path: root/net
2011-01-26xfrm6: Don't forget to propagate peer into ipsec route.David S. Miller
Like ipv4, we have to propagate the ipv6 route peer into the ipsec top-level route during instantiation. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-26Merge branch 'master' of ↵David S. Miller
2011-01-25TCP: fix a bug that triggers large number of TCP RST by mistakeJerry Chu
This patch fixes a bug that causes TCP RST packets to be generated on otherwise correctly behaved applications, e.g., no unread data on close,..., etc. To trigger the bug, at least two conditions must be met: 1. The FIN flag is set on the last data packet, i.e., it's not on a separate, FIN only packet. 2. The size of the last data chunk on the receive side matches exactly with the size of buffer posted by the receiver, and the receiver closes the socket without any further read attempt. This bug was first noticed on our netperf based testbed for our IW10 proposal to IETF where a large number of RST packets were observed. netperf's read side code meets the condition 2 above 100%. Before the fix, tcp_data_queue() will queue the last skb that meets condition 1 to sk_receive_queue even though it has fully copied out (skb_copy_datagram_iovec()) the data. Then if condition 2 is also met, tcp_recvmsg() often returns all the copied out data successfully without actually consuming the skb, due to a check "if ((chunk = len - tp->ucopy.len) != 0) {" and "len -= chunk;" after tcp_prequeue_process() that causes "len" to become 0 and an early exit from the big while loop. I don't see any reason not to free the skb whose data have been fully consumed in tcp_data_queue(), regardless of the FIN flag. We won't get there if MSG_PEEK is on. Am I missing some arcane cases related to urgent data? Signed-off-by: H.K. Jerry Chu <hkchu@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-25mac80211: fix a crash in ieee80211_beacon_get_tim on change_interfaceFelix Fietkau
Some drivers (e.g. ath9k) do not always disable beacons when they're supposed to. When an interface is changed using the change_interface op, the mode specific sdata part is in an undefined state and trying to get a beacon at this point can produce weird crashes. To fix this, add a check for ieee80211_sdata_running before using anything from the sdata. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Cc: stable@kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-25ipv6: Revert 'administrative down' address handling changes.David S. Miller
This reverts the following set of commits: d1ed113f1669390da9898da3beddcc058d938587 ("ipv6: remove duplicate neigh_ifdown") 29ba5fed1bbd09c2cba890798c8f9eaab251401d ("ipv6: don't flush routes when setting loopback down") 9d82ca98f71fd686ef2f3017c5e3e6a4871b6e46 ("ipv6: fix missing in6_ifa_put in addrconf") 2de795707294972f6c34bae9de713e502c431296 ("ipv6: addrconf: don't remove address state on ifdown if the address is being kept") 8595805aafc8b077e01804c9a3668e9aa3510e89 ("IPv6: only notify protocols if address is compeletely gone") 27bdb2abcc5edb3526e25407b74bf17d1872c329 ("IPv6: keep tentative addresses in hash table") 93fa159abe50d3c55c7f83622d3f5c09b6e06f4b ("IPv6: keep route for tentative address") 8f37ada5b5f6bfb4d251a7f510f249cb855b77b3 ("IPv6: fix race between cleanup and add/delete address") 84e8b803f1e16f3a2b8b80f80a63fa2f2f8a9be6 ("IPv6: addrconf notify when address is unavailable") dc2b99f71ef477a31020511876ab4403fb7c4420 ("IPv6: keep permanent addresses on admin down") because the core semantic change to ipv6 address handling on ifdown has broken some things, in particular "disable_ipv6" sysctl handling. Stephen has made several attempts to get things back in working order, but nothing has restored disable_ipv6 fully yet. Reported-by: Eric W. Biederman <ebiederm@xmission.com> Tested-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-24net: clear heap allocation for ethtool_get_regs()Eugene Teo
There is a conflict between commit b00916b1 and a77f5db3. This patch resolves the conflict by clearing the heap allocation in ethtool_get_regs(). Cc: stable@kernel.org Signed-off-by: Eugene Teo <eugeneteo@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-24ipv6: Always clone offlink routes.David S. Miller
Do not handle PMTU vs. route lookup creation any differently wrt. offlink routes, always clone them. Reported-by: PK <runningdoglackey@yahoo.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-24dcbnl: make get_app handling symmetric for IEEE and CEE DCBxJohn Fastabend
The IEEE get/set app handlers use generic routines and do not require the net_device to implement the dcbnl_ops routines. This patch makes it symmetric so user space and drivers do not have to handle the CEE version and IEEE DCBx versions differently. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-24tcp: fix bug in listening_get_next()Eric Dumazet
