path: root/scripts/mod
2012-03-30Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild changes from Michal Marek: - Unification of cmd_uimage among archs that use it - make headers_check tries harder before reporting a missing <linux/types.h> include - kbuild portability fix for shells that do not support echo -e - make clean descends into samples/ - setlocalversion grep fix - modpost typo fix - dtc warnings fix * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: setlocalversion: Use "grep -q" instead of piping output to "read dummy" modpost: fix ALL_INIT_DATA_SECTIONS Kbuild: centralize MKIMAGE and cmd_uimage definitions headers_check: recursively search for linux/types.h inclusion scripts/Kbuild.include: Fix portability problem of "echo -e" scripts: dtc: fix compile warnings kbuild: clean up samples directory kbuild: disable -Wmissing-field-initializers for W=1
2012-03-26modpost: fix ALL_INIT_DATA_SECTIONSJan Beulich
This was lacking a comma between two supposed to be separate strings. Signed-off-by: Jan Beulich <jbeulich@suse.com> Cc: <stable@vger.kernel.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-03-09Merge 3.3-rc6 into driver-core-nextGreg Kroah-Hartman
This was done to resolve a conflict in the drivers/base/cpu.c file. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-27mod/file2alias: make modpost compile on darwin againAndreas Bießmann
commit e49ce14150c64b29a8dd211df785576fa19a9858 breaks cross compiling the linux kernel on darwin hosts. This fix introduce some minimal glue to adopt linker section handling for darwin hosts. Signed-off-by: Andreas Bießmann <andreas@biessmann.de> CC: Rusty Russell <rusty@rustcorp.com.au> CC: Greg Kroah-Hartman <gregkh@linuxfoundation.org> CC: Jochen Friedrich <jochen@scram.de> CC: Samuel Ortiz <sameo@linux.intel.com> CC: "K. Y. Srinivasan" <kys@microsoft.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Tested-by: Bernhard Walle <bernhard@bwalle.de>
2012-02-15ARM: 7324/1: modpost: Fix section warnings for ARM for many compilersTony Lindgren
It turns out that many compilers don't show section warnings on ARM currently because handling for ARM_CALL relocs are missing from modpost.c. Based on commit c2e26114 ([ARM] 3205/1: Handle new EABI relocations when loading kernel modules) it seems that R_ARM_PC24, R_ARM_CALL and R_ARM_JUMP24 can be handled the same way. Note that at least Debian libc6-dev is missing defines for both R_ARM_CALL and R_ARM_JUMP24 in /usr/include/elf.h. So for now we need to define them in modpost.c if not defined. Acked-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: Anders Kaseorg <andersk@ksplice.com> Cc: Greg KH <gregkh@linuxfoundation.org> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-14module: fix broken isapnp handling in file2aliasOndrej Zary
Handling of isapnp module aliases was broken by commit 626596e295d477c0fefa08cd5daa7dd011b1bb2c by changing "isapnp" string to "isa". The code was then modified by commit e49ce14150c64b29a8dd211df785576fa19a9858 but this bug remained. Change the string back to "isapnp". Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-02-13x86/cpu: Clean up modalias feature matchingBen Hutchings
We currently include commas on both sides of the feature ID in a modalias, but this prevents the lowest numbered feature of a CPU from being matched. Since all feature IDs have the same length, we do not need to worry about substring matches, so omit commas from the modalias entirely. Avoid generating multiple adjacent wildcards when there is no feature ID to match. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Acked-by: Thomas Renninger <trenn@suse.de> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-02Merge 3.3-rc2 into the driver-core-next branch.Greg Kroah-Hartman
This was done to resolve a merge and build problem with the drivers/acpi/processor_driver.c file. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-26Add driver auto probing for x86 features v4Andi Kleen
