This patch adds a missing return after fragmentation init. Otherwise we
register a sysctl interface and deregister it afterwards which makes no
sense.
Signed-off-by: Alexander Aring <alex.aring@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs
David Howells says:
net-next: AF_RXRPC fixes and development
Here are some AF_RXRPC fixes:
(1) Fix to remove incorrect checksum calculation made during recvmsg(). It's
unnecessary to try to do this there since we check the checksum before
reading the RxRPC header from the packet.
(2) Fix to prevent the sending of an ABORT packet in response to another
ABORT packet and inducing a storm.
(3) Fix UDP MTU calculation from parsing ICMP_FRAG_NEEDED packets where we
don't handle the ICMP packet not specifying an MTU size.
And development patches:
(4) Add sysctls for configuring RxRPC parameters, specifically various delays
pertaining to ACK generation, the time before we resend a packet for
which we don't receive an ACK, the maximum time a call is permitted to
live and the amount of time transport, connection and dead call
information is cached.
(5) Improve ACK packet production by adjusting the handling of ACK_REQUESTED
packets, ignoring the MORE_PACKETS flag, delaying the production of
otherwise immediate ACK_IDLE packets and delaying all ACK_IDLE production
(barring the call termination) to half a second.
(6) Add more sysctl parameters to expose the Rx window size, the maximum
packet size that we're willing to receive and the number of jumbo rxrpc
packets we're willing to handle in a single UDP packet.
(7) Request ACKs on alternate DATA packets so that the other side doesn't
wait till we fill up the Tx window.
(8) Use a RCU hash table to look up the rxrpc_call for an incoming packet
rather than stepping through a hierarchy involving several spinlocks.
There is no reason to orphan skb in l2tp.
This breaks things like per socket memory limits, TCP Small queues...
Fix this before more people copy/paste it.
This is very similar to commit 8f646c922d550
("vxlan: keep original skb ownership")
Cc: James Chapman <jchapman@katalix.com>
Usage of skb->tstamp should remain private to TCP stack
(only set on packets on write queue, not on cloned ones)
Otherwise, packets given to loopback interface with a non null tstamp
can confuse netif_rx() / net_timestamp_check()
Other possibility would be to clear tstamp in loopback_xmit(),
as done in skb_scrub_packet()
Fixes: 740b0f1841f6 ("tcp: switch rtt estimations to usec resolution")
Reported-by: Willem de Bruijn <willemb@google.com>
htb_dump() and htb_dump_class() do not strictly need to acquire
qdisc lock to fetch qdisc and/or class parameters.
We hold RTNL and no changes can occur.
This reduces by 50% qdisc lock pressure while doing tc qdisc|class dump
operations.
This header is used by bluetooth and ieee802154 branch. This patch
move this header to the include/net directory to avoid a use of a
relative path in include.
The 6lowpan.h file contains some static inline function which use
internal ipv6 api structs. Add a include of ipv6.h to be sure that it's
known before.
Can be invoked from non-BH context.
Based upon a patch by Eric Dumazet.
Fixes: f19c29e3e391 ("tcp: snmp stats for Fast Open, SYN rtx, and data pkts")
Reported-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Commit e688a604807647 ("net: introduce DST_NOPEER dst flag") introduced
DST_NOPEER because because of crashes in ipv6_select_ident called from
udp6_ufo_fragment.
Since commit 916e4cf46d0204 ("ipv6: reuse ip6_frag_id from
ip6_ufo_append_data") we don't call ipv6_select_ident any more from
ip6_ufo_append_data, thus this flag lost its purpose and can be removed.
drivers/net/wireless/ath/ath9k/recv.c
drivers/net/wireless/mwifiex/pcie.c
net/ipv6/sit.c
The SIT driver conflict consists of a bug fix being done by hand
in 'net' (missing u64_stats_init()) whilst in 'net-next' a helper
was created (netdev_alloc_pcpu_stats()) which takes care of this.
