Trivial conflicts in net/can/isotp.c and
tools/testing/selftests/net/mptcp/mptcp_connect.sh
scaled_ppm_to_ppb() was moved from drivers/ptp/ptp_clock.c
to include/linux/ptp_clock_kernel.h in -next so re-apply
the fix there.
Signed-off-by: Jakub Kicinski <kuba@kernel.org>
Daniel Borkmann says:
pull-request: bpf-next 2021-06-17
The following pull-request contains BPF updates for your *net-next* tree.
We've added 50 non-merge commits during the last 25 day(s) which contain
a total of 148 files changed, 4779 insertions(+), 1248 deletions(-).
The main changes are:
1) BPF infrastructure to migrate TCP child sockets from a listener to another
in the same reuseport group/map, from Kuniyuki Iwashima.
2) Add a provably sound, faster and more precise algorithm for tnum_mul() as
noted in https://arxiv.org/abs/2105.05398, from Harishankar Vishwanathan.
3) Streamline error reporting changes in libbpf as planned out in the
'libbpf: the road to v1.0' effort, from Andrii Nakryiko.
4) Add broadcast support to xdp_redirect_map(), from Hangbin Liu.
5) Extends bpf_map_lookup_and_delete_elem() functionality to 4 more map
types, that is, {LRU_,PERCPU_,LRU_PERCPU_,}HASH, from Denis Salopek.
6) Support new LLVM relocations in libbpf to make them more linker friendly,
also add a doc to describe the BPF backend relocations, from Yonghong Song.
7) Silence long standing KUBSAN complaints on register-based shifts in
interpreter, from Daniel Borkmann and Eric Biggers.
8) Add dummy PT_REGS macros in libbpf to fail BPF program compilation when
target arch cannot be determined, from Lorenz Bauer.
9) Extend AF_XDP to support large umems with 1M+ pages, from Magnus Karlsson.
10) Fix two minor libbpf tc BPF API issues, from Kumar Kartikeya Dwivedi.
11) Move libbpf BPF_SEQ_PRINTF/BPF_SNPRINTF macros that can be used by BPF
programs to bpf_helpers.h header, from Florent Revest.
xdp_sample_pkts usage() is missing the introduction of the
"-S" option, this patch adds it.
Fixes: d50ecc46d18f ("samples/bpf: Attach XDP programs in driver mode by default")
Signed-off-by: Wang Hai <wanghai38@huawei.com>
Signed-off-by: Andrii Nakryiko <andrii@kernel.org>
Acked-by: Jesper Dangaard Brouer <brouer@redhat.com>
Link: https://lore.kernel.org/bpf/20210615135724.29528-1-wanghai38@huawei.com
xdp_fwd usage() is missing the introduction of the "-S"
and "-F" options, this patch adds it.
Link: https://lore.kernel.org/bpf/20210615135554.29158-1-wanghai38@huawei.com
Pull VFIO fixes from Alex Williamson:
- Fix error path return value (Zhen Lei)
- Add vfio-pci CONFIG_MMU dependency (Randy Dunlap)
- Replace open coding with struct_size() (Gustavo A. R. Silva)
- Fix sample driver error path (Wei Yongjun)
- Fix vfio-platform error path module_put() (Max Gurtovoy)
* tag 'vfio-v5.13-rc5' of git://github.com/awilliam/linux-vfio:
vfio/platform: fix module_put call in error flow
samples: vfio-mdev: fix error handing in mdpy_fb_probe()
vfio/iommu_type1: Use struct_size() for kzalloc()
vfio/pci: zap_vma_ptes() needs MMU
vfio/pci: Fix error return code in vfio_ecap_init()
Introduce k parameter in pktgen samples in order to toggle UDP tx
checksum
Signed-off-by: Lorenzo Bianconi <lorenzo@kernel.org>
Link: https://lore.kernel.org/r/cf16417902062c6ea2fd3c79e00510e36a40c31a.1622210713.git.lorenzo@kernel.org
cdc-wdm: s/kill_urbs/poison_urbs/ to fix build
This is a sample for xdp redirect broadcast. In the sample we could forward
all packets between given interfaces. There is also an option -X that could
enable 2nd xdp_prog on egress interface.
Signed-off-by: Hangbin Liu <liuhangbin@gmail.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Toke Høiland-Jørgensen <toke@redhat.com>
Link: https://lore.kernel.org/bpf/20210519090747.1655268-4-liuhangbin@gmail.com
The opening comment mark '/**' is used for highlighting the beginning of
kernel-doc comments.
The header for samples/bpf/ibumad_kern.c follows this syntax, but
the content inside does not comply with kernel-doc.
This line was probably not meant for kernel-doc parsing, but is parsed
due to the presence of kernel-doc like comment syntax(i.e, '/**'), which
causes unexpected warnings from kernel-doc:
warning: This comment starts with '/**', but isn't a kernel-doc comment. Refer Documentation/doc-guide/kernel-doc.rst
* ibumad BPF sample kernel side
Provide a simple fix by replacing this occurrence with general comment
format, i.e. '/*', to prevent kernel-doc from parsing it.
Signed-off-by: Aditya Srivastava <yashsri421@gmail.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
Link: https://lore.kernel.org/bpf/20210523151408.22280-1-yashsri421@gmail.com
Fix to return a negative error code from the framebuffer_alloc() error
handling case instead of 0, also release regions in some error handing
cases.
Fixes: cacade1946a4 ("sample: vfio mdev display - guest driver")
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
Message-Id: <20210520133641.1421378-1-weiyongjun1@huawei.com>
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
While cross compiling on ARM32 , the casting from pointer to __u64 will
cause warnings:
samples/bpf/task_fd_query_user.c: In function 'main':
samples/bpf/task_fd_query_user.c:399:23: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
399 | uprobe_file_offset = (__u64)main - (__u64)&__executable_start;
samples/bpf/task_fd_query_user.c:399:37: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
Workaround this by using "unsigned long" to adapt to different ARCHs.
Signed-off-by: Hailong Liu <liu.hailong6@zte.com.cn>
Link: https://lore.kernel.org/bpf/20210511140429.89426-1-liuhailongg6@163.com
pull-request: bpf 2021-05-11
The following pull-request contains BPF updates for your *net* tree.
