In some places, particularly drivers and __init code, the init utsns is the
appropriate one to use. This patch replaces those with a the init_utsname
helper.
Changes: Removed several uses of init_utsname(). Hope I picked all the
right ones in net/ipv4/ipconfig.c. These are now changed to
utsname() (the per-process namespace utsname) in the previous
patch (2/7)
[akpm@osdl.org: CIFS fix]
Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
Cc: Kirill Korotaev <dev@openvz.org>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Herbert Poetzl <herbert@13thfloor.at>
Cc: Andrey Savochkin <saw@sw.ru>
Cc: Serge Hallyn <serue@us.ibm.com>
Replace references to system_utsname to the per-process uts namespace
where appropriate. This includes things like uname.
Changes: Per Eric Biederman's comments, use the per-process uts namespace
for ELF_PLATFORM, sunrpc, and parts of net/ipv4/ipconfig.c
[jdike@addtoit.com: UML fix]
[clg@fr.ibm.com: cleanup]
[akpm@osdl.org: build fix]
Signed-off-by: Cedric Le Goater <clg@fr.ibm.com>
Cc: Jeff Dike <jdike@addtoit.com>
Actually implement multiple pools. On NUMA machines, allocate a svc_pool per
NUMA node; on SMP a svc_pool per CPU; otherwise a single global pool. Enqueue
sockets on the svc_pool corresponding to the CPU on which the socket bh is run
(i.e. the NIC interrupt CPU). Threads have their cpu mask set to limit them
to the CPUs in the svc_pool that owns them.
This is the patch that allows an Altix to scale NFS traffic linearly
beyond 4 CPUs and 4 NICs.
Incorporates changes and feedback from Neil Brown, Trond Myklebust, and
Christoph Hellwig.
Signed-off-by: Greg Banks <gnb@melbourne.sgi.com>
Signed-off-by: Neil Brown <neilb@suse.de>
Currently knfsd keeps its own list of all nfsd threads in nfssvc.c; add a new
way of managing the list of all threads in a svc_serv. Add
svc_create_pooled() to allow creation of a svc_serv whose threads are managed
by the sunrpc code. Add svc_set_num_threads() to manage the number of threads
in a service, either per-pool or globally across the service.
Split out the list of idle threads and pending sockets from svc_serv into a
new svc_pool structure, and allocate a fixed number (in this patch, 1) of
pools per svc_serv. The new structure contains a lock which takes over
several of the duties of svc_serv->sv_lock, which is now relegated to
protecting only sv_tempsocks, sv_permsocks, and sv_tmpcnt in svc_serv.
The point is to move the hottest fields out of svc_serv and into svc_pool,
allowing a following patch to arrange for a svc_pool per NUMA node or per CPU.
This is a major step towards making the NFS server NUMA-friendly.
The SK_BUSY bit in svc_sock->sk_flags ensures that we do not attempt to
enqueue a socket twice. Currently, setting and clearing the bit is protected
by svc_serv->sv_lock. As I intend to reduce the data that the lock protects
so it's not held when svc_sock_enqueue() tests and sets SK_BUSY, that test and
set needs to be atomic.
Convert the svc_sock->sk_reserved variable from an int protected by
svc_serv->sv_lock, to an atomic. This reduces (by 1) the number of places we
need to take the (effectively global) svc_serv->sv_lock.
Protect the svc_sock->sk_deferred list with a new lock svc_sock->sk_defer_lock
instead of svc_serv->sv_lock. Using the more fine-grained lock reduces the
number of places we need to take the svc_serv lock.
Convert the svc_sock->sk_inuse counter from an int protected by
svc_serv->sv_lock, to an atomic. This reduces the number of places we need to
Following are 11 patches from Greg Banks which combine to make knfsd more
Numa-aware. They reduce hitting on 'global' data structures, and create some
data-structures that can be node-local.
knfsd threads are bound to a particular node, and the thread to handle a new
request is chosen from the threads that are attach to the node that received
the interrupt.
