This is the 5.15.148 stable release
drivers/usb/phy/phy-mxs-usb.c
This is the 5.15.147 stable release
This is the 5.15.146 stable release
This is the 5.15.144 stable release
This is the 5.15.143 stable release
arch/arm64/boot/dts/freescale/imx8mq.dtsi
This is the 5.15.142 stable release
This is the 5.15.141 stable release
This is the 5.15.140 stable release
arch/arm64/boot/dts/freescale/fsl-ls208xa.dtsi
drivers/i3c/master/svc-i3c-master.c
This is the 5.15.139 stable release
drivers/clk/imx/clk-imx8mq.c
Revert the following commits in stable before merging, the sources have
been heavely modified by NXP.
d4c8bf5635c4b rpmsg: Fix possible refcount leak in rpmsg_register_device_override()
a82e0fda8a2f8 rpmsg: glink: Release driver_override
bfd4a664ddfbe rpmsg: Fix calling device_lock() on non-initialized device
2e76b4f6218c4 rpmsg: Fix kfree() of static memory on setting driver_override
5c0da71871d3a rpmsg: Constify local variable in field store macro
drivers/misc/pci_endpoint_test.c
This is the 5.15.137 stable release
This is the 5.15.136 stable release
Documentation/security/keys/trusted-encrypted.rst
security/keys/trusted-keys/trusted_core.c
This is the 5.15.135 stable release
This is the 5.15.134 stable release
This is the 5.15.133 stable release
drivers/perf/fsl_imx8_ddr_perf.c
Used the stable fix
Revert the following commits before merging, the sources have been
5a86ca588b3f9 Revert "perf/imx_ddr: don't enable counter0 if none of 4 counters are used"
56ad67babb7fb Revert "usb: phy: mxs: fix getting wrong state with mxs_phy_is_otg_host()"
50b3a42d82f07 Revert "USB: core: Unite old scheme and new scheme descriptor reads"
cdcf46014f5ca Revert "USB: core: Change usb_get_device_descriptor() API"
2f2af6028f201 Revert "USB: core: Fix race by not overwriting udev->descriptor in hub_port_init()"
9e168d3268f89 Revert "USB: core: Fix oversight in SuperSpeed initialization"
7e95107f9b664 Revert "PCI: dwc: Add start_link/stop_link inlines"
d0bec10a7f796 Revert "PCI: layerscape: Add the endpoint linkup notifier support"
aaf9dc6089bc3 Revert "PCI: layerscape: Add workaround for lost link capabilities during reset"
arch/arm/boot/dts/imx6qdl.dtsi
arch/arm/boot/dts/imx6sx.dtsi
Keep stable node name changes
drivers/gpu/drm/bridge/adv7511/adv7511_drv.c
Keep stable code change
drivers/media/i2c/ov5640.c
commit aabef97a35160461e9c576848ded737558d89055 upstream.
If the ruleset contains consumed quota, restore them accordingly.
Otherwise, listing after restoration shows never used items.
Restore the user-defined quota and flags too.
Fixes: ed0a0c60f0e5 ("netfilter: nft_quota: move stateful fields out of expression data")
commit 860e874290fb3be08e966c9c8ffc510c5b0f2bd8 upstream.
If the ruleset contains last timestamps, restore them accordingly.
Fixes: 33a24de37e81 ("netfilter: nft_last: move stateful fields out of expression data")
commit 558254b0b602b8605d7246a10cfeb584b1fcabfc upstream.
When cloning a packet-based limit expression, copy the cost value as
well. Otherwise the new limit is not functional anymore.
Fixes: 3b9e2ea6c11bf ("netfilter: nft_limit: move stateful fields out of expression data")
Signed-off-by: Phil Sutter <phil@nwl.cc>
commit 1a58f84ea5df7f026bf92a0009f931bf547fe965 upstream.
We need to provide a destroy callback to release the extra fields.
Fixes: 3b9e2ea6c11b ("netfilter: nft_limit: move stateful fields out of expression data")
commit 7d70984a1ad4c445dff08edb9aacce8906b6a222 upstream.
Check if nf_ct_netns_get() fails then release the limit object
previously allocated via kmalloc().
Fixes: 37f319f37d90 ("netfilter: nft_connlimit: move stateful fields out of expression data")
commit 51edb2ff1c6fc27d3fa73f0773a31597ecd8e230 upstream.
This should check for NULL in case memory allocation fails.
Reported-by: Julian Wiedmann <jwiedmann.dev@gmail.com>
Link: https://lore.kernel.org/r/20220110194817.53481-1-pablo@netfilter.org
Signed-off-by: Jakub Kicinski <kuba@kernel.org>
[ Upstream commit 2e7ef287f07c74985f1bf2858bedc62bd9ebf155 ]
idev->mc_ifc_count can be written over without proper locking.
Originally found by syzbot [1], fix this issue by encapsulating calls
to mld_ifc_stop_work() (and mld_gq_stop_work() for good measure) with
mutex_lock() and mutex_unlock() accordingly as these functions
should only be called with mc_lock per their declarations.
