Move the test for -fstack-protector(-strong) option to Kconfig.
If the compiler does not support the option, the corresponding menu
is automatically hidden. If STRONG is not supported, it will fall
back to REGULAR. If REGULAR is not supported, it will be disabled.
This means, AUTO is implicitly handled by the dependency solver of
Kconfig, hence removed.
I also turned the 'choice' into only two boolean symbols. The use of
'choice' is not a good idea here, because all of all{yes,mod,no}config
would choose the first visible value, while we want allnoconfig to
disable as many features as possible.
X86 has additional shell scripts in case the compiler supports those
options, but generates broken code. I added CC_HAS_SANE_STACKPROTECTOR
to test this. I had to add -m32 to gcc-x86_32-has-stack-protector.sh
to make it work correctly.
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
The Makefiles call the respective interpreter explicitly, but this makes
it easier to use the scripts manually.
The correct syntax for gcc -x is "gcc -x assembler", not
"gcc -xassembler". Even though the latter happens to work, the former
is what is documented in the manual page and thus what gcc wrappers
such as icecream do expect.
This isn't a cosmetic change. The missing space prevents icecream from
recognizing compilation tasks it can't handle, leading to silent kernel
miscompilations.
Besides me, credits go to Michael Matz and Dirk Mueller for
investigating the miscompilation issue and tracking it down to this
incorrect -x parameter syntax.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: stable@vger.kernel.org
Cc: Bernhard Walle <bernhard@bwalle.de>
Cc: Michal Marek <mmarek@suse.cz>
Stackprotector builds were failing if CROSS_COMPILER was more than
a single world (such as when distcc was used) - because the check
scripts used $1 instead of $*.
Impact: stack protector for x86_32
Implement stack protector for x86_32. GDT entry 28 is used for it.
It's set to point to stack_canary-20 and have the length of 24 bytes.
CONFIG_CC_STACKPROTECTOR turns off CONFIG_X86_32_LAZY_GS and sets %gs
to the stack canary segment on entry. As %gs is otherwise unused by
the kernel, the canary can be anywhere. It's defined as a percpu
variable.
x86_32 exception handlers take register frame on stack directly as
struct pt_regs. With -fstack-protector turned on, gcc copies the
whole structure after the stack canary and (of course) doesn't copy
back on return thus losing all changed. For now, -fno-stack-protector
is added to all files which contain those functions. We definitely
need something better.