The two wireless conflicts were overlapping changes.
This patch fixes some whitespace issues in Kconfig files of IEEE
802.15.4 subsytem.
MPLS labels may contain traffic control information, which should be
evaluated and used by the wireless subsystem if present.
Also check for IEEE 802.21 which is always network control traffic.
Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
Signed-off-by: Mathias Kretschmer <mathias.kretschmer@fokus.fraunhofer.de>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
Pull networking fixes from David Miller:
1) Fix memory leak in ieee80211_prep_connection(), sta_info leaked on
error. From Eytan Lifshitz.
2) Unintentional switch case fallthrough in nft_reject_inet_eval(),
from Patrick McHardy.
3) Must check if payload lenth is a power of 2 in
nft_payload_select_ops(), from Nikolay Aleksandrov.
4) Fix mis-checksumming in xen-netfront driver, ip_hdr() is not in the
correct place when we invoke skb_checksum_setup(). From Wei Liu.
5) TUN driver should not advertise HW vlan offload features in
vlan_features. Fix from Fernando Luis Vazquez Cao.
6) IPV6_VTI needs to select NET_IPV_TUNNEL to avoid build errors, fix
from Steffen Klassert.
7) Add missing locking in xfrm_migrade_state_find(), we must hold the
per-namespace xfrm_state_lock while traversing the lists. Fix from
Steffen Klassert.
8) Missing locking in ath9k driver, access to tid->sched must be done
under ath_txq_lock(). Fix from Stanislaw Gruszka.
9) Fix two bugs in TCP fastopen. First respect the size argument given
to tcp_sendmsg() in the fastopen path, and secondly prevent
tcp_send_syn_data() from potentially using order-5 allocations.
From Eric Dumazet.
10) Fix handling of default neigh garbage collection params, from Jiri
Pirko.
11) Fix cwnd bloat and over-inflation of RTT when transmit segmentation
is in use. From Eric Dumazet.
12) Missing initialization of Realtek r8169 driver's statistics
seqlocks. Fix from Kyle McMartin.
13) Fix RTNL assertion failures in 802.3ad and AB ARP monitor of bonding
driver, from Ding Tianhong.
14) Bonding slave release race can cause divide by zero, fix from
15) Overzealous return from neigh_periodic_work() causes reachability
time to not be computed. Fix from Duain Jiong.
16) Fix regression in ipv6_find_hdr(), it should not return -ENOENT when
a specific target is specified and found. From Hans Schillstrom.
17) Fix VLAN tag stripping regression in BNA driver, from Ivan Vecera.
18) Tail loss probe can calculate bogus RTTs due to missing packet
marking on retransmit. Fix from Yuchung Cheng.
19) We cannot do skb_dst_drop() in iptunnel_pull_header() because
multicast loopback detection in later code paths need access to
skb_rtable(). Fix from Xin Long.
20) The macvlan driver regresses in that it propagates lower device
offload support disables into itself, causing severe slowdowns when
running over a bridge. Provide the software offloads always on
macvlan devices to deal with this and the regression is gone. From
Vlad Yasevich.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (103 commits)
macvlan: Add support for 'always_on' offload features
net: sctp: fix sctp_sf_do_5_1D_ce to verify if we/peer is AUTH capable
ip_tunnel:multicast process cause panic due to skb->_skb_refdst NULL pointer
net: cpsw: fix cpdma rx descriptor leak on down interface
be2net: isolate TX workarounds not applicable to Skyhawk-R
be2net: Fix skb double free in be_xmit_wrokarounds() failure path
be2net: clear promiscuous bits in adapter->flags while disabling promiscuous mode
be2net: Fix to reset transparent vlan tagging
qlcnic: dcb: a couple off by one bugs
tcp: fix bogus RTT on special retransmission
hsr: off by one sanity check in hsr_register_frame_in()
can: remove CAN FD compatibility for CAN 2.0 sockets
can: flexcan: factor out soft reset into seperate funtion
can: flexcan: flexcan_remove(): add missing netif_napi_del()
can: flexcan: fix transition from and to freeze mode in chip_{,un}freeze
can: flexcan: factor out transceiver {en,dis}able into seperate functions
can: flexcan: fix transition from and to low power mode in chip_{en,dis}able
can: flexcan: flexcan_open(): fix error path if flexcan_chip_start() fails
can: flexcan: fix shutdown: first disable chip, then all interrupts
USB AX88179/178A: Support D-Link DUB-1312
Keep track of rxrpc_call structures in a hashtable so they can be
found directly from the network parameters which define the call.