commit a8b690f98baf9fb19 (tcp: Fix slowness in read /proc/net/tcp) introduced a bug in handling of SYN_RECV sockets. st->offset represents number of sockets found since beginning of listening_hash[st->bucket]. We should not reset st->offset when iterating through syn_table[st->sbucket], or else if more than ~25 sockets (if PAGE_SIZE=4096) are in SYN_RECV state, we exit from listening_get_next() with a too small st->offset Next time we enter tcp_seek_last_pos(), we are not able to seek past already found sockets. Reported-by: PK <runningdoglackey@yahoo.com> CC: Tom Herbert <therbert@google.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-24inetpeer: Use correct AVL tree base pointer in inet_getpeer().David S. Miller
Family was hard-coded to AF_INET but should be daddr->family. This fixes crashes when unlinking ipv6 peer entries, since the unlink code was looking up the base pointer properly. Reported-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-24GRO: fix merging a paged skb after non-paged skbsMichal Schmidt
Suppose that several linear skbs of the same flow were received by GRO. They were thus merged into one skb with a frag_list. Then a new skb of the same flow arrives, but it is a paged skb with data starting in its frags[]. Before adding the skb to the frag_list skb_gro_receive() will of course adjust the skb to throw away the headers. It correctly modifies the page_offset and size of the frag, but it leaves incorrect information in the skb: ->data_len is not decreased at all. ->len is decreased only by headlen, as if no change were done to the frag. Later in a receiving process this causes skb_copy_datagram_iovec() to return -EFAULT and this is seen in userspace as the result of the recv() syscall. In practice the bug can be reproduced with the sfc driver. By default the driver uses an adaptive scheme when it switches between using napi_gro_receive() (with skbs) and napi_gro_frags() (with pages). The bug is reproduced when under rx load with enough successful GRO merging the driver decides to switch from the former to the latter. Manual control is also possible, so reproducing this is easy with netcat: - on machine1 (with sfc): nc -l 12345 > /dev/null - on machine2: nc machine1 12345 < /dev/zero - on machine1: echo 1 > /sys/module/sfc/parameters/rx_alloc_method # use skbs echo 2 > /sys/module/sfc/parameters/rx_alloc_method # use pages - See that nc has quit suddenly. [v2: Modified by Eric Dumazet to avoid advancing skb->data past the end and to use a temporary variable.] Signed-off-by: Michal Schmidt <mschmidt@redhat.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-24Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
2011-01-24net: arp_ioctl() must hold RTNLEric Dumazet
Commit 941666c2e3e0 "net: RCU conversion of dev_getbyhwaddr() and arp_ioctl()" introduced a regression, reported by Jamie Heilman. "arp -Ds 192.168.2.41 eth0 pub" triggered the ASSERT_RTNL() assert in pneigh_lookup() Removing RTNL requirement from arp_ioctl() was a mistake, just revert that part. Reported-by: Jamie Heilman <jamie@audible.transient.net> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-24module: fix missing semicolons in MODULE macro usageRusty Russell
You always needed them when you were a module, but the builtin versions of the macros used to be more lenient. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-01-20net_sched: accurate bytes/packets stats/ratesEric Dumazet
In commit 44b8288308ac9d (net_sched: pfifo_head_drop problem), we fixed a problem with pfifo_head drops that incorrectly decreased sch->bstats.bytes and sch->bstats.packets Several qdiscs (CHOKe, SFQ, pfifo_head, ...) are able to drop a previously enqueued packet, and bstats cannot be changed, so bstats/rates are not accurate (over estimated) This patch changes the qdisc_bstats updates to be done at dequeue() time instead of enqueue() time. bstats counters no longer account for dropped frames, and rates are more correct, since enqueue() bursts dont have effect on dequeue() rate. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (41 commits) sctp: user perfect name for Delayed SACK Timer option net: fix can_checksum_protocol() arguments swap Revert "netlink: test for all flags of the NLM_F_DUMP composite" gianfar: Fix misleading indentation in startup_gfar() net/irda/sh_irda: return to RX mode when TX error net offloading: Do not mask out NETIF_F_HW_VLAN_TX for vlan. USB CDC NCM: tx_fixup() race condition fix ns83820: Avoid bad pointer deref in ns83820_init_one(). ipv6: Silence privacy extensions initialization bnx2x: Update bnx2x version to 1.62.00-4 bnx2x: Fix AER setting for BCM57712 bnx2x: Fix BCM84823 LED behavior bnx2x: Mark full duplex on some external PHYs bnx2x: Fix BCM8073/BCM8727 microcode loading bnx2x: LED fix for BCM8727 over BCM57712 bnx2x: Common init will be executed only once after POR bnx2x: Swap BCM8073 PHY polarity if required iwlwifi: fix valid chain reading from EEPROM ath5k: fix locking in tx_complete_poll_work ath9k_hw: do PA offset calibration only on longcal interval ...
