path: root/scripts/Makefile
2010-10-14ftrace/x86: Add support for C version of recordmcountSteven Rostedt
This patch adds the support for the C version of recordmcount and compile times show ~ 12% improvement. After verifying this works, other archs can add: HAVE_C_MCOUNT_RECORD in its Kconfig and it will use the C version of recordmcount instead of the perl version. Cc: <linux-arch@vger.kernel.org> Cc: Michal Marek <mmarek@suse.cz> Cc: linux-kbuild@vger.kernel.org Cc: John Reiser <jreiser@bitwagon.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-09-15sparc: Kill PROM console driver.David S. Miller
Many years ago when this driver was written, it had a use, but these days it's nothing but trouble and distributions should not enable it in any situation. Pretty much every console device a sparc machine could see has a bonafide real driver, making the PROM console hack unnecessary. If any new device shows up, we should write a driver instead of depending upon this crutch to save us. We've been able to take care of this even when no chip documentation exists (sunxvr500, sunxvr2500) so there are no excuses. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-02Move dtc and libfdt sources from arch/powerpc/boot to scripts/dtcDavid Gibson
The powerpc kernel always requires an Open Firmware like device tree to supply device information. On systems without OF, this comes from a flattened device tree blob. This blob is usually generated by dtc, a tool which compiles a text description of the device tree into the flattened format used by the kernel. Sometimes, the bootwrapper makes small changes to the pre-compiled device tree blob (e.g. filling in the size of RAM). To do this it uses the libfdt library. Because these are only used on powerpc, the code for both these tools is included under arch/powerpc/boot (these were imported and are periodically updated from the upstream dtc tree). However, the microblaze architecture, currently being prepared for merging to mainline also uses dtc to produce device tree blobs. A few other archs have also mentioned some interest in using dtc. Therefore, this patch moves dtc and libfdt from arch/powerpc into scripts, where it can be used by any architecture. The vast bulk of this patch is a literal move, the rest is adjusting the various Makefiles to use dtc and libfdt correctly from their new locations. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-06Revert "fix modules_install via NFS"David Woodhouse
This reverts commit 8b249b6856f16f09b0e5b79ce5f4d435e439b9d6. This 'fix' is not necessary; we just need to undo the damage caused accidentally by Igor/Mauro in 4b29631db33292d416dc395c56122ea865e7635c ("V4L/DVB (9533): cx88: Add support for TurboSight TBS8910 DVB-S PCI card") Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-01-07fix modules_install via NFSSam Ravnborg
Rafael reported: I get the following error from 'make modules_install' on my test boxes: HOSTCC firmware/ihex2fw /home/rafael/src/linux-2.6/firmware/ihex2fw.c:268: fatal error: opening dependency file firmware/.ihex2fw.d: Read-only file system compilation terminated. make[3]: *** [firmware/ihex2fw] Error 1 make[2]: *** [_modinst_post] Error 2 make[1]: *** [sub-make] Error 2 make: *** [all] Error 2 where the configuration is that the kernel is compiled on a build box with 'make O=<destdir> -j5' and then <destdir> is mounted over NFS read-only by each test box (full path to this directory is the same on the build box and on the test boxes). Then, I cd into <destdir>, run 'make modules_install' and get the error above. The issue turns out to be that we when we install firmware pick up the list of firmware blobs from firmware/Makefile. And this triggers the Makefile rules to update ihex2fw. There were two solutions for this issue: 1) Move the list of firmware blobs to a separate file 2) Avoid ihex2fw rebuild by moving it to scripts As I seriously beleive that the list of firmware blobs should be done in a fundamental different way solution 2) was selected. Reported-and-tested-by: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: David Woodhouse <dwmw2@infradead.org>
2008-08-27selinux: add support for installing a dummy policy (v2)Serge E. Hallyn
In August 2006 I posted a patch generating a minimal SELinux policy. This week, David P. Quigley posted an updated version of that as a patch against the kernel. It also had nice logic for auto-installing the policy. Following is David's original patch intro (preserved especially bc it has stats on the generated policies): se interested in the changes there were only two significant changes. The first is that the iteration through the list of classes used NULL as a sentinel value. The problem with this is that the class_to_string array actually has NULL entries in its table as place holders for the user space object classes. The second change was that it would seem at some point the initial sids table was NULL terminated. This is no longer the case so that iteration has to be done on array length instead of looking for NULL. Some statistics on the policy that it generates: The policy consists of 523 lines which contain no blank lines. Of those 523 lines 453 of them are class, permission, and initial sid definitions. These lines are usually little to no concern to the policy developer since they will not be adding object classes or permissions. Of the remaining 70 lines there is one type, one role, and one user statement. The remaining lines are broken into three portions. The first group are TE allow rules which make up 29 of the remaining lines, the second is assignment of labels to the initial sids which consist of 27 lines, and file system labeling statements which are the remaining 11. In addition to the policy.conf generated there is a single file_contexts file containing two lines which labels the entire system with base_t. This policy generates a policy.23 binary that is 7920 bytes. (then a few versions later...): The new policy is 587 lines (stripped of blank lines) with 476 of those lines being the boilerplate that I mentioned last time. The remaining 111 lines have the 3 lines for type, user, and role, 70 lines for the allow rules (one for each object class including user space object classes), 27 lines to assign types to the initial sids, and 11 lines for file system labeling. The policy binary is 9194 bytes. Changelog: Aug 26: Added Documentation/SELinux.txt Aug 26: Incorporated a set of comments by Stephen Smalley: 1. auto-setup SELINUXTYPE=dummy 2. don't auto-install if selinux is enabled with non-dummy policy 3. don't re-compute policy version 4. /sbin/setfiles not /usr/sbin/setfiles Aug 22: As per JMorris comments, made sure make distclean cleans up the mdp directory. Removed a check for file_contexts which is now created in the same file as the check, making it superfluous. Signed-off-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: David Quigley <dpquigl@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2006-10-01[PATCH] allow /proc/config.gz to be built as a moduleRoss Biro
The driver for /proc/config.gz consumes rather a lot of memory and it is in fact possible to build it as a module. In some ways this is a bit risky, because the .config which is used for compiling kernel/configs.c isn't necessarily the same as the .config which was used to build vmlinux. But OTOH the potential memory savings are decent, and it'd be fairly dumb to build your configs.o with a different .config. Signed-off-by: Andrew Morton <akpm@google.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-25kbuild: modpost on vmlinux regardless of CONFIG_MODULESSam Ravnborg
Based on patch from: Magnus Damm <magnus@valinux.co.jp> This has the advantage that all section mismatch checks are run regardless of modules being enabled or not. When running modpost on vmlinux output: MODPOST vmlinux When running modpost on modules output count of modules like this: MODPOST 5 modules Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-25kbuild: use in-kernel unifdefSam Ravnborg
Let headers_install use in-kernel unifdef Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-12-16kconfig: move lxdialog to scripts/kconfig/lxdialogSam Ravnborg
The only lxdialog user i kconfig - for menuconfig. So move it to reflect this. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
