path: root/scripts/kconfig/lkc_proto.h
2009-09-20kconfig: add menu_get_ext_help function to display more informationCheng Renquan
The three functions are moved from mconf.c, then they can be shared in all menuconfig & gconfig & xconfig & config. +void menu_get_ext_help(struct menu *menu, struct gstr *help) +static void get_prompt_str(struct gstr *r, struct property *prop) +void get_symbol_str(struct gstr *r, struct symbol *sym) Signed-off-by: Cheng Renquan <crquan@gmail.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-04-28kconfig: add named choice groupRoman Zippel
As choice dependency are now fully checked, it's quite easy to add support for named choices. This lifts the restriction that a choice value can only appear once, although it still has to be within the same group, but multiple choices can be joined by giving them a name. While at it I cleaned up a little the choice type logic to simplify it a bit. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-11-17x86: simplify "make ARCH=x86" and fix kconfig all.configSam Ravnborg
Simplify "make ARCH=x86" and fix kconfig so we again can set 64BIT in all.config. For a fix the diffstat is nice: 6 files changed, 3 insertions(+), 36 deletions(-) The patch reverts these commits: - 0f855aa64b3f63d35a891510cf7db932a435c116 ("kconfig: add helper to set config symbol from environment variable") - 2a113281f5cd2febbab21a93c8943f8d3eece4d3 ("kconfig: use $K64BIT to set 64BIT with all*config targets") Roman Zippel pointed out that kconfig supported string compares so the additional complexity introduced by the above two patches were not needed. With this patch we have following behaviour: # make {allno,allyes,allmod,rand}config [ARCH=...] option \ host arch | 32bit | 64bit ===================================================== ./. | 32bit | 64bit ARCH=x86 | 32bit | 32bit ARCH=i386 | 32bit | 32bit ARCH=x86_64 | 64bit | 64bit The general rule are that ARCH= and native architecture takes precedence over the configuration. So make ARCH=i386 [whatever] will always build a 32-bit kernel no matter what the configuration says. The configuration will be updated to 32-bit if it was configured to 64-bit and the other way around. This behaviour is consistent with previous behaviour so no suprises here. make ARCH=x86 will per default result in a 32-bit kernel but as the only ARCH= value x86 allow the user to select between 32-bit and 64-bit using menuconfig. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Andreas Herrmann <aherrman@arcor.de> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-12kconfig: add helper to set config symbol from environment variableSam Ravnborg
Add conf_set_env_sym() that can set an already defined symbol based on the value of an environment variable. Unknown symbols are silently ignored. A warning is printed if the value of the environment variable is unexpected. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2007-07-25kconfig: attach help text to menusSam Ravnborg
Roman Zippel wrote: > A simple example would be > help texts, right now they are per symbol, but they should really be per > menu, so archs can provide different help texts for something. This patch does this and at the same time introduce a few API funtions used to access the help text. The relevant api functions are introduced in the various frontends. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2006-12-13[PATCH] kconfig: add "void conf_set_changed_callback(void (*fn)(void))", use ↵Karsten Wiese
it in qconf.cc Added function sets "void (*conf_changed_callback)(void)". Call it, if .config's changed state changes. Use above in qconf.cc to set gui's save-widget's sensitvity. Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] kconfig: make sym_change_count static, let it be altered by 2 ↵Karsten Wiese
functions only Those two functions are void sym_set_change_count(int count) and void sym_add_change_count(int count) All write accesses to sym_change_count are replaced by calls to above functions. Variable and changer-functions are moved to confdata.c. IMO thats ok, as sym_change_count is an attribute of the .config's change state. Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] kconfig: new function "bool conf_get_changed(void)"Karsten Wiese
Run "make xconfig" on a freshly untarred kernel-tree. Look at the floppy disk icon of the qt application, that has just started: Its in a normal, active state. Mouse click on it: .config is being saved. This patch series changes things so taht after the mouse click on the floppy disk icon, the icon is greyed out. If you mouse click on it now, nothing happens. If you change some CONFIG_*, the floppy disk icon returns to "active state", that is, if you mouse click it now, .config is written. This patch: Returns sym_change_count to reflect the .config's change state. All read only accesses of sym_change_count are replaced by calls to conf_get_changed() . mconfig.c is manipulated to ask for saving only when conf_get_changed() returned true. Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-09kconfig: create links in info windowRoman Zippel
Extend the expression print helper function to allow customization of the symbol output and use it to add links to the info window. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-06-09kconfig: allow loading multiple configurationsRoman Zippel
Extend conf_read_simple() so it can load multiple configurations. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-06-09kconfig: fix .config dependenciesRoman Zippel
This fixes one of the worst kbuild warts left - the broken dependencies used to check and regenerate the .config file. This was done via an indirect dependency and the .config itself had an empty command, which can cause make not to reread the changed .config file. Instead of this we generate now a new file include/config/auto.conf from .config, which is used for kbuild and has the proper dependencies. It's also the main make target now for all files generated during this step (and thus replaces include/linux/autoconf.h). This also means we can now relax the syntax requirements for the .config file and we don't have to rewrite it all the time, i.e. silentoldconfig only writes .config now when it's necessary to keep it in sync with the Kconfig files and even this can be suppressed by setting the environment variable KCONFIG_NOSILENTUPDATE, so the update can (and must) be done manually. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-11-09[PATCH] kconfig: preset config during all*configRoman Zippel
Allow to force setting of config variables during all{no,mod,yes,random}config to a specific value. For that conf first checks the KCONFIG_ALLCONFIG environment variable for a file name, otherwise it checks for all{no,mod,yes,random}.config and all.config. The file is a normal config file, which presets the config variables, but they are still subject to normal dependency checks. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
