Pull nfsd updates from Bruce Fields:
"The main change is the pNFS block server support from Christoph, which
allows an NFS client connected to shared disk to do block IO to the
shared disk in place of NFS reads and writes. This also requires xfs
patches, which should arrive soon through the xfs tree, barring
unexpected problems. Support for other filesystems is also possible
if there's interest.
Thanks also to Chuck Lever for continuing work to get NFS/RDMA into
shape"
* 'for-3.20' of git://linux-nfs.org/~bfields/linux: (32 commits)
nfsd: default NFSv4.2 to on
nfsd: pNFS block layout driver
exportfs: add methods for block layout exports
nfsd: add trace events
nfsd: update documentation for pNFS support
nfsd: implement pNFS layout recalls
nfsd: implement pNFS operations
nfsd: make find_any_file available outside nfs4state.c
nfsd: make find/get/put file available outside nfs4state.c
nfsd: make lookup/alloc/unhash_stid available outside nfs4state.c
nfsd: add fh_fsid_match helper
nfsd: move nfsd_fh_match to nfsfh.h
fs: add FL_LAYOUT lease type
fs: track fl_owner for leases
nfs: add LAYOUT_TYPE_MAX enum value
nfsd: factor out a helper to decode nfstime4 values
sunrpc/lockd: fix references to the BKL
nfsd: fix year-2038 nfs4 state problem
svcrdma: Handle additional inline content
svcrdma: Move read list XDR round-up logic
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security layer updates from James Morris:
"Highlights:
- Smack adds secmark support for Netfilter
- /proc/keys is now mandatory if CONFIG_KEYS=y
- TPM gets its own device class
- Added TPM 2.0 support
- Smack file hook rework (all Smack users should review this!)"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (64 commits)
cipso: don't use IPCB() to locate the CIPSO IP option
SELinux: fix error code in policydb_init()
selinux: add security in-core xattr support for pstore and debugfs
selinux: quiet the filesystem labeling behavior message
selinux: Remove unused function avc_sidcmp()
ima: /proc/keys is now mandatory
Smack: Repair netfilter dependency
X.509: silence asn1 compiler debug output
X.509: shut up about included cert for silent build
KEYS: Make /proc/keys unconditional if CONFIG_KEYS=y
MAINTAINERS: email update
tpm/tpm_tis: Add missing ifdef CONFIG_ACPI for pnp_acpi_device
smack: fix possible use after frees in task_security() callers
smack: Add missing logging in bidirectional UDS connect check
Smack: secmark support for netfilter
Smack: Rework file hooks
tpm: fix format string error in tpm-chip.c
char/tpm/tpm_crb: fix build error
smack: Fix a bidirectional UDS connect check typo
smack: introduce a special case for tmpfs in smack_d_instantiate()
Merge second set of updates from Andrew Morton:
"More of MM"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (83 commits)
mm/nommu.c: fix arithmetic overflow in __vm_enough_memory()
mm/mmap.c: fix arithmetic overflow in __vm_enough_memory()
vmstat: Reduce time interval to stat update on idle cpu
mm/page_owner.c: remove unnecessary stack_trace field
Documentation/filesystems/proc.txt: describe /proc/<pid>/map_files
mm: incorporate read-only pages into transparent huge pages
vmstat: do not use deferrable delayed work for vmstat_update
mm: more aggressive page stealing for UNMOVABLE allocations
mm: always steal split buddies in fallback allocations
mm: when stealing freepages, also take pages created by splitting buddy page
mincore: apply page table walker on do_mincore()
mm: /proc/pid/clear_refs: avoid split_huge_page()
mm: pagewalk: fix misbehavior of walk_page_range for vma(VM_PFNMAP)
mempolicy: apply page table walker on queue_pages_range()
arch/powerpc/mm/subpage-prot.c: use walk->vma and walk_page_vma()
memcg: cleanup preparation for page table walk
numa_maps: remove numa_maps->vma
numa_maps: fix typo in gather_hugetbl_stats
pagemap: use walk->vma instead of calling find_vma()
clear_refs: remove clear_refs_private->vma and introduce clear_refs_test_walk()
Pull NFS client updates from Trond Myklebust:
"Highlights incluse:
Features:
- Removing the forced serialisation of open()/close() calls in
NFSv4.x (x>0) makes for a significant performance improvement in
metadata intensive workloads.
- Full support for the pNFS "flexible files" layout type
- Further RPC/RDMA client improvements from Chuck
Bugfixes:
- Stable fix: NFSv4.1 backchannel calls blocking operations with !TASK_RUNNING
- Stable fix: pnfs_generic_pg_init_read/write can be called with lseg == NULL
- Stable fix: Fix an Oopsable condition when nsm_mon_unmon is called
as part of the namespace cleanup,
- Stable fix: Ensure we reference the inode for return-on-close in
delegreturn
- Use SO_REUSEPORT to ensure that NFSv3 TCP connections can rebind to
the same source address/port combination during a disconnect/
reconnect event. This is a requirement imposed by most NFSv3
server duplicate reply cache implementations.