This allows incoming packets to be routed directly to a call without walking
through hierarchy of peer -> transport -> connection -> call and all the
spinlocks that that entailed.
Signed-off-by: Tim Smith <tim@electronghost.co.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
John W. Linville says:
Please pull this batch of fixes intended for the 3.14 stream...
For the mac80211 bits, Johannes says:
"This time I have a fix to get out of an 'infinite error state' in case
regulatory domain updates failed and two fixes for VHT associations: one
to not disconnect immediately when the AP uses more bandwidth than the
new regdomain would allow after a change due to association country
information getting used, and one for an issue in the code where
mac80211 doesn't correctly ignore a reserved field and then uses an HT
instead of VHT association."
For the iwlwifi bits, Emmanuel says:
"Johannes fixes a long standing bug in the AMPDU status reporting.
Max fixes the listen time which was way too long and causes trouble
to several APs."
Along with those, Bing Zhao marks the mwifiex_usb driver as _not_
supporting USB autosuspend after a number of problems with that have
been reported.
RFC4895 introduced AUTH chunks for SCTP; during the SCTP
handshake RANDOM; CHUNKS; HMAC-ALGO are negotiated (CHUNKS
being optional though):
---------- INIT[RANDOM; CHUNKS; HMAC-ALGO] ---------->
<------- INIT-ACK[RANDOM; CHUNKS; HMAC-ALGO] ---------
-------------------- COOKIE-ECHO -------------------->
<-------------------- COOKIE-ACK ---------------------
A special case is when an endpoint requires COOKIE-ECHO
chunks to be authenticated:
------------------ AUTH; COOKIE-ECHO ---------------->
RFC4895, section 6.3. Receiving Authenticated Chunks says:
The receiver MUST use the HMAC algorithm indicated in
the HMAC Identifier field. If this algorithm was not
specified by the receiver in the HMAC-ALGO parameter in
the INIT or INIT-ACK chunk during association setup, the
AUTH chunk and all the chunks after it MUST be discarded
and an ERROR chunk SHOULD be sent with the error cause
defined in Section 4.1. [...] If no endpoint pair shared
key has been configured for that Shared Key Identifier,
all authenticated chunks MUST be silently discarded. [...]
When an endpoint requires COOKIE-ECHO chunks to be
authenticated, some special procedures have to be followed
because the reception of a COOKIE-ECHO chunk might result
in the creation of an SCTP association. If a packet arrives
containing an AUTH chunk as a first chunk, a COOKIE-ECHO
chunk as the second chunk, and possibly more chunks after
them, and the receiver does not have an STCB for that
packet, then authentication is based on the contents of
the COOKIE-ECHO chunk. In this situation, the receiver MUST
authenticate the chunks in the packet by using the RANDOM
parameters, CHUNKS parameters and HMAC_ALGO parameters
obtained from the COOKIE-ECHO chunk, and possibly a local
shared secret as inputs to the authentication procedure
specified in Section 6.3. If authentication fails, then
the packet is discarded. If the authentication is successful,
the COOKIE-ECHO and all the chunks after the COOKIE-ECHO
MUST be processed. If the receiver has an STCB, it MUST
process the AUTH chunk as described above using the STCB
from the existing association to authenticate the
COOKIE-ECHO chunk and all the chunks after it. [...]