[1]
BUG: KCSAN: data-race in ipv6_mc_down / mld_ifc_work
write to 0xffff88813a80c832 of 1 bytes by task 3771 on cpu 0:
mld_ifc_stop_work net/ipv6/mcast.c:1080 [inline]
ipv6_mc_down+0x10a/0x280 net/ipv6/mcast.c:2725
addrconf_ifdown+0xe32/0xf10 net/ipv6/addrconf.c:3949
addrconf_notify+0x310/0x980
notifier_call_chain kernel/notifier.c:93 [inline]
raw_notifier_call_chain+0x6b/0x1c0 kernel/notifier.c:461
__dev_notify_flags+0x205/0x3d0
dev_change_flags+0xab/0xd0 net/core/dev.c:8685
do_setlink+0x9f6/0x2430 net/core/rtnetlink.c:2916
rtnl_group_changelink net/core/rtnetlink.c:3458 [inline]
__rtnl_newlink net/core/rtnetlink.c:3717 [inline]
rtnl_newlink+0xbb3/0x1670 net/core/rtnetlink.c:3754
rtnetlink_rcv_msg+0x807/0x8c0 net/core/rtnetlink.c:6558
netlink_rcv_skb+0x126/0x220 net/netlink/af_netlink.c:2545
rtnetlink_rcv+0x1c/0x20 net/core/rtnetlink.c:6576
netlink_unicast_kernel net/netlink/af_netlink.c:1342 [inline]
netlink_unicast+0x589/0x650 net/netlink/af_netlink.c:1368
netlink_sendmsg+0x66e/0x770 net/netlink/af_netlink.c:1910
write to 0xffff88813a80c832 of 1 bytes by task 22 on cpu 1:
mld_ifc_work+0x54c/0x7b0 net/ipv6/mcast.c:2653
process_one_work kernel/workqueue.c:2627 [inline]
process_scheduled_works+0x5b8/0xa30 kernel/workqueue.c:2700
worker_thread+0x525/0x730 kernel/workqueue.c:2781
Fixes: 2d9a93b4902b ("mld: convert from timer to delayed work")
Reported-by: syzbot+a9400cabb1d784e49abf@syzkaller.appspotmail.com
Link: https://lore.kernel.org/all/000000000000994e09060ebcdffb@google.com/
Signed-off-by: Nikita Zhandarovich <n.zhandarovich@fintech.ru>
Acked-by: Taehee Yoo <ap420073@gmail.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
Reviewed-by: Hangbin Liu <liuhangbin@gmail.com>
Link: https://lore.kernel.org/r/20240117172102.12001-1-n.zhandarovich@fintech.ru
[ Upstream commit f1172f3ee3a98754d95b968968920a7d03fdebcc ]
Accessing an ethernet device that is powered off or clock gated might
cause the CPU to hang. Add ethnl_ops_begin/complete in
ethnl_set_features() to protect against this.
Fixes: 0980bfcd6954 ("ethtool: set netdev features with FEATURES_SET request")
Signed-off-by: Ludvig Pärsson <ludvig.parsson@axis.com>
Link: https://lore.kernel.org/r/20240117-etht2-v2-1-1a96b6e8c650@axis.com
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
[ Upstream commit d6938c1c76c64f42363d0d1f051e1b4641c2ad40 ]
Inside decrement_ttl() upon discovering that the packet ttl has exceeded,
__IP_INC_STATS and __IP6_INC_STATS macros can be called from preemptible
context having the following backtrace:
check_preemption_disabled: 48 callbacks suppressed
BUG: using __this_cpu_add() in preemptible [00000000] code: curl/1177
caller is decrement_ttl+0x217/0x830
CPU: 5 PID: 1177 Comm: curl Not tainted 6.7.0+ #34
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 04/01/2014
Call Trace:
<TASK>
dump_stack_lvl+0xbd/0xe0
check_preemption_disabled+0xd1/0xe0
__ip_vs_get_out_rt+0x4e0/0x1ef0
ip_vs_nat_xmit+0x205/0xcd0
ip_vs_in_hook+0x9b1/0x26a0
nf_hook_slow+0xc2/0x210
nf_hook+0x1fb/0x770
__ip_local_out+0x33b/0x640
ip_local_out+0x2a/0x490
__ip_queue_xmit+0x990/0x1d10
__tcp_transmit_skb+0x288b/0x3d10
tcp_connect+0x3466/0x5180
tcp_v4_connect+0x1535/0x1bb0
__inet_stream_connect+0x40d/0x1040
inet_stream_connect+0x57/0xa0
__sys_connect_file+0x162/0x1a0
__sys_connect+0x137/0x160
__x64_sys_connect+0x72/0xb0
do_syscall_64+0x6f/0x140
entry_SYSCALL_64_after_hwframe+0x6e/0x76
RIP: 0033:0x7fe6dbbc34e0
Use the corresponding preemption-aware variants: IP_INC_STATS and
IP6_INC_STATS.
