path: root/net
2009-04-01Merge branch 'devel' into for-linusTrond Myklebust
2009-04-01SUNRPC: Ensure IPV6_V6ONLY is set on the socket before binding to a portTrond Myklebust
Also ensure that we use the protocol family instead of the address family when calling sock_create_kern(). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-04-01epoll keyed wakeups: make sockets use keyed wakeupsDavide Libenzi
Add support for event-aware wakeups to the sockets code. Events are delivered to the wakeup target, so that epoll can avoid spurious wakeups for non-interesting events. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: William Lee Irwin III <wli@movementarian.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01proc tty: remove struct tty_operations::read_procAlexey Dobriyan
struct tty_operations::proc_fops took it's place and there is one less create_proc_read_entry() user now! Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01proc tty: switch ircomm to ->proc_fopsAlexey Dobriyan
2009-03-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: wireless: remove duplicated .ndo_set_mac_address netfilter: xtables: fix IPv6 dependency in the cluster match tg3: Add GRO support. niu: Add GRO support. ucc_geth: Fix use-after-of_node_put() in ucc_geth_probe(). gianfar: Fix use-after-of_node_put() in gfar_of_init(). kernel: remove HIPQUAD() netpoll: store local and remote ip in net-endian netfilter: fix endian bug in conntrack printks dmascc: fix incomplete conversion to network_device_ops gso: Fix support for linear packets skbuff.h: fix missing kernel-doc ni5010: convert to net_device_ops
2009-03-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-cpumaskLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-cpumask: oprofile: Thou shalt not call __exit functions from __init functions cpumask: remove the now-obsoleted pcibus_to_cpumask(): generic cpumask: remove cpumask_t from core cpumask: convert rcutorture.c cpumask: use new cpumask_ functions in core code. cpumask: remove references to struct irqaction's mask field. cpumask: use mm_cpumask() wrapper: kernel/fork.c cpumask: use set_cpu_active in init/main.c cpumask: remove node_to_first_cpu cpumask: fix seq_bitmap_*() functions. cpumask: remove dangerous CPU_MASK_ALL_PTR, &CPU_MASK_ALL
2009-03-31proc 2/2: remove struct proc_dir_entry::ownerAlexey Dobriyan
Setting ->owner as done currently (pde->owner = THIS_MODULE) is racy as correctly noted at bug #12454. Someone can lookup entry with NULL ->owner, thus not pinning enything, and release it later resulting in module refcount underflow. We can keep ->owner and supply it at registration time like ->proc_fops and ->data. But this leaves ->owner as easy-manipulative field (just one C assignment) and somebody will forget to unpin previous/pin current module when switching ->owner. ->proc_fops is declared as "const" which should give some thoughts. ->read_proc/->write_proc were just fixed to not require ->owner for protection. rmmod'ed directories will be empty and return "." and ".." -- no harm. And directories with tricky enough readdir and lookup shouldn't be modular. We definitely don't want such modular code. Removing ->owner will also make PDE smaller. So, let's nuke it. Kudos to Jeff Layton for reminding about this, let's say, oversight. http://bugzilla.kernel.org/show_bug.cgi?id=12454 Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-03-30cpumask: use new cpumask_ functions in core code.Rusty Russell
Impact: cleanup Time to clean up remaining laggards using the old cpu_ functions. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Trond.Myklebust@netapp.com
2009-03-29netfilter: xtables: fix IPv6 dependency in the cluster matchPablo Neira Ayuso
This patch fixes a dependency with IPv6: ERROR: "__ipv6_addr_type" [net/netfilter/xt_cluster.ko] undefined! This patch adds a function that checks if the higher bits of the address is 0xFF to identify a multicast address, instead of adding a dependency due to __ipv6_addr_type(). I came up with this idea after Patrick McHardy pointed possible problems with runtime module dependencies. Reported-by: Steven Noonan <steven@uplinklabs.net> Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Reported-by: Cyrill Gorcunov <gorcunov@openvz.org> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-29Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2009-03-28netpoll: store local and remote ip in net-endianHarvey Harrison