Commit bbd0d59809f9 introduced the possibility to receive
and verification of AUTH chunk, including the edge case for
authenticated COOKIE-ECHO. On reception of COOKIE-ECHO,
the function sctp_sf_do_5_1D_ce() handles processing,
unpacks and creates a new association if it passed sanity
checks and also tests for authentication chunks being
present. After a new association has been processed, it
invokes sctp_process_init() on the new association and
walks through the parameter list it received from the INIT
chunk. It checks SCTP_PARAM_RANDOM, SCTP_PARAM_HMAC_ALGO
and SCTP_PARAM_CHUNKS, and copies them into asoc->peer
meta data (peer_random, peer_hmacs, peer_chunks) in case
sysctl -w net.sctp.auth_enable=1 is set. If in INIT's
SCTP_PARAM_SUPPORTED_EXT parameter SCTP_CID_AUTH is set,
peer_random != NULL and peer_hmacs != NULL the peer is to be
assumed asoc->peer.auth_capable=1, in any other case
asoc->peer.auth_capable=0.
Now, if in sctp_sf_do_5_1D_ce() chunk->auth_chunk is
available, we set up a fake auth chunk and pass that on to
sctp_sf_authenticate(), which at latest in
sctp_auth_calculate_hmac() reliably dereferences a NULL pointer
at position 0..0008 when setting up the crypto key in
crypto_hash_setkey() by using asoc->asoc_shared_key that is
NULL as condition key_id == asoc->active_key_id is true if
the AUTH chunk was injected correctly from remote. This
happens no matter what net.sctp.auth_enable sysctl says.
The fix is to check for net->sctp.auth_enable and for
asoc->peer.auth_capable before doing any operations like
sctp_sf_authenticate() as no key is activated in
sctp_auth_asoc_init_active_key() for each case.
Now as RFC4895 section 6.3 states that if the used HMAC-ALGO
passed from the INIT chunk was not used in the AUTH chunk, we
SHOULD send an error; however in this case it would be better
to just silently discard such a maliciously prepared handshake
as we didn't even receive a parameter at all. Also, as our
endpoint has no shared key configured, section 6.3 says that
MUST silently discard, which we are doing from now onwards.
Before calling sctp_sf_pdiscard(), we need not only to free
the association, but also the chunk->auth_chunk skb, as
commit bbd0d59809f9 created a skb clone in that case.
I have tested this locally by using netfilter's nfqueue and
re-injecting packets into the local stack after maliciously
modifying the INIT chunk (removing RANDOM; HMAC-ALGO param)
and the SCTP packet containing the COOKIE_ECHO (injecting
AUTH chunk before COOKIE_ECHO). Fixed with this patch applied.
Fixes: bbd0d59809f9 ("[SCTP]: Implement the receive and verification of AUTH chunk")
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Cc: Vlad Yasevich <yasevich@gmail.com>
Cc: Neil Horman <nhorman@tuxdriver.com>
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
git://gitorious.org/linux-can/linux-can
linux-can-fixes-for-3.14-20140303
Marc Kleine-Budde says:
this is a pull request of 8 patches. Oliver Hartkopp contributes a patch which
removes the CAN FD compatibility for CAN 2.0 sockets, as it turns out that this
compatibility has some conceptual cornercases. The remaining 7 patches are by
me, they address a problem in the flexcan driver. When shutting down the
interface ("ifconfig can0 down") under heavy network load the whole system will
hang. This series reworks the actual sequence in close() and the transition
from and to the low power modes of the CAN controller.
Add the following snmp stats:
TCPFastOpenActiveFail: Fast Open attempts (SYN/data) failed beacuse
the remote does not accept it or the attempts timed out.
TCPSynRetrans: number of SYN and SYN/ACK retransmits to break down
retransmissions into SYN, fast-retransmits, timeout retransmits, etc.