Found by Linux Verification Center (linuxtesting.org).
Fixes: 8d8e20e2d7bb ("ipvs: Decrement ttl")
Signed-off-by: Fedor Pchelkin <pchelkin@ispras.ru>
Acked-by: Julian Anastasov <ja@ssi.bg>
Acked-by: Simon Horman <horms@kernel.org>
[ Upstream commit 113661e07460a6604aacc8ae1b23695a89e7d4b3 ]
It is still possible to set on the NFT_SET_CONCAT flag by specifying a
set size and no field description, report EINVAL in such case.
Fixes: 1b6345d4160e ("netfilter: nf_tables: check NFT_SET_CONCAT flag if field_count is specified")
[ Upstream commit 6b1ca88e4bb63673dc9f9c7f23c899f22c3cb17a ]
Delete from packet path relies on the garbage collector to purge
elements with NFT_SET_ELEM_DEAD_BIT on.
Skip these dead elements from nf_tables_dump_setelem() path, I very
rarely see tests/shell/testcases/maps/typeof_maps_add_delete reports
[DUMP FAILED] showing a mismatch in the expected output with an element
that should not be there.
If the netlink dump happens before GC worker run, it might show dead
elements in the ruleset listing.
nft_rhash_get() already skips dead elements in nft_rhash_cmp(),
therefore, it already does not show the element when getting a single
element via netlink control plane.
Fixes: 5f68718b34a5 ("netfilter: nf_tables: GC transaction API to avoid race with control plane")
[ Upstream commit 3ce67e3793f48c1b9635beb9bb71116ca1e51b58 ]
The set description provides the size of each field in the set whose sum
should not mismatch the set key length, bail out otherwise.
I did not manage to crash nft_set_pipapo with mismatch fields and set key
length so far, but this is UB which must be disallowed.
Fixes: f3a2181e16f1 ("netfilter: nf_tables: Support for sets with multiple ranged fields")
[ Upstream commit 91a139cee1202a4599a380810d93c69b5bac6197 ]
Bail out if userspace provides unsupported flags, otherwise future
extensions to the limit expression will be silently ignored by the
kernel.
Fixes: c7862a5f0de5 ("netfilter: nft_limit: allow to invert matching criteria")
[ Upstream commit 42193ffd79bd3acd91bd947e53f3548a3661d0a1 ]
nft_*.c files whose NFT_EXPR_STATEFUL flag is set on need to
use __GFP_ACCOUNT flag for objects that are dynamically
allocated from the packet path.
Such objects are allocated inside nft_expr_ops->init() callbacks
executed in task context while processing netlink messages.
In addition, this patch adds accounting to nft_set_elem_expr_clone()
used for the same purposes.
Signed-off-by: Vasily Averin <vvs@openvz.org>
Acked-by: Roman Gushchin <roman.gushchin@linux.dev>
Stable-dep-of: 91a139cee120 ("netfilter: nft_limit: do not ignore unsupported flags")
[ Upstream commit 3b9e2ea6c11bff72ac1d607f6b954e7666b47409 ]
In preparation for the rule blob representation.
[ Upstream commit 369b6cb5d391750fc01ce951c2500281d2975705 ]
From struct nft_limit to nft_limit_priv.
[ Upstream commit ed0a0c60f0e50fa52853620672af97edde3d3a03 ]
[ Upstream commit 33a24de37e814572491bcb35f42c0de74ad67586 ]
[ Upstream commit 37f319f37d9005693dff085bb72852eeebc803ef ]
[ Upstream commit 0617c3de9b4026b87be12b0cb5c35f42c7c66fcb ]
Report -EINVAL in case userspace provides a unsupported set backend
policy.
Fixes: c50b960ccc59 ("netfilter: nf_tables: implement proper set selection")
[ Upstream commit 66ff70df1a919a066942844bb095d6fcb748d78d ]
syzbot reported that subflow_check_req() was using uninitialized data in
subflow_check_req() [1]
This is because mp_opt.token is only set when OPTION_MPTCP_MPJ_SYN is also set.
While we are are it, fix mptcp_subflow_init_cookie_req()
to test for OPTION_MPTCP_MPJ_ACK.
