[ Upstream commit 6321aa197547da397753757bd84c6ce64b3e3d89 ]
clang warns about overflowing the data[] member in the struct pnpipehdr:
net/phonet/pep.c:295:8: warning: array index 4 is past the end of the array (which contains 1 element) [-Warray-bounds]
if (hdr->data[4] == PEP_IND_READY)
include/net/phonet/pep.h:66:3: note: array 'data' declared here
u8 data[1];
Using a flexible array member at the end of the struct avoids the
warning, but since we cannot have a flexible array member inside
of the union, each index now has to be moved back by one, which
makes it a little uglier.
Acked-by: Rémi Denis-Courmont <remi@remlab.net>
commit bb06c388fa20ae24cfe80c52488de718a7e3a53f upstream.
If msize is less than 4096, we should close and put trans, destroy
tagpool, not just free client. This patch fixes that.
Link: http://lkml.kernel.org/m/1552464097-142659-1-git-send-email-zhengbin13@huawei.com
Cc: stable@vger.kernel.org
Fixes: 574d356b7a02 ("9p/net: put a lower bound on msize")
Signed-off-by: zhengbin <zhengbin13@huawei.com>
Signed-off-by: Dominique Martinet <dominique.martinet@cea.fr>
commit da8ab57863ed7e912d10b179b6bdc652f635bd19 upstream.
Back in linux-4.4, I inadvertently put a call to reqsk_put() in
inet_child_forget(), forgetting it could be called from two different
points.
In the case it is called from inet_csk_reqsk_queue_add(), we want to
keep the reference on the request socket, since it is released later by
the caller (tcp_v{4|6}_rcv())
This bug never showed up because atomic_dec_and_test() was not signaling
the underflow, and SLAB_DESTROY_BY RCU semantic for request sockets
prevented the request to be put in quarantine.
Recent conversion of socket refcount from atomic_t to refcount_t finally
exposed the bug.
So move the reqsk_put() to inet_csk_listen_stop() to fix this.
Thanks to Shankara Pailoor for using syzkaller and providing
a nice set of .config and C repro.
WARNING: CPU: 2 PID: 4277 at lib/refcount.c:186
refcount_sub_and_test+0x167/0x1b0 lib/refcount.c:186
Kernel panic - not syncing: panic_on_warn set ...
CPU: 2 PID: 4277 Comm: syz-executor0 Not tainted 4.13.0-rc7 #3
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS
Ubuntu-1.8.2-1ubuntu1 04/01/2014
Call Trace:
<IRQ>
__dump_stack lib/dump_stack.c:16 [inline]
dump_stack+0xf7/0x1aa lib/dump_stack.c:52
panic+0x1ae/0x3a7 kernel/panic.c:180
__warn+0x1c4/0x1d9 kernel/panic.c:541
report_bug+0x211/0x2d0 lib/bug.c:183
fixup_bug+0x40/0x90 arch/x86/kernel/traps.c:190
do_trap_no_signal arch/x86/kernel/traps.c:224 [inline]
do_trap+0x260/0x390 arch/x86/kernel/traps.c:273
do_error_trap+0x118/0x340 arch/x86/kernel/traps.c:310
do_invalid_op+0x1b/0x20 arch/x86/kernel/traps.c:323
invalid_op+0x18/0x20 arch/x86/entry/entry_64.S:846
RIP: 0010:refcount_sub_and_test+0x167/0x1b0 lib/refcount.c:186
RSP: 0018:ffff88006e006b60 EFLAGS: 00010286
RAX: 0000000000000026 RBX: 0000000000000000 RCX: 0000000000000000
RDX: 0000000000000026 RSI: 1ffff1000dc00d2c RDI: ffffed000dc00d60
RBP: ffff88006e006bf0 R08: 0000000000000001 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: 1ffff1000dc00d6d
R13: 00000000ffffffff R14: 0000000000000001 R15: ffff88006ce9d340
refcount_dec_and_test+0x1a/0x20 lib/refcount.c:211
reqsk_put+0x71/0x2b0 include/net/request_sock.h:123
tcp_v4_rcv+0x259e/0x2e20 net/ipv4/tcp_ipv4.c:1729
ip_local_deliver_finish+0x2e2/0xba0 net/ipv4/ip_input.c:216
NF_HOOK include/linux/netfilter.h:248 [inline]
ip_local_deliver+0x1ce/0x6d0 net/ipv4/ip_input.c:257
dst_input include/net/dst.h:477 [inline]
ip_rcv_finish+0x8db/0x19c0 net/ipv4/ip_input.c:397
ip_rcv+0xc3f/0x17d0 net/ipv4/ip_input.c:488
__netif_receive_skb_core+0x1fb7/0x31f0 net/core/dev.c:4298
__netif_receive_skb+0x2c/0x1b0 net/core/dev.c:4336
process_backlog+0x1c5/0x6d0 net/core/dev.c:5102
napi_poll net/core/dev.c:5499 [inline]
net_rx_action+0x6d3/0x14a0 net/core/dev.c:5565
__do_softirq+0x2cb/0xb2d kernel/softirq.c:284
do_softirq_own_stack+0x1c/0x30 arch/x86/entry/entry_64.S:898
</IRQ>
do_softirq.part.16+0x63/0x80 kernel/softirq.c:328
do_softirq kernel/softirq.c:176 [inline]
__local_bh_enable_ip+0x84/0x90 kernel/softirq.c:181
local_bh_enable include/linux/bottom_half.h:31 [inline]
rcu_read_unlock_bh include/linux/rcupdate.h:705 [inline]
ip_finish_output2+0x8ad/0x1360 net/ipv4/ip_output.c:231
ip_finish_output+0x74e/0xb80 net/ipv4/ip_output.c:317
NF_HOOK_COND include/linux/netfilter.h:237 [inline]
ip_output+0x1cc/0x850 net/ipv4/ip_output.c:405
dst_output include/net/dst.h:471 [inline]
ip_local_out+0x95/0x160 net/ipv4/ip_output.c:124
ip_queue_xmit+0x8c6/0x1810 net/ipv4/ip_output.c:504
tcp_transmit_skb+0x1963/0x3320 net/ipv4/tcp_output.c:1123
tcp_send_ack.part.35+0x38c/0x620 net/ipv4/tcp_output.c:3575
tcp_send_ack+0x49/0x60 net/ipv4/tcp_output.c:3545
tcp_rcv_synsent_state_process net/ipv4/tcp_input.c:5795 [inline]
tcp_rcv_state_process+0x4876/0x4b60 net/ipv4/tcp_input.c:5930
tcp_v4_do_rcv+0x58a/0x820 net/ipv4/tcp_ipv4.c:1483
sk_backlog_rcv include/net/sock.h:907 [inline]
__release_sock+0x124/0x360 net/core/sock.c:2223
release_sock+0xa4/0x2a0 net/core/sock.c:2715
inet_wait_for_connect net/ipv4/af_inet.c:557 [inline]
__inet_stream_connect+0x671/0xf00 net/ipv4/af_inet.c:643
inet_stream_connect+0x58/0xa0 net/ipv4/af_inet.c:682
SYSC_connect+0x204/0x470 net/socket.c:1628
SyS_connect+0x24/0x30 net/socket.c:1609
entry_SYSCALL_64_fastpath+0x18/0xad
RIP: 0033:0x451e59
RSP: 002b:00007f474843fc08 EFLAGS: 00000216 ORIG_RAX: 000000000000002a
RAX: ffffffffffffffda RBX: 0000000000718000 RCX: 0000000000451e59
RDX: 0000000000000010 RSI: 0000000020002000 RDI: 0000000000000007
RBP: 0000000000000046 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000216 R12: 0000000000000000
R13: 00007ffc040a0f8f R14: 00007f47484409c0 R15: 0000000000000000
Fixes: ebb516af60e1 ("tcp/dccp: fix race at listener dismantle phase")
Reported-by: Shankara Pailoor <sp3485@columbia.edu>
Tested-by: Shankara Pailoor <sp3485@columbia.edu>
Cc: Guillaume Nault <gnault@redhat.com>
[ Upstream commit 1e027960edfaa6a43f9ca31081729b716598112b ]
syzbot found another add_timer() issue, this time in net/hsr [1]
Let's use mod_timer() which is safe.
[1]
kernel BUG at kernel/time/timer.c:1136!
