path: root/net
2008-02-069p: fix p9_printfcall exportAndrew Morton
ERROR: "p9_printfcall" [net/9p/9pnet_virtio.ko] undefined! Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-02-069p: transport API reorganizationEric Van Hensbergen
This merges the mux.c (including the connection interface) with trans_fd in preparation for transport API changes. Ultimately, trans_fd will need to be rewritten to clean it up and simplify the implementation, but this reorganization is viewed as the first step. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-02-069p: add remove function to trans_virtioEric Van Hensbergen
Request from rusty: Just cleaning up patches for 2.6.25 merge, and noticed that net/9p/trans_virtio.c doesn't have a remove function. This will crash when removing the module (console doesn't have one because it can't really be removed). Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-02-069p: Convert semaphore to spinlock for p9_idpoolAnthony Liguori
When booting from v9fs, down_interruptible in p9_idpool_get() triggered a BUG as it was being called with IRQs disabled. A spinlock seems like the right thing to be using since the idr functions go out of their way not to sleep. This patch eliminates the BUG by converting the semaphore to a spinlock. Signed-off-by: Anthony Liguori <aliguori@us.ibm.com> Acked-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-02-069p: Fix soft lockup in virtio transportEric Van Hensbergen
This fixes a poorly placed spinlock which could result in a soft lockup condition. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-02-069p: block-based virtio clientEric Van Hensbergen
This replaces the console-based virto client with a block-based client using a single request queue. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-02-069p: create transport rpc cut-thruEric Van Hensbergen
Add a new transport function which allows a cut-thru directly to the transport instead of processing request through the mux if the cut-thru exists. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-02-069p: fix bug in p9_clone_statMartin Stava
This patch fixes a bug in the copying of 9P stat information where string references weren't being updated properly. Signed-off-by: Martin Sava <martin.stava@gmail.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-02-05ipvs: Make wrr "no available servers" error message rate-limitedSven Wegener
No available servers is more an error message than something informational. It should also be rate-limited, else we're going to flood our logs on a busy director, if all real servers are out of order with a weight of zero. Signed-off-by: Sven Wegener <sven.wegener@stealer.net> Acked-by: Simon Horman <horms@verge.net.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-05Merge branch 'fixes' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/linville/wireless-2.6
2008-02-05[NET_SCHED]: cls_flow: support classification based on VLAN tagPatrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-05[NET_SCHED]: cls_flow: fix key mask validity checkPatrick McHardy
Since we're using fls(), we need to check whether the value is non-zero first. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-05[NET_SCHED]: em_meta: fix compile warningPatrick McHardy
net/sched/em_meta.c: In function 'meta_int_vlan_tag': net/sched/em_meta.c:179: warning: 'tag' may be used uninitialized in this function Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-05mac80211: Is not EXPERIMENTAL anymoreMichael Buesch
Remove the EXPERIMENTAL dependency, as the existing mac80211 features are stable. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (21 commits) [PKT_SCHED]: vlan tag match [NET]: Add if_addrlabel.h to sanitized headers. [NET] rtnetlink.c: remove no longer used functions [ICMP]: Restore pskb_pull calls in receive function [INET]: Fix accidentally broken inet(6)_hash_connect's port offset calculations. [NET]: Remove further references to net-modules.txt bluetooth rfcomm tty: destroy before tty_close() bluetooth: blacklist another Broadcom BCM2035 device drivers/bluetooth/btsdio.c: fix double-free drivers/bluetooth/bpa10x.c: fix memleak bluetooth: uninlining bluetooth: hidp_process_hid_control remove unnecessary parameter dealing tun: impossible to deassert IFF_ONE_QUEUE or IFF_NO_PI hamradio: fix dmascc section mismatch [SCTP]: Fix kernel panic while received AUTH chunk with BAD shared key identifier [SCTP]: Fix kernel panic while received AUTH chunk while enabled auth [IPV4]: Formatting fix for /proc/net/fib_trie. [IPV6]: Fix sysctl compilation error. [NET_SCHED]: Add #ifdef CONFIG_NET_EMATCH in net/sched/cls_flow.c (latest git broken build) [IPV4]: Fix compile error building without CONFIG_FS_PROC ...