Optimisations:
- Ask for no NFSv4.1 delegations on OPEN if using O_DIRECT
Other:
- Add Anna Schumaker as co-maintainer for the NFS client"
* tag 'nfs-for-3.20-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (119 commits)
SUNRPC: Cleanup to remove xs_tcp_close()
pnfs: delete an unintended goto
pnfs/flexfiles: Do not dprintk after the free
SUNRPC: Fix stupid typo in xs_sock_set_reuseport
SUNRPC: Define xs_tcp_fin_timeout only if CONFIG_SUNRPC_DEBUG
SUNRPC: Handle connection reset more efficiently.
SUNRPC: Remove the redundant XPRT_CONNECTION_CLOSE flag
SUNRPC: Make xs_tcp_close() do a socket shutdown rather than a sock_release
SUNRPC: Ensure xs_tcp_shutdown() requests a full close of the connection
SUNRPC: Cleanup to remove remaining uses of XPRT_CONNECTION_ABORT
SUNRPC: Remove TCP socket linger code
SUNRPC: Remove TCP client connection reset hack
SUNRPC: TCP/UDP always close the old socket before reconnecting
SUNRPC: Add helpers to prevent socket create from racing
SUNRPC: Ensure xs_reset_transport() resets the close connection flags
SUNRPC: Do not clear the source port in xs_reset_transport
SUNRPC: Handle EADDRINUSE on connect
SUNRPC: Set SO_REUSEPORT socket option for TCP connections
NFSv4.1: Fix pnfs_put_lseg races
NFSv4.1: pnfs_send_layoutreturn should use GFP_NOFS
This allows those get_user_pages calls to pass FAULT_FLAG_ALLOW_RETRY to
the page fault in order to release the mmap_sem during the I/O.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Reviewed-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Andres Lagar-Cavilla <andreslc@google.com>
Cc: Peter Feiner <pfeiner@google.com>
The unified hierarchy interface for memory cgroups will no longer use "-1"
to mean maximum possible resource value. In preparation for this, make
the string an argument and let the caller supply it.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Acked-by: Michal Hocko <mhocko@suse.cz>
Cc: Vladimir Davydov <vdavydov@parallels.com>
Using the IPCB() macro to get the IPv4 options is convenient, but
unfortunately NetLabel often needs to examine the CIPSO option outside
of the scope of the IP layer in the stack. While historically IPCB()
worked above the IP layer, due to the inclusion of the inet_skb_param
struct at the head of the {tcp,udp}_skb_cb structs, recent commit
971f10ec ("tcp: better TCP_SKB_CB layout to reduce cache line misses")
reordered the tcp_skb_cb struct and invalidated this IPCB() trick.
This patch fixes the problem by creating a new function,
cipso_v4_optptr(), which locates the CIPSO option inside the IP header
without calling IPCB(). Unfortunately, this isn't as fast as a simple
lookup so some additional tweaks were made to limit the use of this
new function.
Cc: <stable@vger.kernel.org> # 3.18
Reported-by: Casey Schaufler <casey@schaufler-ca.com>
Signed-off-by: Paul Moore <pmoore@redhat.com>
Tested-by: Casey Schaufler <casey@schaufler-ca.com>
xs_tcp_close() is now just a call to xs_tcp_shutdown(), so remove it,
and replace the entry in xs_tcp_ops.
Suggested-by: Anna Schumaker <anna.schumaker@netapp.com>
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
Packetization Layer Path MTU Discovery works separately beside
Path MTU Discovery at IP level, different net namespace has
various requirements on which one to chose, e.g., a virutalized
container instance would require TCP PMTU to probe an usable
effective mtu for underlying tunnel, while the host would
employ classical ICMP based PMTU to function.
Hence making TCP PMTU mechanism per net namespace to decouple
two functionality. Furthermore the probe base MSS should also
be configured separately for each namespace.
Signed-off-by: Fan Du <fan.du@intel.com>
Yes, kernel_setsockopt() hates you for using a char argument.
If a server has enabled Fast Open and it receives a pure SYN-data
packet (without a Fast Open option), it won't accept the data but it
incorrectly returns a SYN-ACK with a Fast Open cookie and also
increments the SNMP stat LINUX_MIB_TCPFASTOPENPASSIVEFAIL.
This patch makes the server include a Fast Open cookie in SYN-ACK
only if the SYN has some Fast Open option (i.e., when client
requests or presents a cookie).