2011-01-19sctp: user perfect name for Delayed SACK Timer optionShan Wei
The option name of Delayed SACK Timer should be SCTP_DELAYED_SACK, not SCTP_DELAYED_ACK. Left SCTP_DELAYED_ACK be concomitant with SCTP_DELAYED_SACK, for making compatibility with existing applications. Reference: 8.1.19. Get or Set Delayed SACK Timer (SCTP_DELAYED_SACK) (http://tools.ietf.org/html/draft-ietf-tsvwg-sctpsocket-25) Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Acked-by: Wei Yongjun <yjwei@cn.fujitsu.com> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-19net: fix can_checksum_protocol() arguments swapEric Dumazet
commit 0363466866d901fbc (net offloading: Convert checksums to use centrally computed features.) mistakenly swapped can_checksum_protocol() arguments. This broke IPv6 on bnx2 for instance, on NIC without TCPv6 checksum offloads. Reported-by: Hans de Bruin <jmdebruin@xmsnet.nl> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-19Revert "netlink: test for all flags of the NLM_F_DUMP composite"David S. Miller
This reverts commit 0ab03c2b1478f2438d2c80204f7fef65b1bca9cf. It breaks several things including the avahi daemon. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-19Bluetooth: Fix race condition with conn->sec_levelJohan Hedberg
The conn->sec_level value is supposed to represent the current level of security that the connection has. However, by assigning to it before requesting authentication it will have the wrong value during the authentication procedure. To fix this a pending_sec_level variable is added which is used to track the desired security level while making sure that sec_level always represents the current level of security. Signed-off-by: Johan Hedberg <johan.hedberg@nokia.com> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-01-19Bluetooth: Fix authentication request for L2CAP raw socketsJohan Hedberg
When there is an existing connection l2cap_check_security needs to be called to ensure that the security level of the new socket is fulfilled. Normally l2cap_do_start takes care of this, but that function doesn't get called for SOCK_RAW type sockets. This patch adds the necessary l2cap_check_security call to the appropriate branch in l2cap_do_connect. Signed-off-by: Johan Hedberg <johan.hedberg@nokia.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-01-19Bluetooth: Create a unified auth_type evaluation functionJohan Hedberg
The logic for determining the needed auth_type for an L2CAP socket is rather complicated and has so far been duplicated in l2cap_check_security as well as l2cap_do_connect. Additionally the l2cap_check_security code was completely missing the handling of SOCK_RAW type sockets. This patch creates a unified function for the evaluation and makes l2cap_do_connect and l2cap_check_security use that function. Signed-off-by: Johan Hedberg <johan.hedberg@nokia.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-01-19Bluetooth: Fix MITM protection requirement preservationJohan Hedberg
If an existing connection has a MITM protection requirement (the first bit of the auth_type) then that requirement should not be cleared by new sockets that reuse the ACL but don't have that requirement. Signed-off-by: Johan Hedberg <johan.hedberg@nokia.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-01-19Revert "Bluetooth: Update sec_level/auth_type for already existing connections"Johan Hedberg
This reverts commit 045309820afe047920a50de25634dab46a1e851d. That commit is wrong for two reasons: - The conn->sec_level shouldn't be updated without performing authentication first (as it's supposed to represent the level of security that the existing connection has) - A higher auth_type value doesn't mean "more secure" like the commit seems to assume. E.g. dedicated bonding with MITM protection is 0x03 whereas general bonding without MITM protection is 0x04. hci_conn_auth already takes care of updating conn->auth_type so hci_connect doesn't need to do it. Signed-off-by: Johan Hedberg <johan.hedberg@nokia.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-01-19Bluetooth: Never deallocate a session when some DLC points to itLukáš Turek
