path: root/net
2007-05-10Merge branch 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: [S390] update default configuration. [S390] Kconfig: no wireless on s390. [S390] Kconfig: use common Kconfig files for s390. [S390] Kconfig: common config options for s390. [S390] Kconfig: unwanted menus for s390. [S390] Kconfig: menus with depends on HAS_IOMEM. [S390] Kconfig: refine depends statements. [S390] Avoid compile warning. [S390] qdio: re-add lost perf_stats.tl_runs change in qdio_handle_pci [S390] Avoid sparse warnings. [S390] dasd: Fix modular build. [S390] monreader inlining cleanup. [S390] cio: Make some structures and a function static. [S390] cio: Get rid of _ccw_device_get_device_number(). [S390] fix subsystem removal fallout
2007-05-10AF_RXRPC: reduce debugging noiseDavid Howells
Reduce debugging noise generated by AF_RXRPC. Signed-off-by: David Howells <dhowells@redhat.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10[S390] Kconfig: no wireless on s390.Martin Schwidefsky
Hide the config menues for wireless on s390. Cc: John W. Linville <linville@tuxdriver.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-05-10[S390] Kconfig: unwanted menus for s390.Martin Schwidefsky
Disable some more menus in the configuration files that are of no interest to a s390 machine. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-05-09Merge branch 'upstream' of ↵Jeff Garzik
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 into upstream
2007-05-09sunrpc: fix crash in rpc_malloc()Peter Zijlstra
While the comment says: * To prevent rpciod from hanging, this allocator never sleeps, * returning NULL if the request cannot be serviced immediately. The function does not actually check for NULL pointers being returned. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-09SUNRPC: Fix pointer arithmetic bug recently introduced in rpc_malloc/freeChuck Lever
Use a cleaner method to find the size of an rpc_buffer. This actually works on x86-64! Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (25 commits) sound: convert "sound" subdirectory to UTF-8 MAINTAINERS: Add cxacru website/mailing list include files: convert "include" subdirectory to UTF-8 general: convert "kernel" subdirectory to UTF-8 documentation: convert the Documentation directory to UTF-8 Convert the toplevel files CREDITS and MAINTAINERS to UTF-8. remove broken URLs from net drivers' output Magic number prefix consistency change to Documentation/magic-number.txt trivial: s/i_sem /i_mutex/ fix file specification in comments drivers/base/platform.c: fix small typo in doc misc doc and kconfig typos Remove obsolete fat_cvf help text Fix occurrences of "the the " Fix minor typoes in kernel/module.c Kconfig: Remove reference to external mqueue library Kconfig: A couple of grammatical fixes in arch/i386/Kconfig Correct comments in genrtc.c to refer to correct /proc file. Fix more "deprecated" spellos. Fix "deprecated" typoes. ... Fix trivial comment conflict in kernel/relay.c.
2007-05-09Add suspend-related notifications for CPU hotplugRafael J. Wysocki
Since nonboot CPUs are now disabled after tasks and devices have been frozen and the CPU hotplug infrastructure is used for this purpose, we need special CPU hotplug notifications that will help the CPU-hotplug-aware subsystems distinguish normal CPU hotplug events from CPU hotplug events related to a system-wide suspend or resume operation in progress. This patch introduces such notifications and causes them to be used during suspend and resume transitions. It also changes all of the CPU-hotplug-aware subsystems to take these notifications into consideration (for now they are handled in the same way as the corresponding "normal" ones). [oleg@tv-sign.ru: cleanups] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09knfsd: simplify a 'while' condition in svcsock.cNeilBrown
This while loop has an overly complex condition, which performs a couple of assignments. This hurts readability. We don't really need a loop at all. We can just return -EAGAIN and (providing we set SK_DATA), the function will be called again. So discard the loop, make the complex conditional become a few clear function calls, and hopefully improve readability. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09knfsd: rpcgss: RPC_GSS_PROC_ DESTROY request will get a bad rpcWei Yongjun
If I send a RPC_GSS_PROC_DESTROY message to NFSv4 server, it will reply with a bad rpc reply which lacks an authentication verifier. Maybe this patch is needed. Send/recv packets as following: send: RemoteProcedureCall xid rpcvers = 2 prog = 100003 vers = 4 proc = 0 cred = AUTH_GSS version = 1 gss_proc = 3 (RPCSEC_GSS_DESTROY) service = 1 (RPC_GSS_SVC_NONE) verf = AUTH_GSS checksum reply: RemoteProcedureReply xid msg_type reply_stat accepted_reply Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09knfsd: fix resource leak resulting in module refcount leak for ↵Frank Filz