There's a growing number of drivers that support a specific x86 feature or CPU. Currently loading these drivers currently on a generic distribution requires various driver specific hacks and it often doesn't work. This patch adds auto probing for drivers based on the x86 cpuid information, in particular based on vendor/family/model number and also based on CPUID feature bits. For example a common issue is not loading the SSE 4.2 accelerated CRC module: this can significantly lower the performance of BTRFS which relies on fast CRC. Another issue is loading the right CPUFREQ driver for the current CPU. Currently distributions often try all all possible driver until one sticks, which is not really a good way to do this. It works with existing udev without any changes. The code exports the x86 information as a generic string in sysfs that can be matched by udev's pattern matching. This scheme does not support numeric ranges, so if you want to handle e.g. ranges of model numbers they have to be encoded in ASCII or simply all models or families listed. Fixing that would require changing udev. Another issue is that udev will happily load all drivers that match, there is currently no nice way to stop a specific driver from being loaded if it's not needed (e.g. if you don't need fast CRC) But there are not that many cpu specific drivers around and they're all not that bloated, so this isn't a particularly serious issue. Originally this patch added the modalias to the normal cpu sysdevs. However sysdevs don't have all the infrastructure needed for udev, so it couldn't really autoload drivers. This patch instead adds the CPU modaliases to the cpuid devices, which are real devices with full support for udev. This implies that the cpuid driver has to be loaded to use this. This patch just adds infrastructure, some driver conversions in followups. Thanks to Kay for helping with some sysfs magic. v2: Constifcation, some updates v4: (trenn@suse.de): - Use kzalloc instead of kmalloc to terminate modalias buffer - Use uppercase hex values to match correctly against hex values containing letters Cc: Dave Jones <davej@redhat.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Jen Axboe <axboe@kernel.dk> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Huang Ying <ying.huang@intel.com> Cc: Len Brown <lenb@kernel.org> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Thomas Renninger <trenn@suse.de> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-20Revert "ARM: sa11x0: Implement autoloading of codec and codec pdata for mcp ↵Russell King
bus." This reverts commit 5dd7bf59e0e8563265b3e5b33276099ef628fcc7. Conflicts: scripts/mod/file2alias.c This change is wrong on many levels. First and foremost, it causes a regression. On boot on Assabet, which this patch gives a codec id of 'ucb1x00', it gives: ucb1x00 ID not found: 1005 0x1005 is a valid ID for the UCB1300 device. Secondly, this patch is way over the top in terms of complexity. The only device which has been seen to be connected with this MCP code is the UCB1x00 (UCB1200, UCB1300 etc) devices, and they all use the same driver. Adding a match table, requiring the codec string to match the hardware ID read out of the ID register, etc is completely over the top when we can just read the hardware ID register.
2012-01-14Merge tag 'for-linus' of git://github.com/rustyrussell/linuxLinus Torvalds
Autogenerated GPG tag for Rusty D1ADB8F1: 15EE 8D6C AB0E 7F0C F999 BFCB D920 0E6C D1AD B8F1 * tag 'for-linus' of git://github.com/rustyrussell/linux: module_param: check that bool parameters really are bool. intelfbdrv.c: bailearly is an int module_param paride/pcd: fix bool verbose module parameter. module_param: make bool parameters really bool (drivers & misc) module_param: make bool parameters really bool (arch) module_param: make bool parameters really bool (core code) kernel/async: remove redundant declaration. printk: fix unnecessary module_param_name. lirc_parallel: fix module parameter description. module_param: avoid bool abuse, add bint for special cases. module_param: check type correctness for module_param_array modpost: use linker section to generate table. modpost: use a table rather than a giant if/else statement. modules: sysfs - export: taint, coresize, initsize kernel/params: replace DEBUGP with pr_debug module: replace DEBUGP with pr_debug module: struct module_ref should contains long fields module: Fix performance regression on modules with large symbol tables module: Add comments describing how the "strmap" logic works Fix up conflicts in scripts/mod/file2alias.c due to the new linker- generated table approach to adding __mod_*_device_table entries. The ARM sa11x0 mcp bus needed to be converted to that too.