[1]
BUG: KMSAN: uninit-value in subflow_token_join_request net/mptcp/subflow.c:91 [inline]
BUG: KMSAN: uninit-value in subflow_check_req+0x1028/0x15d0 net/mptcp/subflow.c:209
subflow_v6_route_req+0x269/0x410 net/mptcp/subflow.c:367
tcp_conn_request+0x153a/0x4240 net/ipv4/tcp_input.c:7164
subflow_v6_conn_request+0x3ee/0x510
tcp_rcv_state_process+0x2e1/0x4ac0 net/ipv4/tcp_input.c:6659
tcp_v6_do_rcv+0x11bf/0x1fe0 net/ipv6/tcp_ipv6.c:1669
tcp_v6_rcv+0x480b/0x4fb0 net/ipv6/tcp_ipv6.c:1900
ip6_protocol_deliver_rcu+0xda6/0x2a60 net/ipv6/ip6_input.c:438
ip6_input_finish net/ipv6/ip6_input.c:483 [inline]
NF_HOOK include/linux/netfilter.h:314 [inline]
ip6_input+0x15d/0x430 net/ipv6/ip6_input.c:492
dst_input include/net/dst.h:461 [inline]
ip6_rcv_finish+0x5db/0x870 net/ipv6/ip6_input.c:79
ipv6_rcv+0xda/0x390 net/ipv6/ip6_input.c:310
__netif_receive_skb_one_core net/core/dev.c:5532 [inline]
__netif_receive_skb+0x1a6/0x5a0 net/core/dev.c:5646
netif_receive_skb_internal net/core/dev.c:5732 [inline]
netif_receive_skb+0x58/0x660 net/core/dev.c:5791
tun_rx_batched+0x3ee/0x980 drivers/net/tun.c:1555
tun_get_user+0x53af/0x66d0 drivers/net/tun.c:2002
tun_chr_write_iter+0x3af/0x5d0 drivers/net/tun.c:2048
call_write_iter include/linux/fs.h:2020 [inline]
new_sync_write fs/read_write.c:491 [inline]
vfs_write+0x8ef/0x1490 fs/read_write.c:584
ksys_write+0x20f/0x4c0 fs/read_write.c:637
__do_sys_write fs/read_write.c:649 [inline]
__se_sys_write fs/read_write.c:646 [inline]
__x64_sys_write+0x93/0xd0 fs/read_write.c:646
do_syscall_x64 arch/x86/entry/common.c:52 [inline]
do_syscall_64+0x44/0x110 arch/x86/entry/common.c:83
entry_SYSCALL_64_after_hwframe+0x63/0x6b
Local variable mp_opt created at:
subflow_check_req+0x6d/0x15d0 net/mptcp/subflow.c:145
CPU: 1 PID: 5924 Comm: syz-executor.3 Not tainted 6.7.0-rc8-syzkaller-00055-g5eff55d725a4 #0
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 11/17/2023
Fixes: f296234c98a8 ("mptcp: Add handling of incoming MP_JOIN requests")
Reported-by: syzbot <syzkaller@googlegroups.com>
Cc: Florian Westphal <fw@strlen.de>
Cc: Peter Krystad <peter.krystad@linux.intel.com>
Cc: Matthieu Baerts <matttbe@kernel.org>
Cc: Mat Martineau <martineau@kernel.org>
Cc: Geliang Tang <geliang.tang@linux.dev>
Reviewed-by: Simon Horman <horms@kernel.org>
Acked-by: Paolo Abeni <pabeni@redhat.com>
Reviewed-by: Mat Martineau <martineau@kernel.org>
Link: https://lore.kernel.org/r/20240111194917.4044654-5-edumazet@google.com
[ Upstream commit be1d9d9d38da922bd4beeec5b6dd821ff5a1dfeb ]
subflow_finish_connect() uses four fields (backup, join_id, thmac, none)
that may contain garbage unless OPTION_MPTCP_MPJ_SYNACK has been set
in mptcp_parse_option()
Link: https://lore.kernel.org/r/20240111194917.4044654-4-edumazet@google.com
[ Upstream commit c1665273bdc7c201766c65e561c06711f2e050dc ]
mp_opt->hmac contains uninitialized data unless OPTION_MPTCP_MPJ_ACK
was set in mptcp_parse_option().
We must refine the condition before we call subflow_hmac_valid().
Link: https://lore.kernel.org/r/20240111194917.4044654-3-edumazet@google.com
[ Upstream commit 0799e21b5a76d9f14d8a8f024d0b6b9847ad1a03 ]
The parameter 'sk' became useless since the code using it was dropped
from mptcp_get_options() in the commit 8d548ea1dd15 ("mptcp: do not set
unconditionally csum_reqd on incoming opt"). Let's drop it.
Signed-off-by: Geliang Tang <geliang.tang@suse.com>
Signed-off-by: Matthieu Baerts <matthieu.baerts@tessares.net>
Stable-dep-of: c1665273bdc7 ("mptcp: strict validation before using mp_opt->hmac")
[ Upstream commit 89e23277f9c16df6f9f9c1a1a07f8f132339c15c ]
mptcp_parse_option() currently sets OPTIONS_MPTCP_MPJ, for the three
possible cases handled for MPTCPOPT_MP_JOIN option.
OPTIONS_MPTCP_MPJ is the combination of three flags:
- OPTION_MPTCP_MPJ_SYN
- OPTION_MPTCP_MPJ_SYNACK
- OPTION_MPTCP_MPJ_ACK
This is a problem, because backup, join_id, token, nonce and/or hmac fields
could be left uninitialized in some cases.
Distinguish the three cases, as following patches will need this step.
