[ Upstream commit 64a8f8f7127da228d59a39e2c5e75f86590f90b4 ]
The value of an arithmetic expression "n * id.data" is subject
to possible overflow due to a failure to cast operands to a larger data
type before performing arithmetic. Used macro for multiplication instead
operator for avoiding overflow.
Found by Linux Verification Center (linuxtesting.org) with SVACE.
Signed-off-by: Maxim Korotkov <korotkov.maxim.s@gmail.com>
Reviewed-by: Alexander Lobakin <alexandr.lobakin@intel.com>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Link: https://lore.kernel.org/r/20221122122901.22294-1-korotkov.maxim.s@gmail.com
Signed-off-by: Jakub Kicinski <kuba@kernel.org>
[ Upstream commit ab0377803dafc58f1e22296708c1c28e309414d6 ]
The caller of del_timer_sync must prevent restarting of the timer, If
we have no this synchronization, there is a small probability that the
cancellation will not be successful.
And syzbot report the fellowing crash:
BUG: KASAN: use-after-free in hlist_add_head include/linux/list.h:929 [inline]
BUG: KASAN: use-after-free in enqueue_timer+0x18/0xa4 kernel/time/timer.c:605
Write at addr f9ff000024df6058 by task syz-fuzzer/2256
Pointer tag: [f9], memory tag: [fe]
CPU: 1 PID: 2256 Comm: syz-fuzzer Not tainted 6.1.0-rc5-syzkaller-00008-
ge01d50cbd6ee #0
Hardware name: linux,dummy-virt (DT)
Call trace:
dump_backtrace.part.0+0xe0/0xf0 arch/arm64/kernel/stacktrace.c:156
dump_backtrace arch/arm64/kernel/stacktrace.c:162 [inline]
show_stack+0x18/0x40 arch/arm64/kernel/stacktrace.c:163
__dump_stack lib/dump_stack.c:88 [inline]
dump_stack_lvl+0x68/0x84 lib/dump_stack.c:106
print_address_description mm/kasan/report.c:284 [inline]
print_report+0x1a8/0x4a0 mm/kasan/report.c:395
kasan_report+0x94/0xb4 mm/kasan/report.c:495
__do_kernel_fault+0x164/0x1e0 arch/arm64/mm/fault.c:320
do_bad_area arch/arm64/mm/fault.c:473 [inline]
do_tag_check_fault+0x78/0x8c arch/arm64/mm/fault.c:749
do_mem_abort+0x44/0x94 arch/arm64/mm/fault.c:825
el1_abort+0x40/0x60 arch/arm64/kernel/entry-common.c:367
el1h_64_sync_handler+0xd8/0xe4 arch/arm64/kernel/entry-common.c:427
el1h_64_sync+0x64/0x68 arch/arm64/kernel/entry.S:576
mod_timer+0x14/0x20 kernel/time/timer.c:1161
mrp_periodic_timer_arm net/802/mrp.c:614 [inline]
mrp_periodic_timer+0xa0/0xc0 net/802/mrp.c:627
call_timer_fn.constprop.0+0x24/0x80 kernel/time/timer.c:1474
expire_timers+0x98/0xc4 kernel/time/timer.c:1519
To fix it, we can introduce a new active flags to make sure the timer will
not restart.
Reported-by: syzbot+6fd64001c20aa99e34a4@syzkaller.appspotmail.com
Signed-off-by: Schspa Shi <schspa@gmail.com>
[ Upstream commit cb34b7cf17ecf33499c9298943f85af247abc1e9 ]
syzbot/KCSAN reported that multiple cpus are updating dev->stats.tx_error
concurrently.
This is because sit tunnels are NETIF_F_LLTX, meaning their ndo_start_xmit()
is not protected by a spinlock.
While original KCSAN report was about tx path, rx path has the same issue.
Reported-by: syzbot <syzkaller@googlegroups.com>
[ Upstream commit 6c1c5097781f563b70a81683ea6fdac21637573b ]
Long standing KCSAN issues are caused by data-race around
some dev->stats changes.
Most performance critical paths already use per-cpu
variables, or per-queue ones.
It is reasonable (and more correct) to use atomic operations
for the slow paths.
This patch adds an union for each field of net_device_stats,
so that we can convert paths that are not yet protected
by a spinlock or a mutex.
netdev_stats_to_stats64() no longer has an #if BITS_PER_LONG==64
Note that the memcpy() we were using on 64bit arches
had no provision to avoid load-tearing,
while atomic_long_read() is providing the needed protection
at no cost.
[ Upstream commit 07ec7b502800ba9f7b8b15cb01dd6556bb41aaca ]
syzkaller managed to trigger another case where skb->len == 0
when we enter __dev_queue_xmit:
WARNING: CPU: 0 PID: 2470 at include/linux/skbuff.h:2576 skb_assert_len include/linux/skbuff.h:2576 [inline]
WARNING: CPU: 0 PID: 2470 at include/linux/skbuff.h:2576 __dev_queue_xmit+0x2069/0x35e0 net/core/dev.c:4295
Call Trace:
dev_queue_xmit+0x17/0x20 net/core/dev.c:4406
__bpf_tx_skb net/core/filter.c:2115 [inline]
__bpf_redirect_no_mac net/core/filter.c:2140 [inline]
__bpf_redirect+0x5fb/0xda0 net/core/filter.c:2163
____bpf_clone_redirect net/core/filter.c:2447 [inline]
bpf_clone_redirect+0x247/0x390 net/core/filter.c:2419
bpf_prog_48159a89cb4a9a16+0x59/0x5e
bpf_dispatcher_nop_func include/linux/bpf.h:897 [inline]
__bpf_prog_run include/linux/filter.h:596 [inline]
bpf_prog_run include/linux/filter.h:603 [inline]
bpf_test_run+0x46c/0x890 net/bpf/test_run.c:402
bpf_prog_test_run_skb+0xbdc/0x14c0 net/bpf/test_run.c:1170
bpf_prog_test_run+0x345/0x3c0 kernel/bpf/syscall.c:3648
__sys_bpf+0x43a/0x6c0 kernel/bpf/syscall.c:5005
__do_sys_bpf kernel/bpf/syscall.c:5091 [inline]
__se_sys_bpf kernel/bpf/syscall.c:5089 [inline]
__x64_sys_bpf+0x7c/0x90 kernel/bpf/syscall.c:5089
do_syscall_64+0x54/0x70 arch/x86/entry/common.c:48
entry_SYSCALL_64_after_hwframe+0x61/0xc6
The reproducer doesn't really reproduce outside of syzkaller
environment, so I'm taking a guess here. It looks like we
do generate correct ETH_HLEN-sized packet, but we redirect
the packet to the tunneling device. Before we do so, we
__skb_pull l2 header and arrive again at skb->len == 0.
Doesn't seem like we can do anything better than having
an explicit check after __skb_pull?
Cc: Eric Dumazet <edumazet@google.com>
Reported-by: syzbot+f635e86ec3fa0a37e019@syzkaller.appspotmail.com
Signed-off-by: Stanislav Fomichev <sdf@google.com>
Link: https://lore.kernel.org/r/20221027225537.353077-1-sdf@google.com
Signed-off-by: Martin KaFai Lau <martin.lau@kernel.org>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
[ Upstream commit e0c8bccd40fc1c19e1d246c39bcf79e357e1ada3 ]
Changheon Lee reported TCP socket leaks, with a nice repro.
It seems we leak TCP sockets with the following sequence:
1) SOF_TIMESTAMPING_TX_ACK is enabled on the socket.
Each ACK will cook an skb put in error queue, from __skb_tstamp_tx().
__skb_tstamp_tx() is using skb_clone(), unless
SOF_TIMESTAMPING_OPT_TSONLY was also requested.
2) If the application is also using MSG_ZEROCOPY, then we put in the
error queue cloned skbs that had a struct ubuf_info attached to them.
Whenever an struct ubuf_info is allocated, sock_zerocopy_alloc()
does a sock_hold().
As long as the cloned skbs are still in sk_error_queue,
socket refcount is kept elevated.
3) Application closes the socket, while error queue is not empty.
Since tcp_close() no longer purges the socket error queue,
we might end up with a TCP socket with at least one skb in
error queue keeping the socket alive forever.
This bug can be (ab)used to consume all kernel memory
and freeze the host.
We need to purge the error queue, with proper synchronization
against concurrent writers.
Fixes: 24bcbe1cc69f ("net: stream: don't purge sk_error_queue in sk_stream_kill_queues()")
Reported-by: Changheon Lee <darklight2357@icloud.com>
[ Upstream commit 4feb2c44629e6f9b459b41a5a60491069d346a95 ]
One of the error paths in rxrpc_do_sendmsg() doesn't unlock the call mutex
before returning. Fix it to do this.
