I intend to turn struct flowi into a union of AF specific flowi
structs. There will be a common structure that each variant includes
first, much like struct sock_common.
This is the first step to move in that direction.
There is only one caller of xfrm_bundle_ok(), and that always passes these
parameters as NULL.
The idea here is this minimizes the number of places one has to edit
in order to make changes to how flows are defined and used.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
Completely unused.
fl->oif will always be zero on the input path, so there is no reason
to test for that.
All callers are under rcu_read_lock() protection already.
Rename to ip_check_mc_rcu() to make it even more clear.
drivers/net/bnx2x/bnx2x_cmn.c
Add necessary alias to autoload ip6ip6 tunnel module.
When configs BRIDGE=y and IPV6=m, this build error occurs:
br_multicast.c:(.text+0xa3341): undefined reference to `ipv6_dev_get_saddr'
BRIDGE_IGMP_SNOOPING is boolean; if it were tristate, then adding
depends on IPV6 || IPV6=n
to BRIDGE_IGMP_SNOOPING would be a good fix. As it is currently,
making BRIDGE depend on the IPV6 config works.
Reported-by: Patrick Schaaf <netdev@bof.de>
Like in commit 44713b67db10c774f14280c129b0d5fd13c70cf2
("ipv4: Optimize flow initialization in output route lookup."
we can optimize the on-stack flow setup to only initialize
the members which are actually used.
Otherwise we bzero the entire structure, then initialize
explicitly the first half of it.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=29252
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=30462
In commit d80bc0fd262ef840ed4e82593ad6416fa1ba3fc4 ("ipv6: Always
clone offlink routes.") we forced the kernel to always clone offlink
routes.
The reason we do that is to make sure we never bind an inetpeer to a
prefixed route.
The logic turned on here has existed in the tree for many years,
but was always off due to a protecting CPP define. So perhaps
it's no surprise that there is a logic bug here.
The problem is that we canot clone a route that is already a
host route (ie. has DST_HOST set). Because if we do, an identical
entry already exists in the routing tree and therefore the
ip6_rt_ins() call is going to fail.
This sets off a series of failures and high cpu usage, because when
ip6_rt_ins() fails we loop retrying this operation a few times in
order to handle a race between two threads trying to clone and insert
the same host route at the same time.
Fix this by simply using the route as-is when DST_HOST is set.
Reported-by: slash@ac.auone-net.jp
Reported-by: Ernst Sjöstrand <ernstp@gmail.com>
Since a8f80e8ff94ecba629542d9b4b5f5a8ee3eb565c any process with
CAP_NET_ADMIN may load any module from /lib/modules/. This doesn't mean
that CAP_NET_ADMIN is a superset of CAP_SYS_MODULE as modules are
limited to /lib/modules/**. However, CAP_NET_ADMIN capability shouldn't
allow anybody load any module not related to networking.
This patch restricts an ability of autoloading modules to netdev modules
with explicit aliases. This fixes CVE-2011-1019.
Arnd Bergmann suggested to leave untouched the old pre-v2.6.32 behavior
of loading netdev modules by name (without any prefix) for processes
with CAP_SYS_MODULE to maintain the compatibility with network scripts
that use autoloading netdev modules by aliases like "eth0", "wlan0".
Currently there are only three users of the feature in the upstream
kernel: ipip, ip_gre and sit.