2012-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (59 commits) rtc: max8925: Add function to work as wakeup source mfd: Add pm ops to max8925 mfd: Convert aat2870 to dev_pm_ops mfd: Still check other interrupts if we get a wm831x touchscreen IRQ mfd: Introduce missing kfree in 88pm860x probe routine mfd: Add S5M series configuration mfd: Add s5m series irq driver mfd: Add S5M core driver mfd: Improve mc13xxx dt binding document mfd: Fix stmpe section mismatch mfd: Fix stmpe build warning mfd: Fix STMPE I2c build failure mfd: Constify aat2870-core i2c_device_id table gpio: Add support for stmpe variant 801 mfd: Add support for stmpe variant 801 mfd: Add support for stmpe variant 610 mfd: Add support for STMPE SPI interface mfd: Separate out STMPE controller and interface specific code misc: Remove max8997-muic sysfs attributes mfd: Remove unused wm831x_irq_data_to_mask_reg() ... Fix up trivial conflict in drivers/leds/Kconfig due to addition of LEDS_MAX8997 and LEDS_TCA6507 next to each other.
2012-01-13modpost: use linker section to generate table.Rusty Russell
This means (most) future busses need only have one hunk in their patch. Also took the opportunity to check that function matches the type. Again, inspired by Alessandro's patch series. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Alessandro Rubini <rubini@gnudd.com>
2012-01-13modpost: use a table rather than a giant if/else statement.Rusty Russell
We look for symbols of form __mod_<busname>_device_table, and for all but three cases we use a standard interation function (do_table) to walk over the contents and dump out the aliases. Alessandro Rubini did this first, I just repainted the bikeshed a bit. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Alessandro Rubini <rubini@gnudd.com>
2012-01-09ARM: sa11x0: Implement autoloading of codec and codec pdata for mcp bus.Jochen Friedrich
Signed-off-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-11-22ARM: amba: Auto-generate AMBA driver module aliases during modpostDave Martin
This patch adds the necessary support in file2alias.c to define suitable aliases based on the amba_id table in AMBA driver modules. This should be sufficient to allow such modules to be auto-loaded via udev. The AMBA bus driver's uevent hotplug code is also modified to pass an approriate MODALIAS string in the event. For simplicity, the AMBA ID is treated an an opaque 32-bit numeber. Module alises use patterns as appropriate to describe the value- mask pairs described in the driver's amba_id list. The proposed alias format is (extended regex): ^amba:d(HEX){8}$ Where HEX is a single upper-case HEX digit or a pattern (? or [] expression) matching a single upper-case HEX digit, as expected by udev. "d" is short for "device", following existing alias naming conventions for other device types. This adds some flexibility for unambiguously extending the alias format in the future by adding additional leading and trailing fields, if this turns out to be necessary. Signed-off-by: Dave Martin <dave.martin@linaro.org> Acked-by: Pawel Moll <pawel.moll@arm.com>
2011-11-07module,bug: Add TAINT_OOT_MODULE flag for modules not built in-treeBen Hutchings
Use of the GPL or a compatible licence doesn't necessarily make the code any good. We already consider staging modules to be suspect, and this should also be true for out-of-tree modules which may receive very little review. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Reviewed-by: Dave Jones <davej@redhat.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (patched oops-tracing.txt)
2011-08-25Staging: hv: file2alias: fix up alias creation logic for hv_vmbus_device_idGreg Kroah-Hartman
When I added the driver_data field to hv_vmbus_device_id, I forgot to take into the account how the alias was created, so it would append the kernel pointer to the end of the alias, which is not correct. This changes how the hv_vmbus_device_id alias is created to proper account for the driver_data field. As no module yet uses this alias, it is safe to fix this up at this point in the commit stream. Cc: K. Y. Srinivasan <kys@microsoft.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-25Staging: hv: Add code to parse struct hv_vmbus_device_id tableK. Y. Srinivasan
Add code to parse struct hv_vmbus_device_id table. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-24modpost: Fix modpost's license checking V3Alessio Igor Bogani