invalid opcode: 0000 [#1] PREEMPT SMP KASAN
CPU: 0 PID: 15909 Comm: syz-executor.3 Not tainted 5.0.0+ #97
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
kobject: 'loop2' (00000000f5629718): kobject_uevent_env
RIP: 0010:add_timer kernel/time/timer.c:1136 [inline]
RIP: 0010:add_timer+0x654/0xbe0 kernel/time/timer.c:1134
Code: 0f 94 c5 31 ff 44 89 ee e8 09 61 0f 00 45 84 ed 0f 84 77 fd ff ff e8 bb 5f 0f 00 e8 07 10 a0 ff e9 68 fd ff ff e8 ac 5f 0f 00 <0f> 0b e8 a5 5f 0f 00 0f 0b e8 9e 5f 0f 00 4c 89 b5 58 ff ff ff e9
RSP: 0018:ffff8880656eeca0 EFLAGS: 00010246
kobject: 'loop2' (00000000f5629718): fill_kobj_path: path = '/devices/virtual/block/loop2'
RAX: 0000000000040000 RBX: 1ffff1100caddd9a RCX: ffffc9000c436000
RDX: 0000000000040000 RSI: ffffffff816056c4 RDI: ffff88806a2f6cc8
RBP: ffff8880656eed58 R08: ffff888067f4a300 R09: ffff888067f4abc8
R10: 0000000000000000 R11: 0000000000000000 R12: ffff88806a2f6cc0
R13: dffffc0000000000 R14: 0000000000000001 R15: ffff8880656eed30
FS: 00007fc2019bf700(0000) GS:ffff8880ae800000(0000) knlGS:0000000000000000
CR2: 0000000000738000 CR3: 0000000067e8e000 CR4: 00000000001406f0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
hsr_check_announce net/hsr/hsr_device.c:99 [inline]
hsr_check_carrier_and_operstate+0x567/0x6f0 net/hsr/hsr_device.c:120
hsr_netdev_notify+0x297/0xa00 net/hsr/hsr_main.c:51
notifier_call_chain+0xc7/0x240 kernel/notifier.c:93
__raw_notifier_call_chain kernel/notifier.c:394 [inline]
raw_notifier_call_chain+0x2e/0x40 kernel/notifier.c:401
call_netdevice_notifiers_info+0x3f/0x90 net/core/dev.c:1739
call_netdevice_notifiers_extack net/core/dev.c:1751 [inline]
call_netdevice_notifiers net/core/dev.c:1765 [inline]
dev_open net/core/dev.c:1436 [inline]
dev_open+0x143/0x160 net/core/dev.c:1424
team_port_add drivers/net/team/team.c:1203 [inline]
team_add_slave+0xa07/0x15d0 drivers/net/team/team.c:1933
do_set_master net/core/rtnetlink.c:2358 [inline]
do_set_master+0x1d4/0x230 net/core/rtnetlink.c:2332
do_setlink+0x966/0x3510 net/core/rtnetlink.c:2493
rtnl_setlink+0x271/0x3b0 net/core/rtnetlink.c:2747
rtnetlink_rcv_msg+0x465/0xb00 net/core/rtnetlink.c:5192
netlink_rcv_skb+0x17a/0x460 net/netlink/af_netlink.c:2485
rtnetlink_rcv+0x1d/0x30 net/core/rtnetlink.c:5210
netlink_unicast_kernel net/netlink/af_netlink.c:1310 [inline]
netlink_unicast+0x536/0x720 net/netlink/af_netlink.c:1336
netlink_sendmsg+0x8ae/0xd70 net/netlink/af_netlink.c:1925
sock_sendmsg_nosec net/socket.c:622 [inline]
sock_sendmsg+0xdd/0x130 net/socket.c:632
sock_write_iter+0x27c/0x3e0 net/socket.c:923
call_write_iter include/linux/fs.h:1869 [inline]
do_iter_readv_writev+0x5e0/0x8e0 fs/read_write.c:680
do_iter_write fs/read_write.c:956 [inline]
do_iter_write+0x184/0x610 fs/read_write.c:937
vfs_writev+0x1b3/0x2f0 fs/read_write.c:1001
do_writev+0xf6/0x290 fs/read_write.c:1036
__do_sys_writev fs/read_write.c:1109 [inline]
__se_sys_writev fs/read_write.c:1106 [inline]
__x64_sys_writev+0x75/0xb0 fs/read_write.c:1106
do_syscall_64+0x103/0x610 arch/x86/entry/common.c:290
entry_SYSCALL_64_after_hwframe+0x49/0xbe
RIP: 0033:0x457f29
Code: ad b8 fb ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 7b b8 fb ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007fc2019bec78 EFLAGS: 00000246 ORIG_RAX: 0000000000000014
RAX: ffffffffffffffda RBX: 0000000000000003 RCX: 0000000000457f29
RDX: 0000000000000001 RSI: 00000000200000c0 RDI: 0000000000000003
RBP: 000000000073bf00 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 00007fc2019bf6d4
R13: 00000000004c4a60 R14: 00000000004dd218 R15: 00000000ffffffff
Fixes: f421436a591d ("net/hsr: Add support for the High-availability Seamless Redundancy protocol (HSRv0)")
Reported-by: syzbot <syzkaller@googlegroups.com>
Cc: Arvid Brodin <arvid.brodin@alten.se>
[ Upstream commit ae3b564179bfd06f32d051b9e5d72ce4b2a07c37 ]
Several u->addr and u->path users are not holding any locks in
common with unix_bind(). unix_state_lock() is useless for those
purposes.
u->addr is assign-once and *(u->addr) is fully set up by the time
we set u->addr (all under unix_table_lock). u->path is also
set in the same critical area, also before setting u->addr, and
any unix_sock with ->path filled will have non-NULL ->addr.
So setting ->addr with smp_store_release() is all we need for those
"lockless" users - just have them fetch ->addr with smp_load_acquire()
and don't even bother looking at ->path if they see NULL ->addr.
Users of ->addr and ->path fall into several classes now:
1) ones that do smp_load_acquire(u->addr) and access *(u->addr)
and u->path only if smp_load_acquire() has returned non-NULL.
2) places holding unix_table_lock. These are guaranteed that
*(u->addr) is seen fully initialized. If unix_sock is in one of the
"bound" chains, so's ->path.
3) unix_sock_destructor() using ->addr is safe. All places
that set u->addr are guaranteed to have seen all stores *(u->addr)
while holding a reference to u and unix_sock_destructor() is called
when (atomic) refcount hits zero.
4) unix_release_sock() using ->path is safe. unix_bind()
is serialized wrt unix_release() (normally - by struct file
refcount), and for the instances that had ->path set by unix_bind()
unix_release_sock() comes from unix_release(), so they are fine.
Instances that had it set in unix_stream_connect() either end up
attached to a socket (in unix_accept()), in which case the call
chain to unix_release_sock() and serialization are the same as in
the previous case, or they never get accept'ed and unix_release_sock()
is called when the listener is shut down and its queue gets purged.
In that case the listener's queue lock provides the barriers needed -
unix_stream_connect() shoves our unix_sock into listener's queue
under that lock right after having set ->path and eventual
unix_release_sock() caller picks them from that queue under the
same lock right before calling unix_release_sock().
5) unix_find_other() use of ->path is pointless, but safe -
it happens with successful lookup by (abstract) name, so ->path.dentry
is guaranteed to be NULL there.
earlier-variant-reviewed-by: "Paul E. McKenney" <paulmck@linux.ibm.com>
[ Upstream commit 97f0082a0592212fc15d4680f5a4d80f79a1687c ]
Set rtm_table to RT_TABLE_COMPAT for ipv6 for tables > 255 to
keep legacy software happy. This is similar to what was done for
ipv4 in commit 709772e6e065 ("net: Fix routing tables with
id > 255 for legacy software").
Signed-off-by: Kalash Nainwal <kalash@arista.com>
[ Upstream commit 797a22bd5298c2674d927893f46cadf619dad11d ]
syzbot was able to trigger another soft lockup [1]
I first thought it was the O(N^2) issue I mentioned in my
prior fix (f657d22ee1f "net/x25: do not hold the cpu
too long in x25_new_lci()"), but I eventually found
that x25_bind() was not checking SOCK_ZAPPED state under
socket lock protection.
This means that multiple threads can end up calling
x25_insert_socket() for the same socket, and corrupt x25_list
[1]
watchdog: BUG: soft lockup - CPU#0 stuck for 123s! [syz-executor.2:10492]
Modules linked in:
irq event stamp: 27515
hardirqs last enabled at (27514): [<ffffffff81006673>] trace_hardirqs_on_thunk+0x1a/0x1c
hardirqs last disabled at (27515): [<ffffffff8100668f>] trace_hardirqs_off_thunk+0x1a/0x1c
softirqs last enabled at (32): [<ffffffff8632ee73>] x25_get_neigh+0xa3/0xd0 net/x25/x25_link.c:336
softirqs last disabled at (34): [<ffffffff86324bc3>] x25_find_socket+0x23/0x140 net/x25/af_x25.c:341
CPU: 0 PID: 10492 Comm: syz-executor.2 Not tainted 5.0.0-rc7+ #88
RIP: 0010:__sanitizer_cov_trace_pc+0x4/0x50 kernel/kcov.c:97
Code: f4 ff ff ff e8 11 9f ea ff 48 c7 05 12 fb e5 08 00 00 00 00 e9 c8 e9 ff ff 90 90 90 90 90 90 90 90 90 90 90 90 90 55 48 89 e5 <48> 8b 75 08 65 48 8b 04 25 40 ee 01 00 65 8b 15 38 0c 92 7e 81 e2
RSP: 0018:ffff88806e94fc48 EFLAGS: 00000286 ORIG_RAX: ffffffffffffff13
RAX: 1ffff1100d84dac5 RBX: 0000000000000001 RCX: ffffc90006197000
RDX: 0000000000040000 RSI: ffffffff86324bf3 RDI: ffff88806c26d628
RBP: ffff88806e94fc48 R08: ffff88806c1c6500 R09: fffffbfff1282561
R10: fffffbfff1282560 R11: ffffffff89412b03 R12: ffff88806c26d628
R13: ffff888090455200 R14: dffffc0000000000 R15: 0000000000000000
FS: 00007f3a107e4700(0000) GS:ffff8880ae800000(0000) knlGS:0000000000000000
CR2: 00007f3a107e3db8 CR3: 00000000a5544000 CR4: 00000000001406f0
Call Trace:
__x25_find_socket net/x25/af_x25.c:327 [inline]
x25_find_socket+0x7d/0x140 net/x25/af_x25.c:342
x25_new_lci net/x25/af_x25.c:355 [inline]
x25_connect+0x380/0xde0 net/x25/af_x25.c:784
__sys_connect+0x266/0x330 net/socket.c:1662
__do_sys_connect net/socket.c:1673 [inline]
__se_sys_connect net/socket.c:1670 [inline]
__x64_sys_connect+0x73/0xb0 net/socket.c:1670
RIP: 0033:0x457e29
RSP: 002b:00007f3a107e3c78 EFLAGS: 00000246 ORIG_RAX: 000000000000002a
RAX: ffffffffffffffda RBX: 0000000000000003 RCX: 0000000000457e29
RDX: 0000000000000012 RSI: 0000000020000200 RDI: 0000000000000005
RBP: 000000000073c040 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 00007f3a107e46d4
R13: 00000000004be362 R14: 00000000004ceb98 R15: 00000000ffffffff
Sending NMI from CPU 0 to CPUs 1:
NMI backtrace for cpu 1
CPU: 1 PID: 10493 Comm: syz-executor.3 Not tainted 5.0.0-rc7+ #88
RIP: 0010:__read_once_size include/linux/compiler.h:193 [inline]
RIP: 0010:queued_write_lock_slowpath+0x143/0x290 kernel/locking/qrwlock.c:86
Code: 4c 8d 2c 01 41 83 c7 03 41 0f b6 45 00 41 38 c7 7c 08 84 c0 0f 85 0c 01 00 00 8b 03 3d 00 01 00 00 74 1a f3 90 41 0f b6 55 00 <41> 38 d7 7c eb 84 d2 74 e7 48 89 df e8 cc aa 4e 00 eb dd be 04 00
RSP: 0018:ffff888085c47bd8 EFLAGS: 00000206
RAX: 0000000000000300 RBX: ffffffff89412b00 RCX: 1ffffffff1282560
RDX: 0000000000000000 RSI: 0000000000000004 RDI: ffffffff89412b00
RBP: ffff888085c47c70 R08: 1ffffffff1282560 R09: fffffbfff1282561
R10: fffffbfff1282560 R11: ffffffff89412b03 R12: 00000000000000ff
R13: fffffbfff1282560 R14: 1ffff11010b88f7d R15: 0000000000000003
FS: 00007fdd04086700(0000) GS:ffff8880ae900000(0000) knlGS:0000000000000000
CR2: 00007fdd04064db8 CR3: 0000000090be0000 CR4: 00000000001406e0
Call Trace:
queued_write_lock include/asm-generic/qrwlock.h:104 [inline]
do_raw_write_lock+0x1d6/0x290 kernel/locking/spinlock_debug.c:203
__raw_write_lock_bh include/linux/rwlock_api_smp.h:204 [inline]
_raw_write_lock_bh+0x3b/0x50 kernel/locking/spinlock.c:312
x25_insert_socket+0x21/0xe0 net/x25/af_x25.c:267
x25_bind+0x273/0x340 net/x25/af_x25.c:703
__sys_bind+0x23f/0x290 net/socket.c:1481
__do_sys_bind net/socket.c:1492 [inline]
__se_sys_bind net/socket.c:1490 [inline]
__x64_sys_bind+0x73/0xb0 net/socket.c:1490
RIP: 0033:0x457e29
Fixes: 90c27297a9bf ("X.25 remove bkl in bind")
Cc: andrew hendry <andrew.hendry@gmail.com>
[ Upstream commit 9d3e1368bb45893a75a5dfb7cd21fdebfa6b47af ]
Commit 7716682cc58e ("tcp/dccp: fix another race at listener
dismantle") let inet_csk_reqsk_queue_add() fail, and adjusted
{tcp,dccp}_check_req() accordingly. However, TFO and syncookies
weren't modified, thus leaking allocated resources on error.