Note that this still doesn't get rid of the checker warning:
../net/rxrpc/sendmsg.c:617:5: warning: context imbalance in 'rxrpc_do_sendmsg' - wrong count at exit
I think the interplay between the socket lock and the call's user_mutex may
be too complicated for checker to analyse, especially as
rxrpc_new_client_call_for_sendmsg(), which it calls, returns with the
call's user_mutex if successful but unconditionally drops the socket lock.
Fixes: e754eba685aa ("rxrpc: Provide a cmsg to specify the amount of Tx data for a call")
cc: Marc Dionne <marc.dionne@auristor.com>
cc: linux-afs@lists.infradead.org
[ Upstream commit 9cd3fd2054c3b3055163accbf2f31a4426f10317 ]
When TCF_EM_SIMPLE was introduced, it is supposed to be convenient
for ematch implementation:
https://lore.kernel.org/all/20050105110048.GO26856@postel.suug.ch/
"You don't have to, providing a 32bit data chunk without TCF_EM_SIMPLE
set will simply result in allocating & copy. It's an optimization,
nothing more."
So if an ematch module provides ops->datalen that means it wants a
complex data structure (saved in its em->data) instead of a simple u32
value. We should simply reject such a combination, otherwise this u32
could be misinterpreted as a pointer.
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Reported-and-tested-by: syzbot+4caeae4c7103813598ae@syzkaller.appspotmail.com
Reported-by: Jun Nie <jun.nie@linaro.org>
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
Cc: Paolo Abeni <pabeni@redhat.com>
Signed-off-by: Cong Wang <cong.wang@bytedance.com>
Acked-by: Paolo Abeni <pabeni@redhat.com>
[ Upstream commit 2d7afdcbc9d32423f177ee12b7c93783aea338fb ]
Extending the tail can have some unexpected side effects if a program uses
a helper like BPF_FUNC_skb_pull_data to read partial content beyond the
head skb headlen when all the skbs in the gso frag_list are linear with no
head_frag -
kernel BUG at net/core/skbuff.c:4219!
pc : skb_segment+0xcf4/0xd2c
lr : skb_segment+0x63c/0xd2c
Call trace:
__udp_gso_segment+0xa4/0x544
udp4_ufo_fragment+0x184/0x1c0
inet_gso_segment+0x16c/0x3a4
skb_mac_gso_segment+0xd4/0x1b0
__skb_gso_segment+0xcc/0x12c
udp_rcv_segment+0x54/0x16c
udp_queue_rcv_skb+0x78/0x144
udp_unicast_rcv_skb+0x8c/0xa4
__udp4_lib_rcv+0x490/0x68c
udp_rcv+0x20/0x30
ip_protocol_deliver_rcu+0x1b0/0x33c
ip_local_deliver+0xd8/0x1f0
ip_rcv+0x98/0x1a4
deliver_ptype_list_skb+0x98/0x1ec
__netif_receive_skb_core+0x978/0xc60
Fix this by marking these skbs as GSO_DODGY so segmentation can handle
the tail updates accordingly.
Fixes: 3dcbdb134f32 ("net: gso: Fix skb_segment splat when splitting gso_size mangled skb having linear-headed frag_list")
Signed-off-by: Sean Tranchetti <quic_stranche@quicinc.com>
Signed-off-by: Subash Abhinov Kasiviswanathan <quic_subashab@quicinc.com>
Reviewed-by: Alexander Duyck <alexanderduyck@fb.com>
Link: https://lore.kernel.org/r/1671084718-24796-1-git-send-email-quic_subashab@quicinc.com
[ Upstream commit 68bb10101e6b0a6bb44e9c908ef795fc4af99eae ]
The commit mentioned below causes the ovs_flow_tbl_lookup() function
to be called with the masked key. However, it's supposed to be called
with the unmasked key. This due to the fact that the datapath supports
installing wider flows, and OVS relies on this behavior. For example
if ipv4(src=1.1.1.1/192.0.0.0, dst=1.1.1.2/192.0.0.0) exists, a wider
flow (smaller mask) of ipv4(src=192.1.1.1/128.0.0.0,dst=192.1.1.2/
128.0.0.0) is allowed to be added.
However, if we try to add a wildcard rule, the installation fails:
$ ovs-appctl dpctl/add-flow system@myDP "in_port(1),eth_type(0x0800), \
ipv4(src=1.1.1.1/192.0.0.0,dst=1.1.1.2/192.0.0.0,frag=no)" 2
ipv4(src=192.1.1.1/0.0.0.0,dst=49.1.1.2/0.0.0.0,frag=no)" 2
ovs-vswitchd: updating flow table (File exists)
The reason is that the key used to determine if the flow is already
present in the system uses the original key ANDed with the mask.
This results in the IP address not being part of the (miniflow) key,
i.e., being substituted with an all-zero value. When doing the actual
lookup, this results in the key wrongfully matching the first flow,
and therefore the flow does not get installed.
This change reverses the commit below, but rather than having the key
on the stack, it's allocated.
Fixes: 190aa3e77880 ("openvswitch: Fix Frame-size larger than 1024 bytes warning.")
Signed-off-by: Eelco Chaudron <echaudro@redhat.com>
[ Upstream commit 3ff8bff704f4de125dca2262e5b5b963a3da1d87 ]
There is a race resulting in alive SOCK_SEQPACKET socket
may change its state from TCP_ESTABLISHED to TCP_CLOSE:
unix_release_sock(peer) unix_dgram_sendmsg(sk)
sock_orphan(peer)
sock_set_flag(peer, SOCK_DEAD)
sock_alloc_send_pskb()
if !(sk->sk_shutdown & SEND_SHUTDOWN)
OK
if sock_flag(peer, SOCK_DEAD)
sk->sk_state = TCP_CLOSE
sk->sk_shutdown = SHUTDOWN_MASK
After that socket sk remains almost normal: it is able to connect, listen, accept
and recvmsg, while it can't sendmsg.
Since this is the only possibility for alive SOCK_SEQPACKET to change
the state in such way, we should better fix this strange and potentially
danger corner case.
Note, that we will return EPIPE here like this is normally done in sock_alloc_send_pskb().
Originally used ECONNREFUSED looks strange, since it's strange to return
a specific retval in dependence of race in kernel, when user can't affect on this.
Also, move TCP_CLOSE assignment for SOCK_DGRAM sockets under state lock
to fix race with unix_dgram_connect():
unix_dgram_connect(other) unix_dgram_sendmsg(sk)
unix_peer(sk) = NULL
unix_state_unlock(sk)
unix_state_double_lock(sk, other)
sk->sk_state = TCP_ESTABLISHED
unix_peer(sk) = other
unix_state_double_unlock(sk, other)
sk->sk_state = TCP_CLOSED
This patch fixes both of these races.
Fixes: 83301b5367a9 ("af_unix: Set TCP_ESTABLISHED for datagram sockets too")
Signed-off-by: Kirill Tkhai <tkhai@ya.ru>
Link: https://lore.kernel.org/r/135fda25-22d5-837a-782b-ceee50e19844@ya.ru
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
[ Upstream commit 5fb45f95eec682621748b7cb012c6a8f0f981e6a ]
The for-loop was broken from the start. It translates to:
for (i = 0; i < 4; i += 4)
which means the loop statement is run only once, so only the highest
32-bit of the IPv6 address gets mangled.
Fix the loop increment.
Fixes: 0e07e25b481a ("netfilter: flowtable: fix NAT IPv6 offload mangling")
Fixes: 5c27d8d76ce8 ("netfilter: nf_flow_table_offload: add IPv6 support")
Signed-off-by: Qingfang DENG <dqfext@gmail.com>
[ Upstream commit e095493091e850d5292ad01d8fbf5cde1d89ac53 ]
If dsa_tag_8021q_setup() fails, for example due to the inability of the
device to install a VLAN, the tag_8021q context of the switch will leak.
Make sure it is freed on the error path.
Fixes: 328621f6131f ("net: dsa: tag_8021q: absorb dsa_8021q_setup into dsa_tag_8021q_{,un}register")
Signed-off-by: Vladimir Oltean <vladimir.oltean@nxp.com>
Link: https://lore.kernel.org/r/20221209235242.480344-1-vladimir.oltean@nxp.com
[ Upstream commit 0ba18967d4544955b2eff2fbc4f2a8750c4df90a ]
It is not allowed to call kfree_skb() from hardware interrupt
context or with interrupts being disabled. So replace kfree_skb()
with dev_kfree_skb_irq() under spin_lock_irqsave().
