Change-Id: Iccd6dc23522057bae039600ce72017fccbf7febe
This reverts commit 8860020e0be1f03d83dc9e9e93e18a4ddbe01038.
drivers/net/wireless/ath/ath6kl/cfg80211.c
include/linux/nl80211.h
include/net/cfg80211.h
net/wireless/nl80211.c
Change-Id: I4b495d6af3a9c47256aa6e984830dc413ca6631b
Change-Id: Ib3b69ffc5ac3e07c9cc44cc49e9142088eec477e
A new driver is implemented to actively manage the bluetooth module
power. bluesleep also tries to manage the power of the transport used.
Two signals (GPIOs) are used to manage the power events.
BT_WAKE : signal from HOST to BT chip to intimate BT chip can sleep.
HOST_WAKE: signal from BT chip to HOST to intimate HOST should wakeup/
activate the transport modules required for BT communication.
Bug 791669, 773186
(cherry picked from commit 111f4ccd3c4cfde2fa52ae4c0c56a2288c3af3a8)
Original-Change-Id: Iff1e81bb22d9bd43113f7cdd01329da3ae852a15
Reviewed-on: http://git-master/r/19858
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Rebase-Id: R1eca7f2f51475daf6104e71e90ad5db1213fa6ea
arch/arm/common/Kconfig
arch/arm/mm/Makefile
arch/arm/mm/cache-l2x0.c
drivers/misc/Kconfig
drivers/misc/Makefile
drivers/mmc/core/core.c
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Kerin Millar reported hardlockups while running `conntrackd -c'
in a busy firewall. That system (with several processors) was
acting as backup in a primary-backup setup.
After several tries, I found a race condition between the deletion
operation of ctnetlink and timeout expiration. This patch fixes
this problem.
Tested-by: Kerin Millar <kerframil@gmail.com>
Reported-by: Kerin Millar <kerframil@gmail.com>
ip6_mc_find_dev_rcu() is called with rcu_read_lock(), so don't
need to dev_hold().
With dev_hold(), not corresponding dev_put(), will lead to leak.
[ bug introduced in 96b52e61be1 (ipv6: mcast: RCU conversions) ]
Signed-off-by: RongQing.Li <roy.qing.li@gmail.com>
This reverts commit d47a0ac7b6 (sch_sfq: dont put new flow at the end of
flows)
As Jesper found out, patch sounded great but has bad side effects.
In stress situation, pushing new flows in front of the queue can prevent
old flows doing any progress. Packets can stay in SFQ queue for
unlimited amount of time.
It's possible to add heuristics to limit this problem, but this would
add complexity outside of SFQ scope.
A more sensible answer to Dave Taht concerns (who reported the issued I
tried to solve in original commit) is probably to use a qdisc hierarchy
so that high prio packets dont enter a potentially crowded SFQ qdisc.
Reported-by: Jesper Dangaard Brouer <jdb@comx.dk>
Cc: Dave Taht <dave.taht@gmail.com>
commit 87a115783 ( ipv6: Move xfrm_lookup() call down into
icmp6_dst_alloc().) forgot to convert one error path, leading
to crashes in mld_sendpack()
Many thanks to Dave Jones for providing a very complete bug report.
Reported-by: Dave Jones <davej@redhat.com>
commit ea4fc0d619 (ipv4: Don't use rt->rt_{src,dst} in ip_queue_xmit())
added a serious regression on synflood handling.
Simon Kirby discovered a successful connection was delayed by 20 seconds
before being responsive.
In my tests, I discovered that xmit frames were lost, and needed ~4
retransmits and a socket dst rebuild before being really sent.
In case of syncookie initiated connection, we use a different path to
initialize the socket dst, and inet->cork.fl.u.ip4 is left cleared.
As ip_queue_xmit() now depends on inet flow being setup, fix this by
copying the temp flowi4 we use in cookie_v4_check().
Reported-by: Simon Kirby <sim@netnation.com>
Bisected-by: Simon Kirby <sim@netnation.com>
Tested-by: Eric Dumazet <eric.dumazet@gmail.com>
As we invalidate the inetpeer tree along with the routing cache now,
we don't need a genid to reset the redirect handling when the routing
cache is flushed.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
We initialize the routing metrics with the values cached on the
inetpeer in rt_init_metrics(). So if we have the metrics cached on the
inetpeer, we ignore the user configured fib_metrics.