Contrary to tcp_check_req(), in both syncookies and TFO cases,
we need to drop the request socket. Also, since the child socket is
created with inet_csk_clone_lock(), we have to unlock it and drop an
extra reference (->sk_refcount is initially set to 2 and
inet_csk_reqsk_queue_add() drops only one ref).
For TFO, we also need to revert the work done by tcp_try_fastopen()
(with reqsk_fastopen_remove()).
Fixes: 7716682cc58e ("tcp/dccp: fix another race at listener dismantle")
Signed-off-by: Guillaume Nault <gnault@redhat.com>
[ Upstream commit ee60ad219f5c7c4fb2f047f88037770063ef785f ]
The race occurs in __mkroute_output() when 2 threads lookup a dst:
CPU A CPU B
find_exception()
find_exception() [fnhe expires]
ip_del_fnhe() [fnhe is deleted]
rt_bind_exception()
In rt_bind_exception() it will bind a deleted fnhe with the new dst, and
this dst will get no chance to be freed. It causes a dev defcnt leak and
consecutive dmesg warnings:
unregister_netdevice: waiting for ethX to become free. Usage count = 1
Especially thanks Jon to identify the issue.
This patch fixes it by setting fnhe_daddr to 0 in ip_del_fnhe() to stop
binding the deleted fnhe with a new dst when checking fnhe's fnhe_daddr
and daddr in rt_bind_exception().
It works as both ip_del_fnhe() and rt_bind_exception() are protected by
fnhe_lock and the fhne is freed by kfree_rcu().
Fixes: deed49df7390 ("route: check and remove route cache when we get route")
Signed-off-by: Jon Maxwell <jmaxwell37@gmail.com>
Signed-off-by: Xin Long <lucien.xin@gmail.com>
Reviewed-by: David Ahern <dsahern@gmail.com>
[ Upstream commit ee74d0bd4325efb41e38affe5955f920ed973f23 ]
In case x25_connect() fails and frees the socket neighbour,
we also need to undo the change done to x25->state.
Before my last bug fix, we had use-after-free so this
patch fixes a latent bug.
syzbot report :
kasan: CONFIG_KASAN_INLINE enabled
kasan: GPF could be caused by NULL-ptr deref or user memory access
general protection fault: 0000 [#1] PREEMPT SMP KASAN
CPU: 1 PID: 16137 Comm: syz-executor.1 Not tainted 5.0.0+ #117
RIP: 0010:x25_write_internal+0x1e8/0xdf0 net/x25/x25_subr.c:173
Code: 00 40 88 b5 e0 fe ff ff 0f 85 01 0b 00 00 48 8b 8b 80 04 00 00 48 ba 00 00 00 00 00 fc ff df 48 8d 79 1c 48 89 fe 48 c1 ee 03 <0f> b6 34 16 48 89 fa 83 e2 07 83 c2 03 40 38 f2 7c 09 40 84 f6 0f
RSP: 0018:ffff888076717a08 EFLAGS: 00010207
RAX: ffff88805f2f2292 RBX: ffff8880a0ae6000 RCX: 0000000000000000
kobject: 'loop5' (0000000018d0d0ee): kobject_uevent_env
RDX: dffffc0000000000 RSI: 0000000000000003 RDI: 000000000000001c
RBP: ffff888076717b40 R08: ffff8880950e0580 R09: ffffed100be5e46d
R10: ffffed100be5e46c R11: ffff88805f2f2363 R12: ffff888065579840
kobject: 'loop5' (0000000018d0d0ee): fill_kobj_path: path = '/devices/virtual/block/loop5'
R13: 1ffff1100ece2f47 R14: 0000000000000013 R15: 0000000000000013
FS: 00007fb88cf43700(0000) GS:ffff8880ae900000(0000) knlGS:0000000000000000
CR2: 00007f9a42a41028 CR3: 0000000087a67000 CR4: 00000000001406e0
Call Trace:
x25_release+0xd0/0x340 net/x25/af_x25.c:658
__sock_release+0xd3/0x2b0 net/socket.c:579
sock_close+0x1b/0x30 net/socket.c:1162
__fput+0x2df/0x8d0 fs/file_table.c:278
____fput+0x16/0x20 fs/file_table.c:309
task_work_run+0x14a/0x1c0 kernel/task_work.c:113
get_signal+0x1961/0x1d50 kernel/signal.c:2388
do_signal+0x87/0x1940 arch/x86/kernel/signal.c:816
exit_to_usermode_loop+0x244/0x2c0 arch/x86/entry/common.c:162
prepare_exit_to_usermode arch/x86/entry/common.c:197 [inline]
syscall_return_slowpath arch/x86/entry/common.c:268 [inline]
do_syscall_64+0x52d/0x610 arch/x86/entry/common.c:293
RIP: 0033:0x457f29
RSP: 002b:00007fb88cf42c78 EFLAGS: 00000246 ORIG_RAX: 000000000000002a
RAX: fffffffffffffe00 RBX: 0000000000000003 RCX: 0000000000457f29
RDX: 0000000000000012 RSI: 0000000020000080 RDI: 0000000000000004
R10: 0000000000000000 R11: 0000000000000246 R12: 00007fb88cf436d4
R13: 00000000004be462 R14: 00000000004cec98 R15: 00000000ffffffff
Modules linked in:
Fixes: 95d6ebd53c79 ("net/x25: fix use-after-free in x25_device_event()")
[ Upstream commit 95d6ebd53c79522bf9502dbc7e89e0d63f94dae4 ]
In case of failure x25_connect() does a x25_neigh_put(x25->neighbour)
but forgets to clear x25->neighbour pointer, thus triggering use-after-free.
Since the socket is visible in x25_list, we need to hold x25_list_lock
to protect the operation.
syzbot report :
BUG: KASAN: use-after-free in x25_kill_by_device net/x25/af_x25.c:217 [inline]
BUG: KASAN: use-after-free in x25_device_event+0x296/0x2b0 net/x25/af_x25.c:252
Read of size 8 at addr ffff8880a030edd0 by task syz-executor003/7854
CPU: 0 PID: 7854 Comm: syz-executor003 Not tainted 5.0.0+ #97
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x172/0x1f0 lib/dump_stack.c:113
print_address_description.cold+0x7c/0x20d mm/kasan/report.c:187
kasan_report.cold+0x1b/0x40 mm/kasan/report.c:317
__asan_report_load8_noabort+0x14/0x20 mm/kasan/generic_report.c:135
__dev_notify_flags+0x1e9/0x2c0 net/core/dev.c:7607
dev_change_flags+0x10d/0x170 net/core/dev.c:7643
dev_ifsioc+0x2b0/0x940 net/core/dev_ioctl.c:237
dev_ioctl+0x1b8/0xc70 net/core/dev_ioctl.c:488
sock_do_ioctl+0x1bd/0x300 net/socket.c:995
sock_ioctl+0x32b/0x610 net/socket.c:1096
vfs_ioctl fs/ioctl.c:46 [inline]
file_ioctl fs/ioctl.c:509 [inline]
do_vfs_ioctl+0xd6e/0x1390 fs/ioctl.c:696
ksys_ioctl+0xab/0xd0 fs/ioctl.c:713
__do_sys_ioctl fs/ioctl.c:720 [inline]
__se_sys_ioctl fs/ioctl.c:718 [inline]
__x64_sys_ioctl+0x73/0xb0 fs/ioctl.c:718
RIP: 0033:0x4467c9
Code: e8 0c e8 ff ff 48 83 c4 18 c3 0f 1f 80 00 00 00 00 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 5b 07 fc ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007fdbea222d98 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
RAX: ffffffffffffffda RBX: 00000000006dbc58 RCX: 00000000004467c9
RDX: 0000000020000340 RSI: 0000000000008914 RDI: 0000000000000003
RBP: 00000000006dbc50 R08: 00007fdbea223700 R09: 0000000000000000
R10: 00007fdbea223700 R11: 0000000000000246 R12: 00000000006dbc5c
R13: 6000030030626669 R14: 0000000000000000 R15: 0000000030626669
Allocated by task 7843:
save_stack+0x45/0xd0 mm/kasan/common.c:73
set_track mm/kasan/common.c:85 [inline]
__kasan_kmalloc mm/kasan/common.c:495 [inline]
__kasan_kmalloc.constprop.0+0xcf/0xe0 mm/kasan/common.c:468
kasan_kmalloc+0x9/0x10 mm/kasan/common.c:509
kmem_cache_alloc_trace+0x151/0x760 mm/slab.c:3615
kmalloc include/linux/slab.h:545 [inline]
x25_link_device_up+0x46/0x3f0 net/x25/x25_link.c:249
x25_device_event+0x116/0x2b0 net/x25/af_x25.c:242
__dev_notify_flags+0x121/0x2c0 net/core/dev.c:7605
Freed by task 7865:
__kasan_slab_free+0x102/0x150 mm/kasan/common.c:457
kasan_slab_free+0xe/0x10 mm/kasan/common.c:465
__cache_free mm/slab.c:3494 [inline]
kfree+0xcf/0x230 mm/slab.c:3811
x25_neigh_put include/net/x25.h:253 [inline]
x25_connect+0x8d8/0xde0 net/x25/af_x25.c:824
__sys_connect+0x266/0x330 net/socket.c:1685
__do_sys_connect net/socket.c:1696 [inline]
__se_sys_connect net/socket.c:1693 [inline]
__x64_sys_connect+0x73/0xb0 net/socket.c:1693
The buggy address belongs to the object at ffff8880a030edc0
which belongs to the cache kmalloc-256 of size 256
The buggy address is located 16 bytes inside of
256-byte region [ffff8880a030edc0, ffff8880a030eec0)
The buggy address belongs to the page:
page:ffffea000280c380 count:1 mapcount:0 mapping:ffff88812c3f07c0 index:0x0
flags: 0x1fffc0000000200(slab)
raw: 01fffc0000000200 ffffea0002806788 ffffea00027f0188 ffff88812c3f07c0
raw: 0000000000000000 ffff8880a030e000 000000010000000c 0000000000000000
page dumped because: kasan: bad access detected
Reported-by: syzbot+04babcefcd396fabec37@syzkaller.appspotmail.com
[ Upstream commit a843dc4ebaecd15fca1f4d35a97210f72ea1473b ]
In func check_6rd,tunnel->ip6rd.relay_prefixlen may equal to
32,so UBSAN complain about it.
