path: root/scripts/coccinelle
2015-04-15scripts/coccinelle/misc/bugon.cocci: update bug_on conversion warningFabian Frederick
if()/BUG conversion to BUG_ON must be avoided when there's side effect in condition. The reason being BUG_ON won't execute the condition when CONFIG_BUG is not defined. Inspired-by: J. Bruce Fields <bfields@fieldses.org> Suggested-by: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Michal Marek <mmarek@suse.cz>
2015-03-25irqf_oneshot.cocci: add check of devm_request_threaded_irq()Valentin Rothberg
Since commit 1c6c69525b40eb76de8adf039409722015927dc3 ("genirq: Reject bogus threaded irq requests") threaded IRQs without a primary handler need to be requested with IRQF_ONESHOT, otherwise the request will fail. Until now, this coccinelle script only checked request_threaded_irq(). However, the counterpart devm function (see kernel/irq/devres.c) is also affected by the missing flag which can be detected with this patch. Signed-off-by: Valentin Rothberg <valentinrothberg@gmail.com> Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-12-20Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull misc kbuild changes from Michal Marek: "There are only a few things in the misc branch: - Fix for bugon.cocci semantic patch - Kdevelop4 files are .gitignored - Put make binrpm-pkg on diet" * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: scripts/package: binrpm-pkg do not create source and devel package .gitignore: Add Kdevelop4 project files bugon.cocci: fix Options at the macro
2014-11-24bugon.cocci: fix Options at the macroMauro Carvalho Chehab
The comma after --no-includes makes coccinelle to not run the script: /usr/bin/spatch -D report --very-quiet --no-show-diff --cocci-file ./scripts/coccinelle/misc/bugon.cocci --no-includes, --include-headers --patch . --dir drivers/media/platform/coda/ -I ./arch/x86/include -I arch/x86/include/generated -I include -I ./arch/x86/include/uapi -I arch/x86/include/generated/uapi -I ./include/uapi -I include/generated/uapi -I ./include/linux/kconfig.h Usage: spatch.opt --sp-file <SP> <infile> [-o <outfile>] [--iso-file <iso>] [options] Options are: --sp-file <file> the semantic patch file -o <file> the output file --in-place do the modification on the file directly --backup-suffix suffix to use when making a backup for inplace ... At least with Fedora 20 coccinelle package: coccinelle-1.0.0-0.rc20.1.fc21.x86_64 Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Tested-by: Wolfram Sang <wsa@the-dreams.de> Fixes: 5be1df66 (Coccinelle: Script to replace if and BUG with BUG_ON) Cc: stable@vger.kernel.org Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-11-06coccinelle: api: add spatch to prevent unnecessary .ownerWolfram Sang
There are calls which silently set the owner of a module. This is the preferred way [1], so avoid setting it manually. Currently, we only care about platform drivers, but there might be more calls to be added later. [1] https://lkml.org/lkml/2014/10/12/87 Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-26coccinelle: misc: semantic patch to delete overly complex return code processingJulia Lawall
This semantic patch simplifies cases where the effect of the processing of a function call's return code is just to return the result of the function directly. It may also delete a local return flag variable, if this is no longer used. This was proposed by Uwe Kleine-König. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-08-14Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull misc kbuild updates from Michal Marek: "This is the non-critical part of kbuild for 3.17-rc1: - make help hint to use make -s with make kernelrelease et al. - moved a kbuild document to Documentation/kbuild where it belongs - four new Coccinelle scripts, one dropped and one fixed - new make kselftest target to run various tests on the kernel" * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: kselftest - new make target to build and run kernel selftests Coccinelle: Script to replace if and BUG with BUG_ON Coccinelle: Script to detect incorrect argument to sizeof Coccinelle: Script to use ARRAY_SIZE instead of division of two sizeofs Coccinelle: Script to detect cast after memory allocation coccinelle/null: solve parse error Documentation: headers_install.txt is part of kbuild kbuild: make -s should be used with kernelrelease/kernelversion/image_name
2014-08-08scripts/coccinelle/free/ifnullfree.cocci: add copyright informationFabian Frederick
All coccinelle scripts have a copyright in the header. Signed-off-by: Fabian Frederick <fabf@skynet.be> Suggested-by: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08scripts/coccinelle/free: add NULL test before freeing functionsFabian Frederick