The distribution of threads across nodes can be controlled by a new file in
the 'nfsd' filesystem, though the default approach of an even spread is
probably fine for most sites.
Some (old) numbers that show the efficacy of these patches: N == number of
NICs == number of CPUs == nmber of clients. Number of NUMA nodes == N/2
N Throughput, MiB/s CPU usage, % (max=N*100)
Before After Before After
4 312 435 350 228
6 500 656 501 418
8 562 804 690 589
This patch:
Move the aging of RPC/TCP connection sockets from the main svc_recv() loop to
a timer which uses a mark-and-sweep algorithm every 6 minutes. This reduces
the amount of work that needs to be done in the main RPC loop and the length
of time we need to hold the (effectively global) svc_serv->sv_lock.
[akpm@osdl.org: cleanup]
It isn't needed as it is available in rqstp->rq_server, and dropping it allows
some local vars to be dropped.
Cc: "J. Bruce Fields" <bfields@fieldses.org>
Userspace should create and bind a socket (but not connectted) and write the
'fd' to portlist. This will cause the nfs server to listen on that socket.
To close a socket, the name of the socket - as read from 'portlist' can be
written to 'portlist' with a preceding '-'.
This file will list all ports that nfsd has open.
Default when TCP enabled will be
ipv4 udp 0.0.0.0 2049
ipv4 tcp 0.0.0.0 2049
Later, the list of ports will be settable.
'portlist' chosen rather than 'ports', to avoid unnecessary confusion with
non-mainline patches which created 'ports' with different semantics.
[akpm@osdl.org: cleanups, build fix]
nfsd has some cleanup that it wants to do when the last thread exits, and
there will shortly be some more. So collect this all into one place and
define a callback for an rpc service to call when the service is about to be
destroyed.
In an effort to make kprobe modules more portable, here is a patch that:
o Introduces the "symbol_name" field to struct kprobe.
The symbol->address resolution now happens in the kernel in an
architecture agnostic manner. 64-bit powerpc users no longer have
to specify the ".symbols"
o Introduces the "offset" field to struct kprobe to allow a user to
specify an offset into a symbol.
o The legacy mechanism of specifying the kprobe.addr is still supported.
However, if both the kprobe.addr and kprobe.symbol_name are specified,
probe registration fails with an -EINVAL.
o The symbol resolution code uses kallsyms_lookup_name(). So
CONFIG_KPROBES now depends on CONFIG_KALLSYMS
o Apparantly kprobe modules were the only legitimate out-of-tree user of
the kallsyms_lookup_name() EXPORT. Now that the symbol resolution
happens in-kernel, remove the EXPORT as suggested by Christoph Hellwig
o Modify tcp_probe.c that uses the kprobe interface so as to make it
work on multiple platforms (in its earlier form, the code wouldn't
work, say, on powerpc)
Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Signed-off-by: Prasanna S Panchamukhi <prasanna@in.ibm.com>
As part of an SMP cleanliness pass over UML, I consted a bunch of
structures in order to not have to document their locking. One of these
structures was a struct tty_operations. In order to const it in UML
without introducing compiler complaints, the declaration of
tty_set_operations needs to be changed, and then all of its callers need to
be fixed.
This patch declares all struct tty_operations in the tree as const. In all
cases, they are static and used only as input to tty_set_operations. As an
extra check, I ran an i386 allyesconfig build which produced no extra
warnings.
53 drivers are affected. I checked the history of a bunch of them, and in
most cases, there have been only a handful of maintenance changes in the
last six months. serial_core.c was the busiest one that I looked at.
Signed-off-by: Jeff Dike <jdike@addtoit.com>
Acked-by: Alan Cox <alan@redhat.com>
File handles can be requested to send sigio and sigurg to processes. By
tracking the destination processes using struct pid instead of pid_t we make
the interface safe from all potential pid wrap around problems.