We've added 13 non-merge commits during the last 8 day(s) which contain
a total of 21 files changed, 817 insertions(+), 382 deletions(-).
1) Fix multiple ringbuf bugs in particular to prevent writable mmap of
read-only pages, from Andrii Nakryiko & Thadeu Lima de Souza Cascardo.
2) Fix verifier alu32 known-const subregister bound tracking for bitwise
operations and/or/xor, from Daniel Borkmann.
3) Reject trampoline attachment for functions with variable arguments,
and also add a deny list of other forbidden functions, from Jiri Olsa.
4) Fix nested bpf_bprintf_prepare() calls used by various helpers by
switching to per-CPU buffers, from Florent Revest.
5) Fix kernel compilation with BTF debug info on ppc64 due to pahole
missing TCP-CC functions like cubictcp_init, from Martin KaFai Lau.
6) Add a kconfig entry to provide an option to disallow unprivileged
BPF by default, from Daniel Borkmann.
7) Fix libbpf compilation for older libelf when GELF_ST_VISIBILITY()
macro is not available, from Arnaldo Carvalho de Melo.
8) Migrate test_tc_redirect to test_progs framework as prep work
for upcoming skb_change_head() fix & selftest, from Jussi Maki.
9) Fix a libbpf segfault in add_dummy_ksym_var() if BTF is not
present, from Ian Rogers.
10) Fix tx_only micro-benchmark in xdpsock BPF sample with proper frame
size, from Magnus Karlsson.
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild
Pull more Kbuild updates from Masahiro Yamada:
- Convert sh and sparc to use generic shell scripts to generate the
syscall headers
- refactor .gitignore files
- Update kernel/config_data.gz only when the content of the .config
is really changed, which avoids the unneeded re-link of vmlinux
- move "remove stale files" workarounds to scripts/remove-stale-files
- suppress unused-but-set-variable warnings by default for Clang
as well
- fix locale setting LANG=C to LC_ALL=C
- improve 'make distclean'
- always keep intermediate objects from scripts/link-vmlinux.sh
- move IF_ENABLED out of <linux/kconfig.h> to make it self-contained
- misc cleanups
* tag 'kbuild-v5.13-2' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild: (25 commits)
linux/kconfig.h: replace IF_ENABLED() with PTR_IF() in <linux/kernel.h>
kbuild: Don't remove link-vmlinux temporary files on exit/signal
kbuild: remove the unneeded comments for external module builds
kbuild: make distclean remove tag files in sub-directories
kbuild: make distclean work against $(objtree) instead of $(srctree)
kbuild: refactor modname-multi by using suffix-search
kbuild: refactor fdtoverlay rule
kbuild: parameterize the .o part of suffix-search
arch: use cross_compiling to check whether it is a cross build or not
kbuild: remove ARCH=sh64 support from top Makefile
.gitignore: prefix local generated files with a slash
kbuild: replace LANG=C with LC_ALL=C
Makefile: Move -Wno-unused-but-set-variable out of GCC only block
kbuild: add a script to remove stale generated files
kbuild: update config_data.gz only when the content of .config is changed
.gitignore: ignore only top-level modules.builtin
.gitignore: move tags and TAGS close to other tag files
kernel/.gitgnore: remove stale timeconst.h and hz.bc
usr/include: refactor .gitignore
genksyms: fix stale comment
Merge yet more updates from Andrew Morton:
"This is everything else from -mm for this merge window.
90 patches.
Subsystems affected by this patch series: mm (cleanups and slub),
alpha, procfs, sysctl, misc, core-kernel, bitmap, lib, compat,
checkpatch, epoll, isofs, nilfs2, hpfs, exit, fork, kexec, gcov,
panic, delayacct, gdb, resource, selftests, async, initramfs, ipc,
drivers/char, and spelling"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (90 commits)
mm: fix typos in comments
treewide: remove editor modelines and cruft
ipc/sem.c: spelling fix
fs: fat: fix spelling typo of values
kernel/sys.c: fix typo
kernel/up.c: fix typo
kernel/user_namespace.c: fix typos
kernel/umh.c: fix some spelling mistakes
include/linux/pgtable.h: few spelling fixes
mm/slab.c: fix spelling mistake "disired" -> "desired"
scripts/spelling.txt: add "overflw"
scripts/spelling.txt: Add "diabled" typo
scripts/spelling.txt: add "overlfow"
arm: print alloc free paths for address in registers
mm/vmalloc: remove vwrite()
mm: remove xlate_dev_kmem_ptr()
drivers/char: remove /dev/kmem for good
mm: fix some typos and code style problems
ipc/sem.c: mundane typo fixes
The section "19) Editor modelines and other cruft" in
Documentation/process/coding-style.rst clearly says, "Do not include any
of these in source files."
I recently receive a patch to explicitly add a new one.
Let's do treewide cleanups, otherwise some people follow the existing code
and attempt to upstream their favoriate editor setups.
It is even nicer if scripts/checkpatch.pl can check it.
If we like to impose coding style in an editor-independent manner, I think
editorconfig (patch [1]) is a saner solution.
[1] https://lore.kernel.org/lkml/20200703073143.423557-1-danny@kdrag0n.dev/
Link: https://lkml.kernel.org/r/20210324054457.1477489-1-masahiroy@kernel.org
Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Reviewed-by: Miguel Ojeda <ojeda@kernel.org> [auxdisplay]
Fix the tx_only micro-benchmark in xdpsock to take frame size into
consideration. It was hardcoded to the default value of frame_size
which is 4K. Changing this on the command line to 2K made half of the
packets illegal as they were outside the umem and were therefore
discarded by the kernel.
Fixes: 46738f73ea4f ("samples/bpf: add use of need_wakeup flag in xdpsock")
Signed-off-by: Magnus Karlsson <magnus.karlsson@intel.com>
Acked-by: Maciej Fijalkowski <maciej.fijalkowski@intel.com>
Link: https://lore.kernel.org/bpf/20210506124349.6666-1-magnus.karlsson@gmail.com
Pull more VFIO updates from Alex Williamson:
"A second small set of commits for this merge window, primarily to
unbreak some deletions from our uAPI header.
