the individual socket
Introduce sk_gfp_atomic(), this function allows to inject sock specific
flags to each sock related allocation. It is only used on allocation
paths that may be required for writing pages back to network storage.
[davem@davemloft.net: Use sk_gfp_atomic only when necessary]
Cc: Neil Brown <neilb@suse.de>
Cc: Mike Christie <michaelc@cs.wisc.edu>
Cc: Eric B Munson <emunson@mgebm.net>
Cc: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
Cc: Christoph Lameter <cl@linux.com>
Sanity:
CONFIG_CGROUP_MEM_RES_CTLR -> CONFIG_MEMCG
CONFIG_CGROUP_MEM_RES_CTLR_SWAP -> CONFIG_MEMCG_SWAP
CONFIG_CGROUP_MEM_RES_CTLR_SWAP_ENABLED -> CONFIG_MEMCG_SWAP_ENABLED
CONFIG_CGROUP_MEM_RES_CTLR_KMEM -> CONFIG_MEMCG_KMEM
[mhocko@suse.cz: fix missed bits]
Cc: Glauber Costa <glommer@parallels.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
Cc: Tejun Heo <tj@kernel.org>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Pull NFS client updates from Trond Myklebust:
"Features include:
- More preparatory patches for modularising NFSv2/v3/v4. Split out
the various NFSv2/v3/v4-specific code into separate files
- More preparation for the NFSv4 migration code
- Ensure that OPEN(O_CREATE) observes the pNFS mds threshold
parameters
- pNFS fast failover when the data servers are down
- Various cleanups and debugging patches"
* tag 'nfs-for-3.6-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (67 commits)
nfs: fix fl_type tests in NFSv4 code
NFS: fix pnfs regression with directio writes
NFS: fix pnfs regression with directio reads
sunrpc: clnt: Add missing braces
nfs: fix stub return type warnings
NFS: exit_nfs_v4() shouldn't be an __exit function
SUNRPC: Add a missing spin_unlock to gss_mech_list_pseudoflavors
NFS: Split out NFS v4 client functions
NFS: Split out the NFS v4 filesystem types
NFS: Create a single nfs_clone_super() function
NFS: Split out NFS v4 server creating code
NFS: Initialize the NFS v4 client from init_nfs_v4()
NFS: Move the v4 getroot code to nfs4getroot.c
NFS: Split out NFS v4 file operations
NFS: Initialize v4 sysctls from nfs_init_v4()
NFS: Create an init_nfs_v4() function
NFS: Split out NFS v4 inode operations
NFS: Split out NFS v3 inode operations
NFS: Split out NFS v2 inode operations
NFS: Clean up nfs4_proc_setclientid() and friends
Add a missing set of braces that commit 4e0038b6b24
("SUNRPC: Move clnt->cl_server into struct rpc_xprt")
forgot.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: stable@vger.kernel.org [>= 3.4]
Back in 2006, commit 1a2449a87b ("[I/OAT]: TCP recv offload to I/OAT")
added support for receive offloading to IOAT dma engine if available.
The code in tcp_rcv_established() tries to perform early DMA copy if
applicable. It however does so without checking whether the userspace
task is actually expecting the data in the buffer.
This is not a problem under normal circumstances, but there is a corner
case where this doesn't work -- and that's when MSG_TRUNC flag to
recvmsg() is used.
If the IOAT dma engine is not used, the code properly checks whether
there is a valid ucopy.task and the socket is owned by userspace, but
misses the check in the dmaengine case.
This problem can be observed in real trivially -- for example 'tbench' is a
good reproducer, as it makes a heavy use of MSG_TRUNC. On systems utilizing
IOAT, you will soon find tbench waiting indefinitely in sk_wait_data(), as they
have been already early-copied in tcp_rcv_established() using dma engine.
This patch introduces the same check we are performing in the simple
iovec copy case to the IOAT case as well. It fixes the indefinite
recvmsg(MSG_TRUNC) hangs.
This reverts commit 5b3e7e6cb5771bedda51cdb6f715d1da8cd9e644.
The problem that the original commit was attempting to fix can
never happen in practice because validation is done one a per-flow
basis rather than a per-packet basis. Adding additional checks at
runtime is unnecessary and inconsistent with the rest of the code.
CC: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Jesse Gross <jesse@nicira.com>
commit 92101b3b2e317 (ipv4: Prepare for change of rt->rt_iif encoding.)
invalidated TCP early demux, because rx_dst_ifindex is not properly
initialized and checked.