The commit f02e8a6 sorts symbols placing each of them in its own elf section. The sorting and merging into the canonical sections are done by the linker. Unfortunately modpost to generate Module.symvers file parses vmlinux (already linked) and all modules object files (which aren't linked yet). These aren't sanitized by the linker yet. That breaks modpost that can't detect license properly for modules. This patch makes modpost aware of the new exported symbols structure. Thanks to Arnaud Lacombe <lacombar@gmail.com> and Anders Kaseorg <andersk@ksplice.com> for providing useful suggestions about code. This work was supported by a hardware donation from the CE Linux Forum. Reported-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Alessio Igor Bogani <abogani@kernel.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits) macvlan: fix panic if lowerdev in a bond tg3: Add braces around 5906 workaround. tg3: Fix NETIF_F_LOOPBACK error macvlan: remove one synchronize_rcu() call networking: NET_CLS_ROUTE4 depends on INET irda: Fix error propagation in ircomm_lmp_connect_response() irda: Kill set but unused variable 'bytes' in irlan_check_command_param() irda: Kill set but unused variable 'clen' in ircomm_connect_indication() rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport() be2net: Kill set but unused variable 'req' in lancer_fw_download() irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication() atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined. rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer(). rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler() rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection() rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window() pkt_sched: Kill set but unused variable 'protocol' in tc_classify() isdn: capi: Use pr_debug() instead of ifdefs. tg3: Update version to 3.119 tg3: Apply rx_discards fix to 5719/5720 ... Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c as per Davem.
2011-05-19modpost: Update 64k section support for binutils 2.18.50Anders Kaseorg
Binutils 2.18.50 made a backwards-incompatible change in the way it writes ELF objects with over 65280 sections, to improve conformance with the ELF specification and interoperability with other ELF tools. Specifically, it no longer adds 256 to section indices SHN_LORESERVE and higher to skip over the reserved range SHN_LORESERVE through SHN_HIRESERVE; those values are only considered special in the st_shndx field, and not in other places where section indices are stored. See: http://sourceware.org/bugzilla/show_bug.cgi?id=5900 http://groups.google.com/group/generic-abi/browse_thread/thread/e8bb63714b072e67/6c63738f12cc8a17 Signed-off-by: Anders Kaseorg <andersk@ksplice.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-05-10bcma: add Broadcom specific AMBA bus driverRafał Miłecki
Broadcom has released cards based on a new AMBA-based bus type. From a programming point of view, this new bus type differs from AMBA and does not use AMBA common registers. It also differs enough from SSB. We decided that a new bus driver is needed to keep the code clean. In its current form, the driver detects devices present on the bus and registers them in the system. It allows registering BCMA drivers for specified bus devices and provides them basic operations. The bus driver itself includes two important bus managing drivers: ChipCommon core driver and PCI(c) core driver. They are early used to allow correct initialization. Currently code is limited to supporting buses on PCI(e) devices, however the driver is designed to be used also on other hosts. The host abstraction layer is implemented and already used for PCI(e). Support for PCI(e) hosts is working and seems to be stable (access to 80211 core was tested successfully on a few devices). We can still optimize it by using some fixed windows, but this can be done later without affecting any external code. Windows are just ranges in MMIO used for accessing cores on the bus. Cc: Greg KH <greg@kroah.com> Cc: Michael Büsch <mb@bu3sch.de> Cc: Larry Finger <Larry.Finger@lwfinger.net> Cc: George Kashperko <george@znau.edu.ua> Cc: Arend van Spriel <arend@broadcom.com> Cc: linux-arm-kernel@lists.infradead.org Cc: Russell King <rmk@arm.