Fix a bug introduced in commit 9cf5b0ea3a7f1432c61029f7aaf4b8b338628884: function rfcomm_recv_ua calls rfcomm_session_put without checking that the session is not referenced by some DLC. If the session is freed, that DLC would refer to deallocated memory, causing an oops later, as shown in this bug report: https://bugzilla.kernel.org/show_bug.cgi?id=15994 Signed-off-by: Lukas Turek <8an@praha12.net> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-01-19Bluetooth: Fix leaking blacklist when unregistering a hci deviceJohan Hedberg
The blacklist should be freed before the hci device gets unregistered. Signed-off-by: Johan Hedberg <johan.hedberg@nokia.com> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-01-19Bluetooth: l2cap: fix misuse of logical operation in place of bitopDavid Sterba
CC: Marcel Holtmann <marcel@holtmann.org> CC: "Gustavo F. Padovan" <padovan@profusion.mobi> CC: João Paulo Rechi Vita <jprvita@profusion.mobi> Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-01-18net offloading: Do not mask out NETIF_F_HW_VLAN_TX for vlan.Jesse Gross
In netif_skb_features() we return only the features that are valid for vlans if we have a vlan packet. However, we should not mask out NETIF_F_HW_VLAN_TX since it enables transmission of vlan tags and is obviously valid. Reported-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Jesse Gross <jesse@nicira.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-18ipv6: Silence privacy extensions initializationRomain Francoise
When a network namespace is created (via CLONE_NEWNET), the loopback interface is automatically added to the new namespace, triggering a printk in ipv6_add_dev() if CONFIG_IPV6_PRIVACY is set. This is problematic for applications which use CLONE_NEWNET as part of a sandbox, like Chromium's suid sandbox or recent versions of vsftpd. On a busy machine, it can lead to thousands of useless "lo: Disabled Privacy Extensions" messages appearing in dmesg. It's easy enough to check the status of privacy extensions via the use_tempaddr sysctl, so just removing the printk seems like the most sensible solution. Signed-off-by: Romain Francoise <romain@orebokech.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-18Merge branch 'master' of ↵David S. Miller
2011-01-15caif: checking the wrong variableDan Carpenter
In the original code we check if (servl == NULL) twice. The first time should print the message that cfmuxl_remove_uplayer() failed and set "ret" correctly, but instead it just returns success. The second check should be checking the value of "ret" instead of "servl". Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-15can: test size of struct sockaddr in sendmsgKurt Van Dijck
This patch makes the CAN socket code conform to the manpage of sendmsg. Signed-off-by: Kurt Van Dijck <kurt.van.dijck@eia.be> Acked-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-15Merge branch 'for-david' of git://git.open-mesh.org/ecsv/linux-mergeDavid S. Miller
2011-01-16batman-adv: Use "__attribute__" shortcut macrosSven Eckelmann
Linux 2.6.21 defines different macros for __attribute__ which are also used inside batman-adv. The next version of checkpatch.pl warns about the usage of __attribute__((packed))). Linux 2.6.33 defines an extra macro __always_unused which is used to assist source code analyzers and can be used to removed the last existing __attribute__ inside the source code. Signed-off-by: Sven Eckelmann <sven@narfation.org>
2011-01-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (47 commits) GRETH: resolve SMP issues and other problems GRETH: handle frame error interrupts GRETH: avoid writing bad speed/duplex when setting transfer mode GRETH: fixed skb buffer memory leak on frame errors GRETH: GBit transmit descriptor handling optimization GRETH: fix opening/closing GRETH: added raw AMBA vendor/device number to match against. cassini: Fix build bustage on x86. e1000e: consistent use of Rx/Tx vs. RX/TX/rx/tx in comments/logs e1000e: update Copyright for 2011 e1000: Avoid unhandled IRQ r8169: keep firmware in memory. netdev: tilepro: Use is_unicast_ether_addr helper etherdevice.h: Add is_unicast_ether_addr function ks8695net: Use default implementation of ethtool_ops::get_link ks8695net: Disable non-working ethtool operations USB CDC NCM: Don't deref NULL in cdc_ncm_rx_fixup() and don't use uninitialized variable. vxge: Remember to release firmware after upgrading firmware netdev: bfin_mac: Remove is_multicast_ether_addr use in netdev_for_each_mc_addr ipsec: update MAX_AH_AUTH_LEN to support sha512 ...