Fixes: 81be03e026dc ("Bluetooth: RFCOMM: Replace use of memcpy_from_msg with bt_skb_sendmmsg")
Signed-off-by: Yang Yingliang <yangyingliang@huawei.com>
Signed-off-by: Luiz Augusto von Dentz <luiz.von.dentz@intel.com>
[ Upstream commit 39c1eb6fcbae8ce9bb71b2ac5cb609355a2b181b ]
Fixes: 9238f36a5a50 ("Bluetooth: Add request cmd_complete and cmd_status functions")
[ Upstream commit 3b1c7c00b8c22b3cb79532252c59eb0b287bb86d ]
When validating the parameter length for MGMT_OP_ADD_EXT_ADV_PARAMS
command, use the correct op code in error status report:
was MGMT_OP_ADD_ADVERTISING, changed to MGMT_OP_ADD_EXT_ADV_PARAMS.
Fixes: 12410572833a2 ("Bluetooth: Break add adv into two mgmt commands")
Signed-off-by: Inga Stotland <inga.stotland@intel.com>
[ Upstream commit da05cecc4939c0410d56c29e252998b192756318 ]
Recently, a customer reported that from their container whose
net namespace is different to the host's init_net, they can't set
the container's net.sctp.rto_max to any value smaller than
init_net.sctp.rto_min.
For instance,
Host:
sudo sysctl net.sctp.rto_min
net.sctp.rto_min = 1000
Container:
echo 100 > /mnt/proc-net/sctp/rto_min
echo 400 > /mnt/proc-net/sctp/rto_max
echo: write error: Invalid argument
This is caused by the check made from this'commit 4f3fdf3bc59c
("sctp: add check rto_min and rto_max in sysctl")'
When validating the input value, it's always referring the boundary
value set for the init_net namespace.
Having container's rto_max smaller than host's init_net.sctp.rto_min
does make sense. Consider that the rto between two containers on the
same host is very likely smaller than it for two hosts.
So to fix this problem, as suggested by Marcelo, this patch makes the
extra pointers of rto_min, rto_max, pf_retrans, and ps_retrans point
to the corresponding variables from the newly created net namespace while
the new net namespace is being registered in sctp_sysctl_net_register.
Fixes: 4f3fdf3bc59c ("sctp: add check rto_min and rto_max in sysctl")
Reviewed-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Reviewed-by: Jakub Kicinski <kuba@kernel.org>
Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Signed-off-by: Firo Yang <firo.yang@suse.com>
Link: https://lore.kernel.org/r/20221209054854.23889-1-firo.yang@suse.com
[ Upstream commit 73e341e0281a35274629e9be27eae2f9b1b492bf ]
If register unix_stream_proto returns error, unix_dgram_proto needs
be unregistered.
Fixes: 94531cfcbe79 ("af_unix: Add unix_stream_proto for sockmap")
Reviewed-by: Simon Horman <simon.horman@corigine.com>
Reviewed-by: Kuniyuki Iwashima <kuniyu@amazon.com>
[ Upstream commit 3cf7203ca620682165706f70a1b12b5194607dce ]
There is a race condition in vxlan that when deleting a vxlan device
during receiving packets, there is a possibility that the sock is
released after getting vxlan_sock vs from sk_user_data. Then in
later vxlan_ecn_decapsulate(), vxlan_get_sk_family() we will got
NULL pointer dereference. e.g.
#0 [ffffa25ec6978a38] machine_kexec at ffffffff8c669757
#1 [ffffa25ec6978a90] __crash_kexec at ffffffff8c7c0a4d
#2 [ffffa25ec6978b58] crash_kexec at ffffffff8c7c1c48
#3 [ffffa25ec6978b60] oops_end at ffffffff8c627f2b
#4 [ffffa25ec6978b80] page_fault_oops at ffffffff8c678fcb
#5 [ffffa25ec6978bd8] exc_page_fault at ffffffff8d109542
#6 [ffffa25ec6978c00] asm_exc_page_fault at ffffffff8d200b62
[exception RIP: vxlan_ecn_decapsulate+0x3b]
RIP: ffffffffc1014e7b RSP: ffffa25ec6978cb0 RFLAGS: 00010246
RAX: 0000000000000008 RBX: ffff8aa000888000 RCX: 0000000000000000
RDX: 000000000000000e RSI: ffff8a9fc7ab803e RDI: ffff8a9fd1168700
RBP: ffff8a9fc7ab803e R8: 0000000000700000 R9: 00000000000010ae
R10: ffff8a9fcb748980 R11: 0000000000000000 R12: ffff8a9fd1168700
R13: ffff8aa000888000 R14: 00000000002a0000 R15: 00000000000010ae
ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0018
#7 [ffffa25ec6978ce8] vxlan_rcv at ffffffffc10189cd [vxlan]
#8 [ffffa25ec6978d90] udp_queue_rcv_one_skb at ffffffff8cfb6507
#9 [ffffa25ec6978dc0] udp_unicast_rcv_skb at ffffffff8cfb6e45
#10 [ffffa25ec6978dc8] __udp4_lib_rcv at ffffffff8cfb8807
#11 [ffffa25ec6978e20] ip_protocol_deliver_rcu at ffffffff8cf76951
#12 [ffffa25ec6978e48] ip_local_deliver at ffffffff8cf76bde
#13 [ffffa25ec6978ea0] __netif_receive_skb_one_core at ffffffff8cecde9b
#14 [ffffa25ec6978ec8] process_backlog at ffffffff8cece139
#15 [ffffa25ec6978f00] __napi_poll at ffffffff8ceced1a
#16 [ffffa25ec6978f28] net_rx_action at ffffffff8cecf1f3
#17 [ffffa25ec6978fa0] __softirqentry_text_start at ffffffff8d4000ca
#18 [ffffa25ec6978ff0] do_softirq at ffffffff8c6fbdc3
Reproducer: https://github.com/Mellanox/ovs-tests/blob/master/test-ovs-vxlan-remove-tunnel-during-traffic.sh
Fix this by waiting for all sk_user_data reader to finish before
releasing the sock.
Reported-by: Jianlin Shi <jishi@redhat.com>
Suggested-by: Jakub Sitnicki <jakub@cloudflare.com>
Fixes: 6a93cc905274 ("udp-tunnel: Add a few more UDP tunnel APIs")
Signed-off-by: Hangbin Liu <liuhangbin@gmail.com>
Reviewed-by: Jiri Pirko <jiri@nvidia.com>
[ Upstream commit 44aa5a6dba8283bfda28b1517af4de711c5652a4 ]
vmci_transport_dgram_enqueue() does not check the return value
of memcpy_from_msg(). If memcpy_from_msg() fails, it is possible that
uninitialized memory contents are sent unintentionally instead of user's
message in the datagram to the destination. Return with an error if
memcpy_from_msg() fails.
Fixes: 0f7db23a07af ("vmci_transport: switch ->enqeue_dgram, ->enqueue_stream and ->dequeue_stream to msghdr")
Signed-off-by: Artem Chernyshev <artem.chernyshev@red-soft.ru>
Reviewed-by: Stefano Garzarella <sgarzare@redhat.com>
Reviewed-by: Vishnu Dasa <vdasa@vmware.com>
[ Upstream commit 50fa355bc0d75911fe9d5072a5ba52cdb803aff7 ]
socket dynamically created is not released when getting an unintended
address family type in rpc_sockname(), direct to out_release for calling
sock_release().
Fixes: 2e738fdce22f ("SUNRPC: Add API to acquire source address")
Signed-off-by: Wang ShaoBo <bobo.shaobowang@huawei.com>
Signed-off-by: Trond Myklebust <trond.myklebust@hammerspace.com>
[ Upstream commit 9181f40fb2952fd59ecb75e7158620c9c669eee3 ]
If rdma receive buffer allocate failed, should call rpcrdma_regbuf_free()
to free the send buffer, otherwise, the buffer data will be leaked.
Fixes: bb93a1ae2bf4 ("xprtrdma: Allocate req's regbufs at xprt create time")
Signed-off-by: Zhang Xiaoxu <zhangxiaoxu5@huawei.com>
[ Upstream commit 0a182f8d607464911756b4dbef5d6cad8de22469 ]
sock_map_free() calls release_sock(sk) without owning a reference
on the socket. This can cause use-after-free as syzbot found [1]
Jakub Sitnicki already took care of a similar issue
in sock_hash_free() in commit 75e68e5bf2c7 ("bpf, sockhash:
Synchronize delete from bucket list on map free")
[1]
refcount_t: decrement hit 0; leaking memory.