Warns or generates patch for NULL check before the following functions: kfree usb_free_urb debugfs_remove debugfs_remove_recursive Signed-off-by: Fabian Frederick <fabf@skynet.be> Acked-by: Julia Lawall <Julia.Lawall@lip6.fr> Cc: Gilles Muller <Gilles.Muller@lip6.fr> Cc: Joe Perches <joe@perches.com> Cc: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-06Coccinelle: Script to replace if and BUG with BUG_ONHimangi Saraogi
This script detects cases where BUG() follows an if condition on an expression and replaces the if condition and BUG() with a BUG_ON having the conditional expression of the if statement as argument. Signed-off-by: Himangi Saraogi <himangi774@gmail.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-08-06Coccinelle: Script to detect incorrect argument to sizeofHimangi Saraogi
This makes an effort to find cases where the argument to sizeof is wrong in memory allocation functions by checking the type of the allocated memory when it is a double pointer and ensuring the sizeof argument takes a pointer to the the memory being allocated. There are false positives in cases the sizeof argument is not used in constructing the return value. Signed-off-by: Himangi Saraogi <himangi774@gmail.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-08-06Coccinelle: Script to use ARRAY_SIZE instead of division of two sizeofsHimangi Saraogi
This script detects cases where ARRAY_SIZE can be used such as where there is a division of sizeof the array by the sizeof its first element or by any indexed element or the element type. It replaces the division of the two sizeofs by ARRAY_SIZE. Signed-off-by: Himangi Saraogi <himangi774@gmail.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-08-06Coccinelle: Script to detect cast after memory allocationHimangi Saraogi
This script detects cases of use of cast for the value returned by kmalloc, kzalloc, kcalloc, kmem_cache_alloc, kmem_cache_zalloc, kmem_cache_alloc_node, kmalloc_node and kzalloc_node and removes the cast as it is not useful. This Coccinelle script replaces drop_kmalloc_cast.cocci as it removes the casting in more limited cases of kmalloc, kzalloc and kcalloc. Signed-off-by: Himangi Saraogi <himangi774@gmail.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-08-06coccinelle/null: solve parse errorHimangi Saraogi
This patch solves the parse-error by adding @@ . This is necessary since Coccinelle version 1.0.0-rc20. Also, the comment is added to use a recent version of Coccinelle. Signed-off-by: Himangi Saraogi <himangi774@gmail.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-06-19devres: remove devm_request_and_ioremap()Jingoo Han
devm_request_and_ioremap() was obsoleted by the commit 7509657 ("lib: devres: Introduce devm_ioremap_resource()") and has been deprecated for a long time. So, let's remove this function. In addition, all usages of devm_request_and_ioremap() are also removed. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-10coccicheck: Add unneeded return variable testPeter Senna Tschudin
This semantic patch looks for variables that are initialized with a constant, are never updated, and are only used as parameter of return. Return the constant instead of using a variable. Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-06-09coccinelle: Check for missing NULL terminators in of_device_id tablesStephen Boyd
Failure to terminate an of_device_id table can lead to confusing failures depending on where the compiler places the array. Add a check to make sure these tables are terminated. Thanks to Mitchel Humpherys for coming up with the pattern initially. Cc: Mitchel Humpherys <mitchelh@codeaurora.org> Cc: Gilles Muller <Gilles.Muller@lip6.fr> Cc: Nicolas Palix <nicolas.palix@imag.fr> Cc: Rob Herring <robh+dt@kernel.org> Cc: devicetree@vger.kernel.org Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Acked-by: Grant Likely <grant.likely@linaro.org> Signed-off-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-04-08scripts/coccinelle: Use PTR_ERR_OR_ZEROSachin Kamat
PTR_RET is deprecated. Do not recommend its usage anymore. Use PTR_ERR_OR_ZERO instead. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-03-29Coccicheck: Remove memcpy to struct assignment testPeter Senna Tschudin
The Coccinelle script scripts/coccinelle/misc/memcpy-assign.cocci look for opportunities to replace a call to memcpy by a struct assignment. This patch removes memcpy-assign.cocci as it is not clear that this convention has an impact on the generated code. Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-01-03scripts: Coccinelle script for pm_runtime_* return checks with IS_ERR_VALUENishanth Menon