TCPOrigDataSent: number of outgoing packets with original data (excluding
retransmission but including data-in-SYN). This counter is different from
TcpOutSegs because TcpOutSegs also tracks pure ACKs. TCPOrigDataSent is
more useful to track the TCP retransmission rate.
Change TCPFastOpenActive to track only successful Fast Opens to be symmetric to
TCPFastOpenPassive.
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Signed-off-by: Nandita Dukkipati <nanditad@google.com>
Signed-off-by: Lawrence Brakmo <brakmo@google.com>
when ip_tunnel process multicast packets, it may check if the packet is looped
back packet though 'rt_is_output_route(skb_rtable(skb))' in ip_tunnel_rcv(),
but before that , skb->_skb_refdst has been dropped in iptunnel_pull_header(),
so which leads to a panic.
fix the bug: https://bugzilla.kernel.org/show_bug.cgi?id=70681
Signed-off-by: Xin Long <lucien.xin@gmail.com>
On x86_64 we have 3 holes in struct tbf_sched_data.
The member peak_present can be replaced with peak.rate_bytes_ps,
because peak.rate_bytes_ps is set only when peak is specified in
tbf_change(). tbf_peak_present() is introduced to test
peak.rate_bytes_ps.
The member max_size is moved to fill 32bit hole.
Signed-off-by: Hiroaki SHIMODA <shimoda.hiroaki@gmail.com>
RTT may be bogus with tall loss probe (TLP) when a packet
is retransmitted and latter (s)acked without TCPCB_SACKED_RETRANS flag.
For example, TLP calls __tcp_retransmit_skb() instead of
tcp_retransmit_skb(). The skb timestamps are updated but the sacked
flag is not marked with TCPCB_SACKED_RETRANS. As a result we'll
get bogus RTT in tcp_clean_rtx_queue() or in tcp_sacktag_one() on
spurious retransmission.
The fix is to apply the sticky flag TCP_EVER_RETRANS to enforce Karn's
check on RTT sampling. However this will disable F-RTO if timeout occurs
after TLP, by resetting undo_marker in tcp_enter_loss(). We relax this
check to only if any pending retransmists are still in-flight.
Acked-by: Neal Cardwell <ncardwell@google.com>
Acked-by: Nandita Dukkipati <nanditad@google.com>
This is a sanity check and we never pass invalid values so this patch
doesn't change anything. However the node->time_in[] array has
HSR_MAX_SLAVE (2) elements and not HSR_MAX_DEV (3).
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
In commit e2d265d3b587 (canfd: add support for CAN FD in CAN_RAW sockets)
CAN FD frames with a payload length up to 8 byte are passed to legacy
sockets where the CAN FD support was not enabled by the application.
After some discussions with developers at a fair this well meant feature
leads to confusion as no clean switch for CAN / CAN FD is provided to the
application programmer. Additionally a compatibility like this for legacy
CAN_RAW sockets requires some compatibility handling for the sending, e.g.
make CAN2.0 frames a CAN FD frame with BRS at transmission time (?!?).
This will become a mess when people start to develop applications with
real CAN FD hardware. This patch reverts the bad compatibility code
together with the documentation describing the removed feature.
Acked-by: Stephane Grosjean <s.grosjean@peak-system.com>
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
The initialization of the tag value doesn't matter at begin of
fragmentation. This patch removes the initialization to zero.
Datagram size value is u16 because we convert it to host byte order
and we need to read it. Only the tag value belongs to __be16 type.
This patch drops the current way of 6lowpan fragmentation on receiving
side and replace it with a implementation which use the inet_frag api.
The old fragmentation handling has some race conditions and isn't
rfc4944 compatible. Also adding support to match fragments on
destination address, source address, tag value and datagram_size
which is missing in the current implementation.