WARNING: CPU: 0 PID: 3785 at lib/refcount.c:31 refcount_warn_saturate+0x17c/0x1a0 lib/refcount.c:31
Modules linked in:
CPU: 0 PID: 3785 Comm: kworker/u4:6 Not tainted 6.1.0-rc7-syzkaller-00103-gef4d3ea40565 #0
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 10/26/2022
Workqueue: events_unbound bpf_map_free_deferred
RIP: 0010:refcount_warn_saturate+0x17c/0x1a0 lib/refcount.c:31
Code: 68 8b 31 c0 e8 75 71 15 fd 0f 0b e9 64 ff ff ff e8 d9 6e 4e fd c6 05 62 9c 3d 0a 01 48 c7 c7 80 bb 68 8b 31 c0 e8 54 71 15 fd <0f> 0b e9 43 ff ff ff 89 d9 80 e1 07 80 c1 03 38 c1 0f 8c a2 fe ff
RSP: 0018:ffffc9000456fb60 EFLAGS: 00010246
RAX: eae59bab72dcd700 RBX: 0000000000000004 RCX: ffff8880207057c0
RDX: 0000000000000000 RSI: 0000000000000201 RDI: 0000000000000000
RBP: 0000000000000004 R08: ffffffff816fdabd R09: fffff520008adee5
R10: fffff520008adee5 R11: 1ffff920008adee4 R12: 0000000000000004
R13: dffffc0000000000 R14: ffff88807b1c6c00 R15: 1ffff1100f638dcf
FS: 0000000000000000(0000) GS:ffff8880b9800000(0000) knlGS:0000000000000000
CR2: 0000001b30c30000 CR3: 000000000d08e000 CR4: 00000000003506f0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
<TASK>
__refcount_dec include/linux/refcount.h:344 [inline]
refcount_dec include/linux/refcount.h:359 [inline]
__sock_put include/net/sock.h:779 [inline]
tcp_release_cb+0x2d0/0x360 net/ipv4/tcp_output.c:1092
release_sock+0xaf/0x1c0 net/core/sock.c:3468
sock_map_free+0x219/0x2c0 net/core/sock_map.c:356
process_one_work+0x81c/0xd10 kernel/workqueue.c:2289
worker_thread+0xb14/0x1330 kernel/workqueue.c:2436
kthread+0x266/0x300 kernel/kthread.c:376
ret_from_fork+0x1f/0x30 arch/x86/entry/entry_64.S:306
</TASK>
Fixes: 7e81a3530206 ("bpf: Sockmap, ensure sock lock held during tear down")
Cc: Jakub Sitnicki <jakub@cloudflare.com>
Cc: John Fastabend <john.fastabend@gmail.com>
Cc: Alexei Starovoitov <ast@kernel.org>
Cc: Daniel Borkmann <daniel@iogearbox.net>
Cc: Song Liu <songliubraving@fb.com>
Acked-by: John Fastabend <john.fastabend@gmail.com>
Link: https://lore.kernel.org/r/20221202111640.2745533-1-edumazet@google.com
[ Upstream commit 5c7aa13210c3abdd34fd421f62347665ec6eb551 ]
hsr_register_frame_out() compares new sequence_nr vs the old one
recorded in hsr_node::seq_out and if the new sequence_nr is higher then
it will be written to hsr_node::seq_out as the new value.
This operation isn't locked so it is possible that two frames with the
same sequence number arrive (via the two slave devices) and are fed to
hsr_register_frame_out() at the same time. Both will pass the check and
update the sequence counter later to the same value. As a result the
content of the same packet is fed into the stack twice.
This was noticed by running ping and observing DUP being reported from
time to time.
Instead of using the hsr_priv::seqnr_lock for the whole receive path (as
it is for sending in the master node) add an additional lock that is only
used for sequence number checks and updates.
Add a per-node lock that is used during sequence number reads and
updates.
Fixes: f421436a591d3 ("net/hsr: Add support for the High-availability Seamless Redundancy protocol (HSRv0)")
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
[ Upstream commit 06afd2c31d338fa762548580c1bf088703dd1e03 ]
Sending frames via the hsr (master) device requires a sequence number
which is tracked in hsr_priv::sequence_nr and protected by
hsr_priv::seqnr_lock. Each time a new frame is sent, it will obtain a
new id and then send it via the slave devices.
Each time a packet is sent (via hsr_forward_do()) the sequence number is
checked via hsr_register_frame_out() to ensure that a frame is not
handled twice. This make sense for the receiving side to ensure that the
frame is not injected into the stack twice after it has been received
from both slave ports.
There is no locking to cover the sending path which means the following
scenario is possible:
CPU0 CPU1
hsr_dev_xmit(skb1) hsr_dev_xmit(skb2)
fill_frame_info() fill_frame_info()
hsr_fill_frame_info() hsr_fill_frame_info()
handle_std_frame() handle_std_frame()
skb1's sequence_nr = 1
skb2's sequence_nr = 2
hsr_forward_do() hsr_forward_do()
hsr_register_frame_out(, 2) // okay, send)
hsr_register_frame_out(, 1) // stop, lower seq duplicate
Both skbs (or their struct hsr_frame_info) received an unique id.
However since skb2 was sent before skb1, the higher sequence number was
recorded in hsr_register_frame_out() and the late arriving skb1 was
dropped and never sent.
This scenario has been observed in a three node HSR setup, with node1 +
node2 having ping and iperf running in parallel. From time to time ping
reported a missing packet. Based on tracing that missing ping packet did
not leave the system.
It might be possible (didn't check) to drop the sequence number check on
the sending side. But if the higher sequence number leaves on wire
before the lower does and the destination receives them in that order
and it will drop the packet with the lower sequence number and never
inject into the stack.
Therefore it seems the only way is to lock the whole path from obtaining
the sequence number and sending via dev_queue_xmit() and assuming the
packets leave on wire in the same order (and don't get reordered by the
NIC).
Cover the whole path for the master interface from obtaining the ID
until after it has been forwarded via hsr_forward_skb() to ensure the
skbs are sent to the NIC in the order of the assigned sequence numbers.
[ Upstream commit d5c7652eb16fa203d82546e0285136d7b321ffa9 ]
The hsr device is a software device. Its
net_device_ops::ndo_start_xmit() routine will process the packet and
then pass the resulting skb to dev_queue_xmit().
During processing, hsr acquires a lock with spin_lock_bh()
(hsr_add_node()) which needs to be promoted to the _irq() suffix in
order to avoid a potential deadlock.
Then there are the warnings in dev_queue_xmit() (due to
local_bh_disable() with disabled interrupts) left.
Instead trying to address those (there is qdisc and…) for netpoll sake,
just disable netpoll on hsr.
Disable netpoll on hsr and replace the _irqsave() locking with _bh().
[ Upstream commit 0c74d9f79ec4299365bbe803baa736ae0068179e ]
Due to the hashed-MAC optimisation one problem become visible:
hsr_handle_sup_frame() walks over the list of available nodes and merges
two node entries into one if based on the information in the supervision
both MAC addresses belong to one node. The list-walk happens on a RCU
protected list and delete operation happens under a lock.
If the supervision arrives on both slave interfaces at the same time
then this delete operation can occur simultaneously on two CPUs. The
result is the first-CPU deletes the from the list and the second CPUs
BUGs while attempting to dereference a poisoned list-entry. This happens
more likely with the optimisation because a new node for the mac_B entry
is created once a packet has been received and removed (merged) once the
supervision frame has been received.
Avoid removing/ cleaning up a hsr_node twice by adding a `removed' field
which is set to true after the removal and checked before the removal.
Fixes: f266a683a4804 ("net/hsr: Better frame dispatch")
[ Upstream commit 5aa2820177af650293b2f9f1873c1f6f8e4ad7a4 ]
hsr_forward_skb() a skb and keeps information in an on-stack
hsr_frame_info. hsr_get_node() assigns hsr_frame_info::node_src which is
from a RCU list. This pointer is used later in hsr_forward_do().
I don't see a reason why this pointer can't vanish midway since there is
no guarantee that hsr_forward_skb() is invoked from an RCU read section.
Use rcu_read_lock() to protect hsr_frame_info::node_src from its
assignment until it is no longer used.
[ Upstream commit 833a9fd28c9b7ccb39a334721379e992dc1c0c89 ]
In regulatory_init_db(), when it's going to return a error, reg_pdev
should be unregistered. When load_builtin_regdb_keys() fails it doesn't
do it and makes cfg80211 can't be reload with report:
sysfs: cannot create duplicate filename '/devices/platform/regulatory.0'
<TASK>
dump_stack_lvl+0x79/0x9b
sysfs_warn_dup.cold+0x1c/0x29
sysfs_create_dir_ns+0x22d/0x290
kobject_add_internal+0x247/0x800
kobject_add+0x135/0x1b0
device_add+0x389/0x1be0
platform_device_add+0x28f/0x790
platform_device_register_full+0x376/0x4b0
regulatory_init+0x9a/0x4b2 [cfg80211]
cfg80211_init+0x84/0x113 [cfg80211]
Fixes: 90a53e4432b1 ("cfg80211: implement regdb signature checking")
Signed-off-by: Chen Zhongjin <chenzhongjin@huawei.com>
Link: https://lore.kernel.org/r/20221109090237.214127-1-chenzhongjin@huawei.com
[ Upstream commit 13e5afd3d773c6fc6ca2b89027befaaaa1ea7293 ]
When register_netdevice() failed in ieee80211_if_add(), ndev->tstats
isn't released. Fix it.