2008-02-05NetLabel: introduce a new kernel configuration API for NetLabelPaul Moore
Add a new set of configuration functions to the NetLabel/LSM API so that LSMs can perform their own configuration of the NetLabel subsystem without relying on assistance from userspace. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> Reviewed-by: James Morris <jmorris@namei.org> Cc: Chris Wright <chrisw@sous-sol.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05[PKT_SCHED]: vlan tag matchStephen Hemminger
Provide a way to use tc filters on vlan tag even if tag is buried in skb due to hardware acceleration. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-05[NET] rtnetlink.c: remove no longer used functionsAdrian Bunk
This patch removes the following no longer used functions: - rtattr_parse() - rtattr_strlcpy() - __rtattr_parse_nested_compat() Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-05[ICMP]: Restore pskb_pull calls in receive functionHerbert Xu
Somewhere along the development of my ICMP relookup patch the header length check went AWOL on the non-IPsec path. This patch restores the check. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-05[INET]: Fix accidentally broken inet(6)_hash_connect's port offset calculations.Pavel Emelyanov
The port offset calculations depend on the protocol family, but, as Adrian noticed, I broke this logic with the commit 5ee31fc1ecdcbc234c8c56dcacef87c8e09909d8 [INET]: Consolidate inet(6)_hash_connect. Return this logic back, by passing the port offset directly into the consolidated function. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Noticed-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-05bluetooth rfcomm tty: destroy before tty_close()Dave Young
rfcomm dev could be deleted in tty_hangup, so we must not call rfcomm_dev_del again to prevent from destroying rfcomm dev before tty close. Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-05bluetooth: uninliningAndrew Morton
Remove all those inlines which were either a) unneeded or b) increased code size. text data bss dec hex filename before: 6997 74 8 7079 1ba7 net/bluetooth/hidp/core.o after: 6492 74 8 6574 19ae net/bluetooth/hidp/core.o Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-05bluetooth: hidp_process_hid_control remove unnecessary parameter dealingDave Young
According to the bluetooth HID spec v1.0 chapter 7.4.2 "This code requests a major state change in a BT-HID device. A HID_CONTROL request does not generate a HANDSHAKE response." "A HID_CONTROL packet with a parameter of VIRTUAL_CABLE_UNPLUG is the only HID_CONTROL packet a device can send to a host. A host will ignore all other packets." So in the hidp_precess_hid_control function, we just need to deal with the UNLUG packet. Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-05[SCTP]: Fix kernel panic while received AUTH chunk with BAD shared key ↵Wei Yongjun
identifier If SCTP-AUTH is enabled, received AUTH chunk with BAD shared key identifier will cause kernel panic. Test as following: step1: enabled /proc/sys/net/sctp/auth_enable step 2: connect to SCTP server with auth capable. Association is established between endpoints. Then send a AUTH chunk with a bad shareid, SCTP server will kernel panic after received that AUTH chunk. SCTP client SCTP server INIT ----------> (with auth capable) <---------- INIT-ACK (with auth capable) COOKIE-ECHO ----------> <---------- COOKIE-ACK AUTH ----------> AUTH chunk is like this: AUTH chunk Chunk type: AUTH (15) Chunk flags: 0x00 Chunk length: 28 Shared key identifier: 10 HMAC identifier: SHA-1 (1) HMAC: 0000000000000000000000000000000000000000 The assignment of NULL to key can safely be removed, since key_for_each (which is just list_for_each_entry under the covers does an initial assignment to key anyway). If the endpoint_shared_keys list is empty, or if the key_id being requested does not exist, the function as it currently stands returns the actuall list_head (in this case endpoint_shared_keys. Since that list_head isn't surrounded by an actuall data structure, the last iteration through list_for_each_entry will do a container_of on key, and we wind up returning a bogus pointer, instead of NULL, as we should. > Neil Horman wrote: >> On Tue, Jan 22, 2008 at 05:29:20PM +0900, Wei Yongjun wrote: >> >> FWIW, Ack from me. The assignment of NULL to key can safely be >> removed, since >> key_for_each (which is just list_for_each_entry under the covers does >> an initial >> assignment to key anyway). >> If the endpoint_shared_keys list is empty, or if the key_id being >> requested does >> not exist, the function as it currently stands returns the actuall >> list_head (in >> this case endpoint_shared_keys. Since that list_head isn't >> surrounded by an >> actuall data structure, the last iteration through >> list_for_each_entry will do a >> container_of on key, and we wind up returning a bogus pointer, >> instead of NULL, >> as we should. Wei's patch corrects that. >> >> Regards >> Neil >> >> Acked-by: Neil Horman <nhorman@tuxdriver.com> >> > > Yep, the patch is correct. > > Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> > > -vlad > Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-05[SCTP]: Fix kernel panic while received AUTH chunk while enabled authWei Yongjun