UBSAN: Undefined behaviour in net/ipv6/sit.c:781:47
shift exponent 32 is too large for 32-bit type 'unsigned int'
CPU: 6 PID: 20036 Comm: syz-executor.0 Not tainted 4.19.27 #2
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1ubuntu1
04/01/2014
Call Trace:
dump_stack+0xca/0x13e lib/dump_stack.c:113
ubsan_epilogue+0xe/0x81 lib/ubsan.c:159
__ubsan_handle_shift_out_of_bounds+0x293/0x2e8 lib/ubsan.c:425
check_6rd.constprop.9+0x433/0x4e0 net/ipv6/sit.c:781
try_6rd net/ipv6/sit.c:806 [inline]
ipip6_tunnel_xmit net/ipv6/sit.c:866 [inline]
sit_tunnel_xmit+0x141c/0x2720 net/ipv6/sit.c:1033
__netdev_start_xmit include/linux/netdevice.h:4300 [inline]
netdev_start_xmit include/linux/netdevice.h:4309 [inline]
xmit_one net/core/dev.c:3243 [inline]
dev_hard_start_xmit+0x17c/0x780 net/core/dev.c:3259
__dev_queue_xmit+0x1656/0x2500 net/core/dev.c:3829
neigh_output include/net/neighbour.h:501 [inline]
ip6_finish_output2+0xa36/0x2290 net/ipv6/ip6_output.c:120
ip6_finish_output+0x3e7/0xa20 net/ipv6/ip6_output.c:154
NF_HOOK_COND include/linux/netfilter.h:278 [inline]
ip6_output+0x1e2/0x720 net/ipv6/ip6_output.c:171
dst_output include/net/dst.h:444 [inline]
ip6_local_out+0x99/0x170 net/ipv6/output_core.c:176
ip6_send_skb+0x9d/0x2f0 net/ipv6/ip6_output.c:1697
ip6_push_pending_frames+0xc0/0x100 net/ipv6/ip6_output.c:1717
rawv6_push_pending_frames net/ipv6/raw.c:616 [inline]
rawv6_sendmsg+0x2435/0x3530 net/ipv6/raw.c:946
inet_sendmsg+0xf8/0x5c0 net/ipv4/af_inet.c:798
sock_sendmsg_nosec net/socket.c:621 [inline]
sock_sendmsg+0xc8/0x110 net/socket.c:631
___sys_sendmsg+0x6cf/0x890 net/socket.c:2114
__sys_sendmsg+0xf0/0x1b0 net/socket.c:2152
do_syscall_64+0xc8/0x580 arch/x86/entry/common.c:290
Signed-off-by: linmiaohe <linmiaohe@huawei.com>
[ Upstream commit 6caabe7f197d3466d238f70915d65301f1716626 ]
If hsr_add_port(hsr, hsr_dev, HSR_PT_MASTER) failed to
add port, it directly returns res and forgets to free the node
that allocated in hsr_create_self_node(), and forgets to delete
the node->mac_list linked in hsr->self_node_db.
BUG: memory leak
unreferenced object 0xffff8881cfa0c780 (size 64):
comm "syz-executor.0", pid 2077, jiffies 4294717969 (age 2415.377s)
hex dump (first 32 bytes):
e0 c7 a0 cf 81 88 ff ff 00 02 00 00 00 00 ad de ................
00 e6 49 cd 81 88 ff ff c0 9b 87 d0 81 88 ff ff ..I.............
backtrace:
[<00000000e2ff5070>] hsr_dev_finalize+0x736/0x960 [hsr]
[<000000003ed2e597>] hsr_newlink+0x2b2/0x3e0 [hsr]
[<000000003fa8c6b6>] __rtnl_newlink+0xf1f/0x1600 net/core/rtnetlink.c:3182
[<000000001247a7ad>] rtnl_newlink+0x66/0x90 net/core/rtnetlink.c:3240
[<00000000e7d1b61d>] rtnetlink_rcv_msg+0x54e/0xb90 net/core/rtnetlink.c:5130
[<000000005556bd3a>] netlink_rcv_skb+0x129/0x340 net/netlink/af_netlink.c:2477
[<00000000741d5ee6>] netlink_unicast_kernel net/netlink/af_netlink.c:1310 [inline]
[<00000000741d5ee6>] netlink_unicast+0x49a/0x650 net/netlink/af_netlink.c:1336
[<000000009d56f9b7>] netlink_sendmsg+0x88b/0xdf0 net/netlink/af_netlink.c:1917
[<0000000046b35c59>] sock_sendmsg_nosec net/socket.c:621 [inline]
[<0000000046b35c59>] sock_sendmsg+0xc3/0x100 net/socket.c:631
[<00000000d208adc9>] __sys_sendto+0x33e/0x560 net/socket.c:1786
[<00000000b582837a>] __do_sys_sendto net/socket.c:1798 [inline]
[<00000000b582837a>] __se_sys_sendto net/socket.c:1794 [inline]
[<00000000b582837a>] __x64_sys_sendto+0xdd/0x1b0 net/socket.c:1794
[<00000000c866801d>] do_syscall_64+0x147/0x600 arch/x86/entry/common.c:290
[<00000000fea382d9>] entry_SYSCALL_64_after_hwframe+0x49/0xbe
[<00000000e01dacb3>] 0xffffffffffffffff
Fixes: c5a759117210 ("net/hsr: Use list_head (and rcu) instead of array for slave devices.")
Signed-off-by: Mao Wenan <maowenan@huawei.com>
[ Upstream commit 163d1c3d6f17556ed3c340d3789ea93be95d6c28 ]
Back in 2013 Hannes took care of most of such leaks in commit
bceaa90240b6 ("inet: prevent leakage of uninitialized memory to user in recv syscalls")
But the bug in l2tp_ip6_recvmsg() has not been fixed.
syzbot report :
BUG: KMSAN: kernel-infoleak in _copy_to_user+0x16b/0x1f0 lib/usercopy.c:32
CPU: 1 PID: 10996 Comm: syz-executor362 Not tainted 5.0.0+ #11
Call Trace:
dump_stack+0x173/0x1d0 lib/dump_stack.c:113
kmsan_report+0x12e/0x2a0 mm/kmsan/kmsan.c:600
kmsan_internal_check_memory+0x9f4/0xb10 mm/kmsan/kmsan.c:694
kmsan_copy_to_user+0xab/0xc0 mm/kmsan/kmsan_hooks.c:601
copy_to_user include/linux/uaccess.h:174 [inline]
move_addr_to_user+0x311/0x570 net/socket.c:227
___sys_recvmsg+0xb65/0x1310 net/socket.c:2283
do_recvmmsg+0x646/0x10c0 net/socket.c:2390
__sys_recvmmsg net/socket.c:2469 [inline]
__do_sys_recvmmsg net/socket.c:2492 [inline]
__se_sys_recvmmsg+0x1d1/0x350 net/socket.c:2485
__x64_sys_recvmmsg+0x62/0x80 net/socket.c:2485
do_syscall_64+0xbc/0xf0 arch/x86/entry/common.c:291
entry_SYSCALL_64_after_hwframe+0x63/0xe7
RIP: 0033:0x445819
Code: e8 6c b6 02 00 48 83 c4 18 c3 0f 1f 80 00 00 00 00 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 2b 12 fc ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007f64453eddb8 EFLAGS: 00000246 ORIG_RAX: 000000000000012b
RAX: ffffffffffffffda RBX: 00000000006dac28 RCX: 0000000000445819
RDX: 0000000000000005 RSI: 0000000020002f80 RDI: 0000000000000003
RBP: 00000000006dac20 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 00000000006dac2c
R13: 00007ffeba8f87af R14: 00007f64453ee9c0 R15: 20c49ba5e353f7cf
Local variable description: ----addr@___sys_recvmsg
Variable was created at:
___sys_recvmsg+0xf6/0x1310 net/socket.c:2244
Bytes 0-31 of 32 are uninitialized
Memory access of size 32 starts at ffff8880ae62fbb0
Data copied to user address 0000000020000000
Fixes: a32e0eec7042 ("l2tp: introduce L2TPv3 IP encapsulation support for IPv6")
commit 644c7e48cb59cfc6988ddc7bf3d3b1ba5fe7fa9d upstream.
Baozeng Ding reported a KASAN stack out of bounds issue - it uncovered that
the TCP option parsing routines in netfilter TCP connection tracking could
read one byte out of the buffer of the TCP options. Therefore in the patch
we check that the available data length is large enough to parse both TCP
option code and size.
Reported-by: Baozeng Ding <sploving1@gmail.com>
Tested-by: Baozeng Ding <sploving1@gmail.com>
Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
Cc: Zubin Mithra <zsm@chromium.org>
commit 017b1b6d28c479f1ad9a7a41f775545a3e1cba35 upstream.
nfacct_filter_alloc doesn't validate the NFACCT_FILTER_MASK and
NFACCT_FILTER_VALUE parameters which can trigger a NULL pointer
dereference. CAP_NET_ADMIN is required to trigger the bug.
Signed-off-by: Phil Turnbull <phil.turnbull@oracle.com>
commit eb075954e9fde114f57adc39a9ea6d379c13f81e upstream.
This patch stops processing options for unknown command.
Signed-off-by: Ken-ichirou MATSUZAWA <chamas@h4.dion.ne.jp>
GET_ENTRIES
commit b301f2538759933cf9ff1f7c4f968da72e3f0757 upstream.
Make sure the table names via getsockopt GET_ENTRIES is nul-terminated
in ebtables and all the x_tables variants and their respective compat
code. Uncovered by KASAN.
commit 30c7be26fd3587abcb69587f781098e3ca2d565b upstream.
In commits 93821778def10 ("udp: Fix rcv socket locking") and
f7ad74fef3af ("net/ipv6/udp: UDP encapsulation: break backlog_rcv into
__udpv6_queue_rcv_skb") UDP backlog handlers were renamed, but UDPlite
was forgotten.
This leads to crashes if UDPlite header is pulled twice, which happens
starting from commit e6afc8ace6dd ("udp: remove headers from UDP packets
before queueing")
Bug found by syzkaller team, thanks a lot guys !