Link: https://lore.kernel.org/r/20240111194917.4044654-2-edumazet@google.com
commit da9065caa594d19b26e1a030fd0cc27bd365d685 upstream.
In min_key_size_set():
if (val > hdev->le_max_key_size || val < SMP_MIN_ENC_KEY_SIZE)
return -EINVAL;
hci_dev_lock(hdev);
hdev->le_min_key_size = val;
hci_dev_unlock(hdev);
In max_key_size_set():
if (val > SMP_MAX_ENC_KEY_SIZE || val < hdev->le_min_key_size)
return -EINVAL;
hci_dev_lock(hdev);
hdev->le_max_key_size = val;
The atomicity violation occurs due to concurrent execution of set_min and
set_max funcs.Consider a scenario where setmin writes a new, valid 'min'
value, and concurrently, setmax writes a value that is greater than the
old 'min' but smaller than the new 'min'. In this case, setmax might check
against the old 'min' value (before acquiring the lock) but write its
value after the 'min' has been updated by setmin. This leads to a
situation where the 'max' value ends up being smaller than the 'min'
value, which is an inconsistency.
This possible bug is found by an experimental static analysis tool
developed by our team, BassCheck[1]. This tool analyzes the locking APIs
to extract function pairs that can be concurrently executed, and then
analyzes the instructions in the paired functions to identify possible
concurrency bugs including data races and atomicity violations. The above
possible bug is reported when our tool analyzes the source code of
Linux 5.17.
To resolve this issue, it is suggested to encompass the validity checks
within the locked sections in both set_min and set_max funcs. The
modification ensures that the validation of 'val' against the
current min/max values is atomic, thus maintaining the integrity of the
settings. With this patch applied, our tool no longer reports the bug,
with the kernel configuration allyesconfig for x86_64. Due to the lack of
associated hardware, we cannot test the patch in runtime testing, and just
verify it according to the code logic.
[1] https://sites.google.com/view/basscheck/
Fixes: 18f81241b74f ("Bluetooth: Move {min,max}_key_size debugfs ...")
Cc: stable@vger.kernel.org
Signed-off-by: Gui-Dong Han <2045gemini@gmail.com>
Signed-off-by: Luiz Augusto von Dentz <luiz.von.dentz@intel.com>
generation
commit b1db244ffd041a49ecc9618e8feb6b5c1afcdaa7 upstream.
When deactivating the catch-all set element, check the state in the next
generation that represents this transaction.
This bug uncovered after the recent removal of the element busy mark
a2dd0233cbc4 ("netfilter: nf_tables: remove busy mark and gc batch API").
Fixes: aaa31047a6d2 ("netfilter: nftables: add catch-all set element support")
Reported-by: lonial con <kongln9170@gmail.com>
commit acc657692aed438e9931438f8c923b2b107aebf9 upstream.
Fix the size check added to dns_resolver_preparse() for the V1 server-list
header so that it doesn't give EINVAL if the size supplied is the same as
the size of the header struct (which should be valid).
This can be tested with:
echo -n -e '\0\0\01\xff\0\0' | keyctl padd dns_resolver desc @p
which will give "add_key: Invalid argument" without this fix.
Fixes: 1997b3cb4217 ("keys, dns: Fix missing size check of V1 server-list header")
Reported-by: Pengfei Xu <pengfei.xu@intel.com>
Link: https://lore.kernel.org/r/ZZ4fyY4r3rqgZL+4@xpf.sh.intel.com/
Cc: Petr Vorel <pvorel@suse.cz>
[ Upstream commit d375b98e0248980681e5e56b712026174d617198 ]
syzbot pointed out [1] that NEXTHDR_FRAGMENT handling is broken.
Reading frag_off can only be done if we pulled enough bytes
to skb->head. Currently we might access garbage.