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
This avoids setting TUNNEL_VXLAN_OPT for VXLAN frames which don't
have any GBP metadata set. It is not invalid to set it but unnecessary.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
Acked-by: Pravin B Shelar <pshelar@nicira.com>
Make __ipv6_select_ident() static as it isn't used outside
the file.
Fixes: 0508c07f5e0c9 (ipv6: Select fragment id during UFO segmentation if not set.)
Signed-off-by: Vladislav Yasevich <vyasevic@redhat.com>
Recent commit:
0508c07f5e0c94f38afd5434e8b2a55b84553077
Author: Vlad Yasevich <vyasevich@gmail.com>
Date: Tue Feb 3 16:36:15 2015 -0500
Introduced a bug on LE in how ipv6 fragment id is assigned.
This was cought by nightly sparce check:
Resolve the following sparce error:
net/ipv6/output_core.c:57:38: sparse: incorrect type in assignment
(different base types)
net/ipv6/output_core.c:57:38: expected restricted __be32
[usertype] ip6_frag_id
net/ipv6/output_core.c:57:38: got unsigned int [unsigned]
[assigned] [usertype] id
Bridge's default_pvid adds a vid by default, by which we cannot add a
non-vlan fdb entry by default, because br_fdb_add() adds fdb entries for
all vlans instead of a non-vlan one when any vlan is configured.
# ip link add br0 type bridge
# ip link set eth0 master br0
# bridge fdb add 12:34:56:78:90:ab dev eth0 master temp
# bridge fdb show brport eth0 | grep 12:34:56:78:90:ab
12:34:56:78:90:ab dev eth0 vlan 1 static
We expect a non-vlan fdb entry as well as vlan 1:
12:34:56:78:90:ab dev eth0 static
To fix this, we need to insert a non-vlan fdb entry if vlan is not
specified, even when any vlan is configured.
Fixes: 5be5a2df40f0 ("bridge: Add filtering support for default_pvid")
Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp>
dsa_slave_phy_setup() finds the phy for the port via device tree and
using of_phy_connect(), or it uses the fall back of taking a phy from
the switch internal mdio bus and calling phy_connect_direct(). Either
way, if a phy is found, phy_attach_direct() is called to attach the
phy to the slave device.
In dsa_slave_create(), a second call to phy_attach() is made. This
results in the warning "PHY already attached". Remove this second,
redundant attaching of the phy.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
Tested-by: Florian Fainelli <f.fainelli@gmail.com>
tipc_snprintf() was heavily utilized by the old netlink API which no
longer exists (now netlink compat).
In this patch we swap tipc_snprintf() to the identical scnprintf() in
the only remaining occurrence.
Signed-off-by: Richard Alpe <richard.alpe@ericsson.com>
Reviewed-by: Erik Hugne <erik.hugne@ericsson.com>
Reviewed-by: Ying Xue <ying.xue@windriver.com>
Reviewed-by: Jon Maloy <jon.maloy@ericsson.com>
Add TIPC_CMD_NOOP to compat layer and remove the old framework.
All legacy nl commands are now converted to the compat layer in
netlink_compat.c.
Convert TIPC_CMD_SHOW_STATS to compat layer. This command does not
have any counterpart in the new API, meaning it now solely exists as a
function in the compat layer.
Convert TIPC_CMD_GET_NETID to compat dumpit.
Convert TIPC_CMD_SET_NETID to compat doit.
Convert TIPC_CMD_SET_NODE_ADDR to compat doit.
Convert TIPC_CMD_GET_NODES to compat dumpit and remove global node
counter solely used by the legacy API.
Convert TIPC_CMD_GET_MEDIA_NAMES to compat dumpit.
Convert socket (port) listing to compat dumpit call. If a socket
(port) has publications a second dumpit call is issued to collect them
and format then into the legacy buffer before continuing to process
the sockets (ports).
Command converted in this patch:
TIPC_CMD_SHOW_PORTS
Add functionality for printing a dump header and convert
TIPC_CMD_SHOW_NAME_TABLE to compat dumpit.
Convert TIPC_CMD_RESET_LINK_STATS to compat doit.
Convert setting of link proprieties to compat doit calls.
Commands converted in this patch:
TIPC_CMD_SET_LINK_TOL
TIPC_CMD_SET_LINK_PRI
TIPC_CMD_SET_LINK_WINDOW
Convert TIPC_CMD_GET_LINKS to compat dumpit and remove global link
Add functionality for safely appending string data to a TLV without
keeping write count in the caller.
Convert TIPC_CMD_SHOW_LINK_STATS to compat dumpit.
Introduce a framework for transcoding legacy nl action into actions
(.doit) calls from the new nl API. This is done by converting the
incoming TLV data into netlink data with nested netlink attributes.