rpcsec_gss_krb5.ko I have been investigating a module reference count leak on the server for rpcsec_gss_krb5.ko. It turns out the problem is a reference count leak for the security context in net/sunrpc/auth_gss/svcauth_gss.c. The problem is that gss_write_init_verf() calls gss_svc_searchbyctx() which does a rsc_lookup() but never releases the reference to the context. There is another issue that rpc.svcgssd sets an "end of time" expiration for the context By adding a cache_put() call in gss_svc_searchbyctx(), and setting an expiration timeout in the downcall, cache_clean() does clean up the context and the module reference count now goes to zero after unmount. I also verified that if the context expires and then the client makes a new request, a new context is established. Here is the patch to fix the kernel, I will start a separate thread to discuss what expiration time should be set by rpc.svcgssd. Acked-by: "J. Bruce Fields" <bfields@citi.umich.edu> Signed-off-by: Frank Filz <ffilzlnx@us.ibm.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09knfsd: rpc: fix server-side wrapping of krb5i repliesNeilBrown
It's not necessarily correct to assume that the xdr_buf used to hold the server's reply must have page data whenever it has tail data. And there's no need for us to deal with that case separately anyway. Acked-by: "J. Bruce Fields" <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09sunrpc: fix error path in module_initAkinobu Mita
register_rpc_pipefs() needs to clean up rpc_inode_cache by kmem_cache_destroy() on register_filesystem() failure. init_sunrpc() needs to unregister rpc_pipe_fs by unregister_rpc_pipefs() when rpc_init_mempool() returns error. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Neil Brown <neilb@suse.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09RPC: add wrapper for svc_reserve to account for checksumJeff Layton
When the kernel calls svc_reserve to downsize the expected size of an RPC reply, it fails to account for the possibility of a checksum at the end of the packet. If a client mounts a NFSv2/3 with sec=krb5i/p, and does I/O then you'll generally see messages similar to this in the server's ring buffer: RPC request reserved 164 but used 208 While I was never able to verify it, I suspect that this problem is also the root cause of some oopses I've seen under these conditions: https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=227726 This is probably also a problem for other sec= types and for NFSv4. The large reserved size for NFSv4 compound packets seems to generally paper over the problem, however. This patch adds a wrapper for svc_reserve that accounts for the possibility of a checksum. It also fixes up the appropriate callers of svc_reserve to call the wrapper. For now, it just uses a hardcoded value that I determined via testing. That value may need to be revised upward as things change, or we may want to eventually add a new auth_op that attempts to calculate this somehow. Unfortunately, there doesn't seem to be a good way to reliably determine the expected checksum length prior to actually calculating it, particularly with schemes like spkm3. Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: Neil Brown <neilb@suse.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Acked-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09knfsd: rename sk_defer_lock to sk_lockNeilBrown
Now that sk_defer_lock protects two different things, make the name more generic. Also don't bother with disabling _bh as the lock is only ever taken from process context. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09unify flush_work/flush_work_keventd and rename it to cancel_work_syncOleg Nesterov
flush_work(wq, work) doesn't need the first parameter, we can use cwq->wq (this was possible from the very beginnig, I missed this). So we can unify flush_work_keventd and flush_work. Also, rename flush_work() to cancel_work_sync() and fix all callers. Perhaps this is not the best name, but "flush_work" is really bad. (akpm: this is why the earlier patches bypassed maintainers) Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Tejun Heo <htejun@gmail.com> Cc: Auke Kok <auke-jan.h.kok@intel.com>, Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09ipvs: flush defense_work before module unloadOleg Nesterov
net/ipv4/ipvs/ip_vs_core.c module_exit ip_vs_cleanup ip_vs_control_cleanup cancel_rearming_delayed_work // done This is unsafe. The module may be unloaded and the memory may be freed while defense_work's handler is still running/preempted. Do flush_work(&defense_work.work) after cancel_rearming_delayed_work(). Alternatively, we could add flush_work() to cancel_rearming_delayed_work(), but note that we can't change cancel_delayed_work() in the same manner because it may be called from atomic context. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Fix occurrences of "the the "Michael Opdenacker
Signed-off-by: Michael Opdenacker <michael@free-electrons.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-09Fix trivial typos in Kconfig* filesDavid Sterba