Also remove the use of inet_iif(skb) in favor or skb->skb_iif
When device flags are set using rtnetlink, IFF_PROMISC and IFF_ALLMULTI
flags are handled specially. Function dev_change_flags sets IFF_PROMISC and
IFF_ALLMULTI bits in dev->gflags according to the passed value but
do_setlink passes a result of rtnl_dev_combine_flags which takes those bits
from dev->flags.
This can be easily trigerred by doing:
tcpdump -i eth0 &
ip l s up eth0
ip sets IFF_UP flag in ifi_flags and ifi_change, which is combined with
IFF_PROMISC by rtnl_dev_combine_flags, causing __dev_change_flags to set
IFF_PROMISC in gflags.
Reported-by: Max Matveev <makc@redhat.com>
Signed-off-by: Jiri Benc <jbenc@redhat.com>
TCP_USER_TIMEOUT is a TCP level socket option that takes an unsigned int. But
patch "tcp: Add TCP_USER_TIMEOUT socket option"(dca43c75) didn't check the negative
values. If a user assign -1 to it, the socket will set successfully and wait
for 4294967295 miliseconds. This patch add a negative value check to avoid
this issue.
Signed-off-by: Hangbin Liu <liuhangbin@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds
Pull LED subsystem update from Bryan Wu.
* 'for-3.6-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds: (50 commits)
leds-lp8788: forgotten unlock at lp8788_led_work
LEDS: propagate error codes in blinkm_detect()
LEDS: memory leak in blinkm_led_common_set()
leds: add new lp8788 led driver
LEDS: add BlinkM RGB LED driver, documentation and update MAINTAINERS
leds: max8997: Simplify max8997_led_set_mode implementation
leds/leds-s3c24xx: use devm_gpio_request
leds: convert Network Space v2 LED driver to devm_kzalloc() and cleanup error exit path
leds: convert DAC124S085 LED driver to devm_kzalloc()
leds: convert LM3530 LED driver to devm_kzalloc() and cleanup error exit path
leds: convert TCA6507 LED driver to devm_kzalloc()
leds: convert Freescale MC13783 LED driver to devm_kzalloc() and cleanup error exit path
leds: convert ADP5520 LED driver to devm_kzalloc() and cleanup error exit path
leds: convert PCA955x LED driver to devm_kzalloc() and cleanup error exit path
leds: convert Sun Fire LED driver to devm_kzalloc() and cleanup error exit path
leds: convert PCA9532 LED driver to devm_kzalloc()
leds: convert LT3593 LED driver to devm_kzalloc()
leds: convert Renesas TPU LED driver to devm_kzalloc() and cleanup error exit path
leds: convert LP5523 LED driver to devm_kzalloc() and cleanup error exit path
leds: convert PCA9633 LED driver to devm_kzalloc()
Pull networking updates and fixes from David Miller:
1) Reinstate the no-ref optimization for input route lookups in ipv4 to
fix some routing cache removal perf regressions.
2) Make TCP socket pre-demux work on ipv6 side too, from Eric Dumazet.
3) Get RX hash value from correct place in be2net driver, from
Sarveshwar Bandi.
4) Validation of FIB cached routes missing critical check, from Eric
Dumazet.
5) EEH support in mlx4 driver, from Kleber Sacilotto de Souza.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (23 commits)
ipv6: Early TCP socket demux
ipv4: Fix input route performance regression.
pch_gbe: vlan skb len fix
pch_gbe: add extra clean tx
pch_gbe: fix transmit watchdog timeout
ixgbe: fix panic while dumping packets on Tx hang with IOMMU
be2net: Fix to parse RSS hash from Receive completions correctly.
net/mlx4_en: Limit the RFS filter IDs to be < RPS_NO_FILTER
hyperv: Add error handling to rndis_filter_device_add()
hyperv: Add a check for ring_size value
ipv4: rt_cache_valid must check expired routes
net/pch_gpe: Cannot disable ethernet autonegation
qeth: repair crash in qeth_l3_vlan_rx_kill_vid()
netiucv: cleanup attribute usage
net: wiznet add missing HAS_IOMEM dependency
be2net: Missing byteswap in be_get_fw_log_level causes oops on PowerPC
mlx4: Add support for EEH error recovery
cdc-ncm: tag Ericsson WWAN devices (eg F5521gw) with FLAG_WWAN
wanmain: comparing array with NULL
caif: fix NULL pointer check
This is the IPv6 missing bits for infrastructure added in commit
41063e9dd1195 (ipv4: Early TCP socket demux.)
With the routing cache removal we lost the "noref" code paths on
input, and this can kill some routing workloads.