Unfortunately due to the randomness of the legacy API we can't do this
generically so each legacy netlink command requires a specific
transcoding recipe. In this case for bearer enable and bearer disable.
Convert TIPC_CMD_ENABLE_BEARER and TIPC_CMD_DISABLE_BEARER into doit
compat calls.
Introduce a framework for dumping netlink data from the new netlink
API and formatting it to the old legacy API format. This is done by
looping the dump data and calling a format handler for each entity, in
this case a bearer.
We dump until either all data is dumped or we reach the limited buffer
size of the legacy API. Remember, the legacy API doesn't scale.
In this commit we convert TIPC_CMD_GET_BEARER_NAMES to use the compat
layer.
The new netlink API is no longer "v2" but rather the standard API and
the legacy API is now "nl compat". We split them into separate
start/stop and put them in different files in order to further
distinguish them.
Now that the linger code is gone, the xs_tcp_fin_timeout variable has
no real function. Keep it for now, since it is part of the /proc
interface, but only define it if that /proc interface is enabled.
Suggested-by: Anna Schumaker <Anna.Schumaker@netapp.com>
If the connection reset is due to an active call on our side, then
the state change is sometimes not reported. Catch those instances
using xs_error_report() instead.
Also remove the xs_tcp_shutdown() call in xs_tcp_send_request() as
the change in behaviour makes it redundant.
Use of socket shutdown() means that we monitor the shutdown process
through the xs_tcp_state_change() callback, so it is preferable to
a full close in all cases unless we're destroying the transport.
The previous behaviour left the connection half-open in order to try
to scrape the last replies from the socket. Now that we have more reliable
reconnection, change the behaviour to close down the socket faster.
Now that we no longer use the partial shutdown code when closing the
socket, we no longer need to worry about the TCP linger2 state.
Make sure root user does not try something stupid.
Also make sure mask field in struct rps_sock_flow_table
does not share a cache line with the potentially often dirtied
flow table.
Fixes: 567e4b79731c ("net: rfs: add hash collision detection")
Instead we rely on SO_REUSEPORT to provide the reconnection semantics
that we need for NFSv2/v3.
It is not safe to call xs_reset_transport() from inside xs_udp_setup_socket()
or xs_tcp_setup_socket(), since they do not own the correct locks. Instead,
do it in xs_connect().
The socket lock is currently held by the task that is requesting the
connection be established. While that is efficient in the case where
the connection happens quickly, it is racy in the case where it doesn't.
What we really want is for the connect helper to be able to block access
to the socket while it is being set up.
This patch does so by arranging to transfer the socket lock from the
task that is requesting the connect attempt, and then releasing that
lock once everything is done.
This scheme also gives us automatic protection against collisions with
the RPC close code, so we can kill the cancel_delayed_work_sync()
call in xs_close().
Otherwise, we may end up looping.
Now that we can reuse bound ports after a close, we never really want to
clear the transport's source port after it has been set. Doing so really
messes up the NFSv3 DRC on the server.
Now that we're setting SO_REUSEPORT, we still need to handle the
case where a connect() is attempted, but the old socket is still
lingering.
Essentially, all we want to do here is handle the error by waiting
a few seconds and then retrying.
Receive Flow Steering is a nice solution but suffers from
hash collisions when a mix of connected and unconnected traffic
is received on the host, when flow hash table is populated.
Also, clearing flow in inet_release() makes RFS not very good
for short lived flows, as many packets can follow close().
(FIN , ACK packets, ...)
This patch extends the information stored into global hash table
to not only include cpu number, but upper part of the hash value.
I use a 32bit value, and dynamically split it in two parts.
For host with less than 64 possible cpus, this gives 6 bits for the
cpu number, and 26 (32-6) bits for the upper part of the hash.
Since hash bucket selection use low order bits of the hash, we have
a full hash match, if /proc/sys/net/core/rps_sock_flow_entries is big
enough.
If the hash found in flow table does not match, we fallback to RPS (if
it is enabled for the rxqueue).
This means that a packet for an non connected flow can avoid the
IPI through a unrelated/victim CPU.
This also means we no longer have to clear the table at socket
close time, and this helps short lived flows performance.
Acked-by: Tom Herbert <therbert@google.com>
encap.sport and encap.dport are __be16, use nla_{get,put}_be16 instead
of nla_{get,put}_u16.
Fixes the sparse warnings:
warning: incorrect type in assignment (different base types)
expected restricted __be32 [addressable] [usertype] o_key
got restricted __be16 [addressable] [usertype] i_flags
expected restricted __be16 [usertype] sport
got unsigned short
expected restricted __be16 [usertype] dport
got unsigned short
warning: incorrect type in argument 3 (different base types)
expected unsigned short [unsigned] [usertype] value
got restricted __be16 [usertype] sport
got restricted __be16 [usertype] dport
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