Fix several typos in help text in Kconfig* files. Signed-off-by: David Sterba <dave@jikos.cz> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-08Fix sunrpc warning noiseGeert Uytterhoeven
Commit c5a4dd8b7c15927a8fbff83171b57cad675a79b9 introduced the following compiler warnings: net/sunrpc/sched.c:766: warning: format '%u' expects type 'unsigned int', but argument 3 has type 'size_t' net/sunrpc/sched.c:785: warning: format '%u' expects type 'unsigned int', but argument 2 has type 'size_t' - Use %zu to format size_t - Kill 2 useless casts Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08VFS: delay the dentry name generation on sockets and pipesEric Dumazet
1) Introduces a new method in 'struct dentry_operations'. This method called d_dname() might be called from d_path() to build a pathname for special filesystems. It is called without locks. Future patches (if we succeed in having one common dentry for all pipes/sockets) may need to change prototype of this method, but we now use : char *d_dname(struct dentry *dentry, char *buffer, int buflen); 2) Adds a dynamic_dname() helper function that eases d_dname() implementations 3) Defines d_dname method for sockets : No more sprintf() at socket creation. This is delayed up to the moment someone does an access to /proc/pid/fd/... 4) Defines d_dname method for pipes : No more sprintf() at pipe creation. This is delayed up to the moment someone does an access to /proc/pid/fd/... A benchmark consisting of 1.000.000 calls to pipe()/close()/close() gives a *nice* speedup on my Pentium(M) 1.6 Ghz : 3.090 s instead of 3.450 s Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Acked-by: Christoph Hellwig <hch@infradead.org> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08[PATCH] ieee80211: include frequency in scan resultsLarry Finger
In ieee80211, the output of scan results lists channels, but not frequencies, which are needed by NetworkManager. This patch uses the new ieee80211_channel_to_freq routine to add the frequency to the output. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-05-08[PATCH] ieee80211: add ieee80211_channel_to_freqLarry Finger
The routines that interrogate the ieee80211_geo struct are missing a channel to frequency entry. This patch adds it. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-05-07Fix bluetooth HCI sysfs compileLinus Torvalds
More fallout from the removal of "struct subsystem" from the core device model. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: [NET]: rfkill: add support for input key to control wireless radio [NET] net/core: Fix error handling [TG3]: Update version and reldate. [TG3]: Eliminate spurious interrupts. [TG3]: Add ASPM workaround. [Bluetooth] Correct SCO buffer for another Broadcom based dongle [Bluetooth] Add support for Targus ACB10US USB dongle [Bluetooth] Disconnect L2CAP connection after last RFCOMM DLC [Bluetooth] Check that device is in rfcomm_dev_list before deleting [Bluetooth] Use in-kernel sockets API [Bluetooth] Attach host adapters to the Bluetooth bus [Bluetooth] Fix L2CAP and HCI setsockopt() information leaks
2007-05-07[NET]: rfkill: add support for input key to control wireless radioIvo van Doorn
The RF kill patch that provides infrastructure for implementing switches controlling radio states on various network and other cards. [dtor@insightbb.com: address review comments] [akpm@linux-foundation.org: cleanups, build fixes] Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-07[NET] net/core: Fix error handlingJosef 'Jeff' Sipek
Upon failure to register "ptype" procfs entry, "softnet_stat" was not removed, and an incorrect attempt was made to remove the "ptype" entry. Signed-off-by: Josef 'Jeff' Sipek <jsipek@cs.sunysb.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/holtmann/bluetooth-2.6David S. Miller
2007-05-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: (38 commits) kconfig: fix mconf segmentation fault kbuild: enable use of code from a different dir kconfig: error out if recursive dependencies are found kbuild: scripts/basic/fixdep segfault on pathological string-o-death kconfig: correct minor typo in Kconfig warning message. kconfig: fix path to modules.txt in Kconfig help usr/Kconfig: fix typo kernel-doc: alphabetically-sorted entries in index.html of 'htmldocs' kbuild: be more explicit on missing .config file kbuild: clarify the creation of the LOCALVERSION_AUTO string. kbuild: propagate errors from find in scripts/gen_initramfs_list.sh kconfig: refer to qt3 if we cannot find qt libraries kbuild: handle compressed cpio initramfs-es kbuild: ignore section mismatch warning for references from .paravirtprobe to .init.text kbuild: remove stale comment in modpost.c kbuild/mkuboot.sh: allow spaces in CROSS_COMPILE kbuild: fix make mrproper for Documentation/DocBook/man kbuild: remove kconfig binaries during make mrproper kconfig/menuconfig: do not hardcode '.config' kbuild: override build timestamp & version ...