Reinstate the noref path when we hit a cached route in the FIB
nexthops.
With help from Eric Dumazet.
Reported-by: Alexander Duyck <alexander.duyck@gmail.com>
commit d2d68ba9fe8 (ipv4: Cache input routes in fib_info nexthops.)
introduced rt_cache_valid() helper. It unfortunately doesn't check if
route is expired before caching it.
I noticed sk_setup_caps() was constantly called on a tcp workload.
gcc really should warn about these !
Signed-off-by: Alan Cox <alan@linux.intel.com>
1) Remove a non needed pskb_may_pull() in tcp_v4_early_demux()
and fix a potential bug if skb->head was reallocated
(iph & th pointers were not reloaded)
TCP stack will pull/check headers anyway.
2) must reload iph in ip_rcv_finish() after early_demux()
call since skb->head might have changed.
3) skb->dev->ifindex can be now replaced by skb->skb_iif
Pull trivial tree from Jiri Kosina:
"Trivial updates all over the place as usual."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (29 commits)
Fix typo in include/linux/clk.h .
pci: hotplug: Fix typo in pci
iommu: Fix typo in iommu
video: Fix typo in drivers/video
Documentation: Add newline at end-of-file to files lacking one
arm,unicore32: Remove obsolete "select MISC_DEVICES"
module.c: spelling s/postition/position/g
cpufreq: Fix typo in cpufreq driver
trivial: typo in comment in mksysmap
mach-omap2: Fix typo in debug message and comment
scsi: aha152x: Fix sparse warning and make printing pointer address more portable.
Change email address for Steve Glendinning
Btrfs: fix typo in convert_extent_bit
via: Remove bogus if check
netprio_cgroup.c: fix comment typo
backlight: fix memory leak on obscure error path
Documentation: asus-laptop.txt references an obsolete Kconfig item
Documentation: ManagementStyle: fixed typo
mm/vmscan: cleanup comment error in balance_pgdat
mm: cleanup on the comments of zone_reclaim_stat
Pull networking changes from David S Miller:
1) Remove the ipv4 routing cache. Now lookups go directly into the FIB
trie and use prebuilt routes cached there.
No more garbage collection, no more rDOS attacks on the routing
cache. Instead we now get predictable and consistent performance,
no matter what the pattern of traffic we service.
This has been almost 2 years in the making. Special thanks to
Julian Anastasov, Eric Dumazet, Steffen Klassert, and others who
have helped along the way.
I'm sure that with a change of this magnitude there will be some
kind of fallout, but such things ought the be simple to fix at this
point. Luckily I'm not European so I'll be around all of August to
fix things :-)
The major stages of this work here are each fronted by a forced
merge commit whose commit message contains a top-level description
of the motivations and implementation issues.
2) Pre-demux of established ipv4 TCP sockets, saves a route demux on
input.
3) TCP SYN/ACK performance tweaks from Eric Dumazet.
4) Add namespace support for netfilter L4 conntrack helpers, from Gao
Feng.
5) Add config mechanism for Energy Efficient Ethernet to ethtool, from
Yuval Mintz.
6) Remove quadratic behavior from /proc/net/unix, from Eric Dumazet.
7) Support for connection tracker helpers in userspace, from Pablo
Neira Ayuso.
8) Allow userspace driven TX load balancing functions in TEAM driver,
from Jiri Pirko.
9) Kill off NLMSG_PUT and RTA_PUT macros, more gross stuff with
embedded gotos.
10) TCP Small Queues, essentially minimize the amount of TCP data queued
up in the packet scheduler layer. Whereas the existing BQL (Byte
Queue Limits) limits the pkt_sched --> netdevice queuing levels,
this controls the TCP --> pkt_sched queueing levels.
From Eric Dumazet.
11) Reduce the number of get_page/put_page ops done on SKB fragments,
from Alexander Duyck.
12) Implement protection against blind resets in TCP (RFC 5961), from
Eric Dumazet.
13) Support the client side of TCP Fast Open, basically the ability to
send data in the SYN exchange, from Yuchung Cheng.
Basically, the sender queues up data with a sendmsg() call using
MSG_FASTOPEN, then they do the connect() which emits the queued up
fastopen data.
14) Avoid all the problems we get into in TCP when timers or PMTU events
hit a locked socket. The TCP Small Queues changes added a
tcp_release_cb() that allows us to queue work up to the
release_sock() caller, and that's what we use here too. From Eric
Dumazet.