To fix this issue, we replace the old tree with a fresh initialized
inet_peer_base. The old tree is removed later with a delayed work queue.
Now we have:
eth0: link *down*
br0: port 1(eth0) entered *forwarding* state
br_log_state(p) should be called *after* p->state is set
to BR_STATE_DISABLED.
Reported-by: Zilvinas Valinskas <zilvinas@wilibox.com>
Signed-off-by: Paulius Zaleckas <paulius.zaleckas@gmail.com>
Acked-by: Stephen Hemminger <shemminger@vyatta.com>
When br_log_state() is reporting state it should say "entered"
istead of "entering" since state at this point is already
changed.
git://git.kernel.org/pub/scm/linux/kernel/git/jesse/openvswitch
When modifying IP addresses or ports on a UDP packet we don't
correctly follow the rules for unchecksummed packets. This meant
that packets without a checksum can be given a incorrect new checksum
and packets with a checksum can become marked as being unchecksummed.
This fixes it to handle those requirements.
Signed-off-by: Jesse Gross <jesse@nicira.com>
When OVS_VPORT_ATTR_NAME is specified and dp_ifindex is nonzero, the
logical behavior would be for the vport name lookup scope to be limited
to the specified datapath, but in fact the dp_ifindex value was ignored.
This commit causes the search scope to be honored.
Signed-off-by: Ben Pfaff <blp@nicira.com>
When forwarding was set and a new net device is register,
we need add this device to the all-router mcast group.
Signed-off-by: Li Wei <lw@cn.fujitsu.com>
If reliable event delivery is enabled and ctnetlink fails to deliver
the destroy event in early_drop, the conntrack subsystem cannot
drop any the candidate flow that was planned to be evicted.
When net.bridge.bridge-nf-filter-vlan-tagged is 0 (default), vlan packets
arriving should not be sent to ip(6)tables by bridge netfilter.
However, it turns out that we currently always send VLAN packets to
netfilter, if ..
a), CONFIG_VLAN_8021Q is enabled ; or
b), CONFIG_VLAN_8021Q is not set but rx vlan offload is enabled
on the bridge port.
This is because bridge netfilter treats skb with
skb->protocol == ETH_P_IP{V6} as "non-vlan packet".
With rx vlan offload on or CONFIG_VLAN_8021Q=y, the vlan header has
already been removed here, and we cannot rely on skb->protocol alone.
Fix this by only using skb->protocol if the skb has no vlan tag,
or if a vlan tag is present and filter-vlan-tagged bridge netfilter
sysctl is enabled.
We cannot remove the skb->protocol == htons(ETH_P_8021Q) test
because the vlan tag is still around in the CONFIG_VLAN_8021Q=n &&
"ethtool -K $itf rxvlan off" case.
reproducer:
iptables -t raw -I PREROUTING -i br0
iptables -t raw -I PREROUTING -i br0.1
Then send packets to an ip address configured on br0.1 interface.
Even with net.bridge.bridge-nf-filter-vlan-tagged=0, the 1st rule
will match instead of the 2nd one.
With this patch applied, the 2nd rule will match instead.
In the non-local address case, netfilter won't be consulted after
this patch unless the sysctl is switched on.
In adf7ff8, a invalid dereference was added in ebt_make_names.
CC [M] net/bridge/netfilter/ebtables.o
net/bridge/netfilter/ebtables.c: In function `ebt_make_names':
net/bridge/netfilter/ebtables.c:1371:20: warning: `t' may be used uninitialized in this function [-Wuninitialized]
Since 7d367e0, ctnetlink_new_conntrack is called without holding
the nf_conntrack_lock spinlock. Thus, ctnetlink_parse_nat_setup
does not require to release that spinlock anymore in the NAT module
autoload case.
user-space ebtables expects 32 bytes-long names, but xt_match names
use 29 bytes. We have to copy less 29 bytes and then, make sure we
fill the remaining bytes with zeroes.
Signed-off-by: Santosh Nayak <santoshprasadnayak@gmail.com>
This commit fixes tcp_shift_skb_data() so that it does not shift
SACKed data below snd_una.