root@albatros:~# capsh --drop=$(seq -s, 0 11),$(seq -s, 13 34) --
root@albatros:~# grep Cap /proc/$$/status
CapInh: 0000000000000000
CapPrm: fffffff800001000
CapEff: fffffff800001000
CapBnd: fffffff800001000
root@albatros:~# modprobe xfs
FATAL: Error inserting xfs
(/lib/modules/2.6.38-rc6-00001-g2bf4ca3/kernel/fs/xfs/xfs.ko): Operation not permitted
root@albatros:~# lsmod | grep xfs
root@albatros:~# ifconfig xfs
xfs: error fetching interface information: Device not found
root@albatros:~# lsmod | grep sit
root@albatros:~# ifconfig sit
sit: error fetching interface information: Device not found
root@albatros:~# ifconfig sit0
sit0 Link encap:IPv6-in-IPv4
NOARP MTU:1480 Metric:1
sit 10457 0
tunnel4 2957 1 sit
For CAP_SYS_MODULE module loading is still relaxed:
CapPrm: ffffffffffffffff
CapEff: ffffffffffffffff
CapBnd: ffffffffffffffff
xfs 745319 0
Reference: https://lkml.org/lkml/2011/2/24/203
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
Signed-off-by: Michael Tokarev <mjt@tls.msk.ru>
Acked-by: Kees Cook <kees.cook@canonical.com>
Signed-off-by: James Morris <jmorris@namei.org>
The units in show_results in pktgen were not correct.
The results are in usec but it was displayed nsec.
Reported-by: Jong-won Lee <ljw@handong.edu>
Signed-off-by: Daniel Turull <daniel.turull@gmail.com>
In contrast to SIOCOUTQ which returns the amount of data sent
but not yet acknowledged plus data not yet sent this patch only
returns the data not sent.
For various methods of live streaming bitrate control it may
be helpful to know how much data are in the tcp outqueue are
not sent yet.
Signed-off-by: Mario Schuknecht <m.schuknecht@dresearch.de>
Signed-off-by: Steffen Sledz <sledz@dresearch.de>
Create a common helper for this operation, since we do
it identically in three spots.
Suggested by Eric Dumazet.
In usual cases ifa_address == ifa_local, but in the case where
SIOCSIFDSTADDR sets the destination address on a point-to-point
link, ifa_address gets set to that destination address.
Therefore we should use ifa_local when we want the local interface
address.
There were two cases where the selection was done incorrectly:
1) When devinet_ioctl() does matching, it checks ifa_address even
though gifconf correct reported ifa_local to the user
2) IN_DEV_ARP_NOTIFY handling sends a gratuitous ARP using
ifa_address instead of ifa_local.
Reported-by: Julian Anastasov <ja@ssi.bg>
Waiting until the status is received can cause the same rate to be
probed multiple times consecutively.
Cc: Felix Fietkau <nbd@openwrt.org>
Signed-off-by: Daniel Halperin <dhalperi@cs.washington.edu>
Regulatory devices issue change uevents to inform userspace of a need
to call the crda tool; however these can often be sent before udevd is
running, and were not previously included in the results of
udevadm trigger (which requests a new change event using the /uevent
attribute of the sysfs object).
Add a uevent function to the device type which includes the COUNTRY
information from the last request if it has yet to be processed, the
case of multiple requests is already handled in the code by checking
whether an unprocessed one is queued in the same manner and refusing
to queue a new one.
The existing udev rule continues to work as before.
Signed-off-by: Scott James Remnant <keybuk@google.com>
Acked-By: Kay Sievers <kay.sievers@vrfy.org>
This is now a run-time choice so that a single kernel can support both
old and new generation ISI modems. Support for manually enabling the
pipe flow is removed as it did not work properly, does not fit well
with the socket API, and I am not aware of any use at the moment.
Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com>
This provides support for newer ISI modems with no need for the
earlier experimental compile-time alternative choice. With this,
we can now use the same kernel and userspace with both types of
modems.
This also avoids confusing two different and incompatible state
machines, actively connected vs accepted sockets, and adds
connection response error handling (processing "SYN/RST" of sorts).
User-space sometimes needs this information. In particular, the GPRS
context or the AT commands pipe setups may use the pipe handle as a
reference.
This removes the settable pipe handle with CONFIG_PHONET_PIPECTRLR.
It did not handle error cases correctly. Furthermore, the kernel
*could* implement a smart scheme for allocating handles (if ever
needed), but userspace really cannot.
This moves most of the accept logic to process context like other
socket stacks do. Then we can use a few more common socket helpers
and simplify a bit.
With the addition of the pipe controller, there is now quite a bit
of repetitive code for small signaling messages. Lets factor it.