Detected with:
./scripts/checkpatch.pl --strict -f net/ieee802154/6lowpan_rtnl.c
We have a 6lowpan.c file and 6lowpan.ko file. To avoid confusing we
should move 6lowpan.c to 6lowpan_rtnl.c. Then we can support multiple
source files for 6lowpan module.
This patch fix the fragmentation on sending side according to rfc4944.
Also add improvement to use the full payload of a PDU which calculate
the nearest divided to 8 payload length for the fragmentation datagram
size attribute.
The main issue is that the datagram size of fragmentation header use the
ipv6 payload length, but rfc4944 says it's the ipv6 payload length inclusive
network header size (and transport header size if compressed).
This patch add a lookup function for uncompressed 6LoWPAN header
size. This is needed to estimate the real size after uncompress the
6LoWPAN header.
Commit 57f89bfa2140 ("network: Allow af_packet to transmit +4 bytes
for VLAN packets.") added the possibility for non-mmaped frames to
send extra 4 byte for VLAN header so the MTU increases from 1500 to
1504 byte, for example.
Commit cbd89acb9eb2 ("af_packet: fix for sending VLAN frames via
packet_mmap") attempted to fix that for the mmap part but was
reverted as it caused regressions while using eth_type_trans()
on output path.
Lets just act analogous to 57f89bfa2140 and add a similar logic
to TX_RING. We presume size_max as overcharged with +4 bytes and
later on after skb has been built by tpacket_fill_skb() check
for ETH_P_8021Q header on packets larger than normal MTU. Can
be easily reproduced with a slightly modified trafgen in mmap(2)
mode, test cases:
{ fill(0xff, 12) const16(0x8100) fill(0xff, <1504|1505>) }
{ fill(0xff, 12) const16(0x0806) fill(0xff, <1500|1501>) }
Note that we need to do the test right after tpacket_fill_skb()
as sockets can have PACKET_LOSS set where we would not fail but
instead just continue to traverse the ring.
Reported-by: Mathias Kretschmer <mathias.kretschmer@fokus.fraunhofer.de>
Cc: Ben Greear <greearb@candelatech.com>
Cc: Phil Sutter <phil@nwl.cc>
Tested-by: Mathias Kretschmer <mathias.kretschmer@fokus.fraunhofer.de>
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211
The commit 9195bb8e381d81d5a315f911904cdf0cfcc919b8 ("ipv6: improve
ipv6_find_hdr() to skip empty routing headers") broke ipv6_find_hdr().
When a target is specified like IPPROTO_ICMPV6 ipv6_find_hdr()
returns -ENOENT when it's found, not the header as expected.
A part of IPVS is broken and possible also nft_exthdr_eval().
When target is -1 which it is most cases, it works.
This patch exits the do while loop if the specific header is found
so the nexthdr could be returned as expected.
Reported-by: Art -kwaak- van Breemen <ard@telegraafnet.nl>
Signed-off-by: Hans Schillstrom <hans@schillstrom.com>
CC:Ansis Atteka <aatteka@nicira.com>
If the neigh table's entries is less than gc_thresh1, the function
will return directly, and the reachabletime will not be recompute,
so the reachabletime can be guessed.
Signed-off-by: Duan Jiong <duanj.fnst@cn.fujitsu.com>
Regarding the mac80211 bits, Johannes says:
"This time, I have a fix from Arik for scheduled scan recovery (something
that only recently went into the tree), a memory leak fix from Eytan and
a small regulatory bugfix from Inbal. The EAPOL change from Felix makes
rekeying more stable while lots of traffic is flowing, and there's
Emmanuel's and my fixes for a race in the code handling powersaving
clients."
Regarding the NFC bits, Samuel says:
"We only have one candidate for 3.14 fixes, and this is a NCI NULL
pointer dereference introduced during the 3.14 merge window."