This fixes an issue whose symptoms exactly match reports showing
tp->sacked_out going negative since 3.3.0-rc4 (see "WARNING: at
net/ipv4/tcp_input.c:3418" thread on netdev).
Since 2008 (832d11c5cd076abc0aa1eaf7be96c81d1a59ce41)
tcp_shift_skb_data() had been shifting SACKed ranges that were below
snd_una. It checked that the *end* of the skb it was about to shift
from was above snd_una, but did not check that the end of the actual
shifted range was above snd_una; this commit adds that check.
Shifting SACKed ranges below snd_una is problematic because for such
ranges tcp_sacktag_one() short-circuits: it does not declare anything
as SACKed and does not increase sacked_out.
Before the fixes in commits cc9a672ee522d4805495b98680f4a3db5d0a0af9
and daef52bab1fd26e24e8e9578f8fb33ba1d0cb412, shifting SACKed ranges
below snd_una happened to work because tcp_shifted_skb() was always
(incorrectly) passing in to tcp_sacktag_one() an skb whose end_seq
tcp_shift_skb_data() had already guaranteed was beyond snd_una. Hence
tcp_sacktag_one() never short-circuited and always increased
tp->sacked_out in this case.
After those two fixes, my testing has verified that shifting SACKed
ranges below snd_una could cause tp->sacked_out to go negative with
the following sequence of events:
(1) tcp_shift_skb_data() sees an skb whose end_seq is beyond snd_una,
then shifts a prefix of that skb that is below snd_una
(2) tcp_shifted_skb() increments the packet count of the
already-SACKed prev sk_buff
(3) tcp_sacktag_one() sees the end of the new SACKed range is below
snd_una, so it short-circuits and doesn't increase tp->sacked_out
(5) tcp_clean_rtx_queue() sees the SACKed skb has been ACKed,
decrements tp->sacked_out by this "inflated" pcount that was
missing a matching increase in tp->sacked_out, and hence
tp->sacked_out underflows to a u32 like 0xFFFFFFFF, which casted
to s32 is negative.
(6) this leads to the warnings seen in the recent "WARNING: at
net/ipv4/tcp_input.c:3418" thread on the netdev list; e.g.:
tcp_input.c:3418 WARN_ON((int)tp->sacked_out < 0);
More generally, I think this bug can be tickled in some cases where
two or more ACKs from the receiver are lost and then a DSACK arrives
that is immediately above an existing SACKed skb in the write queue.
This fix changes tcp_shift_skb_data() to abort this sequence at step
(1) in the scenario above by noticing that the bytes are below snd_una
and not shifting them.
Signed-off-by: Neal Cardwell <ncardwell@google.com>
otherwise source IPv6 address of ICMPV6_MGM_QUERY packet
might be random junk if IPv6 is disabled on interface or
link-local address is not yet ready (DAD).
Signed-off-by: Ulrich Weber <ulrich.weber@sophos.com>
nlmsg_parse() might return an error, so test its return value before
potential random memory accesses.
Errors introduced in commit 115c9b81928 (rtnetlink: Fix problem with
buffer allocation)
Cc: Greg Rose <gregory.v.rose@intel.com>
commit bridge: send proper message_age in config BPDU
added this gem:
bpdu.message_age = (jiffies - root->designated_age)
p->designated_age = jiffies + bpdu->message_age;
Notice how bpdu->message_age is negated when reassigned to
bpdu.message_age. This causes message age to decrease breaking the
STP protocol.
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
min age increment needs to round up its min age tick for all
HZ values to guarantee message age is increasing.
In tcp_mark_head_lost() we should not attempt to fragment a SACKed skb
to mark the first portion as lost. This is for two primary reasons:
(1) tcp_shifted_skb() coalesces adjacent regions of SACKed skbs. When
doing this, it preserves the sum of their packet counts in order to
reflect the real-world dynamics on the wire. But given that skbs can
have remainders that do not align to MSS boundaries, this packet count
preservation means that for SACKed skbs there is not necessarily a
direct linear relationship between tcp_skb_pcount(skb) and
skb->len. Thus tcp_mark_head_lost()'s previous attempts to fragment
off and mark as lost a prefix of length (packets - oldcnt)*mss from
SACKed skbs were leading to occasional failures of the WARN_ON(len >
skb->len) in tcp_fragment() (which used to be a BUG_ON(); see the
recent "crash in tcp_fragment" thread on netdev).