If STCP is started while /proc/sys/net/sctp/auth_enable is set 0 and association is established between endpoints. Then if /proc/sys/net/sctp/auth_enable is set 1, a received AUTH chunk will cause kernel panic. Test as following: step 1: echo 0> /proc/sys/net/sctp/auth_enable step 2: SCTP client SCTP server INIT ---------> <--------- INIT-ACK COOKIE-ECHO ---------> <--------- COOKIE-ACK step 3: echo 1> /proc/sys/net/sctp/auth_enable step 4: SCTP client SCTP server AUTH -----------> Kernel Panic This patch fix this probleam to treat AUTH chunk as unknow chunk if peer has initialized with no auth capable. > Sorry for the delay. Was on vacation without net access. > > Wei Yongjun wrote: >> >> >> This patch fix this probleam to treat AUTH chunk as unknow chunk if >> peer has initialized with no auth capable. >> >> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> > > Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> > >> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-05[IPV4]: Formatting fix for /proc/net/fib_trie.Denis V. Lunev
The line in the /proc/net/fib_trie for route with TOS specified - has extra \n at the end - does not have a space after route scope like below. |-- 1.1.1.1 /32 universe UNICASTtos =1 Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-05[NET_SCHED]: Add #ifdef CONFIG_NET_EMATCH in net/sched/cls_flow.c (latest ↵Rami Rosen
git broken build) The 2.6 latest git build was broken when using the following configuration options: CONFIG_NET_EMATCH=n CONFIG_NET_CLS_FLOW=y with the following error: net/sched/cls_flow.c: In function 'flow_dump': net/sched/cls_flow.c:598: error: 'struct tcf_ematch_tree' has no member named 'hdr' make[2]: *** [net/sched/cls_flow.o] Error 1 make[1]: *** [net/sched] Error 2 make: *** [net] Error 2 see the recent post by Li Zefan: http://www.spinics.net/lists/netdev/msg54434.html The reason for this crash is that struct tcf_ematch_tree (net/pkt_cls.h) is empty when CONFIG_NET_EMATCH is not defined. When CONFIG_NET_EMATCH is defined, the tcf_ematch_tree structure indeed holds a struct tcf_ematch_tree_hdr (hdr) as flow_dump() expects. This patch adds #ifdef CONFIG_NET_EMATCH in flow_dump to avoid this. Signed-off-by: Rami Rosen <ramirose@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-05[IPSEC] xfrm4_beet_input(): fix an if()Adrian Bunk
A bug every C programmer makes at some point in time... Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: (25 commits) virtio: balloon driver virtio: Use PCI revision field to indicate virtio PCI ABI version virtio: PCI device virtio_blk: implement naming for vda-vdz,vdaa-vdzz,vdaaa-vdzzz virtio_blk: Dont waste major numbers virtio_blk: provide getgeo virtio_net: parametrize the napi_weight for virtio receive queue. virtio: free transmit skbs when notified, not on next xmit. virtio: flush buffers on open virtnet: remove double ether_setup virtio: Allow virtio to be modular and used by modules virtio: Use the sg_phys convenience function. virtio: Put the virtio under the virtualization menu virtio: handle interrupts after callbacks turned off virtio: reset function virtio: populate network rings in the probe routine, not open virtio: Tweak virtio_net defines virtio: Net header needs hdr_len virtio: remove unused id field from struct virtio_blk_outhdr virtio: clarify NO_NOTIFY flag usage ...
2008-02-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (79 commits) Jesper Juhl is the new trivial patches maintainer Documentation: mention email-clients.txt in SubmittingPatches fs/binfmt_elf.c: spello fix do_invalidatepage() comment typo fix Documentation/filesystems/porting fixes typo fixes in net/core/net_namespace.c typo fix in net/rfkill/rfkill.c typo fixes in net/sctp/sm_statefuns.c lib/: Spelling fixes kernel/: Spelling fixes include/scsi/: Spelling fixes include/linux/: Spelling fixes include/asm-m68knommu/: Spelling fixes include/asm-frv/: Spelling fixes fs/: Spelling fixes drivers/watchdog/: Spelling fixes drivers/video/: Spelling fixes drivers/ssb/: Spelling fixes drivers/serial/: Spelling fixes drivers/scsi/: Spelling fixes ...