- Additional mdev sample driver cleanup (Dan Carpenter)
- Doc fix (Alyssa Ross)
- Unbreak uAPI from NVLink2 support removal (Alex Williamson)"
* tag 'vfio-v5.13-rc1pt2' of git://github.com/awilliam/linux-vfio:
docs: vfio: fix typo
vfio/pci: Revert nvlink removal uAPI breakage
vfio/mdev: remove unnecessary NULL check in mbochs_create()
git://git.kernel.org/pub/scm/linux/kernel/git/riscv/linux
Pull RISC-V updates from Palmer Dabbelt:
- Support for the memtest= kernel command-line argument.
- Support for building the kernel with FORTIFY_SOURCE.
- Support for generic clockevent broadcasts.
- Support for the buildtar build target.
- Some build system cleanups to pass more LLVM-friendly arguments.
- Support for kprobes.
- A rearranged kernel memory map, the first part of supporting sv48
systems.
- Improvements to kexec, along with support for kdump and crash
kernels.
- An alternatives-based errata framework, along with support for
handling a pair of errata that manifest on some SiFive designs
(including the HiFive Unmatched).
- Support for XIP.
- A device tree for the Microchip PolarFire ICICLE SoC and associated
dev board.
... along with a bunch of cleanups. There are already a handful of fixes
on the list so there will likely be a part 2.
* tag 'riscv-for-linus-5.13-mw0' of git://git.kernel.org/pub/scm/linux/kernel/git/riscv/linux: (45 commits)
RISC-V: Always define XIP_FIXUP
riscv: Remove 32b kernel mapping from page table dump
riscv: Fix 32b kernel build with CONFIG_DEBUG_VIRTUAL=y
RISC-V: Fix error code returned by riscv_hartid_to_cpuid()
RISC-V: Enable Microchip PolarFire ICICLE SoC
RISC-V: Initial DTS for Microchip ICICLE board
dt-bindings: riscv: microchip: Add YAML documentation for the PolarFire SoC
RISC-V: Add Microchip PolarFire SoC kconfig option
RISC-V: enable XIP
RISC-V: Add crash kernel support
RISC-V: Add kdump support
RISC-V: Improve init_resources()
RISC-V: Add kexec support
RISC-V: Add EM_RISCV to kexec UAPI header
riscv: vdso: fix and clean-up Makefile
riscv/mm: Use BUG_ON instead of if condition followed by BUG.
riscv/kprobe: fix kernel panic when invoking sys_read traced by kprobe
riscv: Set ARCH_HAS_STRICT_MODULE_RWX if MMU
riscv: module: Create module allocations without exec permissions
riscv: bpf: Avoid breaking W^X
Originally "type" could be NULL and these checks were required, but we
recently changed how "type" is assigned and that's no longer the case.
Now "type" points to an element in the middle of a non-NULL array.
Removing the checks does not affect runtime at all, but it makes the
code a little bit simpler to read.
Fixes: 3d3a360e570616 ("vfio/mbochs: Use mdev_get_type_group_id()")
Reviewed-by: Jason Gunthorpe <jgg@nvidia.com>
Message-Id: <20210429095327.GY1981@kadam>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull Landlock LSM from James Morris:
"Add Landlock, a new LSM from Mickaël Salaün.
Briefly, Landlock provides for unprivileged application sandboxing.
From Mickaël's cover letter:
"The goal of Landlock is to enable to restrict ambient rights (e.g.
global filesystem access) for a set of processes. Because Landlock
is a stackable LSM [1], it makes possible to create safe security
sandboxes as new security layers in addition to the existing
system-wide access-controls. This kind of sandbox is expected to
help mitigate the security impact of bugs or unexpected/malicious
behaviors in user-space applications. Landlock empowers any
process, including unprivileged ones, to securely restrict
themselves.
Landlock is inspired by seccomp-bpf but instead of filtering
syscalls and their raw arguments, a Landlock rule can restrict the
use of kernel objects like file hierarchies, according to the
kernel semantic. Landlock also takes inspiration from other OS
sandbox mechanisms: XNU Sandbox, FreeBSD Capsicum or OpenBSD
Pledge/Unveil.
In this current form, Landlock misses some access-control features.
This enables to minimize this patch series and ease review. This
series still addresses multiple use cases, especially with the
combined use of seccomp-bpf: applications with built-in sandboxing,
init systems, security sandbox tools and security-oriented APIs [2]"
The cover letter and v34 posting is here:
https://lore.kernel.org/linux-security-module/20210422154123.13086-1-mic@digikod.net/
See also:
https://landlock.io/
This code has had extensive design discussion and review over several
years"
Link: https://lore.kernel.org/lkml/50db058a-7dde-441b-a7f9-f6837fe8b69f@schaufler-ca.com/ [1]
Link: https://lore.kernel.org/lkml/f646e1c7-33cf-333f-070c-0a40ad0468cd@digikod.net/ [2]
* tag 'landlock_v34' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security:
landlock: Enable user space to infer supported features
landlock: Add user and kernel documentation
samples/landlock: Add a sandbox manager example
selftests/landlock: Add user space tests
landlock: Add syscall implementations
arch: Wire up Landlock syscalls
fs,security: Add sb_delete hook
landlock: Support filesystem access-control
LSM: Infrastructure management of the superblock
landlock: Add ptrace restrictions
landlock: Set up the security framework and manage credentials
landlock: Add ruleset and domain management
landlock: Add object management
The pattern prefixed with '/' matches files in the same directory,
but not ones in sub-directories.
Acked-by: Miguel Ojeda <ojeda@kernel.org>
Acked-by: Rob Herring <robh@kernel.org>
Acked-by: Andra Paraschiv <andraprs@amazon.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Gabriel Krisman Bertazi <krisman@collabora.com>
Patch series "remap_vmalloc_range cleanups".
This series removes an open coded instance of remap_vmalloc_range and
removes the unused remap_vmalloc_range_partial export.
This patch (of 2):
Use remap_vmalloc_range instead of open coding it using
remap_vmalloc_range_partial.