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Andy Botting <andy@andybotting.com> Cc: linuxdriverproject <devel@linuxdriverproject.org> Cc: linux-kernel@vger.kernel.org <linux-kernel@vger.kernel.org> Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-21Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: kbuild: Make DEBUG_SECTION_MISMATCH selectable, but not on by default genksyms: Regenerate lexer and parser genksyms: Track changes to enum constants genksyms: simplify usage of find_symbol() genksyms: Add helpers for building string lists genksyms: Simplify printing of symbol types genksyms: Simplify lexer genksyms: Do not paste the bison header file to lex.c modpost: fix trailing comma KBuild: silence "'scripts/unifdef' is up to date." kbuild: Add extra gcc checks kbuild: reenable section mismatch analysis unifdef: update to upstream version 2.5
2011-03-17modpost: fix trailing commaRandy Dunlap
Consolidate locations that print a section whitelist into calls to print_section_list(). Fix print_section_list() so that it does not print a trailing comma & space: If the reference is valid then annotate the variable with __init* or __refdata (see linux/init.h) or name the variable: *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console, becomes: If the reference is valid then annotate the variable with __init* or __refdata (see linux/init.h) or name the variable: *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-03-13kbuild: Fix computing srcversion for modulesMichal Marek
Recent change to fixdep: commit b7bd182176960fdd139486cadb9962b39f8a2b50 Author: Michal Marek <mmarek@suse.cz> Date: Thu Feb 17 15:13:54 2011 +0100 fixdep: Do not record dependency on the source file itself changed the format of the *.cmd files without realizing that it is also used by modpost. Put the path to the source file to the file back, in a special variable, so that modpost sees all source files when calculating srcversion for modules. Reported-and-tested-by: Henrik Rydberg <rydberg@euromail.se> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2010-12-28modpost: Fix address calculation in reloc_location()Olof Johansson
This patch fixes a segfault in modpost that is observed when the gold linker is used to link the input objects. The problem is that reloc_location (modpost.c) is computing the address of the relocation target incorrectly. Here, elf->hdr points to the beginning of the ELF file in memory, sechdr points to the relocation section header, section is the index of the section being relocated, and sechdrs[section].sh_offset would be the offset of that section, relative to the beginning of the ELF file. Adding elf->hdr + sechdrs[section].sh_offset gives you the address of the beginning of the section, and adding r->r_offset to that gives you the address of the location to be relocated. You do not need to subtract sechdrs[section].sh_addr from that -- the result of this is an address outside the file, and causes the segfault when addend_386_rel tries to dereference it. This bug is not observed when GNU ld is used to link the inputs. The object file ubuntu/omnibook/omnibook.o is the result of an ld -r of several other files. When GNU ld does an ld -r, it sets the vaddr field for each section to 0, but gold lays out the section addresses sequentially instead: Section Headers: [Nr] Name Type Addr Off Size ES Flg Lk Inf Al [ 0] NULL 00000000 000000 000000 00 0 0 0 [ 1] .text PROGBITS 00000000 000034 004794 00 AX 0 0 4 [ 2] .data PROGBITS 0000b9d0 0047c8 0009c0 00 WA 0 0 4 [ 3] .bss NOBITS 000162f8 005188 00013c 00 WA 0 0 4 [ 4] .rodata.str1.1 PROGBITS 00004f2d 0052c4 001b1a 01 AMS 0 0 1 [ 5] .init.text PROGBITS 00004794 006dde 0005fa 00 AX 0 0 1 [ 6] .exit.text PROGBITS 00004d8e 0073d8 00018a 00 AX 0 0 1 ... So the bug in the tool remained undiscovered because the section's vaddr always happened to be 0. Signed-off-by: Raymes Khoury <raymes@google.com> Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-12-16modpost: Put .zdebug* section on white listH.J. Lu
"as --compress-debug-sections" will generate compressed debug sections with section names ".zdebug*". This patch puts .zdebug* section on white list. Signed-off-by: H.J. Lu <hjl.tools@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-28Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: initramfs: Fix build break on symbol-prefixed archs initramfs: fix initramfs size calculation initramfs: generalize initramfs_data.xxx.S variants scripts/kallsyms: Enable error messages while hush up unnecessary warnings scripts/setlocalversion: update comment kbuild: Use a single clean rule for kernel and external modules kbuild: Do not run make clean in $(srctree) scripts/mod/modpost.c: fix commentary accordingly to last changes kbuild: Really don't clean bounds.h and asm-offsets.h