As indicated by Sekhar in [1], there seems to be a tendency to use IS_ERR_VALUE to check the error result for pm_runtime_* functions which make no sense considering commit c48cd65 (ARM: OMAP: use consistent error checking) - the error values can either be < 0 for error OR 0, 1 in cases where we have success. So, setup a coccinelle script to help identify the same. [1] http://marc.info/?t=138472678100003&r=1&w=2 Cc: Russell King <rmk+kernel@arm.linux.org.uk> Reported-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-10-23scripts/coccinelle/api: remove devm_request_and_ioremap.cocciWolfram Sang
Use of this function is discouraged in favour of devm_ioremap_resource(). Don't advertise it. Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-09-07Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull misc kbuild updates from Michal Marek: "In the kbuild misc branch, I have: - make rpm-pkg updates, most importantly the rpm package now calls /sbin/installkernel - make deb-pkg: debuginfo split, correct kernel image path for parisc, mips and powerpc and a couple more minor fixes - New coccinelle check" * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: scripts/checkkconfigsymbols.sh: replace echo -e with printf Provide version number for Debian firmware package coccinelle: replace 0/1 with false/true in functions returning bool deb-pkg: add a hook argument to match debian hooks parameters deb-pkg: fix installed image path on parisc, mips and powerpc deb-pkg: split debug symbols in their own package deb-pkg: use KCONFIG_CONFIG instead of .config file directly rpm-pkg: add generation of kernel-devel rpm-pkg: install firmware files in kernel relative directory rpm-pkg: add %post section to create initramfs and grub hooks
2013-08-13coccinelle: replace 0/1 with false/true in functions returning boolRasmus Villemoes
This semantic patch replaces "return {0,1};" with "return {false,true};" in functions returning bool. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Acked-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-07-15PTR_RET is now PTR_ERR_OR_ZERO(): Replace most.Rusty Russell
Sweep of the simple cases. Cc: netdev@vger.kernel.org Cc: linuxppc-dev@lists.ozlabs.org Cc: linux-arm-kernel@lists.infradead.org Cc: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-07-03Coccinelle: Update the options used to the new option schemeNicolas Palix
spatch has changed its option scheme. E.g., --no_show_diff is now --no-show-diff This patch updates: - scripts/coccicheck - Semantic patches under scripts/coccinelle/ Signed-off-by: Nicolas Palix <nicolas.palix@imag.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-07-03scripts: Coccinelle script for pci_free_consistent()strnape1@fel.cvut.cz
Created coccinelle script for reporting missing pci_free_consistent() calls. Signed-off-by: Petr Strnad <strnape1@fel.cvut.cz> Signed-off-by: Nicolas Palix <nicolas.palix@imag.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-06-14scripts/coccinelle: check for field address argument to kfreeJulia Lawall
The argument to kfree should not be the address of a structure field. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-02-27Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull misc non-critical kbuild changes from Michal Marek: - Fix for make TAGS - Fix for make rpm - Some new coccinelle semantic patches * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: scripts/coccinelle: find constant additions that could be bit ors coccicheck: Allow to show the executed command line coccicheck: Allow the user to give a V= (verbose) argument scripts/coccinelle/misc/memcpy-assign.cocci: Replace memcpy with struct assignment kbuild: clear KBUILD_SRC when calling 'make' in RPM spec scripts/coccinelle/misc/semicolon.cocci: Add unneeded semicolon test scripts/tags.sh: Fix regex syntax for etags
2013-02-22scripts/coccinelle: find constant additions that could be bit orsJulia Lawall
Semantic patch (http://coccinelle.lip6.fr/) to check for constants that are added but are used elsewhere as bitmasks. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-02-22scripts/coccinelle/misc/memcpy-assign.cocci: Replace memcpy with struct ↵Peter Senna Tschudin
assignment There are error-prone memcpy() that can be replaced by struct assignment that are type-safe and much easier to read. This semantic patch looks for memcpy() that can be replaced by struct assignment. Inspired by patches sent by Ezequiel Garcia <elezegarcia@gmail.com> Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-01-24scripts/coccinelle/misc/semicolon.cocci: Add unneeded semicolon testPeter Senna Tschudin
This semantic patch looks for semicolons that can be removed without changing the semantics of the code. The confidence is moderate because there are some false positives on cases like: b/drivers/mmc/host/cb710-mmc.c:589 break; case MMC_POWER_UP: default: - /* ignore */; } There are 37 patches accepted reported by this semantic patch and more than 300 fixes to be applied. Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-01-22lib: devres: Introduce devm_ioremap_resource()Thierry Reding