Allows for the removal of byteswapping in some places and the removal of HIPQUAD (replaced by %pI4). Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-28netfilter: fix endian bug in conntrack printksHarvey Harrison
dcc_ip is treated as a host-endian value in the first printk, but the second printk uses %pI4 which expects a be32. This will cause a mismatch between the debug statement and the warning statement. Treat as a be32 throughout and avoid some byteswapping during some comparisions, and allow another user of HIPQUAD to bite the dust. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-28gso: Fix support for linear packetsHerbert Xu
When GRO/frag_list support was added to GSO, I made an error which broke the support for segmenting linear GSO packets (GSO packets are normally non-linear in the payload). These days most of these packets are constructed by the tun driver, which prefers to allocate linear memory if possible. This is fixed in the latest kernel, but for 2.6.29 and earlier it is still the norm. Therefore this bug causes failures with GSO when used with tun in 2.6.29. Reported-by: James Huang <jamesclhuang@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: smack: Add a new '-CIPSO' option to the network address label configuration netlabel: Cleanup the Smack/NetLabel code to fix incoming TCP connections lsm: Remove the socket_post_accept() hook selinux: Remove the "compat_net" compatibility code netlabel: Label incoming TCP connections correctly in SELinux lsm: Relocate the IPv4 security_inet_conn_request() hooks TOMOYO: Fix a typo. smack: convert smack to standard linux lists
2009-03-28Merge branch 'percpu-cpumask-x86-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'percpu-cpumask-x86-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (682 commits) percpu: fix spurious alignment WARN in legacy SMP percpu allocator percpu: generalize embedding first chunk setup helper percpu: more flexibility for @dyn_size of pcpu_setup_first_chunk() percpu: make x86 addr <-> pcpu ptr conversion macros generic linker script: define __per_cpu_load on all SMP capable archs x86: UV: remove uv_flush_tlb_others() WARN_ON percpu: finer grained locking to break deadlock and allow atomic free percpu: move fully free chunk reclamation into a work percpu: move chunk area map extension out of area allocation percpu: replace pcpu_realloc() with pcpu_mem_alloc() and pcpu_mem_free() x86, percpu: setup reserved percpu area for x86_64 percpu, module: implement reserved allocation and use it for module percpu variables percpu: add an indirection ptr for chunk page map access x86: make embedding percpu allocator return excessive free space percpu: use negative for auto for pcpu_setup_first_chunk() arguments percpu: improve first chunk initial area map handling percpu: cosmetic renames in pcpu_setup_first_chunk() percpu: clean up percpu constants x86: un-__init fill_pud/pmd/pte x86: remove vestigial fix_ioremap prototypes ... Manually merge conflicts in arch/ia64/kernel/irq_ia64.c
2009-03-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (119 commits) [SCSI] scsi_dh_rdac: Retry for NOT_READY check condition [SCSI] mpt2sas: make global symbols unique [SCSI] sd: Make revalidate less chatty [SCSI] sd: Try READ CAPACITY 16 first for SBC-2 devices [SCSI] sd: Refactor sd_read_capacity() [SCSI] mpt2sas v00.100.11.15 [SCSI] mpt2sas: add MPT2SAS_MINOR(221) to miscdevice.h [SCSI] ch: Add scsi type modalias [SCSI] 3w-9xxx: add power management support [SCSI] bsg: add linux/types.h include to bsg.h [SCSI] cxgb3i: fix function descriptions [SCSI] libiscsi: fix possbile null ptr session command cleanup [SCSI] iscsi class: remove host no argument from session creation callout [SCSI] libiscsi: pass session failure a session struct [SCSI] iscsi lib: remove qdepth param from iscsi host allocation [SCSI] iscsi lib: have lib create work queue for transmitting IO [SCSI] iscsi class: fix lock dep warning on logout [SCSI] libiscsi: don't cap queue depth in iscsi modules [SCSI] iscsi_tcp: replace scsi_debug/tcp_debug logging with iscsi conn logging [SCSI] libiscsi_tcp: replace tcp_debug/scsi_debug logging with session/conn logging ...