Fixes: 5a490510ba5f ("mac80211: use per-CPU TX/RX statistics")
Signed-off-by: Zhengchao Shao <shaozhengchao@huawei.com>
Link: https://lore.kernel.org/r/20221117064500.319983-1-shaozhengchao@huawei.com
[ Upstream commit 9072931f020bfd907d6d89ee21ff1481cd78b407 ]
Use apply_bytes on ingress redirect, when apply_bytes is less than
the length of msg data, some data may be skipped and lost in
bpf_tcp_ingress().
If there is still data in the scatterlist that has not been consumed,
we cannot move the msg iter.
Fixes: 604326b41a6f ("bpf, sockmap: convert to generic sk_msg interface")
Signed-off-by: Pengcheng Yang <yangpc@wangsu.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Jakub Sitnicki <jakub@cloudflare.com>
Link: https://lore.kernel.org/bpf/1669718441-2654-4-git-send-email-yangpc@wangsu.com
[ Upstream commit a351d6087bf7d3d8440d58d3bf244ec64b89394a ]
When redirecting, we use sk_msg_to_ingress() to get the BPF_F_INGRESS
flag from the msg->flags. If apply_bytes is used and it is larger than
the current data being processed, sk_psock_msg_verdict() will not be
called when sendmsg() is called again. At this time, the msg->flags is 0,
and we lost the BPF_F_INGRESS flag.
So we need to save the BPF_F_INGRESS flag in sk_psock and use it when
redirection.
Fixes: 8934ce2fd081 ("bpf: sockmap redirect ingress support")
Link: https://lore.kernel.org/bpf/1669718441-2654-3-git-send-email-yangpc@wangsu.com
[ Upstream commit 7a9841ca025275b5b0edfb0b618934abb6ceec15 ]
In tcp_bpf_send_verdict() redirection, the eval variable is assigned to
__SK_REDIRECT after the apply_bytes data is sent, if msg has more_data,
sock_put() will be called multiple times.
We should reset the eval variable to __SK_NONE every time more_data
starts.
This causes:
IPv4: Attempt to release TCP socket in state 1 00000000b4c925d7
refcount_t: addition on 0; use-after-free.
WARNING: CPU: 5 PID: 4482 at lib/refcount.c:25 refcount_warn_saturate+0x7d/0x110
Modules linked in:
CPU: 5 PID: 4482 Comm: sockhash_bypass Kdump: loaded Not tainted 6.0.0 #1
Hardware name: Red Hat KVM, BIOS 1.11.0-2.el7 04/01/2014
Call Trace:
<TASK>
__tcp_transmit_skb+0xa1b/0xb90
? __alloc_skb+0x8c/0x1a0
? __kmalloc_node_track_caller+0x184/0x320
tcp_write_xmit+0x22a/0x1110
__tcp_push_pending_frames+0x32/0xf0
do_tcp_sendpages+0x62d/0x640
tcp_bpf_push+0xae/0x2c0
tcp_bpf_sendmsg_redir+0x260/0x410
? preempt_count_add+0x70/0xa0
tcp_bpf_send_verdict+0x386/0x4b0
tcp_bpf_sendmsg+0x21b/0x3b0
sock_sendmsg+0x58/0x70
__sys_sendto+0xfa/0x170
? xfd_validate_state+0x1d/0x80
? switch_fpu_return+0x59/0xe0
__x64_sys_sendto+0x24/0x30
do_syscall_64+0x37/0x90
entry_SYSCALL_64_after_hwframe+0x63/0xcd
Fixes: cd9733f5d75c ("tcp_bpf: Fix one concurrency problem in the tcp_bpf_send_verdict function")
Link: https://lore.kernel.org/bpf/1669718441-2654-2-git-send-email-yangpc@wangsu.com
[ Upstream commit 7d7cfb48d81353e826493d24c7cec7360950968f ]
icmp conntrack will set icmp redirects as RELATED, but icmpv6 will not
do this.
For icmpv6, only icmp errors (code <= 128) are examined for RELATED state.
ICMPV6 Redirects are part of neighbour discovery mechanism, those are
handled by marking a selected subset (e.g. neighbour solicitations) as
UNTRACKED, but not REDIRECT -- they will thus be flagged as INVALID.
Add minimal support for REDIRECTs. No parsing of neighbour options is
added for simplicity, so this will only check that we have the embeeded
original header (ND_OPT_REDIRECT_HDR), and then attempt to do a flow
lookup for this tuple.
Also extend the existing test case to cover redirects.
Fixes: 9fb9cbb1082d ("[NETFILTER]: Add nf_conntrack subsystem.")
Reported-by: Eric Garver <eric@garver.life>
Link: https://github.com/firewalld/firewalld/issues/1046
Acked-by: Eric Garver <eric@garver.life>
[ Upstream commit 114039b342014680911c35bd6b72624180fd669a ]
To avoid potentially breaking existing users.
Both mac/no-mac cases have to be amended; mac_header >= network_header
is not enough (verified with a new test, see next patch).
Fixes: fd1894224407 ("bpf: Don't redirect packets with invalid pkt_len")
Link: https://lore.kernel.org/r/20221121180340.1983627-1-sdf@google.com
[ Upstream commit d2c135619cb89d1d5693df81ab408c5e8e97e898 ]
inet_csk_bind_conflict() can access sk->sk_bound_dev_if for
unlocked sockets.
[ Upstream commit 8889a711f9b4dcf4dd1330fa493081beebd118c9 ]
ack.bufferSize should be set to 0 when generating an ack.
Fixes: 8d94aa381dab ("rxrpc: Calls shouldn't hold socket refs")
Reported-by: Jeffrey Altman <jaltman@auristor.com>
[ Upstream commit b261eda84ec136240a9ca753389853a3a1bccca2 ]
Kazuho Oku reported that setsockopt(SO_INCOMING_CPU) does not work
with setsockopt(SO_REUSEPORT) since v4.6.
With the combination of SO_REUSEPORT and SO_INCOMING_CPU, we could
build a highly efficient server application.
setsockopt(SO_INCOMING_CPU) associates a CPU with a TCP listener
or UDP socket, and then incoming packets processed on the CPU will
likely be distributed to the socket. Technically, a socket could
even receive packets handled on another CPU if no sockets in the
reuseport group have the same CPU receiving the flow.
The logic exists in compute_score() so that a socket will get a higher
score if it has the same CPU with the flow. However, the score gets
ignored after the blamed two commits, which introduced a faster socket
selection algorithm for SO_REUSEPORT.
This patch introduces a counter of sockets with SO_INCOMING_CPU in
a reuseport group to check if we should iterate all sockets to find
a proper one. We increment the counter when
* calling listen() if the socket has SO_INCOMING_CPU and SO_REUSEPORT
* enabling SO_INCOMING_CPU if the socket is in a reuseport group
Also, we decrement it when
* detaching a socket out of the group to apply SO_INCOMING_CPU to
migrated TCP requests
* disabling SO_INCOMING_CPU if the socket is in a reuseport group
When the counter reaches 0, we can get back to the O(1) selection
algorithm.
The overall changes are negligible for the non-SO_INCOMING_CPU case,
and the only notable thing is that we have to update sk_incomnig_cpu
under reuseport_lock. Otherwise, the race prevents transitioning to
the O(n) algorithm and results in the wrong socket selection.
cpu1 (setsockopt) cpu2 (listen)
lock_sock(sk1) lock_sock(sk2)
reuseport_update_incoming_cpu(sk1, val)
| /* set CPU as 0 */
|- WRITE_ONCE(sk1->incoming_cpu, val)
| spin_lock_bh(&reuseport_lock)
| reuseport_grow(sk2, reuse)
| |- more_socks_size = reuse->max_socks * 2U;
| |- if (more_socks_size > U16_MAX &&
| | reuse->num_closed_socks)
| | |- RCU_INIT_POINTER(sk1->sk_reuseport_cb, NULL);
| | `- __reuseport_detach_closed_sock(sk1, reuse)
| | `- reuseport_put_incoming_cpu(sk1, reuse)
| | | /* Read shutdown()ed sk1's sk_incoming_cpu
| | | * without lock_sock().
| | `- if (sk1->sk_incoming_cpu >= 0)
| | | /* decrement not-yet-incremented
| | | * count, which is never incremented.
| | `- __reuseport_put_incoming_cpu(reuse);
| `- spin_lock_bh(&reuseport_lock)
|- reuse = rcu_dereference_protected(sk1->sk_reuseport_cb, ...)
|- if (!reuse)
| | /* Cannot increment reuse->incoming_cpu. */
| `- goto out;
`- spin_unlock_bh(&reuseport_lock)
Fixes: e32ea7e74727 ("soreuseport: fast reuseport UDP socket selection")
Fixes: c125e80b8868 ("soreuseport: fast reuseport TCP socket selection")
Reported-by: Kazuho Oku <kazuhooku@gmail.com>
Signed-off-by: Kuniyuki Iwashima <kuniyu@amazon.com>
[ Upstream commit bcd70260ef56e0aee8a4fc6cd214a419900b0765 ]
By keep sending L2CAP_CONF_REQ packets, chan->num_conf_rsp increases
multiple times and eventually it will wrap around the maximum number
(i.e., 255).