15) Zero copy on TX support for TUN driver, from Michael S. Tsirkin.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1870 commits)
genetlink: define lockdep_genl_is_held() when CONFIG_LOCKDEP
r8169: revert "add byte queue limit support".
ipv4: Change rt->rt_iif encoding.
net: Make skb->skb_iif always track skb->dev
ipv4: Remove all RTCF_DIRECTSRC handliing.
ipv4: Really ignore ICMP address requests/replies.
decnet: Don't set RTCF_DIRECTSRC.
net/ipv4/ip_vti.c: Fix __rcu warnings detected by sparse.
ipv4: Remove redundant assignment
rds: set correct msg_namelen
openvswitch: potential NULL deref in sample()
tcp: dont drop MTU reduction indications
bnx2x: Add new 57840 device IDs
tcp: avoid oops in tcp_metrics and reset tcpm_stamp
niu: Change niu_rbr_fill() to use unlikely() to check niu_rbr_add_page() return value
niu: Fix to check for dma mapping errors.
net: Fix references to out-of-scope variables in put_cmsg_compat()
net: ethernet: davinci_emac: add pm_runtime support
net: ethernet: davinci_emac: Remove unnecessary #include
lockdep_is_held() is defined when CONFIG_LOCKDEP, not CONFIG_PROVE_LOCKING.
Cc: Jesse Gross <jesse@nicira.com>
Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com>
Rename leds external interface led_brightness_set() to led_set_brightness().
This is the second phase of the change to reduce confusion between the
leds internal and external interfaces that set brightness. With this change,
now the external interface is led_set_brightness(). The first phase renamed
the internal interface led_set_brightness() to __led_set_brightness().
There are no changes to the interface implementations.
Signed-off-by: Shuah Khan <shuahkhan@gmail.com>
Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
On input packet processing, rt->rt_iif will be zero if we should
use skb->dev->ifindex.
Since we access rt->rt_iif consistently via inet_iif(), that is
the only spot whose interpretation have to adjust.
Make it follow device decapsulation, from things such as VLAN and
bonding.
The stuff that actually cares about pre-demuxed device pointers, is
handled by the "orig_dev" variable in __netif_receive_skb(). And
the only consumer of that is the po->origdev feature of AF_PACKET
sockets.
Use inet_iif() consistently, and for TCP record the input interface of
cached RX dst in inet sock.
rt->rt_iif is going to be encoded differently, so that we can
legitimately cache input routes in the FIB info more aggressively.
When the input interface is "use SKB device index" the rt->rt_iif will
be set to zero.
This forces us to move the TCP RX dst cache installation into the ipv4
specific code, and as well it should since doing the route caching for
ipv6 is pointless at the moment since it is not inspected in the ipv6
input paths yet.
Also, remove the unlikely on dst->obsolete, all ipv4 dsts have
obsolete set to a non-zero value to force invocation of the check
callback.
The last and final kernel user, ICMP address replies,
has been removed.
Alexey removed kernel side support for requests, and the
only thing we do for replies is log a message if something
doesn't look right.
As Alexey's comment indicates, this belongs in userspace (if
anywhere), and thus we can safely just get rid of this code.
It's an ipv4 defined route flag, and only ipv4 uses it.
With CONFIG_SPARSE_RCU_POINTER=y sparse identified references which did not
specificy __rcu in ip_vti.c
Signed-off-by: Saurabh Mohan <saurabh.mohan@vyatta.com>
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
It is redundant to set no_addr and accept_local to 0 and then set them
with other values just after that.
Signed-off-by: Lin Ming <mlin@ss.pku.edu.cn>
Pull the big VFS changes from Al Viro:
"This one is *big* and changes quite a few things around VFS. What's in there:
- the first of two really major architecture changes - death to open
intents.
The former is finally there; it was very long in making, but with
Miklos getting through really hard and messy final push in
fs/namei.c, we finally have it. Unlike his variant, this one
doesn't introduce struct opendata; what we have instead is
->atomic_open() taking preallocated struct file * and passing
everything via its fields.
Instead of returning struct file *, it returns -E... on error, 0
on success and 1 in "deal with it yourself" case (e.g. symlink
found on server, etc.).
See comments before fs/namei.c:atomic_open(). That made a lot of
goodies finally possible and quite a few are in that pile:
->lookup(), ->d_revalidate() and ->create() do not get struct
nameidata * anymore; ->lookup() and ->d_revalidate() get lookup
flags instead, ->create() gets "do we want it exclusive" flag.
