This causes joydev.ko to not be automaticly loaded when inserting a joystick, resulting in a non working joystick (for the average user). In scripts/mod/file2alias.c is the following code for generating the input aliases: static void do_input(char *alias, kernel_ulong_t *arr, unsigned int min, unsigned int max) { unsigned int i; for (i = min; i < max; i++) if (arr[i / BITS_PER_LONG] & (1 << (i%BITS_PER_LONG))) sprintf(alias + strlen(alias), "%X,*", i); } On 32 bits systems, this correctly generates "0,*" for the first alias, "8,*" for the second etc. However on 64 bits it generates: "0,*20,*" resp "8,*28,*" Notice how it adds 20 + first entry (hex) ! to the list of hex codes, which is 32 more then the first entry, thus is because the bit test above wraps at 32 bits instead of 64. scripts/mod/file2alias.c, line 379 reads: if (arr[i / BITS_PER_LONG] & (1 << (i%BITS_PER_LONG))) That should be: if (arr[i / BITS_PER_LONG] & (1L << (i%BITS_PER_LONG))) Notice the added 'L' after the 1, otherwise that is an 32 bit int instead of a 64 bit long, and when that int gets shifted >= 32 times, appearantly the number by which to shift is wrapped at 5 bits ( % 32) causing it to test a bit 32 bits too low. The patch below makes the nescesarry 1 char change :) Signed-off-by: Hans de Goede <j.w.r.degoede@hhs.nl> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-01kbuild: always use $(CC) for $(call cc-version)Sam Ravnborg
The possibility to specify an optional parameter did not work out as expected and it was not used - so remove the possibility. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-08-01kconfig: correct oldconfig for unset choice optionsRoman Zippel
oldconfig currently ignores unset choice options and doesn't ask for them. Correct the SYMBOL_DEF_USER flag of the choice symbol to be only set if it's set for all values. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-08-01kbuild: fix typo in modpostDave Jones
Reported by a Fedora user when they tried to build some out of tree module.. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-08-01kbuild: improve error from file2aliasSam Ravnborg
The original errormessage was just plain unreadable. Sample error message after this update (not for real - I provoked it): FATAL: drivers/net/s2io: sizeof(struct pci_device_id)=33 is not a modulo of the size of section __mod_pci_device_table=160. Fix definition of struct pci_device_id in mod_devicetable.h Before a warning was generated - this is now a fatal error. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-07-31[PATCH] vDSO hash-style fixRoland McGrath
The latest toolchains can produce a new ELF section in DSOs and dynamically-linked executables. The new section ".gnu.hash" replaces ".hash", and allows for more efficient runtime symbol lookups by the dynamic linker. The new ld option --hash-style={sysv|gnu|both} controls whether to produce the old ".hash", the new ".gnu.hash", or both. In some new systems such as Fedora Core 6, gcc by default passes --hash-style=gnu to the linker, so that a standard invocation of "gcc -shared" results in producing a DSO with only ".gnu.hash". The new ".gnu.hash" sections need to be dealt with the same way as ".hash" sections in all respects; only the dynamic linker cares about their contents. To work with older dynamic linkers (i.e. preexisting releases of glibc), a binary must have the old ".hash" section. The --hash-style=both option produces binaries that a new dynamic linker can use more efficiently, but an old dynamic linker can still handle. The new section runs afoul of the custom linker scripts used to build vDSO images for the kernel. On ia64, the failure mode for this is a boot-time panic because the vDSO's PT_IA_64_UNWIND segment winds up ill-formed. This patch addresses the problem in two ways. First, it mentions ".gnu.hash" in all the linker scripts alongside ".hash". This produces correct vDSO images with --hash-style=sysv (or old tools), with --hash-style=gnu, or with --hash-style=both. Second, it passes the --hash-style=sysv option when building the vDSO images, so that ".gnu.hash" is not actually produced. This is the most conservative choice for compatibility with any old userland. There is some concern that some ancient glibc builds (though not any known old production system) might choke on --hash-style=both binaries. The optimizations provided by the new style of hash section do not really matter for a DSO with a tiny number of symbols, as the vDSO has. If someone wants to use =gnu or =both for their vDSO builds and worry less about that compatibility, just change the option and the linker script changes will make any choice work fine. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Andi Kleen <ak@muc.de> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] kernel-doc: ignore __devinitRandy Dunlap