2008-02-04virtio: explicit enable_cb/disable_cb rather than callback return.Rusty Russell
It seems that virtio_net wants to disable callbacks (interrupts) before calling netif_rx_schedule(), so we can't use the return value to do so. Rename "restart" to "cb_enable" and introduce "cb_disable" hook: callback now returns void, rather than a boolean. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-02-04virtio: simplify config mechanism.Rusty Russell
Previously we used a type/len pair within the config space, but this seems overkill. We now simply define a structure which represents the layout in the config space: the config space can now only be extended at the end. The main driver-visible changes: 1) We indicate what fields are present with an explicit feature bit. 2) Virtqueues are explicitly numbered, and not in the config space. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-02-04virtio: Implement skb_partial_csum_set, for setting partial csums on ↵Rusty Russell
untrusted packets. Use it in virtio_net (replacing buggy version there), it's also going to be used by TAP for partial csum support. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: David S. Miller <davem@davemloft.net>
2008-02-03typo fixes in net/core/net_namespace.cOliver Pinter
Signed-off-by: Oliver Pinter <oliver.pntr@gmail.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-02-03typo fix in net/rfkill/rfkill.cOliver Pinter
2008-02-03typo fixes in net/sctp/sm_statefuns.cOliver Pinter
2008-02-03Merge branch 'fixes' of ↵David S. Miller
2008-02-03[SOCK] proto: Add hashinfo member to struct protoArnaldo Carvalho de Melo
This way we can remove TCP and DCCP specific versions of sk->sk_prot->get_port: both v4 and v6 use inet_csk_get_port sk->sk_prot->hash: inet_hash is directly used, only v6 need a specific version to deal with mapped sockets sk->sk_prot->unhash: both v4 and v6 use inet_hash directly struct inet_connection_sock_af_ops also gets a new member, bind_conflict, so that inet_csk_get_port can find the per family routine. Now only the lookup routines receive as a parameter a struct inet_hashtable. With this we further reuse code, reducing the difference among INET transport protocols. Eventually work has to be done on UDP and SCTP to make them share this infrastructure and get as a bonus inet_diag interfaces so that iproute can be used with these protocols. net-2.6/net/ipv4/inet_hashtables.c: struct proto | +8 struct inet_connection_sock_af_ops | +8 2 structs changed __inet_hash_nolisten | +18 __inet_hash | -210 inet_put_port | +8 inet_bind_bucket_create | +1 __inet_hash_connect | -8 5 functions changed, 27 bytes added, 218 bytes removed, diff: -191 net-2.6/net/core/sock.c: proto_seq_show | +3 1 function changed, 3 bytes added, diff: +3 net-2.6/net/ipv4/inet_connection_sock.c: inet_csk_get_port | +15 1 function changed, 15 bytes added, diff: +15 net-2.6/net/ipv4/tcp.c: tcp_set_state | -7 1 function changed, 7 bytes removed, diff: -7 net-2.6/net/ipv4/tcp_ipv4.c: tcp_v4_get_port | -31 tcp_v4_hash | -48 tcp_v4_destroy_sock | -7 tcp_v4_syn_recv_sock | -2 tcp_unhash | -179 5 functions changed, 267 bytes removed, diff: -267 net-2.6/net/ipv6/inet6_hashtables.c: __inet6_hash | +8 1 function changed, 8 bytes added, diff: +8 net-2.6/net/ipv4/inet_hashtables.c: inet_unhash | +190 inet_hash | +242 2 functions changed, 432 bytes added, diff: +432 vmlinux: 16 functions changed, 485 bytes added, 492 bytes removed, diff: -7 /home/acme/git/net-2.6/net/ipv6/tcp_ipv6.c: tcp_v6_get_port | -31 tcp_v6_hash | -7 tcp_v6_syn_recv_sock | -9 3 functions changed, 47 bytes removed, diff: -47 /home/acme/git/net-2.6/net/dccp/proto.c: dccp_destroy_sock | -7 dccp_unhash | -179 dccp_hash | -49 dccp_set_state | -7 dccp_done | +1 5 functions changed, 1 bytes added, 242 bytes removed, diff: -241 /home/acme/git/net-2.6/net/dccp/ipv4.c: dccp_v4_get_port | -31 dccp_v4_request_recv_sock | -2 2 functions changed, 33 bytes removed, diff: -33 /home/acme/git/net-2.6/net/dccp/ipv6.c: dccp_v6_get_port | -31 dccp_v6_hash | -7 dccp_v6_request_recv_sock | +5 3 functions changed, 5 bytes added, 38 bytes removed, diff: -33 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-02Merge branch 'for-linus' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-linus' of git://linux-nfs.org/~bfields/linux: (100 commits) SUNRPC: RPC program information is stored in unsigned integers SUNRPC: Move exported symbol definitions after function declaration part 2 NLM: tear down RPC clients in nlm_shutdown_hosts SUNRPC: spin svc_rqst initialization to its own function nfsd: more careful input validation in nfsctl write methods lockd: minor log message fix knfsd: don't bother mapping putrootfh enoent to eperm rdma: makefile rdma: ONCRPC RDMA protocol marshalling rdma: SVCRDMA sendto rdma: SVCRDMA recvfrom rdma: SVCRDMA Core Transport Services rdma: SVCRDMA Transport Module rdma: SVCRMDA Header File svc: Add svc_xprt_names service to replace svc_sock_names knfsd: Support adding transports by writing portlist file svc: Add svc API that queries for a transport instance svc: Add /proc/sys/sunrpc/transport files svc: Add transport hdr size for defer/revisit svc: Move the xprt independent code to the svc_xprt.c file ...