With the introduction of new helper (kern_path_locked()) we are rid
of all struct nameidata instances outside of fs/namei.c; it's still
visible in namei.h, but not for long. Come the next cycle,
declaration will move either to fs/internal.h or to fs/namei.c
itself. [me, miklos, hch]
- The second major change: behaviour of final fput(). Now we have
__fput() done without any locks held by caller *and* not from deep
in call stack.
That obviously lifts a lot of constraints on the locking in there.
Moreover, it's legal now to call fput() from atomic contexts (which
has immediately simplified life for aio.c). We also don't need
anti-recursion logics in __scm_destroy() anymore.
There is a price, though - the damn thing has become partially
asynchronous. For fput() from normal process we are guaranteed
that pending __fput() will be done before the caller returns to
userland, exits or gets stopped for ptrace.
For kernel threads and atomic contexts it's done via
schedule_work(), so theoretically we might need a way to make sure
it's finished; so far only one such place had been found, but there
might be more.
There's flush_delayed_fput() (do all pending __fput()) and there's
__fput_sync() (fput() analog doing __fput() immediately). I hope
we won't need them often; see warnings in fs/file_table.c for
details. [me, based on task_work series from Oleg merged last
cycle]
- sync series from Jan
- large part of "death to sync_supers()" work from Artem; the only
bits missing here are exofs and ext4 ones. As far as I understand,
those are going via the exofs and ext4 trees resp.; once they are
in, we can put ->write_super() to the rest, along with the thread
calling it.
- preparatory bits from unionmount series (from dhowells).
- assorted cleanups and fixes all over the place, as usual.
This is not the last pile for this cycle; there's at least jlayton's
ESTALE work and fsfreeze series (the latter - in dire need of fixes,
so I'm not sure it'll make the cut this cycle). I'll probably throw
symlink/hardlink restrictions stuff from Kees into the next pile, too.
Plus there's a lot of misc patches I hadn't thrown into that one -
it's large enough as it is..."
* 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (127 commits)
ext4: switch EXT4_IOC_RESIZE_FS to mnt_want_write_file()
btrfs: switch btrfs_ioctl_balance() to mnt_want_write_file()
switch dentry_open() to struct path, make it grab references itself
spufs: shift dget/mntget towards dentry_open()
zoran: don't bother with struct file * in zoran_map
ecryptfs: don't reinvent the wheels, please - use struct completion
don't expose I_NEW inodes via dentry->d_inode
tidy up namei.c a bit
unobfuscate follow_up() a bit
ext3: pass custom EOF to generic_file_llseek_size()
ext4: use core vfs llseek code for dir seeks
vfs: allow custom EOF in generic_file_llseek code
vfs: Avoid unnecessary WB_SYNC_NONE writeback during sys_sync and reorder sync passes
vfs: Remove unnecessary flushing of block devices
vfs: Make sys_sync writeout also block device inodes
vfs: Create function for iterating over block devices
vfs: Reorder operations during sys_sync
quota: Move quota syncing to ->sync_fs method
quota: Split dquot_quota_sync() to writeback and cache flushing part
vfs: Move noop_backing_dev_info check from sync into writeback
Jay Fenlason (fenlason@redhat.com) found a bug,
that recvfrom() on an RDS socket can return the contents of random kernel
memory to userspace if it was called with a address length larger than
sizeof(struct sockaddr_in).
rds_recvmsg() also fails to set the addr_len paramater properly before
returning, but that's just a bug.
There are also a number of cases wher recvfrom() can return an entirely bogus
address. Anything in rds_recvmsg() that returns a non-negative value but does
not go through the "sin = (struct sockaddr_in *)msg->msg_name;" code path
at the end of the while(1) loop will return up to 128 bytes of kernel memory
to userspace.
And I write two test programs to reproduce this bug, you will see that in
rds_server, fromAddr will be overwritten and the following sock_fd will be
destroyed.
Yes, it is the programmer's fault to set msg_namelen incorrectly, but it is
better to make the kernel copy the real length of address to user space in
such case.
How to run the test programs ?
I test them on 32bit x86 system, 3.5.0-rc7.