Link: https://lkml.kernel.org/r/20210301082235.932968-1-hch@lst.de
Link: https://lkml.kernel.org/r/20210301082235.932968-2-hch@lst.de
Cc: Kirti Wankhede <kwankhede@nvidia.com>
The intent with this code was to return negative error codes but instead
it returns positives.
The problem is how type promotion works with ternary operations. These
functions return long, "ret" is an int and "copied" is a u32. The
negative error code is first cast to u32 so it becomes a high positive and
then cast to long where it's still a positive.
We could fix this by declaring "ret" as a ssize_t but let's just get rid
of the ternaries instead.
Link: https://lkml.kernel.org/r/YIE+/cK1tBzSuQPU@mwanda
Fixes: 5bf2b19320ec ("kfifo: add example files to the kernel sample directory")
Cc: Stefani Seibold <stefani@seibold.net>
git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net-next
Pull networking updates from Jakub Kicinski:
"Core:
- bpf:
- allow bpf programs calling kernel functions (initially to
reuse TCP congestion control implementations)
- enable task local storage for tracing programs - remove the
need to store per-task state in hash maps, and allow tracing
programs access to task local storage previously added for
BPF_LSM
- add bpf_for_each_map_elem() helper, allowing programs to walk
all map elements in a more robust and easier to verify fashion
- sockmap: support UDP and cross-protocol BPF_SK_SKB_VERDICT
redirection
- lpm: add support for batched ops in LPM trie
- add BTF_KIND_FLOAT support - mostly to allow use of BTF on
s390 which has floats in its headers files
- improve BPF syscall documentation and extend the use of kdoc
parsing scripts we already employ for bpf-helpers
- libbpf, bpftool: support static linking of BPF ELF files
- improve support for encapsulation of L2 packets
- xdp: restructure redirect actions to avoid a runtime lookup,
improving performance by 4-8% in microbenchmarks
- xsk: build skb by page (aka generic zerocopy xmit) - improve
performance of software AF_XDP path by 33% for devices which don't
need headers in the linear skb part (e.g. virtio)
- nexthop: resilient next-hop groups - improve path stability on
next-hops group changes (incl. offload for mlxsw)
- ipv6: segment routing: add support for IPv4 decapsulation
- icmp: add support for RFC 8335 extended PROBE messages
- inet: use bigger hash table for IP ID generation
- tcp: deal better with delayed TX completions - make sure we don't
give up on fast TCP retransmissions only because driver is slow in
reporting that it completed transmitting the original
- tcp: reorder tcp_congestion_ops for better cache locality
- mptcp:
- add sockopt support for common TCP options
- add support for common TCP msg flags
- include multiple address ids in RM_ADDR
- add reset option support for resetting one subflow
- udp: GRO L4 improvements - improve 'forward' / 'frag_list'
co-existence with UDP tunnel GRO, allowing the first to take place
correctly even for encapsulated UDP traffic
- micro-optimize dev_gro_receive() and flow dissection, avoid
retpoline overhead on VLAN and TEB GRO
- use less memory for sysctls, add a new sysctl type, to allow using
u8 instead of "int" and "long" and shrink networking sysctls
- veth: allow GRO without XDP - this allows aggregating UDP packets
before handing them off to routing, bridge, OvS, etc.
- allow specifing ifindex when device is moved to another namespace
- netfilter:
- nft_socket: add support for cgroupsv2
- nftables: add catch-all set element - special element used to
define a default action in case normal lookup missed
- use net_generic infra in many modules to avoid allocating
per-ns memory unnecessarily
- xps: improve the xps handling to avoid potential out-of-bound
accesses and use-after-free when XPS change race with other
re-configuration under traffic
- add a config knob to turn off per-cpu netdev refcnt to catch
underflows in testing
Device APIs:
- add WWAN subsystem to organize the WWAN interfaces better and
hopefully start driving towards more unified and vendor-
independent APIs
- ethtool:
- add interface for reading IEEE MIB stats (incl. mlx5 and bnxt
support)
- allow network drivers to dump arbitrary SFP EEPROM data,
current offset+length API was a poor fit for modern SFP which
define EEPROM in terms of pages (incl. mlx5 support)
- act_police, flow_offload: add support for packet-per-second
policing (incl. offload for nfp)
- psample: add additional metadata attributes like transit delay for
packets sampled from switch HW (and corresponding egress and
policy-based sampling in the mlxsw driver)
- dsa: improve support for sandwiched LAGs with bridge and DSA
- netfilter:
- flowtable: use direct xmit in topologies with IP forwarding,
bridging, vlans etc.
- nftables: counter hardware offload support
- Bluetooth:
- improvements for firmware download w/ Intel devices
- add support for reading AOSP vendor capabilities
- add support for virtio transport driver
- mac80211:
- allow concurrent monitor iface and ethernet rx decap
- set priority and queue mapping for injected frames
- phy: add support for Clause-45 PHY Loopback
- pci/iov: add sysfs MSI-X vector assignment interface to distribute
MSI-X resources to VFs (incl. mlx5 support)
New hardware/drivers:
- dsa: mv88e6xxx: add support for Marvell mv88e6393x - 11-port
Ethernet switch with 8x 1-Gigabit Ethernet and 3x 10-Gigabit
interfaces.
- dsa: support for legacy Broadcom tags used on BCM5325, BCM5365 and
BCM63xx switches
- Microchip KSZ8863 and KSZ8873; 3x 10/100Mbps Ethernet switches
- ath11k: support for QCN9074 a 802.11ax device
- Bluetooth: Broadcom BCM4330 and BMC4334
- phy: Marvell 88X2222 transceiver support
- mdio: add BCM6368 MDIO mux bus controller
- r8152: support RTL8153 and RTL8156 (USB Ethernet) chips
- mana: driver for Microsoft Azure Network Adapter (MANA)
- Actions Semi Owl Ethernet MAC
- can: driver for ETAS ES58X CAN/USB interfaces
Pure driver changes:
- add XDP support to: enetc, igc, stmmac
- add AF_XDP support to: stmmac
- virtio:
- page_to_skb() use build_skb when there's sufficient tailroom
(21% improvement for 1000B UDP frames)
- support XDP even without dedicated Tx queues - share the Tx
queues with the stack when necessary
- mlx5:
- flow rules: add support for mirroring with conntrack, matching
on ICMP, GTP, flex filters and more
- support packet sampling with flow offloads
- persist uplink representor netdev across eswitch mode changes
- allow coexistence of CQE compression and HW time-stamping
- add ethtool extended link error state reporting
- ice, iavf: support flow filters, UDP Segmentation Offload
- dpaa2-switch:
- move the driver out of staging
- add spanning tree (STP) support
- add rx copybreak support
- add tc flower hardware offload on ingress traffic
- ionic:
- implement Rx page reuse
- support HW PTP time-stamping
- octeon: support TC hardware offloads - flower matching on ingress
and egress ratelimitting.