Note that backlog use in UDP/UDPlite is scheduled to be removed starting
from linux-4.10, so this patch is only needed up to linux-4.9
Fixes: 93821778def1 ("udp: Fix rcv socket locking")
Fixes: f7ad74fef3af ("net/ipv6/udp: UDP encapsulation: break backlog_rcv into __udpv6_queue_rcv_skb")
Fixes: e6afc8ace6dd ("udp: remove headers from UDP packets before queueing")
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Cc: Benjamin LaHaise <bcrl@kvack.org>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
[ Upstream commit 53ab60baa1ac4f20b080a22c13b77b6373922fd7 ]
There is a UBSAN bug report as below:
UBSAN: Undefined behaviour in net/netfilter/ipvs/ip_vs_ctl.c:2227:21
signed integer overflow:
-2147483647 * 1000 cannot be represented in type 'int'
Reproduce program:
#include <stdio.h>
#include <sys/types.h>
#include <sys/socket.h>
#define IPPROTO_IP 0
#define IPPROTO_RAW 255
#define IP_VS_BASE_CTL (64+1024+64)
#define IP_VS_SO_SET_TIMEOUT (IP_VS_BASE_CTL+10)
/* The argument to IP_VS_SO_GET_TIMEOUT */
struct ipvs_timeout_t {
int tcp_timeout;
int tcp_fin_timeout;
int udp_timeout;
int main() {
int ret = -1;
int sockfd = -1;
struct ipvs_timeout_t to;
sockfd = socket(AF_INET, SOCK_RAW, IPPROTO_RAW);
if (sockfd == -1) {
printf("socket init error\n");
return -1;
to.tcp_timeout = -2147483647;
to.tcp_fin_timeout = -2147483647;
to.udp_timeout = -2147483647;
ret = setsockopt(sockfd,
IPPROTO_IP,
IP_VS_SO_SET_TIMEOUT,
(char *)(&to),
sizeof(to));
printf("setsockopt return %d\n", ret);
return ret;
Return -EINVAL if the timeout value is negative or max than 'INT_MAX / HZ'.
Signed-off-by: ZhangXiaoxu <zhangxiaoxu5@huawei.com>
Acked-by: Simon Horman <horms@verge.net.au>
[ Upstream commit dd9ee3444014e8f28c0eefc9fffc9ac9c5248c12 ]
Recently we run a network test over ipcomp virtual tunnel.We find that
if a ipv4 packet needs fragment, then the peer can't receive
it.
We deep into the code and find that when packet need fragment the smaller
fragment will be encapsulated by ipip not ipcomp. So when the ipip packet
goes into xfrm, it's skb->dev is not properly set. The ipv4 reassembly code
always set skb'dev to the last fragment's dev. After ipv4 defrag processing,
when the kernel rp_filter parameter is set, the skb will be drop by -EXDEV
error.
This patch adds compatible support for the ipip process in ipcomp virtual tunnel.
Signed-off-by: Su Yanjun <suyj.fnst@cn.fujitsu.com>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit 87c11f1ddbbad38ad8bad47af133a8208985fbdf ]
Similar to commit 44f49dd8b5a6 ("ipmr: fix possible race resulting from
improper usage of IP_INC_STATS_BH() in preemptible context."), we cannot
assume preemption is disabled when incrementing the counter and
accessing a per-CPU variable.
Preemption can be enabled when we add a route in process context that
corresponds to packets stored in the unresolved queue, which are then
forwarded using this route [1].
Fix this by using IP6_INC_STATS() which takes care of disabling
preemption on architectures where it is needed.
[1]
[ 157.451447] BUG: using __this_cpu_add() in preemptible [00000000] code: smcrouted/2314
[ 157.460409] caller is ip6mr_forward2+0x73e/0x10e0
[ 157.460434] CPU: 3 PID: 2314 Comm: smcrouted Not tainted 5.0.0-rc7-custom-03635-g22f2712113f1 #1336
[ 157.460449] Hardware name: Mellanox Technologies Ltd. MSN2100-CB2FO/SA001017, BIOS 5.6.5 06/07/2016
[ 157.460461] Call Trace:
[ 157.460486] dump_stack+0xf9/0x1be
[ 157.460553] check_preemption_disabled+0x1d6/0x200
[ 157.460576] ip6mr_forward2+0x73e/0x10e0
[ 157.460705] ip6_mr_forward+0x9a0/0x1510
[ 157.460771] ip6mr_mfc_add+0x16b3/0x1e00
[ 157.461155] ip6_mroute_setsockopt+0x3cb/0x13c0
[ 157.461384] do_ipv6_setsockopt.isra.8+0x348/0x4060
[ 157.462013] ipv6_setsockopt+0x90/0x110
[ 157.462036] rawv6_setsockopt+0x4a/0x120
[ 157.462058] __sys_setsockopt+0x16b/0x340
[ 157.462198] __x64_sys_setsockopt+0xbf/0x160
[ 157.462220] do_syscall_64+0x14d/0x610
[ 157.462349] entry_SYSCALL_64_after_hwframe+0x49/0xbe
Fixes: 0912ea38de61 ("[IPV6] MROUTE: Add stats in multicast routing module method ip6_mr_forward().")
Signed-off-by: Ido Schimmel <idosch@mellanox.com>
Reported-by: Amit Cohen <amitc@mellanox.com>
[ Upstream commit 5578de4834fe0f2a34fedc7374be691443396d1f ]
There are two array out-of-bounds memory accesses, one in
cipso_v4_map_lvl_valid(), the other in netlbl_bitmap_walk(). Both
errors are embarassingly simple, and the fixes are straightforward.
As a FYI for anyone backporting this patch to kernels prior to v4.8,
you'll want to apply the netlbl_bitmap_walk() patch to
cipso_v4_bitmap_walk() as netlbl_bitmap_walk() doesn't exist before
Linux v4.8.
Reported-by: Jann Horn <jannh@google.com>
Fixes: 446fda4f2682 ("[NetLabel]: CIPSOv4 engine")
Fixes: 3faa8f982f95 ("netlabel: Move bitmap manipulation functions to the NetLabel core.")
Signed-off-by: Paul Moore <paul@paul-moore.com>
[ Upstream commit 3da1ed7ac398f34fff1694017a07054d69c5f5c5 ]
Extract IP options in cipso_v4_error and use __icmp_send.
Signed-off-by: Sergey Nazarov <s-nazarov@yandex.ru>
Acked-by: Paul Moore <paul@paul-moore.com>
[ Upstream commit 9ef6b42ad6fd7929dd1b6092cb02014e382c6a91 ]
Add __icmp_send function having ip_options struct parameter
Reviewed-by: Paul Moore <paul@paul-moore.com>
[ Upstream commit 58bdd544e2933a21a51eecf17c3f5f94038261b5 ]
KASAN report this:
BUG: KASAN: null-ptr-deref in nfc_llcp_build_gb+0x37f/0x540 [nfc]
Read of size 3 at addr 0000000000000000 by task syz-executor.0/5401
CPU: 0 PID: 5401 Comm: syz-executor.0 Not tainted 5.0.0-rc7+ #45
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1ubuntu1 04/01/2014
Call Trace:
dump_stack+0xfa/0x1ce lib/dump_stack.c:113
kasan_report+0x171/0x18d mm/kasan/report.c:321
memcpy+0x1f/0x50 mm/kasan/common.c:130
nfc_llcp_register_device+0x6eb/0xb50 [nfc]
nfc_register_device+0x50/0x1d0 [nfc]
nfcsim_device_new+0x394/0x67d [nfcsim]
? 0xffffffffc1080000
nfcsim_init+0x6b/0x1000 [nfcsim]
do_one_initcall+0xfa/0x5ca init/main.c:887
do_init_module+0x204/0x5f6 kernel/module.c:3460
load_module+0x66b2/0x8570 kernel/module.c:3808
__do_sys_finit_module+0x238/0x2a0 kernel/module.c:3902
RIP: 0033:0x462e99
Code: f7 d8 64 89 02 b8 ff ff ff ff c3 66 0f 1f 44 00 00 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 c7 c1 bc ff ff ff f7 d8 64 89 01 48
RSP: 002b:00007f9cb79dcc58 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
RAX: ffffffffffffffda RBX: 000000000073bf00 RCX: 0000000000462e99
RDX: 0000000000000000 RSI: 0000000020000280 RDI: 0000000000000003
RBP: 00007f9cb79dcc70 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 00007f9cb79dd6bc
R13: 00000000004bcefb R14: 00000000006f7030 R15: 0000000000000004
nfc_llcp_build_tlv will return NULL on fails, caller should check it,
otherwise will trigger a NULL dereference.
Fixes: eda21f16a5ed ("NFC: Set MIU and RW values from CONNECT and CC LLCP frames")
Fixes: d646960f7986 ("NFC: Initial LLCP support")
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
[ Upstream commit 895a5e96dbd6386c8e78e5b78e067dcc67b7f0ab ]
syzkaller report this:
BUG: memory leak
unreferenced object 0xffff88837a71a500 (size 256):
comm "syz-executor.2", pid 9770, jiffies 4297825125 (age 17.843s)
00 00 00 00 ad 4e ad de ff ff ff ff 00 00 00 00 .....N..........
ff ff ff ff ff ff ff ff 20 c0 ef 86 ff ff ff ff ........ .......
backtrace:
[<00000000db12624b>] netdev_register_kobject+0x124/0x2e0 net/core/net-sysfs.c:1751
[<00000000dc49a994>] register_netdevice+0xcc1/0x1270 net/core/dev.c:8516
[<00000000e5f3fea0>] tun_set_iff drivers/net/tun.c:2649 [inline]
[<00000000e5f3fea0>] __tun_chr_ioctl+0x2218/0x3d20 drivers/net/tun.c:2883
[<000000001b8ac127>] vfs_ioctl fs/ioctl.c:46 [inline]
[<000000001b8ac127>] do_vfs_ioctl+0x1a5/0x10e0 fs/ioctl.c:690
[<0000000079b269f8>] ksys_ioctl+0x89/0xa0 fs/ioctl.c:705
[<00000000de649beb>] __do_sys_ioctl fs/ioctl.c:712 [inline]
[<00000000de649beb>] __se_sys_ioctl fs/ioctl.c:710 [inline]
[<00000000de649beb>] __x64_sys_ioctl+0x74/0xb0 fs/ioctl.c:710
[<000000007ebded1e>] do_syscall_64+0xc8/0x580 arch/x86/entry/common.c:290
[<00000000db315d36>] entry_SYSCALL_64_after_hwframe+0x49/0xbe
[<00000000115be9bb>] 0xffffffffffffffff
It should call kset_unregister to free 'dev->queues_kset'
in error path of register_queue_kobjects, otherwise will cause a mem leak.