1 compile
gcc -o rds_client rds_client.c
gcc -o rds_server rds_server.c
2 run ./rds_server on one console
3 run ./rds_client on another console
4 you will see something like:
server is waiting to receive data...
old socket fd=3
server received data from client:data from client
msg.msg_namelen=32
new socket fd=-1067277685
sendmsg()
: Bad file descriptor
/***************** rds_client.c ********************/
int main(void)
int sock_fd;
struct sockaddr_in serverAddr;
struct sockaddr_in toAddr;
char recvBuffer[128] = "data from client";
struct msghdr msg;
struct iovec iov;
sock_fd = socket(AF_RDS, SOCK_SEQPACKET, 0);
if (sock_fd < 0) {
perror("create socket error\n");
exit(1);
memset(&serverAddr, 0, sizeof(serverAddr));
serverAddr.sin_family = AF_INET;
serverAddr.sin_addr.s_addr = inet_addr("127.0.0.1");
serverAddr.sin_port = htons(4001);
if (bind(sock_fd, (struct sockaddr*)&serverAddr, sizeof(serverAddr)) < 0) {
perror("bind() error\n");
close(sock_fd);
exit(1);
memset(&toAddr, 0, sizeof(toAddr));
toAddr.sin_family = AF_INET;
toAddr.sin_addr.s_addr = inet_addr("127.0.0.1");
toAddr.sin_port = htons(4000);
msg.msg_name = &toAddr;
msg.msg_namelen = sizeof(toAddr);
msg.msg_iov = &iov;
msg.msg_iovlen = 1;
msg.msg_iov->iov_base = recvBuffer;
msg.msg_iov->iov_len = strlen(recvBuffer) + 1;
msg.msg_control = 0;
msg.msg_controllen = 0;
msg.msg_flags = 0;
if (sendmsg(sock_fd, &msg, 0) == -1) {
perror("sendto() error\n");
close(sock_fd);
exit(1);
printf("client send data:%s\n", recvBuffer);
memset(recvBuffer, '\0', 128);
msg.msg_iov = &iov;
msg.msg_iovlen = 1;
msg.msg_iov->iov_len = 128;
msg.msg_flags = 0;
if (recvmsg(sock_fd, &msg, 0) == -1) {
perror("recvmsg() error\n");
close(sock_fd);
exit(1);
printf("receive data from server:%s\n", recvBuffer);
close(sock_fd);
return 0;
/***************** rds_server.c ********************/
int main(void)
struct sockaddr_in fromAddr;
int sock_fd;
unsigned int addrLen;
char recvBuffer[128];
struct msghdr msg;
struct iovec iov;
if(sock_fd < 0) {
exit(0);
serverAddr.sin_port = htons(4000);
perror("bind error\n");
close(sock_fd);
exit(1);
printf("server is waiting to receive data...\n");
msg.msg_name = &fromAddr;
* I add 16 to sizeof(fromAddr), ie 32,
* and pay attention to the definition of fromAddr,
* recvmsg() will overwrite sock_fd,
* since kernel will copy 32 bytes to userspace.
* If you just use sizeof(fromAddr), it works fine.
msg.msg_namelen = sizeof(fromAddr) + 16;
/* msg.msg_namelen = sizeof(fromAddr); */
msg.msg_iov = &iov;
msg.msg_iovlen = 1;
msg.msg_flags = 0;
while (1) {
printf("old socket fd=%d\n", sock_fd);
close(sock_fd);
exit(1);
printf("server received data from client:%s\n", recvBuffer);
printf("msg.msg_namelen=%d\n", msg.msg_namelen);
printf("new socket fd=%d\n", sock_fd);
strcat(recvBuffer, "--data from server");
perror("sendmsg()\n");
close(sock_fd);
exit(1);
close(sock_fd);
return 0;
Signed-off-by: Weiping Pan <wpan@redhat.com>
If there is no OVS_SAMPLE_ATTR_ACTIONS set then "acts_list" is NULL and
it leads to a NULL dereference when we call nla_len(acts_list). This
is a static checker fix, not something I have seen in testing.
ICMP messages generated in output path if frame length is bigger than
mtu are actually lost because socket is owned by user (doing the xmit)
One example is the ipgre_tunnel_xmit() calling
icmp_send(skb, ICMP_DEST_UNREACH, ICMP_FRAG_NEEDED, htonl(mtu));
We had a similar case fixed in commit a34a101e1e6 (ipv6: disable GSO on
sockets hitting dst_allfrag).
Problem of such fix is that it relied on retransmit timers, so short tcp
sessions paid a too big latency increase price.
This patch uses the tcp_release_cb() infrastructure so that MTU
reduction messages (ICMP messages) are not lost, and no extra delay
is added in TCP transmits.
Reported-by: Maciej Żenczykowski <maze@google.com>
Diagnosed-by: Neal Cardwell <ncardwell@google.com>
Cc: Nandita Dukkipati <nanditad@google.com>
Cc: Tom Herbert <therbert@google.com>
Cc: Tore Anderson <tore@fud.no>
In tcp_tw_remember_stamp we incorrectly checked tw
instead of tm, it can lead to oops if the cached entry is
not found.
tcpm_stamp was not updated in tcpm_check_stamp when
tcpm_suck_dst was called, move the update into tcpm_suck_dst,
so that we do not call it infinitely on every next cache hit
after TCP_METRICS_TIMEOUT.