The devm_request_and_ioremap() function is very useful and helps avoid a whole lot of boilerplate. However, one issue that keeps popping up is its lack of a specific error code to determine which of the steps that it performs failed. Furthermore, while the function gives an example and suggests what error code to return on failure, a wide variety of error codes are used throughout the tree. In an attempt to fix these problems, this patch adds a new function that drivers can transition to. The devm_ioremap_resource() returns a pointer to the remapped I/O memory on success or an ERR_PTR() encoded error code on failure. Callers can check for failure using IS_ERR() and determine its cause by extracting the error code using PTR_ERR(). devm_request_and_ioremap() is implemented as a wrapper around the new API and return NULL on failure as before. This ensures that backwards compatibility is maintained until all users have been converted to the new API, at which point the old devm_request_and_ioremap() function should be removed. A semantic patch is included which can be used to convert from the old devm_request_and_ioremap() API to the new devm_ioremap_resource() API. Some non-trivial cases may require manual intervention, though. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Cc: Arnd Bergmann <arnd@arndb.de> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-20Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild misc changes from Michal Marek: "This is the non-critical part of kbuild - scripts/kernel-doc requires a "Return:" section for non-void functions - ARCH=arm SUBARCH=... support for make tags - COMPILED_SOURCE=1 support for make tags (only indexes .c files for which a .o exists) - New coccinelle check - Option parsing fix for scripts/config" * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: scripts/config: Fix wrong "shift" for --keep-case scripts/tags.sh: Support compiled source scripts/tags.sh: Support subarch for ARM scripts/coccinelle/misc/warn.cocci: use WARN scripts/kernel-doc: check that non-void fcts describe their return value Kernel-doc: Convention: Use a "Return" section to describe return values
2012-12-18Coccinelle: add api/d_find_alias.cocciCyril Roelandt
Ensure that calls to d_find_alias() have a corresponding dput(). Signed-off-by: Cyril Roelandt <tipecaml@gmail.com> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Cc: Gilles Muller <Gilles.Muller@lip6.fr> Cc: Nicolas Palix <nicolas.palix@imag.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-09scripts/coccinelle/misc/warn.cocci: use WARNJulia Lawall
Use WARN(1,...) rather than printk followed by WARN(1). Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-10-12Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild misc changes from Michal Marek: "In the non-critical part of kbuild, I have - Some make coccicheck improvements and two new tests - Support for a cleaner html output in scripts/kernel-doc, named html5 (no, it does not play videos, yet) BTW, Randy wants to route further kernel-doc patches through the kbuild tree." * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: Update SmPL/Coccinelle section of MAINTAINERS coccicheck: Add the rep+ctxt mode scripts/coccinelle/tests/odd_ptr_err.cocci: semantic patch for IS_ERR/PTR_ERR inconsistency scripts/tags.sh: Add magic for pci access functions scripts/coccinelle: ptr_ret: Add ternary operator version scripts/kernel-doc: drop maintainer scripts/kernel-doc: added support for html5
2012-10-11scripts/coccinelle/tests/odd_ptr_err.cocci: semantic patch for ↵Julia Lawall
IS_ERR/PTR_ERR inconsistency Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-10-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull the trivial tree from Jiri Kosina: "Tiny usual fixes all over the place" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits) doc: fix old config name of kprobetrace fs/fs-writeback.c: cleanup riteback_sb_inodes kerneldoc btrfs: fix the commment for the action flags in delayed-ref.h btrfs: fix trivial typo for the comment of BTRFS_FREE_INO_OBJECTID vfs: fix kerneldoc for generic_fh_to_parent() treewide: fix comment/printk/variable typos ipr: fix small coding style issues doc: fix broken utf8 encoding nfs: comment fix platform/x86: fix asus_laptop.wled_type module parameter mfd: printk/comment fixes doc: getdelays.c: remember to close() socket on error in create_nl_socket() doc: aliasing-test: close fd on write error mmc: fix comment typos dma: fix comments spi: fix comment/printk typos in spi Coccinelle: fix typo in memdup_user.cocci tmiofb: missing NULL pointer checks tools: perf: Fix typo in tools/perf tools/testing: fix comment / output typos ...