This patch prevents this by adding a boundary check with
L2CAP_MAX_CONF_RSP
Btmon log:
Bluetooth monitor ver 5.64
= Note: Linux version 6.1.0-rc2 (x86_64) 0.264594
= Note: Bluetooth subsystem version 2.22 0.264636
@ MGMT Open: btmon (privileged) version 1.22 {0x0001} 0.272191
= New Index: 00:00:00:00:00:00 (Primary,Virtual,hci0) [hci0] 13.877604
@ RAW Open: 9496 (privileged) version 2.22 {0x0002} 13.890741
= Open Index: 00:00:00:00:00:00 [hci0] 13.900426
> ACL Data RX: Handle 200 flags 0x00 dlen 1033 #32 [hci0] 14.273106
invalid packet size (12 != 1033)
08 00 01 00 02 01 04 00 01 10 ff ff ............
> ACL Data RX: Handle 200 flags 0x00 dlen 1547 #33 [hci0] 14.273561
invalid packet size (14 != 1547)
0a 00 01 00 04 01 06 00 40 00 00 00 00 00 ........@.....
> ACL Data RX: Handle 200 flags 0x00 dlen 2061 #34 [hci0] 14.274390
invalid packet size (16 != 2061)
0c 00 01 00 04 01 08 00 40 00 00 00 00 00 00 04 ........@.......
> ACL Data RX: Handle 200 flags 0x00 dlen 2061 #35 [hci0] 14.274932
0c 00 01 00 04 01 08 00 40 00 00 00 07 00 03 00 ........@.......
= bluetoothd: Bluetooth daemon 5.43 14.401828
> ACL Data RX: Handle 200 flags 0x00 dlen 1033 #36 [hci0] 14.275753
08 00 01 00 04 01 04 00 40 00 00 00 ........@...
Signed-off-by: Sungwoo Kim <iam@sung-woo.kim>
[ Upstream commit 803e84867de59a1e5d126666d25eb4860cfd2ebe ]
Blamed commit claimed rcu_read_lock() was held by ip6_fragment() callers.
It seems to not be always true, at least for UDP stack.
syzbot reported:
BUG: KASAN: use-after-free in ip6_dst_idev include/net/ip6_fib.h:245 [inline]
BUG: KASAN: use-after-free in ip6_fragment+0x2724/0x2770 net/ipv6/ip6_output.c:951
Read of size 8 at addr ffff88801d403e80 by task syz-executor.3/7618
CPU: 1 PID: 7618 Comm: syz-executor.3 Not tainted 6.1.0-rc6-syzkaller-00012-g4312098baf37 #0
Call Trace:
<TASK>
dump_stack_lvl+0xd1/0x138 lib/dump_stack.c:106
print_report+0x15e/0x45d mm/kasan/report.c:395
kasan_report+0xbf/0x1f0 mm/kasan/report.c:495
__ip6_finish_output net/ipv6/ip6_output.c:193 [inline]
ip6_finish_output+0x9a3/0x1170 net/ipv6/ip6_output.c:206
NF_HOOK_COND include/linux/netfilter.h:291 [inline]
ip6_output+0x1f1/0x540 net/ipv6/ip6_output.c:227
dst_output include/net/dst.h:445 [inline]
ip6_local_out+0xb3/0x1a0 net/ipv6/output_core.c:161
ip6_send_skb+0xbb/0x340 net/ipv6/ip6_output.c:1966
udp_v6_send_skb+0x82a/0x18a0 net/ipv6/udp.c:1286
udp_v6_push_pending_frames+0x140/0x200 net/ipv6/udp.c:1313
udpv6_sendmsg+0x18da/0x2c80 net/ipv6/udp.c:1606
inet6_sendmsg+0x9d/0xe0 net/ipv6/af_inet6.c:665
sock_sendmsg_nosec net/socket.c:714 [inline]
sock_sendmsg+0xd3/0x120 net/socket.c:734
sock_write_iter+0x295/0x3d0 net/socket.c:1108
call_write_iter include/linux/fs.h:2191 [inline]
new_sync_write fs/read_write.c:491 [inline]
vfs_write+0x9ed/0xdd0 fs/read_write.c:584
ksys_write+0x1ec/0x250 fs/read_write.c:637
do_syscall_x64 arch/x86/entry/common.c:50 [inline]
do_syscall_64+0x39/0xb0 arch/x86/entry/common.c:80
RIP: 0033:0x7fde3588c0d9
Code: 28 00 00 00 75 05 48 83 c4 28 c3 e8 f1 19 00 00 90 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 c7 c1 b8 ff ff ff f7 d8 64 89 01 48
RSP: 002b:00007fde365b6168 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
RAX: ffffffffffffffda RBX: 00007fde359ac050 RCX: 00007fde3588c0d9
RDX: 000000000000ffdc RSI: 00000000200000c0 RDI: 000000000000000a
RBP: 00007fde358e7ae9 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000000
R13: 00007fde35acfb1f R14: 00007fde365b6300 R15: 0000000000022000
</TASK>
Allocated by task 7618:
kasan_save_stack+0x22/0x40 mm/kasan/common.c:45
kasan_set_track+0x25/0x30 mm/kasan/common.c:52
__kasan_slab_alloc+0x82/0x90 mm/kasan/common.c:325
kasan_slab_alloc include/linux/kasan.h:201 [inline]
slab_post_alloc_hook mm/slab.h:737 [inline]
slab_alloc_node mm/slub.c:3398 [inline]
slab_alloc mm/slub.c:3406 [inline]
__kmem_cache_alloc_lru mm/slub.c:3413 [inline]
kmem_cache_alloc+0x2b4/0x3d0 mm/slub.c:3422
dst_alloc+0x14a/0x1f0 net/core/dst.c:92
ip6_dst_alloc+0x32/0xa0 net/ipv6/route.c:344
ip6_rt_pcpu_alloc net/ipv6/route.c:1369 [inline]
rt6_make_pcpu_route net/ipv6/route.c:1417 [inline]
ip6_pol_route+0x901/0x1190 net/ipv6/route.c:2254
pol_lookup_func include/net/ip6_fib.h:582 [inline]
fib6_rule_lookup+0x52e/0x6f0 net/ipv6/fib6_rules.c:121
ip6_route_output_flags_noref+0x2e6/0x380 net/ipv6/route.c:2625
ip6_route_output_flags+0x76/0x320 net/ipv6/route.c:2638
ip6_route_output include/net/ip6_route.h:98 [inline]
ip6_dst_lookup_tail+0x5ab/0x1620 net/ipv6/ip6_output.c:1092
ip6_dst_lookup_flow+0x90/0x1d0 net/ipv6/ip6_output.c:1222
ip6_sk_dst_lookup_flow+0x553/0x980 net/ipv6/ip6_output.c:1260
udpv6_sendmsg+0x151d/0x2c80 net/ipv6/udp.c:1554
__sys_sendto+0x23a/0x340 net/socket.c:2117
__do_sys_sendto net/socket.c:2129 [inline]
__se_sys_sendto net/socket.c:2125 [inline]
__x64_sys_sendto+0xe1/0x1b0 net/socket.c:2125
Freed by task 7599:
kasan_save_free_info+0x2e/0x40 mm/kasan/generic.c:511
____kasan_slab_free mm/kasan/common.c:236 [inline]
____kasan_slab_free+0x160/0x1c0 mm/kasan/common.c:200
kasan_slab_free include/linux/kasan.h:177 [inline]
slab_free_hook mm/slub.c:1724 [inline]
slab_free_freelist_hook+0x8b/0x1c0 mm/slub.c:1750
slab_free mm/slub.c:3661 [inline]
kmem_cache_free+0xee/0x5c0 mm/slub.c:3683
dst_destroy+0x2ea/0x400 net/core/dst.c:127
rcu_do_batch kernel/rcu/tree.c:2250 [inline]
rcu_core+0x81f/0x1980 kernel/rcu/tree.c:2510
__do_softirq+0x1fb/0xadc kernel/softirq.c:571
Last potentially related work creation:
__kasan_record_aux_stack+0xbc/0xd0 mm/kasan/generic.c:481
call_rcu+0x9d/0x820 kernel/rcu/tree.c:2798
dst_release net/core/dst.c:177 [inline]
dst_release+0x7d/0xe0 net/core/dst.c:167
refdst_drop include/net/dst.h:256 [inline]
skb_dst_drop include/net/dst.h:268 [inline]
skb_release_head_state+0x250/0x2a0 net/core/skbuff.c:838