Signed-off-by: Julian Anastasov <ja@ssi.bg>
In net/compat.c::put_cmsg_compat() we may assign 'data' the address of
either the 'ctv' or 'cts' local variables inside the 'if
(!COMPAT_USE_64BIT_TIME)' branch.
Those variables go out of scope at the end of the 'if' statement, so
when we use 'data' further down in 'copy_to_user(CMSG_COMPAT_DATA(cm),
data, cmlen - sizeof(struct compat_cmsghdr))' there's no telling what
it may be refering to - not good.
Fix the problem by simply giving 'ctv' and 'cts' function scope.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
The ipv4 routing cache is non-deterministic, performance wise, and is
subject to reasonably easy to launch denial of service attacks.
The routing cache works great for well behaved traffic, and the world
was a much friendlier place when the tradeoffs that led to the routing
cache's design were considered.
What it boils down to is that the performance of the routing cache is
a product of the traffic patterns seen by a system rather than being a
product of the contents of the routing tables. The former of which is
controllable by external entitites.
Even for "well behaved" legitimate traffic, high volume sites can see
hit rates in the routing cache of only ~%10.
The general flow of this patch series is that first the routing cache
is removed. We build a completely new rtable entry every lookup
request.
Next we make some simplifications due to the fact that removing the
routing cache causes several members of struct rtable to become no
longer necessary.
Then we need to make some amends such that we can legally cache
pre-constructed routes in the FIB nexthops. Firstly, we need to
invalidate routes which are hit with nexthop exceptions. Secondly we
have to change the semantics of rt->rt_gateway such that zero means
that the destination is on-link and non-zero otherwise.
Now that the preparations are ready, we start caching precomputed
routes in the FIB nexthops. Output and input routes need different
kinds of care when determining if we can legally do such caching or
not. The details are in the commit log messages for those changes.
The patch series then winds down with some more struct rtable
simplifications and other tidy ups that remove unnecessary overhead.
On a SPARC-T3 output route lookups are ~876 cycles. Input route
lookups are ~1169 cycles with rpfilter disabled, and about ~1468
cycles with rpfilter enabled.
These measurements were taken with the kbench_mod test module in the
net_test_tools GIT tree:
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net_test_tools.git
That GIT tree also includes a udpflood tester tool and stresses
route lookups on packet output.
For example, on the same SPARC-T3 system we can run:
time ./udpflood -l 10000000 10.2.2.11
with routing cache:
real 1m21.955s user 0m6.530s sys 1m15.390s
without routing cache:
real 1m31.678s user 0m6.520s sys 1m25.140s
Performance undoubtedly can easily be improved further.
For example fib_table_lookup() performs a lot of excessive
computations with all the masking and shifting, some of it
conditionalized to deal with edge cases.
Also, Eric's no-ref optimization for input route lookups can be
re-instated for the FIB nexthop caching code path. I would be really
pleased if someone would work on that.
In fact anyone suitable motivated can just fire up perf on the loading
of the test net_test_tools benchmark kernel module. I spend much of
my time going:
bash# perf record insmod ./kbench_mod.ko dst=172.30.42.22 src=74.128.0.1 iif=2
bash# perf report
Thanks to helpful feedback from Joe Perches, Eric Dumazet, Ben
Hutchings, and others.
recursion in __scm_destroy() will be cut by delaying final fput()
Instead of updating the sk_cgrp_prioidx struct field on every send
this only updates the field when a task is moved via cgroup
infrastructure.
This allows sockets that may be used by a kernel worker thread
to be managed. For example in the iscsi case today a user can
put iscsid in a netprio cgroup and control traffic will be sent
with the correct sk_cgrp_prioidx value set but as soon as data
is sent the kernel worker thread isssues a send and sk_cgrp_prioidx
is updated with the kernel worker threads value which is the
default case.
It seems more correct to only update the field when the user
explicitly sets it via control group infrastructure. This allows
the users to manage sockets that may be used with other threads.
Signed-off-by: John Fastabend <john.r.fastabend@intel.com>
Export skb_copy_ubufs so that modules can orphan frags.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
zero copy packets are normally sent to the outside
network, but bridging, tun etc might loop them
back to host networking stack. If this happens
destructors will never be called, so orphan
the frags immediately on receive.
Reduce code duplication a bit using the new helper.