2012-09-01Coccinelle: fix typo in memdup_user.cocciFengguang Wu
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-08-31scripts/coccinelle: ptr_ret: Add ternary operator versionLars-Peter Clausen
Add a ternary operator version of the open-coded PTR_RET(). Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-07-13scripts/coccinelle: list iterator variable semantic patchJulia Lawall
If list_for_each_entry, etc complete a traversal of the list, the iterator variable ends up pointing to an address at an offset from the list head, and not a meaningful structure. Thus this value should not be used after the end of the iterator. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-07-13scripts/coccinelle: Find threaded IRQs requests which are missing IRQF_ONESHOTLars-Peter Clausen
Since commit 1c6c69525b ("genirq: Reject bogus threaded irq requests") threaded IRQs without a primary handler need to be requested with IRQF_ONESHOT, otherwise the request will fail. This semantic patch will help to statically identify (and fix) such cases. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-05-28Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull misc kbuild changes from Michal Marek: "The non-critical part of kbuild for 3.5 includes - two new coccinelle checks - fix for make deb-pkg to include generated headers in arch/*/include I have more make-deb-pkg fixes in the backlog, but these will likely have to wait for 3.6." * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: builddeb: include autogenerated header files scripts/coccinelle: sizeof of pointer scripts/coccinelle: address test is always true
2012-05-25scripts/coccinelle: sizeof of pointerJulia Lawall
2012-05-25scripts/coccinelle: address test is always trueJulia Lawall
2012-04-05Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge batch of fixes from Andrew Morton: "The simple_open() cleanup was held back while I wanted for laggards to merge things. I still need to send a few checkpoint/restore patches. I've been wobbly about merging them because I'm wobbly about the overall prospects for success of the project. But after speaking with Pavel at the LSF conference, it sounds like they're further toward completion than I feared - apparently davem is at the "has stopped complaining" stage regarding the net changes. So I need to go back and re-review those patchs and their (lengthy) discussion." * emailed from Andrew Morton <akpm@linux-foundation.org>: (16 patches) memcg swap: use mem_cgroup_uncharge_swap fix backlight: add driver for DA9052/53 PMIC v1 C6X: use set_current_blocked() and block_sigmask() MAINTAINERS: add entry for sparse checker MAINTAINERS: fix REMOTEPROC F: typo alpha: use set_current_blocked() and block_sigmask() simple_open: automatically convert to simple_open() scripts/coccinelle/api/simple_open.cocci: semantic patch for simple_open() libfs: add simple_open() hugetlbfs: remove unregister_filesystem() when initializing module drivers/rtc/rtc-88pm860x.c: fix rtc irq enable callback fs/xattr.c:setxattr(): improve handling of allocation failures fs/xattr.c:listxattr(): fall back to vmalloc() if kmalloc() failed fs/xattr.c: suppress page allocation failure warnings from sys_listxattr() sysrq: use SEND_SIG_FORCED instead of force_sig() proc: fix mount -t proc -o AAA
2012-04-05scripts/coccinelle/api/simple_open.cocci: semantic patch for simple_open()Julia Lawall
Find instances of an open-coded simple_open() and replace them with calls to simple_open(). Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Reported-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-26scripts/coccinelle/api/ptr_ret.cocci: semantic patch for ptr_errJulia Lawall
2012-02-25coccinelle: semantic patch for bool issuesJulia Lawall
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Reviewed-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-02-25coccinelle: semantic patch to check for PTR_ERR after reassignmentJulia Lawall