skb_release_all net/core/skbuff.c:852 [inline]
__kfree_skb net/core/skbuff.c:868 [inline]
kfree_skb_reason+0x151/0x4b0 net/core/skbuff.c:891
kfree_skb_list_reason+0x4b/0x70 net/core/skbuff.c:901
kfree_skb_list include/linux/skbuff.h:1227 [inline]
ip6_fragment+0x2026/0x2770 net/ipv6/ip6_output.c:949
Second to last potentially related work creation:
__dev_queue_xmit+0x1b9d/0x3ba0 net/core/dev.c:4211
dev_queue_xmit include/linux/netdevice.h:3008 [inline]
neigh_resolve_output net/core/neighbour.c:1552 [inline]
neigh_resolve_output+0x51b/0x840 net/core/neighbour.c:1532
neigh_output include/net/neighbour.h:546 [inline]
ip6_finish_output2+0x56c/0x1530 net/ipv6/ip6_output.c:134
__ip6_finish_output net/ipv6/ip6_output.c:195 [inline]
ip6_finish_output+0x694/0x1170 net/ipv6/ip6_output.c:206
NF_HOOK include/linux/netfilter.h:302 [inline]
NF_HOOK include/linux/netfilter.h:296 [inline]
mld_sendpack+0xa09/0xe70 net/ipv6/mcast.c:1820
mld_send_cr net/ipv6/mcast.c:2121 [inline]
mld_ifc_work+0x720/0xdc0 net/ipv6/mcast.c:2653
process_one_work+0x9bf/0x1710 kernel/workqueue.c:2289
worker_thread+0x669/0x1090 kernel/workqueue.c:2436
kthread+0x2e8/0x3a0 kernel/kthread.c:376
The buggy address belongs to the object at ffff88801d403dc0
which belongs to the cache ip6_dst_cache of size 240
The buggy address is located 192 bytes inside of
240-byte region [ffff88801d403dc0, ffff88801d403eb0)
The buggy address belongs to the physical page:
page:ffffea00007500c0 refcount:1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x1d403
memcg:ffff888022f49c81
flags: 0xfff00000000200(slab|node=0|zone=1|lastcpupid=0x7ff)
raw: 00fff00000000200 ffffea0001ef6580 dead000000000002 ffff88814addf640
raw: 0000000000000000 00000000800c000c 00000001ffffffff ffff888022f49c81
page dumped because: kasan: bad access detected
page_owner tracks the page as allocated
page last allocated via order 0, migratetype Unmovable, gfp_mask 0x112a20(GFP_ATOMIC|__GFP_NOWARN|__GFP_NORETRY|__GFP_HARDWALL), pid 3719, tgid 3719 (kworker/0:6), ts 136223432244, free_ts 136222971441
prep_new_page mm/page_alloc.c:2539 [inline]
get_page_from_freelist+0x10b5/0x2d50 mm/page_alloc.c:4288
__alloc_pages+0x1cb/0x5b0 mm/page_alloc.c:5555
alloc_pages+0x1aa/0x270 mm/mempolicy.c:2285
alloc_slab_page mm/slub.c:1794 [inline]
allocate_slab+0x213/0x300 mm/slub.c:1939
new_slab mm/slub.c:1992 [inline]
___slab_alloc+0xa91/0x1400 mm/slub.c:3180
__slab_alloc.constprop.0+0x56/0xa0 mm/slub.c:3279
slab_alloc_node mm/slub.c:3364 [inline]
kmem_cache_alloc+0x31a/0x3d0 mm/slub.c:3422
icmp6_dst_alloc+0x71/0x680 net/ipv6/route.c:3261
mld_sendpack+0x5de/0xe70 net/ipv6/mcast.c:1809
page last free stack trace:
reset_page_owner include/linux/page_owner.h:24 [inline]
free_pages_prepare mm/page_alloc.c:1459 [inline]
free_pcp_prepare+0x65c/0xd90 mm/page_alloc.c:1509
free_unref_page_prepare mm/page_alloc.c:3387 [inline]
free_unref_page+0x1d/0x4d0 mm/page_alloc.c:3483
__unfreeze_partials+0x17c/0x1a0 mm/slub.c:2586
qlink_free mm/kasan/quarantine.c:168 [inline]
qlist_free_all+0x6a/0x170 mm/kasan/quarantine.c:187
kasan_quarantine_reduce+0x184/0x210 mm/kasan/quarantine.c:294
__kasan_slab_alloc+0x66/0x90 mm/kasan/common.c:302
kmem_cache_alloc_node+0x304/0x410 mm/slub.c:3443
__alloc_skb+0x214/0x300 net/core/skbuff.c:497
alloc_skb include/linux/skbuff.h:1267 [inline]
netlink_alloc_large_skb net/netlink/af_netlink.c:1191 [inline]
netlink_sendmsg+0x9a6/0xe10 net/netlink/af_netlink.c:1896
Fixes: 1758fd4688eb ("ipv6: remove unnecessary dst_hold() in ip6_fragment()")
Reported-by: syzbot+8c0ac31aa9681abb9e2d@syzkaller.appspotmail.com
Cc: Wei Wang <weiwan@google.com>
Cc: Martin KaFai Lau <kafai@fb.com>
Link: https://lore.kernel.org/r/20221206101351.2037285-1-edumazet@google.com
[ Upstream commit 88956177db179e4eba7cd590971961857d1565b8 ]
When sending packets between nodes in netns, it calls tipc_lxc_xmit() for
peer node to receive the packets where tipc_sk_mcast_rcv()/tipc_sk_rcv()
might be called, and it's pretty much like in tipc_rcv().
Currently the local 'node rw lock' is held during calling tipc_lxc_xmit()
to protect the peer_net not being freed by another thread. However, when
receiving these packets, tipc_node_add_conn() might be called where the
peer 'node rw lock' is acquired. Then a dead lock warning is triggered by
lockdep detector, although it is not a real dead lock:
WARNING: possible recursive locking detected
conn_server/1086 is trying to acquire lock:
ffff8880065cb020 (&n->lock#2){++--}-{2:2}, \
at: tipc_node_add_conn.cold.76+0xaa/0x211 [tipc]
but task is already holding lock:
ffff8880065cd020 (&n->lock#2){++--}-{2:2}, \
at: tipc_node_xmit+0x285/0xb30 [tipc]
Possible unsafe locking scenario:
CPU0
lock(&n->lock#2);
lock(&n->lock#2);
*** DEADLOCK ***
May be due to missing lock nesting notation
4 locks held by conn_server/1086:
#0: ffff8880036d1e40 (sk_lock-AF_TIPC){+.+.}-{0:0}, \
at: tipc_accept+0x9c0/0x10b0 [tipc]
#1: ffff8880036d5f80 (sk_lock-AF_TIPC/1){+.+.}-{0:0}, \
at: tipc_accept+0x363/0x10b0 [tipc]
#2: ffff8880065cd020 (&n->lock#2){++--}-{2:2}, \
#3: ffff888012e13370 (slock-AF_TIPC){+...}-{2:2}, \
at: tipc_sk_rcv+0x2da/0x1b40 [tipc]
Call Trace:
<TASK>
dump_stack_lvl+0x44/0x5b
__lock_acquire.cold.77+0x1f2/0x3d7
lock_acquire+0x1d2/0x610
_raw_write_lock_bh+0x38/0x80
tipc_sk_finish_conn+0x21e/0x640 [tipc]
tipc_sk_filter_rcv+0x147b/0x3030 [tipc]
tipc_sk_rcv+0xbb4/0x1b40 [tipc]
tipc_lxc_xmit+0x225/0x26b [tipc]
tipc_node_xmit.cold.82+0x4a/0x102 [tipc]
__tipc_sendstream+0x879/0xff0 [tipc]
tipc_accept+0x966/0x10b0 [tipc]
do_accept+0x37d/0x590
This patch avoids this warning by not holding the 'node rw lock' before
calling tipc_lxc_xmit(). As to protect the 'peer_net', rcu_read_lock()
should be enough, as in cleanup_net() when freeing the netns, it calls
synchronize_rcu() before the free is continued.