2007-05-05[MAC80211]: Add debugfs attributes.Jiri Benc
Export various mac80211 internal variables through debugfs. Signed-off-by: Jiri Benc <jbenc@suse.cz> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-05[MAC80211]: Add mac80211 wireless stack.Jiri Benc
Add mac80211, the IEEE 802.11 software MAC layer. Signed-off-by: Jiri Benc <jbenc@suse.cz> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-05-05[AF_IUCV]: Compile fix - adopt to skbuff changes.Heiko Carstens
From: Heiko Carstens <heiko.carstens@de.ibm.com> CC [M] net/iucv/af_iucv.o net/iucv/af_iucv.c: In function `iucv_fragment_skb': net/iucv/af_iucv.c:984: error: structure has no member named `h' net/iucv/af_iucv.c:985: error: structure has no member named `nh' net/iucv/af_iucv.c:988: error: incompatible type for argument 1 of `skb_queue_tail' Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-04Merge git://git.linux-nfs.org/pub/linux/nfs-2.6Linus Torvalds
* git://git.linux-nfs.org/pub/linux/nfs-2.6: (28 commits) NFS: Fix a compile glitch on 64-bit systems NFS: Clean up nfs_create_request comments spkm3: initialize hash spkm3: remove bad kfree, unnecessary export spkm3: fix spkm3's use of hmac NFS4: invalidate cached acl on setacl NFS: Fix directory caching problem - with test case and patch. NFS: Set meaningful value for fattr->time_start in readdirplus results. NFS: Added support to turn off the NFSv3 READDIRPLUS RPC. SUNRPC: RPC client should retry with different versions of rpcbind SUNRPC: remove old portmapper NFS: switch NFSROOT to use new rpcbind client SUNRPC: switch the RPC server to use the new rpcbind registration API SUNRPC: switch socket-based RPC transports to use rpcbind SUNRPC: introduce rpcbind: replacement for in-kernel portmapper SUNRPC: Eliminate side effects from rpc_malloc SUNRPC: RPC buffer size estimates are too large NLM: Shrink the maximum request size of NLM4 requests NFS: Use pgoff_t in structures and functions that pass page cache offsets NFS: Clean up nfs_sync_mapping_wait() ...