2011-01-14Merge branch 'for-2.6.38' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.38' of git://linux-nfs.org/~bfields/linux: (62 commits) nfsd4: fix callback restarting nfsd: break lease on unlink, link, and rename nfsd4: break lease on nfsd setattr nfsd: don't support msnfs export option nfsd4: initialize cb_per_client nfsd4: allow restarting callbacks nfsd4: simplify nfsd4_cb_prepare nfsd4: give out delegations more quickly in 4.1 case nfsd4: add helper function to run callbacks nfsd4: make sure sequence flags are set after destroy_session nfsd4: re-probe callback on connection loss nfsd4: set sequence flag when backchannel is down nfsd4: keep finer-grained callback status rpc: allow xprt_class->setup to return a preexisting xprt rpc: keep backchannel xprt as long as server connection rpc: move sk_bc_xprt to svc_xprt nfsd4: allow backchannel recovery nfsd4: support BIND_CONN_TO_SESSION nfsd4: modify session list under cl_lock Documentation: fl_mylease no longer exists ... Fix up conflicts in fs/nfsd/vfs.c with the vfs-scale work. The vfs-scale work touched some msnfs cases, and this merge removes support for that entirely, so the conflict was trivial to resolve.
2011-01-14rxrpc: rxrpc_workqueue isn't used during memory reclaimTejun Heo
rxrpc_workqueue isn't depended upon while reclaiming memory. Convert to alloc_workqueue() without WQ_MEM_RECLAIM. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: David Howells <dhowells@redhat.com> Cc: linux-afs@lists.infradead.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13net: remove dev_txq_stats_fold()Eric Dumazet
After recent changes, (percpu stats on vlan/tunnels...), we dont need anymore per struct netdev_queue tx_bytes/tx_packets/tx_dropped counters. Only remaining users are ixgbe, sch_teql, gianfar & macvlan : 1) ixgbe can be converted to use existing tx_ring counters. 2) macvlan incremented txq->tx_dropped, it can use the dev->stats.tx_dropped counter. 3) sch_teql : almost revert ab35cd4b8f42 (Use net_device internal stats) Now we have ndo_get_stats64(), use it, even for "unsigned long" fields (No need to bring back a struct net_device_stats) 4) gianfar adds a stats structure per tx queue to hold tx_bytes/tx_packets This removes a lockdep warning (and possible lockup) in rndis gadget, calling dev_get_stats() from hard IRQ context. Ref: http://www.spinics.net/lists/netdev/msg149202.html Reported-by: Neil Jones <neiljay@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Jarek Poplawski <jarkao2@gmail.com> CC: Alexander Duyck <alexander.h.duyck@intel.com> CC: Jeff Kirsher <jeffrey.t.kirsher@intel.com> CC: Sandeep Gopalpet <sandeep.kumar@freescale.com> CC: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-13batman-adv: Even Batman should not dereference NULL pointersJesper Juhl
There's a problem in net/batman-adv/unicast.c::frag_send_skb(). dev_alloc_skb() allocates memory and may fail, thus returning NULL. If this happens we'll pass a NULL pointer on to skb_split() which in turn hands it to skb_split_inside_header() from where it gets passed to skb_put() that lets skb_tail_pointer() play with it and that function dereferences it. And thus the bat dies. While I was at it I also moved the call to dev_alloc_skb() above the assignment to 'unicast_packet' since there's no reason to do that assignment if the memory allocation fails. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Sven Eckelmann <sven@narfation.org>
2011-01-13mac80211: use maximum number of AMPDU frames as default in BA RXLuciano Coelho
When the buffer size is set to zero in the block ack parameter set field, we should use the maximum supported number of subframes. The existing code was bogus and was doing some unnecessary calculations that lead to wrong values. Thanks Johannes for helping me figure this one out. Cc: stable@kernel.org Cc: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Luciano Coelho <coelho@ti.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-13mac80211: fix lockdep warningJohannes Berg
