path: root/scripts/Makefile.build
2006-03-12kbuild: add -fverbose-asm to i386 MakefileChuck Ebbert
Add -fverbose-asm to i386 Makefile rule for building .s files. This makes the assembler output much more readable for humans. Suggested by Der Herr Hofrat <der.herr@hofr.at> Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-03-12kbuild: fix genksyms build errorSam Ravnborg
genksyms needs to know when a symbol must have a "_" prefex as is true for a few architectures. Pass $(ARCH) as commandline argument and hardcode what architectures that needs this info. Previous attemt to take it from elfconfig.h was br0ken since elfconfig.h is a generated file. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-03-06kbuild: change kbuild to not rely on incorrect GNU make behaviorPaul Smith
The kbuild system takes advantage of an incorrect behavior in GNU make. Once this behavior is fixed, all files in the kernel rebuild every time, even if nothing has changed. This patch ensures kbuild works with both the incorrect and correct behaviors of GNU make. For more details on the incorrect behavior, see: http://lists.gnu.org/archive/html/bug-make/2006-03/msg00003.html Changes in this patch: - Keep all targets that are to be marked .PHONY in a variable, PHONY. - Add .PHONY: $(PHONY) to mark them properly. - Remove any $(PHONY) files from the $? list when determining whether targets are up-to-date or not. Signed-off-by: Paul Smith <psmith@gnu.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-02-19kbuild: consolidate command line escapingJan Beulich
While the recent change to also escape # symbols when storing C-file compilation command lines was helpful, it should be in effect for all command lines, as much as the dollar escaping should be in effect for C-source compilation commands. Additionally, for better readability and maintenance, consolidating all the escaping (single quotes, dollars, and now sharps) was also desirable. Signed-Off-By: Jan Beulich <jbeulich@novell.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-02-19kbuild: make cc-version available in kbuild filesSam Ravnborg
Move $(CC) support functions to Kbuild.include so they are available in the kbuild files. In addition the following was done: o as-option documented in Documentation/kbuild/makefiles.txt o Moved documentation to new section to match new scope of functions o added cc-ifversion used to conditionally select a text string dependent on actual $(CC) version o documented cc-ifversion o change so Kbuild.include is read before the kbuild file Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-01-06kbuild: introduce escsq to escapre single quotesSam Ravnborg
This makes things a little bit more reader friendly and gvim is less confused. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-07-27kbuild: fix building external modulesSam Ravnborg
kbuild failed to locate Makefile for external modules. This brought to my attention how the variables for directories have different values in different usage scenarios. Different kbuild usage scenarios: make - plain make in same directory where kernel source lives make O= - kbuild is told to store output files in another directory make M= - building an external module make O= M= - building an external module with kernel output seperate from src Value assigned to the different variables: |$(src) |$(obj) |$(srctree) |$(objtree) make |reldir to k src |as src |abs path to k src |abs path to k src make O= |reldir to k src |as src |abs path to k src |abs path to output dir make M= |abs path to src |as src |abs path to k src |abs path to k src make O= M= |abs path to src |as src |abs path to k src |abs path to k output path to kbuild file: make | $(srctree)/$(src), $(src) make O= | $(srctree)/$(src) make M= | $(src) make O= M= | $(src) From the table above it can be seen that the only good way to find the home directory of the kbuild file is to locate the one of the two variants that is an absolute path. If $(src) is an absolute path (starts with /) then use it, otherwise prefix $(src) with $(srctree). Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-07-25kbuild: fix make O=...Sam Ravnborg
kbuild failed to locate Kbuild.include. Teach kbuild how to find Kbuild files when using make O=... Signed-off-by: Sam Ravnborg <sam@ravnborg.org> ---
2005-07-25kbuild: introduce Kbuild.includeSam Ravnborg
Kbuild.include is a placeholder for definitions originally present in both the top-level Makefile and scripts/Makefile.build. There were a slight difference in the filechk definition, so the most videly used version was kept and usr/Makefile was adopted for this syntax. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> ---
2005-07-14kbuild: Fix build as root then userSam Ravnborg
From: Matthew Wilcox <matthew@wil.cx> I inadvertently built a tree as root and then rebuilt it as a user. I got a lot of prompts ... mv: overwrite `drivers/char/drm/drm_auth.o', overriding mode 0644? Using mv -f fixes that. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-06-23[PATCH] apply quotation handling to Makefile.buildJan Beulich
Adding quotation handling to rule_cc_o_c in scripts/Makefile.build as used elsewhere. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