In some cases, the Phonet pipe backlog callbacks returned negative
errno instead of NET_RX_* values.
In other cases, NET_RX_DROP was returned for invalid packets, even
though it seems only intended for buffering problems (not for
deliberately discarded packets).
Phonet assumes that packets are never dropped. We try our best to
avoid this situation. But lets return ENOBUFS if queueing to the
network device fails so that the caller knows things went wrong.
The previous Phonet patch series introduced per-socket implicit
destination (i.e. connect()). In that case, the destination
socket address is NULL in the transmit function.
However commit a8059512b120362b15424f152b2548fe8b11bd0c
("Phonet: implement per-socket destination/peer address")
is incomplete and would trigger a NULL dereference.
(Fortunately, the code is not in released kernel, and in fact
currently not reachable.)
If modifications on other cpus are ok, then modifications to
the tree during lookup done by the local cpu are ok too.
The mv88e6060 uses either the lower 16 or upper 16 mii addresses,
depending on the value of the EE_CLK/ADDR4 pin. Support both
configurations by using the sw_addr setting as base address.
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
Acked-by: Lennert Buytenhek <buytenh@wantstofly.org>
Recently had this bug halt reported to me:
kernel BUG at net/rds/send.c:329!
Oops: Exception in kernel mode, sig: 5 [#1]
SMP NR_CPUS=1024 NUMA pSeries
Modules linked in: rds sunrpc ipv6 dm_mirror dm_region_hash dm_log ibmveth sg
ext4 jbd2 mbcache sd_mod crc_t10dif ibmvscsic scsi_transport_srp scsi_tgt
dm_mod [last unloaded: scsi_wait_scan]
NIP: d000000003ca68f4 LR: d000000003ca67fc CTR: d000000003ca8770
REGS: c000000175cab980 TRAP: 0700 Not tainted (2.6.32-118.el6.ppc64)
MSR: 8000000000029032 <EE,ME,CE,IR,DR> CR: 44000022 XER: 00000000
TASK = c00000017586ec90[1896] 'krdsd' THREAD: c000000175ca8000 CPU: 0
GPR00: 0000000000000150 c000000175cabc00 d000000003cb7340 0000000000002030
GPR04: ffffffffffffffff 0000000000000030 0000000000000000 0000000000000030
GPR08: 0000000000000001 0000000000000001 c0000001756b1e30 0000000000010000
GPR12: d000000003caac90 c000000000fa2500 c0000001742b2858 c0000001742b2a00
GPR16: c0000001742b2a08 c0000001742b2820 0000000000000001 0000000000000001
GPR20: 0000000000000040 c0000001742b2814 c000000175cabc70 0800000000000000
GPR24: 0000000000000004 0200000000000000 0000000000000000 c0000001742b2860
GPR28: 0000000000000000 c0000001756b1c80 d000000003cb68e8 c0000001742b27b8
NIP [d000000003ca68f4] .rds_send_xmit+0x4c4/0x8a0 [rds]
LR [d000000003ca67fc] .rds_send_xmit+0x3cc/0x8a0 [rds]
Call Trace:
[c000000175cabc00] [d000000003ca67fc] .rds_send_xmit+0x3cc/0x8a0 [rds]
(unreliable)
[c000000175cabd30] [d000000003ca7e64] .rds_send_worker+0x54/0x100 [rds]
[c000000175cabdb0] [c0000000000b475c] .worker_thread+0x1dc/0x3c0
[c000000175cabed0] [c0000000000baa9c] .kthread+0xbc/0xd0
[c000000175cabf90] [c000000000032114] .kernel_thread+0x54/0x70
Instruction dump:
4bfffd50 60000000 60000000 39080001 935f004c f91f0040 41820024 813d017c
7d094a78 7d290074 7929d182 394a0020 <0b090000> 40e2ff68 4bffffa4 39200000
Kernel panic - not syncing: Fatal exception
Call Trace:
[c000000175cab560] [c000000000012e04] .show_stack+0x74/0x1c0 (unreliable)
[c000000175cab610] [c0000000005a365c] .panic+0x80/0x1b4
[c000000175cab6a0] [c00000000002fbcc] .die+0x21c/0x2a0
[c000000175cab750] [c000000000030000] ._exception+0x110/0x220
[c000000175cab910] [c000000000004b9c] program_check_common+0x11c/0x180
master.kernel.org:/pub/scm/linux/kernel/git/jkirsher/net-next-2.6
We have to use cfg->fc_scope not the final nh_scope value.