(2) there is no real point in fragmenting off part of a SACKed skb and
calling tcp_skb_mark_lost() on it, since tcp_skb_mark_lost() is a NOP
for SACKed skbs.
Acked-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Acked-by: Yuchung Cheng <ycheng@google.com>
Acked-by: Nandita Dukkipati <nanditad@google.com>
When tcp_shifted_skb() shifts bytes from the skb that is currently
pointed to by 'highest_sack' then the increment of
TCP_SKB_CB(skb)->seq implicitly advances tcp_highest_sack_seq(). This
implicit advancement, combined with the recent fix to pass the correct
SACKed range into tcp_sacktag_one(), caused tcp_sacktag_one() to think
that the newly SACKed range was before the tcp_highest_sack_seq(),
leading to a call to tcp_update_reordering() with a degree of
reordering matching the size of the newly SACKed range (typically just
1 packet, which is a NOP, but potentially larger).
This commit fixes this by simply calling tcp_sacktag_one() before the
TCP_SKB_CB(skb)->seq advancement that can advance our notion of the
highest SACKed sequence.
Correspondingly, we can simplify the code a little now that
tcp_shifted_skb() should update the lost_cnt_hint in all cases where
skb == tp->lost_skb_hint.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
1) ICMP sockets leave err uninitialized but we try to return it for the
unsupported MSG_OOB case, reported by Dave Jones.
2) Add new Zaurus device ID entries, from Dave Jones.
3) Pointer calculation in hso driver memset is wrong, from Dan
Carpenter.
4) ks8851_probe() checks unsigned value as negative, fix also from Dan
Carpenter.
5) Fix crashes in atl1c driver due to TX queue handling, from Eric
Dumazet. I anticipate some TX side locking fixes coming in the near
future for this driver as well.
6) The inline directive fix in Bluetooth which was breaking the build
only with very new versions of GCC, from Johan Hedberg.
7) Fix crashes in the ATP CLIP code due to ARP cleanups this merge
window, reported by Meelis Roos and fixed by Eric Dumazet.
8) JME driver doesn't flush RX FIFO correctly, from Guo-Fu Tseng.
9) Some ip6_route_output() callers test the return value for NULL, but
this never happens as the convention is to return a dst entry with
dst->error set. Fixes from RonQing Li.
10) Logitech Harmony 900 should be handled by zaurus driver not
cdc_ether, update white lists and black lists accordingly. From
Scott Talbert.
11) Receiving from certain kinds of devices there won't be a MAC header,
so there is no MAC header to fixup in the IPSEC code, and if we try
to do it we'll crash. Fix from Eric Dumazet.
12) Port type array indexing off-by-one in mlx4 driver, fix from Yevgeny
Petrilin.
13) Fix regression in link-down handling in davinci_emac which causes
all RX descriptors to be freed up and therefore RX to wedge
completely, from Christian Riesch.
14) It took two attempts, but ctnetlink soft lockups seem to be
cured now, from Pablo Neira Ayuso.
15) Endianness bug fix in ENIC driver, from Santosh Nayak.
16) The long ago conversion of the PPP fragmentation code over to
abstracted SKB list handling wasn't perfect, once we get an
out of sequence SKB we don't flush the rest of them like we
should. From Ben McKeegan.
17) Fix regression of ->ip_summed initialization in sfc driver.
From Ben Hutchings.
18) Bluetooth timeout mistakenly using msecs instead of jiffies,
from Andrzej Kaczmarek.
19) Using _sync variant of work cancellation results in deadlocks,
use the non _sync variants instead. From Andre Guedes.
20) Bluetooth rfcomm code had reference counting problems leading
to crashes, fix from Octavian Purdila.
21) The conversion of netem over to classful qdisc handling added
two bugs to netem_dequeue(), fixes from Eric Dumazet.
22) Missing pci_iounmap() in ATM Solos driver. Fix from Julia Lawall.
23) b44_pci_exit() should not have __exit tag since it's invoked from
non-__exit code. From Nikola Pajkovsky.