- stmmac:
- add RX frame steering based on VLAN priority in tc flower
- support frame preemption (FPE)
- intel: add cross time-stamping freq difference adjustment
- ocelot:
- support forwarding of MRP frames in HW
- support multiple bridges
- support PTP Sync one-step timestamping
- dsa: mv88e6xxx, dpaa2-switch: offload bridge port flags like
learning, flooding etc.
- ipa: add IPA v4.5, v4.9 and v4.11 support (Qualcomm SDX55, SM8350,
SC7280 SoCs)
- mt7601u: enable TDLS support
- mt76:
- add support for 802.3 rx frames (mt7915/mt7615)
- mt7915 flash pre-calibration support
- mt7921/mt7663 runtime power management fixes"
* tag 'net-next-5.13' of git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net-next: (2451 commits)
net: selftest: fix build issue if INET is disabled
net: netrom: nr_in: Remove redundant assignment to ns
net: tun: Remove redundant assignment to ret
net: phy: marvell: add downshift support for M88E1240
net: dsa: ksz: Make reg_mib_cnt a u8 as it never exceeds 255
net/sched: act_ct: Remove redundant ct get and check
icmp: standardize naming of RFC 8335 PROBE constants
bpf, selftests: Update array map tests for per-cpu batched ops
bpf: Add batched ops support for percpu array
bpf: Implement formatted output helpers with bstr_printf
seq_file: Add a seq_bprintf function
sfc: adjust efx->xdp_tx_queue_count with the real number of initialized queues
net:nfc:digital: Fix a double free in digital_tg_recv_dep_req
net: fix a concurrency bug in l2tp_tunnel_register()
net/smc: Remove redundant assignment to rc
mpls: Remove redundant assignment to err
llc2: Remove redundant assignment to rc
net/tls: Remove redundant initialization of record
rds: Remove redundant assignment to nr_sig
dt-bindings: net: mdio-gpio: add compatible for microchip,mdio-smi0
Add riscv specific info dump in both handler_pre() and handler_post().
Signed-off-by: Jisheng Zhang <jszhang@kernel.org>
Acked-by: Masami Hiramatsu <mhiramat@kernel.org>
Signed-off-by: Palmer Dabbelt <palmerdabbelt@google.com>
Add a basic sandbox tool to launch a command which can only access a
list of file hierarchies in a read-only or read-write way.
Cc: Serge E. Hallyn <serge@hallyn.com>
Signed-off-by: Mickaël Salaün <mic@linux.microsoft.com>
Reviewed-by: Jann Horn <jannh@google.com>
Link: https://lore.kernel.org/r/20210422154123.13086-12-mic@digikod.net
Signed-off-by: James Morris <jamorris@linux.microsoft.com>
>From commit c0bbbdc32feb ("__netif_receive_skb_core: pass skb by
reference"), the first argument passed into __netif_receive_skb_core
has changed to reference of a skb pointer.
This commit fixes by using bpf_probe_read_kernel.
Signed-off-by: Yaqi Chen <chendotjs@gmail.com>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
Acked-by: Yonghong Song <yhs@fb.com>
Link: https://lore.kernel.org/bpf/20210416154803.37157-1-chendotjs@gmail.com
The driver core standard is to pass in the properly typed object, the
properly typed attribute and the buffer data. It stems from the root
kobject method:
ssize_t (*show)(struct kobject *kobj, struct kobj_attribute *attr,..)
Each subclass of kobject should provide their own function with the same
signature but more specific types, eg struct device uses:
ssize_t (*show)(struct device *dev, struct device_attribute *attr,..)
In this case the existing signature is:
ssize_t (*show)(struct kobject *kobj, struct device *dev,..)
Where kobj is a 'struct mdev_type *' and dev is 'mdev_type->parent->dev'.
Change the mdev_type related sysfs attribute functions to:
ssize_t (*show)(struct mdev_type *mtype, struct mdev_type_attribute *attr,..)
In order to restore type safety and match the driver core standard
There are no current users of 'attr', but if it is ever needed it would be
hard to add in retroactively, so do it now.
Reviewed-by: Kevin Tian <kevin.tian@intel.com>
Reviewed-by: Cornelia Huck <cohuck@redhat.com>
Signed-off-by: Jason Gunthorpe <jgg@nvidia.com>
Message-Id: <18-v2-d36939638fc6+d54-vfio2_jgg@nvidia.com>
The kobj here is a type-erased version of mdev_type, which is already
stored in the struct mdev_device being passed in. It was only ever used to
compute the type_group_id, which is now extracted directly from the mdev.
Message-Id: <17-v2-d36939638fc6+d54-vfio2_jgg@nvidia.com>
The mbochs_types array is parallel to the supported_type_groups array, so
the type_group_id indexes both. Instead of doing string searching just
directly index with type_group_id in all places.
Message-Id: <14-v2-d36939638fc6+d54-vfio2_jgg@nvidia.com>
The mdpy_types array is parallel to the supported_type_groups array, so
Message-Id: <13-v2-d36939638fc6+d54-vfio2_jgg@nvidia.com>
The type_group_id directly gives the single or dual port index, no
need for string searching.