Commit 76ff5cc91935c51fcf1a6a99ffa28b97a6e7a884
(rtnl: allow to specify number of rx and tx queues
on device creation) added a reference to the net_device
structure's 'num_rx_queues' member in
net/core/rtnetlink.c:rtnl_fill_ifinfo()
However, the definition for 'num_rx_queues' is surrounded
by an '#ifdef CONFIG_RPS' while the new reference to it is
not. This causes a compile error when CONFIG_RPS is not
defined.
Fix the compile error by surrounding the new reference to
'num_rx_queues' by an '#ifdef CONFIG_RPS'.
CC: Jiri Pirko <jiri@resnulli.us>
Signed-off-by: Mark A. Greer <mgreer@animalcreek.com>
I've seen several attempts recently made to do quick failover of sctp transports
by reducing various retransmit timers and counters. While its possible to
implement a faster failover on multihomed sctp associations, its not
particularly robust, in that it can lead to unneeded retransmits, as well as
false connection failures due to intermittent latency on a network.
Instead, lets implement the new ietf quick failover draft found here:
http://tools.ietf.org/html/draft-nishida-tsvwg-sctp-failover-05
This will let the sctp stack identify transports that have had a small number of
errors, and avoid using them quickly until their reliability can be
re-established. I've tested this out on two virt guests connected via multiple
isolated virt networks and believe its in compliance with the above draft and
works well.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
CC: Vlad Yasevich <vyasevich@gmail.com>
CC: Sridhar Samudrala <sri@us.ibm.com>
CC: "David S. Miller" <davem@davemloft.net>
CC: linux-sctp@vger.kernel.org
CC: joe@perches.com
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
Fix race condition in several network drivers when reading stats on 32bit
UP architectures. These drivers update their stats in a BH context and
therefore should use u64_stats_fetch_begin_bh/u64_stats_fetch_retry_bh
instead of u64_stats_fetch_begin/u64_stats_fetch_retry when reading the
stats.
Signed-off-by: Kevin Groeneveld <kgroeneveld@gmail.com>
Set unicast_sock uc_ttl to -1 so that we select the right ttl,
instead of sending packets with a 0 ttl.
Bug added in commit be9f4a44e7d4 (ipv4: tcp: remove per net tcp_sock)
Signed-off-by: Hiroaki SHIMODA <shimoda.hiroaki@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jesse/openvswitch
Jesse Gross says:
A few bug fixes and small enhancements for net-next/3.6.
Ansis Atteka (1):
openvswitch: Do not send notification if ovs_vport_set_options() failed
Ben Pfaff (1):
openvswitch: Check gso_type for correct sk_buff in queue_gso_packets().
Jesse Gross (2):
openvswitch: Enable retrieval of TCP flags from IPv6 traffic.
openvswitch: Reset upper layer protocol info on internal devices.
Leo Alterman (1):
openvswitch: Fix typo in documentation.
Pravin B Shelar (1):
openvswitch: Check currect return value from skb_gso_segment()
Raju Subramanian (1):
openvswitch: Replace Nicira Networks.
At the point where it was used, skb_shinfo(skb)->gso_type referred to a
post-GSO sk_buff. Thus, it would always be 0. We want to know the pre-GSO
gso_type, so we need to obtain it before segmenting.
Before this change, the kernel would pass inconsistent data to userspace:
packets for UDP fragments with nonzero offset would be passed along with
flow keys that indicate a zero offset (that is, the flow key for "later"
fragments claimed to be "first" fragments). This inconsistency tended
to confuse Open vSwitch userspace, causing it to log messages about
"failed to flow_del" the flows with "later" fragments.
Signed-off-by: Ben Pfaff <blp@nicira.com>
Fix return check typo.
Signed-off-by: Pravin B Shelar <pshelar@nicira.com>
It's not really needed.
We only grabbed a reference to the fib_info for the sake of fib_info
local metrics.
However, fib_info objects are freed using RCU, as are therefore their
private metrics (if any).
We would have triggered a route cache flush if we eliminated a
reference to a fib_info object in the routing tables.
Therefore, any existing cached routes will first check and see that
they have been invalidated before an errant reference to these
metric values would occur.
That is this value's only use, as a boolean to indicate whether
a route is an input route or not.
So implement it that way, using a u16 gap present in the struct
already.
Never actually used.
It was being set on output routes to the original OIF specified in the
flow key used for the lookup.
Adjust the only user, ipmr_rt_fib_lookup(), for greater correctness of
the flowi4_oif and flowi4_iif values, thanks to feedback from Julian
Anastasov.