2008-02-01SUNRPC: RPC program information is stored in unsigned integersChuck Lever
Clean up: When looping over RPC version and procedure numbers, use unsigned index variables. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01SUNRPC: Move exported symbol definitions after function declaration part 2Trond Myklebust
Do it for the server code... Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01SUNRPC: spin svc_rqst initialization to its own functionJeff Layton
Move the initialzation in __svc_create_thread that happens prior to thread creation to a new function. Export the function to allow services to have better control over the svc_rqst structs. Also rearrange the rqstp initialization to prevent NULL pointer dereferences in svc_exit_thread in case allocations fail. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01rdma: makefileTom Tucker
Add the svcrdma module to the xprtrdma makefile. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01rdma: ONCRPC RDMA protocol marshallingTom Tucker
This logic parses the ONCRDMA protocol headers that precede the actual RPC header. It is placed in a separate file to keep all protocol aware code in a single place. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01rdma: SVCRDMA sendtoTom Tucker
This file implements the RDMA transport sendto function. A RPC reply on an RDMA transport consists of some number of RDMA_WRITE requests followed by an RDMA_SEND request. The sendto function parses the ONCRPC RDMA reply header to determine how to send the reply back to the client. The send queue is sized so as to be able to send complete replies for requests in most cases. In the event that there are not enough SQ WR slots to reply, e.g. big data, the send will block the NFSD thread. The I/O callback functions in svc_rdma_transport.c that reap WR completions wake any waiters blocked on the SQ. In general, the goal is not to block NFSD threads and the has_wspace method stall requests when the SQ is nearly full. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01rdma: SVCRDMA recvfromTom Tucker
This file implements the RDMA transport recvfrom function. The function dequeues work reqeust completion contexts from an I/O list that it shares with the I/O tasklet in svc_rdma_transport.c. For ONCRPC RDMA, an RPC may not be complete when it is received. Instead, the RDMA header that precedes the RPC message informs the transport where to get the RPC data from on the client and where to place it in the RPC message before it is delivered to the server. The svc_rdma_recvfrom function therefore, parses this RDMA header and issues any necessary RDMA operations to fetch the remainder of the RPC from the client. Special handling is required when the request involves an RDMA_READ. In this case, recvfrom submits the RDMA_READ requests to the underlying transport driver and then returns 0. When the transport completes the last RDMA_READ for the request, it enqueues it on a read completion queue and enqueues the transport. The recvfrom code favors this queue over the regular DTO queue when satisfying reads. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01rdma: SVCRDMA Core Transport ServicesTom Tucker
This file implements the core transport data management and I/O path. The I/O path for RDMA involves receiving callbacks on interrupt context. Since all the svc transport locks are _bh locks we enqueue the transport on a list, schedule a tasklet to dequeue data indications from the RDMA completion queue. The tasklet in turn takes _bh locks to enqueue receive data indications on a list for the transport. The svc_rdma_recvfrom transport function dequeues data from this list in an NFSD thread context. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01rdma: SVCRDMA Transport ModuleTom Tucker
This file implements the RDMA transport module initialization and termination logic and registers the transport sysctl variables. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Add svc_xprt_names service to replace svc_sock_namesTom Tucker
Create a transport independent version of the svc_sock_names function. The toclose capability of the svc_sock_names service can be implemented using the svc_xprt_find and svc_xprt_close services. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01knfsd: Support adding transports by writing portlist fileTom Tucker
Update the write handler for the portlist file to allow creating new listening endpoints on a transport. The general form of the string is: <transport_name><space><port number> For example: echo "tcp 2049" > /proc/fs/nfsd/portlist This is intended to support the creation of a listening endpoint for RDMA transports without adding #ifdef code to the nfssvc.c file. Transports can also be removed as follows: '-'<transport_name><space><port number> For example: echo "-tcp 2049" > /proc/fs/nfsd/portlist Attempting to add a listener with an invalid transport string results in EPROTONOSUPPORT and a perror string of "Protocol not supported". Attempting to remove an non-existent listener (.e.g. bad proto or port) results in ENOTCONN and a perror string of "Transport endpoint is not connected" Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