Since the introduction of the fixes for the reorder timer, mac80211 will cause lockdep warnings because lockdep confuses local->skb_queue and local->rx_skb_queue and treats their lock as the same. However, their locks are different, and are valid in different contexts (the former is used in IRQ context, the latter in BH only) and the only thing to be done is mark the former as a different lock class so that lockdep can tell the difference. Reported-by: Larry Finger <Larry.Finger@lwfinger.net> Reported-by: Sujith <m.sujith@gmail.com> Reported-by: Miles Lane <miles.lane@gmail.com> Tested-by: Sujith <m.sujith@gmail.com> Tested-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-13Merge branch 'master' of git://1984.lsi.us.es/net-2.6David S. Miller
2011-01-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (41 commits) fs: add documentation on fallocate hole punching Gfs2: fail if we try to use hole punch Btrfs: fail if we try to use hole punch Ext4: fail if we try to use hole punch Ocfs2: handle hole punching via fallocate properly XFS: handle hole punching via fallocate properly fs: add hole punching to fallocate vfs: pass struct file to do_truncate on O_TRUNC opens (try #2) fix signedness mess in rw_verify_area() on 64bit architectures fs: fix kernel-doc for dcache::prepend_path fs: fix kernel-doc for dcache::d_validate sanitize ecryptfs ->mount() switch afs move internal-only parts of ncpfs headers to fs/ncpfs switch ncpfs switch 9p pass default dentry_operations to mount_pseudo() switch hostfs switch affs switch configfs ...
2011-01-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (46 commits) hwrng: via_rng - Fix memory scribbling on some CPUs crypto: padlock - Move padlock.h into include/crypto hwrng: via_rng - Fix asm constraints crypto: n2 - use __devexit not __exit in n2_unregister_algs crypto: mark crypto workqueues CPU_INTENSIVE crypto: mv_cesa - dont return PTR_ERR() of wrong pointer crypto: ripemd - Set module author and update email address crypto: omap-sham - backlog handling fix crypto: gf128mul - Remove experimental tag crypto: af_alg - fix af_alg memory_allocated data type crypto: aesni-intel - Fixed build with binutils 2.16 crypto: af_alg - Make sure sk_security is initialized on accept()ed sockets net: Add missing lockdep class names for af_alg include: Install linux/if_alg.h for user-space crypto API crypto: omap-aes - checkpatch --file warning fixes crypto: omap-aes - initialize aes module once per request crypto: omap-aes - unnecessary code removed crypto: omap-aes - error handling implementation improved crypto: omap-aes - redundant locking is removed crypto: omap-aes - DMA initialization fixes for OMAP off mode ...
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: rbd: fix cleanup when trying to mount inexistent image net/ceph: make ceph_msgr_wq non-reentrant ceph: fsc->*_wq's aren't used in memory reclaim path ceph: Always free allocated memory in osdmap_decode() ceph: Makefile: Remove unnessary code ceph: associate requests with opening sessions ceph: drop redundant r_mds field ceph: implement DIRLAYOUTHASH feature to get dir layout from MDS ceph: add dir_layout to inode
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2011-01-13netfilter: ctnetlink: fix loop in ctnetlink_get_conntrack()Pablo Neira Ayuso
This patch fixes a loop in ctnetlink_get_conntrack() that can be triggered if you use the same socket to receive events and to perform a GET operation. Under heavy load, netlink_unicast() may return -EAGAIN, this error code is reserved in nfnetlink for the module load-on-demand. Instead, we return -ENOBUFS which is the appropriate error code that has to be propagated to user-space. Reported-by: Holger Eitzenberger <holger@eitzenberger.org> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2011-01-12eth: fix new kernel-doc warningRandy Dunlap
Fix new kernel-doc warning (copy-paste typo): Warning(net/ethernet/eth.c:366): No description found for parameter 'rxqs' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-12Merge branch 'master' of git://1984.lsi.us.es/net-2.6David S. Miller