24) The conversion of the neighbour hash tables over to RCU added a
race, fixed here by adding the necessary reread of tbl->nht, fix
from Michel Machado.
25) When we added VF (virtual function) attributes for network device
dumps, this potentially bloats up the size of the dump of one
network device such that the dump size is too large for the buffer
allocated by properly written netlink applications.
In particular, if you add 255 VFs to a network device, parts of
GLIBC stop working.
To fix this, we add an attribute that is used to turn on these
extended portions of the network device dump. Sophisticaed
applications like 'ip' that want to see this stuff will be changed
to set the attribute, whereas things like GLIBC that don't care
about VFs simply will not, and therefore won't be busted by the
mere presence of VFs on a network device.
Thanks to the tireless work of Greg Rose on this fix.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (53 commits)
sfc: Fix assignment of ip_summed for pre-allocated skbs
ppp: fix 'ppp_mp_reconstruct bad seq' errors
enic: Fix endianness bug.
gre: fix spelling in comments
netfilter: ctnetlink: fix soft lockup when netlink adds new entries (v2)
Revert "netfilter: ctnetlink: fix soft lockup when netlink adds new entries"
davinci_emac: Do not free all rx dma descriptors during init
mlx4_core: Fixing array indexes when setting port types
phy: IC+101G and PHY_HAS_INTERRUPT flag
netdev/phy/icplus: Correct broken phy_init code
ipsec: be careful of non existing mac headers
Move Logitech Harmony 900 from cdc_ether to zaurus
hso: memsetting wrong data in hso_get_count()
netfilter: ip6_route_output() never returns NULL.
ethernet/broadcom: ip6_route_output() never returns NULL.
ipv6: ip6_route_output() never returns NULL.
jme: Fix FIFO flush issue
atm: clip: remove clip_tbl
ipv4: ping: Fix recvmsg MSG_OOB error handling.
rtnetlink: Fix problem with buffer allocation
We expected 0 if module doesn't exist, which is no longer the case
(42046e2e45c109ba703993c510401a11f716c8df,
netfilter: x_tables: return -ENOENT for non-existant matches/targets).
The original spelling and bad word choice makes these comments hard to read.
Marcell Zambo and Janos Farago noticed and reported that when
new conntrack entries are added via netlink and the conntrack table
gets full, soft lockup happens. This is because the nf_conntrack_lock
is held while nf_conntrack_alloc is called, which is in turn wants
to lock nf_conntrack_lock while evicting entries from the full table.
The patch fixes the soft lockup with limiting the holding of the
nf_conntrack_lock to the minimum, where it's absolutely required.
It required to extend (and thus change) nf_conntrack_hash_insert
so that it makes sure conntrack and ctnetlink do not add the same entry
twice to the conntrack table.
Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
This reverts commit af14cca162ddcdea017b648c21b9b091e4bf1fa4.
This patch contains a race condition between packets and ctnetlink
in the conntrack addition. A new patch to fix this issue follows up.
Niccolo Belli reported ipsec crashes in case we handle a frame without
mac header (atm in his case)
Before copying mac header, better make sure it is present.
Bugzilla reference: https://bugzilla.kernel.org/show_bug.cgi?id=42809
Reported-by: Niccolò Belli <darkbasic@linuxsystems.it>
Tested-by: Niccolò Belli <darkbasic@linuxsystems.it>
ip6_route_output() never returns NULL, so it is wrong to
check if the return value is NULL.
Commit 32092ecf0644 (atm: clip: Use device neigh support on top of
"arp_tbl".) introduced a bug since clip_tbl is zeroed : Crash occurs in
__neigh_for_each_release()
idle_timer_check() must use instead arp_tbl and neigh_check_cb() should
ignore non clip neighbours.
Idea from David Miller.
Reported-by: Meelis Roos <mroos@linux.ee>
Tested-by: Meelis Roos <mroos@linux.ee>
Don't return an uninitialized variable as the error, return
-EOPNOTSUPP instead.
Implement a new netlink attribute type IFLA_EXT_MASK. The mask
is a 32 bit value that can be used to indicate to the kernel that
certain extended ifinfo values are requested by the user application.