Fixes: 1d24eb4815d1 ("xps: Transmit Packet Steering")
commit 971df15bd54ad46e907046ff33750a137b2f0096 upstream.
The standard return value for unsupported attribute names is
-EOPNOTSUPP, as opposed to undefined but supported attributes
(-ENODATA).
Also, fail for attribute names like "system.sockprotonameXXX" and
simplify the code a bit.
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
[removes a build warning on 4.4.y - gregkh]
[ Upstream commit 93183bdbe73bbdd03e9566c8dc37c9d06b0d0db6 ]
Recently, DMG frequency bands have been extended till 71GHz, so extend
the range check till 20GHz (45-71GHZ), else some channels will be marked
as disabled.
Signed-off-by: Chaitanya Tata <Chaitanya.Tata@bluwireless.co.uk>
[ Upstream commit 7ed5285396c257fd4070b1e29e7b2341aae2a1ce ]
Following call trace is observed while adding TDLS peer entry in driver
during TDLS setup.
Call Trace:
[<c1301476>] dump_stack+0x47/0x61
[<c10537d2>] __warn+0xe2/0x100
[<fa22415f>] ? sta_apply_parameters+0x49f/0x550 [mac80211]
[<c1053895>] warn_slowpath_null+0x25/0x30
[<fa22415f>] sta_apply_parameters+0x49f/0x550 [mac80211]
[<fa20ad42>] ? sta_info_alloc+0x1c2/0x450 [mac80211]
[<fa224623>] ieee80211_add_station+0xe3/0x160 [mac80211]
[<c1876fe3>] nl80211_new_station+0x273/0x420
[<c170f6d9>] genl_rcv_msg+0x219/0x3c0
[<c170f4c0>] ? genl_rcv+0x30/0x30
[<c170ee7e>] netlink_rcv_skb+0x8e/0xb0
[<c170f4ac>] genl_rcv+0x1c/0x30
[<c170e8aa>] netlink_unicast+0x13a/0x1d0
[<c170ec18>] netlink_sendmsg+0x2d8/0x390
[<c16c5acd>] sock_sendmsg+0x2d/0x40
[<c16c6369>] ___sys_sendmsg+0x1d9/0x1e0
Fixing this by allowing TDLS setup request only when we have completed
association.
Signed-off-by: Balaji Pothunoori <bpothuno@codeaurora.org>
[ Upstream commit a0dc02039a2ee54fb4ae400e0b755ed30e73e58c ]
In ieee80211_rx_h_mesh_fwding, we increment the 'dropped_frames_ttl'
counter when we decrement the ttl to zero. For unicast frames
destined for other hosts, we stop processing the frame at that point.
For multicast frames, we do not rebroadcast it in this case, but we
do pass the frame up the stack to process it on this STA. That
doesn't match the usual definition of "dropped," so don't count
those as such.
With this change, something like `ping6 -i0.2 ff02::1%mesh0` from a
peer in a ttl=1 network no longer increments the counter rapidly.
Signed-off-by: Bob Copeland <bobcopeland@fb.com>
commit 0fd3fd0a9bb0b02b6435bb7070e9f7b82a23f068 upstream.
The authorize reply can be empty, for example when the ticket used to
build the authorizer is too old and TAG_BADAUTHORIZER is returned from
the service. Calling ->verify_authorizer_reply() results in an attempt
to decrypt and validate (somewhat) random data in au->buf (most likely
the signature block from calc_signature()), which fails and ends up in
con_fault_finish() with !con->auth_retry. The ticket isn't invalidated
and the connection is retried again and again until a new ticket is
obtained from the monitor:
libceph: osd2 192.168.122.1:6809 bad authorize reply
Let TAG_BADAUTHORIZER handler kick in and increment con->auth_retry.
Fixes: 5c056fdc5b47 ("libceph: verify authorize reply on connect")
Link: https://tracker.ceph.com/issues/20164
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
Reviewed-by: Sage Weil <sage@redhat.com>
[idryomov@gmail.com: backport to 4.4: extra arg, no CEPHX_V2]
source 0.0.0.0"
commit 278e2148c07559dd4ad8602f22366d61eb2ee7b7 upstream.
This reverts commit 5a2de63fd1a5 ("bridge: do not add port to router list
when receives query with source 0.0.0.0") and commit 0fe5119e267f ("net:
bridge: remove ipv6 zero address check in mcast queries")
The reason is RFC 4541 is not a standard but suggestive. Currently we
will elect 0.0.0.0 as Querier if there is no ip address configured on
bridge. If we do not add the port which recives query with source
0.0.0.0 to router list, the IGMP reports will not be about to forward
to Querier, IGMP data will also not be able to forward to dest.
As Nikolay suggested, revert this change first and add a boolopt api
to disable none-zero election in future if needed.
Reported-by: Linus Lüssing <linus.luessing@c0d3.blue>
Reported-by: Sebastian Gottschall <s.gottschall@newmedia-net.de>
Fixes: 5a2de63fd1a5 ("bridge: do not add port to router list when receives query with source 0.0.0.0")
Fixes: 0fe5119e267f ("net: bridge: remove ipv6 zero address check in mcast queries")
Signed-off-by: Hangbin Liu <liuhangbin@gmail.com>
Acked-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
[ Upstream commit 173656accaf583698bac3f9e269884ba60d51ef4 ]
If we disabled IPv6 from the kernel command line (ipv6.disable=1), we should
not call ip6_err_gen_icmpv6_unreach(). This:
ip link add sit1 type sit local 192.0.2.1 remote 192.0.2.2 ttl 1
ip link set sit1 up
ip addr add 198.51.100.1/24 dev sit1
ping 198.51.100.2
if IPv6 is disabled at boot time, will crash the kernel.
v2: there's no need to use in6_dev_get(), use __in6_dev_get() instead,
as we only need to check that idev exists and we are under
rcu_read_lock() (from netif_receive_skb_internal()).
Reported-by: Jianlin Shi <jishi@redhat.com>
Fixes: ca15a078bd90 ("sit: generate icmpv6 error when receiving icmpv4 error")
Cc: Oussama Ghorbel <ghorbel@pivasoftware.com>
Reviewed-by: Stefano Brivio <sbrivio@redhat.com>
[ Upstream commit fc62814d690cf62189854464f4bd07457d5e9e50 ]
When calculating rb->frames_per_block * req->tp_block_nr the result
can overflow. Check it for overflow without limiting the total buffer
size to UINT_MAX.
This change fixes support for packet ring buffers >= UINT_MAX.
Fixes: 8f8d28e4d6d8 ("net/packet: fix overflow in check for tp_frame_nr")
Signed-off-by: Kal Conley <kal.conley@dectris.com>
[ Upstream commit 4ffcbfac60642f63ae3d80891f573ba7e94a265c ]
KMSAN reported batadv_interface_tx() was possibly using a
garbage value [1]
batadv_get_vid() does have a pskb_may_pull() call
but batadv_interface_tx() does not actually make sure
this did not fail.
[1]
BUG: KMSAN: uninit-value in batadv_interface_tx+0x908/0x1e40 net/batman-adv/soft-interface.c:231
CPU: 0 PID: 10006 Comm: syz-executor469 Not tainted 4.20.0-rc7+ #5
Call Trace:
kmsan_report+0x12e/0x2a0 mm/kmsan/kmsan.c:613
__msan_warning+0x82/0xf0 mm/kmsan/kmsan_instr.c:313
__netdev_start_xmit include/linux/netdevice.h:4356 [inline]
netdev_start_xmit include/linux/netdevice.h:4365 [inline]
xmit_one net/core/dev.c:3257 [inline]
dev_hard_start_xmit+0x607/0xc40 net/core/dev.c:3273
__dev_queue_xmit+0x2e42/0x3bc0 net/core/dev.c:3843
dev_queue_xmit+0x4b/0x60 net/core/dev.c:3876
packet_snd net/packet/af_packet.c:2928 [inline]
packet_sendmsg+0x8306/0x8f30 net/packet/af_packet.c:2953
sock_sendmsg net/socket.c:631 [inline]
__sys_sendto+0x8c4/0xac0 net/socket.c:1788
__do_sys_sendto net/socket.c:1800 [inline]
__se_sys_sendto+0x107/0x130 net/socket.c:1796
__x64_sys_sendto+0x6e/0x90 net/socket.c:1796
RIP: 0033:0x441889
Code: 18 89 d0 c3 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 00 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 bb 10 fc ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007ffdda6fd468 EFLAGS: 00000216 ORIG_RAX: 000000000000002c
RAX: ffffffffffffffda RBX: 0000000000000002 RCX: 0000000000441889
RDX: 000000000000000e RSI: 00000000200000c0 RDI: 0000000000000003
RBP: 0000000000000003 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000216 R12: 00007ffdda6fd4c0
R13: 00007ffdda6fd4b0 R14: 0000000000000000 R15: 0000000000000000
Uninit was created at:
kmsan_save_stack_with_flags mm/kmsan/kmsan.c:204 [inline]
kmsan_internal_poison_shadow+0x92/0x150 mm/kmsan/kmsan.c:158
kmsan_kmalloc+0xa6/0x130 mm/kmsan/kmsan_hooks.c:176
kmsan_slab_alloc+0xe/0x10 mm/kmsan/kmsan_hooks.c:185
slab_post_alloc_hook mm/slab.h:446 [inline]
slab_alloc_node mm/slub.c:2759 [inline]
__kmalloc_node_track_caller+0xe18/0x1030 mm/slub.c:4383
__kmalloc_reserve net/core/skbuff.c:137 [inline]
__alloc_skb+0x309/0xa20 net/core/skbuff.c:205
alloc_skb include/linux/skbuff.h:998 [inline]
alloc_skb_with_frags+0x1c7/0xac0 net/core/skbuff.c:5220
sock_alloc_send_pskb+0xafd/0x10e0 net/core/sock.c:2083
packet_alloc_skb net/packet/af_packet.c:2781 [inline]
packet_snd net/packet/af_packet.c:2872 [inline]
packet_sendmsg+0x661a/0x8f30 net/packet/af_packet.c:2953
Fixes: c6c8fea29769 ("net: Add batman-adv meshing protocol")
Cc: Marek Lindner <mareklindner@neomailbox.ch>
Cc: Simon Wunderlich <sw@simonwunderlich.de>
Cc: Antonio Quartulli <a@unstable.cc>
commit 63530aba7826a0f8e129874df9c4d264f9db3f9e upstream.
syzbot found that ax25 routes where not properly protected
against concurrent use [1].
In this particular report the bug happened while
copying ax25->digipeat.
Fix this problem by making sure we call ax25_get_route()
while ax25_route_lock is held, so that no modification
could happen while using the route.
The current two ax25_get_route() callers do not sleep,
so this change should be fine.