[1]
BUG: KMSAN: uninit-value in ip6_tnl_parse_tlv_enc_lim+0x94f/0xbb0
ipxip6_tnl_xmit net/ipv6/ip6_tunnel.c:1326 [inline]
ip6_tnl_start_xmit+0xab2/0x1a70 net/ipv6/ip6_tunnel.c:1432
__netdev_start_xmit include/linux/netdevice.h:4940 [inline]
netdev_start_xmit include/linux/netdevice.h:4954 [inline]
xmit_one net/core/dev.c:3548 [inline]
dev_hard_start_xmit+0x247/0xa10 net/core/dev.c:3564
__dev_queue_xmit+0x33b8/0x5130 net/core/dev.c:4349
dev_queue_xmit include/linux/netdevice.h:3134 [inline]
neigh_connected_output+0x569/0x660 net/core/neighbour.c:1592
neigh_output include/net/neighbour.h:542 [inline]
ip6_finish_output2+0x23a9/0x2b30 net/ipv6/ip6_output.c:137
ip6_finish_output+0x855/0x12b0 net/ipv6/ip6_output.c:222
NF_HOOK_COND include/linux/netfilter.h:303 [inline]
ip6_output+0x323/0x610 net/ipv6/ip6_output.c:243
dst_output include/net/dst.h:451 [inline]
ip6_local_out+0xe9/0x140 net/ipv6/output_core.c:155
ip6_send_skb net/ipv6/ip6_output.c:1952 [inline]
ip6_push_pending_frames+0x1f9/0x560 net/ipv6/ip6_output.c:1972
rawv6_push_pending_frames+0xbe8/0xdf0 net/ipv6/raw.c:582
rawv6_sendmsg+0x2b66/0x2e70 net/ipv6/raw.c:920
inet_sendmsg+0x105/0x190 net/ipv4/af_inet.c:847
sock_sendmsg_nosec net/socket.c:730 [inline]
__sock_sendmsg net/socket.c:745 [inline]
____sys_sendmsg+0x9c2/0xd60 net/socket.c:2584
___sys_sendmsg+0x28d/0x3c0 net/socket.c:2638
__sys_sendmsg net/socket.c:2667 [inline]
__do_sys_sendmsg net/socket.c:2676 [inline]
__se_sys_sendmsg net/socket.c:2674 [inline]
__x64_sys_sendmsg+0x307/0x490 net/socket.c:2674
Uninit was created at:
slab_post_alloc_hook+0x129/0xa70 mm/slab.h:768
slab_alloc_node mm/slub.c:3478 [inline]
__kmem_cache_alloc_node+0x5c9/0x970 mm/slub.c:3517
__do_kmalloc_node mm/slab_common.c:1006 [inline]
__kmalloc_node_track_caller+0x118/0x3c0 mm/slab_common.c:1027
kmalloc_reserve+0x249/0x4a0 net/core/skbuff.c:582
pskb_expand_head+0x226/0x1a00 net/core/skbuff.c:2098
__pskb_pull_tail+0x13b/0x2310 net/core/skbuff.c:2655
pskb_may_pull_reason include/linux/skbuff.h:2673 [inline]
pskb_may_pull include/linux/skbuff.h:2681 [inline]
ip6_tnl_parse_tlv_enc_lim+0x901/0xbb0 net/ipv6/ip6_tunnel.c:408
CPU: 0 PID: 7345 Comm: syz-executor.3 Not tainted 6.7.0-rc8-syzkaller-00024-gac865f00af29 #0
Fixes: fbfa743a9d2a ("ipv6: fix ip6_tnl_parse_tlv_enc_lim()")
Cc: Willem de Bruijn <willemb@google.com>
Reviewed-by: Willem de Bruijn <willemb@google.com>
Reviewed-by: David Ahern <dsahern@kernel.org>
[ Upstream commit 3f14b377d01d8357eba032b4cabc8c1149b458b6 ]
act_ct adds skb->users before defragmentation. If frags arrive in order,
the last frag's reference is reset in:
inet_frag_reasm_prepare
skb_morph
which is not straightforward.
However when frags arrive out of order, nobody unref the last frag, and
all frags are leaked. The situation is even worse, as initiating packet
capture can lead to a crash[0] when skb has been cloned and shared at the
same time.
Fix the issue by removing skb_get() before defragmentation. act_ct
returns TC_ACT_CONSUMED when defrag failed or in progress.
[0]:
[ 843.804823] ------------[ cut here ]------------
[ 843.809659] kernel BUG at net/core/skbuff.c:2091!
[ 843.814516] invalid opcode: 0000 [#1] PREEMPT SMP
[ 843.819296] CPU: 7 PID: 0 Comm: swapper/7 Kdump: loaded Tainted: G S 6.7.0-rc3 #2
[ 843.824107] Hardware name: XFUSION 1288H V6/BC13MBSBD, BIOS 1.29 11/25/2022
[ 843.828953] RIP: 0010:pskb_expand_head+0x2ac/0x300
[ 843.833805] Code: 8b 70 28 48 85 f6 74 82 48 83 c6 08 bf 01 00 00 00 e8 38 bd ff ff 8b 83 c0 00 00 00 48 03 83 c8 00 00 00 e9 62 ff ff ff 0f 0b <0f> 0b e8 8d d0 ff ff e9 b3 fd ff ff 81 7c 24 14 40 01 00 00 4c 89
[ 843.843698] RSP: 0018:ffffc9000cce07c0 EFLAGS: 00010202
[ 843.848524] RAX: 0000000000000002 RBX: ffff88811a211d00 RCX: 0000000000000820
[ 843.853299] RDX: 0000000000000640 RSI: 0000000000000000 RDI: ffff88811a211d00