At this time the only mask value defined is RTEXT_FILTER_VF to
indicate that the user wants the ifinfo dump to send information
about the VFs belonging to the interface.
This patch fixes a bug in which certain applications do not have
large enough buffers to accommodate the extra information returned
by the kernel with large numbers of SR-IOV virtual functions.
Those applications will not send the new netlink attribute with
the interface info dump request netlink messages so they will
not get unexpectedly large request buffers returned by the kernel.
Modifies the rtnl_calcit function to traverse the list of net
devices and compute the minimum buffer size that can hold the
info dumps of all matching devices based upon the filter passed
in via the new netlink attribute filter mask. If no filter
mask is sent then the buffer allocation defaults to NLMSG_GOODSIZE.
With this change it is possible to add yet to be defined netlink
attributes to the dump request which should make it fairly extensible
in the future.
Signed-off-by: Greg Rose <gregory.v.rose@intel.com>
When the fixed race condition happens:
1. While function neigh_periodic_work scans the neighbor hash table
pointed by field tbl->nht, it unlocks and locks tbl->lock between
buckets in order to call cond_resched.
2. Assume that function neigh_periodic_work calls cond_resched, that is,
the lock tbl->lock is available, and function neigh_hash_grow runs.
3. Once function neigh_hash_grow finishes, and RCU calls
neigh_hash_free_rcu, the original struct neigh_hash_table that function
neigh_periodic_work was using doesn't exist anymore.
4. Once back at neigh_periodic_work, whenever the old struct
neigh_hash_table is accessed, things can go badly.
Signed-off-by: Michel Machado <michel@digirati.com.br>
drivers/mmc/core/sdio.c
drivers/staging/android/Kconfig
drivers/staging/android/lowmemorykiller.c
Change-Id: I39ef9b27bb9febaee811b200ccac0ed5d51147f3
nothing needs to be done for monitor/AP_VLAN mode on calling
ieee80211_bss_info_change_notify -> drv_bss_info_changed with the change
flag 'BSS_CHANGED_IDLE'. 'wl1271' seems to use BSS_CHANGED_IDLE only for
STA and IBSS mode. further the non-idle state of the monitor mode is
taken care by the 'count' variable which counts non-idle interfaces.
ieee80211_idle_off(local, "in use") will be called.
this fixes the following WARNING when we have initially STA mode
(network manager running) and not associated, and change it to monitor
mode with network manager disabled and bringing up the monitor mode.
this changes the idle state from 'true' (STA unassociated) to 'false'
(MONITOR mode)
exposed by the commit 405385f8ce7a2ed8f82e216d88b5282142e1288b
"mac80211: set bss_conf.idle when vif is connected"
WARNING: net/mac80211/main.c:212
ieee80211_bss_info_change_notify+0x1cf/0x330 [mac80211]()
Hardware name: 64756D6
Pid: 3835, comm: ifconfig Tainted: G O
3.3.0-rc3-wl #9
Call Trace:
[<c0133b02>] warn_slowpath_common+0x72/0xa0
[<fc8e8c3f>] ?
[<fc8e8c3f>] ?
[<c0133b52>] warn_slowpath_null+0x22/0x30
[<fc8e8c3f>]
[<fc8f9de3>] __ieee80211_recalc_idle+0x113/0x430
[mac80211]
[<fc8fabc6>] ieee80211_do_open+0x156/0x7e0 [mac80211]
[<fc8f8a25>] ?
ieee80211_check_concurrent_iface+0x25/0x180 [mac80211]
[<c015dd9f>] ? raw_notifier_call_chain+0x1f/0x30
[<fc8fb290>] ieee80211_open+0x40/0x80 [mac80211]
[<c05894f6>] __dev_open+0x96/0xe0
[<c068fba5>] ? _raw_spin_unlock_bh+0x35/0x40
[<c05881d9>] __dev_change_flags+0x109/0x170
[<c0589423>] dev_change_flags+0x23/0x60
[<c05f3770>] devinet_ioctl+0x6a0/0x770
ieee80211 phy0: device no longer idle - in use
Cc: Eliad Peller <eliad@wizery.com>
Signed-off-by: Mohammed Shafi Shajakhan <mohammed@qca.qualcomm.com>