2009-03-28SUNRPC: Remove CONFIG_SUNRPC_REGISTER_V4Chuck Lever
We just augmented the kernel's RPC service registration code so that it automatically adjusts to what is supported in user space. Thus we no longer need the kernel configuration option to enable registering RPC services with v4 -- it's all done automatically. This patch is part of a series that addresses http://bugzilla.kernel.org/show_bug.cgi?id=12256 Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-28SUNRPC: rpcb_register() should handle errors silentlyChuck Lever
Move error reporting for RPC registration to rpcb_register's caller. This way the caller can choose to recover silently from certain errors, but report errors it does not recognize. Error reporting for kernel RPC service registration is now handled in one place. This patch is part of a series that addresses http://bugzilla.kernel.org/show_bug.cgi?id=12256 Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-28SUNRPC: Simplify kernel RPC service registrationChuck Lever
The kernel registers RPC services with the local portmapper with an rpcbind SET upcall to the local portmapper. Traditionally, this used rpcbind v2 (PMAP), but registering RPC services that support IPv6 requires rpcbind v3 or v4. Since we now want separate PF_INET and PF_INET6 listeners for each kernel RPC service, svc_register() will do only one of those registrations at a time. For PF_INET, it tries an rpcb v4 SET upcall first; if that fails, it does a legacy portmap SET. This makes it entirely backwards compatible with legacy user space, but allows a proper v4 SET to be used if rpcbind is available. For PF_INET6, it does an rpcb v4 SET upcall. If that fails, it fails the registration, and thus the transport creation. This let's the kernel detect if user space is able to support IPv6 RPC services, and thus whether it should maintain a PF_INET6 listener for each service at all. This provides complete backwards compatibilty with legacy user space that only supports rpcbind v2. The only down-side is that registering a new kernel RPC service may take an extra exchange with the local portmapper on legacy systems, but this is an infrequent operation and is done over UDP (no lingering sockets in TIMEWAIT), so it shouldn't be consequential. This patch is part of a series that addresses http://bugzilla.kernel.org/show_bug.cgi?id=12256 Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-28SUNRPC: Simplify svc_unregister()Chuck Lever
Our initial implementation of svc_unregister() assumed that PMAP_UNSET cleared all rpcbind registrations for a [program, version] tuple. However, we now have evidence that PMAP_UNSET clears only "inet" entries, and not "inet6" entries, in the rpcbind database. For backwards compatibility with the legacy portmapper, the svc_unregister() function also must work if user space doesn't support rpcbind version 4 at all. Thus we'll send an rpcbind v4 UNSET, and if that fails, we'll send a PMAP_UNSET. This simplifies the code in svc_unregister() and provides better backwards compatibility with legacy user space that does not support rpcbind version 4. We can get rid of the conditional compilation in here as well. This patch is part of a series that addresses http://bugzilla.kernel.org/show_bug.cgi?id=12256 Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-28SUNRPC: Allow callers to pass rpcb_v4_register a NULL addressChuck Lever
The user space TI-RPC library uses an empty string for the universal address when unregistering all target addresses for [program, version]. The kernel's rpcb client should behave the same way. Here, we are switching between several registration methods based on the protocol family of the incoming address. Rename the other rpcbind v4 registration functions to make it clear that they, as well, are switched on protocol family. In /etc/netconfig, this is either "inet" or "inet6". NB: The loopback protocol families are not supported in the kernel. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-28SUNRPC: rpcbind actually interprets r_owner stringChuck Lever
RFC 1833 has little to say about the contents of r_owner; it only specifies that it is a string, and states that it is used to control who can UNSET an entry. Our port of rpcbind (from Sun) assumes this string contains a numeric UID value, not alphabetical or symbolic characters, but checks this value only for AF_LOCAL RPCB_SET or RPCB_UNSET requests. In all other cases, rpcbind ignores the contents of the r_owner string. The reference user space implementation of rpcb_set(3) uses a numeric UID for all SET/UNSET requests (even via the network) and an empty string for all other requests. We emulate that behavior here to maintain bug-for-bug compatibility. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-28SUNRPC: Clean up address type casts in rpcb_v4_register()Chuck Lever
Clean up: Simplify rpcb_v4_register() and its helpers by moving the details of sockaddr type casting to rpcb_v4_register()'s helper functions. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-28SUNRPC: Don't return EPROTONOSUPPORT in svc_register()'s helpersChuck Lever