[ 843.857974] RBP: ffff888127d39518 R08: 00000000bee97314 R09: 0000000000000000
[ 843.862584] R10: 0000000000000000 R11: ffff8881109f0000 R12: 0000000000000880
[ 843.867147] R13: ffff888127d39580 R14: 0000000000000640 R15: ffff888170f7b900
[ 843.871680] FS: 0000000000000000(0000) GS:ffff889ffffc0000(0000) knlGS:0000000000000000
[ 843.876242] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 843.880778] CR2: 00007fa42affcfb8 CR3: 000000011433a002 CR4: 0000000000770ef0
[ 843.885336] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 843.889809] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
[ 843.894229] PKRU: 55555554
[ 843.898539] Call Trace:
[ 843.902772] <IRQ>
[ 843.906922] ? __die_body+0x1e/0x60
[ 843.911032] ? die+0x3c/0x60
[ 843.915037] ? do_trap+0xe2/0x110
[ 843.918911] ? pskb_expand_head+0x2ac/0x300
[ 843.922687] ? do_error_trap+0x65/0x80
[ 843.926342] ? pskb_expand_head+0x2ac/0x300
[ 843.929905] ? exc_invalid_op+0x50/0x60
[ 843.933398] ? pskb_expand_head+0x2ac/0x300
[ 843.936835] ? asm_exc_invalid_op+0x1a/0x20
[ 843.940226] ? pskb_expand_head+0x2ac/0x300
[ 843.943580] inet_frag_reasm_prepare+0xd1/0x240
[ 843.946904] ip_defrag+0x5d4/0x870
[ 843.950132] nf_ct_handle_fragments+0xec/0x130 [nf_conntrack]
[ 843.953334] tcf_ct_act+0x252/0xd90 [act_ct]
[ 843.956473] ? tcf_mirred_act+0x516/0x5a0 [act_mirred]
[ 843.959657] tcf_action_exec+0xa1/0x160
[ 843.962823] fl_classify+0x1db/0x1f0 [cls_flower]
[ 843.966010] ? skb_clone+0x53/0xc0
[ 843.969173] tcf_classify+0x24d/0x420
[ 843.972333] tc_run+0x8f/0xf0
[ 843.975465] __netif_receive_skb_core+0x67a/0x1080
[ 843.978634] ? dev_gro_receive+0x249/0x730
[ 843.981759] __netif_receive_skb_list_core+0x12d/0x260
[ 843.984869] netif_receive_skb_list_internal+0x1cb/0x2f0
[ 843.987957] ? mlx5e_handle_rx_cqe_mpwrq_rep+0xfa/0x1a0 [mlx5_core]
[ 843.991170] napi_complete_done+0x72/0x1a0
[ 843.994305] mlx5e_napi_poll+0x28c/0x6d0 [mlx5_core]
[ 843.997501] __napi_poll+0x25/0x1b0
[ 844.000627] net_rx_action+0x256/0x330
[ 844.003705] __do_softirq+0xb3/0x29b
[ 844.006718] irq_exit_rcu+0x9e/0xc0
[ 844.009672] common_interrupt+0x86/0xa0
[ 844.012537] </IRQ>
[ 844.015285] <TASK>
[ 844.017937] asm_common_interrupt+0x26/0x40
[ 844.020591] RIP: 0010:acpi_safe_halt+0x1b/0x20
[ 844.023247] Code: ff 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 40 00 65 48 8b 04 25 00 18 03 00 48 8b 00 a8 08 75 0c 66 90 0f 00 2d 81 d0 44 00 fb f4 <fa> c3 0f 1f 00 89 fa ec 48 8b 05 ee 88 ed 00 a9 00 00 00 80 75 11
[ 844.028900] RSP: 0018:ffffc90000533e70 EFLAGS: 00000246
[ 844.031725] RAX: 0000000000004000 RBX: 0000000000000001 RCX: 0000000000000000
[ 844.034553] RDX: ffff889ffffc0000 RSI: ffffffff828b7f20 RDI: ffff88a090f45c64
[ 844.037368] RBP: ffff88a0901a2800 R08: ffff88a090f45c00 R09: 00000000000317c0
[ 844.040155] R10: 00ec812281150475 R11: ffff889fffff0e04 R12: ffffffff828b7fa0
[ 844.042962] R13: ffffffff828b7f20 R14: 0000000000000001 R15: 0000000000000000
[ 844.045819] acpi_idle_enter+0x7b/0xc0
[ 844.048621] cpuidle_enter_state+0x7f/0x430
[ 844.051451] cpuidle_enter+0x2d/0x40
[ 844.054279] do_idle+0x1d4/0x240
[ 844.057096] cpu_startup_entry+0x2a/0x30
[ 844.059934] start_secondary+0x104/0x130
[ 844.062787] secondary_startup_64_no_verify+0x16b/0x16b
[ 844.065674] </TASK>
Fixes: b57dc7c13ea9 ("net/sched: Introduce action ct")
Signed-off-by: Tao Liu <taoliu828@163.com>
Link: https://lore.kernel.org/r/20231228081457.936732-1-taoliu828@163.com
[ Upstream commit d03376c185926098cb4d668d6458801eb785c0a5 ]
This reverts 19f8def031bfa50c579149b200bfeeb919727b27
"Bluetooth: Fix auth_complete_evt for legacy units" which seems to be
working around a bug on a broken controller rather then any limitation
imposed by the Bluetooth spec, in fact if there ws not possible to
re-auth the command shall fail not succeed.