Ignore __devinit in function definitions so that kernel-doc won't fail on them. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-04Merge git://git.infradead.org/hdrinstall-2.6Linus Torvalds
* git://git.infradead.org/hdrinstall-2.6: Remove export of include/linux/isdn/tpam.h Remove <linux/i2c-id.h> and <linux/i2c-algo-ite.h> from userspace export Restrict headers exported to userspace for SPARC and SPARC64 Add empty Kbuild files for 'make headers_install' in remaining arches. Add Kbuild file for Alpha 'make headers_install' Add Kbuild file for SPARC 'make headers_install' Add Kbuild file for IA64 'make headers_install' Add Kbuild file for S390 'make headers_install' Add Kbuild file for i386 'make headers_install' Add Kbuild file for x86_64 'make headers_install' Add Kbuild file for PowerPC 'make headers_install' Add generic Kbuild files for 'make headers_install' Basic implementation of 'make headers_check' Basic implementation of 'make headers_install'
2006-07-03kbuild: introduce utsrelease.hSam Ravnborg
include/linux/version.h contained both actual KERNEL version and UTS_RELEASE that contains a subset from git SHA1 for when kernel was compiled as part of a git repository. This had the unfortunate side-effect that all files including version.h would be recompiled when some git changes was made due to changes SHA1. Split it out so we keep independent parts in separate files. Also update checkversion.pl script to no longer check for UTS_RELEASE. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-07-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: kbuild: documentation change on allowing checkers besides sparse kbuild: warn when a moduled uses a symbol marked UNUSED kbuild: fix segv in modpost kconfig: enhancing accessibility of lxdialog kbuild: fix ia64 breakage after introducing make -rR
2006-07-01[PATCH] kernel-doc: make man/text mode function output sameRandy Dunlap
Make output of function descriptions in text mode match contents of 'man' mode by adding Name: plus function-short-description ("purpose") and changing Function: to Synopsis:. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-01[PATCH] kernel-doc: consistent text/man mode outputRandy.Dunlap
Add a space between data type and struct field name in man-mode bitfield struct output so that they don't run together. For text-mode struct output, print the struct 'purpose' or short description (as done in man-mode output). For text-mode enum output, print the enum 'purpose' or short description (as done in man-mode output). For text-mode typedef output, print the typedef 'purpose' or short description (as done in man-mode output). Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-01kbuild: warn when a moduled uses a symbol marked UNUSEDSam Ravnborg
We now have infrastructure in place to mark an EXPORTed symbol as unused. So the natural next step is to warn during buildtime when a module uses a symbol marked UNUSED. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-07-01kbuild: fix segv in modpostSam Ravnborg
Parsing an old Modules.symvers file casued modpost to SEGV. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-07-01kconfig: enhancing accessibility of lxdialogSamuel Thibault
Some fix that I forgot for good accessibility of lxdialog (the cursor should always be left at the focus location): Have the checklist display the currently highlighted entry last, for having the cursor left on it (rather than on the last line of the list). Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-07-01kbuild: fix ia64 breakage after introducing make -rRSam Ravnborg
kbuild used $¤(*F to get filename of target without extension. This was used in several places all over kbuild, but introducing make -rR broke his for all cases where we specified full path to target/prerequsite. It is assumed that make -rR disables old style suffix-rules which is why is suddenly failed. ia64 was impacted by this change because several div* routines in arch/ia64/lib are build using explicit paths and then kbuild failed. Thanks to David Mosberger-Tang <David.Mosberger@acm.org> for an explanation what was the root-cause and for testing on ia64. This patch also fixes two uses of $(*F) in arch/um Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-06-27[PATCH] rtmutex: Modify rtmutex-tester to test the setscheduler propagationThomas Gleixner
Make test suite setscheduler calls asynchronously. Remove the waits in the test cases and add a new testcase to verify the correctness of the setscheduler priority propagation. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