Once we do that, ax25_get_route() no longer needs to
grab a reference on the found route.
[1]
ax25_connect(): syz-executor0 uses autobind, please contact jreuter@yaina.de
BUG: KASAN: use-after-free in memcpy include/linux/string.h:352 [inline]
BUG: KASAN: use-after-free in kmemdup+0x42/0x60 mm/util.c:113
Read of size 66 at addr ffff888066641a80 by task syz-executor2/531
CPU: 1 PID: 531 Comm: syz-executor2 Not tainted 5.0.0-rc2+ #10
Call Trace:
dump_stack+0x1db/0x2d0 lib/dump_stack.c:113
check_memory_region_inline mm/kasan/generic.c:185 [inline]
check_memory_region+0x123/0x190 mm/kasan/generic.c:191
memcpy+0x24/0x50 mm/kasan/common.c:130
kmemdup include/linux/string.h:425 [inline]
ax25_rt_autobind+0x25d/0x750 net/ax25/ax25_route.c:424
ax25_connect.cold+0x30/0xa4 net/ax25/af_ax25.c:1224
__sys_connect+0x357/0x490 net/socket.c:1664
__do_sys_connect net/socket.c:1675 [inline]
__se_sys_connect net/socket.c:1672 [inline]
__x64_sys_connect+0x73/0xb0 net/socket.c:1672
do_syscall_64+0x1a3/0x800 arch/x86/entry/common.c:290
RIP: 0033:0x458099
Code: 6d b7 fb ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 3b b7 fb ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007f870ee22c78 EFLAGS: 00000246 ORIG_RAX: 000000000000002a
RAX: ffffffffffffffda RBX: 0000000000000003 RCX: 0000000000458099
RDX: 0000000000000048 RSI: 0000000020000080 RDI: 0000000000000005
ax25_connect(): syz-executor4 uses autobind, please contact jreuter@yaina.de
R10: 0000000000000000 R11: 0000000000000246 R12: 00007f870ee236d4
R13: 00000000004be48e R14: 00000000004ce9a8 R15: 00000000ffffffff
Allocated by task 526:
__kasan_kmalloc mm/kasan/common.c:496 [inline]
__kasan_kmalloc.constprop.0+0xcf/0xe0 mm/kasan/common.c:469
kasan_kmalloc+0x9/0x10 mm/kasan/common.c:504
ax25_connect(): syz-executor5 uses autobind, please contact jreuter@yaina.de
kmem_cache_alloc_trace+0x151/0x760 mm/slab.c:3609
ax25_rt_add net/ax25/ax25_route.c:95 [inline]
ax25_rt_ioctl+0x3b9/0x1270 net/ax25/ax25_route.c:233
ax25_ioctl+0x322/0x10b0 net/ax25/af_ax25.c:1763
sock_do_ioctl+0xe2/0x400 net/socket.c:950
sock_ioctl+0x32f/0x6c0 net/socket.c:1074
do_vfs_ioctl+0x107b/0x17d0 fs/ioctl.c:696
Freed by task 550:
__kasan_slab_free+0x102/0x150 mm/kasan/common.c:458
kasan_slab_free+0xe/0x10 mm/kasan/common.c:466
__cache_free mm/slab.c:3487 [inline]
kfree+0xcf/0x230 mm/slab.c:3806
ax25_rt_add net/ax25/ax25_route.c:92 [inline]
ax25_rt_ioctl+0x304/0x1270 net/ax25/ax25_route.c:233
The buggy address belongs to the object at ffff888066641a80
which belongs to the cache kmalloc-96 of size 96
The buggy address is located 0 bytes inside of
96-byte region [ffff888066641a80, ffff888066641ae0)
page:ffffea0001999040 count:1 mapcount:0 mapping:ffff88812c3f04c0 index:0x0
raw: 01fffc0000000200 ffffea0001817948 ffffea0002341dc8 ffff88812c3f04c0
raw: 0000000000000000 ffff888066641000 0000000100000020 0000000000000000
Memory state around the buggy address:
ffff888066641980: fb fb fb fb fb fb fb fb fb fb fb fb fc fc fc fc
ffff888066641a00: 00 00 00 00 00 00 00 00 02 fc fc fc fc fc fc fc
>ffff888066641a80: fb fb fb fb fb fb fb fb fb fb fb fb fc fc fc fc
ffff888066641b00: fb fb fb fb fb fb fb fb fb fb fb fb fc fc fc fc
ffff888066641b80: 00 00 00 00 00 00 00 00 00 00 00 00 fc fc fc fc
commit cf657d22ee1f0e887326a92169f2e28dc932fd10 upstream.
Due to quadratic behavior of x25_new_lci(), syzbot was able
to trigger an rcu stall.
Fix this by not blocking BH for the whole duration of
the function, and inserting a reschedule point when possible.
If we care enough, using a bitmap could get rid of the quadratic
behavior.
syzbot report :
rcu: INFO: rcu_preempt self-detected stall on CPU
rcu: 0-...!: (10500 ticks this GP) idle=4fa/1/0x4000000000000002 softirq=283376/283376 fqs=0
rcu: (t=10501 jiffies g=383105 q=136)
rcu: rcu_preempt kthread starved for 10502 jiffies! g383105 f0x0 RCU_GP_WAIT_FQS(5) ->state=0x402 ->cpu=0
rcu: RCU grace-period kthread stack dump:
rcu_preempt I28928 10 2 0x80000000
Call Trace:
context_switch kernel/sched/core.c:2844 [inline]
__schedule+0x817/0x1cc0 kernel/sched/core.c:3485
schedule+0x92/0x180 kernel/sched/core.c:3529
schedule_timeout+0x4db/0xfd0 kernel/time/timer.c:1803
rcu_gp_fqs_loop kernel/rcu/tree.c:1948 [inline]
rcu_gp_kthread+0x956/0x17a0 kernel/rcu/tree.c:2105
kthread+0x357/0x430 kernel/kthread.c:246
ret_from_fork+0x3a/0x50 arch/x86/entry/entry_64.S:352
NMI backtrace for cpu 0
CPU: 0 PID: 8759 Comm: syz-executor2 Not tainted 5.0.0-rc4+ #51
Call Trace:
<IRQ>
nmi_cpu_backtrace.cold+0x63/0xa4 lib/nmi_backtrace.c:101
nmi_trigger_cpumask_backtrace+0x1be/0x236 lib/nmi_backtrace.c:62
arch_trigger_cpumask_backtrace+0x14/0x20 arch/x86/kernel/apic/hw_nmi.c:38
trigger_single_cpu_backtrace include/linux/nmi.h:164 [inline]
rcu_dump_cpu_stacks+0x183/0x1cf kernel/rcu/tree.c:1211
print_cpu_stall kernel/rcu/tree.c:1348 [inline]
check_cpu_stall kernel/rcu/tree.c:1422 [inline]
rcu_pending kernel/rcu/tree.c:3018 [inline]
rcu_check_callbacks.cold+0x500/0xa4a kernel/rcu/tree.c:2521
update_process_times+0x32/0x80 kernel/time/timer.c:1635
tick_sched_handle+0xa2/0x190 kernel/time/tick-sched.c:161
tick_sched_timer+0x47/0x130 kernel/time/tick-sched.c:1271
__run_hrtimer kernel/time/hrtimer.c:1389 [inline]
__hrtimer_run_queues+0x33e/0xde0 kernel/time/hrtimer.c:1451
hrtimer_interrupt+0x314/0x770 kernel/time/hrtimer.c:1509
local_apic_timer_interrupt arch/x86/kernel/apic/apic.c:1035 [inline]
smp_apic_timer_interrupt+0x120/0x570 arch/x86/kernel/apic/apic.c:1060
apic_timer_interrupt+0xf/0x20 arch/x86/entry/entry_64.S:807
</IRQ>
RIP: 0010:queued_write_lock_slowpath+0x13e/0x290 kernel/locking/qrwlock.c:86
Code: 00 00 fc ff df 4c 8d 2c 01 41 83 c7 03 41 0f b6 45 00 41 38 c7 7c 08 84 c0 0f 85 0c 01 00 00 8b 03 3d 00 01 00 00 74 1a f3 90 <41> 0f b6 55 00 41 38 d7 7c eb 84 d2 74 e7 48 89 df e8 6c 0f 4f 00
RSP: 0018:ffff88805f117bd8 EFLAGS: 00000206 ORIG_RAX: ffffffffffffff13
RAX: 0000000000000300 RBX: ffffffff89413ba0 RCX: 1ffffffff1282774
RDX: 0000000000000000 RSI: 0000000000000004 RDI: ffffffff89413ba0
RBP: ffff88805f117c70 R08: 1ffffffff1282774 R09: fffffbfff1282775
R10: fffffbfff1282774 R11: ffffffff89413ba3 R12: 00000000000000ff
R13: fffffbfff1282774 R14: 1ffff1100be22f7d R15: 0000000000000003
x25_bind+0x273/0x340 net/x25/af_x25.c:705
__sys_bind+0x23f/0x290 net/socket.c:1505
__do_sys_bind net/socket.c:1516 [inline]
__se_sys_bind net/socket.c:1514 [inline]
__x64_sys_bind+0x73/0xb0 net/socket.c:1514
RIP: 0033:0x457e39
RSP: 002b:00007fafccd0dc78 EFLAGS: 00000246 ORIG_RAX: 0000000000000031
RAX: ffffffffffffffda RBX: 0000000000000003 RCX: 0000000000457e39
RDX: 0000000000000012 RSI: 0000000020000240 RDI: 0000000000000004
R10: 0000000000000000 R11: 0000000000000246 R12: 00007fafccd0e6d4
R13: 00000000004bdf8b R14: 00000000004ce4b8 R15: 00000000ffffffff
CPU: 1 PID: 8752 Comm: syz-executor4 Not tainted 5.0.0-rc4+ #51
RIP: 0010:__x25_find_socket+0x78/0x120 net/x25/af_x25.c:328
Code: 89 f8 48 c1 e8 03 80 3c 18 00 0f 85 a6 00 00 00 4d 8b 64 24 68 4d 85 e4 74 7f e8 03 97 3d fb 49 83 ec 68 74 74 e8 f8 96 3d fb <49> 8d bc 24 88 04 00 00 48 89 f8 48 c1 e8 03 0f b6 04 18 84 c0 74
RSP: 0018:ffff8880639efc58 EFLAGS: 00000246
RAX: 0000000000040000 RBX: dffffc0000000000 RCX: ffffc9000e677000
RDX: 0000000000040000 RSI: ffffffff863244b8 RDI: ffff88806a764628
RBP: ffff8880639efc80 R08: ffff8880a80d05c0 R09: fffffbfff1282775
R10: fffffbfff1282774 R11: ffffffff89413ba3 R12: ffff88806a7645c0
R13: 0000000000000001 R14: ffff88809f29ac00 R15: 0000000000000000
FS: 00007fe8d0c58700(0000) GS:ffff8880ae900000(0000) knlGS:0000000000000000
CR2: 0000001b32823000 CR3: 00000000672eb000 CR4: 00000000001406e0
Call Trace:
x25_new_lci net/x25/af_x25.c:357 [inline]
x25_connect+0x374/0xdf0 net/x25/af_x25.c:786
__sys_connect+0x266/0x330 net/socket.c:1686
__do_sys_connect net/socket.c:1697 [inline]
__se_sys_connect net/socket.c:1694 [inline]
__x64_sys_connect+0x73/0xb0 net/socket.c:1694
RIP: 0033:0x457e39
RSP: 002b:00007fe8d0c57c78 EFLAGS: 00000246 ORIG_RAX: 000000000000002a
RDX: 0000000000000012 RSI: 0000000020000200 RDI: 0000000000000004
R10: 0000000000000000 R11: 0000000000000246 R12: 00007fe8d0c586d4
R13: 00000000004be378 R14: 00000000004ceb00 R15: 00000000ffffffff
Cc: Andrew Hendry <andrew.hendry@gmail.com>
Cc: linux-x25@vger.kernel.org
[ Upstream commit c09551c6ff7fe16a79a42133bcecba5fc2fc3291 ]
According to the algorithm described in the comment block at the
beginning of ip_rt_send_redirect, the host should try to send
'ip_rt_redirect_number' ICMP redirect packets with an exponential
backoff and then stop sending them at all assuming that the destination
ignores redirects.