Fixes: 19f8def031bf ("Bluetooth: Fix auth_complete_evt for legacy units")
[ Upstream commit 08e4c8c5919fd405a4d709b4ba43d836894a26eb ]
If a transaction is aborted, we should mark the to-be-released NEWSET dead,
just like commit path does for DEL and DESTROYSET commands.
In both cases all remaining elements will be released via
set->ops->destroy().
The existing abort code does NOT post the actual release to the work queue.
Also the entire __nf_tables_abort() function is wrapped in gc_seq
begin/end pair.
Therefore, async gc worker will never try to release the pending set
elements, as gc sequence is always stale.
It might be possible to speed up transaction aborts via work queue too,
this would result in a race and a possible use-after-free.
So fix this before it becomes an issue.
[ Upstream commit 93b80887668226180ea5f5349cc728ca6dc700ab ]
Add one more condition for sending credit update during dequeue from
stream socket: when number of bytes in the rx queue is smaller than
SO_RCVLOWAT value of the socket. This is actual for non-default value
of SO_RCVLOWAT (e.g. not 1) - idea is to "kick" peer to continue data
transmission, because we need at least SO_RCVLOWAT bytes in our rx
queue to wake up user for reading data (in corner case it is also
possible to stuck both tx and rx sides, this is why 'Fixes' is used).
Fixes: b89d882dc9fc ("vsock/virtio: reduce credit update messages")
Signed-off-by: Arseniy Krasnov <avkrasnov@salutedevices.com>
Reviewed-by: Stefano Garzarella <sgarzare@redhat.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
[ Upstream commit 3084b58bfd0b9e4b5e034f31f31b42977db35f12 ]
The netlink interface for major and minor version numbers doesn't actually
return the major and minor version numbers.
It reports a u32 that contains the (major, minor, update, alpha1)
components as the major version number, and then alpha2 as the minor
version number.
For whatever reason, the u32 byte order was reversed (ntohl): maybe it was
assumed that the encoded value was a single big-endian u32, and alpha2 was
the minor version.
The correct way to get the supported NC-SI version from the network
controller is to parse the Get Version ID response as described in 8.4.44
of the NC-SI spec[1].
Get Version ID Response Packet Format
Bits
Bytes | 31..24 | 23..16 | 15..8 | 7..0 |
| 0..15 | NC-SI Header |
| 16..19| Response code | Reason code |
|20..23 | Major | Minor | Update | Alpha1 |
|24..27 | reserved | Alpha2 |
| .... other stuff .... |
The major, minor, and update fields are all binary-coded decimal (BCD)
encoded [2]. The spec provides examples below the Get Version ID response
format in section 8.4.44.1, but for practical purposes, this is an example
from a live network card:
root@bmc:~# ncsi-util 0x15
NC-SI Command Response:
cmd: GET_VERSION_ID(0x15)
Response: COMMAND_COMPLETED(0x0000) Reason: NO_ERROR(0x0000)
Payload length = 40
20: 0xf1 0xf1 0xf0 0x00 <<<<<<<<< (major, minor, update, alpha1)
24: 0x00 0x00 0x00 0x00 <<<<<<<<< (_, _, _, alpha2)
28: 0x6d 0x6c 0x78 0x30
32: 0x2e 0x31 0x00 0x00
36: 0x00 0x00 0x00 0x00
40: 0x16 0x1d 0x07 0xd2
44: 0x10 0x1d 0x15 0xb3
48: 0x00 0x17 0x15 0xb3
52: 0x00 0x00 0x81 0x19
This should be parsed as "1.1.0".
"f" in the upper-nibble means to ignore it, contributing zero.
If both nibbles are "f", I think the whole field is supposed to be ignored.
Major and minor are "required", meaning they're not supposed to be "ff",
but the update field is "optional" so I think it can be ff. I think the
simplest thing to do is just set the major and minor to zero instead of
juggling some conditional logic or something.
bcd2bin() from "include/linux/bcd.h" seems to assume both nibbles are 0-9,
so I've provided a custom BCD decoding function.
Alpha1 and alpha2 are ISO/IEC 8859-1 encoded, which just means ASCII
characters as far as I can tell, although the full encoding table for
non-alphabetic characters is slightly different (I think).
I imagine the alpha fields are just supposed to be alphabetic characters,
but I haven't seen any network cards actually report a non-zero value for
either.
If people wrote software against this netlink behavior, and were parsing
the major and minor versions themselves from the u32, then this would
definitely break their code.
[1] https://www.dmtf.org/sites/default/files/standards/documents/DSP0222_1.0.0.pdf
[2] https://en.wikipedia.org/wiki/Binary-coded_decimal
[2] https://en.wikipedia.org/wiki/ISO/IEC_8859-1
Signed-off-by: Peter Delevoryas <peter@pjd.dev>
Fixes: 138635cc27c9 ("net/ncsi: NCSI response packet handler")