Message-Id: <12-v2-d36939638fc6+d54-vfio2_jgg@nvidia.com>
These should always be prefixed with static, otherwise compilation
will fail on non-modular builds with
ld: samples/vfio-mdev/mbochs.o:(.data+0x2e0): multiple definition of `mdev_type_attr_name'; samples/vfio-mdev/mdpy.o:(.data+0x240): first defined here
Fixes: a5e6e6505f38 ("sample: vfio bochs vbe display (host device for bochs-drm)")
Fixes: d61fc96f47fd ("sample: vfio mdev display - host device")
Message-Id: <1-v2-d36939638fc6+d54-vfio2_jgg@nvidia.com>
With the introduction of bpf_link in xsk's libbpf part, there's no
further need for explicit unload of prog on xdpsock's termination. When
process dies, the bpf_link's refcount will be decremented and resources
will be unloaded/freed under the hood in case when there are no more
active users.
While at it, don't dump stats on error path.
Signed-off-by: Maciej Fijalkowski <maciej.fijalkowski@intel.com>
Link: https://lore.kernel.org/bpf/20210329224316.17793-8-maciej.fijalkowski@intel.com
The header <linux/version.h> is useless in sampleip_kern.c
and trace_event_kern.c, remove it.
Signed-off-by: Lu Wei <luwei32@huawei.com>
Link: https://lore.kernel.org/bpf/20210324083147.149278-1-luwei32@huawei.com
Alexei Starovoitov says:
pull-request: bpf-next 2021-03-24
We've added 37 non-merge commits during the last 15 day(s) which contain
a total of 65 files changed, 3200 insertions(+), 738 deletions(-).
1) Static linking of multiple BPF ELF files, from Andrii.
2) Move drop error path to devmap for XDP_REDIRECT, from Lorenzo.
3) Spelling fixes from various folks.
This patch fixes a spelling typo in do_hbm_test.sh
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Link: https://lore.kernel.org/bpf/20210315124454.1744594-1-standby24x7@gmail.com
To configure various complex flows we for sure can create custom
pktgen init scripts, but sometimes thats not that easy.
New "-a" (append) option in all the existing sample scripts allows
to append more "devices" into pktgen threads.
The most straightforward usecases for that are:
- using multiple devices. We have to generate full linerate on
all physical functions (ports) of our multiport device.
- pushing multiple flows (with different packet options)
Signed-off-by: Igor Russkikh <irusskikh@marvell.com>
DELAY may now be explicitly specified via common parameter -w
Pull networking fixes from David Miller:
1) Fix transmissions in dynamic SMPS mode in ath9k, from Felix Fietkau.
2) TX skb error handling fix in mt76 driver, also from Felix.
3) Fix BPF_FETCH atomic in x86 JIT, from Brendan Jackman.
4) Avoid double free of percpu pointers when freeing a cloned bpf prog.
From Cong Wang.
5) Use correct printf format for dma_addr_t in ath11k, from Geert
Uytterhoeven.
6) Fix resolve_btfids build with older toolchains, from Kun-Chuan
Hsieh.
7) Don't report truncated frames to mac80211 in mt76 driver, from
Lorenzop Bianconi.
8) Fix watcdog timeout on suspend/resume of stmmac, from Joakim Zhang.
9) mscc ocelot needs NET_DEVLINK selct in Kconfig, from Arnd Bergmann.
10) Fix sign comparison bug in TCP_ZEROCOPY_RECEIVE getsockopt(), from
Arjun Roy.
11) Ignore routes with deleted nexthop object in mlxsw, from Ido
Schimmel.
12) Need to undo tcp early demux lookup sometimes in nf_nat, from
Florian Westphal.
13) Fix gro aggregation for udp encaps with zero csum, from Daniel
Borkmann.
14) Make sure to always use imp*_ndo_send when necessaey, from Jason A.
Donenfeld.
15) Fix TRSCER masks in sh_eth driver from Sergey Shtylyov.
16) prevent overly huge skb allocationsd in qrtr, from Pavel Skripkin.
17) Prevent rx ring copnsumer index loss of sync in enetc, from Vladimir
Oltean.
18) Make sure textsearch copntrol block is large enough, from Wilem de
Bruijn.
19) Revert MAC changes to r8152 leading to instability, from Hates Wang.
20) Advance iov in 9p even for empty reads, from Jissheng Zhang.
21) Double hook unregister in nftables, from PabloNeira Ayuso.
22) Fix memleak in ixgbe, fropm Dinghao Liu.
23) Avoid dups in pkt scheduler class dumps, from Maximilian Heyne.
24) Various mptcp fixes from Florian Westphal, Paolo Abeni, and Geliang
Tang.
25) Fix DOI refcount bugs in cipso, from Paul Moore.
26) One too many irqsave in ibmvnic, from Junlin Yang.
27) Fix infinite loop with MPLS gso segmenting via virtio_net, from
Balazs Nemeth.
* git://git.kernel.org:/pub/scm/linux/kernel/git/netdev/net: (164 commits)
s390/qeth: fix notification for pending buffers during teardown
s390/qeth: schedule TX NAPI on QAOB completion
s390/qeth: improve completion of pending TX buffers
s390/qeth: fix memory leak after failed TX Buffer allocation
net: avoid infinite loop in mpls_gso_segment when mpls_hlen == 0
net: check if protocol extracted by virtio_net_hdr_set_proto is correct
net: dsa: xrs700x: check if partner is same as port in hsr join
net: lapbether: Remove netif_start_queue / netif_stop_queue
atm: idt77252: fix null-ptr-dereference
atm: uPD98402: fix incorrect allocation
atm: fix a typo in the struct description
net: qrtr: fix error return code of qrtr_sendmsg()
mptcp: fix length of ADD_ADDR with port sub-option
net: bonding: fix error return code of bond_neigh_init()
net: enetc: allow hardware timestamping on TX queues with tc-etf enabled
net: enetc: set MAC RX FIFO to recommended value
net: davicom: Use platform_get_irq_optional()
net: davicom: Fix regulator not turned off on driver removal
net: davicom: Fix regulator not turned off on failed probe
net: dsa: fix switchdev objects on bridge master mistakenly being applied on ports
We mmap the umem region, but we never munmap it.
Add the missing call at the end of the cleanup.
Fixes: 3945b37a975d ("samples/bpf: use hugepages in xdpsock app")
Acked-by: Björn Töpel <bjorn.topel@intel.com>
Link: https://lore.kernel.org/bpf/20210303185636.18070-3-maciej.fijalkowski@intel.com
Update contact info.