2010-08-26scripts/mod/modpost.c: fix commentary accordingly to last changesAndy Shevchenko
The last commits 37ed19d5cce35a40d3913cf9aa208ce9f60db3d7 5003bab82d56754b27be01eef24495a02e00039d have introduced new behaviour of sec2annotation() method. However, the commentary inside the method was left as before. Let's fix it accordingly. Signed-off-by: Andy Shevchenko <ext-andriy.shevchenko@nokia.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Andrew Morton <akpm@linux-foundation.org> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-08-12Merge branch 'params' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus * 'params' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: (22 commits) param: don't deref arg in __same_type() checks param: update drivers/acpi/debug.c to new scheme param: use module_param in drivers/message/fusion/mptbase.c ide: use module_param_named rather than module_param_call param: update drivers/char/ipmi/ipmi_watchdog.c to new scheme param: lock if_sdio's lbs_helper_name and lbs_fw_name against sysfs changes. param: lock myri10ge_fw_name against sysfs changes. param: simple locking for sysfs-writable charp parameters param: remove unnecessary writable charp param: add kerneldoc to moduleparam.h param: locking for kernel parameters param: make param sections const. param: use free hook for charp (fix leak of charp parameters) param: add a free hook to kernel_param_ops. param: silence .init.text references from param ops Add param ops struct for hvc_iucv driver. nfs: update for module_param_named API change AppArmor: update for module_param_named API change param: use ops in struct kernel_param, rather than get and set fns directly param: move the EXPORT_SYMBOL to after the definitions. ...
2010-08-12MN10300: Permit .GCC-command-line sectionsDavid Howells
Permit .GCC-command-line sections in modules. Otherwise modpost says things like: WARNING: drivers/mtd/chips/map_ram.o (.GCC-command-line): unexpected non-allocatable section. Did you forget to use "ax"/"aw" in a .S file? Note that for example <linux/init.h> contains section definitions for use in .S files. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11fix "scripts/mod/modpost.c: fix memory leak"Andrew Morton
Fix error introduced by 37ed19d5cce35a40d3913cf9aa208ce9f60db3d7 ("scripts/mod/modpost.c: fix memory leak"). - don't kfree("") - fix one missed conversion Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Tested-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Alexey Fomenko <ext-alexey.fomenko@nokia.com> Cc: Trevor Keith <tsrk@tsrk.net> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11param: silence .init.text references from param opsRusty Russell
Ideally, we'd check that it was only the "set" function which was __init, and that the permissions were r/o. But that's a little hard. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Sam Ravnborg <sam@ravnborg.org> Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
2010-08-09scripts/mod/modpost.c: fix memory leakAlexey Fomenko
sec2annotation returns malloc'ed buffer directly to printf as an argument. Free this buffer after printing. Signed-off-by: Alexey Fomenko <ext-alexey.fomenko@nokia.com> Cc: Trevor Keith <tsrk@tsrk.net> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-04Merge commit 'v2.6.35' into kbuild/kbuildMichal Marek
Conflicts: arch/powerpc/Makefile
2010-08-03modpost: support objects with more than 64k sectionsDenys Vlasenko
This patch makes modpost able to process object files with more than 64k sections. Needed for huge kernel builds (allyesconfig, for example) with -ffunction-sections. 64k sections handling is covered, for example, by this document: "IA-64 gABI Proposal 74: Section Indexes" http://www.codesourcery.com/public/cxx-abi/abi/prop-74-sindex.html Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Signed-off-by: Anders Kaseorg <andersk@mit.edu> Acked-by: Sam Ravnborg <sam@ravnborg.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-07-08powerpc: Fix module building for gcc 4.5 and 64 bitStephen Rothwell
