This is the result of a brute-force attempt to update the kernel to 2.6.23.
Now that we have a git tree, our effort will be a little nicer in the future.
Signed-off-by: Justin Waters <justin.waters@timesys.com>
Update to checkpatch.pl v0.06. Of note:
- do { and else handled correctly as control structures for { matching
- trailing whitespace correctly tripped when line otherwise empty
- support for const, including const foo * const bar
- multiline macros defining values correctly reported
This version of checkpatch.pl can be found at the following URL:
http://www.kernel.org/pub/linux/kernel/people/apw/checkpatch/checkpatch.pl-0.06
Full Changelog:
Andy Whitcroft (14):
Version: 0.06
cleanup the Type regular expression declarations
fix up block counting
end of line counts as a space for ++ and --
do { needs the same checks as if, for et al
handle "const foo * const a" as a valid type
add spacing checks following ;
complete whitespace lines should trip trailing whitespace check
else is also a block control structure
badly formatted else can trip function declaration
detect and report trailing statements after else
types need to be terminated by a boundary
multiline macros defining values should be surrounded by parentheses
soften the wording of the Signed-off-by: warnings
Signed-off-by: Andy Whitcroft <apw@shadowen.org>
Cc: "Randy.Dunlap" <rdunlap@xenotime.net>
This version brings a some new tests, and a host of changes to fix
false positives, of particular note:
- detect 'var ++;' and 'var --;' as a bad combination
- multistatement #defines are now checked based on statement count
- multistatement #defines with initialisation correctly reported
- checks the location of the inline keywords
- EXPORT_SYMBOL for variables are now understood
- typedefs are loosened to handle sparse etc
http://www.shadowen.org/~apw/public/checkpatch/checkpatch.pl-0.05
Full Changelog:
Andy Whitcroft (18):
Version: 0.05
macro definition checks should be for a single statement
avoid assignements only in if conditionals
declarations of function pointers need no space
multiline macros which are purely initialisation cannot be wrapped
EXPORT_SYMBOL can also directly follow a variable definition
check on the location of the inline keyword
EXPORT_SYMBOL needs to allow for attributes
ensure we do not find C99 // in strings
handle malformed #include lines
accept the {0,} form
typedefs are sensible for defining function pointer parameters
ensure { handling correctly handles nested switch() statements
trailing whitespace checks are not anchored
typedefs for sparse bitwise annotations make sense
update the type matcher to include sparse annotations
clean up indent and spacing
- check for and report #if 0
- extend checking of line lengths and spacing for .pl, .sh etc
- extends the pointer type checks to multiple levels
- updates printk handling to track newlines
- adds a wrapped patch detector
- drops the leading component of the filenames
- extends switch indent handling to switch statmentes rooted in
the context
- adds foo * bar single pointer checks
http://www.shadowen.org/~apw/public/checkpatch/checkpatch.pl-0.04
Full Changelog:
Andy Whitcroft (16):
allow checking line lengths and spacing on other source files
clean up that whitespace
sanitise the input line standardising the content of quotes
clean up pointer type * and space checks
fix up the sanitiser so it maintains the line length
apply the printk facility checks only to the first printk in a set
switch/case indent checks may anchor in the context
add a wrapped patch detector
put the #ifdef in C file checks on ice
asm volatile is acceptable
drop the leading component of the filename as patches are -p1
use the original line when reporting operator errors
correct spelling of Joel's name
Version: 0.04
add support for struct foo * bar checks
Geert Uytterhoeven (1):
Fix checkpatch.pl name in usage template
Randy Dunlap (1):
checkpatch: produce fewer lines of output
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Joel Schopp <jschopp@austin.ibm.com>
Produce one less line of output per flagged incident.
Change this:
use tabs not spaces
PATCH: /home/rddunlap/arcmsr1200014.patch4:756:
FILE: b/drivers/scsi/arcmsr/arcmsr_hba.c:1843:
+ return PCI_ERS_RESULT_NEED_RESET;$
to this:
use tabs not spaces
#756: FILE: b/drivers/scsi/arcmsr/arcmsr_hba.c:1843:
Cc: Andy Whitcroft <apw@shadowen.org>
This version brings a host of changes to cure false positives and
bugs detected on patches submitted to lkml and -mm. It also brings
a number of new tests in response to reviews, of particular note:
- catch use of volatile
- allow deprecated functions to be listed in feature-removal-schedule.txt
- warn about #ifdef's in c files
- check that spinlock_t and struct mutex use is commented
- report on architecture specific defines being used
- report memory barriers without an associated comment
Full changelog:
convert other quoted string checks to common routine
alloc deprecated functions to be listed in feature-removal-schedule.txt
split out the line length and indent for each line
improve switch block handling
handle GNU diff context lines with no leading space
tidy up tests for signed-off-by using raw mode
syntax checks for open brace placement may drop off the bottom of hunk
when a sign off is present but ugly do not report it missing
do not mistake bitfield definitions for indented labels
major update to the operator checks
prevent switch/if/while etc matching foo_switch
generify assignement in condition error message
introduce an operator context marker
Version: 0.03
scripts/checkpatch.pl should be executable, make it so.
Acked-by: Andrew Morton <akpm@linux-foundation.org>
Acked-by: Joel Schopp <jschopp@austin.ibm.com>
We are seeing increasing levels of minor patch style violations in submissions
to the mailing lists as well as making it into the tree. These detract from
the quality of the submission and cause unnessary work for reviewers.
As a first step package up the current state of the patch style checker and
include it in the kernel tree. Add instructions suggesting running it on
submissions. This adds version v0.01 of the checkpatch.pl script.
Signed-off-by: Joel Schopp <jschopp@austin.ibm.com>
Cc: Dave Jones <davej@codemonkey.org.uk>