2007-05-05[Bluetooth] Disconnect L2CAP connection after last RFCOMM DLCMarcel Holtmann
The RFCOMM specification says that the device closing the last DLC on a particular session is responsible for closing the multiplexer by closing the corresponding L2CAP channel. Signed-off-by: Ville Tervo <ville.tervo@nokia.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-05-05[Bluetooth] Check that device is in rfcomm_dev_list before deletingMarcel Holtmann
If RFCOMM_RELEASE_ONHUP flag is on and rfcomm_release_dev is called before connection is closed, rfcomm_dev is deleted twice from the rfcomm_dev_list and refcount is messed up. This patch adds a check before deleting device that the device actually is listed. Signed-off-by: Ville Tervo <ville.tervo@nokia.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-05-05[Bluetooth] Use in-kernel sockets APIMarcel Holtmann
The kernel provides a new convenient way to access the sockets API for in-kernel users. It is a good idea to actually use it. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-05-05[Bluetooth] Attach host adapters to the Bluetooth busMarcel Holtmann
The Bluetooth host adapters are attached to the Bluetooth class and the low-level connections are children of these class devices. Having class devices as parent of bus devices breaks a lot of reasonable assumptions about sysfs. The host adapters should be attached to the Bluetooth bus to simplify the dependency resolving. For compatibility an additional symlink from the Bluetooth class will be used. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-05-05[Bluetooth] Fix L2CAP and HCI setsockopt() information leaksMarcel Holtmann
The L2CAP and HCI setsockopt() implementations have a small information leak that makes it possible to leak kernel stack memory to userspace. If the optlen parameter is 0, no data will be copied by copy_from_user(), but the uninitialized stack buffer will be read and stored later. A call to getsockopt() can now retrieve the leaked information. To fix this problem the stack buffer given to copy_from_user() must be initialized with the current settings. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-05-04[SCTP]: Set assoc_id correctly during INIT collision.Vlad Yasevich
During the INIT/COOKIE-ACK collision cases, it's possible to get into a situation where the association id is not yet set at the time of the user event generation. As a result, user events have an association id set to 0 which will confuse applications. This happens if we hit case B of duplicate cookie processing. In the particular example found and provided by Oscar Isaula <Oscar.Isaula@motorola.com>, flow looks like this: A B ---- INIT-------> (lost) <---------INIT------ ---- INIT-ACK---> <------ Cookie ECHO When the Cookie Echo is received, we end up trying to update the association that was created on A as a result of the (lost) INIT, but that association doesn't have the ID set yet. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-04[SCTP]: Re-order SCTP initializations to avoid race with sctp_rcv()Sridhar Samudrala
Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-04[SCTP]: Fix the SO_REUSEADDR handling to be similar to TCP.Vlad Yasevich
Update the SO_REUSEADDR handling to also check for listen state. This was muliple listening server sockets can't be created and they will not steal packets from each other. Reported by Paolo Galtieri <pgaltieri@mvista.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-04[SCTP]: Verify all destination ports in sctp_connectx.Vlad Yasevich
We need to make sure that all destination ports are the same, since the association really must not connect to multiple different ports at once. This was reported on the sctp-impl list. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-04[XFRM] SPD info TLV aggregationJamal Hadi Salim
Aggregate the SPD info TLVs. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-04[XFRM] SAD info TLV aggregationxJamal Hadi Salim
Aggregate the SAD info TLVs. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-04[AF_RXRPC]: Sort out MTU handling.David Howells
Sort out the MTU determination and handling in AF_RXRPC: (1) If it's present, parse the additional information supplied by the peer at the end of the ACK packet (struct ackinfo) to determine the MTU sizes that peer is willing to support. (2) Initialise the MTU size to that peer from the kernel's routing records. (3) Send ACKs rather than ACKALLs as the former carry the additional info, and the latter do not. (4) Declare the interface MTU size in outgoing ACKs as a maximum amount of data that can be stuffed into an RxRPC packet without it having to be fragmented to come in this computer's NIC. (5) If sendmsg() is given MSG_MORE then it should allocate an skb of the maximum size rather than one just big enough for the data it's got left to process on the theory that there is more data to come that it can append to that packet. This means, for example, that if AFS does a large StoreData op, all the packets barring the last will be filled to the maximum unfragmented size. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-04[AF_IUCV/IUCV] : Add missing section annotationsHeiko Carstens
Add missing section annotations and found and fixed some Coding Style issues. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Frank Pavlic <fpavlic@de.ibm.com>
2007-05-04[AF_IUCV]: Implementation of a skb backlog queueJennifer Hunt
With the inital implementation we missed to implement a skb backlog queue . The result is that socket receive processing tossed packets. Since AF_IUCV connections are working synchronously it leads to connection hangs. Problems with read, close and select also occured. Using a skb backlog queue is fixing all of these problems . Signed-off-by: Jennifer Hunt <jenhunt@us.ibm.com> Signed-off-by: Frank Pavlic <fpavlic@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