When doing output route lookups, we have to select the source address
if the user has not specified an explicit one.
First, if the route has an explicit preferred source address
specified, then we use that.
Otherwise we search the route's outgoing interface for a suitable
address.
This search can be precomputed and cached at route insertion time.
The only missing part is that we have to refresh this precomputed
value any time addresses are added or removed from the interface, and
this is accomplished by fib_update_nh_saddrs().
Add the new target ddp offload support ndo_fcoe_ddp_target().
Signed-off-by: Yi Zou <yi.zou@intel.com>
Signed-off-by: Kiran Patil <kiran.patil@intel.com>
Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net>
ip6_mc_source(), ip6_mc_msfilter() as well as ip6_mc_msfget() declare
and assign dev but do not use the variable afterwards.
This was there before, I forgot about this. Allows deliveries to
ptype_base handlers registered for orig_dev. I presume this is still
desired.
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Reviewed-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr>
The unix_dgram_recvmsg and unix_stream_recvmsg routines in
net/af_unix.c utilize mutex_lock(&u->readlock) calls in order to
serialize read operations of multiple threads on a single socket. This
implies that, if all n threads of a process block in an AF_UNIX recv
call trying to read data from the same socket, one of these threads
will be sleeping in state TASK_INTERRUPTIBLE and all others in state
TASK_UNINTERRUPTIBLE. Provided that a particular signal is supposed to
be handled by a signal handler defined by the process and that none of
this threads is blocking the signal, the complete_signal routine in
kernel/signal.c will select the 'first' such thread it happens to
encounter when deciding which thread to notify that a signal is
supposed to be handled and if this is one of the TASK_UNINTERRUPTIBLE
threads, the signal won't be handled until the one thread not blocking
on the u->readlock mutex is woken up because some data to process has
arrived (if this ever happens). The included patch fixes this by
changing mutex_lock to mutex_lock_interruptible and handling possible
error returns in the same way interruptions are handled by the actual
receive-code.
Signed-off-by: Rainer Weikusat <rweikusat@mobileactivedefense.com>
This elimiates a lot of pure overhead due to parameter
passing.
fib_semantic_match() requires that if the type doesn't signal an
automatic error, it must be of type RTN_UNICAST, RTN_LOCAL,
RTN_BROADCAST, RTN_ANYCAST, or RTN_MULTICAST.
Checking this every route lookup is pointless work.
Instead validate it during route insertion, via fib_create_info().
Also, there was nothing making sure the type value was less than
RTN_MAX, so add that missing check while we're here.
exthdrs_core.c and addrconf_core.c in net/ipv6/ contain bits which
must be made available even if IPv6 is disabled.
net/ipv6/Makefile already correctly includes them if CONFIG_IPV6=n
but net/Makefile prevents entering the subdirectory.
Signed-off-by: Thomas Graf <tgraf@infradead.org>
The scan code has a race that Michael reported
he ran into, but it's easy to fix while at the
same time simplifying the code.
The race resulted in the following warning:
WARNING: at net/mac80211/scan.c:310 ieee80211_rx_bss_free+0x20c/0x4b8 [mac80211]()
Modules linked in: [...]
[<c0033edc>] (unwind_backtrace+0x0/0xe0) from [<c004f2a4>] (warn_slowpath_common+0x4c/0x64)
[... backtrace wasn't useful ...]
Reported-by: Michael Buesch <mb@bu3sch.de>
Add a log message to ieee80211_restart_hw() to highlight
that special codepath in the logs. This helps debugging
bugs in the rarely tested restart code.
Signed-off-by: Michael Buesch <mb@bu3sch.de>
Compile test only.
Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com>