Gcc 4.5 is now generating out of line register save and restore in the function prefix and postfix when we use -Os. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-06-12kbuild: Fix modpost segfaultKrzysztof Halasa
Alan <alan@clueserver.org> writes: > program: /home/alan/GitTrees/linux-2.6-mid-ref/scripts/mod/modpost -o > Module.symvers -S vmlinux.o > > Program received signal SIGSEGV, Segmentation fault. It just hit me. It's the offset calculation in reloc_location() which overflows: return (void *)elf->hdr + sechdrs[section].sh_offset + (r->r_offset - sechdrs[section].sh_addr); E.g. for the first rodata r entry: r->r_offset < sechdrs[section].sh_addr and the expression in the parenthesis produces 0xFFFFFFE0 or something equally wise. Reported-by: Alan <alan@clueserver.org> Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl> Tested-by: Alan <alan@clueserver.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-06-01Merge branch 'for-35' of git://repo.or.cz/linux-kbuildLinus Torvalds
* 'for-35' of git://repo.or.cz/linux-kbuild: (81 commits) kbuild: Revert part of e8d400a to resolve a conflict kbuild: Fix checking of scm-identifier variable gconfig: add support to show hidden options that have prompts menuconfig: add support to show hidden options which have prompts gconfig: remove show_debug option gconfig: remove dbg_print_ptype() and dbg_print_stype() kconfig: fix zconfdump() kconfig: some small fixes add random binaries to .gitignore kbuild: Include gen_initramfs_list.sh and the file list in the .d file kconfig: recalc symbol value before showing search results .gitignore: ignore *.lzo files headerdep: perlcritic warning scripts/Makefile.lib: Align the output of LZO kbuild: Generate modules.builtin in make modules_install Revert "kbuild: specify absolute paths for cscope" kbuild: Do not unnecessarily regenerate modules.builtin headers_install: use local file handles headers_check: fix perl warnings export_report: fix perl warnings ...
2010-05-21Merge branch 'modules' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus * 'modules' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: module: drop the lock while waiting for module to complete initialization. MODULE_DEVICE_TABLE(isapnp, ...) does nothing hisax_fcpcipnp: fix broken isapnp device table. isapnp: move definitions to mod_devicetable.h so file2alias can reach them.
2010-05-19MODULE_DEVICE_TABLE(isapnp, ...) does nothingOndrej Zary
On Monday 23 November 2009 04:29:53 Rusty Russell wrote: > On Mon, 23 Nov 2009 07:31:57 am Ondrej Zary wrote: > > The problem is that > > scripts/mod/file2alias.c simply ignores isapnp. > > AFAICT it always has, and noone has complained until now. Perhaps > something was still reading /lib/modules/`uname -r`/modules.isapnpmap? The patch below works fine (at least with Debian). It needs your first patch that moves the definitions to mod_devicetable.h. Verified that aliases for these modules are generated correctly: drivers/media/radio/radio-sf16fmi.c drivers/net/ne.c drivers/net/3c515.c drivers/net/smc-ultra.c drivers/pcmcia/i82365.c drivers/scsi/aha1542.c drivers/scsi/aha152x.c drivers/scsi/sym53c416.c drivers/scsi/g_NCR5380.c Tested with RTL8019AS (ne), AVA-1505AE (aha152x) and dtc436e (g_NCR5380) cards - they now work automatically. Generate pnp:d aliases for isapnp_device_tables. This allows udev to load these modules automatically. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-05-18Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: include/linux/mod_devicetable.h scripts/mod/file2alias.c
2010-05-17m68k: amiga - Zorro bus modalias supportGeert Uytterhoeven
Add Amiga Zorro bus modalias and uevent support Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2010-04-02phylib: Support phy module autoloadingDavid Woodhouse
We don't use the normal hotplug mechanism because it doesn't work. It will load the module some time after the device appears, but that's not good enough for us -- we need the driver loaded _immediately_ because otherwise the NIC driver may just abort and then the phy 'device' goes away. [bwh: s/phy/mdio/ in module alias, kerneldoc for struct mdio_device_id] Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Acked-by: Andy Fleming <afleming@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-30modpost: don't allow *driver to reference .init.*Uwe Kleine-König
2010-01-30modpost: make symbol white list a per mismatch type variableUwe Kleine-König
2010-01-30modpost: remove now unused NO_MISMATCH constantUwe Kleine-König