This is mostly included for parity with dec_nlink(), where we will have some
more hooks. This one should stay pretty darn straightforward for now.
Signed-off-by: Dave Hansen <haveblue@us.ibm.com>
Acked-by: Christoph Hellwig <hch@lst.de>
This patch removes readv() and writev() methods and replaces them with
aio_read()/aio_write() methods.
Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com>
This patch vectorizes aio_read() and aio_write() methods to prepare for
collapsing all aio & vectored operations into one interface - which is
aio_read()/aio_write().
Cc: Michael Holzheu <HOLZHEU@de.ibm.com>
All on stack DECLARE_COMPLETIONs should be replaced by:
DECLARE_COMPLETION_ONSTACK
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil>
We only need the timestamp on COOKIE-ECHO chunks, so instead of always
timestamping every SCTP packet, let common code timestamp if the socket
option is set. For COOKIE-ECHO, simply get the time of day if we don't
have a timestamp. This introduces a small possibility that the cookie
may be considered expired, but it will be renegotiated.
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
Signed-off-by: Sridhar Samudrala <sri@us.ibm.com>
Currently if the sender is sending small messages, it can cause a receiver
to run out of receive buffer space even when the advertised receive window
is still open and results in packet drops and retransmissions. Including
a overhead while updating the sender's view of peer receive window will
reduce the chances of receive buffer space overshooting the receive window.
This allows more aggressive bundling of chunks when sending small
messages.
Fix some issues Steve Grubb had with the way NetLabel was using the audit
subsystem. This should make NetLabel more consistent with other kernel
generated audit messages specifying configuration changes.
Signed-off-by: Paul Moore <paul.moore@hp.com>
Acked-by: Steve Grubb <sgrubb@redhat.com>
GWOL might provide passwords
GSET, GLINK, and GSTATS might poke the hardware
Based upon feedback from Jeff Garzik.
The bt_sysfs_cleanup() is marked with __exit attribute, but it will
be called from an __init function in the error case. So the __exit
attribute must be removed.
Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
In the case of device pairing the only safe method is to establish
a low-level ACL link. In this case, the remote side should not use
the disconnect timer to give the other side the chance to enter the
PIN code. If the disconnect timer is used, the connection will be
dropped to soon, because it is impossible to identify an actual user
of this link.
There is no reason to not allow non-admin users to query network
statistics and settings.
[ Removed PHYS_ID and GREGS based upon feedback from Auke Kok
and Michael Chan -DaveM]
Acked-by: James Morris <jmorris@namei.org>
This patch adds audit support to NetLabel, including six new audit message
types shown below.
#define AUDIT_MAC_UNLBL_ACCEPT 1406
#define AUDIT_MAC_UNLBL_DENY 1407
#define AUDIT_MAC_CIPSOV4_ADD 1408
#define AUDIT_MAC_CIPSOV4_DEL 1409
#define AUDIT_MAC_MAP_ADD 1410
#define AUDIT_MAC_MAP_DEL 1411
This changes the microsecond RTT sampling so that samples are taken in
the same way that RTT samples are taken for the RTO calculator: on the
last segment acknowledged, and only when the segment hasn't been
retransmitted.
Signed-off-by: John Heffner <jheffner@psc.edu>
Acked-by: Stephen Hemminger <shemminger@osdl.org>
This patch fix the chance for tcp_lp_remote_hz_estimator return 0, if
0 < rhz < 64. It also make sure the flag LP_VALID_RHZ is set
correctly.
Signed-off-by: Wong Hoi Sing Edison <hswong3i@gmail.com>
coverity spotted this one as possible dereference in the dprintk(),
but since there is only one caller of svc_create_socket(), which always
passes a valid sin, we dont need this check.
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
(p[3]<<24) | (p[2]<<16) | (p[1]<<8) | p[0] is not a valid
way to spell get_unaligned((__be32 *)p