Regarding the iwlwifi bits, Emmanuel says:
"This should fix an issue raised in iwldvm when we have lots of
association failures. There is a bugzilla for this bug - it hasn't
been validated by the user, but I hope it will do the trick."
Beyond that...
Amitkumar Karwar brings two mwifiex fixes, one to avoid a NULL pointer
dereference and another to address an improperly timed interrupt.
Arend van Spriel gives us a brcmfmac fix to avoid a crash during
scatter-gather packet transfers.
Avinash Patila offers an mwifiex to avoid an invalid memory access
when a device is removed.
Bing Zhao delivers a simple fix to avoid a naming conflict between
libertas and mwifiex.
Felix Fietkau provides a trio of ath9k fixes that properly account
for sequence numbering in ps-poll frames, reduce the rate for false
positives during baseband hang detection, and fix a regression related
to rx descriptor handling.
James Cameron shows us a libertas fix to ignore zero-length IEs when
processing scan results.
Kirill Tkhai brings a hostap fix to avoid prematurely freeing a timer.
Stanislaw Gruszka fixes an ath9k locking problem.
Sujith Manoharan addresses ETSI compliance for a device handled by
ath9k by adjusting the minimum CCA power threshold values.
Because those following if conditions will not be matched.
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec-next
Steffen Klassert says:
This is the rework of the IPsec virtual tunnel interface
for ipv4 to support inter address family tunneling and
namespace crossing. The only change to the last RFC version
is a compile fix for an odd configuration where CONFIG_XFRM
is set but CONFIG_INET is not set.
1) Add and use a IPsec protocol multiplexer.
2) Add xfrm_tunnel_skb_cb to the skb common buffer
to store a receive callback there.
3) Make vti work with i_key set by not including the i_key
when comupting the hash for the tunnel lookup in case of
vti tunnels.
4) Update ip_vti to use it's own receive hook.
5) Remove xfrm_tunnel_notifier, this is replaced by the IPsec
6) We need to be protocol family indepenent, so use the on xfrm_lookup
returned dst_entry instead of the ipv4 rtable in vti_tunnel_xmit().
7) Add support for inter address family tunneling.
8) Check if the tunnel endpoints of the xfrm state and the vti interface
are matching and return an error otherwise.
8) Enable namespace crossing tor vti devices.
1) Build fix for ip_vti when NET_IP_TUNNEL is not set.
We need this set to have ip_tunnel_get_stats64()
available.
2) Fix a NULL pointer dereference on sub policy usage.
We try to access a xfrm_state from the wrong array.
3) Take xfrm_state_lock in xfrm_migrate_state_find(),
we need it to traverse through the state lists.
4) Clone states properly on migration, otherwise we crash
when we migrate a state with aead algorithm attached.
5) Fix unlink race when between thread context and timer
when policies are deleted.
Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
When a VHT network uses 20 or 40 MHz as per the HT operation
information, the channel center frequency segment 0 field in
the VHT operation information is reserved, so ignore it.
This fixes association with such networks when the AP puts 0
into the field, previously we'd disconnect due to an invalid
channel with the message
wlan0: AP VHT information is invalid, disable VHT
Cc: stable@vger.kernel.org
Fixes: f2d9d270c15ae ("mac80211: support VHT association")
Reported-by: Tim Nelson <tim.l.nelson@gmail.com>
The allocated child qdisc is not freed in error conditions.
Defer the allocation after user configuration turns out to be
valid and acceptable.
Fixes: cc106e441a63b ("net: sched: tbf: fix the calculation of max_size")
Cc: Yang Yingliang <yangyingliang@huawei.com>
Upcoming congestion controls for TCP require usec resolution for RTT
estimations. Millisecond resolution is simply not enough these days.
FQ/pacing in DC environments also require this change for finer control
and removal of bimodal behavior due to the current hack in
tcp_update_pacing_rate() for 'small rtt'
TCP_CONG_RTT_STAMP is no longer needed.