The RPC client returns -EPROTONOSUPPORT if there is a protocol version mismatch (ie the remote RPC server doesn't support the RPC protocol version sent by the client). Helpers for the svc_register() function return -EPROTONOSUPPORT if they don't recognize the passed-in IPPROTO_ value. These are two entirely different failure modes. Have the helpers return -ENOPROTOOPT instead of -EPROTONOSUPPORT. This will allow callers to determine more precisely what the underlying problem is, and decide to report or recover appropriately. This patch is part of a series that addresses http://bugzilla.kernel.org/show_bug.cgi?id=12256 Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-28SUNRPC: Use IPv4 loopback for registering AF_INET6 kernel RPC servicesChuck Lever
The kernel uses an IPv6 loopback address when registering its AF_INET6 RPC services so that it can tell whether the local portmapper is actually IPv6-enabled. Since the legacy portmapper doesn't listen on IPv6, however, this causes a long timeout on older systems if the kernel happens to try creating and registering an AF_INET6 RPC service. Originally I wanted to use a connected transport (either TCP or connected UDP) so that the upcall would fail immediately if the portmapper wasn't listening on IPv6, but we never agreed on what transport to use. In the end, it's of little consequence to the kernel whether the local portmapper is listening on IPv6. It's only important whether the portmapper supports rpcbind v4. And the kernel can't tell that at all if it is sending requests via IPv6 -- the portmapper will just ignore them. So, send both rpcbind v2 and v4 SET/UNSET requests via IPv4 loopback to maintain better backwards compatibility between new kernels and legacy user space, and prevent multi-second hangs in some cases when the kernel attempts to register RPC services. This patch is part of a series that addresses http://bugzilla.kernel.org/show_bug.cgi?id=12256 Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-28SUNRPC: Set IPV6ONLY flag on PF_INET6 RPC listener socketsChuck Lever
We are about to convert to using separate RPC listener sockets for PF_INET and PF_INET6. This echoes the way IPv6 is handled in user space by TI-RPC, and eliminates the need for ULPs to worry about mapped IPv4 AF_INET6 addresses when doing address comparisons. Start by setting the IPV6ONLY flag on PF_INET6 RPC listener sockets. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-28SUNRPC: Remove @family argument from svc_create() and svc_create_pooled()Chuck Lever
Since an RPC service listener's protocol family is specified now via svc_create_xprt(), it no longer needs to be passed to svc_create() or svc_create_pooled(). Remove that argument from the synopsis of those functions, and remove the sv_family field from the svc_serv struct. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-28SUNRPC: Change svc_create_xprt() to take a @family argumentChuck Lever
The sv_family field is going away. Pass a protocol family argument to svc_create_xprt() instead of extracting the family from the passed-in svc_serv struct. Again, as this is a listener socket and not an address, we make this new argument an "int" protocol family, instead of an "sa_family_t." Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-28SUNRPC: svc_setup_socket() gets protocol family from socketChuck Lever
Since the sv_family field is going away, modify svc_setup_socket() to extract the protocol family from the passed-in socket instead of from the passed-in svc_serv struct. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-28SUNRPC: Pass a family argument to svc_register()Chuck Lever
The sv_family field is going away. Instead of using sv_family, have the svc_register() function take a protocol family argument. Since this argument represents a protocol family, and not an address family, this argument takes an int, as this is what is passed to sock_create_kern(). Also make sure svc_register's helpers are checking for PF_FOO instead of AF_FOO. The value of [AP]F_FOO are equivalent; this is simply a symbolic change to reflect the semantics of the value stored in that variable. sock_create_kern() should return EPFNOSUPPORT if the passed-in protocol family isn't supported, but it uses EAFNOSUPPORT for this case. We will stick with that tradition here, as svc_register() is called by the RPC server in the same path as sock_create_kern(). Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-28SUNRPC: Clean up svc_find_xprt() calling sequenceChuck Lever
Clean up: add documentating comment and use appropriate data types for svc_find_xprt()'s arguments. This also eliminates a mixed sign comparison: @port was an int, while the return value of svc_xprt_local_port() is an unsigned short. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-28SUNRPC: Don't flag empty RPCB_GETADDR reply as bogusChuck Lever
In 2007, commit e65fe3976f594603ed7b1b4a99d3e9b867f573ea added additional sanity checking to rpcb_decode_getaddr() to make sure we were getting a reply that was long enough to be an actual universal address. If the uaddr string isn't long enough, the XDR decoder returns EIO. However, an empty string is a valid RPCB_GETADDR response if the requested service isn't registered. Moreover, "::.n.m" is also a valid RPCB_GETADDR response for IPv6 addresses that is shorter than rpcb_decode_getaddr()'s lower limit of 11. So this sanity check introduced a regression for rpcbind requests against IPv6 remotes. So revert the lower bound check added by commit e65fe3976f594603ed7b1b4a99d3e9b867f573ea, and add an explicit check for an empty uaddr string, similar to libtirpc's rpcb_getaddr(3). Pointed-out-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-28netlabel: Cleanup the Smack/NetLabel code to fix incoming TCP connectionsPaul Moore