Link: https://lkml.kernel.org/r/20210206162524.GA11520@kernel.org
Signed-off-by: Miguel Ojeda <ojeda@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver updates from Greg KH:
"Here is the large set of char/misc/whatever driver subsystem updates
for 5.12-rc1. Over time it seems like this tree is collecting more and
more tiny driver subsystems in one place, making it easier for those
maintainers, which is why this is getting larger.
Included in here are:
- coresight driver updates
- habannalabs driver updates
- virtual acrn driver addition (proper acks from the x86 maintainers)
- broadcom misc driver addition
- speakup driver updates
- soundwire driver updates
- fpga driver updates
- amba driver updates
- mei driver updates
- vfio driver updates
- greybus driver updates
- nvmeem driver updates
- phy driver updates
- mhi driver updates
- interconnect driver udpates
- fsl-mc bus driver updates
- random driver fix
- some small misc driver updates (rtsx, pvpanic, etc.)
All of these have been in linux-next for a while, with the only
reported issue being a merge conflict due to the dfl_device_id
addition from the fpga subsystem in here"
* tag 'char-misc-5.12-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (311 commits)
spmi: spmi-pmic-arb: Fix hw_irq overflow
Documentation: coresight: Add PID tracing description
coresight: etm-perf: Support PID tracing for kernel at EL2
coresight: etm-perf: Clarify comment on perf options
ACRN: update MAINTAINERS: mailing list is subscribers-only
regmap: sdw-mbq: use MODULE_LICENSE("GPL")
regmap: sdw: use no_pm routines for SoundWire 1.2 MBQ
regmap: sdw: use _no_pm functions in regmap_read/write
soundwire: intel: fix possible crash when no device is detected
MAINTAINERS: replace my with email with replacements
mhi: Fix double dma free
uapi: map_to_7segment: Update example in documentation
uio: uio_pci_generic: don't fail probe if pdev->irq equals to IRQ_NOTCONNECTED
drivers/misc/vmw_vmci: restrict too big queue size in qp_host_alloc_queue
firewire: replace tricky statement by two simple ones
vme: make remove callback return void
firmware: google: make coreboot driver's remove callback return void
firmware: xilinx: Use explicit values for all enum values
sample/acrn: Introduce a sample of HSM ioctl interface usage
virt: acrn: Introduce an interface for Service VM to control vCPU
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs
Pull keyring updates from David Howells:
"Here's a set of minor keyrings fixes/cleanups that I've collected from
various people for the upcoming merge window.
A couple of them might, in theory, be visible to userspace:
- Make blacklist_vet_description() reject uppercase letters as they
don't match the all-lowercase hex string generated for a blacklist
search.
This may want reconsideration in the future, but, currently, you
can't add to the blacklist keyring from userspace and the only
source of blacklist keys generates lowercase descriptions.
- Fix blacklist_init() to use a new KEY_ALLOC_* flag to indicate that
it wants KEY_FLAG_KEEP to be set rather than passing KEY_FLAG_KEEP
into keyring_alloc() as KEY_FLAG_KEEP isn't a valid alloc flag.
This isn't currently a problem as the blacklist keyring isn't
currently writable by userspace.
The rest of the patches are cleanups and I don't think they should
have any visible effect"
* tag 'keys-misc-20210126' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs:
watch_queue: rectify kernel-doc for init_watch()
certs: Replace K{U,G}IDT_INIT() with GLOBAL_ROOT_{U,G}ID
certs: Fix blacklist flag type confusion
PKCS#7: Fix missing include
certs: Fix blacklisted hexadecimal hash string check
certs/blacklist: fix kernel doc interface issue
crypto: public_key: Remove redundant header file from public_key.h
keys: remove trailing semicolon in macro definition
crypto: pkcs7: Use match_string() helper to simplify the code
PKCS#7: drop function from kernel-doc pkcs7_validate_trust_one
encrypted-keys: Replace HTTP links with HTTPS ones
crypto: asymmetric_keys: fix some comments in pkcs7_parser.h
KEYS: remove redundant memset
security: keys: delete repeated words in comments
KEYS: asymmetric: Fix kerneldoc
security/keys: use kvfree_sensitive()
watch_queue: Drop references to /dev/watch_queue
keys: Remove outdated __user annotations
security: keys: Fix fall-through warnings for Clang
Pull documentation updates from Jonathan Corbet:
"It has been a relatively quiet cycle in docsland.
- As promised, the minimum Sphinx version to build the docs is now
1.7, and we have dropped support for Python 2 entirely. That
allowed the removal of a bunch of compatibility code.
- A set of treewide warning fixups from Mauro that I applied after it
became clear nobody else was going to deal with them.
- The automarkup mechanism can now create cross-references from
relative paths to RST files.
- More translations, typo fixes, and warning fixes"
* tag 'docs-5.12' of git://git.lwn.net/linux: (75 commits)
docs: kernel-hacking: be more civil
docs: Remove the Microsoft rhetoric
Documentation/admin-guide: kernel-parameters: Update nohlt section
doc/admin-guide: fix spelling mistake: "perfomance" -> "performance"
docs: Document cross-referencing using relative path
docs: Enable usage of relative paths to docs on automarkup
docs: thermal: fix spelling mistakes
Documentation: admin-guide: Update kvm/xen config option
docs: Make syscalls' helpers naming consistent
coding-style.rst: Avoid comma statements
Documentation: /proc/loadavg: add 3 more field descriptions
Documentation/submitting-patches: Add blurb about backtraces in commit messages
Docs: drop Python 2 support
Move our minimum Sphinx version to 1.7
Documentation: input: define ABS_PRESSURE/ABS_MT_PRESSURE resolution as grams
scripts/kernel-doc: add internal hyperlink to DOC: sections
Update Documentation/admin-guide/sysctl/fs.rst
docs: Update DTB format references
docs: zh_CN: add iio index.rst translation
docs/zh_CN: add iio ep93xx_adc.rst translation
Launch a simple guest (with several instructions as payload) on ACRN
with demonstration ioctl usage.