Also since tipc_lxc_xmit() is like the RX path in tipc_rcv(), it makes
sense to call it under rcu_read_lock(). Note that the right lock order
must be:
rcu_read_lock();
tipc_node_read_lock(n);
tipc_node_read_unlock(n);
tipc_lxc_xmit();
rcu_read_unlock();
instead of:
rcu_read_lock();
tipc_lxc_xmit();
rcu_read_unlock();
and we have to call tipc_node_read_lock/unlock() twice in
tipc_node_xmit().
Fixes: f73b12812a3d ("tipc: improve throughput between nodes in netns")
Reported-by: Shuang Li <shuali@redhat.com>
Signed-off-by: Xin Long <lucien.xin@gmail.com>
Link: https://lore.kernel.org/r/5bdd1f8fee9db695cfff4528a48c9b9d0523fb00.1670110641.git.lucien.xin@gmail.com
[ Upstream commit c0d999348e01df03e0a7f550351f3907fabbf611 ]
Cited commit added the table ID to the FIB info structure, but did not
properly initialize it when table ID 0 is used. This can lead to a route
in the default VRF with a preferred source address not being flushed
when the address is deleted.
Consider the following example:
# ip address add dev dummy1 192.0.2.1/28
# ip address add dev dummy1 192.0.2.17/28
# ip route add 198.51.100.0/24 via 192.0.2.2 src 192.0.2.17 metric 100
# ip route add table 0 198.51.100.0/24 via 192.0.2.2 src 192.0.2.17 metric 200
# ip route show 198.51.100.0/24
198.51.100.0/24 via 192.0.2.2 dev dummy1 src 192.0.2.17 metric 100
198.51.100.0/24 via 192.0.2.2 dev dummy1 src 192.0.2.17 metric 200
Both routes are installed in the default VRF, but they are using two
different FIB info structures. One with a metric of 100 and table ID of
254 (main) and one with a metric of 200 and table ID of 0. Therefore,
when the preferred source address is deleted from the default VRF,
the second route is not flushed:
# ip address del dev dummy1 192.0.2.17/28
Fix by storing a table ID of 254 instead of 0 in the route configuration
structure.
Add a test case that fails before the fix:
# ./fib_tests.sh -t ipv4_del_addr
IPv4 delete address route tests
Regular FIB info
TEST: Route removed from VRF when source address deleted [ OK ]
TEST: Route in default VRF not removed [ OK ]
TEST: Route removed in default VRF when source address deleted [ OK ]
TEST: Route in VRF is not removed by address delete [ OK ]
Identical FIB info with different table ID
Table ID 0
TEST: Route removed in default VRF when source address deleted [FAIL]
Tests passed: 8
Tests failed: 1
And passes after:
Regular FIB info
Table ID 0
Tests passed: 9
Tests failed: 0
Fixes: 5a56a0b3a45d ("net: Don't delete routes in different VRFs")
Reported-by: Donald Sharp <sharpd@nvidia.com>
Signed-off-by: Ido Schimmel <idosch@nvidia.com>
Reviewed-by: David Ahern <dsahern@kernel.org>
[ Upstream commit f96a3d74554df537b6db5c99c27c80e7afadc8d1 ]
prevent structures with different table IDs from being consolidated.
This can lead to routes being flushed from a VRF when an address is
deleted from a different VRF.
Fix by taking the table ID into account when looking for a matching FIB
info. This is already done for FIB info structures backed by a nexthop
object in fib_find_info_nh().
Add test cases that fail before the fix:
Regular FIB info
TEST: Route removed from VRF when source address deleted [FAIL]
RTNETLINK answers: File exists
TEST: Route in VRF is not removed by address delete [FAIL]
Tests passed: 6
Tests failed: 2
And pass after:
Regular FIB info
Tests passed: 8
Tests failed: 0
[ Upstream commit 743117a997bbd4840e827295c07e59bcd7f7caa3 ]
Fix the potential risk of OOB if skb_linearize() fails in
tipc_link_proto_rcv().
Fixes: 5cbb28a4bf65 ("tipc: linearize arriving NAME_DISTR and LINK_PROTO buffers")
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
Link: https://lore.kernel.org/r/20221203094635.29024-1-yuehaibing@huawei.com
[ Upstream commit ee496694b9eea651ae1aa4c4667d886cdf74aa3b ]
Although the type I ERSPAN is based on the barebones IP + GRE
encapsulation and no extra ERSPAN header. Report erspan version on GRE
interface looks unreasonable. Fix this by separating the erspan and gre
fill info.
IPv6 GRE does not have this info as IPv6 only supports erspan version
1 and 2.
Fixes: f989d546a2d5 ("erspan: Add type I version 0 support.")
Acked-by: William Tu <u9012063@gmail.com>
Link: https://lore.kernel.org/r/20221203032858.3130339-1-liuhangbin@gmail.com
[ Upstream commit e329e71013c9b5a4535b099208493c7826ee4a64 ]
While running under CONFIG_FORTIFY_SOURCE=y, syzkaller reported:
memcpy: detected field-spanning write (size 129) of single field "target->sensf_res" at net/nfc/nci/ntf.c:260 (size 18)
This appears to be a legitimate lack of bounds checking in
nci_add_new_protocol(). Add the missing checks.
Reported-by: syzbot+210e196cef4711b65139@syzkaller.appspotmail.com
Link: https://lore.kernel.org/lkml/0000000000001c590f05ee7b3ff4@google.com
Fixes: 019c4fbaa790 ("NFC: Add NCI multiple targets support")
Reviewed-by: Krzysztof Kozlowski <krzysztof.kozlowski@linaro.org>
Link: https://lore.kernel.org/r/20221202214410.never.693-kees@kernel.org
[ Upstream commit b3d72d3135d2ef68296c1ee174436efd65386f04 ]
Kernel fault injection test reports null-ptr-deref as follows:
BUG: kernel NULL pointer dereference, address: 0000000000000008
RIP: 0010:cfg802154_netdev_notifier_call+0x120/0x310 include/linux/list.h:114
Call Trace:
<TASK>
raw_notifier_call_chain+0x6d/0xa0 kernel/notifier.c:87
call_netdevice_notifiers_info+0x6e/0xc0 net/core/dev.c:1944
unregister_netdevice_many_notify+0x60d/0xcb0 net/core/dev.c:1982
unregister_netdevice_queue+0x154/0x1a0 net/core/dev.c:10879
register_netdevice+0x9a8/0xb90 net/core/dev.c:10083
ieee802154_if_add+0x6ed/0x7e0 net/mac802154/iface.c:659
ieee802154_register_hw+0x29c/0x330 net/mac802154/main.c:229
mcr20a_probe+0xaaa/0xcb1 drivers/net/ieee802154/mcr20a.c:1316
ieee802154_if_add() allocates wpan_dev as netdev's private data, but not
init the list in struct wpan_dev. cfg802154_netdev_notifier_call() manage
the list when device register/unregister, and may lead to null-ptr-deref.
Use INIT_LIST_HEAD() on it to initialize it correctly.
Fixes: fcf39e6e88e9 ("ieee802154: add wpan_dev_list")
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
Acked-by: Alexander Aring <aahringo@redhat.com>
Link: https://lore.kernel.org/r/20221130091705.1831140-1-weiyongjun@huaweicloud.com
Signed-off-by: Stefan Schmidt <stefan@datenfreihafen.org>
[ Upstream commit 8948876335b1752176afdff8e704099a3ea0f6e6 ]
Return NULL if we got unexpected value from skb_trim_rcsum() in
sja1110_rcv_inband_control_extension()
Fixes: 4913b8ebf8a9 ("net: dsa: add support for the SJA1110 native tagging protocol")
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
Link: https://lore.kernel.org/r/20221201140032.26746-3-artem.chernyshev@red-soft.ru
[ Upstream commit d4edb50688652eb10be270bc515da63815de428f ]
in hellcreek_rcv()
Fixes: 01ef09caad66 ("net: dsa: Add tag handling for Hirschmann Hellcreek switches")
Reviewed-by: Kurt Kanzenbach <kurt@linutronix.de>
Link: https://lore.kernel.org/r/20221201140032.26746-2-artem.chernyshev@red-soft.ru
[ Upstream commit 3d8fdcbf1f42e2bb9ae8b8c0b6f202278c788a22 ]
in ksz_common_rcv()
Fixes: bafe9ba7d908 ("net: dsa: ksz: Factor out common tag code")
Reviewed-by: Vladimir Oltean <olteanv@gmail.com>
Link: https://lore.kernel.org/r/20221201140032.26746-1-artem.chernyshev@red-soft.ru