As Julian Anastasov pointed out, we need to keep user compatibility :
tcp_metrics used to export RTT and RTTVAR in msec resolution,
so we added RTT_US and RTTVAR_US. An iproute2 patch is needed
to use the new attributes if provided by the kernel.
In this example ss command displays a srtt of 32 usecs (10Gbit link)
lpk51:~# ./ss -i dst lpk52
Netid State Recv-Q Send-Q Local Address:Port Peer
Address:Port
tcp ESTAB 0 1 10.246.11.51:42959
10.246.11.52:64614
cubic wscale:6,6 rto:201 rtt:0.032/0.001 ato:40 mss:1448
cwnd:10 send
3620.0Mbps pacing_rate 7240.0Mbps unacked:1 rcv_rtt:993 rcv_space:29559
Updated iproute2 ip command displays :
lpk51:~# ./ip tcp_metrics | grep 10.246.11.52
10.246.11.52 age 561.914sec cwnd 10 rtt 274us rttvar 213us source
10.246.11.51
Old binary displays :
lpk51:~# ip tcp_metrics | grep 10.246.11.52
10.246.11.52 age 561.914sec cwnd 10 rtt 250us rttvar 125us source
10.246.11.51
With help from Julian Anastasov, Stephen Hemminger and Yuchung Cheng
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Yuchung Cheng <ycheng@google.com>
Cc: Larry Brakmo <brakmo@google.com>
Cc: Julian Anastasov <ja@ssi.bg>
This option has the same semantic as IP_PMTUDISC_OMIT for IPv4 which
got recently introduced. It doesn't honor the path mtu discovered by the
host but in contrary to IPV6_PMTUDISC_INTERFACE allows the generation of
fragments if the packet size exceeds the MTU of the outgoing interface
MTU.
Fixes: 93b36cf3425b9b ("ipv6: support IPV6_PMTU_INTERFACE on sockets")
Cc: Florian Weimer <fweimer@redhat.com>
IP_PMTUDISC_INTERFACE has a design error: because it does not allow the
generation of fragments if the interface mtu is exceeded, it is very
hard to make use of this option in already deployed name server software
for which I introduced this option.
This patch adds yet another new IP_MTU_DISCOVER option to not honor any
path mtu information and not accepting new icmp notifications destined for
the socket this option is enabled on. But we allow outgoing fragmentation
in case the packet size exceeds the outgoing interface mtu.
As such this new option can be used as a drop-in replacement for
IP_PMTUDISC_DONT, which is currently in use by most name server software
making the adoption of this option very smooth and easy.
The original advantage of IP_PMTUDISC_INTERFACE is still maintained:
ignoring incoming path MTU updates and not honoring discovered path MTUs
in the output path.
Fixes: 482fc6094afad5 ("ipv4: introduce new IP_MTU_DISCOVER mode IP_PMTUDISC_INTERFACE")
ip_skb_dst_mtu mostly falls back to ip_dst_mtu_maybe_forward if no socket
is attached to the skb (in case of forwarding) or determines the mtu like
we do in ip_finish_output, which actually checks if we should branch to
ip_fragment. Thus use the same function to determine the mtu here, too.
This is important for the introduction of IP_PMTUDISC_OMIT, where we
want the packets getting cut in pieces of the size of the outgoing
interface mtu. IPv6 already does this correctly.
iproute2 arpd seems to expect this as there's code and comments
to handle netlink probes with NUD_PROBE set. It is used to flush
the arpd cached mappings.
opennhrp instead turns off unicast probes (so it can handle all
neighbour discovery). Without this change it will not see NUD_PROBE
probes and cannot reconfirm the mapping. Thus currently neigh entry
will just fail and can cause few packets dropped until broadcast
discovery is restarted.
Earlier discussion on the subject:
http://marc.info/?t=139305877100001&r=1&w=2
Signed-off-by: Timo Teräs <timo.teras@iki.fi>