If the device has previously sent some ICMP error packets that are
rate-limited (e.g TTL expired) and continues to receive traffic,
the redirect packets will never be transmitted. This happens since
peer->rate_tokens will be typically greater than 'ip_rt_redirect_number'
and so it will never be reset even if the redirect silence timeout
(ip_rt_redirect_silence) has elapsed without receiving any packet
requiring redirects.
Fix it by using a dedicated counter for the number of ICMP redirect
packets that has been sent by the host
I have not been able to identify a given commit that introduced the
issue since ip_rt_send_redirect implements the same rate-limiting
algorithm from commit 1da177e4c3f4 ("Linux-2.6.12-rc2")
Signed-off-by: Lorenzo Bianconi <lorenzo.bianconi@redhat.com>
[ Upstream commit 04c03114be82194d4a4858d41dba8e286ad1787c ]
soukjin bae reported a crash in tcp_v4_err() handling
ICMP_DEST_UNREACH after tcp_write_queue_head(sk)
returned a NULL pointer.
Current logic should have prevented this :
if (seq != tp->snd_una || !icsk->icsk_retransmits ||
!icsk->icsk_backoff || fastopen)
break;
Problem is the write queue might have been purged
and icsk_backoff has not been cleared.
Reported-by: soukjin bae <soukjin.bae@samsung.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
[ Upstream commit 3bed3cc4156eedf652b4df72bdb35d4f1a2a739d ]
This patch addresses the fact that there are drivers, specifically tun,
that will call into the network page fragment allocators with buffer sizes
that are not cache aligned. Doing this could result in data alignment
and DMA performance issues as these fragment pools are also shared with the
skb allocator and any other devices that will use napi_alloc_frags or
netdev_alloc_frags.
Fixes: ffde7328a36d ("net: Split netdev_alloc_frag into __alloc_page_frag and add __napi_alloc_frag")
Signed-off-by: Alexander Duyck <alexander.h.duyck@linux.intel.com>
[ Upstream commit 2c4cc9712364c051b1de2d175d5fbea6be948ebf ]
ICMP handlers are not very often stressed, we should
make them more resilient to bugs that might surface in
the future.
If there is no packet in retransmit queue, we should
avoid a NULL deref.
Acked-by: Soheil Hassas Yeganeh <soheil@google.com>
[ Upstream commit 3b89ea9c5902acccdbbdec307c85edd1bf52515e ]
The features attribute is of type u64 and stored in the native endianes on
the system. The for_each_set_bit() macro takes a pointer to a 32 bit array
and goes over the bits in this area. On little Endian systems this also
works with an u64 as the most significant bit is on the highest address,
but on big endian the words are swapped. When we expect bit 15 here we get
bit 47 (15 + 32).
This patch converts it more or less to its own for_each_set_bit()
implementation which works on 64 bit integers directly. This is then
completely in host endianness and should work like expected.
Fixes: fd867d51f ("net/core: generic support for disabling netdev features down stack")
Signed-off-by: Hauke Mehrtens <hauke.mehrtens@intel.com>
[ Upstream commit 225d9464268599a5b4d094d02ec17808e44c7553 ]
In the unlikely event that the kmalloc call in vmci_transport_socket_init()
fails, we end-up calling vmci_transport_destruct() with a NULL vmci_trans()
and oopsing.
This change addresses the above explicitly checking for zero vmci_trans()
at destruction time.
Reported-by: Xiumei Mu <xmu@redhat.com>
Fixes: d021c344051a ("VSOCK: Introduce VM Sockets")
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
Reviewed-by: Stefano Garzarella <sgarzare@redhat.com>
Reviewed-by: Jorgen Hansen <jhansen@vmware.com>
[ Upstream commit e75913c93f7cd5f338ab373c34c93a655bd309cb ]
Follow those steps:
# ip addr add 2001:123::1/32 dev eth0
# ip addr add 2001:123:456::2/64 dev eth0
# ip addr del 2001:123::1/32 dev eth0
# ip addr del 2001:123:456::2/64 dev eth0
and then prefix route of 2001:123::1/32 will still exist.
This is because ipv6_prefix_equal in check_cleanup_prefix_route
func does not check whether two IPv6 addresses have the same
prefix length. If the prefix of one address starts with another
shorter address prefix, even though their prefix lengths are
different, the return value of ipv6_prefix_equal is true.
Here I add a check of whether two addresses have the same prefix
to decide whether their prefixes are equal.
Fixes: 5b84efecb7d9 ("ipv6 addrconf: don't cleanup prefix route for IFA_F_NOPREFIXROUTE")
Signed-off-by: Zhiqiang Liu <liuzhiqiang26@huawei.com>
Reported-by: Wenhao Zhang <zhangwenhao8@huawei.com>
commit 9114daa825fc3f335f9bea3313ce667090187280 upstream.
The caller of ndo_start_xmit may not already have called
skb_reset_mac_header. The returned value of skb_mac_header/eth_hdr
therefore can be in the wrong position and even outside the current skbuff.
This for example happens when the user binds to the device using a
PF_PACKET-SOCK_RAW with enabled qdisc-bypass:
int opt = 4;
setsockopt(sock, SOL_PACKET, PACKET_QDISC_BYPASS, &opt, sizeof(opt));
Since eth_hdr is used all over the codebase, the batadv_interface_tx
function must always take care of resetting it.
Reported-by: syzbot+9d7405c7faa390e60b4e@syzkaller.appspotmail.com
Reported-by: syzbot+7d20bc3f1ddddc0f9079@syzkaller.appspotmail.com
Signed-off-by: Sven Eckelmann <sven@narfation.org>
Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
commit 955d3411a17f590364238bd0d3329b61f20c1cd2 upstream.
It is not allowed to use WARN* helpers on potential incorrect input from
the user or transient problems because systems configured as panic_on_warn
will reboot due to such a problem.
A NULL return value of __dev_get_by_index can be caused by various problems
which can either be related to the system configuration or problems
(incorrectly returned network namespaces) in other (virtual) net_device
drivers. batman-adv should not cause a (harmful) WARN in this situation and
instead only report it via a simple message.
Fixes: b7eddd0b3950 ("batman-adv: prevent using any virtual device created on batman-adv as hard-interface")
Reported-by: syzbot+c764de0fcfadca9a8595@syzkaller.appspotmail.com
commit 35e6103861a3a970de6c84688c6e7a1f65b164ca upstream.
The check assumes that in transport mode, the first templates family
must match the address family of the policy selector.
Syzkaller managed to build a template using MODE_ROUTEOPTIMIZATION,
with ipv4-in-ipv6 chain, leading to following splat:
BUG: KASAN: stack-out-of-bounds in xfrm_state_find+0x1db/0x1854
Read of size 4 at addr ffff888063e57aa0 by task a.out/2050
xfrm_tmpl_resolve+0x100/0x1d0
xfrm_resolve_and_create_bundle+0x108/0x1000 [..]
Problem is that addresses point into flowi4 struct, but xfrm_state_find
treats them as being ipv6 because it uses templ->encap_family is used
(AF_INET6 in case of reproducer) rather than family (AF_INET).
This patch inverts the logic: Enforce 'template family must match
selector' EXCEPT for tunnel and BEET mode.
In BEET and Tunnel mode, xfrm_tmpl_resolve_one will have remote/local
address pointers changed to point at the addresses found in the template,
rather than the flowi ones, so no oob read will occur.
Reported-by: 3ntr0py1337@gmail.com
Reported-by: Daniel Borkmann <daniel@iogearbox.net>
commit 4aac9228d16458cedcfd90c7fb37211cf3653ac3 upstream.
con_fault() can transition the connection into STANDBY right after
ceph_con_keepalive() clears STANDBY in clear_standby():
libceph user thread ceph-msgr worker
mutex_lock(&con->mutex)
clear_standby(con)
mutex_unlock(&con->mutex)
con_fault()
if KEEPALIVE_PENDING isn't set
set state to STANDBY
set KEEPALIVE_PENDING
set WRITE_PENDING
This triggers warnings in clear_standby() when either ceph_con_send()
or ceph_con_keepalive() get to clearing STANDBY next time.
I don't see a reason to condition queue_con() call on the previous
value of KEEPALIVE_PENDING, so move the setting of KEEPALIVE_PENDING
into the critical section -- unlike WRITE_PENDING, KEEPALIVE_PENDING
could have been a non-atomic flag.
Reported-by: syzbot+acdeb633f6211ccdf886@syzkaller.appspotmail.com
Tested-by: Myungho Jung <mhjungk@gmail.com>
commit 9d0f50b80222dc273e67e4e14410fcfa4130a90c upstream.
Some drivers use IEEE80211_KEY_FLAG_SW_MGMT_TX to indicate that management
frames need to be software encrypted. Since normal data packets are still
encrypted by the hardware, crypto_tx_tailroom_needed_cnt gets decremented
after key upload to hw. This can lead to passing skbs to ccmp_encrypt_skb,
which don't have the necessary tailroom for software encryption.
Change the code to add tailroom for encrypted management packets, even if
crypto_tx_tailroom_needed_cnt is 0.
Cc: stable@vger.kernel.org
Signed-off-by: Felix Fietkau <nbd@nbd.name>