This patch cleans up a lot of the Smack network access control code. The largest changes are to fix the labeling of incoming TCP connections in a manner similar to the recent SELinux changes which use the security_inet_conn_request() hook to label the request_sock and let the label move to the child socket via the normal network stack mechanisms. In addition to the incoming TCP connection fixes this patch also removes the smk_labled field from the socket_smack struct as the minor optimization advantage was outweighed by the difficulty in maintaining it's proper state. Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-03-28lsm: Remove the socket_post_accept() hookPaul Moore
The socket_post_accept() hook is not currently used by any in-tree modules and its existence continues to cause problems by confusing people about what can be safely accomplished using this hook. If a legitimate need for this hook arises in the future it can always be reintroduced. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-03-28netlabel: Label incoming TCP connections correctly in SELinuxPaul Moore
The current NetLabel/SELinux behavior for incoming TCP connections works but only through a series of happy coincidences that rely on the limited nature of standard CIPSO (only able to convey MLS attributes) and the write equality imposed by the SELinux MLS constraints. The problem is that network sockets created as the result of an incoming TCP connection were not on-the-wire labeled based on the security attributes of the parent socket but rather based on the wire label of the remote peer. The issue had to do with how IP options were managed as part of the network stack and where the LSM hooks were in relation to the code which set the IP options on these newly created child sockets. While NetLabel/SELinux did correctly set the socket's on-the-wire label it was promptly cleared by the network stack and reset based on the IP options of the remote peer. This patch, in conjunction with a prior patch that adjusted the LSM hook locations, works to set the correct on-the-wire label format for new incoming connections through the security_inet_conn_request() hook. Besides the correct behavior there are many advantages to this change, the most significant is that all of the NetLabel socket labeling code in SELinux now lives in hooks which can return error codes to the core stack which allows us to finally get ride of the selinux_netlbl_inode_permission() logic which greatly simplfies the NetLabel/SELinux glue code. In the process of developing this patch I also ran into a small handful of AF_INET6 cleanliness issues that have been fixed which should make the code safer and easier to extend in the future. Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-03-28lsm: Relocate the IPv4 security_inet_conn_request() hooksPaul Moore
The current placement of the security_inet_conn_request() hooks do not allow individual LSMs to override the IP options of the connection's request_sock. This is a problem as both SELinux and Smack have the ability to use labeled networking protocols which make use of IP options to carry security attributes and the inability to set the IP options at the start of the TCP handshake is problematic. This patch moves the IPv4 security_inet_conn_request() hooks past the code where the request_sock's IP options are set/reset so that the LSM can safely manipulate the IP options as needed. This patch intentionally does not change the related IPv6 hooks as IPv6 based labeling protocols which use IPv6 options are not currently implemented, once they are we will have a better idea of the correct placement for the IPv6 hooks. Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: James Morris <jmorris@namei.org>
2009-03-28Merge branch 'linus' into percpu-cpumask-x86-for-linus-2Ingo Molnar
Conflicts: arch/sparc/kernel/time_64.c drivers/gpu/drm/drm_proc.c Manual merge to resolve build warning due to phys_addr_t type change on x86: drivers/gpu/drm/drm_info.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (166 commits) Revert "ax25: zero length frame filtering in AX25" Revert "netrom: zero length frame filtering in NetRom" cfg80211: default CONFIG_WIRELESS_OLD_REGULATORY to n mac80211/iwlwifi: move virtual A-MDPU queue bookkeeping to iwlwifi mac80211: fix aggregation to not require queue stop mac80211: add skb length sanity checking mac80211: unify and fix TX aggregation start mac80211: clean up __ieee80211_tx args mac80211: rework the pending packets code mac80211: fix A-MPDU queue assignment mac80211: rewrite fragmentation iwlwifi: show current driver status in user readable format b43: Add BCM4307 PCI-ID cfg80211: fix locking in nl80211_set_wiphy mac80211: fix RX path ath5k: properly drop packets from ops->tx ar9170: single module build ath9k: fix dma mapping leak of rx buffer upon rmmod rt2x00: New USB ID for rt73usb ath5k: warn and correct rate for unknown hw rate indexes ...