Signed-off-by: Shuo Liu <shuo.a.liu@intel.com>
Link: https://lore.kernel.org/r/20210207031040.49576-19-shuo.a.liu@intel.com
Eliminate the following coccicheck warning:
./samples/bpf/cookie_uid_helper_example.c:316:3-4: Unneeded semicolon
Reported-by: Abaci Robot <abaci@linux.alibaba.com>
Signed-off-by: Yang Li <yang.lee@linux.alibaba.com>
Link: https://lore.kernel.org/bpf/1612322248-35398-1-git-send-email-yang.lee@linux.alibaba.com
There exists many build errors when make M=samples/bpf on the Loongson
platform. This issue is MIPS related, x86 compiles just fine.
Here are some errors:
CLANG-bpf samples/bpf/sockex2_kern.o
In file included from samples/bpf/sockex2_kern.c:2:
In file included from ./include/uapi/linux/in.h:24:
In file included from ./include/linux/socket.h:8:
In file included from ./include/linux/uio.h:8:
In file included from ./include/linux/kernel.h:11:
In file included from ./include/linux/bitops.h:32:
In file included from ./arch/mips/include/asm/bitops.h:19:
In file included from ./arch/mips/include/asm/barrier.h:11:
./arch/mips/include/asm/addrspace.h:13:10: fatal error: 'spaces.h' file not found
1 error generated.
In file included from ./arch/mips/include/asm/bitops.h:22:
In file included from ./arch/mips/include/asm/cpu-features.h:13:
In file included from ./arch/mips/include/asm/cpu-info.h:15:
In file included from ./include/linux/cache.h:6:
./arch/mips/include/asm/cache.h:12:10: fatal error: 'kmalloc.h' file not found
1 error generated.
./arch/mips/include/asm/cpu-features.h:15:10: fatal error: 'cpu-feature-overrides.h' file not found
1 error generated.
$ find arch/mips/include/asm -name spaces.h | sort
arch/mips/include/asm/mach-ar7/spaces.h
arch/mips/include/asm/mach-generic/spaces.h
arch/mips/include/asm/mach-loongson64/spaces.h
arch/mips/include/asm/mach-tx49xx/spaces.h
$ find arch/mips/include/asm -name kmalloc.h | sort
arch/mips/include/asm/mach-generic/kmalloc.h
arch/mips/include/asm/mach-ip32/kmalloc.h
arch/mips/include/asm/mach-tx49xx/kmalloc.h
$ find arch/mips/include/asm -name cpu-feature-overrides.h | sort
arch/mips/include/asm/mach-ath25/cpu-feature-overrides.h
arch/mips/include/asm/mach-generic/cpu-feature-overrides.h
arch/mips/include/asm/mach-loongson64/cpu-feature-overrides.h
arch/mips/include/asm/mach-tx49xx/cpu-feature-overrides.h
In the arch/mips/Makefile, there exists the following board-dependent
options:
include arch/mips/Kbuild.platforms
cflags-y += -I$(srctree)/arch/mips/include/asm/mach-generic
So we can do the similar things in samples/bpf/Makefile, just add
platform specific and generic include dir for MIPS Loongson64 to
fix the build errors.
Signed-off-by: Tiezhu Yang <yangtiezhu@loongson.cn>
Link: https://lore.kernel.org/bpf/1611669925-25315-1-git-send-email-yangtiezhu@loongson.cn
There exists many build warnings when make M=samples/bpf on the Loongson
platform, this issue is MIPS related, x86 compiles just fine.
Here are some warnings:
CC samples/bpf/ibumad_user.o
samples/bpf/ibumad_user.c: In function ‘dump_counts’:
samples/bpf/ibumad_user.c:46:24: warning: format ‘%llu’ expects argument of type ‘long long unsigned int’, but argument 3 has type ‘__u64’ {aka ‘long unsigned int’} [-Wformat=]
printf("0x%02x : %llu\n", key, value);
%lu
CC samples/bpf/offwaketime_user.o
samples/bpf/offwaketime_user.c: In function ‘print_ksym’:
samples/bpf/offwaketime_user.c:34:17: warning: format ‘%llx’ expects argument of type ‘long long unsigned int’, but argument 3 has type ‘__u64’ {aka ‘long unsigned int’} [-Wformat=]
printf("%s/%llx;", sym->name, addr);
%lx
samples/bpf/offwaketime_user.c: In function ‘print_stack’:
samples/bpf/offwaketime_user.c:68:17: warning: format ‘%lld’ expects argument of type ‘long long int’, but argument 3 has type ‘__u64’ {aka ‘long unsigned int’} [-Wformat=]
printf(";%s %lld\n", key->waker, count);
%ld
MIPS needs __SANE_USERSPACE_TYPES__ before <linux/types.h> to select
'int-ll64.h' in arch/mips/include/uapi/asm/types.h, then it can avoid
build warnings when printing __u64 with %llu, %llx or %lld.
The header tools/include/linux/types.h defines __SANE_USERSPACE_TYPES__,
it seems that we can include <linux/types.h> in the source files which
have build warnings, but it has no effect due to actually it includes
usr/include/linux/types.h instead of tools/include/linux/types.h, the
problem is that "usr/include" is preferred first than "tools/include"
in samples/bpf/Makefile, that sounds like a ugly hack to -Itools/include
before -Iusr/include.
So define __SANE_USERSPACE_TYPES__ for MIPS in samples/bpf/Makefile
is proper, if add "TPROGS_CFLAGS += -D__SANE_USERSPACE_TYPES__" in
samples/bpf/Makefile, it appears the following error:
Auto-detecting system features:
... libelf: [ on ]
... zlib: [ on ]
... bpf: [ OFF ]
BPF API too old
make[3]: *** [Makefile:293: bpfdep] Error 1
make[2]: *** [Makefile:156: all] Error 2
With #ifndef __SANE_USERSPACE_TYPES__ in tools/include/linux/types.h,
the above error has gone and this ifndef change does not hurt other
compilations.
Link: https://lore.kernel.org/bpf/1611551146-14052-1-git-send-email-yangtiezhu@loongson.cn
This patch add a xdp program on egress to show that we can modify
the packet on egress. In this sample we will set the pkt's src
mac to egress's mac address. The xdp_prog will be attached when
-X option supplied.
Link: https://lore.kernel.org/bpf/20210122025007.2968381-1-liuhangbin@gmail.com