2009-03-27Merge branch 'master' of ↵David S. Miller
2009-03-27Revert "ax25: zero length frame filtering in AX25"David S. Miller
This reverts commit f99bcff7a290768e035f3d4726e103c6ebe858bf. Like netrom, Alan Cox says that zero lengths have real meaning and are useful in this protocol. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-27Revert "netrom: zero length frame filtering in NetRom"David S. Miller
This reverts commit a3ac80a130300573de351083cf4a5b46d233e8bf. Alan Cox says that zero length writes do have special meaning and are useful in this protocol. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-27cfg80211: default CONFIG_WIRELESS_OLD_REGULATORY to nLuis R. Rodriguez
And update description and feature-removal schedule according to the new plan. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27mac80211/iwlwifi: move virtual A-MDPU queue bookkeeping to iwlwifiJohannes Berg
This patch removes all the virtual A-MPDU-queue bookkeeping from mac80211. Curiously, iwlwifi already does its own bookkeeping, so it doesn't require much changes except where it needs to handle starting and stopping the queues in mac80211. To handle the queue stop/wake properly, we rewrite the software queue number for aggregation frames and internally to iwlwifi keep track of the queues that map into the same AC queue, and only talk to mac80211 about the AC queue. The implementation requires calling two new functions, iwl_stop_queue and iwl_wake_queue instead of the mac80211 counterparts. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Reinette Chattre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27mac80211: fix aggregation to not require queue stopJohannes Berg
Instead of stopping the entire AC queue when enabling aggregation (which was only done for hardware with aggregation queues) buffer the packets for each station, and release them to the pending skb queue once aggregation is turned on successfully. We get a little more code, but it becomes conceptually simpler and we can remove the entire virtual queue mechanism from mac80211 in a follow-up patch. This changes how mac80211 behaves towards drivers that support aggregation but have no hardware queues -- those drivers will now not be handed packets while the aggregation session is being established, but only after it has been fully established. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27mac80211: add skb length sanity checkingJohannes Berg
We just found a bug in zd1211rw where it would reject packets in the ->tx() method but leave them modified, which would cause retransmit attempts with completely bogus skbs, eventually leading to a panic due to not having enough headroom in those. This patch adds a sanity check to mac80211 to catch such driver mistakes; in this case we warn and drop the skb. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27mac80211: unify and fix TX aggregation startJohannes Berg
When TX aggregation becomes operational, we do a number of steps: 1) print a debug message 2) wake the virtual queue 3) notify the driver Unfortunately, 1) and 3) are only done if the driver is first to reply to the aggregation request, it is, however, possible that the remote station replies before the driver! Thus, unify the code for this and call the new function ieee80211_agg_tx_operational in both places where TX aggregation can become operational. Additionally, rename the driver notification from IEEE80211_AMPDU_TX_RESUME to IEEE80211_AMPDU_TX_OPERATIONAL. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27mac80211: clean up __ieee80211_tx argsJohannes Berg
__ieee80211_tx takes a struct ieee80211_tx_data argument, but only uses a few of its members, namely 'skb' and 'sta'. Make that explicit, so that less internal knowledge is required in ieee80211_tx_pending and the possibility of introducing errors here is removed. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Reviewed-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27mac80211: rework the pending packets codeJohannes Berg
The pending packets code is quite incomprehensible, uses memory barriers nobody really understands, etc. This patch reworks it entirely, using the queue spinlock, proper stop bits and the skb queues themselves to indicate whether packets are pending or not (rather than a separate variable like before). Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Reviewed-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27mac80211: fix A-MPDU queue assignmentJohannes Berg
Internally, mac80211 requires the skb's queue mapping to be set to the AC queue, not the virtual A-MPDU queue. This is not done correctly currently, this patch moves the code down to directly before the driver is invoked and adds a comment that it will be moved into the driver later. Since this requires __ieee80211_tx() to have the sta pointer, make sure to provide it in ieee80211_tx_pending(). Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Reviewed-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
